  4. MQTT Adapter geht seit heute nicht mehr
1 Beiträge 1 Kommentatoren 410 Aufrufe
  • H Offline
    homecineplexx
    hallo
    wollte heute bissl was arbeiten (coden), und da merk ich, mein MQTT Adapter bleibt auf gelb und wird nicht mehr grün.
    Logs sagen leider nicht viel aus:
    2018-10-17 18:41:53.669  - ESC[34mdebugESC[39m: mqtt.0 onStateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1539794513660,"q":0,"from":"system.adapter.mqtt.0","lc":1539793802461}
    2018-10-17 18:42:12.359  - ESC[32minfoESC[39m: host.raspberrypi object change system.adapter.mqtt.0
    2018-10-17 18:42:12.360  - ESC[32minfoESC[39m: host.raspberrypi stopInstance system.adapter.mqtt.0
    2018-10-17 18:42:12.360  - ESC[32minfoESC[39m: host.raspberrypi stopInstance system.adapter.mqtt.0 killing pid 3114
    2018-10-17 18:42:12.941  - ESC[32minfoESC[39m: host.raspberrypi instance system.adapter.mqtt.0 terminated with code 156 ()
    2018-10-17 18:42:14.890  - ESC[32minfoESC[39m: host.raspberrypi instance system.adapter.mqtt.0 started with pid 3131
    2018-10-17 18:42:15.847  - ESC[34mdebugESC[39m: mqtt.0 objectDB connected
    2018-10-17 18:42:15.909  - ESC[34mdebugESC[39m: mqtt.0 statesDB connected
    2018-10-17 18:42:16.026  - ESC[32minfoESC[39m: mqtt.0 starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.mqtt, node: v10.10.0
    2018-10-17 18:42:16.684  - ESC[32minfoESC[39m: mqtt.0 Starting MQTT ' authenticated  server on port 1886
    2018-10-17 18:42:16.685  - ESC[32minfoESC[39m: mqtt.0 Starting MQTT -WebSocket' authenticated  server on port 1887
    2018-10-17 18:42:16.696  - ESC[34mdebugESC[39m: mqtt.0 stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1539794536688,"q":0,"from":"system.adapter.mqtt.0","lc":1539793802461}
    2018-10-17 18:42:16.697  - ESC[34mdebugESC[39m: mqtt.0 onStateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1539794536688,"q":0,"from":"system.adapter.mqtt.0","lc":1539793802461}
