  4. [gelöst]Backup & Restore klappt nicht
39 Beiträge 11 Kommentatoren 8.3k Aufrufe 3 Beobachtet
    ahnungslos
    ich bin neu hier im Forum und komme leider mit dem Backup nicht zurecht. Wenn ich das Backup über die Konsole erstelle (./iobroker backup) dann wird das Backup im entsprechenden Ordner erstellt, versuche ich es jedoch nach dem stoppen des iobroker dieses per "sudo iobroker restore 0" zurück zu spielen erhalte ich immer folgenden Text:
    pi@ioBroker-RasPi:/opt/iobroker $ sudo iobroker stop
    Stopping iobroker controller daemon...
    iobroker controller daemon stopped.
    fs.js:1123
      return binding.chmod(pathModule._makeLong(path), modeNum(mode));
    Error: ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/iobr oker.js-controller/lib/../killall.sh'
        at Object.fs.chmodSync (fs.js:1123:18)
        at Daemon.daemon.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:286:32)
        at emitOne (events.js:121:20)
        at Daemon.emit (events.js:211:7)
        at Daemon. <anonymous>(/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:267:14)
        at Daemon._tryKill (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:277:23)
        at ontimeout (timers.js:482:11)
        at tryOnTimeout (timers.js:317:5)
        at Timer.listOnTimeout (timers.js:277:5)
    pi@ioBroker-RasPi:/opt/iobroker $ ./iobroker backup
    Backup created: /opt/iobroker/backups/2018_08_19-20_48_52_backupiobroker.tar.gz
    pi@ioBroker-RasPi:/opt/iobroker $ sudo iobroker restore 0
    /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:568
            if (parseInt(name.trim(), 10).toString() === name.trim().toString()) {
    TypeError: name.trim is not a function
        at BackupRestore.restoreBackup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:568:27)
        at dbConnect (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1456:28)
        at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3079:82)
        at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemServer.js:184:26)
        at runCallback (timers.js:794:20)
        at tryOnImmediate (timers.js:752:5)
        at processImmediate [as _immediateCallback] (timers.js:729:5)
    pi@ioBroker-RasPi:/opt/iobroker $ ^C
    pi@ioBroker-RasPi:/opt/iobroker $</anonymous>
    Hat jemand eine Idee?
    Vielen Dank im Voraus.
    Dominique
    geändert: Code in Code-Tags und formatierungen; Homoran (Admin)
    • apollon77A Offline
      Welche js-Controller Version?
      Gesendet vom Handy …
      • StabilostickS Offline
        Stabilostick
        Nachdem anscheinend die Datei ‚killall.sh‘ nicht aufgerufen werden kann, könnte man doch versuchen, den js-controller erneut zu installieren:
        cd /opt/iobroker
        sudo npm install iobroker.js-controller
        und dann das Restore nochmal probieren.
          ahnungslos
          Controller "js-controller" : 1.4.2 , installed 1.5.0
          VG
            ahnungslos
            Hallo Stabilostick,
            wenn ich das versuche bekomme ich folgrendes:
            pi@ioBroker-RasPi:/opt/iobroker $ sudo npm install iobroker.js-controller
            iobroker.js-controller@1.5.0 preinstall /opt/iobroker/node_modules/iobroker.js-controller
            node lib/preinstallCheck.js
            │ npm update check failed │
            │ Try running with sudo or get access │
            │ to the local update config store via │
            │ sudo chown -R $USER:$(id -gn $USER) /root/.config │
            NPM version: 5.8.0
            npm version >= 5: disabling package-lock
            iobroker.js-controller@1.5.0 install /opt/iobroker/node_modules/iobroker.js-controller
            node iobroker.js setup first
            • iobroker.js-controller@1.5.0
            updated 1 package in 42.599s
              Stabilostick
              Warum nutzt Du den js-Controller, der sich gerade in Entwicklung befindet? Absicht? Mutig, mutig…
              Installiere bitte den „stabilen“ :D
              cd /opt/iobroker
              sudo npm install iobroker.js-controller@stable —force —production —save
              Geht jetzt das Restore?
                ahnungslos
                wenn ich das versuche bekomme ich das :
                pi@ioBroker-RasPi:/opt/iobroker $ sudo npm install iobroker.js-controller@stable -force -production -save
                npm WARN using –force I sure hope you know what you are doing.
                iobroker.js-controller@1.4.2 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                node lib/preinstall_check.js
                NPM version: 5.8.0
                iobroker.js-controller@1.4.2 install /opt/iobroker/node_modules/iobroker.js-controller
                Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
                Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
                fs.js:885
                return binding.mkdir(pathModule._makeLong(path),
                Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
                at Object.fs.mkdirSync (fs.js:885:18)
                at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:143:58)
                at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:629:27
                at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:661:15)
                at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3166:5)
                at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:100)
                at Module._compile (module.js:652:30)
                at Object.Module._extensions..js (module.js:663:10)
                at Module.load (module.js:565:32)
                at tryModuleLoad (module.js:505:12)
                • iobroker.js-controller@1.4.2
                removed 5 packages, updated 6 packages and moved 1 package in 53.315s
                Viele Grüße
                Dominique</anonymous>
                  Stabilostick
                  OK, nächster Versuch ;)
                  cd /opt/iobroker
                  sudo iobroker stop
                  sudo chmod 777 * -R
                  sudo npm install -g npm@4
                  sudo npm install iobroker.js-controller@stable --production --force --save
                  sudo iobroker start
                    ahnungslos
                    Hey das hat geklappt, vieeeeeeeeeeeeeeelen Dank !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                    Wie kann ich diesen Topic als gelöst kennzeichnen?
                      Stabilostick
                      In Deinem ersten Post den Titel bearbeiten.
                      Freut mich für Dich. Prima. Viel Spaß noch mit ioBroker.
                        ahnungslos
                        Prima, danke nochmals.
                          bjoernson
                          Danke! Der Beitrag hat mir nach vielen Stunden erfolglosen probierens, auch endlich geholfen :)
                          • ? Offline
                            Ich habe den selben Fehler, allerdings haben all die Tipps hier nichts gebracht :-(
                            Hardware: Beelink BT3 Pro
                            OS: Debian 9 ( aktuellste Version )
                            Fehler:
                            root@debianiobroker:/opt/iobroker# iobroker restore 0
                            at BackupRestore.restoreBackup (/opt/iobroker/node_modules/iobroker.js-contr oller/lib/setup/setupBackup.js:568:27)
                            at dbConnect (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js :1474:28)
                            at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/s etup.js:3087:29)
                            at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller /lib/states/statesInMemServer.js:184:26)
                            at runCallback (timers.js:810:20)
                            at tryOnImmediate (timers.js:768:5)
                            at processImmediate [as _immediateCallback] (timers.js:745:5)
                            Suche schon seit Stunden wie blöd, aber nichts funktioniert...
                            js controller version iobroker.js-controller@1.5.11
                            node und nodejs version v8.16.0
                            npm v6.9.0
                            • Tg-71T Offline
                              Tg-71T Offline
                              Tg-71
                              Forum Testing
                              Die Fehlermeldung hatte ich auch gerade. Ich hab den Namen der Backupdatei mit angegeben. Dann hat es funktioniert.
                              CheesysC 1 Antwort Letzte Antwort
                              • Tg-71T Tg-71
                                CheesysC Offline
                                CheesysC Offline
                                Cheesys
                                @Tg-71 Dickes Dankeschön an dich
                                danach musste nur noch redis installiert werden dann hat es ohne Probleme funktioniert
                                  Fehler:
                                  npm v6.9.0
                                  DirtyAtze
                                  @SayAndre
                                  hast du inzwischein eine Lösung gefunden?
                                  Ich versucher gerade, den ioBroker von einem RPi 3 auf einen Pi 4 umzuziehen.
                                  Hab einen neues System aufgesetzt (Buster lite und ioBroker manuell installiert).
                                  Soweit läuft alles, aber ich kann kein Backup einspielen. Bekomme auch immer den Fehler:
                                  name.trim is not a function.
                                  node:
                                  10.16.0
                                  nodejs
                                  10.16.0
                                  npm
                                  6.9.0
                                  pi@RaspIO4:/opt/iobroker $ sudo npm install iobroker.js-controller@stable --production --force --save
                                  npm WARN using --force I sure hope you know what you are doing.
                                  npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                                  > iobroker.js-controller@1.5.11 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                  NPM version: 6.9.0
                                  Could not check npm version: Error: EACCES: permission denied, open '/opt/iobroker/.npmrc'
                                  Assuming that correct version is installed.
                                  > osx-temperature-sensor@1.0.3 install /opt/iobroker/node_modules/osx-temperature-sensor
                                  > node-gyp rebuild
                                  gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/10.16.0"
                                  gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
                                  gyp ERR! configure error
                                  gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/osx-temperature-sensor/build'
                                  gyp ERR! System Linux 4.19.50-v7l+
                                  gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                  gyp ERR! cwd /opt/iobroker/node_modules/osx-temperature-sensor
                                  gyp ERR! node -v v10.16.0
                                  gyp ERR! node-gyp -v v3.8.0
                                  gyp ERR! not ok
                                  > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram
                                  > node-gyp rebuild
                                  gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/unix-dgram/build'
                                  gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
                                  gyp ERR! not ok
                                  > iobroker.js-controller@1.5.11 install /opt/iobroker/node_modules/iobroker.js-controller
                                  fs.js:114
                                      throw err;
                                      at Object.mkdirSync (fs.js:757:3)
                                      at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:157:58)
                                      at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:634:27
                                      at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:664:15)
                                      at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:38)
                                      at Module._compile (internal/modules/cjs/loader.js:776:30)
                                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10)
                                      at Module.load (internal/modules/cjs/loader.js:653:32)
                                      at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                  + iobroker.js-controller@1.5.11
                                  added 7 packages from 9 contributors, updated 3 packages and audited 2110 packages in 22.619s
                                  found 39 vulnerabilities (28 low, 11 high)
                                    run `npm audit fix` to fix them, or `npm audit` for details
                                  RöstkartoffelR HomoranH 2 Antworten Letzte Antwort
                                  • D DirtyAtze
                                    @SayAndre
                                    node:
                                    10.16.0
                                    nodejs
                                    10.16.0
                                    npm
                                    6.9.0
                                    NPM version: 6.9.0
                                    > node-gyp rebuild
                                    gyp ERR! not ok
                                    > node-gyp rebuild
                                    gyp ERR! not ok
                                    fs.js:114
                                        throw err;
                                    RöstkartoffelR Offline
                                    Röstkartoffel
                                    @DirtyAtze
                                    Meine Suche im Forum führt mich dahin:
                                    https://forum.iobroker.net/topic/23036/gelöst-iobroker-restore-typeerror-name-trim-is-not-a-function/1
                                    Vielleicht hilft dir das auch bei deinem Problem
                                    NUC7i3BNH mit Proxmox und ioBroker (VM Debian Buster), Raspi3 (Slave Smartmeter für eHZ easymeter), Hardware CCU2, SMA SB5000TL-21
                                    • D DirtyAtze
                                      @SayAndre
                                      node:
                                      10.16.0
                                      nodejs
                                      10.16.0
                                      npm
                                      6.9.0
                                      NPM version: 6.9.0
                                      > node-gyp rebuild
                                      gyp ERR! not ok
                                      > node-gyp rebuild
                                      gyp ERR! not ok
                                      fs.js:114
                                          throw err;
                                      @DirtyAtze sagte in [gelöst]Backup & Restore klappt nicht:
                                      Dort ging es um den "trim is not a function" Error, den hast du doch nicht, oder?
                                      Bei dir dürfte der Fixer schon helfen
                                        DirtyAtze
                                        Ich hab den trim Fehler vorher auch gehabt.
                                        Das war der lösungsansatz von weiter oben. Hat aber auch nicht funktioniert.
                                        Den fix hab ich auch schon durchlaufen lassen. Bringt keinen Fehler, hilft aber nicht.
                                        Wenn ich die setupBackup.js ändere, wie im anderen thread beschrieben, bekomme ich den Fehler:
                                        [ERROR] [minimal] host.ioBrokerPi4 Cannot find extracted file from file...
                                        • D DirtyAtze
                                          @DirtyAtze
                                          Wo liegt dein Backup?
                                          hast du darauf zugriff?
                                          und wenn du den Fixer erfolgreich hast laufen lassen:
                                          Hat der User iobroker darauf Zugriff?
