  4. JS Adapter defekt
JS Adapter defekt
4 Beiträge 2 Kommentatoren 607 Aufrufe
    miwe1974
    nach dem Neustart hat sich offenbar der JS Adapter verabschiedet.
    Wie bekomme ich das wieder heile?
    Dankeschön
    LOG:
    oker 2018-12-02 11:44:48.479 warn startInstance cannot find adapter "javascript". Try to install it… 2 attempt
    host.iobroker 2018-12-02 11:44:47.458 info iobroker exit 0
    host.iobroker 2018-12-02 11:44:47.443 error iobroker Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
    host.iobroker 2018-12-02 11:44:47.392 error iobroker host.iobroker Adapter directory "null" does not exists
    host.iobroker 2018-12-02 11:44:47.362 info iobroker npm ERR! npm ERR! Additional logging details can be found in: npm ERR! /npm-debug.log npm ERR! not ok code 0
    host.iobroker 2018-12-02 11:44:47.337 info iobroker npm ERR! code E405
    host.iobroker 2018-12-02 11:44:47.337 info iobroker /npm ERR! node -v v8.11.1 npm ERR! npm -v 1.4.21
    host.iobroker 2018-12-02 11:44:47.336 info iobroker npm ERR! System Linux 4.14.79-v7+ npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.javascript" "--production" "--save" "--prefix" "/opt/iobroker" npm ERR! cwd
    host.iobroker 2018-12-02 11:44:47.325 info iobroker npm ERR! If you need help, you may report this entire log,npm ERR! including the npm and node versions, at: npm ERR! <http://github.com/npm/npm/issues>
    host.iobroker 2018-12-02 11:44:47.323 info iobroker npm ERR! Error: Method Not Allowednpm ERR! at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10) npm ERR! at /usr/share/npm/lib/cache/add-named.js:203:12 npm ERR! at sav
    host.iobroker 2018-12-02 11:44:41.837 info iobroker npm WARN package.json xmlhttprequest-ssl@1.5.3 No license field.npm WARN package.json window-size@0.1.0 No license field.
    host.iobroker 2018-12-02 11:44:41.764 info iobroker npm WARN package.json wake_on_lan@0.0.4 No license field.
    host.iobroker 2018-12-02 11:44:41.718 info iobroker WARN package.json utile@0.3.0 No license field.
    host.iobroker 2018-12-02 11:44:41.714 info iobroker npm
    host.iobroker 2018-12-02 11:44:41.692 info iobroker WARN package.json unix-dgram@0.2.3 license should be a valid SPDX license expression
    host.iobroker 2018-12-02 11:44:41.687 info iobroker npm
    host.iobroker 2018-12-02 11:44:41.652 info iobroker package.json traits@0.4.0 No license field.
    host.iobroker 2018-12-02 11:44:41.652 info iobroker npm WARN
    host.iobroker 2018-12-02 11:44:41.652 info iobroker WARN package.json traits@0.4.0 No repository field.
    host.iobroker 2018-12-02 11:44:41.652 info iobroker WARN package.json traits@0.4.0 No descriptionnpm
    host.iobroker 2018-12-02 11:44:41.648 info iobroker npm
    host.iobroker 2018-12-02 11:44:41.619 info iobroker npm WARN package.json tr-O64@0.2.4 license should be a valid SPDX license expression
    host.iobroker 2018-12-02 11:44:41.602 info iobroker npm WARN package.json suncalc@1.8.0 No license field.npm WARN package.json to-array@0.1.4 No license field.
    host.iobroker 2018-12-02 11:44:41.571 info iobroker npm WARN package.json string_decoder@0.10.31 string_decoder is also the name of a node core module.
    host.iobroker 2018-12-02 11:44:41.562 info iobroker WARN package.json streamsearch@0.1.2 No license field.
    host.iobroker 2018-12-02 11:44:41.561 info iobroker npm
    host.iobroker 2018-12-02 11:44:41.531 info iobroker WARN package.json source-map@0.2.0 No license field.
    host.iobroker 2018-12-02 11:44:41.530 info iobroker npm
    host.iobroker 2018-12-02 11:44:41.455 info iobroker WARN package.json semaphore@1.0.5 No license field.
    host.iobroker 2018-12-02 11:44:41.454 info iobroker npm
    host.iobroker 2018-12-02 11:44:41.430 info iobroker WARN package.json revalidator@0.1.8 license should be a valid SPDX license expression
    host.iobroker 2018-12-02 11:44:41.429 info iobroker npm
    host.iobroker 2018-12-02 11:44:41.353 info iobroker WARN package.json q@1.4.1 license should be a valid SPDX license expression
    host.iobroker 2018-12-02 11:44:41.352 info iobroker npm
    host.iobroker 2018-12-02 11:44:41.343 info iobroker WARN package.json punycode@1.4.1 punycode is also the name of a node core module.
    host.iobroker 2018-12-02 11:44:41.340 info iobroker npm
    host.iobroker 2018-12-02 11:44:41.293 info iobroker WARN package.json prelude-ls@1.1.2 No license field.
    host.iobroker 2018-12-02 11:44:41.286 info iobroker npm
    host.iobroker 2018-12-02 11:44:41.274 info iobroker WARN package.json pkijs@1.3.33 No license field.
    host.iobroker 2018-12-02 11:44:41.268 info iobroker npm
    host.iobroker 2018-12-02 11:44:41.248 info iobroker WARN package.json pause@0.0.1 No license field.
    host.iobroker 2018-12-02 11:44:41.247 info iobroker WARN package.json pause@0.0.1 No repository field.npm
    host.iobroker 2018-12-02 11:44:41.246 info iobroker npm
    host.iobroker 2018-12-02 11:44:41.202 info iobroker passport-strategy@1.0.0 No license field.
    host.iobroker 2018-12-02 11:44:41.202 info iobroker package.json
    host.iobroker 2018-12-02 11:44:41.200 info iobroker WARN
    host.iobroker 2018-12-02 11:44:41.194 info iobroker npm
    host.iobroker 2018-12-02 11:44:41.190 info iobroker passport-local@1.0.0 No license field.
    host.iobroker 2018-12-02 11:44:41.190 info iobroker package.json
    host.iobroker 2018-12-02 11:44:41.189 info iobroker WARN
    host.iobroker 2018-12-02 11:44:41.187 info iobroker npm
    host.iobroker 2018-12-02 11:44:41.113 info iobroker WARN package.json optimist@0.6.1 license should be a valid SPDX license expression
    host.iobroker 2018-12-02 11:44:41.112 info iobroker npm
    host.iobroker 2018-12-02 11:44:41.072 info iobroker npm WARN package.json options@0.0.6 No license field.
    host.iobroker 2018-12-02 11:44:41.067 info iobroker WARN package.json object-component@0.0.3 No license field.
    host.iobroker 2018-12-02 11:44:41.067 info iobroker WARN package.json object-component@0.0.3 No repository field.npm
    host.iobroker 2018-12-02 11:44:41.066 info iobroker npm
    host.iobroker 2018-12-02 11:44:40.957 info iobroker npm WARN package.json ms@0.7.1 No license field.
    host.iobroker 2018-12-02 11:44:40.886 info iobroker WARN package.json longest@1.0.1 license should be a valid SPDX license expression
    host.iobroker 2018-12-02 11:44:40.885 info iobroker npm
    host.iobroker 2018-12-02 11:44:40.644 info iobroker json3@3.3.2 No license field.
    host.iobroker 2018-12-02 11:44:40.644 info iobroker package.json
    host.iobroker 2018-12-02 11:44:40.643 info iobroker
    host.iobroker 2018-12-02 11:44:40.643 info iobroker WARN
    host.iobroker 2018-12-02 11:44:40.642 info iobroker npm
    host.iobroker 2018-12-02 11:44:40.627 info iobroker json-schema@0.2.3 No license field.
    host.iobroker 2018-12-02 11:44:40.627 info iobroker WARN package.json
    host.iobroker 2018-12-02 11:44:40.626 info iobroker npm
    host.iobroker 2018-12-02 11:44:40.487 info iobroker WARN package.json iobroker.vis-fancyswitch@1.1.0 license should be a valid SPDX license expression
    host.iobroker 2018-12-02 11:44:40.486 info iobroker npm
    host.iobroker 2018-12-02 11:44:40.467 info iobroker WARN package.json iobroker.hue@1.1.0 license should be a valid SPDX license expression
    host.iobroker 2018-12-02 11:44:40.466 info iobroker npm
    host.iobroker 2018-12-02 11:44:40.374 info iobroker WARN package.json i@0.3.6 No license field.
    host.iobroker 2018-12-02 11:44:40.373 info iobroker npm
    host.iobroker 2018-12-02 11:44:40.365 info iobroker package.json indexof@0.0.1 No license field.
    host.iobroker 2018-12-02 11:44:40.364 info iobroker indexof@0.0.1 No repository field.npm WARN
    host.iobroker 2018-12-02 11:44:40.350 info iobroker package.json
    host.iobroker 2018-12-02 11:44:40.349 info iobroker WARN
    host.iobroker 2018-12-02 11:44:40.348 info iobroker npm
    host.iobroker 2018-12-02 11:44:40.271 info iobroker has-binary@0.1.7 No repository field.
    host.iobroker 2018-12-02 11:44:40.271 info iobroker package.json
    host.iobroker 2018-12-02 11:44:40.270 info iobroker WARN
    host.iobroker 2018-12-02 11:44:40.269 info iobroker npm
    host.iobroker 2018-12-02 11:44:40.236 info iobroker package.json glossy@0.1.7 No license field.
    host.iobroker 2018-12-02 11:44:40.234 info iobroker
    host.iobroker 2018-12-02 11:44:40.233 info iobroker WARN
    host.iobroker 2018-12-02 11:44:40.232 info iobroker npm
    host.iobroker 2018-12-02 11:44:40.121 info iobroker npm WARN package.json eyes@0.1.8 No license field.
    host.iobroker 2018-12-02 11:44:40.120 info iobroker npm WARN package.json eyes@0.1.8 No repository field.
    host.iobroker 2018-12-02 11:44:40.109 info iobroker npm WARN package.json estraverse@1.9.3 No license field.
    host.iobroker 2018-12-02 11:44:40.103 info iobroker npm WARN package.json esutils@2.0.2 No license field.
    host.iobroker 2018-12-02 11:44:40.033 info iobroker npm WARN package.json dicer@0.2.5 No license field.
    host.iobroker 2018-12-02 11:44:40.027 info iobroker npm WARN package.json dgram@1.0.1 dgram is also the name of a node core module.
    host.iobroker 2018-12-02 11:44:40.003 info iobroker npm WARN package.json deep-is@0.1.3 license should be a valid SPDX license expression
    host.iobroker 2018-12-02 11:44:39.951 info iobroker npm WARN package.json daemonize2@0.4.2 No repository field.npm WARN package.json daemonize2@0.4.2 No license field.
    host.iobroker 2018-12-02 11:44:39.947 info iobroker npm WARN package.json cycle@1.0.3 No license field.
    host.iobroker 2018-12-02 11:44:39.919 info iobroker npm WARN package.json connect-flash@0.1.1 No license field.
    host.iobroker 2018-12-02 11:44:39.889 info iobroker npm WARN package.json component-inherit@0.0.3 No license field.
    host.iobroker 2018-12-02 11:44:39.877 info iobroker npm WARN package.json component-bind@1.0.0 No license field.
    host.iobroker 2018-12-02 11:44:39.840 info iobroker npm WARN package.json callsite@1.0.0 No license field.
    host.iobroker 2018-12-02 11:44:39.839 info iobroker npm WARN package.json callsite@1.0.0 No repository field.
    host.iobroker 2018-12-02 11:44:39.831 info iobroker npm WARN package.json busboy@0.2.14 No license field.
    host.iobroker 2018-12-02 11:44:39.807 info iobroker npm WARN package.json browser-request@0.3.3 No license field.
    host.iobroker 2018-12-02 11:44:39.790 info iobroker npm WARN package.json blob@0.0.4 No license field.
    host.iobroker 2018-12-02 11:44:39.779 info iobroker npm WARN package.json better-assert@1.0.2 No license field.
    host.iobroker 2018-12-02 11:44:39.770 info iobroker npm WARN package.json bcrypt-pbkdf@1.0.1 No repository field.
    host.iobroker 2018-12-02 11:44:39.767 info iobroker npm WARN package.json base64-arraybuffer@0.1.5 No license field.
    host.iobroker 2018-12-02 11:44:39.745 info iobroker npm WARN package.json asn1js@1.2.12 No license field.
    host.iobroker 2018-12-02 11:44:39.738 info iobroker npm WARN package.json arraybuffer.slice@0.0.6 No license field.
    host.iobroker 2018-12-02 11:44:39.677 info iobroker WARN package.json ansi-wrap@0.1.0 license should be a valid SPDX license expression
    host.iobroker 2018-12-02 11:44:39.675 info iobroker npm
    host.iobroker 2018-12-02 11:44:38.898 info instance system.adapter.vis.0 terminated while should be started once
    vis.0 2018-12-02 11:44:37.092 info vis license is OK.
    host.iobroker 2018-12-02 11:44:34.727 info iobroker (node:1115) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
    host.iobroker 2018-12-02 11:44:31.699 info iobroker npm install iobroker.javascript –production --save --prefix "/opt/iobroker" (System call)
    vis.0 2018-12-02 11:44:28.901 info starting. Version 1.1.8 in /opt/iobroker/node_modules/iobroker.vis, node: v8.11.1
    host.iobroker 2018-12-02 11:44:28.638 info iobroker NPM version: 1.4.21
    host.iobroker 2018-12-02 11:44:28.632 error iobroker (node:1092) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
    host.iobroker 2018-12-02 11:44:20.911 info iobroker install javascript
    host.iobroker 2018-12-02 11:44:20.910 warn startInstance cannot find adapter "javascript". Try to install it… 1 attempt
    • apollon77A Online
      apollon77A Online
      npm 1.4.21 ?! Ääähm .da ist was mit deiner installation im system komisch!! bitte node und npm prüfen und ggf fixen
        miwe1974
        Sorry für die blöde Frage:
        Aber wie fixe ich node und npm?
          miwe1974
          Moin,
          sodele - NPM hat nun Version 6.4.1 - JS Adapter läuft wieder.
          Eine Fehlermeldung folgt noch:
          javascript.0 2018-12-02 11:36:32.330 error : message handler implemented, but messagebox not enabled. Define common.messagebox in io-package.json for adapter or delete message handler.
          Node.JS hat die V8.11.1 - ist das korrekt oder habe ich hier auch die falsche Version am Start?
