  4. [gelöst]Fehler in iobroker.knx
3 Beiträge 2 Kommentatoren 1.1k Aufrufe
  • ruhigundrelaxedR Offline
    ruhigundrelaxed
    ersteinmal ein frohes neues!!
    Ich habe einen seltsamen Fehler und brauche eure Unterstützung.
    Nach einer Neuinstallation bekomme ich o.g. Adapter nicht mehr ans rennen. Er terminiert mit code(1). Ursächlich war wohl die Tatsache, dass er "adapter.js" aufgrund einer fehlerhaften Pfadangabe nicht requiren konnte. Nach manueller korrektur:
    ( "require(__dirname + '/../../lib/adapter.js')" -> require(__dirname + '/../iobroker.js-controller/lib/adapter.js') in knx.js rennt er zwar los, trifft
    allerdings relativ schnell die Wand:
    { Name: 'Rolladen K Move', Address: '0/0/11' }
    { _id: '0/0/11',
      type: 'state',
      common: { name: 'Rolladen K Move' },
      native: {} }
    2016-01-15 13:22:53.408  - error: uncaught exception: Maximum call stack size exceeded
    2016-01-15 13:22:53.420  - error: RangeError: Maximum call stack size exceeded
        at onwriteError (_stream_writable.js:305:22)
        at onwrite (_stream_writable.js:335:5)
        at WritableState.onwrite (_stream_writable.js:105:5)
        at fireErrorCallbacks (net.js:456:13)
        at Socket._destroy (net.js:467:5)
        at Socket._writeGeneric (net.js:658:10)
        at Socket._write (net.js:711:8)
        at doWrite (_stream_writable.js:301:12)
        at writeOrBuffer (_stream_writable.js:288:5)
        at Socket.Writable.write (_stream_writable.js:217:11)
    2016-01-15 13:22:53.725  - error: uncaught exception: Cannot set property 'end' of null
    2016-01-15 13:22:53.730  - error: TypeError: Cannot set property 'end' of null
        at Object.require.unload (/opt/iobroker/node_modules/iobroker.knx/knx.js:52:42)
        at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2768:21)
        at process.g (events.js:199:16)
        at process.emit (events.js:107:17)
        at process.exit (node.js:600:17)
        at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2826:21)
        at Timer.listOnTimeout (timers.js:119:15)
    2016-01-15 13:22:53.743  - error: host.zuhause instance system.adapter.knx.0 terminated with code 0 (OK)
    Ausserdem fällt mir auf, dass der Adapter in Version 0.0.1 installiert wird, obwohl laut iobroker 0.2.10 aktuell ist.
    Fällt irgendjemand was dazu ein?
    Martin
    iobroker auf debian bullseye amd64 (i5-8259U)
    homematic -> homegear -> HM-CFG-LAN ~> 11 x hm-cc-rt-dn | 3 x hm-sec-sd
    knx -> eibd -> SCN‐IP000.01 ~> 4 x AMS-1216.01 | (1 x JAL-0810.01 | 1 x JAL-0410.01) | 2 x BE-16000.01 | …
      ruhigundrelaxed
      Habe ein wenig rumgebastelt und konnte das Problem lösen.
      Falls jemand zufällig das gleiche Problem hat, hier ist meine Lösung.
      1.) Wie schon im Eingangspost erwähnt: ( "require(__dirname + '/../../lib/adapter.js')" -> require(__dirname + '/../iobroker.js-controller/lib/adapter.js') in knx.js
      2.) Im Verzeichniss des Adapters ein: "npm install eibd" absetzen.
      Ich werde mich heute abend mal dransetzen und die defekte gegen die funktionierende Installation vergleichen.
      Ich vermute das der Adapter eine falsche Version von eibd installiert.
      Desweiteren wird wohl die Codebasis von 0.2.10 installiert, aber 0.0.1 angezeigt.
      • V Offline
        V Offline
        versteckt
        Hey super, du nutzt bereits knx?
        Ich habe einen Endkunden der auch knx besitzt und da muss ich demnächst eine ioBroker Installation durchführen.
        Wenn ich Fragen / Probleme habe, darf ich mich an dich wenden?
        LG Christian
        Raspi 1, Raspi 2, iobroker, Mac Mini: alles mit aktueller ioBroker Version
        homegear für Homematic und MAX!
        occ, zWave, rpi, hmm und homekit Entwickler
