  4. [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere)
    6.5k
547 Beiträge 97 Kommentatoren 208.7k Aufrufe 20 Beobachtet
  • ElzersharkE Offline
    ElzersharkE Offline
    Elzershark
    $ ./iobroker upgrade tuya
    Update tuya from @0.1.2 to @0.1.3
    NPM version: 6.4.1
    npm install iobroker.tuya@0.1.3 --production --save --prefix "/opt/iobroker" (System call)
    npm
    WARN
    deprecated
    clipboard-js@0.3.6: Please migrate to https://github.com/lgarron/clipboard-polyfill
    npm
    WARN
    svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
    npm
    WARN optional
    SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm
    WARN notsup
    SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    ! npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.tuya"
    npm
    WARN deprecated clipboard-js@0.3.6: Please migrate to https://github.com/lgarron/clipboard-polyfill
    npm
    WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
    npm
    WARN
    deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
    npm
    WARN
    deprecated
    minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
    npm
    WARN
    deprecated
    minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
    npm
    WARN
    deprecated
    graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
    npm
    notice created a lockfile as package-lock.json. You should commit this file.
    npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
    ! got /opt/iobroker/node_modules/iobroker.tuya/admin
    upload [2] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript
    upload [1] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/tuya.png tuya.png image/png
    upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/index_m.html index_m.html text/html
    Adapter "tuya" updated
    process exited with code 0
    Bei mir Warn Hinweise beim upgraden.
    Sonst alles OK.
    Eventuell noch den "Warn" Hinweis machen, wenn man den Port im W-Lan eingestellt hat, und die Prozedur ist fertig, das man wieder den Port deaktivieren sollte, da sonst das Internet nicht funktioniert im Handy
    https://www.youtube.com/c/Elzershark
    https://t.me/joinchat/BD87n3xMU0QzYmUy
    https://www.facebook.com/elzershark
      ElzersharkE Offline
      Elzershark
      Falls Du möchtest:
      • apollon77A Offline
        Cool, Danke, übernehme ich noch!
          ElzersharkE Offline
          Elzershark
          Rolladen Zeitschaltuhr Jalousien Schalter = https://amzn.to/2DaecSr
          Alle die so aussehen, funktionieren
          Geräte IP= IP=192.168.178.34
          0 = ? keine Funktion (kein Fehler)
          1 = auf
          2 = zu
          3 = pause/stopp
          Neues Shema:
          2018-11-07 23:54:03.483 - info: host.Elzershark object change system.adapter.tuya.0
          2018-11-07 23:54:03.513 - info: host.Elzershark instance system.adapter.tuya.0 started with pid 10356
          2018-11-07 23:54:07.727 - info: tuya.0 starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.tuya, node: v8.12.0
          2018-11-07 23:54:07.815 - info: tuya.0 Existing devices initialized
          2018-11-07 23:54:07.827 - info: tuya.0 Discover for local Tuya devices on port 6666
          2018-11-07 23:54:09.142 - info: tuya.0 0120000660019448e30f Init with IP=192.168.178.28, Key=undefined
          2018-11-07 23:54:09.159 - info: tuya.0 0120000660019448e30f: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
          2018-11-07 23:54:09.161 - info: tuya.0 07652000807d3a1da477 Init with IP=192.168.178.26, Key=undefined
          2018-11-07 23:54:09.163 - info: tuya.0 07652000807d3a1da477: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
          2018-11-07 23:54:09.405 - info: tuya.0 16683183807d3a375847 Init with IP=192.168.178.34, Key=undefined
          2018-11-07 23:54:09.406 - info: tuya.0 16683183807d3a375847: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
          2018-11-07 23:54:09.484 - info: tuya.0 16683183807d3a375847: No schema exists, init basic states ...
          2018-11-07 23:54:09.812 - info: tuya.0 0120000660019448d9fe Init with IP=192.168.178.27, Key=undefined
          2018-11-07 23:54:09.813 - info: tuya.0 0120000660019448d9fe: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
          2018-11-07 23:54:09.879 - debug: fritzdect.0 system.adapter.admin.0: logging false
          2018-11-07 23:54:24.173 - info: tuya.0 Anyproxy ready to receive requests
          2018-11-07 23:54:54.765 - info: tuya.0 new Shema added for product type TtXKwTMwiPpURWLJ. Please send next line from logfile on disk to developer!
          2018-11-07 23:54:54.765 - info: tuya.0 {"schema":"[{"mode":"rw","code":"status","name":"门帘状态","property":{"range":["0","1","2","3"],"type":"enum"},"id":1,"type":"obj","desc":"开 关 暂停"}]","schemaExt":"[]"}
          2018-11-07 23:54:55.849 - info: tuya.0 16683183807d3a375847 Init with IP=192.168.178.34, Key=1cda4bbb517721f4
          2018-11-07 23:54:55.885 - info: tuya.0 0120000660019448e30f Init with IP=192.168.178.28, Key=2f489f0430013398
          2018-11-07 23:54:55.889 - info: tuya.0 16683183807d3a375847 Init with IP=192.168.178.34, Key=1cda4bbb517721f4
          2018-11-07 23:54:55.893 - info: tuya.0 16683183807d3a375847 Init with IP=192.168.178.34, Key=1cda4bbb517721f4
          2018-11-07 23:54:55.895 - info: tuya.0 0120000660019448e30f Init with IP=192.168.178.28, Key=2f489f0430013398
          2018-11-07 23:54:55.898 - info: tuya.0 0120000660019448d9fe Init with IP=192.168.178.27, Key=44b3f41b3a451109
          2018-11-07 23:54:55.905 - info: tuya.0 07652000807d3a1da477 Init with IP=192.168.178.26, Key=0756207f82130213
          2018-11-07 23:54:55.910 - info: tuya.0 0120000660019448e30f Init with IP=192.168.178.28, Key=2f489f0430013398
          2018-11-07 23:54:55.912 - info: tuya.0 0120000660019448d9fe Init with IP=192.168.178.27, Key=44b3f41b3a451109
          2018-11-07 23:54:55.914 - info: tuya.0 07652000807d3a1da477 Init with IP=192.168.178.26, Key=0756207f82130213
          2018-11-07 23:54:55.916 - info: tuya.0 0120000660019448d9fe Init with IP=192.168.178.27, Key=44b3f41b3a451109
          2018-11-07 23:54:55.945 - info: tuya.0 07652000807d3a1da477 Init with IP=192.168.178.26, Key=0756207f82130213
          2018-11-07 23:54:55.957 - info: tuya.0 16683183807d3a375847 Init with IP=192.168.178.34, Key=1cda4bbb517721f4
          2018-11-07 23:54:55.961 - info: tuya.0 0120000660019448e30f Init with IP=192.168.178.28, Key=2f489f0430013398
          2018-11-07 23:54:55.964 - info: tuya.0 0120000660019448d9fe Init with IP=192.168.178.27, Key=44b3f41b3a451109
          2018-11-07 23:54:55.967 - info: tuya.0 07652000807d3a1da477 Init with IP=192.168.178.26, Key=0756207f82130213
          2018-11-07 23:55:26.452 - info: host.Elzershark object change system.adapter.tuya.0
          2018-11-07 23:55:26.453 - info: host.Elzershark stopInstance system.adapter.tuya.0
          2018-11-07 23:55:26.453 - info: host.Elzershark stopInstance system.adapter.tuya.0 killing pid 10356
          2018-11-07 23:55:26.988 - info: host.Elzershark instance system.adapter.tuya.0 terminated with code 0 (OK)
          2018-11-07 23:55:28.979 - info: host.Elzershark instance system.adapter.tuya.0 started with pid 10372
          2018-11-07 23:55:33.076 - info: tuya.0 starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.tuya, node: v8.12.0
          2018-11-07 23:55:33.483 - info: tuya.0 16683183807d3a375847 Init with IP=192.168.178.34, Key=1cda4bbb517721f4
          2018-11-07 23:55:33.505 - info: tuya.0 0120000660019448d9fe Init with IP=192.168.178.27, Key=44b3f41b3a451109
          2018-11-07 23:55:33.511 - info: tuya.0 07652000807d3a1da477 Init with IP=192.168.178.26, Key=0756207f82130213
          2018-11-07 23:55:33.515 - info: tuya.0 0120000660019448e30f Init with IP=192.168.178.28, Key=2f489f0430013398
          2018-11-07 23:55:33.517 - info: tuya.0 Existing devices initialized
          2018-11-07 23:55:33.529 - info: tuya.0 Discover for local Tuya devices on port 6666
           ![4339_clipboard_1.jpg](/assets/uploads/files/4339_clipboard_1.jpg)
            Apropo
            Ich habe den Adapter jetzt auch mal installiert.
            Die Objekte werden auch angezeigt. Leider nicht komplett richtig. Kannst du da was dran machen? Der aktuelle Stromverbrauch aktualisiert sich brav. Aber bei den beiden obersten Punkten sind so komische chinesiche Zeichen dahinter. Ob die beiden Punkte überhaupt funktionieren weiß ich nicht. Ich vermute das ist der Langzeitverbrauch. Den gibts natürlich noch nicht, da ich die Steckdose gerade erst in Betrieb genommen hab.
            Außerdem bekomme ich am laufenden Band eine Meldung im Log:
            tuya.0	2018-11-08 15:51:26.477	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
            tuya.0	2018-11-08 15:50:50.459	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
            tuya.0	2018-11-08 15:50:14.431	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
            tuya.0	2018-11-08 15:49:38.425	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
            tuya.0	2018-11-08 15:49:02.406	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
            tuya.0	2018-11-08 15:48:26.387	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
            tuya.0	2018-11-08 15:47:50.374	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
            tuya.0	2018-11-08 15:47:14.349	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
            tuya.0	2018-11-08 15:46:38.324	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
            tuya.0	2018-11-08 15:46:02.313	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
            tuya.0	2018-11-08 15:45:26.298	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
            tuya.0	2018-11-08 15:44:50.284	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
            tuya.0	2018-11-08 15:44:14.273	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
            tuya.0	2018-11-08 15:43:38.129	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
            tuya.0	2018-11-08 15:43:02.113	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
            tuya.0	2018-11-08 15:42:26.103	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
            tuya.0	2018-11-08 15:41:50.094	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
            tuya.0	2018-11-08 15:41:14.081	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
            tuya.0	2018-11-08 15:40:38.071	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
            tuya.0	2018-11-08 15:40:02.051	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
            tuya.0	2018-11-08 15:39:26.028	info	80027536bcddc28a85f4: Error from device (0): App still open on your mobile phone? Error: Error from socket
            tuya.0	2018-11-08 15:38:51.023	info	Discover for local Tuya devices on port 6666
            Die App ist definitiv beendet. Die Meldung kommt sogar wenn ich das Smartphone ganz aus habe.
            Hast du eine Idee? Brauchst du noch was von mir?
            Steckdosen sind übrigens die hier: https://www.amazon.de/gp/product/B07DGH … UTF8&psc=1
              @Apropo:
              Die Objekte werden auch angezeigt. Leider nicht komplett richtig. Kannst du da was dran machen? Der aktuelle Stromverbrauch aktualisiert sich brav. Aber bei den beiden obersten Punkten sind so komische chinesiche Zeichen dahinter. Ob die beiden Punkte überhaupt funktionieren weiß ich nicht. Ich vermute das ist der Langzeitverbrauch. Den gibts natürlich noch nicht, da ich die Steckdose gerade erst in Betrieb genommen hab. `
              Die chinesischen Zeichen sind die Unit weil es keine andere Info in englisch gibt :-)
              Add_Ele keine Ahnung, Countdown glaube wäre ne Timer-Einstellung. Musst Du mal rumprobieren.
              @Apropo:
              Hast du eine Idee? Brauchst du noch was von mir? `
              Ne, die Geräte sind manchmal etwas zickig mit dem verbinden. Die nächsten Versionen packen weniger ins Log :-)
                Apropo
                Ok, danke. Also lass ich erst mal so und hoffe auf eine neue Version, damit wieder Ruhe einkehrt :D
                Mir ist auch noch aufgefallen, dass der "Online Status" und "If Connected tu Tuya" zwischendurch immer wieder auf "false" springen und danach sofort wieder auf "true". Ich denke in dem Moment kommt dann auch die Meldung im Log …
                  #66
                  Korrekt :-)
                    #67
                    1.0.0 release und ab morgen auch im Stable Repo.
                    Changelog 1.0.0:
                    • Weniger Logging (ausser bei debug Loglevel)
                    • Neue Schematas
                      Apropo
                      #68
                      Funktioniert perfekt. Die nervigen Meldungen sind verschwunden. Danke!
                        bastimiau
                        #69
                        Ich bin sehr neu dabei.
                        Ich habe mir nun den Adapter tuya installiert aber ich bekomme keinen QR-Code.
                        Im Log zeigt er mir ganz viele Fehler an.
                          #70
                          Kann sein das da irgendwie RAM knapp ist? memory allocation failed … der Proxy brauch recht viel ram
                            bastimiau
                            #71
                            du hast recht gehabt :)
                            Habe ich nicht darauf geachtet :)
                            Nebenbei wenn mein Ram voll ist kann man den wie bei einen pc erweitern? :P
                            Also ich habe den QR Code nun erhalten habe das Zertifikat installiert und habe dan meine Wlan verbindung so angepasst wie beschrieben habe dan die App beendet/Erzwungen hat sich nichts getan. Ich habe das jetzt mehrmals versucht :P 9676_problem2.png
                              ElzersharkE Offline
                              Elzershark
                              #72
                              Beim deinstallieren des Adapters, löscht er nicht alle Objekte. Eventuell mal Testen ob das bei mehreren so ist.
                                #73
                                hast Du auch Reload im Admin gedrückt? manchmal bekommt der Admin-Adapter bei "Massenaktionen" nicht alles direkt mit sondern erst nach einem Reload.
                                  ElzersharkE Offline
                                  Elzershark
                                  #74
                                  ja, hab ich. Reload, browser neu gestartet.. Aber bei mir sind eh einige sachen "komisch". Bei einem frisch installieren iobroker kommt das nicht vor. Also denke ich, alles i.O.
                                  • H Offline
                                    homecineplexx
                                    #75
                                    ich versuch das nun schon zum xten Mal und ich bekomm zwar in den Objekten 2 devices angezeigt, aber ich kann nichts damit tun, das sagt auch der adapter.
                                    und das sagt der log dazu:
                                    tuya.0	2018-11-10 19:34:23.088	info	0720006884f3eb84ad80: No schema exists, init basic states ...
                                    tuya.0	2018-11-10 19:34:23.072	info	0720006884f3eb84ad80: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                                    tuya.0	2018-11-10 19:34:23.070	info	0720006884f3eb84ad80 Init with IP=192.168.1.174, Key=undefined
                                    tuya.0	2018-11-10 19:34:21.060	info	07200068dc4f223ec823: No schema exists, init basic states ...
                                    tuya.0	2018-11-10 19:34:21.029	info	07200068dc4f223ec823: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                                    tuya.0	2018-11-10 19:34:21.028	info	07200068dc4f223ec823 Init with IP=192.168.1.173, Key=undefined
                                      Apropo
                                      #76
                                      Ich hab auch ein neues Schema
                                      tuya.0	2018-11-10 19:44:02.768	info	{"schema":"[{\"mode\":\"rw\",\"code\":\"switch_on\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power3\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\"
                                      tuya.0	2018-11-10 19:44:02.767	info	new Shema added for product type VDy8SyAxa6Q83vvr. Please send next line from logfile on disk to developer!
                                        #77
                                        @homecineplexx:
                                        Na dann mach was da steht … Admin öffnen und über den Proxy mit der App syncen. Danach kannst du steuern. Was sollte das log noch sagen? Zusammen mit der Adapter readme sollte das doch erstmal reichen oder?!
                                        Gesendet vom Handy ...
                                        • H Offline
                                          homecineplexx
                                          #78
                                          @homecineplexx:
                                          und wenn ich das dann mit dem proxy versuche und die SmartLife App starte kommt folgender log
                                          host.raspberrypi	2018-11-10 20:06:40.194	info	Restart adapter system.adapter.tuya.0 because enabled
                                          host.raspberrypi	2018-11-10 20:06:40.194	error	instance system.adapter.tuya.0 terminated with code 7 (Adapter already running)
                                          host.raspberrypi	2018-11-10 20:06:40.194	error	Caught by controller[2]: at TCP.onStreamRead (internal/stream_base_commons.js:111:27)
                                          host.raspberrypi	2018-11-10 20:06:40.194	error	Caught by controller[2]: Error: read ECONNRESET
                                          host.raspberrypi	2018-11-10 20:06:40.194	error	Caught by controller[2]: 1<process.argv.length?process.argv[1].replace( \\/g,"/"):"unknown-program");b.arguments="process.argv.slice(2);&quot;undefined&quot;!==typeof" module&&(module.exports="b);process.on(&quot;uncau" host.raspberrypi/2018-11-10/20:06:40.194/error/caught/by/controller[2]:/opt/iobroker/node_modules/brotli/build/encode.js:3/20:06:40.193/controller[1]:/at/tcp.onstreamread/(internal/stream_base_commons.js:111:27)/errno:/'econnreset',/code:/syscall:/'read'/}/{/error:/read/econnreset/<e=""></process.argv.length?process.argv[1].replace(>
