  4. Error delete file…
Error delete file…
4 Beiträge 4 Kommentatoren 1.3k Aufrufe
    AndyUM61
    bei mir kann ioBroker die backup-Files nicht löschen.
    Ist da irgend ein Fehler drin?
    Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-12_18-12_states.json.gz: {}
    Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-12_16-11_states.json.gz: {}
    Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-12_15-22_states.json.gz: {}
    Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-12_13-34_states.json.gz: {}
    Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-12_11-34_states.json.gz: {}
    Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-12_09-33_states.json.gz: {}
    Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-12_07-33_states.json.gz: {}
    Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-12_05-33_states.json.gz: {}
    Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-12_03-33_states.json.gz: {}
    Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-12_01-33_states.json.gz: {}
    Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-11_23-33_states.json.gz: {}
    Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-11_21-33_states.json.gz: {}
    Internette Grüße
    Andy
    RaspberryMatic (Raspberry Pi3), CUxD, ioBroker (Synology/ Docker)
    • Merlin123M Merlin123
      Ich habe den Fehler auch. Habe node.js 8.11.4 installiert.
      Was könnte das noch sein?
      David McNeillD Offline
      David McNeill
      root cause is explained by user voretsen ... here
      Die Ursache wird vom Benutzer voretsen erklärt ... hier
      • paul53P Offline
        Nodejs 10.x ? Dann https://forum.iobroker.net/viewtopic.php?f=17&t=15083&p=157659#p157659 (node.exe austauschen).
        • Merlin123M Offline
          Merlin123M Offline
          Merlin123
          Beta-Tester
          David McNeillD 1 Antwort Letzte Antwort
            David McNeill
