  4. IOBroker Anbindung an einen Kostal Plenticore
1.3k Beiträge 83 Kommentatoren 562.8k Aufrufe 72 Beobachtet
  • DiginixD Diginix
    @StrathCole 2.0.1.7 stürzt ebenso ab:
    2020-03-20 09:00:19.268 - info: plenticore.0 (4530) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.plenticore, node: v10.19.0
    2020-03-20 09:00:19.317 - info: plenticore.0 (4530) [START] Starting adapter plenticore v2.1.0.7
    2020-03-20 09:00:19.335 - debug: plenticore.0 (4530) Panel tilt: 23°
    2020-03-20 09:00:19.335 - debug: plenticore.0 (4530) Panel direction: 180°
    2020-03-20 09:00:19.336 - debug: plenticore.0 (4530) Panel efficiency: 19.3%
    2020-03-20 09:00:19.336 - debug: plenticore.0 (4530) Panel surface: 39m²
    2020-03-20 09:00:22.368 - info: plenticore.0 (4530) got weather data from met.no with 229 elements.
    2020-03-20 09:02:58.471 - error: host.BT3-PRO Caught by controller[0]: FATAL ERROR: invalid array length Allocation failed - JavaScript heap out of memory
    2020-03-20 09:02:58.472 - error: host.BT3-PRO Caught by controller[0]: 1: 0x8fa090 node::Abort() [io.plenticore.0]
    2020-03-20 09:02:58.473 - error: host.BT3-PRO Caught by controller[0]: 2: 0x8fa0dc [io.plenticore.0]
    2020-03-20 09:02:58.473 - error: host.BT3-PRO Caught by controller[1]: 3: 0xb0052e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.plenticore.0]
    2020-03-20 09:02:58.473 - error: host.BT3-PRO Caught by controller[2]: 4: 0xb00764 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.plenticore.0]
    2020-03-20 09:02:58.473 - error: host.BT3-PRO Caught by controller[3]: 5: 0xef4c72 [io.plenticore.0]
    2020-03-20 09:02:58.473 - error: host.BT3-PRO Caught by controller[4]: 6: 0xecc7b9 [io.plenticore.0]
    2020-03-20 09:02:58.474 - error: host.BT3-PRO Caught by controller[5]: 7: 0xece53d v8::internal::Factory::NewFixedDoubleArray(int, v8::internal::PretenureFlag) [io.plenticore.0]
    2020-03-20 09:02:58.474 - error: host.BT3-PRO Caught by controller[6]: 8: 0xe7c8ff [io.plenticore.0]
    2020-03-20 09:02:58.474 - error: host.BT3-PRO Caught by controller[6]: 9: 0x1127ded v8::internal::Runtime_GrowArrayElements(int, v8::internal::Object**, v8::internal::Isolate*) [io.plenticore.0]
    2020-03-20 09:02:58.474 - error: host.BT3-PRO Caught by controller[6]: 10: 0x33b7e975be1d
    2020-03-20 09:02:58.474 - warn: host.BT3-PRO instance system.adapter.plenticore.0 terminated due to SIGABRT
    StrathColeS Offline
    StrathColeS Offline
    StrathCole
    #441
    @Diginix ich versuche gerade herauszufinden, an welcher Stelle genau er abstürzt. Mich irritiert, dass nach dem "met.no" keine weiteren Meldungen kommen. Eigentlich müssten da im Debug-Modus viel mehr kommen. Ich teste ein paar Dinge und gebe Bescheid, wenn du noch mal aktualisieren kannst.
    SolarWatt-Anlage mit 9,6 kWp – KOSTAL Plenticore Plus 10 – BYD B-Box HV 8,96 – Viessmann Vitocal 333g – Zehnder ComfoD 350 (Comfoair 350) mit RS232-Ethernet-Konverter
    • DiginixD Offline
      DiginixD Offline
      Diginix
      schrieb am zuletzt editiert von Diginix
      #442
      Stehe in den Startlöchern, aber kein Stress! ;-)
      Loglevel Debug ist dauerhaft aktiv für deinen Adapter.
      ..:: So long! Tom ::..
      StrathColeS 1 Antwort Letzte Antwort
      • DiginixD Diginix
        StrathColeS Offline
        StrathColeS Offline
        StrathCole
        #443
        @Diginix so. Bitte einmal aus dem git laden. Ich habe mal met.no auskommentiert. Wird jetzt sicher Warnungen oder Fehler werfen, aber so sehe ich, ob es ggf. daran liegt.
        • StrathColeS StrathCole
          DiginixD Offline
          DiginixD Offline
          Diginix
          #444
          @StrathCole Läuft wieder!
          • DiginixD Diginix
            StrathColeS Offline
            StrathColeS Offline
            StrathCole
            #445
            @Diginix Nicht gut.
              tp1de
              #446
              @StrathCole bei mir auch
                tp1de
                #447
                @StrathCole
                habe jetzt aber folgende Meldungen:
                plenticore.0	2020-03-20 09:24:09.969	warn	(14408) Could not read weatherunderground.0.forecastHourly.4h.sky. It returned null state.
                plenticore.0	2020-03-20 09:24:09.968	warn	(14408) Could not read weatherunderground.0.forecastHourly.3h.sky. It returned null state.
                plenticore.0	2020-03-20 09:24:09.922	warn	(14408) Could not read weatherunderground.0.forecastHourly.2h.sky. It returned null state.
                plenticore.0	2020-03-20 09:24:09.919	warn	(14408) Could not read weatherunderground.0.forecastHourly.1h.sky. It returned null state.
                • T tp1de
                  @StrathCole
                  StrathColeS Offline
                  StrathColeS Offline
                  StrathCole
                  #448
                  @tom57 Danach schaue ich dann, wenn ich den anderen Fehler gefunden habe. Das ist echt ein seltsames Phänomen.
                  • StrathColeS Offline
                    StrathColeS Offline
                    StrathCole
                    #449
                    So, hab eine neue Version im Git. Ich hoffe, damit geht es auch trotz metno.
                      tp1de
                      #450
                      @StrathCole sagte in IOBroker Anbindung an einen Kostal Plenticore:
                      Ja scheint zu funktionieren ... auch die WU-Meldungen sind weg. Werde ich jetzt mal beobachten.
                      • T tp1de
                        StrathColeS Offline
                        StrathColeS Offline
                        StrathCole
                        #451
                        @tom57 Ähm … auch keine [warn] Meldung?
                        • DiginixD Offline
                          DiginixD Offline
                          Diginix
                          #452
                          Ich bekomme mit 2.0.1.9 zumindest diese bzgl met.no
                          2020-03-20 09:57:56.350	warn	(11834) Met.no got more than 10 entries in from/to entry. This is bad. Stopping.
                          • DiginixD Diginix
                            StrathColeS Offline
                            StrathColeS Offline
                            StrathCole
                            #453
                            @Diginix Danke, genau das habe ich erwartet. Kannst du mir die debug Meldungen, die davor und danach kommen, noch mitteilen? Das scheint nämlich genau der Punkt zu sein, an dem der Adapter bei euch abgestürzt ist und bei mir nicht.
                              DiginixD Offline
                              DiginixD Offline
                              Diginix
                              #454
                              @StrathCole
                              Da musst du dich mal durchkämpfen:
                              Ach hab das vor 3 Stunden schon gepostet aber das Log war zu lang und der Post wurde gar nicht gesendet.
                              Also hier mal das Log in meiner Dropbox:
                              https://www.dropbox.com/s/w8wouypxj3hi20b/2020-03-19_plenticore.log?dl=0
                              • DiginixD Diginix
                                @StrathCole
                                StrathColeS Offline
                                StrathColeS Offline
                                StrathCole
                                #455
                                @Diginix Danke sehr. Das genügt mir schon. So etwas hatte ich mir gedacht. Du kannst das Log wieder löschen. Ich denke, mit der neuesten Version ist das Problem behoben.
                                  DiginixD Offline
                                  DiginixD Offline
                                  Diginix
                                  #456
                                  @StrathCole Ok, hab die neue von GIT installiert.
                                    tp1de
                                    #457
                                    @Diginix @StrathCole
                                    Bei mir kommt auch mit der neuen Version noch die Meldung:
                                    plenticore.0	2020-03-20 14:30:31.114	warn	(19507) Met.no got more than 10 entries in from/to entry. This is bad. Stopping.
                                    • T tp1de
                                      DiginixD Offline
                                      DiginixD Offline
                                      Diginix
                                      #458
                                      @tom57 Ist bei mir auch so, aber ich vermute dass es @StrathCole ja dann intern zu handeln weiß.
                                        StrathColeS Offline
                                        StrathCole
                                        #459
                                        @tom57 @Diginix das wird in der nächsten Version verschwinden. Ich habe den Grund für das Problem gefunden.
                                        Für alle, die ein bisschen Javascript können oder Programmierung mögen:
                                        toTime
                                        -> Date Sun Mar 29 2020 03:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
                                         toTime.setHours(toTime.getHours()-1)
                                        toTime
                                        Das Problem war, dass eure Server in deutscher Zeit laufen und er bei Zeitberechnungen da ein Problem kriegt (3 Uhr am 29.3. minus eine Stunde ist wieder 3 Uhr am 29.3.) und in eine Endlosschleife läuft. Darum trat es jetzt auch plötzlich auf, weil die Wetterdaten jetzt bis zu dem Datum gingen.
                                        Ich muss stattdessen komplett in UTC Zeitzone rechnen, also:
                                        toTime
                                         toTime.setUTCHours(toTime.getUTCHours()-1)
                                        toTime
                                        -> Date Sun Mar 29 2020 01:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
                                        Damit verschwindet dann auch diese Warnmeldung.
                                          toTime
                                          toTime
                                          toTime
                                          toTime
                                          tp1de
                                          schrieb am zuletzt editiert von tp1de
                                          #460
                                          @StrathCole Danke für die Info.
                                          @Diginix
                                          Ich war übrigens erstaunt, dass seit gestern Abend der WU-Adapter mit Koordinaten auf einmal keine Daten und Fehlermeldungen produzierte. Warum auch immer so plötzlich. Der Plenticore Adapter bekam dann Null-Werte und produzierte Fehler.
                                          Nach Eingabe des Ortsnamens geht der WU-Adapter dann wieder. Hattet Ihr das auch?
                                          StrathColeS 2 Antworten Letzte Antwort
