  4. Performance: History-Adapter mach Probleme: error: uncaught exception: Cannot read property 'ts' of null
3 Beiträge 1 Kommentatoren 825 Aufrufe
  • sissiwupS Offline
    sissiwupS Offline
    sissiwup
    2015-11-06 10:39:01.837  - info: history.0 moving 480 entries to couchdb
    2015-11-06 10:39:02.040  - error: uncaught exception: Cannot read property 'ts' of null
    2015-11-06 10:39:02.069  - error: TypeError: Cannot read property 'ts' of null
        at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.history/history.js:105:33)
        at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
        at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
        at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
        at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
        at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
        at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
        at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
        at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
        at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:291:16)
    2015-11-06 10:39:02.435  - error: host.raspberrypi instance system.adapter.history.0 terminated with code 6 (uncaught exception)
    2015-11-06 10:39:02.450  - info: host.raspberrypi Restart adapter system.adapter.history.0 because enabled
    2015-11-06 10:39:32.585  - info: host.raspberrypi instance system.adapter.history.0 started with pid 11064
    2015-11-06 10:39:35.698  - info: history.0 starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.history
    2015-11-06 10:39:36.163  - info: history.0 enabled logging of system.adapter.hm-rpc.upload
    2015-11-06 10:39:36.169  - info: history.0 enabled logging of hm-rpc.0.updated</anonymous></anonymous></anonymous>
    Wie kann ich diesen Fehler eingrenzen?
    MfG
    Sissi
    • sissiwupS Offline
      sissiwupS Offline
      sissiwup
      Ich habe jetzt den History-Adapter deaktiviert.
      Traumhafte Loadwerte von 0,5 und kleiner. Speicherplatz ohne Ende.
      Irgendwo scheint er sich hochzuschaukeln bei dem Fehler.
      MfG
      Sissi
      • sissiwupS Offline
        sissiwupS Offline
        sissiwup
        History-Adapter wieder aktiviert, allerdings nur mit wenigen Messpunkten.
        Geht sofort wieder hoch die Auslastung.
        Da scheint noch der Wurm drinn zu sein.
        Ohne History-Adapter: Load 0,5-1
        Mist History-Adapter: Load 2,5-4
        (ca. 200 Logpunkte / Temp, Status, Helligkeit etc. Keine die sich minütlich ändern / Log nur auf Änderung)
        Ab 11:00 aus und dann wieder hinzugefügt …
        Kann das wer bestätigen?
        Unter CCU.IO logge ich alle Werte ohne merkliche CPU-Last.
        MfG
        Sissi
