  4. [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere)
    6.8k
547 Beiträge 97 Kommentatoren 209.3k Aufrufe 20 Beobachtet
  • V varg
    @apollon77
    tuya.0 2019-09-05 08:05:47.044 debug sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
    tuya.0 2019-09-05 08:05:47.044 debug Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":56,"ack":false,"time":1567663547023},"_id":59700414}
    tuya.0 2019-09-05 08:05:32.301 info Listen for encrypted local Tuya devices on port 6667
    tuya.0 2019-09-05 08:05:32.301 info Listen for local Tuya devices on port 6666
    tuya.0 2019-09-05 08:05:32.301 info Existing devices initialized
    tuya.0 2019-09-05 08:05:32.301 info 01200803ecfabc819d1e: None of the discovered devices matches 😞
    tuya.0 2019-09-05 08:05:32.301 debug 01200803ecfabc819d1e: Try to initialize encrypted device with received UDP messages: version=undefined, key=134a0d1b36f6478b
    tuya.0 2019-09-05 08:05:32.286 info 02200301600194731900: None of the discovered devices matches 😞
    tuya.0 2019-09-05 08:05:32.283 debug 02200301600194731900: Try to initialize encrypted device with received UDP messages: version=undefined, key=5dffb2235e73d795
    tuya.0 2019-09-05 08:05:32.075 debug 01200803ecfabc819d1e: Create device objects if not exist
    tuya.0 2019-09-05 08:05:32.075 debug 02200301600194731900: Create device objects if not exist
    tuya.0 2019-09-05 08:05:32.074 debug init 2 known devices
    tuya.0 2019-09-05 08:05:32.040 debug connected set to false
    tuya.0 2019-09-05 08:05:32.028 info starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.tuya, node: v10.16.3
    host.raspberrypi 2019-09-05 08:05:31.631 info instance system.adapter.tuya.0 terminated with code 156 ()
    host.raspberrypi 2019-09-05 08:05:31.096 info instance system.adapter.tuya.0 started with pid 9696
    host.raspberrypi 2019-09-05 08:05:28.566 info stopInstance system.adapter.tuya.0 killing pid 2607
    host.raspberrypi 2019-09-05 08:05:28.564 info object change system.adapter.tuya.0
    zigbee.0 2019-09-05 08:05:20.668 warn Dev 0x00178801032907f0 SML001 not configured yet, will try again in latest 300 sec.
    tuya.0 2019-09-05 08:05:06.036 error at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1106:14)
    tuya.0 2019-09-05 08:05:06.036 error Error: connect ECONNRESET 192.168.178.70:8888
    tuya.0 2019-09-05 08:05:06.035 error SSL-Proxy ERROR: Error: connect ECONNRESET 192.168.178.70:8888
    tuya.0 2019-09-05 08:05:06.035 debug sendTo "stopProxy" to system.adapter.admin.0 from system.adapter.tuya.0
    tuya.0 2019-09-05 08:05:06.034 debug Message: {"command":"stopProxy","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":54,"ack":false,"time":1567663506023},"_id":59700410}
    tuya.0 2019-09-05 08:05:00.303 debug stateChange tuya.0.01200803ecfabc819d1e.10 {"val":"ffff0506ff000000ff00ffff00ff00ff0000ffff0000","ack":true,"ts":1567663500277,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":156
    tuya.0 2019-09-05 08:05:00.283 info 01200803ecfabc819d1e: None of the discovered devices matches 😞
    tuya.0 2019-09-05 08:05:00.282 debug 01200803ecfabc819d1e: Try to initialize encrypted device with received UDP messages: version=undefined, key=134a0d1b36f6478b
    tuya.0 2019-09-05 08:05:00.275 debug stateChange tuya.0.01200803ecfabc819d1e.9 {"val":"ffff5001ff0000","ack":true,"ts":1567663500247,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148052}
    tuya.0 2019-09-05 08:05:00.254 info 02200301600194731900: None of the discovered devices matches 😞
    tuya.0 2019-09-05 08:05:00.254 debug 02200301600194731900: Try to initialize encrypted device with received UDP messages: version=undefined, key=5dffb2235e73d795
    tuya.0 2019-09-05 08:05:00.250 debug stateChange tuya.0.01200803ecfabc819d1e.8 {"val":"ffff8006ff000000ff000000ffff0000ff0000ff0000","ack":true,"ts":1567663500214,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567
    tuya.0 2019-09-05 08:05:00.215 debug stateChange tuya.0.01200803ecfabc819d1e.7 {"val":"ffff3301ff0084","ack":true,"ts":1567663500195,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148037}
    tuya.0 2019-09-05 08:05:00.182 debug stateChange tuya.0.01200803ecfabc819d1e.6 {"val":"bd76000168ffff","ack":true,"ts":1567663500154,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148026}
    tuya.0 2019-09-05 08:05:00.152 debug stateChange tuya.0.01200803ecfabc819d1e.5 {"val":"ff25000008ffff","ack":true,"ts":1567663500125,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148024}
    tuya.0 2019-09-05 08:05:00.097 debug stateChange tuya.0.01200803ecfabc819d1e.4 {"val":255,"ack":true,"ts":1567663500072,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148009}
    tuya.0 2019-09-05 08:05:00.075 debug stateChange tuya.0.01200803ecfabc819d1e.3 {"val":255,"ack":true,"ts":1567663500052,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148006}
    tuya.0 2019-09-05 08:05:00.022 debug stateChange tuya.0.01200803ecfabc819d1e.2 {"val":"1","ack":true,"ts":1567663499992,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147996}
    tuya.0 2019-09-05 08:05:00.015 debug stateChange tuya.0.01200803ecfabc819d1e.1 {"val":false,"ack":true,"ts":1567663499990,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618230760}
    tuya.0 2019-09-05 08:04:59.962 debug stateChange tuya.0.02200301600194731900.10 {"val":"ffff0505ff000000ff00ffff00ff00ff0000ff000000","ack":true,"ts":1567663499932,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":156
    tuya.0 2019-09-05 08:04:59.935 debug stateChange tuya.0.02200301600194731900.9 {"val":"ffff5001ff0000","ack":true,"ts":1567663499910,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147954}
    tuya.0 2019-09-05 08:04:59.881 debug stateChange tuya.0.02200301600194731900.8 {"val":"ffff8003ff000000ff000000ff000000000000000000","ack":true,"ts":1567663499855,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567
    tuya.0 2019-09-05 08:04:59.877 debug stateChange tuya.0.02200301600194731900.7 {"val":"ffff500100ff00","ack":true,"ts":1567663499852,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147941}
    tuya.0 2019-09-05 08:04:59.826 debug stateChange tuya.0.02200301600194731900.6 {"val":"00ff0000000000","ack":true,"ts":1567663499800,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147930}
    tuya.0 2019-09-05 08:04:59.802 debug stateChange tuya.0.02200301600194731900.5 {"val":"ff46000010ffff","ack":true,"ts":1567663499778,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147927}
    tuya.0 2019-09-05 08:04:59.748 debug stateChange tuya.0.02200301600194731900.4 {"val":255,"ack":true,"ts":1567663499722,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147911}
    tuya.0 2019-09-05 08:04:59.698 debug stateChange tuya.0.02200301600194731900.3 {"val":255,"ack":true,"ts":1567663499677,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147909}
    tuya.0 2019-09-05 08:04:59.698 debug stateChange tuya.0.02200301600194731900.2 {"val":"1","ack":true,"ts":1567663499675,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147887}
    tuya.0 2019-09-05 08:04:59.606 debug stateChange tuya.0.02200301600194731900.1 {"val":false,"ack":true,"ts":1567663499590,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618224893}
    tuya.0 2019-09-05 08:04:59.571 debug stateChange tuya.0.01200803ecfabc819d1e.online {"val":false,"ack":true,"ts":1567663499543,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147981}
    tuya.0 2019-09-05 08:04:59.566 debug stateChange tuya.0.02200301600194731900.online {"val":false,"ack":true,"ts":1567663499536,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147857}
    tuya.0 2019-09-05 08:04:59.539 debug 01200803ecfabc819d1e: Create device objects if not exist
    tuya.0 2019-09-05 08:04:59.538 debug 01200803ecfabc819d1e: Schema found for xw0AjeWMmnX0LX7Z: {"schema":[{"mode":"rw","code":"led_switch","name":"开关","property":{"type":"bool"},"iconname":"icon-dp_power2","id":1,"type":"obj","desc":""},
    tuya.0 2019-09-05 08:04:59.534 debug 02200301600194731900: Create device objects if not exist
    tuya.0 2019-09-05 08:04:59.532 debug 02200301600194731900: Schema found for xw0AjeWMmnX0LX7Z: {"schema":[{"mode":"rw","code":"led_switch","name":"开关","property":{"type":"bool"},"iconname":"icon-dp_power2","id":1,"type":"obj","desc":""},
    tuya.0 2019-09-05 08:04:59.532 debug Found 2 devices
    tuya.0 2019-09-05 08:04:59.532 debug Found 1 device schema information
    tuya.0 2019-09-05 08:04:56.034 debug sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
    tuya.0 2019-09-05 08:04:56.033 debug Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":53,"ack":false,"time":1567663496024},"_id":59700408}
    tuya.0 2019-09-05 08:04:51.895 debug stateChange tuya.0.01200803ecfabc819d1e.10 {"val":"ffff0506ff000000ff00ffff00ff00ff0000ffff0000","ack":true,"ts":1567663491872,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":156
    tuya.0 2019-09-05 08:04:51.894 info 01200803ecfabc819d1e: None of the discovered devices matches 😞
    tuya.0 2019-09-05 08:04:51.894 debug 01200803ecfabc819d1e: Try to initialize encrypted device with received UDP messages: version=undefined, key=134a0d1b36f6478b
    tuya.0 2019-09-05 08:04:51.869 debug stateChange tuya.0.01200803ecfabc819d1e.9 {"val":"ffff5001ff0000","ack":true,"ts":1567663491845,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148052}
    tuya.0 2019-09-05 08:04:51.868 info 02200301600194731900: None of the discovered devices matches 😞
    tuya.0 2019-09-05 08:04:51.868 debug 02200301600194731900: Try to initialize encrypted device with received UDP messages: version=undefined, key=5dffb2235e73d795
    tuya.0 2019-09-05 08:04:51.842 debug stateChange tuya.0.01200803ecfabc819d1e.8 {"val":"ffff8006ff000000ff000000ffff0000ff0000ff0000","ack":true,"ts":1567663491817,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567
    tuya.0 2019-09-05 08:04:51.814 debug stateChange tuya.0.01200803ecfabc819d1e.7 {"val":"ffff3301ff0084","ack":true,"ts":1567663491789,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148037}
    tuya.0 2019-09-05 08:04:51.777 debug stateChange tuya.0.01200803ecfabc819d1e.6 {"val":"bd76000168ffff","ack":true,"ts":1567663491745,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148026}
    tuya.0 2019-09-05 08:04:51.742 debug stateChange tuya.0.01200803ecfabc819d1e.5 {"val":"ff25000008ffff","ack":true,"ts":1567663491717,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148024}
    tuya.0 2019-09-05 08:04:51.714 debug stateChange tuya.0.01200803ecfabc819d1e.4 {"val":255,"ack":true,"ts":1567663491687,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148009}
    tuya.0 2019-09-05 08:04:51.685 debug stateChange tuya.0.01200803ecfabc819d1e.3 {"val":255,"ack":true,"ts":1567663491657,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148006}
    tuya.0 2019-09-05 08:04:51.656 debug stateChange tuya.0.01200803ecfabc819d1e.2 {"val":"1","ack":true,"ts":1567663491628,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147996}
    tuya.0 2019-09-05 08:04:51.626 debug stateChange tuya.0.01200803ecfabc819d1e.1 {"val":false,"ack":true,"ts":1567663491596,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618230760}
    tuya.0 2019-09-05 08:04:51.595 debug stateChange tuya.0.02200301600194731900.10 {"val":"ffff0505ff000000ff00ffff00ff00ff0000ff000000","ack":true,"ts":1567663491565,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":156
    tuya.0 2019-09-05 08:04:51.563 debug stateChange tuya.0.02200301600194731900.9 {"val":"ffff5001ff0000","ack":true,"ts":1567663491529,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147954}
    tuya.0 2019-09-05 08:04:51.528 debug stateChange tuya.0.02200301600194731900.8 {"val":"ffff8003ff000000ff000000ff000000000000000000","ack":true,"ts":1567663491490,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567
    tuya.0 2019-09-05 08:04:51.489 debug stateChange tuya.0.02200301600194731900.7 {"val":"ffff500100ff00","ack":true,"ts":1567663491462,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147941}
    tuya.0 2019-09-05 08:04:51.460 debug stateChange tuya.0.02200301600194731900.6 {"val":"00ff0000000000","ack":true,"ts":1567663491431,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147930}
    tuya.0 2019-09-05 08:04:51.429 debug stateChange tuya.0.02200301600194731900.5 {"val":"ff46000010ffff","ack":true,"ts":1567663491400,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147927}
    tuya.0 2019-09-05 08:04:51.404 debug stateChange tuya.0.02200301600194731900.4 {"val":255,"ack":true,"ts":1567663491387,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147911}
    tuya.0 2019-09-05 08:04:51.341 debug stateChange tuya.0.02200301600194731900.3 {"val":255,"ack":true,"ts":1567663491316,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147909}
    tuya.0 2019-09-05 08:04:51.290 debug stateChange tuya.0.02200301600194731900.2 {"val":"1","ack":true,"ts":1567663491267,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147887}
    tuya.0 2019-09-05 08:04:51.290 debug stateChange tuya.0.02200301600194731900.1 {"val":false,"ack":true,"ts":1567663491265,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618224893}
    tuya.0 2019-09-05 08:04:51.211 debug stateChange tuya.0.01200803ecfabc819d1e.online {"val":false,"ack":true,"ts":1567663491184,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147981}
    tuya.0 2019-09-05 08:04:51.211 debug stateChange tuya.0.02200301600194731900.online {"val":false,"ack":true,"ts":1567663491184,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147857}
    tuya.0 2019-09-05 08:04:51.179 debug 01200803ecfabc819d1e: Create device objects if not exist
    tuya.0 2019-09-05 08:04:51.178 debug 01200803ecfabc819d1e: Schema found for xw0AjeWMmnX0LX7Z: {"schema":[{"mode":"rw","code":"led_switch","name":"开关","property":{"type":"bool"},"iconname":"icon-dp_power2","id":1,"type":"obj","desc":""},
    tuya.0 2019-09-05 08:04:51.174 debug 02200301600194731900: Create device objects if not exist
    tuya.0 2019-09-05 08:04:51.173 debug 02200301600194731900: Schema found for xw0AjeWMmnX0LX7Z: {"schema":[{"mode":"rw","code":"led_switch","name":"开关","property":{"type":"bool"},"iconname":"icon-dp_power2","id":1,"type":"obj","desc":""},
    tuya.0 2019-09-05 08:04:51.173 debug Found 2 devices
    tuya.0 2019-09-05 08:04:51.172 debug Found 1 device schema information
    tuya.0 2019-09-05 08:04:50.936 debug stateChange tuya.0.01200803ecfabc819d1e.10 {"val":"ffff0506ff000000ff00ffff00ff00ff0000ffff0000","ack":true,"ts":1567663490909,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":156
    tuya.0 2019-09-05 08:04:50.934 info 01200803ecfabc819d1e: None of the discovered devices matches 😞
    tuya.0 2019-09-05 08:04:50.933 debug 01200803ecfabc819d1e: Try to initialize encrypted device with received UDP messages: version=undefined, key=134a0d1b36f6478b
    tuya.0 2019-09-05 08:04:50.907 debug stateChange tuya.0.01200803ecfabc819d1e.9 {"val":"ffff5001ff0000","ack":true,"ts":1567663490881,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148052}
    tuya.0 2019-09-05 08:04:50.906 info 02200301600194731900: None of the discovered devices matches 😞
    tuya.0 2019-09-05 08:04:50.905 debug 02200301600194731900: Try to initialize encrypted device with received UDP messages: version=undefined, key=5dffb2235e73d795
    tuya.0 2019-09-05 08:04:50.878 debug stateChange tuya.0.01200803ecfabc819d1e.8 {"val":"ffff8006ff000000ff000000ffff0000ff0000ff0000","ack":true,"ts":1567663490851,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567
    tuya.0 2019-09-05 08:04:50.848 debug stateChange tuya.0.01200803ecfabc819d1e.7 {"val":"ffff3301ff0084","ack":true,"ts":1567663490821,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148037}
    tuya.0 2019-09-05 08:04:50.818 debug stateChange tuya.0.01200803ecfabc819d1e.6 {"val":"bd76000168ffff","ack":true,"ts":1567663490791,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148026}
    tuya.0 2019-09-05 08:04:50.788 debug stateChange tuya.0.01200803ecfabc819d1e.5 {"val":"ff25000008ffff","ack":true,"ts":1567663490765,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148024}
    tuya.0 2019-09-05 08:04:50.756 debug stateChange tuya.0.01200803ecfabc819d1e.4 {"val":255,"ack":true,"ts":1567663490728,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148009}
    tuya.0 2019-09-05 08:04:50.725 debug stateChange tuya.0.01200803ecfabc819d1e.3 {"val":255,"ack":true,"ts":1567663490695,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148006}
    tuya.0 2019-09-05 08:04:50.692 debug stateChange tuya.0.01200803ecfabc819d1e.2 {"val":"1","ack":true,"ts":1567663490661,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147996}
    tuya.0 2019-09-05 08:04:50.658 debug stateChange tuya.0.01200803ecfabc819d1e.1 {"val":false,"ack":true,"ts":1567663490632,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618230760}
    tuya.0 2019-09-05 08:04:50.497 debug stateChange tuya.0.02200301600194731900.10 {"val":"ffff0505ff000000ff00ffff00ff00ff0000ff000000","ack":true,"ts":1567663490471,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":156
    tuya.0 2019-09-05 08:04:50.468 debug stateChange tuya.0.02200301600194731900.9 {"val":"ffff5001ff0000","ack":true,"ts":1567663490442,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147954}
    tuya.0 2019-09-05 08:04:50.440 debug stateChange tuya.0.02200301600194731900.8 {"val":"ffff8003ff000000ff000000ff000000000000000000","ack":true,"ts":1567663490414,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567
    tuya.0 2019-09-05 08:04:50.411 debug stateChange tuya.0.02200301600194731900.7 {"val":"ffff500100ff00","ack":true,"ts":1567663490385,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147941}
    tuya.0 2019-09-05 08:04:50.382 debug stateChange tuya.0.02200301600194731900.6 {"val":"00ff0000000000","ack":true,"ts":1567663490356,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147930}
    tuya.0 2019-09-05 08:04:50.353 debug stateChange tuya.0.02200301600194731900.5 {"val":"ff46000010ffff","ack":true,"ts":1567663490327,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147927}
    tuya.0 2019-09-05 08:04:50.324 debug stateChange tuya.0.02200301600194731900.4 {"val":255,"ack":true,"ts":1567663490298,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147911}
    tuya.0 2019-09-05 08:04:50.295 debug stateChange tuya.0.02200301600194731900.3 {"val":255,"ack":true,"ts":1567663490267,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147909}
    tuya.0 2019-09-05 08:04:50.264 debug stateChange tuya.0.02200301600194731900.2 {"val":"1","ack":true,"ts":1567663490235,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147887}
    tuya.0 2019-09-05 08:04:50.257 debug stateChange tuya.0.02200301600194731900.1 {"val":false,"ack":true,"ts":1567663490229,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618224893}
    tuya.0 2019-09-05 08:04:50.075 debug sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
    tuya.0 2019-09-05 08:04:50.075 debug Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":52,"ack":false,"time":1567663490067},"_id":59700406}
    tuya.0 2019-09-05 08:04:50.073 debug stateChange tuya.0.01200803ecfabc819d1e.online {"val":false,"ack":true,"ts":1567663490047,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147981}
    tuya.0 2019-09-05 08:04:50.072 debug stateChange tuya.0.02200301600194731900.online {"val":false,"ack":true,"ts":1567663490038,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147857}
    tuya.0 2019-09-05 08:04:50.044 debug sendTo "getProxyResult" to system.adapter.admin.0 from system.adapter.tuya.0
    tuya.0 2019-09-05 08:04:50.041 debug 01200803ecfabc819d1e: Create device objects if not exist
    tuya.0 2019-09-05 08:04:50.040 debug 01200803ecfabc819d1e: Schema found for xw0AjeWMmnX0LX7Z: {"schema":[{"mode":"rw","code":"led_switch","name":"开关","property":{"type":"bool"},"iconname":"icon-dp_power2","id":1,"type":"obj","desc":""},
    tuya.0 2019-09-05 08:04:50.035 debug 02200301600194731900: Create device objects if not exist
    sigi234S Online
    sigi234S Online
    sigi234
    #501
    @varg
    Bitte benutzt die Code Tags Funktion -> </>
    Immer Daten sichern!
    V 1 Antwort Letzte Antwort
    • sigi234S sigi234
      @varg
      V Offline
      V Offline
      varg
      #502
      @sigi234 erledigt. sorry
      • apollon77A Offline
        #503
        Also zwei Geräte sind da und verbunden. Zwei ander nicht. Dazu einmal mit dem Proxy arbeiten. Ich sehe in Code nur wie der Proxy gestoppt wird. Hast du ihn gestartet und erfolgreich Sync gemacht?
        • apollon77A apollon77
          V Offline
          V Offline
          varg
          schrieb am zuletzt editiert von varg
          #504
          @apollon77
          es gibt nur diese beiden geräte, welche als nicht verbunden angezeigt werden. Der sync lief erfolgreich via smartlife app durch.
          Auf Deine Nachfrage zwecks log habe ich den proxy nochmals gestartet und auch auf dem smartphone zerti und proxy eingegeben. Daraus ergab sich jedoch keine Änderung.
          tuya.0	2019-09-05 21:11:06.826	debug	sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
          tuya.0	2019-09-05 21:11:06.826	debug	Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":178,"ack":false,"time":1567710666820},"_id":59700712}
          host.raspberrypi	2019-09-05 21:10:52.126	info	Restart adapter system.adapter.tuya.0 because enabled
          host.raspberrypi	2019-09-05 21:10:52.125	error	instance system.adapter.tuya.0 terminated with code 7 (Adapter already running)
          host.raspberrypi	2019-09-05 21:10:51.233	info	instance system.adapter.tuya.0 started with pid 4061
          host.raspberrypi	2019-09-05 21:10:21.220	info	Restart adapter system.adapter.tuya.0 because enabled
          host.raspberrypi	2019-09-05 21:10:21.220	error	instance system.adapter.tuya.0 terminated with code 7 (Adapter already running)
          tuya.0	2019-09-05 21:10:21.208	error	already running
          tuya.0	2019-09-05 21:10:21.202	debug	statesDB connected
          tuya.0	2019-09-05 21:10:21.176	debug	objectDB connected
          host.raspberrypi	2019-09-05 21:10:20.301	info	instance system.adapter.tuya.0 started with pid 3413
          ECONNRESET
          tuya.0	2019-09-05 21:10:06.820	debug	sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
          tuya.0	2019-09-05 21:10:06.820	debug	Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":176,"ack":false,"time":1567710606818},"_id":59700708}
          host.raspberrypi	2019-09-05 21:09:50.280	info	Restart adapter system.adapter.tuya.0 because enabled
          host.raspberrypi	2019-09-05 21:09:50.279	error	instance system.adapter.tuya.0 terminated with code 7 (Adapter already running)
          tuya.0	2019-09-05 21:09:50.270	debug	stateChange tuya.0.info.connection {"val":false,"ack":true,"ts":1567710590268,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567617072084}
          tuya.0	2019-09-05 21:09:50.265	error	already running
          tuya.0	2019-09-05 21:09:50.258	debug	statesDB connected
          tuya.0	2019-09-05 21:09:50.230	debug	objectDB connected
          raspberry pi 4 buster
          node v10.16.3
          npm 6.9.0
          vor etwa einer Stunde hatte ich etliche weitere Fehlermeldungen im log. Dummerweise gelöscht. Falls es nochmals auftritt poste ich es.
          Nach reboot erstmal diese Meldungen:
          tuya.0	2019-09-05 21:29:19.209	info	Listen for encrypted local Tuya devices on port 6667
          tuya.0	2019-09-05 21:29:19.209	info	Listen for local Tuya devices on port 6666
          tuya.0	2019-09-05 21:29:19.209	info	Existing devices initialized
          tuya.0	2019-09-05 21:29:19.209	info	02200301600194731900: None of the discovered devices matches :-(
          tuya.0	2019-09-05 21:29:19.209	debug	02200301600194731900: Try to initialize encrypted device with received UDP messages: version=undefined, key=5dffb2235e73d795
          tuya.0	2019-09-05 21:29:19.208	info	01200803ecfabc819d1e: None of the discovered devices matches :-(
          tuya.0	2019-09-05 21:29:19.207	debug	01200803ecfabc819d1e: Try to initialize encrypted device with received UDP messages: version=undefined, key=134a0d1b36f6478b
          tuya.0	2019-09-05 21:29:18.875	debug	01200803ecfabc819d1e: Create device objects if not exist
          tuya.0	2019-09-05 21:29:18.875	debug	02200301600194731900: Create device objects if not exist
          tuya.0	2019-09-05 21:29:18.873	debug	init 2 known devices
          tuya.0	2019-09-05 21:29:18.830	debug	connected set to false
          tuya.0	2019-09-05 21:29:18.815	info	starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.tuya, node: v10.16.3
          Gerade nochmals Proxy und App gestartet:
          "Erfolg! 2 Geräte und 1 Schemata wurden erkannt. Überprüfen Sie das Log, wenn neue Schemas an den Entwickler gemeldet werden sollen. Der Proxy wird in 10 Sekunden ausgeschaltet"
          tuya.0	2019-09-05 21:36:25.502	debug	sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
          tuya.0	2019-09-05 21:36:25.501	debug	Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":26,"ack":false,"time":1567712185490},"_id":48972593}
          tuya.0	2019-09-05 21:36:21.677	debug	sendTo "stopProxy" to system.adapter.admin.0 from system.adapter.tuya.0
          tuya.0	2019-09-05 21:36:21.676	debug	Message: {"command":"stopProxy","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":24,"ack":false,"time":1567712181670},"_id":48972589}
          tuya.0	2019-09-05 21:36:08.192	debug	stateChange tuya.0.01200803ecfabc819d1e.10 {"val":"ffff0506ff000000ff00ffff00ff00ff0000ffff0000","ack":true,"ts":1567712168189,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":156
          tuya.0	2019-09-05 21:36:08.192	info	01200803ecfabc819d1e: None of the discovered devices matches :-(
          tuya.0	2019-09-05 21:36:08.192	debug	01200803ecfabc819d1e: Try to initialize encrypted device with received UDP messages: version=undefined, key=134a0d1b36f6478b
          tuya.0	2019-09-05 21:36:08.185	debug	stateChange tuya.0.01200803ecfabc819d1e.9 {"val":"ffff5001ff0000","ack":true,"ts":1567712168178,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148052}
          tuya.0	2019-09-05 21:36:08.182	info	02200301600194731900: None of the discovered devices matches :-(
          tuya.0	2019-09-05 21:36:08.182	debug	02200301600194731900: Try to initialize encrypted device with received UDP messages: version=undefined, key=5dffb2235e73d795
          tuya.0	2019-09-05 21:36:08.181	debug	stateChange tuya.0.01200803ecfabc819d1e.8 {"val":"ffff8006ff000000ff000000ffff0000ff0000ff0000","ack":true,"ts":1567712168175,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567
          tuya.0	2019-09-05 21:36:08.159	debug	stateChange tuya.0.01200803ecfabc819d1e.7 {"val":"ffff3301ff0084","ack":true,"ts":1567712168156,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148037}
          tuya.0	2019-09-05 21:36:08.146	debug	stateChange tuya.0.01200803ecfabc819d1e.6 {"val":"bd76000168ffff","ack":true,"ts":1567712168141,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148026}
          tuya.0	2019-09-05 21:36:08.131	debug	stateChange tuya.0.01200803ecfabc819d1e.5 {"val":"ff25000008ffff","ack":true,"ts":1567712168129,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148024}
          tuya.0	2019-09-05 21:36:08.102	debug	stateChange tuya.0.01200803ecfabc819d1e.4 {"val":255,"ack":true,"ts":1567712168096,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148009}
          tuya.0	2019-09-05 21:36:08.075	debug	stateChange tuya.0.01200803ecfabc819d1e.3 {"val":255,"ack":true,"ts":1567712168068,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148006}
          tuya.0	2019-09-05 21:36:08.062	debug	stateChange tuya.0.01200803ecfabc819d1e.2 {"val":"1","ack":true,"ts":1567712168051,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147996}
          tuya.0	2019-09-05 21:36:08.042	debug	stateChange tuya.0.01200803ecfabc819d1e.1 {"val":true,"ack":true,"ts":1567712168035,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567711994790}
          tuya.0	2019-09-05 21:36:08.031	debug	stateChange tuya.0.02200301600194731900.10 {"val":"ffff0505ff000000ff00ffff00ff00ff0000ff000000","ack":true,"ts":1567712168021,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":156
          tuya.0	2019-09-05 21:36:08.016	debug	stateChange tuya.0.02200301600194731900.9 {"val":"ffff5001ff0000","ack":true,"ts":1567712168004,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147954}
          tuya.0	2019-09-05 21:36:08.000	debug	stateChange tuya.0.02200301600194731900.8 {"val":"ffff8003ff000000ff000000ff000000000000000000","ack":true,"ts":1567712167992,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567
          tuya.0	2019-09-05 21:36:07.987	debug	stateChange tuya.0.02200301600194731900.7 {"val":"ffff500100ff00","ack":true,"ts":1567712167978,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147941}
          tuya.0	2019-09-05 21:36:07.962	debug	stateChange tuya.0.02200301600194731900.6 {"val":"00ff0000000000","ack":true,"ts":1567712167954,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147930}
          tuya.0	2019-09-05 21:36:07.957	debug	stateChange tuya.0.02200301600194731900.5 {"val":"ff46000010ffff","ack":true,"ts":1567712167951,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147927}
          tuya.0	2019-09-05 21:36:07.941	debug	stateChange tuya.0.02200301600194731900.4 {"val":255,"ack":true,"ts":1567712167929,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147911}
          tuya.0	2019-09-05 21:36:07.934	debug	stateChange tuya.0.02200301600194731900.3 {"val":255,"ack":true,"ts":1567712167924,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147909}
          tuya.0	2019-09-05 21:36:07.911	debug	stateChange tuya.0.02200301600194731900.2 {"val":"1","ack":true,"ts":1567712167905,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147887}
          tuya.0	2019-09-05 21:36:07.906	debug	stateChange tuya.0.02200301600194731900.1 {"val":true,"ack":true,"ts":1567712167904,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567711994673}
          tuya.0	2019-09-05 21:36:07.875	debug	stateChange tuya.0.01200803ecfabc819d1e.online {"val":false,"ack":true,"ts":1567712167869,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147981}
          tuya.0	2019-09-05 21:36:07.874	debug	stateChange tuya.0.02200301600194731900.online {"val":false,"ack":true,"ts":1567712167859,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147857}
          tuya.0	2019-09-05 21:36:07.863	debug	01200803ecfabc819d1e: Create device objects if not exist
          tuya.0	2019-09-05 21:36:07.861	debug	01200803ecfabc819d1e: Schema found for xw0AjeWMmnX0LX7Z: {"schema":[{"mode":"rw","code":"led_switch","name":"开关","property":{"type":"bool"},"iconname":"icon-dp_power2","id":1,"type":"obj","desc":""},
          tuya.0	2019-09-05 21:36:07.857	debug	02200301600194731900: Create device objects if not exist
          tuya.0	2019-09-05 21:36:07.856	debug	02200301600194731900: Schema found for xw0AjeWMmnX0LX7Z: {"schema":[{"mode":"rw","code":"led_switch","name":"开关","property":{"type":"bool"},"iconname":"icon-dp_power2","id":1,"type":"obj","desc":""},
          tuya.0	2019-09-05 21:36:07.855	debug	Found 2 devices
          tuya.0	2019-09-05 21:36:07.855	debug	Found 1 device schema information
          tuya.0	2019-09-05 21:36:06.909	debug	stateChange tuya.0.01200803ecfabc819d1e.10 {"val":"ffff0506ff000000ff00ffff00ff00ff0000ffff0000","ack":true,"ts":1567712166905,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":156
          tuya.0	2019-09-05 21:36:06.908	info	01200803ecfabc819d1e: None of the discovered devices matches :-(
          tuya.0	2019-09-05 21:36:06.908	debug	01200803ecfabc819d1e: Try to initialize encrypted device with received UDP messages: version=undefined, key=134a0d1b36f6478b
          tuya.0	2019-09-05 21:36:06.906	info	02200301600194731900: None of the discovered devices matches :-(
          tuya.0	2019-09-05 21:36:06.906	debug	02200301600194731900: Try to initialize encrypted device with received UDP messages: version=undefined, key=5dffb2235e73d795
          tuya.0	2019-09-05 21:36:06.905	debug	stateChange tuya.0.01200803ecfabc819d1e.9 {"val":"ffff5001ff0000","ack":true,"ts":1567712166903,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148052}
          tuya.0	2019-09-05 21:36:06.894	debug	stateChange tuya.0.01200803ecfabc819d1e.8 {"val":"ffff8006ff000000ff000000ffff0000ff0000ff0000","ack":true,"ts":1567712166888,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567
          tuya.0	2019-09-05 21:36:06.890	debug	stateChange tuya.0.01200803ecfabc819d1e.7 {"val":"ffff3301ff0084","ack":true,"ts":1567712166886,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148037}
          tuya.0	2019-09-05 21:36:06.875	debug	stateChange tuya.0.01200803ecfabc819d1e.6 {"val":"bd76000168ffff","ack":true,"ts":1567712166868,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148026}
          tuya.0	2019-09-05 21:36:06.871	debug	stateChange tuya.0.01200803ecfabc819d1e.5 {"val":"ff25000008ffff","ack":true,"ts":1567712166866,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148024}
          tuya.0	2019-09-05 21:36:06.853	debug	stateChange tuya.0.01200803ecfabc819d1e.4 {"val":255,"ack":true,"ts":1567712166848,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148009}
          tuya.0	2019-09-05 21:36:06.849	debug	stateChange tuya.0.01200803ecfabc819d1e.3 {"val":255,"ack":true,"ts":1567712166847,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618148006}
          tuya.0	2019-09-05 21:36:06.835	debug	stateChange tuya.0.01200803ecfabc819d1e.2 {"val":"1","ack":true,"ts":1567712166825,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147996}
          tuya.0	2019-09-05 21:36:06.828	debug	stateChange tuya.0.01200803ecfabc819d1e.1 {"val":true,"ack":true,"ts":1567712166823,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567711994790}
          tuya.0	2019-09-05 21:36:06.815	debug	stateChange tuya.0.02200301600194731900.10 {"val":"ffff0505ff000000ff00ffff00ff00ff0000ff000000","ack":true,"ts":1567712166809,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":156
          tuya.0	2019-09-05 21:36:06.811	debug	stateChange tuya.0.02200301600194731900.9 {"val":"ffff5001ff0000","ack":true,"ts":1567712166807,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147954}
          tuya.0	2019-09-05 21:36:06.797	debug	stateChange tuya.0.02200301600194731900.8 {"val":"ffff8003ff000000ff000000ff000000000000000000","ack":true,"ts":1567712166792,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567
          tuya.0	2019-09-05 21:36:06.794	debug	stateChange tuya.0.02200301600194731900.7 {"val":"ffff500100ff00","ack":true,"ts":1567712166790,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147941}
          tuya.0	2019-09-05 21:36:06.782	debug	stateChange tuya.0.02200301600194731900.6 {"val":"00ff0000000000","ack":true,"ts":1567712166775,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147930}
          tuya.0	2019-09-05 21:36:06.778	debug	stateChange tuya.0.02200301600194731900.5 {"val":"ff46000010ffff","ack":true,"ts":1567712166772,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147927}
          tuya.0	2019-09-05 21:36:06.747	debug	stateChange tuya.0.02200301600194731900.4 {"val":255,"ack":true,"ts":1567712166738,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147911}
          tuya.0	2019-09-05 21:36:06.739	debug	stateChange tuya.0.02200301600194731900.3 {"val":255,"ack":true,"ts":1567712166735,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147909}
          tuya.0	2019-09-05 21:36:06.704	debug	stateChange tuya.0.02200301600194731900.2 {"val":"1","ack":true,"ts":1567712166691,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147887}
          tuya.0	2019-09-05 21:36:06.703	debug	stateChange tuya.0.02200301600194731900.1 {"val":true,"ack":true,"ts":1567712166689,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567711994673}
          tuya.0	2019-09-05 21:36:06.679	debug	sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
          tuya.0	2019-09-05 21:36:06.679	debug	Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":23,"ack":false,"time":1567712166670},"_id":48972587}
          tuya.0	2019-09-05 21:36:06.670	debug	stateChange tuya.0.01200803ecfabc819d1e.online {"val":false,"ack":true,"ts":1567712166660,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147981}
          tuya.0	2019-09-05 21:36:06.670	debug	stateChange tuya.0.02200301600194731900.online {"val":false,"ack":true,"ts":1567712166645,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1567618147857}
          tuya.0	2019-09-05 21:36:06.656	debug	sendTo "getProxyResult" to system.adapter.admin.0 from system.adapter.tuya.0
          tuya.0	2019-09-05 21:36:06.652	debug	01200803ecfabc819d1e: Create device objects if not exist
          tuya.0	2019-09-05 21:36:06.649	debug	01200803ecfabc819d1e: Schema found for xw0AjeWMmnX0LX7Z: {"schema":[{"mode":"rw","code":"led_switch","name":"开关","property":{"type":"bool"},"iconname":"icon-dp_power2","id":1,"type":"obj","desc":""},
          tuya.0	2019-09-05 21:36:06.634	debug	02200301600194731900: Create device objects if not exist
          tuya.0	2019-09-05 21:36:06.632	debug	02200301600194731900: Schema found for xw0AjeWMmnX0LX7Z: {"schema":[{"mode":"rw","code":"led_switch","name":"开关","property":{"type":"bool"},"iconname":"icon-dp_power2","id":1,"type":"obj","desc":""},
          tuya.0	2019-09-05 21:36:06.631	debug	Found 2 devices
          tuya.0	2019-09-05 21:36:06.630	debug	Found 1 device schema information
          tuya.0	2019-09-05 21:35:55.589	debug	Message: {"command":"getProxyResult","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":22,"ack":false,"time":1567712155586},"_id":48972585}
          tuya.0	2019-09-05 21:35:55.563	debug	sendTo "startProxy" to system.adapter.admin.0 from system.adapter.tuya.0
          tuya.0	2019-09-05 21:35:55.457	info	SSL-Proxy ready to receive requests
          tuya.0	2019-09-05 21:35:55.433	debug	Use first network interface (192.168.178.70)
          tuya.0	2019-09-05 21:35:55.431	debug	Message: {"command":"startProxy","message":{"proxyPort":"8888","proxyWebPort":"8889"},"from":"system.adapter.admin.0","callback":{"message":{"proxyPort":"8888","proxyWebPort":"8889"},"id":21,"ack":fa
          tuya.0	2019-09-05 21:35:54.120	debug	sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
          tuya.0	2019-09-05 21:35:54.120	debug	Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":20,"ack":false,"time":1567712154117},"_id":48972581}
          tuya.0	2019-09-05 21:35:33.678	debug	sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
          tuya.0	2019-09-05 21:35:33.678	debug	Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":19,"ack":false,"time":1567712133673},"_id":48972579}
          tuya.0	2019-09-05 21:40:05.963	debug	sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
          tuya.0	2019-09-05 21:40:05.963	debug	Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":32,"ack":false,"time":1567712405955},"_id":48972609}
          tuya.0	2019-09-05 21:39:57.336	debug	system.adapter.admin.0: logging true
          tuya.0	2019-09-05 21:39:51.757	debug	02200301600194731900Device communication not initialized ...
          tuya.0	2019-09-05 21:39:51.756	debug	stateChange tuya.0.02200301600194731900.1 {"val":false,"ack":false,"ts":1567712391751,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1567712391751}
          keine Änderung, Geräte sind nicht steuerbar. Adapter bleibt gelb.
          "Status: 2 Geräte im Netzwerk gefunden, 0 Geräte verbunden, 2 mit bekanntem Schema, 2 initialisiert für Echtzeit-Updates und zur Steuerung"
            A.J.
            #505
            Moin moin,
            erstmal vielen Dank an @apollon77 für den Adapter und danach an euch alle, für die tolle Community hier.
            Ich würde gerne diesen Adapter bei mir zum laufen bringen aber Scheiter leider immer wieder bei der Proxy-Sync. Habe hier viele Beiträge gelesen, einige verlinkte Videos mir angeschaut und gehe ganz nach Anleitung vor aber es klappt einfach nicht.
            Der AnyProxy läuft und greift auch alle zugriffe vom Handy ab aber bei tuya hat es scheinbar ein Verbindungsproblem. (siehe Scrennshot) ich kann z.b. einfach heise.de aufrufen und komme dann auch auf der Heise Seite. Im AnyProxy sehe ich dann auch jede einzelne zugriff. Rufe ich die SmartLife App auf sieht es dann anders auf. Die App meldet dann auch Verbindungsprobleme.
            Ich hab wirklich alles versucht, mit ios oder Android. Habe sogar mein iobrocker komplet neu aufgesetzt aber immer das gleiche Problem! vielleicht kann mir jemand hier helfen!
            Danke und Grüße
            A.J.
            • A A.J.
              Moin moin,
              Danke und Grüße
              A.J.
              #506
              @A-J Anyproxy ist tod. Bitte die 3.0.0 vom Github versuchen ...
                Moskito
                #507
                Hallo!
                Nachdem Version 2 nicht mehr funktioniert habe ich die Version 3 getestet.
                Leider bekomme ich folgende Meldungen:
                2019-09-11 17:33:31.787  - info: host.iobroker object change system.adapter.tuya.0
                2019-09-11 17:33:31.787  - info: host.iobroker stopInstance system.adapter.tuya.0
                2019-09-11 17:33:31.788  - info: host.iobroker stopInstance system.adapter.tuya.0 killing pid 6912
                2019-09-11 17:33:34.311  - info: host.iobroker instance system.adapter.tuya.0 started with pid 14822
                2019-09-11 17:33:34.840  - info: host.iobroker instance system.adapter.tuya.0 terminated with code 156 ()
                2019-09-11 17:33:35.718  - info: tuya.0 starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.tuya, node: v10.16.3
                2019-09-11 17:33:35.793  - info: tuya.0 Existing devices initialized
                2019-09-11 17:33:35.812  - info: tuya.0 Listen for local Tuya devices on port 6666
                2019-09-11 17:33:35.812  - info: tuya.0 Listen for encrypted local Tuya devices on port 6667
                2019-09-11 17:34:44.382  - info: tuya.0 SSL-Proxy ready to receive requests
                2019-09-11 17:34:59.725  - error: tuya.0 SSL-Proxy ERROR: Error: 140287171663680:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                2019-09-11 17:34:59.727  - error: tuya.0 Error: 140287171663680:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                2019-09-11 17:35:00.798  - error: tuya.0 SSL-Proxy ERROR: Error: 140287171663680:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                2019-09-11 17:35:00.801  - error: tuya.0 Error: 140287171663680:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                2019-09-11 17:35:00.802  - error: tuya.0 SSL-Proxy ERROR: Error: 140287171663680:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                2019-09-11 17:35:00.803  - error: tuya.0 Error: 140287171663680:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                2019-09-11 17:35:00.808  - error: tuya.0 SSL-Proxy ERROR: Error: 140287171663680:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                2019-09-11 17:35:00.808  - error: tuya.0 Error: 140287171663680:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                2019-09-11 17:35:01.006  - error: tuya.0 SSL-Proxy ERROR: Error: 140287171663680:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                2019-09-11 17:35:01.006  - error: tuya.0 Error: 140287171663680:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                Ich habe dies mehrfach ausprobiert, aber leider immer das gleich Ergebnis bekommen.😞
                Viele Grüße,
                Marcus
                  benziman
                  schrieb am zuletzt editiert von benziman
                  #508
                  Hi Zusammen,
                  ich nutze den Tuyaadapter 2.0.4 mit sechs Rolladenschaltern (Gen. 3) und habe diese in einem Blocklyscript eigebunden.
                  Das Script funktioniert auch wunderbar, allerdings tritt hier bisher ein mal am Tag der Fehler auf, dass bei allen Schaltern die Stopptaste blinkt und die Schalter dann nicht mehr bedient werden können. Erst ein beenden und Starten des Scripts bringt abhilfe.
                  Das Log sieht dann so aus:
                  (Fehler erscheint dann im Sekundentakt!)
                  Gerne poste ich auch das Script hier (relativ Umfangreich) wenn das helfen solte. (Bild oder als Textformat?)
                  B 1 Antwort Letzte Antwort
                  • M Moskito
                    Hallo!
                    Moskito
                    #509
                    @Moskito sagte in [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere):
                    Hallo!
                    Kommando zurück!
                    Ich habe es mit der Version 3 hinbekommen.
                    Hatte nochmal alles von vorne abgearbeitet und das Zertifikat bei "VPN und Apps" und bei "WLAN" installiert.
                    Bin mir nicht sicher ob es daran lag und ich es vielleicht vorher nicht so gemacht hatte....
                    Jedenfalls sind die Objekte jetzt vorhanden.
                    Viele Grüße,
                    Marcus
                      #510
                      Für alle geschädigten der Fehler bitte mal die 3.0.1 vom GitHub versuchen. Ich hab mal ein paar Dinge versucht ... Wenn es nicht tut bitte zusammen mit Eurer nodejs Version reporten. (Auch wenns tut )
                      A 1 Antwort Letzte Antwort
                        A.J.
                        schrieb am zuletzt editiert von A.J.
                        #511
                        @apollon77 hmm, es will und will einfach nicht bei mir laufen.
                        habs jetzt mit der 3.0.1 Version auch versucht. Problem ist nach wie vor die Sync. über Proxy.
                        Vorgehensweise:
                        -Adapter über git installiert
                        • Proxy gestartet
                        • QR-Code wird angezeigt, mit ein App eingescant und auf die Seite mit Zertifikat die Datei auf Tablet geladen.
                        • Zertifikat installiert
                        • unter Wlan-Einstellung Proxy Daten eingetragen (Raspberry IP und port 8888)
                        • SmartLife App gestartet.
                        Aber da läuft scheinbar wieder etwas schief. Bin jetzt extra mit ein Andriod Tab (HUAWEI, Android 9) unterwegs
                        2019-09-12 06:48:05.939 - info: iobroker host.raspberrypi create instance tuya
                        2019-09-12 06:48:05.953 - info: iobroker host.raspberrypi object tuya.0.info.connection created
                        2019-09-12 06:48:05.984 - info: iobroker host.raspberrypi object tuya.0.info created
                        2019-09-12 06:48:06.020 - info: iobroker host.raspberrypi object system.adapter.tuya.0.outputCount created
                        2019-09-12 06:48:06.053 - info: iobroker host.raspberrypi object system.adapter.tuya.0.inputCount created
                        2019-09-12 06:48:06.087 - info: iobroker host.raspberrypi object system.adapter.tuya.0.uptime created
                        2019-09-12 06:48:06.122 - info: iobroker host.raspberrypi object system.adapter.tuya.0.memRss created
                        2019-09-12 06:48:06.155 - info: iobroker host.raspberrypi object system.adapter.tuya.0.memHeapTotal created
                        2019-09-12 06:48:06.189 - info: iobroker host.raspberrypi object system.adapter.tuya.0.memHeapUsed created
                        2019-09-12 06:48:06.225 - info: iobroker host.raspberrypi object system.adapter.tuya.0.cputime created
                        2019-09-12 06:48:06.257 - info: iobroker host.raspberrypi object system.adapter.tuya.0.cpu created
                        2019-09-12 06:48:06.291 - info: iobroker host.raspberrypi object system.adapter.tuya.0.connected created
                        2019-09-12 06:48:06.323 - info: iobroker host.raspberrypi object system.adapter.tuya.0.alive created
                        2019-09-12 06:48:06.374 - info: host.raspberrypi object change system.adapter.tuya.0
                        2019-09-12 06:48:06.387 - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 19367
                        2019-09-12 06:48:06.400 - info: iobroker host.raspberrypi object system.adapter.tuya.0 created
                        2019-09-12 06:48:06.419 - info: iobroker exit 0
                        2019-09-12 06:48:08.332 - info: tuya.0 starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.tuya, node: v10.16.3
                        2019-09-12 06:48:08.428 - info: tuya.0 Existing devices initialized
                        2019-09-12 06:48:08.450 - info: tuya.0 Listen for local Tuya devices on port 6666
                        2019-09-12 06:48:08.451 - info: tuya.0 Listen for encrypted local Tuya devices on port 6667
                        2019-09-12 06:48:08.560 - info: tuya.0 3050061084f3eb745219 Init with IP=192.168.178.89, Key=undefined, Version=3.1
                        2019-09-12 06:48:08.566 - info: tuya.0 3050061084f3eb745219: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                        2019-09-12 06:48:08.609 - info: tuya.0 3050061084f3eb745219: No schema exists, init basic states ...
                        2019-09-12 06:48:08.858 - info: tuya.0 05110774cc50e3490fe1 Init with IP=192.168.178.77, Key=undefined, Version=3.1
                        2019-09-12 06:48:08.859 - info: tuya.0 05110774cc50e3490fe1: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                        2019-09-12 06:48:08.878 - info: tuya.0 05110774cc50e3490fe1: No schema exists, init basic states ...
                        2019-09-12 06:48:10.123 - info: tuya.0 36822714807d3a3f2518 Init with IP=192.168.178.78, Key=undefined, Version=3.1
                        2019-09-12 06:48:10.125 - info: tuya.0 36822714807d3a3f2518: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                        2019-09-12 06:48:11.273 - info: tuya.0 36822714807d3a3f271d Init with IP=192.168.178.76, Key=undefined, Version=3.1
                        2019-09-12 06:48:11.274 - info: tuya.0 36822714807d3a3f271d: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                        2019-09-12 06:48:11.285 - info: tuya.0 36822714807d3a3f2741 Init with IP=192.168.178.75, Key=undefined, Version=3.1
                        2019-09-12 06:48:11.286 - info: tuya.0 36822714807d3a3f2741: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                        2019-09-12 06:48:11.438 - info: tuya.0 01530667807d3a1e2e98 Init with IP=192.168.178.29, Key=undefined, Version=3.1
                        2019-09-12 06:48:11.439 - info: tuya.0 01530667807d3a1e2e98: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                        2019-09-12 06:48:11.463 - info: tuya.0 01530667807d3a1e2e98: No schema exists, init basic states ...
                        2019-09-12 06:55:41.467 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
                        2019-09-12 07:00:55.143 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
                        2019-09-12 07:02:00.149 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
                        2019-09-12 07:07:51.465 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
                        2019-09-12 07:08:56.470 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
                        2019-09-12 07:13:57.313 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
                        2019-09-12 07:15:29.266 - info: info.0 Popup-News readed...
                        2019-09-12 07:20:51.476 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
                        2019-09-12 07:21:56.481 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
                        2019-09-12 07:28:25.414 - info: tuya.0 01530667807d3a1e2e98 Init with IP=192.168.178.29, Key=undefined, Version=3.1
                        2019-09-12 07:28:25.416 - info: tuya.0 01530667807d3a1e2e98: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                        2019-09-12 07:30:15.825 - info: tuya.0 SSL-Proxy ready to receive requests
                        2019-09-12 07:32:20.418 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:32:20.418 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:32:21.177 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:32:21.178 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:32:22.644 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:32:22.644 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:32:25.471 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
                        2019-09-12 07:32:25.659 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:32:25.659 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:32:29.186 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:32:29.187 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:32:35.608 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:32:35.609 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:32:46.346 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:32:46.347 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:33:02.654 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:33:02.654 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:33:30.474 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
                        2019-09-12 07:33:33.532 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:33:33.533 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:34:01.370 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:34:01.370 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:34:01.445 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:34:01.445 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:34:02.784 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:34:02.785 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:34:05.102 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:34:05.102 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:34:09.961 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:34:09.962 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:34:15.574 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:34:15.575 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:34:19.886 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:34:19.887 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:34:21.208 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:34:21.209 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:34:27.549 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:34:27.550 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:34:43.101 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:34:43.101 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:35:19.074 - error: tuya.0 SSL-Proxy ERROR: Error: getaddrinfo ENOTFOUND ksckichr ksckichr:80
                        2019-09-12 07:35:19.075 - error: tuya.0 Error: getaddrinfo ENOTFOUND ksckichr ksckichr:80
                        at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:56:26)
                        2019-09-12 07:35:19.076 - error: tuya.0 SSL-Proxy ERROR: Error: getaddrinfo ENOTFOUND bmwtumghdz bmwtumghdz:80
                        2019-09-12 07:35:19.077 - error: tuya.0 Error: getaddrinfo ENOTFOUND bmwtumghdz bmwtumghdz:80
                        2019-09-12 07:35:19.078 - error: tuya.0 SSL-Proxy ERROR: Error: getaddrinfo ENOTFOUND vhdudyjdwcp vhdudyjdwcp:80
                        2019-09-12 07:35:19.078 - error: tuya.0 Error: getaddrinfo ENOTFOUND vhdudyjdwcp vhdudyjdwcp:80
                        2019-09-12 07:35:38.251 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:35:38.251 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:36:02.161 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:36:02.162 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:36:06.555 - error: tuya.0 SSL-Proxy ERROR: Error: socket hang up
                        2019-09-12 07:36:06.556 - error: tuya.0 Error: socket hang up
                        at TLSSocket.onSocketClose (_tls_wrap.js:764:23)
                        at TLSSocket.emit (events.js:203:15)
                        at _handle.close (net.js:606:12)
                        at Socket.done (_tls_wrap.js:388:7)
                        at Object.onceWrapper (events.js:286:20)
                        at Socket.emit (events.js:198:13)
                        at TCP._handle.close (net.js:606:12)
                        2019-09-12 07:36:19.244 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:36:19.245 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:36:19.296 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14209102:SSL routines:tls_early_post_process_client_hello:unsupported protocol:../deps/openssl/openssl/ssl/statem/statem_srvr.c:1667:
                        2019-09-12 07:36:19.297 - error: tuya.0 Error: 1995598288:error:14209102:SSL routines:tls_early_post_process_client_hello:unsupported protocol:../deps/openssl/openssl/ssl/statem/statem_srvr.c:1667:
                        2019-09-12 07:36:52.111 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14209102:SSL routines:tls_early_post_process_client_hello:unsupported protocol:../deps/openssl/openssl/ssl/statem/statem_srvr.c:1667:
                        2019-09-12 07:36:52.111 - error: tuya.0 Error: 1995598288:error:14209102:SSL routines:tls_early_post_process_client_hello:unsupported protocol:../deps/openssl/openssl/ssl/statem/statem_srvr.c:1667:
                        2019-09-12 07:37:11.317 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        2019-09-12 07:37:11.318 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                        node: v10.16.3
                        nodejs: v10.16.3
                        npm: v6.11.3
                        • A A.J.
                          Vorgehensweise:
                          • Proxy gestartet
                          node: v10.16.3
                          nodejs: v10.16.3
                          npm: v6.11.3
                          Moskito
                          #512
                          @A-J sagte in [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere):
                          Installier das Zertifikat auch mal unter "VPN und Apps".
                          Ich habe auch ein HUAWEI und danach hat es bei mir funktioniert....
                          Viele Grüße,
                          Marcus
                          • M Moskito
                            A.J.
                            #513
                            @Moskito Wie meinst du das? Wenn ich das Zertifikat Downloade, installiere ich das doch inter VPN und Apps oder habe ich da was falsch verstanden?
                            • A A.J.
                              Moskito
                              #514
                              @A-J Installier es unter "VPN und APPS" UND unter WLAN. Also Zertifikat zweimal installieren.
                              Viele Grüße,
                              Marcus
                              • M Moskito
                                A.J.
                                #515
                                @Moskito Achso, das meinst du. Ja hab das auch schon probiert gehabt und eben noch einmal aber es ändert sich nichts. Weiterhin erscheint das im Log, sobald ich die App starte:
                                undefined2019-09-12 09:20:55.391 - info: tuya.0 SSL-Proxy ready to receive requests
                                2019-09-12 09:21:43.804 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
                                2019-09-12 09:22:48.810 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
                                2019-09-12 09:22:51.317 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                2019-09-12 09:22:51.318 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                2019-09-12 09:22:51.772 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                2019-09-12 09:22:51.772 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                2019-09-12 09:22:53.517 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                2019-09-12 09:22:53.518 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                2019-09-12 09:22:56.832 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                2019-09-12 09:22:56.832 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                2019-09-12 09:23:00.708 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                2019-09-12 09:23:00.708 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                2019-09-12 09:23:07.094 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                2019-09-12 09:23:07.094 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                2019-09-12 09:23:16.670 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                2019-09-12 09:23:16.671 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                2019-09-12 09:23:30.338 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                2019-09-12 09:23:30.339 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                2019-09-12 09:23:53.813 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
                                  #516
                                  mich wundern diese komischen ENOTFOUND domainnamen im oberen Log ...
                                  A 2 Antworten Letzte Antwort
                                    A.J.
                                    #517
                                    @apollon77 hmm, da bin ich leider auch überfragt. Ich wiederhole den Vorgang, mal sehen, ob ich die gleiche Fehlermeldung bekomme.
                                      A.J.
                                      #518
                                      @apollon77 ich weiß jetzt was das war, ich hatte nachdem das einmal nicht funktioniert hatte, die Seite heide.de aufgerufen um zu sehen, ob die Seite über Proxy überhaupt aufgeht oder nicht. Die Seite ging auf (also verbindung zu internet ist da) und das sind wohl irgend welche Ad-Server die heise eingebunden hat. Ähnliche ENOTFOUND habe ich angezeigt bekommen, als ich den vorgang genau so wie vorhin probiert habe.
                                      letzte versuch war jetzt ohne Aufruf von irgendwelche Seiten. siehe log:
                                      tuya.0	2019-09-12 10:55:17.830	error	Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                      tuya.0	2019-09-12 10:55:17.830	error	SSL-Proxy ERROR: Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                      tuya.0	2019-09-12 10:55:15.783	error	01530667807d3a1e2e98: Error: connection timed out
                                      tuya.0	2019-09-12 10:55:10.068	error	Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                      tuya.0	2019-09-12 10:55:10.067	error	SSL-Proxy ERROR: Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                      tuya.0	2019-09-12 10:55:05.728	error	Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                      tuya.0	2019-09-12 10:55:05.728	error	SSL-Proxy ERROR: Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                      tuya.0	2019-09-12 10:55:03.205	error	Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                      tuya.0	2019-09-12 10:55:03.204	error	SSL-Proxy ERROR: Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                      tuya.0	2019-09-12 10:55:01.501	error	Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                      tuya.0	2019-09-12 10:55:01.501	error	SSL-Proxy ERROR: Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                      tuya.0	2019-09-12 10:55:01.006	error	Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                      tuya.0	2019-09-12 10:55:01.006	error	SSL-Proxy ERROR: Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                      tuya.0	2019-09-12 10:55:01.003	error	Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                      tuya.0	2019-09-12 10:55:01.003	error	SSL-Proxy ERROR: Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                                      tuya.0	2019-09-12 10:54:10.778	error	01530667807d3a1e2e98: Error: connection timed out
                                      tuya.0	2019-09-12 10:53:05.774	error	01530667807d3a1e2e98: Error: connection timed out
                                      tuya.0	2019-09-12 10:52:21.400	info	SSL-Proxy ready to receive requests
                                      tuya.0	2019-09-12 10:52:00.770	error	01530667807d3a1e2e98: Error: connection timed out
                                      tuya.0	2019-09-12 10:49:51.022	info	05110774cc50e3490fe1: No schema exists, init basic states ...
                                      tuya.0	2019-09-12 10:49:50.840	info	05110774cc50e3490fe1: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                                      tuya.0	2019-09-12 10:49:50.839	info	05110774cc50e3490fe1 Init with IP=192.168.178.77, Key=undefined, Version=3.1
                                      tuya.0	2019-09-12 10:49:50.785	info	01530667807d3a1e2e98: No schema exists, init basic states ...
                                      tuya.0	2019-09-12 10:49:50.743	info	01530667807d3a1e2e98: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                                      tuya.0	2019-09-12 10:49:50.743	info	01530667807d3a1e2e98 Init with IP=192.168.178.29, Key=undefined, Version=3.1
                                      tuya.0	2019-09-12 10:49:50.487	info	3050061084f3eb745219: No schema exists, init basic states ...
                                      tuya.0	2019-09-12 10:49:50.472	info	3050061084f3eb745219: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                                      tuya.0	2019-09-12 10:49:50.471	info	3050061084f3eb745219 Init with IP=192.168.178.89, Key=undefined, Version=3.1
                                      tuya.0	2019-09-12 10:49:50.181	info	36822714807d3a3f271d: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                                      tuya.0	2019-09-12 10:49:50.180	info	36822714807d3a3f271d Init with IP=192.168.178.76, Key=undefined, Version=3.1
                                      tuya.0	2019-09-12 10:49:50.093	info	36822714807d3a3f2741: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                                      tuya.0	2019-09-12 10:49:50.091	info	36822714807d3a3f2741 Init with IP=192.168.178.75, Key=undefined, Version=3.1
                                      tuya.0	2019-09-12 10:49:49.218	info	36822714807d3a3f2518: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                                      tuya.0	2019-09-12 10:49:49.212	info	36822714807d3a3f2518 Init with IP=192.168.178.78, Key=undefined, Version=3.1
                                      tuya.0	2019-09-12 10:49:48.406	info	Listen for encrypted local Tuya devices on port 6667
                                      tuya.0	2019-09-12 10:49:48.405	info	Listen for local Tuya devices on port 6666
                                      tuya.0	2019-09-12 10:49:48.377	info	Existing devices initialized
                                      tuya.0	2019-09-12 10:49:48.281	info	starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.tuya, node: v10.16.3```
                                        #519
                                        heisst generell tut der proxy weil "heise.de" tut, nur die Tuya App macht nix? Oder bei elchem Aufruf kommen diese SSL Fehler?
                                          A.J.
                                          #520
                                          @apollon77 Also die letzte Log oben hat mit Heise nichts zutun. da habe ich einfach nur die App aufgerufen, nachdem ich proxy gestartet habe, das zertifikat installiert und proxy einstellung in wlan eingefügt habe.
                                          Bei irgend eine Version (ich glaube das war noch mit AnyProxy auf ios) hatte ich mal das Problem, dass die App immer internetprobleme angezeigt hat. Da hatte ich dann versucht über Browser eine Seite aufzurufen und das ging gar nicht. Deshalb hatte ich vorhin kurz auch das getestet. wollte nur wissen, ob trotz der proxy das netz überhaupt funktioniert oder nicht.
                                          Im gegensatz zu der Version mit AnyProxy funktioniert das netz, will heißen, ich komme über Browser auf andere Seiten rauf. nur gibt es im log dann diesen komischen ENOTFOUND, was sich dann auf die Ad-Server wohl bezieht.
