  4. [Gelöst] Fehler bei Installation von Java/Blockly
1 Beiträge 1 Kommentatoren 461 Aufrufe
    DJ-Mix
    ich erhalte folgende Fehlermeldung beim installieren von Blockly.
    Da ich Anfänger bin, bin ich ratlos.
    ` > $ ./iobroker add javascript
    NPM version: 4.6.1
    npm install iobroker.javascript –production --save --prefix "/opt/iobroker" (System call)
    npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
    npm
    ERR! path /root/.npm/_logsnpm ERR! code EACCES
    npm ERR! errno -13
    npm ERR! syscall scandir
    npm ERR! Error: EACCES: permission denied, scandir '/root/.npm/_logs'npm ERR! { Error: EACCES: permission denied, scandir '/root/.npm/_logs'
    npm ERR! errno: -13,
    npm ERR! code: 'EACCES',
    npm ERR! syscall: 'scandir',
    npm ERR! path: '/root/.npm/_logs' }
    npm ERR!
    npm
    ERR! Please try running this command again as root/Administrator.
    glob error { Error: EACCES: permission denied, scandir '/root/.npm/_logs' errno: -13,
    code: 'EACCES',
    syscall: 'scandir',
    npm ERR! path /root/.npm/long-timeout/0.1.1/packagenpm ERR! code EACCES
    npm ERR! errno -13
    npm
    ERR! syscall mkdirnpm ERR! Error: EACCES: permission denied, mkdir '/root/.npm/long-timeout/0.1.1/package'
    npm ERR! { Error: EACCES: permission denied, mkdir '/root/.npm/long-timeout/0.1.1/package'
    npm ERR! syscall: 'mkdir',
    npm ERR! path: '/root/.npm/long-timeout/0.1.1/package',
    npm ERR! parent: 'node-schedule' }
    npm ERR!
    npm ERR! Please try running this command again as root/Administrator.
    │ npm update check failed │
    │ Try running with sudo or get access │
    │ to the local update config store via │
    │ sudo chown -R $USER:$(id -gn $USER) /root/.config │
    npm
    ERR! code ELIFECYCLE
    npm ERR! errno 243
    npm ERR! iobroker.javascript@4.0.1 postinstall: node ./install/installTypings.jsnpm ERR! Exit status 243
    npm ERR! npm ERR! Failed at the iobroker.javascript@4.0.1 postinstall script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2018-12-03T19_28_53_634Z-debug.log
    ERROR: host.raspberrypi Cannot install iobroker.javascript: 243
    ERROR: process exited with code 25 `
    Was kann ich hier tun, damit es funktioniert.
    Vielen Dank Vorab
    VG
    DJ-Mix
    Edit: Problem gelöst mit Anleitung hier im Forum (Java Beitrag).
    Nun habe ich jedoch das Problem, dass wenn ich ein Send To Objekt hinzufügen möchte erst die Cloud beenden muss, da es sonst
    nicht auswählbar ist???
