  4. Shelly Adapter: Errors im Log
    6.5k
35 Beiträge 16 Kommentatoren 8.7k Aufrufe 10 Beobachtet
  • MDNM Offline
    MDNM Offline
    MDN
    gestern habe ich meinen ersten Shelly Aktor bekommen und wollte den heute in ioBroker aufnehmen.
    Den Aktor habe ich in Betrieb nehmen und über die Shelly App steuern können.
    Den ioBroker Adapter für Shelly konnte ich auch installieren. Allerdings erzeugt er im Log ganz viele Errors, mit denen ich nichts anfangen kann.
    host.iobroker	2018-12-07 13:44:14.496	info	Restart adapter system.adapter.shelly.0 because enabled
    host.iobroker	2018-12-07 13:44:14.496	error	instance system.adapter.shelly.0 terminated with code 0 (OK)
    Caught	2018-12-07 13:44:14.496	error	by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
    Caught	2018-12-07 13:44:14.496	error	by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    Caught	2018-12-07 13:44:14.496	error	by controller[0]: at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
    Caught	2018-12-07 13:44:14.496	error	by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
    Caught	2018-12-07 13:44:14.496	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
    Caught	2018-12-07 13:44:14.496	error	by controller[0]: at Socket.adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.shelly/shelly.js:104:5)
    Caught	2018-12-07 13:44:14.496	error	by controller[0]: at main (/opt/iobroker/node_modules/iobroker.shelly/shelly.js:932:12)
    Caught	2018-12-07 13:44:14.496	error	by controller[0]: at new ShellyIot (/opt/iobroker/node_modules/shelly-iot/index.js:30:27)
    Caught	2018-12-07 13:44:14.495	error	by controller[0]: at new exports.Client (/opt/iobroker/node_modules/node-rest-client/lib/node-rest-client.js:13:61)
    Caught	2018-12-07 13:44:14.495	error	by controller[0]: at module.exports (/opt/iobroker/node_modules/node-rest-client/lib/nrc-serializer-manager.js:122:18)
    Caught	2018-12-07 13:44:14.495	error	by controller[0]: TypeError: xmlserializer.Builder is not a constructor
    shelly.0	2018-12-07 13:44:14.477	warn	Exception: TypeError: xmlserializer.Builder is not a constructor
    shelly.0	2018-12-07 13:44:14.474	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
    shelly.0	2018-12-07 13:44:14.474	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    shelly.0	2018-12-07 13:44:14.474	error	at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
    shelly.0	2018-12-07 13:44:14.474	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
    shelly.0	2018-12-07 13:44:14.474	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
    shelly.0	2018-12-07 13:44:14.474	error	at Socket.adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.shelly/shelly.js:104:5)
    shelly.0	2018-12-07 13:44:14.474	error	at main (/opt/iobroker/node_modules/iobroker.shelly/shelly.js:932:12)
    shelly.0	2018-12-07 13:44:14.474	error	at new ShellyIot (/opt/iobroker/node_modules/shelly-iot/index.js:30:27)
    shelly.0	2018-12-07 13:44:14.474	error	at new exports.Client (/opt/iobroker/node_modules/node-rest-client/lib/node-rest-client.js:13:61)
    shelly.0	2018-12-07 13:44:14.474	error	at module.exports (/opt/iobroker/node_modules/node-rest-client/lib/nrc-serializer-manager.js:122:18)
    shelly.0	2018-12-07 13:44:14.474	error	TypeError: xmlserializer.Builder is not a constructor
    shelly.0	2018-12-07 13:44:14.474	error	uncaught exception: xmlserializer.Builder is not a constructor
    shelly.0	2018-12-07 13:44:14.407	info	starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v6.14.4
    host.iobroker	2018-12-07 13:44:13.607	info	instance system.adapter.shelly.0 started with pid 2166
    host.iobroker	2018-12-07 13:43:43.599	info	Restart adapter system.adapter.shelly.0 because enabled</anonymous></anonymous>
    Im Internet und auch in diesem Forum habe ich nach der Fehlermeldung gesucht, aber keine Antwort gefunden.
    Ich betreibe den ioBroker als Docker auf einem Synology NAS. (https://hub.docker.com/r/buanet/iobroker/)
    Leider sind meine Docker- und Linuxkenntnisse nur sehr gering. Ich kann nur das, was ich in Anleitungen lese oder in Videos sehe. Wenn dann aber Fehler auftreten stehe ich manchmal - so wie diesmal - im Wald. Deswegen: Bin für jede Hilfe dankbar!
    • apollon77A Offline
      Hm … geh mal in das iobroker Verzeichnis und führe aus
      cd node_modules/iobroker.shelly
      npm install xml2js@0.4.19
      geht es danach?
      W D 2 Antworten Letzte Antwort
      • MDNM Offline
        MDNM Offline
        MDN
        Danke für die Antwort!
        Leider besteht der Fehler immer noch. Exakt das gleiche im Log. :(
          hehe … warte mal ...
          such mal in den "node_modules" verzeichnissen wo ein verzeichnis namens "node-rest-client" ist. dann dort das gleiche nochmal ausführen
          M F S 3 Antworten Letzte Antwort
          • MDNM Offline
            MDNM Offline
            MDN
            TOP! Die Errors sind verschwunden!! DANKE! :D
            Jetzt muss nur noch der Shelly gefunden werden.
              Andy18
              Super, vielen Dank für die Lösung. :D
              Ich hatte das gleiche Problem.
                Rayker
                irgendwie bekomme ich das nicht hin ….....:-(
                host.All-In-One_RasPi 2019-01-29 20:09:52.397 error instance system.adapter.shelly.0 terminated with code 0 (OK)
                shelly.0 2019-01-29 20:09:38.772 info Listening for Shelly packets in the network
                shelly.0 2019-01-29 20:09:38.721 info Starting shelly.0 in version 2.0.7
                shelly.0 2019-01-29 20:09:38.597 info starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
                host.All-In-One_RasPi 2019-01-29 20:09:37.261 info instance system.adapter.shelly.0 started with pid 10485
                host.All-In-One_RasPi 2019-01-29 20:09:07.248 info Restart adapter system.adapter.shelly.0 because enabled
                host.All-In-One_RasPi 2019-01-29 20:09:07.248 error instance system.adapter.shelly.0 terminated with code 0 (OK)
                shelly.0 2019-01-29 20:08:53.637 info Listening for Shelly packets in the network
                shelly.0 2019-01-29 20:08:53.591 info Starting shelly.0 in version 2.0.7
                shelly.0 2019-01-29 20:08:53.468 info starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
                host.All-In-One_RasPi 2019-01-29 20:08:52.103 info instance system.adapter.shelly.0 started with pid 10467
                host.All-In-One_RasPi 2019-01-29 20:08:22.093 info Restart adapter system.adapter.shelly.0 because enabled
                host.All-In-One_RasPi 2019-01-29 20:08:22.092 error instance system.adapter.shelly.0 terminated with code 0 (OK)
                shelly.0 2019-01-29 20:08:08.530 info
                  Sodalle
                  Hallo Zusammen,
                  Seit dem letzten Update des Shelly Adapter 2.0.8 habe ich folgende Errors im Log:
                  shelly.0 2019-02-02 19:03:54.356 info Error handling Shelly data: SyntaxError: Unexpected token [ in JSON at position 29 for JSON {"G":[[0,111, 100],[0,112, 0][0,121, 100],[0,122, 1]]}
                  shelly.0 2019-02-02 19:03:39.346 info Error handling Shelly data: SyntaxError: Unexpected token [ in JSON at position 29 for JSON {"G":[[0,111, 100],[0,112, 0][0,121, 100],[0,122, 1]]}
                  shelly.0 2019-02-02 19:03:24.316 info Error handling Shelly data: SyntaxError: Unexpected token [ in JSON at position 29 for JSON {"G":[[0,111, 100],[0,112, 0][0,121, 100],[0,122, 1]]}
                  Ist der Fehler bekannt bzw. an was könnte das liegen?
                  Grüße
                  Sodalle
                  Proxmox und Iobroker auf Zotac ci 327 mit 16GB Arbeitsspeicher
                  Raspi 3 und Iobroker zum Testen
                    Shepherd
                    Muss das Thema nochmals hochholen,
                    so eine ähnliche Meldung habe ich auch, an was kann das liegen?
                    Error handling Shelly data: SyntaxError: Unexpected token [ in JSON at position 64 for JSON {"G":[[0,111, 10],[0,121, 10],[0,131, 10],[0,141, 10],[0,151, 0][0,161, 0][0,171, 0][0,181, 0]]}
                    Dieser Error kommt alle 15 sek.
                    • W Offline
                      W Offline
                      weidlix
                      Ich bekomme danach immer noch den gleichen Fehler
                      • apollon77A apollon77
                        geht es danach?
                        W Offline
                        W Offline
                        weidlix
                        @apollon77
                          maxpd
                          schrieb am zuletzt editiert von maxpd
                          @apollon77 Ich bekomme in dem Fall die Meldung:
                          maxpd
                          Raspi 4 8gb | iobroker + pivccu3 | 46 Adapter | 68 Scripte, 120 Devices
                          • M maxpd
                            @maxpd Lass das audit fix einfach sein. Tuts denn sonst jetzt?
                              maxpd
                              @apollon77:
                              Leider hat dies nicht geholfen. Nein. Der Adapter startet weiterhin ständig neu.
                              maxpd
                              • M maxpd
                                @apollon77:
                                haselchenH Offline
                                haselchenH Offline
                                haselchen
                                @maxpd
                                Vielleicht alles auf den neuesten Stand bringen?
                                Shellys updaten auf 1.6.2
                                Adapter updaten auf 3.2.2 oder 3.2.3
                                Und Nodejs auf Version 10.19
                                JS Controller 2.2.9
                                Admin 4.0.5
                                Hatte die Fehlermeldung auch.
                                Nun nicht mehr.
                                F 1 Antwort Letzte Antwort
                                • haselchenH haselchen
                                  @maxpd
                                  JS Controller 2.2.9
                                  Admin 4.0.5
                                  Nun nicht mehr.
                                  fero87
                                  ich habe leider den gleichen Fehler. Shelly Adapter startet nicht im CoAP Modus (MQTT funktioniert).
                                  Habe versucht, den oben genannten Befehl
                                  auszuführen. Ich finde allerdings das Verzeichnis
                                  gar nicht erst.
                                  pi@raspberrypi4-iobroker:~ $ ls -all
                                  insgesamt 48
                                  drwxr-xr-x 7 pi   pi   4096 Feb 22 15:47 .
                                  drwxr-xr-x 4 root root 4096 Feb 22 15:45 ..
                                  -rw------- 1 pi   pi   1157 Apr  1 00:40 .bash_history
                                  -rw-r--r-- 1 pi   pi    220 Feb 13 16:55 .bash_logout
                                  -rw-r--r-- 1 pi   pi   3633 Feb 22 15:47 .bashrc
                                  drwxr-xr-x 3 pi   pi   4096 Feb 22 15:46 .cache
                                  drwx------ 3 pi   pi   4096 Feb 22 15:44 .config
                                  drwx------ 3 pi   pi   4096 Feb 22 15:27 .gnupg
                                  drwxr-xr-x 2 pi   pi   4096 Feb 22 15:47 .iobroker
                                  drwxr-xr-x 5 pi   pi   4096 Apr  1 00:25 .npm
                                  -rw------- 1 pi   pi     36 Feb 22 15:44 .npmrc
                                  -rw-r--r-- 1 pi   pi    807 Feb 13 16:55 .profile
                                  pi@raspberrypi4-iobroker:~ $ cd .iobroker
                                  pi@raspberrypi4-iobroker:~/.iobroker $ ls -all
                                  insgesamt 12
                                  drwxr-xr-x 7 pi pi 4096 Feb 22 15:47 ..
                                  -rw-r--r-- 1 pi pi  211 Feb 22 15:47 npm_command_fix
                                  Kann mir jemand helfen?
                                  Shelly Firmware: 1.6.2
                                  Shelly Adapter: 3.2.2
                                  Nodejs: 10.19
                                  JS Controller: 2.2.9
                                  Admin: 4.0.5
                                  Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
                                  Hier gehts zur Hilfe.
                                  • F fero87
                                    gar nicht erst.
                                    insgesamt 48
                                    insgesamt 12
                                    Nodejs: 10.19
                                    Admin: 4.0.5
                                    fero87
                                    sorry, zu schnell...
                                    Nodejs: 10.19
                                    Admin: 4.0.5
                                    • F fero87
                                      Nodejs: 10.19
                                      Admin: 4.0.5
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      @fero87
                                      Hast du das Fehlerlog zur Hand?
                                        @fero87
                                        fero87
                                        @haselchen
                                        2020-04-01 09:19:44.123 - info: shelly.0 (11241) starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.shelly, node: v10.16.3
                                        2020-04-01 09:19:44.233 - info: shelly.0 (11241) Starting Shelly adapter in CoAP modus.
                                        2020-04-01 09:19:44.271 - info: host.raspberrypi4-iobroker instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
                                        2020-04-01 09:19:44.271 - info: host.raspberrypi4-iobroker Restart adapter system.adapter.shelly.0 because enabled
                                        2020-04-01 09:20:09.689 - debug: admin.0 (1851) Unsubscribe LOGS
                                        2020-04-01 09:20:09.691 - debug: admin.0 (1851) Subscribes:
                                        2020-04-01 09:20:09.790 - debug: admin.0 (1851) Subscribe OBJECTS: system.adapter.*
                                        2020-04-01 09:20:09.792 - debug: admin.0 (1851) Subscribe STATES: system.adapter.*
                                        2020-04-01 09:20:09.794 - debug: admin.0 (1851) Subscribes: info.0.newsfeed, system.adapter.*
                                        2020-04-01 09:20:09.797 - debug: admin.0 (1851) Subscribe OBJECTS: system.host.*
                                        2020-04-01 09:20:09.799 - debug: admin.0 (1851) Subscribe STATES: system.host.*
                                        2020-04-01 09:20:09.800 - debug: admin.0 (1851) Subscribes: info.0.newsfeed, system.adapter.*, system.host.*
                                        2020-04-01 09:20:09.803 - debug: admin.0 (1851) Subscribe STATES: *.info.connection
                                        2020-04-01 09:20:09.804 - debug: admin.0 (1851) Subscribes: info.0.newsfeed, system.adapter.*, system.host.*, *.info.connection
                                        2020-04-01 09:20:12.238 - debug: admin.0 (1851) Unsubscribe OBJECTS: system.adapter.*
                                        2020-04-01 09:20:12.284 - debug: admin.0 (1851) Unsubscribe STATES: system.host.*
                                        2020-04-01 09:20:12.287 - debug: admin.0 (1851) Subscribes: info.0.newsfeed, system.adapter.*, *.info.connection
                                        2020-04-01 09:20:12.298 - debug: admin.0 (1851) Unsubscribe OBJECTS: system.host.*
                                        2020-04-01 09:20:12.300 - debug: admin.0 (1851) Unsubscribe STATES: system.adapter.*
                                        2020-04-01 09:20:12.305 - debug: admin.0 (1851) Subscribes: info.0.newsfeed, *.info.connection
                                        2020-04-01 09:20:12.309 - debug: admin.0 (1851) Unsubscribe STATES: *.info.connection
                                        2020-04-01 09:20:12.310 - debug: admin.0 (1851) Subscribes: info.0.newsfeed
                                        2020-04-01 09:20:12.467 - debug: admin.0 (1851) Subscribe LOGS
                                        2020-04-01 09:20:12.468 - debug: admin.0 (1851) Subscribes: dummy
                                        2020-04-01 09:20:14.286 - info: host.raspberrypi4-iobroker instance system.adapter.shelly.0 started with pid 11269
                                        2020-04-01 09:20:15.628 - debug: shelly.0 (11269) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        2020-04-01 09:20:15.663 - debug: shelly.0 (11269) Objects client ready ... initialize now
                                        2020-04-01 09:20:15.668 - debug: shelly.0 (11269) Objects create System PubSub Client
                                        2020-04-01 09:20:15.669 - debug: shelly.0 (11269) Objects create User PubSub Client
                                        2020-04-01 09:20:15.670 - debug: shelly.0 (11269) Objects client initialize lua scripts
                                        2020-04-01 09:20:15.682 - debug: shelly.0 (11269) Objects connected to redis: 127.0.0.1:9001
                                        2020-04-01 09:20:15.688 - debug: shelly.0 (11269) objectDB connected
                                        2020-04-01 09:20:15.691 - debug: shelly.0 (11269) Redis States: Use Redis connection: 127.0.0.1:9000
                                        2020-04-01 09:20:15.697 - debug: shelly.0 (11269) States create User PubSub Client
                                        2020-04-01 09:20:15.699 - debug: shelly.0 (11269) States create System PubSub Client
                                        2020-04-01 09:20:15.707 - debug: shelly.0 (11269) States connected to redis: 127.0.0.1:9000
                                        2020-04-01 09:20:15.708 - debug: shelly.0 (11269) statesDB connected
                                        2020-04-01 09:20:16.600 - info: shelly.0 (11269) starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.shelly, node: v10.16.3
                                        2020-04-01 09:20:16.660 - info: shelly.0 (11269) Starting Shelly adapter in CoAP modus.
                                        2020-04-01 09:20:16.712 - info: host.raspberrypi4-iobroker instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
                                        2020-04-01 09:20:16.713 - info: host.raspberrypi4-iobroker Restart adapter system.adapter.shelly.0 because enabled
                                        • F fero87
                                          @haselchen
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          @fero87
                                          Ich bin so der Typ, der erstmal einmal guckt ob es Updates für den Fehler gibt :)
                                          Ich würde den Shelly Adapter auf Version 3.2.3 bringen (über git)
                                          Und Nodejs ist bei Dir 10.16.3 und nicht wie Du geschrieben hast 10.19.
                                          Da würde ich auch ansetzen mit einem Update.
                                          Ohne Gewähr natürlich , ob der Fehler dann weg ist.
