  4. Daten PV Anlage Envertech Wechselrichter
    5.4k
30 Beiträge 12 Kommentatoren 9.8k Aufrufe 6 Beobachtet
  • adcrafter27A Offline
    adcrafter27
    falls nochmal jemand auf dieses Thema in der Zukunft stoßt:
    Web Daten auslesen mit IoBroker
    https://github.com/adcrafter27/ioBroker.envertech-pv
    JackDanielJ 1 Antwort Letzte Antwort
    • adcrafter27A adcrafter27
      JackDanielJ Offline
      JackDanielJ Offline
      JackDaniel
      @adcrafter27
      wird der adapter noch weiter entwickelt?
      Carpe diem
      • JackDanielJ JackDaniel
        @adcrafter27
        mike2712
        @jackdaniel
        bekomme Ihn nicht installiert.
        $ iobroker url https://github.com/adcrafter27/ioBroker.envertech-pv.git --host iobroker --debug
        install adcrafter27/ioBroker.envertech-pv#17e658f9aed59c663da796229b2783f1aaf93c7a
        NPM version: 6.14.14
        npm install adcrafter27/ioBroker.envertech-pv#17e658f9aed59c663da796229b2783f1aaf93c7a --prefix "/opt/iobroker" (System call)
        > node-aead-crypto@2.2.1 preinstall /opt/iobroker/node_modules/node-aead-crypto> node lib/preinstall.js
        node-aead-crypto not needed on this system, since all ciphers are natively supported
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-aead-crypto@2.2.1 (node_modules/node-aead-crypto):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-aead-crypto@2.2.1 preinstall: `node lib/preinstall.js`
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
        + iobroker.envertech-pv@0.0.7updated 1 package in 22.236s
        42 packages are looking for funding run `npm fund` for details
        upload [4] envertech-pv.admin /opt/iobroker/node_modules/iobroker.envertech-pv/admin/words.js words.js application/javascript
        upload [3] envertech-pv.admin /opt/iobroker/node_modules/iobroker.envertech-pv/admin/style.css style.css text/css
        upload [2] envertech-pv.admin /opt/iobroker/node_modules/iobroker.envertech-pv/admin/index_m.html index_m.html text/html
        upload [1] envertech-pv.admin /opt/iobroker/node_modules/iobroker.envertech-pv/admin/envertech.png envertech.png image/png
        upload [0] envertech-pv.admin /opt/iobroker/node_modules/iobroker.envertech-pv/admin/admin.d.ts admin.d.ts video/mp2t
        Process exited with code 0
        Hat jemand eine Idee woran das liegen könnte?
        Lg Mike
        ioBroker im Docker auf Qnap TS-453A 16GB Ram 4-Bay
        • M mike2712
          @jackdaniel
          Lg Mike
          @mike2712 sagte in Daten PV Anlage Envertech Wechselrichter:
          wieso nicht?
          = erfolgreich installiert
          • K Offline
            klassisch
            schrieb am zuletzt editiert von klassisch
            Wurde der Adapter von Github installiert? Dann hilft oftmals der upload button und dann die Instanz per + manuell installieren
            • K klassisch
              mike2712
              Hallo, vielen Dank für die Hilfe.
              Ja irgendwie hatte ich da etwas falsch verstanden,
              nach dem ich den von Github geladen habe war der Adapter lediglich zum installieren verfügbar, ich habe gedacht das es schon die Installation gewesen ist.
              Offensichtlich ist das dann nur die Verfügbarkeit zur Installation des Adapters?
              Aber dann war dieser unter den Adapter sichtbar und lies sich auch ohne Probleme installieren.
              Aber nach dem ersten Installation, wie oben beschrieben ist kein Adapter unter den Instanzen gewesen.
              Lg Mike
              • M mike2712
                Lg Mike
                @mike2712 bitte die Begriffe Installation, Adapter, Instanzen nicht vermischen
                https://www.iobroker.net/#de/documentation/tutorial/adapter.md
                  michael84
                  @jackdaniel
                  Hallo
                  Ich wolte den adapter auch installieren bekomme bei der Installation einen Fehler Medlung
                  C:\iobroker>iobroker url https://github.com/adcrafter27/ioBroker.envertech-pv.git
                  C:\iobroker>node node_modules/iobroker.js-controller/iobroker.js url https://github.com/adcrafter27/ioBroker.envertech-pv.git
                  install adcrafter27/ioBroker.envertech-pv#46284699d12834e862402428e0153f1150a2b307
                  NPM version: 6.14.15
                  npm install adcrafter27/ioBroker.envertech-pv#46284699d12834e862402428e0153f1150a2b307 --loglevel error (System call)
                  npm ERR! code ENOENT
                  npm ERR! syscall spawn git
                  npm ERR! path git
                  npm ERR! errno -4058
                  npm ERR! enoent Error while executing:
                  npm ERR! enoent undefined ls-remote -h -t ssh://git@github.com/adcrafter27/ioBroker.envertech-pv.git
                  npm ERR! enoent
                  npm ERR! enoent
                  npm ERR! enoent spawn git ENOENT
                  npm ERR! enoent This is related to npm not being able to find a file.
                  npm ERR! enoent
                  npm ERR! C:\Users\adminsys\AppData\Roaming\npm-cache_logs\2022-03-23T22_57_17_862Z-debug.log
                  host.SioBroker1 Cannot install adcrafter27/ioBroker.envertech-pv#46284699d12834e862402428e0153f1150a2b307: 4294963238
                  • JackDanielJ Offline
                    JackDanielJ Offline
                    JackDaniel
                    keine ahnung von einem windows system
                    wenn ich etwas aus dem git installieren dann über die "katze"
                    Carpe diem
                    • K Offline
                      klassisch
                      Ich habe Windows und den Adapter gerade probeweise installiert
                      1. Expertenkopf
                      2. Githubs Katzenpolyp
                      3. Tab Benutzerdefiniert
                      4. Url eintragen
                      5. Installieren
                      Der erste Installationsversuch endet mit Error 25.
                      Das ist bei mir aber leider so üblich.
                      Dann einfach nochmals installieren. Wird mit code 0 ok beendet
                      $ iobroker url https://github.com/adcrafter27/ioBroker.envertech-pv.git --host DESKTOPT(ioBrMain036) --debug
                      npm install adcrafter27/ioBroker.envertech-pv#46284699d12834e862402428e0153f1150a2b307 (System call)
                      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                      npm WARN jscs-loader@0.3.0 requires a peer of jscs@^3.0.3 but none is installed. You must install peer dependencies yourself.
                      + iobroker.envertech-pv@0.0.8 added 4 packages from 4 contributors, removed 1 package, moved 2 packages and audited 2798 packages in 84.925s
                      151 packages are looking for funding
                      found 228 vulnerabilities (25 low, 72 moderate, 122 high, 9 critical) run `npm audit fix` to fix them, or `npm audit` for details
                      upload [4] envertech-pv.admin C:/Program Files/iobroker/ioBrMain036/node_modules/iobroker.envertech-pv/admin/words.js words.js application/javascript
                      upload [3] envertech-pv.admin C:/Program Files/iobroker/ioBrMain036/node_modules/iobroker.envertech-pv/admin/style.css style.css text/css
                      upload [2] envertech-pv.admin C:/Program Files/iobroker/ioBrMain036/node_modules/iobroker.envertech-pv/admin/index_m.html index_m.html text/html
                      upload [1] envertech-pv.admin C:/Program Files/iobroker/ioBrMain036/node_modules/iobroker.envertech-pv/admin/envertech.png envertech.png image/png
                      upload [0] envertech-pv.admin C:/Program Files/iobroker/ioBrMain036/node_modules/iobroker.envertech-pv/admin/admin.d.ts admin.d.ts video/mp2t
                      Dann Datenupload drücken. Braucht man bei Spezialinstallation von git
                      Auch das wird mit Code 0 erfolgreich beendet
                      $ iobroker upload envertech-pv
                      Dann noch eine Instanz anlegen mit dem +
                      Auch das geht
                      $ iobroker add envertech-pv auto --host DESKTOP-IT(ioBrMain036)
                      host.DESKTOP-T(ioBrMain036) create instance envertech-pv
                      host.DESKTOP-T(ioBrMain036) object system.adapter.envertech-pv.0.logLevel created
                      host.DESKTOP-T(ioBrMain036) object system.adapter.envertech-pv.0.sigKill created
                      host.DESKTOP-T(ioBrMain036) object system.adapter.envertech-pv.0.eventLoopLag created
                      host.DESKTOP-T(ioBrMain036) object system.adapter.envertech-pv.0.outputCount created
                      host.DESKTOP-T(ioBrMain036) object system.adapter.envertech-pv.0.inputCount created
                      host.DESKTOP-T(ioBrMain036) object system.adapter.envertech-pv.0.uptime created
                      host.DESKTOP-T(ioBrMain036) object system.adapter.envertech-pv.0.memRss created
                      host.DESKTOP-T(ioBrMain036) object system.adapter.envertech-pv.0.memHeapTotal created
                      host.DESKTOPT(ioBrMain036) object system.adapter.envertech-pv.0.memHeapUsed created
                      host.DESKTOP-T(ioBrMain036) object system.adapter.envertech-pv.0.cputime created
                      host.DESKTOP-E(ioBrMain036) object system.adapter.envertech-pv.0.cpu created
                      host.DESKTOP-T(ioBrMain036) object system.adapter.envertech-pv.0.compactMode created
                      host.DESKTOP-T(ioBrMain036) object system.adapter.envertech-pv.0.connected created
                      host.DESKTOP-(ioBrMain036) object system.adapter.envertech-pv.0.alive created
                      host.DESKTOP-T(ioBrMain036) object system.adapter.envertech-pv.0 created
                      Und die Instanz ist da
                      Weiter komme ich nicht, habe keinen Envertech.
                      Aber gezeigt, daß es auch unter Win installierbar ist.
                      Github Installationen sind umfangreicher, einige manuelle Schritte
