  4. Sonos Adapter Problem mit Sonos Beam
5 Beiträge 4 Kommentatoren 864 Aufrufe 1 Beobachtet
  • 4 Offline
    4 Offline
    4-Real
    Hallo Jungs, habe ein Problem das ich über SayIt nicht meine Beam "angesteuert" bekomme.
    host.IoBroker	2018-07-19 21:02:08.007	error	instance system.adapter.sonos.0 terminated with code 0 (OK)
    Caught	2018-07-19 21:02:08.006	error	by controller[0]: at Timer.listOnTimeout (timers.js:214:5)
    Caught	2018-07-19 21:02:08.006	error	by controller[0]: at tryOnTimeout (timers.js:250:5)
    Caught	2018-07-19 21:02:08.005	error	by controller[0]: at ontimeout (timers.js:396:15)
    Caught	2018-07-19 21:02:08.005	error	by controller[0]: at Timeout.playOnSonos [as _onTimeout] (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:907:9)
    Caught	2018-07-19 21:02:08.002	error	by controller[0]: at fadeOut (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:725:20)
    Caught	2018-07-19 21:02:07.986	error	by controller[0]: TypeError: Cannot create property 'actual' on boolean 'false'
    sonos.0	2018-07-19 21:02:07.895	info	terminating
    sonos.0	2018-07-19 21:02:07.879	info	terminating
    sonos.0	2018-07-19 21:02:07.875	error	at Timer.listOnTimeout (timers.js:214:5)
    sonos.0	2018-07-19 21:02:07.875	error	at tryOnTimeout (timers.js:250:5)
    sonos.0	2018-07-19 21:02:07.875	error	at ontimeout (timers.js:396:15)
    sonos.0	2018-07-19 21:02:07.875	error	at Timeout.playOnSonos [as _onTimeout] (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:907:9)
    sonos.0	2018-07-19 21:02:07.875	error	at fadeOut (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:725:20)
    sonos.0	2018-07-19 21:02:07.875	error	TypeError: Cannot create property 'actual' on boolean 'false'
    sonos.0	2018-07-19 21:02:07.874	error	uncaught exception: Cannot create property 'actual' on boolean 'false'
    sonos.0	2018-07-19 21:02:07.820	info	try to control id sonos.0.root.192_168_178_42.tts with {"val":"70;http://192.168.178.43:8082/state/sayit.0.tts.mp3","ack":false,"ts":1532026927815,"q":0,"from":"system.adapter.sayit.0","lc":153202692
    sayit.0	2018-07-19 21:02:07.783	info	Copied file "/opt/iobroker/node_modules/iobroker.sayit/lib/../sayit.0.say.mp3" to "/opt/iobroker/cache/02b51b320cde111850a78713d47771bc.mp3"
    sayit.0	2018-07-19 21:02:07.743	info	Set "sonos.0.root.192_168_178_42.tts: 70;http://192.168.178.43:8082/state/sayit.0.tts.mp3
    sayit.0	2018-07-19 21:02:07.328	info	saying: Hallo Test
    Jemand eine Idee woran das liegt oder ist die Sonos Beam noch zu neu?…
    • enzoE Offline
      enzoE Offline
      enzo
      Sonos Play 1 seit adapter update 1.7.0 bis 1.7.2 das gleiche problem mit 1.6.2 alles O.K. ?????
      iobroker 2018-07-20 11:18:29.957 info upgrade sonos@1.6.2
      sonos.0 2018-07-20 11:17:07.034 info http sonos server listening on port 8080
      sonos.0 2018-07-20 11:17:06.941 info starting. Version 1.7.2 in C:/ioBroker/node_modules/iobroker.sonos, node: v6.14.3
      host.SERVER 2018-07-20 11:17:04.222 info instance system.adapter.sonos.0 started with pid 26584
      sayit.0 2018-07-20 11:17:02.066 info Set "sonos.0.root.192_168_178_29.tts: 70;http://192.168.178.23:8082/state/sayit.0.tts.mp3
      sayit.0 2018-07-20 11:17:01.879 info saying: DeckenfluterAusgeschaltet
      sayit.0 2018-07-20 11:17:00.863 info Set "sonos.0.root.192_168_178_29.tts: 49;http://192.168.178.23:8082/state/sayit.0.tts.mp3
      sayit.0 2018-07-20 11:17:00.863 info saying: C:\ioBroker\node_modules\iobroker.sayit/gong.mp3
      sayit.0 2018-07-20 11:16:35.394 info Set "sonos.0.root.192_168_178_29.tts: 70;http://192.168.178.23:8082/state/sayit.0.tts.mp3
      sayit.0 2018-07-20 11:16:35.097 info saying: DeckenfluterEingeschaltet
      host.SERVER 2018-07-20 11:16:34.206 info Restart adapter system.adapter.sonos.0 because enabled
      host.SERVER 2018-07-20 11:16:34.206 error instance system.adapter.sonos.0 terminated with code 0 (OK)
      Caught 2018-07-20 11:16:34.206 error by controller[0]: at Timer.listOnTimeout (timers.js:214:5)
      Caught 2018-07-20 11:16:34.206 error by controller[0]: at tryOnTimeout (timers.js:250:5)
      Caught 2018-07-20 11:16:34.206 error by controller[0]: at ontimeout (timers.js:396:15)
      Caught 2018-07-20 11:16:34.206 error by controller[0]: at Timeout.playOnSonos [as _onTimeout] (C:\ioBroker\node_modules\iobroker.sonos\main.js:987:9)
      Caught 2018-07-20 11:16:34.190 error by controller[0]: at fadeOut (C:\ioBroker\node_modules\iobroker.sonos\main.js:805:20)
      Caught 2018-07-20 11:16:34.190 error by controller[0]: TypeError: Cannot create property 'actual' on boolean 'false'
      sonos.0 2018-07-20 11:16:34.144 info terminating
      sonos.0 2018-07-20 11:16:34.128 error at Timer.listOnTimeout (timers.js:214:5)
      sonos.0 2018-07-20 11:16:34.128 error at tryOnTimeout (timers.js:250:5)
      sonos.0 2018-07-20 11:16:34.128 error at ontimeout (timers.js:396:15)
      sonos.0 2018-07-20 11:16:34.128 error at Timeout.playOnSonos [as _onTimeout] (C:\ioBroker\node_modules\iobroker.sonos\main.js:987:9)
      sonos.0 2018-07-20 11:16:34.128 error at fadeOut (C:\ioBroker\node_modules\iobroker.sonos\main.js:805:20)
      sonos.0 2018-07-20 11:16:34.128 error TypeError: Cannot create property 'actual' on boolean 'false'
      sonos.0 2018-07-20 11:16:34.128 error uncaught exception: Cannot create property 'actual' on boolean 'false'
      sonos.0 2018-07-20 11:16:34.113 info try to control id sonos.0.root.192_168_178_29.tts with {"val":"49;http://192.168.178.23:8082/state/sayit. … r
      sayit.0 2018-07-20 11:16:34.082 info Set "sonos.0.root.192_168_178_29.tts: 49;http://192.168.178.23:8082/state/sayit.0.tts.mp3
      sayit.0 2018-07-20 11:16:34.066 info saying: C:\ioBroker\node_modules\iobroker.sayit/gong.mp3
      sayit.0 2018-07-20 11:15:28.019 info All files uploaded
      sayit.0 2018-07-20 11:15:27.879 info Upload announce mp3 files
      sayit.0 2018-07-20 11:15:27.863 info starting. Version 1.6.8 in C:/ioBroker/node_modules/iobroker.sayit, node: v6.14.3
      host.SERVER 2018-07-20 11:15:26.659 info instance system.adapter.sayit.0 started with pid 25796
      host.SERVER 2018-07-20 11:15:24.159 info instance system.adapter.sayit.0 terminated with code 0 (OK)
      host.SERVER 2018-07-20 11:15:24.128 info stopInstance timeout "1000 system.adapter.sayit.0 killing pid 6824
      host.SERVER 2018-07-20 11:15:23.112 info stopInstance system.adapter.sayit.0
      sayit.0 2018-07-20 11:15:23.113 info stopping...
      host.SERVER 2018-07-20 11:15:23.112 info object change system.adapter.sayit.0
      host.SERVER 2018-07-20 11:15:02.956 info instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
      • 4 Offline
        4 Offline
        4-Real
        Komisch, hab auch gerade auf 1.6.2 downgraded und jetzt geht es?! :D
        Scheint wohl noch ein kleiner Bug im Adapter zu sein?
          mamoel
          Ich kann das ebenfalls bestätigen. Ab 1.7.0 habe ich den beschriebenen Fehler. Ein Downgrade auf 1.6.2 löst das Problem.
          <size size="85">ioBroker (docker) auf Synology DS418play
          Alexa2, cloud, fritzdect, g-homa, harmony, hm-rega, hm-rpc, hs100, hue, javascript, nuki, ring, sayit, sonos, sql, viessmannapi</size>
          • C Offline
            chka
            Kann sein dass das problem selbst mit der neusten Version so ist
            INTEL NUC BOXNUC6I3SYH i3-6100U - Proxmox
            Speicher: Transcend MTS800 M.2 SSD 128GB SATA III, MLC
            RAM: 40Gig Crucial 8GB DDR4 CT2K8G4SFS824A + 32GB DDR4CT32G4SFD8266
