  4. [gefixt] Parser-Adapter (1.0.3) stürzt ab
3 Beiträge 2 Kommentatoren 457 Aufrufe
  • K Offline
    Karl_999
    Ich verwende den Parser-Adpater zum Einlesen der Temperaturwerte einer DS1820-Sensoren
    Nun habe ich gerade auf die aktuelle Version 1.0.3 des Parser-Adapters (von 1.0.2) aktualisiert.
    Die bislang funktionstüchtige Konfiguration habe ich dabei nicht geändert.
    Nach der Aktualisierung stürzt der Adapter allerdings hart ab (Ausgaben im Debug-Modus):
    host.ioBroker-RasPi	2018-08-10 21:16:00.388	error	instance system.adapter.parser.0 terminated with code 0 (OK)
    Caught	2018-08-10 21:16:00.387	error	by controller[0]: at normal_reply (/opt/iobroker/node_modules/redis/index.js:726:21)
    Caught	2018-08-10 21:16:00.387	error	by controller[0]: at Command.callback (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:265:49)
    Caught	2018-08-10 21:16:00.387	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
    Caught	2018-08-10 21:16:00.386	error	by controller[0]: at adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.parser/main.js:351:21)
    Caught	2018-08-10 21:16:00.386	error	by controller[0]: at poll (/opt/iobroker/node_modules/iobroker.parser/main.js:319:9)
    Caught	2018-08-10 21:16:00.386	error	by controller[0]: at readLink (/opt/iobroker/node_modules/iobroker.parser/main.js:294:13)
    Caught	2018-08-10 21:16:00.386	error	by controller[0]: at readLink (/opt/iobroker/node_modules/iobroker.parser/main.js:319:54)
    Caught	2018-08-10 21:16:00.385	error	by controller[0]: at analyseDataForStates (/opt/iobroker/node_modules/iobroker.parser/main.js:145:5)
    Caught	2018-08-10 21:16:00.385	error	by controller[0]: at _analyseDataForStates (/opt/iobroker/node_modules/iobroker.parser/main.js:127:9)
    Caught	2018-08-10 21:16:00.385	error	by controller[0]: at analyseData (/opt/iobroker/node_modules/iobroker.parser/main.js:195:29)
    Caught	2018-08-10 21:16:00.384	error	by controller[0]: TypeError: (data || "").replace is not a function
    parser.0	2018-08-10 21:16:00.358	info	terminating
    parser.0	2018-08-10 21:15:59.849	error	at normal_reply (/opt/iobroker/node_modules/redis/index.js:726:21)
    parser.0	2018-08-10 21:15:59.849	error	at Command.callback (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:265:49)
    parser.0	2018-08-10 21:15:59.849	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
    parser.0	2018-08-10 21:15:59.849	error	at adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.parser/main.js:351:21)
    parser.0	2018-08-10 21:15:59.849	error	at poll (/opt/iobroker/node_modules/iobroker.parser/main.js:319:9)
    parser.0	2018-08-10 21:15:59.849	error	at readLink (/opt/iobroker/node_modules/iobroker.parser/main.js:294:13)
    parser.0	2018-08-10 21:15:59.849	error	at readLink (/opt/iobroker/node_modules/iobroker.parser/main.js:319:54)
    parser.0	2018-08-10 21:15:59.849	error	at analyseDataForStates (/opt/iobroker/node_modules/iobroker.parser/main.js:145:5)
    parser.0	2018-08-10 21:15:59.849	error	at _analyseDataForStates (/opt/iobroker/node_modules/iobroker.parser/main.js:127:9)
    parser.0	2018-08-10 21:15:59.849	error	at analyseData (/opt/iobroker/node_modules/iobroker.parser/main.js:195:29)
    parser.0	2018-08-10 21:15:59.849	error	TypeError: (data || "").replace is not a function
    parser.0	2018-08-10 21:15:59.848	error	uncaught exception: (data || "").replace is not a function
    parser.0	2018-08-10 21:15:59.824	debug	analyseData CHECK for parser.0.Temp_KiZi_1_b, old=25.700000000000003
    parser.0	2018-08-10 21:15:59.820	debug	Process ["parser.0.Temp_KiZi_1_b"] for link /sys/bus/w1/devices/10-000802c38ff9/w1_slave
    parser.0	2018-08-10 21:15:58.939	debug	Read file: /sys/bus/w1/devices/10-000802c38ff9/w1_slave
    parser.0	2018-08-10 21:15:58.937	debug	Do Link: /sys/bus/w1/devices/10-000802c38ff9/w1_slave
    parser.0	2018-08-10 21:15:58.936	debug	States for current Interval (10000): ["parser.0.Temp_KiZi_1_b","parser.0.Temp_KiZi_1_a","parser.0.Temp_KiZi_1_w"]
    parser.0	2018-08-10 21:15:58.798	info	starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.parser, node: v8.11.3
    Hat jemand eine Idee, an was das liegen kann?
      Dazu existiert beteits ein issue suf github
      Gruß Rainer
      • K Offline
        Karl_999
        @Homoran:
        Dazu existiert beteits ein issue suf github `
        Danke für die Info.
        Und scheint auch in 1.0.4 gefixt zu sein.
