  4. [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere)
547 Beiträge 97 Kommentatoren 209.6k Aufrufe 20 Beobachtet
  • apollon77A Offline
    #61
    Cool, Danke, übernehme ich noch!
    • ElzersharkE Offline
      ElzersharkE Offline
      Elzershark
      #62
      Rolladen Zeitschaltuhr Jalousien Schalter = https://amzn.to/2DaecSr
      Alle die so aussehen, funktionieren
      Geräte IP= IP=192.168.178.34
      0 = ? keine Funktion (kein Fehler)
      1 = auf
      2 = zu
      3 = pause/stopp
      Neues Shema:
      2018-11-07 23:54:03.483 - info: host.Elzershark object change system.adapter.tuya.0
      2018-11-07 23:54:03.513 - info: host.Elzershark instance system.adapter.tuya.0 started with pid 10356
      2018-11-07 23:54:07.727 - info: tuya.0 starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.tuya, node: v8.12.0
      2018-11-07 23:54:07.815 - info: tuya.0 Existing devices initialized
      2018-11-07 23:54:07.827 - info: tuya.0 Discover for local Tuya devices on port 6666
      2018-11-07 23:54:09.142 - info: tuya.0 0120000660019448e30f Init with IP=192.168.178.28, Key=undefined
      2018-11-07 23:54:09.159 - info: tuya.0 0120000660019448e30f: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
      2018-11-07 23:54:09.161 - info: tuya.0 07652000807d3a1da477 Init with IP=192.168.178.26, Key=undefined
      2018-11-07 23:54:09.163 - info: tuya.0 07652000807d3a1da477: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
      2018-11-07 23:54:09.405 - info: tuya.0 16683183807d3a375847 Init with IP=192.168.178.34, Key=undefined
      2018-11-07 23:54:09.406 - info: tuya.0 16683183807d3a375847: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
      2018-11-07 23:54:09.484 - info: tuya.0 16683183807d3a375847: No schema exists, init basic states ...
      2018-11-07 23:54:09.812 - info: tuya.0 0120000660019448d9fe Init with IP=192.168.178.27, Key=undefined
      2018-11-07 23:54:09.813 - info: tuya.0 0120000660019448d9fe: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
      2018-11-07 23:54:09.879 - debug: fritzdect.0 system.adapter.admin.0: logging false
      2018-11-07 23:54:24.173 - info: tuya.0 Anyproxy ready to receive requests
      2018-11-07 23:54:54.765 - info: tuya.0 new Shema added for product type TtXKwTMwiPpURWLJ. Please send next line from logfile on disk to developer!
      2018-11-07 23:54:54.765 - info: tuya.0 {"schema":"[{"mode":"rw","code":"status","name":"门帘状态","property":{"range":["0","1","2","3"],"type":"enum"},"id":1,"type":"obj","desc":"开 关 暂停"}]","schemaExt":"[]"}
      2018-11-07 23:54:55.849 - info: tuya.0 16683183807d3a375847 Init with IP=192.168.178.34, Key=1cda4bbb517721f4
      2018-11-07 23:54:55.885 - info: tuya.0 0120000660019448e30f Init with IP=192.168.178.28, Key=2f489f0430013398
      2018-11-07 23:54:55.889 - info: tuya.0 16683183807d3a375847 Init with IP=192.168.178.34, Key=1cda4bbb517721f4
      2018-11-07 23:54:55.893 - info: tuya.0 16683183807d3a375847 Init with IP=192.168.178.34, Key=1cda4bbb517721f4
      2018-11-07 23:54:55.895 - info: tuya.0 0120000660019448e30f Init with IP=192.168.178.28, Key=2f489f0430013398
      2018-11-07 23:54:55.898 - info: tuya.0 0120000660019448d9fe Init with IP=192.168.178.27, Key=44b3f41b3a451109
      2018-11-07 23:54:55.905 - info: tuya.0 07652000807d3a1da477 Init with IP=192.168.178.26, Key=0756207f82130213
      2018-11-07 23:54:55.910 - info: tuya.0 0120000660019448e30f Init with IP=192.168.178.28, Key=2f489f0430013398
      2018-11-07 23:54:55.912 - info: tuya.0 0120000660019448d9fe Init with IP=192.168.178.27, Key=44b3f41b3a451109
      2018-11-07 23:54:55.914 - info: tuya.0 07652000807d3a1da477 Init with IP=192.168.178.26, Key=0756207f82130213
      2018-11-07 23:54:55.916 - info: tuya.0 0120000660019448d9fe Init with IP=192.168.178.27, Key=44b3f41b3a451109
      2018-11-07 23:54:55.945 - info: tuya.0 07652000807d3a1da477 Init with IP=192.168.178.26, Key=0756207f82130213
      2018-11-07 23:54:55.957 - info: tuya.0 16683183807d3a375847 Init with IP=192.168.178.34, Key=1cda4bbb517721f4
      2018-11-07 23:54:55.961 - info: tuya.0 0120000660019448e30f Init with IP=192.168.178.28, Key=2f489f0430013398
      2018-11-07 23:54:55.964 - info: tuya.0 0120000660019448d9fe Init with IP=192.168.178.27, Key=44b3f41b3a451109
      2018-11-07 23:54:55.967 - info: tuya.0 07652000807d3a1da477 Init with IP=192.168.178.26, Key=0756207f82130213
      2018-11-07 23:55:26.452 - info: host.Elzershark object change system.adapter.tuya.0
      2018-11-07 23:55:26.453 - info: host.Elzershark stopInstance system.adapter.tuya.0
      2018-11-07 23:55:26.453 - info: host.Elzershark stopInstance system.adapter.tuya.0 killing pid 10356
      2018-11-07 23:55:26.988 - info: host.Elzershark instance system.adapter.tuya.0 terminated with code 0 (OK)
      2018-11-07 23:55:28.979 - info: host.Elzershark instance system.adapter.tuya.0 started with pid 10372
      2018-11-07 23:55:33.076 - info: tuya.0 starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.tuya, node: v8.12.0
      2018-11-07 23:55:33.483 - info: tuya.0 16683183807d3a375847 Init with IP=192.168.178.34, Key=1cda4bbb517721f4
      2018-11-07 23:55:33.505 - info: tuya.0 0120000660019448d9fe Init with IP=192.168.178.27, Key=44b3f41b3a451109
      2018-11-07 23:55:33.511 - info: tuya.0 07652000807d3a1da477 Init with IP=192.168.178.26, Key=0756207f82130213
      2018-11-07 23:55:33.515 - info: tuya.0 0120000660019448e30f Init with IP=192.168.178.28, Key=2f489f0430013398
      2018-11-07 23:55:33.517 - info: tuya.0 Existing devices initialized
      2018-11-07 23:55:33.529 - info: tuya.0 Discover for local Tuya devices on port 6666
       ![4339_clipboard_1.jpg](/assets/uploads/files/4339_clipboard_1.jpg)
      https://www.youtube.com/c/Elzershark
      https://t.me/joinchat/BD87n3xMU0QzYmUy
      https://www.facebook.com/elzershark
        Apropo
        #63
        Ich habe den Adapter jetzt auch mal installiert.
        Die Objekte werden auch angezeigt. Leider nicht komplett richtig. Kannst du da was dran machen? Der aktuelle Stromverbrauch aktualisiert sich brav. Aber bei den beiden obersten Punkten sind so komische chinesiche Zeichen dahinter. Ob die beiden Punkte überhaupt funktionieren weiß ich nicht. Ich vermute das ist der Langzeitverbrauch. Den gibts natürlich noch nicht, da ich die Steckdose gerade erst in Betrieb genommen hab.
        Außerdem bekomme ich am laufenden Band eine Meldung im Log:
        tuya.0	2018-11-08 15:51:26.477	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
        tuya.0	2018-11-08 15:50:50.459	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
        tuya.0	2018-11-08 15:50:14.431	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
        tuya.0	2018-11-08 15:49:38.425	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
        tuya.0	2018-11-08 15:49:02.406	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
        tuya.0	2018-11-08 15:48:26.387	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
        tuya.0	2018-11-08 15:47:50.374	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
        tuya.0	2018-11-08 15:47:14.349	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
        tuya.0	2018-11-08 15:46:38.324	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
        tuya.0	2018-11-08 15:46:02.313	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
        tuya.0	2018-11-08 15:45:26.298	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
        tuya.0	2018-11-08 15:44:50.284	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
        tuya.0	2018-11-08 15:44:14.273	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
        tuya.0	2018-11-08 15:43:38.129	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
        tuya.0	2018-11-08 15:43:02.113	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
        tuya.0	2018-11-08 15:42:26.103	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
        tuya.0	2018-11-08 15:41:50.094	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
        tuya.0	2018-11-08 15:41:14.081	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
        tuya.0	2018-11-08 15:40:38.071	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
        tuya.0	2018-11-08 15:40:02.051	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
        tuya.0	2018-11-08 15:39:26.028	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
        tuya.0	2018-11-08 15:38:51.023	info	Discover for local Tuya devices on port 6666
        Die App ist definitiv beendet. Die Meldung kommt sogar wenn ich das Smartphone ganz aus habe.
        Hast du eine Idee? Brauchst du noch was von mir?
        Steckdosen sind übrigens die hier: https://www.amazon.de/gp/product/B07DGH … UTF8&psc=1
          #64
          @Apropo:
          Die Objekte werden auch angezeigt. Leider nicht komplett richtig. Kannst du da was dran machen? Der aktuelle Stromverbrauch aktualisiert sich brav. Aber bei den beiden obersten Punkten sind so komische chinesiche Zeichen dahinter. Ob die beiden Punkte überhaupt funktionieren weiß ich nicht. Ich vermute das ist der Langzeitverbrauch. Den gibts natürlich noch nicht, da ich die Steckdose gerade erst in Betrieb genommen hab. `
          Die chinesischen Zeichen sind die Unit weil es keine andere Info in englisch gibt :-)
          Add_Ele keine Ahnung, Countdown glaube wäre ne Timer-Einstellung. Musst Du mal rumprobieren.
          @Apropo:
          Hast du eine Idee? Brauchst du noch was von mir? `
          Ne, die Geräte sind manchmal etwas zickig mit dem verbinden. Die nächsten Versionen packen weniger ins Log :-)
            Apropo
            #65
            Ok, danke. Also lass ich erst mal so und hoffe auf eine neue Version, damit wieder Ruhe einkehrt :D
            Mir ist auch noch aufgefallen, dass der "Online Status" und "If Connected tu Tuya" zwischendurch immer wieder auf "false" springen und danach sofort wieder auf "true". Ich denke in dem Moment kommt dann auch die Meldung im Log …
              #66
              Korrekt :-)
                #67
                1.0.0 release und ab morgen auch im Stable Repo.
                Changelog 1.0.0:
                • Weniger Logging (ausser bei debug Loglevel)
                • Neue Schematas
                  Apropo
                  #68
                  Funktioniert perfekt. Die nervigen Meldungen sind verschwunden. Danke!
                    bastimiau
                    #69
                    Ich bin sehr neu dabei.
                    Ich habe mir nun den Adapter tuya installiert aber ich bekomme keinen QR-Code.
                    Im Log zeigt er mir ganz viele Fehler an.
                      #70
                      Kann sein das da irgendwie RAM knapp ist? memory allocation failed … der Proxy brauch recht viel ram
                        bastimiau
                        #71
                        du hast recht gehabt :)
                        Habe ich nicht darauf geachtet :)
                        Nebenbei wenn mein Ram voll ist kann man den wie bei einen pc erweitern? :P
                        Also ich habe den QR Code nun erhalten habe das Zertifikat installiert und habe dan meine Wlan verbindung so angepasst wie beschrieben habe dan die App beendet/Erzwungen hat sich nichts getan. Ich habe das jetzt mehrmals versucht :P 9676_problem2.png
                          ElzersharkE Offline
                          Elzershark
                          #72
                          Beim deinstallieren des Adapters, löscht er nicht alle Objekte. Eventuell mal Testen ob das bei mehreren so ist.
                            #73
                            hast Du auch Reload im Admin gedrückt? manchmal bekommt der Admin-Adapter bei "Massenaktionen" nicht alles direkt mit sondern erst nach einem Reload.
                              ElzersharkE Offline
                              Elzershark
                              #74
                              ja, hab ich. Reload, browser neu gestartet.. Aber bei mir sind eh einige sachen "komisch". Bei einem frisch installieren iobroker kommt das nicht vor. Also denke ich, alles i.O.
                              • H Offline
                                homecineplexx
                                #75
                                ich versuch das nun schon zum xten Mal und ich bekomm zwar in den Objekten 2 devices angezeigt, aber ich kann nichts damit tun, das sagt auch der adapter.
                                und das sagt der log dazu:
                                tuya.0	2018-11-10 19:34:23.088	info	0720006884f3eb84ad80: No schema exists, init basic states ...
                                tuya.0	2018-11-10 19:34:23.072	info	0720006884f3eb84ad80: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                                tuya.0	2018-11-10 19:34:23.070	info	0720006884f3eb84ad80 Init with IP=192.168.1.174, Key=undefined
                                tuya.0	2018-11-10 19:34:21.060	info	07200068dc4f223ec823: No schema exists, init basic states ...
                                tuya.0	2018-11-10 19:34:21.029	info	07200068dc4f223ec823: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                                tuya.0	2018-11-10 19:34:21.028	info	07200068dc4f223ec823 Init with IP=192.168.1.173, Key=undefined
                                  Apropo
                                  #76
                                  Ich hab auch ein neues Schema
                                  tuya.0	2018-11-10 19:44:02.768	info	{"schema":"[{\"mode\":\"rw\",\"code\":\"switch_on\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power3\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\"
                                  tuya.0	2018-11-10 19:44:02.767	info	new Shema added for product type VDy8SyAxa6Q83vvr. Please send next line from logfile on disk to developer!
                                    #77
                                    @homecineplexx:
                                    Na dann mach was da steht … Admin öffnen und über den Proxy mit der App syncen. Danach kannst du steuern. Was sollte das log noch sagen? Zusammen mit der Adapter readme sollte das doch erstmal reichen oder?!
                                    Gesendet vom Handy ...
                                    • H Offline
                                      homecineplexx
                                      #78
                                      @homecineplexx:
                                      und wenn ich das dann mit dem proxy versuche und die SmartLife App starte kommt folgender log
                                      host.raspberrypi	2018-11-10 20:06:40.194	info	Restart adapter system.adapter.tuya.0 because enabled
                                      host.raspberrypi	2018-11-10 20:06:40.194	error	instance system.adapter.tuya.0 terminated with code 7 (Adapter already running)
                                      host.raspberrypi	2018-11-10 20:06:40.194	error	Caught by controller[2]: at TCP.onStreamRead (internal/stream_base_commons.js:111:27)
                                      host.raspberrypi	2018-11-10 20:06:40.194	error	Caught by controller[2]: Error: read ECONNRESET
                                      host.raspberrypi	2018-11-10 20:06:40.194	error	Caught by controller[2]: 1<process.argv.length?process.argv[1].replace( \\/g,"/"):"unknown-program");b.arguments="process.argv.slice(2);&quot;undefined&quot;!==typeof" module&&(module.exports="b);process.on(&quot;uncau" host.raspberrypi/2018-11-10/20:06:40.194/error/caught/by/controller[2]:/opt/iobroker/node_modules/brotli/build/encode.js:3/20:06:40.193/controller[1]:/at/tcp.onstreamread/(internal/stream_base_commons.js:111:27)/errno:/'econnreset',/code:/syscall:/'read'/}/{/error:/read/econnreset/<e=""></process.argv.length?process.argv[1].replace(>
                                        #79
                                        @Apropo:
                                        Bitte wie es da steht vollständig aus dem logfile auf Platte rausholen. Admin schneidet lange Zeilen leider ab. Danke.
                                        Logfile unter /opt/iobroker/log/…
                                          #80
                                          @homecineplexx:
                                          @homecineplexx:
                                          Hm … dann kann scheinbar der iobroker Rechner keine Verbindung weiter zu den Servern für die er Proxiet aufbauen. Econnreset heißt das eine Verbindung abgebrochen wurde.
