  4. Npm update
Npm update
6 Beiträge 3 Kommentatoren 2.8k Aufrufe
    mimquadrat
    hi jungs,
    ich glaub ich war mal wieder zu mutig. Wollte den node-red Adapter installieren, da war ein Fehler mit irgendwas NPM ist nicht das richtige…..
    Daraufhin habe ich das hier gemacht:
    sudo npm install npm -g
    von hier:
    https://docs.npmjs.com/getting-started/installing-node
    das hier ist im Log:
    ` > $ ./iobroker add zwave
    npm install iobroker.zwave –production --prefix "/opt/iobroker" (System call)
    npm
    WARN lifecycle openzwave-shared@1.1.6~preinstall: cannot run in wd %s %s (wd=%s) openzwave-shared@1.1.6 node lib/install-ozw.js /opt/iobroker/node_modules/.staging/openzwave-shared-8e400646
    gyp: Call to 'PKG_CONFIG_PATH= pkg-config --variable=libdir libopenzwave' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp
    ERR!
    configure error
    gyp
    ERR!
    stack
    Error: gyp failed with exit code: 1
    gyp
    ERR! stack
    at ChildProcess.onCpExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:305:16)gyp
    ERR! stack
    at ChildProcess.emit (events.js:110:17)gyp
    ERR! stack
    at Process.ChildProcess._handle.onexit (child_process.js:1074:12)
    gyp ERR!
    System Linux 4.1.7-v7+gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/openzwave-shared
    gyp ERR! node -v v0.12.6
    gyp ERR! node-gyp -v v3.2.1
    gyp ERR! not ok
    npm
    WARN enoent ENOENT, open '/opt/iobroker/package.json'
    npm WARN mongodb-core@1.2.28 requires a peer of kerberos@~0.0 but none was installed.
    npm WARN iobroker No description
    npm WARN iobroker No repository field.
    npm WARN iobroker No README data
    npm WARN iobroker No license field.
    npm
    ERR! Linux 4.1.7-v7+npm ERR! argv "node" "/usr/local/bin/npm" "install" "iobroker.zwave" "--production" "--prefix" "/opt/iobroker"
    npm ERR! node v0.12.6
    npm ERR! npm v3.5.2npm ERR! code ELIFECYCLE
    npm
    ERR! openzwave-shared@1.1.6 install: node-gyp rebuildnpm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the openzwave-shared@1.1.6 install script 'node-gyp rebuild'.
    npm ERR! Make sure you have the latest version of node.js and npm installed.
    npm ERR! If you do, this is most likely a problem with the openzwave-shared package,
    npm ERR!
    not with npm itself.npm ERR! Tell the author that this fails on your system:
    npm ERR! node-gyp rebuild
    npm ERR! You can get information on how to open an issue for this project with:
    npm
    ERR!
    npm bugs openzwave-sharednpm ERR! Or if that isn't available, you can get their info via:
    npm ERR! npm owner ls openzwave-shared
    npm
    ERR! There is likely additional logging output above.
    npm ERR! Please include the following file with any support request:
    npm ERR! /npm-debug.log
    ERROR: host.raspberrypi Cannot install iobroker.zwave: 1
    ERROR: process exited with code 25 `
    was soll ich machen!?
    • BluefoxB Offline
      BluefoxB Offline
      @mimquadrat:
      hi jungs,
      von hier:
      npm
      gyp
      ERR!
      configure error
      gyp
      ERR!
      stack
      gyp
      ERR! stack
      ERR! stack
      ERR! stack
      gyp ERR!
      gyp ERR! not ok
      npm
      npm
      npm
      npm ERR!
      npm ERR!
      npm
      ERR!
      npm
      was soll ich machen!? `
      Was passiert?
      cd /opt/iobroker
      sudo npm install iobroker.zwave
      • V Offline
        V Offline
        versteckt
        Wart mit zwave, morgen bzw. übermorgen gibt es eine neue Version inkl. Dokumentation.
        Gesendet von meinem iPhone mit Tapatalk
        9364_iobroker.2018-11-12.log
        Raspi 1, Raspi 2, iobroker, Mac Mini: alles mit aktueller ioBroker Version
        homegear für Homematic und MAX!
        occ, zWave, rpi, hmm und homekit Entwickler
          mimquadrat
          ich hab stattdessen mit dem Wolf Adapter probiert:
          ` > root@raspberrypi:/opt/iobroker# sudo npm install iobroker.wolf
          /opt/iobroker
          ├── iobroker.icons-addictive-flavour-png@0.1.0
          └── iobroker.wolf@0.1.0
          npm WARN enoent ENOENT, open '/opt/iobroker/package.json'
          npm WARN iobroker No license field. `
          2858_iobroker.2018-11-14_-kopie__3.log
          • BluefoxB Offline
            BluefoxB Offline
            @mimquadrat:
            /opt/iobroker
            Hat doch geklappt. Nur Warnungen
              mimquadrat
              leider ist der Adapter aber unter Instanzen nicht sichtbar
