  4. Hm-rpc crasht bei Zugriff auf EPaper Display
3 Beiträge 2 Kommentatoren 403 Aufrufe
    dwm
    Servus,
    seit geraumer Zeit liegt auf meinem Schreibtisch ein Homematic E-Paper Display.
    Heut hab ich mal wieder damit rumgespielt, und prompt seltsames festgestellt:
    Wenn ich versuche, auf die Zeilen zuzugreifen (hier: hm-rpc.0.NEQ12345678.0.EPAPER_LINE2) , sprich da neue Texte reinzuschreiben, crasht der hm-rpc Adapter. Im Grunde bei allen Zugriffen auf Lines, Icons, Sound etc.
    Im Log erscheint:
    `2018-12-20 13:33:43.035  - [31merror[39m: hm-rpc.0 already running
    2018-12-20 13:33:43.061  - [31merror[39m: Caught by controller[0]: TypeError: line.substring is not a function
    2018-12-20 13:33:43.061  - [31merror[39m: Caught by controller[0]:     at combineEPaperCommand (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:154:23)
    2018-12-20 13:33:43.061  - [31merror[39m: Caught by controller[0]:     at controlEPaper (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:249:17)
    2018-12-20 13:33:43.061  - [31merror[39m: Caught by controller[0]:     at Socket.adapter.getForeignState (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:353:23)
    2018-12-20 13:33:43.061  - [31merror[39m: Caught by controller[0]:     at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
    2018-12-20 13:33:43.061  - [31merror[39m: Caught by controller[0]:     at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
    2018-12-20 13:33:43.061  - [31merror[39m: Caught by controller[0]:     at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    2018-12-20 13:33:43.061  - [31merror[39m: Caught by controller[0]:     at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    2018-12-20 13:33:43.061  - [31merror[39m: Caught by controller[0]:     at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
    2018-12-20 13:33:43.061  - [31merror[39m: Caught by controller[0]:     at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    2018-12-20 13:33:43.061  - [31merror[39m: Caught by controller[0]:     at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    2018-12-20 13:33:43.061  - [31merror[39m: host.dragon instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
    2018-12-20 13:33:43.061  - [32minfo[39m: host.dragon Restart adapter system.adapter.hm-rpc.0 because enabled
    2018-12-20 13:34:13.082  - [32minfo[39m: host.dragon instance system.adapter.hm-rpc.0 started with pid 8940
    2018-12-20 13:34:13.448  - [32minfo[39m: hm-rpc.0 starting. Version 1.7.8 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v8.11.4
    2018-12-20 13:34:13.751  - [32minfo[39m: hm-rpc.0 binrpc server is trying to listen on 0.0.0.0:2001
    2018-12-20 13:34:13.752  - [32minfo[39m: hm-rpc.0 binrpc client is trying to connect to 10.22.1.15:2001/ with ["xmlrpc_bin://10.22.1.40:2001","hm-rpc.0"]
    2018-12-20 13:34:13.759  - [32minfo[39m: hm-rpc.0 binrpc <- system.listMethods ["hm-rpc.0"]
    2018-12-20 13:34:13.766  - [32minfo[39m: hm-rpc.0 binrpc <- listDevices ["hm-rpc.0"]
    2018-12-20 13:34:13.796  - [32minfo[39m: hm-rpc.0 binrpc -> 544 devices
    2018-12-20 13:34:14.590  - [32minfo[39m: hm-rpc.0 Connected[/code]</anonymous></anonymous>`
    Das ging schon mal ... ich kann grad nicht genau nachvollziehen, mit welcher Version von hm-rpc Adapter und CCU Firmware sich das verabschiedet hat ... Hm.
    Die Tasten-Events werden "normal" verarbeitet, das klappt.
    Grad liegt das Ding wie gesagt nur rum, aber schick wär's schon wenns geht :)
    Kann jemand mal reinschaun?
    CU
    Werner
    • apollon77A Online
      apollon77A Online
      Bitte GitHub Issue anlegen
        dwm
        Done
