  4. [Gelöst] Probleme in Java Script nach Update History Adapter auf Ver. 1.84
9 Beiträge 3 Kommentatoren 1.2k Aufrufe
  • aftershowmanA Offline
    aftershowman
    bei mir haben "Send to" im Java Script nicht mehr funktioniert.
    Mit der Version 1.74 vom History Adapter hat noch alles funktiniert.
    Bin dann zurück auf 1.74 und alles ging wieder
    Hier die log Messages:
    history.0	2018-07-02 18:44:10.282	error	message messagebox.system.adapter.history.0 [object Object] Cannot read property 'id' of undefined
    history.0	2018-07-02 18:44:10.244	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
    history.0	2018-07-02 18:44:10.244	error	at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
    history.0	2018-07-02 18:44:10.244	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:233:12)
    history.0	2018-07-02 18:44:10.244	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:275:10)
    history.0	2018-07-02 18:44:10.244	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
    history.0	2018-07-02 18:44:10.244	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    history.0	2018-07-02 18:44:10.244	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3398:41)
    history.0	2018-07-02 18:44:10.244	error	at Object.message (/opt/iobroker/node_modules/iobroker.history/history.js:146:9)
    history.0	2018-07-02 18:44:10.244	error	at processMessage (/opt/iobroker/node_modules/iobroker.history/history.js:225:9)
    history.0	2018-07-02 18:44:10.244	error	at storeState (/opt/iobroker/node_modules/iobroker.history/history.js:994:82)
    history.0	2018-07-02 18:44:10.244	error	TypeError: Cannot read property 'id' of undefined</anonymous></anonymous>
    Hier der Code, der die Fehler verursacht:
    Was mach ich falsch?
    sendTo ("history.0", "storeState", {id: ObjEinspeisung5min, state: {
    "val": mytempVar,
    "ack": 1,
    "ts": new Date(JahrAkt + "." + MonatAkt + "." + TagAkt + " " + StundeAkt + ":" + MinuteAkt + ":00").getTime(),
    "q": 0
    Grüße, Frank
    Edit by Dutchman : Naestes mal in code tags bitte !
    ca. 80 Geräte (Shelly, Zigbee, Modbus, Fronius, GOe)
    ioBroker PC: Linux VM
    • apollon77A Offline
      Schaue ich mir zeitnah an. Legst du es bitte als GitHub issue noch an?! Danke
      Gesendet vom Handy …
        Bitte 1.8.5 vo Github testen. Fehler sollte weg sein.Bitte um Rückmeldung. Danke
        Ingo
          aftershowman
          HAllo,
          Danke für die schnelle Bearbeitung.
          Leider hab ich keien Ahnung wie ich eine Version von GitHub installieren soll.
          Ich mache die updates auschliesslich über den dan IOBroker Admin.
          Bräuchte also ne Anleitung, oder muß warten bis die Version über den IOBroker Admin angeboten wird.
          Sorry.
          Tolles Tool, möchte ich an dieser Stelle einmal loswerden.
          Grüße, Frank
            aftershowman
            issue auf GitHub angelegt
            • StabilostickS Offline
              Stabilostick
              Von Github installieren geht z.B. so:
              Ist dann die Neueste, also gerade eben 1.8.5.
                Update vom GitHub installieren: Admin - Adapter - oben auf das Icon "Custom-Install" (Github Symbol) klicken, dort aus der Liste history wählen. Installieren. Dann History-Instanz neu starten.
                Ab morgen ists im Latest-Repository
                Edit: Danke Stabilostick, ein Bild sagt mehr als tausend Worte :-)
                  aftershowman
                  habe das Update auf Version History 1.85.
                  "Send to" funktioniert wieder.
                  Super Danke.
                  !!!! Super Support.
                  Grüße, Frank
                    Danke. Setzt du den Thread Titel im ersten Post bitte noch auf „gelöst“?!
