  4. Ibroker nach 24 Std. nicht erreichbar
3 Beiträge 2 Kommentatoren 461 Aufrufe
    Ragnar-Lodbrok
    ich habe den ioBroker-RasPi 1.4.2 auf eine RaspberyPi3 installiert. Nachts passiert etwas, so das ich den am nächsten Morgen vom Strom nehmen muss.
    Weder die Admin GUI von noch ein Ping auf den Raspberry geht dann noch.
    Kann das die Ursache sein ?:
    ` > 2018-10-04 06:34:24.891 - error: host.ioBroker-RasPi instance system.adapter.javascript.0 terminated with code 1 ()
    2018-10-04 06:34:29.259 - debug: fritzdect.0 [{"identifier":"099950067621","id":"16","functionbitmask":"320","fwversion":"04.70","manufacturer":"AVM","productname":"FRITZ!DECT 301","present":"1","name":"Heizkörper_Flur","temperature":{"celsius":"200","offset":"0"},"hkr":{"tist":"40","tsoll":"42","absenk":"32","komfort":"42","lock":"0","devicelock":"0","errorcode":"0","batterylow":"0","windowopenactiv":"0","battery":"100","nextchange":{"endperiod":"1538632800","tchange":"32"},"summeractive":"0","holidayactive":"0"}}]
    2018-10-04 06:34:29.261 - debug: fritzdect.0 Comet_099950067621 : errorcode :0
    2018-10-04 06:34:29.270 - debug: fritzdect.0 redis pmessage io.fritzdect.0.* io.fritzdect.0.Comet_099950067621.errorcode {"val":"0","ack":true,"ts":1538627669266,"q":0,"from":"system.adapter.fritzdect.0","lc":1538574803800}
    2018-10-04 06:34:29.273 - debug: fritzdect.0 stateChange fritzdect.0.Comet_099950067621.errorcode {"val":"0","ack":true,"ts":1538627669266,"q":0,"from":"system.adapter.fritzdect.0","lc":1538574803800}
    2018-10-04 06:34:56.085 - error: Caught by controller[0]: /opt/iobroker/node_modules/typescript/lib/typescript.js:63749
    2018-10-04 06:34:56.085 - error: Caught by controller[0]: return faL
    2018-10-04 06:34:56.085 - error: Caught by controller[0]: SyntaxError: Invalid or unexpected token
    2018-10-04 06:34:56.085 - error: Caught by controller[0]: at createScript (vm.js:80:10)
    2018-10-04 06:34:56.086 - error: Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
    2018-10-04 06:34:56.086 - error: Caught by controller[0]: at Module._compile (module.js:616:28)
    2018-10-04 06:34:56.086 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
    2018-10-04 06:34:56.086 - error: Caught by controller[0]: at Module.load (module.js:565:32)
    2018-10-04 06:34:56.086 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
    2018-10-04 06:34:56.086 - error: Caught by controller[0]: at Function.Module._load (module.js:497:3)
    2018-10-04 06:34:56.086 - error: Caught by controller[0]: at Module.require (module.js:596:17)
    2018-10-04 06:34:56.086 - error: Caught by controller[0]: at require (internal/module.js:11:18)
    2018-10-04 06:34:56.086 - error: Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/virtual-tsc/build/compiler.js:3:10)
    2018-10-04 06:34:56.086 - error: Caught by controller[0]: at Module._compile (module.js:652:30)
    2018-10-04 06:34:56.087 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
    2018-10-04 06:34:56.091 - error: Caught by controller[0]: at Function.Module._load (module.js:497:3)
    2018-10-04 06:34:56.091 - error: Caught by controller[0]: at Module.require (module.js:596:17)
    2018-10-04 06:34:56.091 - error: Caught by controller[0]: at require (internal/module.js:11:18)
    2018-10-04 06:34:56.091 - error: Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/virtual-tsc/build/index.js:3:18)
    2018-10-04 06:34:56.091 - error: Caught by controller[0]: at Module._compile (module.js:652:30)
    2018-10-04 06:34:56.091 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
    2018-10-04 06:34:56.091 - error: Caught by controller[0]: at Module.load (module.js:565:32)
    2018-10-04 06:34:56.091 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
    2018-10-04 06:34:56.092 - error: Caught by controller[0]: at Module.require (module.js:596:17)
    2018-10-04 06:34:56.092 - error: Caught by controller[0]: at require (internal/module.js:11:18)
    2018-10-04 06:34:56.092 - error: Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.javascript/javascript.js:23:27
    2018-10-04 06:34:56.092 - error: Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.javascript/javascript.js:3427:3)
    2018-10-04 06:34:56.092 - error: Caught by controller[0]: at Module._compile (module.js:652:30)
    2018-10-04 06:34:56.092 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
    2018-10-04 06:34:56.092 - error: Caught by controller[0]: at Module.load (module.js:565:32)
    2018-10-04 06:34:56.092 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
    2018-10-04 06:34:56.092 - error: Caught by controller[0]: at Function.Module._load (module.js:497:3)
    2018-10-04 06:34:56.093 - error: Caught by controller[0]: at Function.Module.runMain (module.js:693:10)
    2018-10-04 06:34:56.093 - error: Caught by controller[0]: at startup (bootstrap_node.js:188:16)
    2018-10-04 06:34:56.093 - error: Caught by controller[0]: at bootstrap_node.js:609:3
    2018-10-04 06:34:56.093 - error: host.ioBroker-RasPi instance system.adapter.javascript.0 terminated with code 1 ()
    2018-10-04 06:35:27.280 - error: Caught by controller[0]: /opt/iobroker/node_modules/typescript/lib/typescript.js:63749
    2018-10-04 06:35:27.281 - error: Caught by controller[0]: return faL
    2018-10-04 06:35:27.281 - error: Caught by controller[0]: SyntaxError: Invalid or unexpected token
    2018-10-04 06:35:27.281 - error: Caught by controller[0]: at createScript (vm.js:80:10)
    2018-10-04 06:35:27.281 - error: Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
    2018-10-04 06:35:27.281 - error: Caught by controller[0]: at Module._compile (module.js:616:28)
    2018-10-04 06:35:27.281 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
    2018-10-04 06:35:27.281 - error: Caught by controller[0]: at Module.load (module.js:565:32)
    2018-10-04 06:35:27.281 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
    2018-10-04 06:35:27.282 - error: Caught by controller[0]: at Function.Module._load (module.js:497:3)
    2018-10-04 06:35:27.282 - error: Caught by controller[0]: at Module.require (module.js:596:17)
    2018-10-04 06:35:27.282 - error: Caught by controller[0]: at require (internal/module.js:11:18)
    2018-10-04 06:35:27.282 - error: Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/virtual-tsc/build/compiler.js:3:10)
    2018-10-04 06:35:27.282 - error: Caught by controller[0]: at Module._compile (module.js:652:30)
    2018-10-04 06:35:27.282 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
    2018-10-04 06:35:27.282 - error: Caught by controller[0]: at Module.load (module.js:565:32)
    2018-10-04 06:35:27.282 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
    2018-10-04 06:35:27.282 - error: Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/virtual-tsc/build/index.js:3:18)
    2018-10-04 06:35:27.283 - error: Caught by controller[0]: at Module._compile (module.js:652:30)
    2018-10-04 06:35:27.283 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
    2018-10-04 06:35:27.283 - error: Caught by controller[0]: at Module.load (module.js:565:32)
    2018-10-04 06:35:27.283 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
    2018-10-04 06:35:27.283 - error: Caught by controller[0]: at Function.Module._load (module.js:497:3)
    2018-10-04 06:35:27.283 - error: Caught by controller[0]: at Module.require (module.js:596:17)
    2018-10-04 06:35:27.283 - error: Caught by controller[0]: at require (internal/module.js:11:18)
    2018-10-04 06:35:27.283 - error: Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.javascript/javascript.js:23:27
    2018-10-04 06:35:27.283 - error: Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.javascript/javascript.js:3427:3)
    2018-10-04 06:35:27.284 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
    2018-10-04 06:35:27.284 - error: Caught by controller[0]: at Function.Module._load (module.js:497:3)
    2018-10-04 06:35:27.284 - error: Caught by controller[0]: at Function.Module.runMain (module.js:693:10)
    2018-10-04 06:35:27.284 - error: Caught by controller[0]: at startup (bootstrap_node.js:188:16)
    2018-10-04 06:35:27.284 - error: Caught by controller[0]: at bootstrap_node.js:609:3
    2018-10-04 06:35:27.284 - error: host.ioBroker-RasPi instance system.adapter.javascript.0 terminated with code 1 ()
    2018-10-04 06:35:58.514 - error: Caught by controller[0]: /opt/iobroker/node_modules/typescript/lib/typescript.js:63749
    2018-10-04 06:35:58.515 - error: Caught by controller[0]: return faL
    2018-10-04 06:35:58.515 - error: Caught by controller[0]: SyntaxError: Invalid or unexpected token
    2018-10-04 06:35:58.515 - error: Caught by controller[0]: at createScript (vm.js:80:10)
    2018-10-04 06:35:58.515 - error: Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
    2018-10-04 06:35:58.515 - error: Caught by controller[0]: at Module._compile (module.js:616:28)
    2018-10-04 06:35:58.515 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
    2018-10-04 06:35:58.515 - error: Caught by controller[0]: at Module.load (module.js:565:32)
    2018-10-04 06:35:58.516 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
    2018-10-04 06:35:58.516 - error: Caught by controller[0]: at Function.Module._load (module.js:497:3)
    2018-10-04 06:35:58.516 - error: Caught by controller[0]: at Module.require (module.js:596:17)
    2018-10-04 06:35:58.516 - error: Caught by controller[0]: at require (internal/module.js:11:18)
    2018-10-04 06:35:58.516 - error: Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/virtual-tsc/build/compiler.js:3:10)
    2018-10-04 06:35:58.516 - error: Caught by controller[0]: at Module._compile (module.js:652:30)
    2018-10-04 06:35:58.516 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
    2018-10-04 06:35:58.516 - error: Caught by controller[0]: at Module.load (module.js:565:32)
    2018-10-04 06:35:58.516 - error: Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/virtual-tsc/build/index.js:3:18)
    2018-10-04 06:35:58.517 - error: Caught by controller[0]: at Module._compile (module.js:652:30)
    2018-10-04 06:35:58.517 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
    2018-10-04 06:35:58.517 - error: Caught by controller[0]: at Module.load (module.js:565:32)
    2018-10-04 06:35:58.517 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
    2018-10-04 06:35:58.517 - error: Caught by controller[0]: at Function.Module._load (module.js:497:3)
    2018-10-04 06:35:58.517 - error: Caught by controller[0]: at Module.require (module.js:596:17)
    2018-10-04 06:35:58.517 - error: Caught by controller[0]: at require (internal/module.js:11:18)
    2018-10-04 06:35:58.517 - error: Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.javascript/javascript.js:23:27
    2018-10-04 06:35:58.517 - error: Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.javascript/javascript.js:3427:3)
    2018-10-04 06:35:58.518 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
    2018-10-04 06:35:58.518 - error: Caught by controller[0]: at Function.Module._load (module.js:497:3)
    2018-10-04 06:35:58.518 - error: Caught by controller[0]: at Function.Module.runMain (module.js:693:10)
    2018-10-04 06:35:58.518 - error: Caught by controller[0]: at startup (bootstrap_node.js:188:16)
    2018-10-04 06:35:58.518 - error: Caught by controller[0]: at bootstrap_node.js:609:3
    2018-10-04 06:35:58.518 - error: host.ioBroker-RasPi instance system.adapter.javascript.0 terminated with code 1 ()
    2018-10-04 06:36:29.718 - error: Caught by controller[0]: /opt/iobroker/node_modules/typescript/lib/typescript.js:63749
    2018-10-04 06:36:29.718 - error: Caught by controller[0]: return faL
    2018-10-04 06:36:29.719 - error: Caught by controller[0]:</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous> `
    Hardwaresystem: NUC
    Arbeitsspeicher: 64GB
    Festplattenart: SSD
    Betriebssystem:Debian
    Nodejs-Version:3.1.6|
    ioBroker 4.2.1
    • apollon77A Offline
      Es sieht so aus als ob ein File korrupt geworden ist … das sieht eher danach aus das deine SD Karte langsam den geist aufgibt ...
        Ragnar-Lodbrok
        habe den Fehler mittlerweile gefunden. Das Gehäuse ließ den RaspberyPi3 zu heiß werden, dann schaltet er ja ab.
        Das mit der Karte werde ich mal im Auge behalten, Danke 8-)
        Hardwaresystem: NUC
        Festplattenart: SSD
        ioBroker 4.2.1
