  4. Yahka lässt sich nicht installieren
6 Beiträge 2 Kommentatoren 2.2k Aufrufe
    tomily
    Hi guys,
    habe meinen ioBroker vom Raspberry auf eine virtuelle Linux Maschine (Debian GNU/Linux 9 x64) umgezogen.
    Leider kann ich dort den Homekit bzw. Yahka Adapter nicht mehr installieren.
    Hat jemand eine Idee? Erhalte folgende Fehlermeldung.
    Kompletter Auszug des Installationsfensters:
    $ ./iobroker add yahka  --host ioBroker
    NPM version: 6.4.1
    npm install iobroker.yahka --production --save --prefix "/opt/iobroker" (System call)
    gyp
    ERR!
    build error
    gyp
     ERR! stack Error: not found: makegyp ERR! stack
         at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:13:12)gyp ERR! stack     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:68:19)
    gyp ERR! stack
         at E (/usr/lib/node_modules/npm/node_modules/which/which.js:80:29)gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/which/which.js:89:16
    gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/isexe/index.js:42:5
    gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
    gyp ERR! stack     at FSReqWrap.oncomplete (fs.js:152:21)
    gyp ERR! System Linux 4.9.0-7-amd64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/curve25519-n
    gyp ERR! node -v v8.12.0
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    npm
    ERR!
     code ELIFECYCLEnpm ERR! errno 1
    npm
     ERR! curve25519-n@1.4.0 install: `node-gyp rebuild`npm ERR! Exit status 1
    npm ERR!
     npm ERR! Failed at the curve25519-n@1.4.0 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2018-11-09T12_33_37_926Z-debug.log
    host.ioBroker install adapter yahka
    NPM version: 6.4.1npm install iobroker.yahka --production --save --prefix "/opt/iobroker" (System call)
    gyp
    ERR!
    build error
    gyp
    stack     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:13:12)gyp ERR!
     stack     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:68:19)gyp ERR! stack     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:80:29)
    gyp ERR!
     stack     at /usr/lib/node_modules/npm/node_modules/which/which.js:89:16gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/isexe/index.js:42:5
    gyp ERR! not ok
    npm
    ERR!
    code
    npm
    ERR!
     ERR! Exit status 1npm ERR!
    npm ERR!
     Failed at the curve25519-n@1.4.0 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm
    ERR!
     A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2018-11-09T12_33_48_573Z-debug.log
    gyp
    ERR!
    build error
    gyp
    ERR! stack
     Error: not found: makegyp ERR! stack     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:13:12)
    gyp ERR! stack     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:80:29)gyp ERR!
    gyp ERR! not ok
    npm
    ERR!
    code
     ELIFECYCLEnpm
    ERR! errno 1npm
     ERR! npm ERR! Failed at the curve25519-n@1.4.0 install script.
    npm ERR!
    npm
    ERR!
    npm
    ERR!     /root/.npm/_logs/2018-11-09T12_33_58_665Z-debug.log
    ERROR: host.ioBroker Cannot install yahka
    ERROR: process exited with code 13
    • apollon77A Offline
      lass mich mal für dich googeln ..
      https://www.google.com/search?q=Error%3 … 3A+makegyp
      Der erste Link sieht mal ziemlich vielversprechend aus
        tomily
        Danke! Dieser Foreneintrag ist mir trotz intensivem suchen durch die Lappen gegangen.
        Konnte den Adapter dann tatsächlich installieren. Allerdings lässt er sich nicht starten.
        Kann die kommenden Log-Einträge nicht richtig interpretieren. Vll kannst Du was damit anfangen?
        2018-11-11 12:02:39.933 - error: Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:96
        2018-11-11 12:02:39.933 - error: Caught by controller[0]: throw err
        2018-11-11 12:02:39.933 - error: Caught by controller[0]: ^
        2018-11-11 12:02:39.933 - error: Caught by controller[0]: Error: Could not locate the bindings file. Tried:
        2018-11-11 12:02:39.933 - error: Caught by controller[0]: → /opt/iobroker/node_modules/ed25519-hap/build/ed25519.node
        2018-11-11 12:02:39.933 - error: Caught by controller[0]: → /opt/iobroker/node_modules/ed25519-hap/build/Debug/ed25519.node
        2018-11-11 12:02:39.933 - error: Caught by controller[0]: → /opt/iobroker/node_modules/ed25519-hap/build/Release/ed25519.node
        2018-11-11 12:02:39.933 - error: Caught by controller[0]: → /opt/iobroker/node_modules/ed25519-hap/out/Debug/ed25519.node
        2018-11-11 12:02:39.933 - error: Caught by controller[0]: → /opt/iobroker/node_modules/ed25519-hap/Debug/ed25519.node
        2018-11-11 12:02:39.933 - error: Caught by controller[0]: → /opt/iobroker/node_modules/ed25519-hap/out/Release/ed25519.node
        2018-11-11 12:02:39.933 - error: Caught by controller[0]: → /opt/iobroker/node_modules/ed25519-hap/Release/ed25519.node
        2018-11-11 12:02:39.933 - error: Caught by controller[0]: → /opt/iobroker/node_modules/ed25519-hap/build/default/ed25519.node
        2018-11-11 12:02:39.933 - error: Caught by controller[0]: → /opt/iobroker/node_modules/ed25519-hap/compiled/8.12.0/linux/x64/ed25519.node
        2018-11-11 12:02:39.933 - error: Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:93:9)
        2018-11-11 12:02:39.933 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/ed25519-hap/index.js:1:99)
        2018-11-11 12:02:39.933 - error: Caught by controller[0]: at Module._compile (module.js:653:30)
        2018-11-11 12:02:39.933 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
        2018-11-11 12:02:39.933 - error: Caught by controller[0]: at Module.load (module.js:566:32)
        2018-11-11 12:02:39.934 - error: Caught by controller[0]: at tryModuleLoad (module.js:506:12)
        2018-11-11 12:02:39.934 - error: Caught by controller[0]: at Function.Module._load (module.js:498:3)
        2018-11-11 12:02:39.934 - error: Caught by controller[0]: at Module.require (module.js:597:17)
        2018-11-11 12:02:39.934 - error: Caught by controller[0]: at require (internal/module.js:11:18)
        2018-11-11 12:02:39.934 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/hap-nodejs/lib/HAPServer.js:8:15)
        2018-11-11 12:02:39.934 - error: host.ioBroker-test instance system.adapter.yahka.0 terminated with code 1 ()
          Nicht korrekt installiert. Zeig bitte mal das install log.
          Gesendet vom Handy …
            tomily
            im Dateianhang das Log aus dem Verzeichnis /opt/iobroker/log.
            Ich hoffe du hast das gemeint?
            In der ioBroker-Gui bekome ich nur die Einträge, die ich vorhin gesendet habe.
            Oder gibt es ein separates Install-Log?
            Grüße
            9175_iobroker.2018-11-11.log
              tomily
              Moin,
              also ich konnte den Adapter nun ans laufen bringen. Aber leider weiß ich nicht, was letztendlich das Problem gelöst hat.
              Nach der Installation der zwei fehlenden Pakete habe ich den Adapter insgesamt 3x über die Gui installiert. Beim dritten mal hat es funktioniert.
              Werde heute Abend mal ein paar Geräte einfügen und testen, ob die Bridge auch gefunden wird.
              Sorry, dass ich keine vernünftige Rückmeldung gebenkann. Trotzdem 1000 Dank !
