  4. Lets encript 2 ?
Lets encript 2 ?
4 Beiträge 3 Kommentatoren 892 Aufrufe
    stephan61
    Hallo nach dem meine Speicherkarte den Geist aufgegeben hat habe ich mein System neu aufgesetz und mein Backup eingespielt
    hat alles funktioniert
    nur beim socket .io mit lets encript kommt folgende Fehlermeldung im log
    host.tinkerboard	2018-05-20 10:07:34.338	info	Restart adapter system.adapter.socketio.0 because enabled
    host.tinkerboard	2018-05-20 10:07:34.338	error	instance system.adapter.socketio.0 terminated with code 0 (OK)
    host.tinkerboard	2018-05-20 10:07:34.338	error	Caught by controller[13]: at process._tickCallback (internal/process/next_tick.js:180:9) code: 'MODULE_NOT_FOUND' }
    host.tinkerboard	2018-05-20 10:07:34.337	error	Caught by controller[13]: at _combinedTickCallback (internal/process/next_tick.js:135:11)
    host.tinkerboard	2018-05-20 10:07:34.337	error	Caught by controller[13]: at emitCloseNT (net.js:1659:8)
    host.tinkerboard	2018-05-20 10:07:34.337	error	Caught by controller[13]: at Server.emit (events.js:208:7)
    host.tinkerboard	2018-05-20 10:07:34.337	error	Caught by controller[13]: at emitNone (events.js:106:13)
    host.tinkerboard	2018-05-20 10:07:34.337	error	Caught by controller[13]: at Object.onceWrapper (events.js:313:30)
    host.tinkerboard	2018-05-20 10:07:34.337	error	Caught by controller[13]: at Server. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:254:25)
    host.tinkerboard	2018-05-20 10:07:34.337	error	Caught by controller[13]: at /opt/iobroker/node_modules/iobroker.socketio/main.js:90:32
    host.tinkerboard	2018-05-20 10:07:34.337	error	Caught by controller[13]: at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:55:26)
    host.tinkerboard	2018-05-20 10:07:34.337	error	Caught by controller[13]: at Object.Greenlock.create (/opt/iobroker/node_modules/greenlock/index.js:218:12)
    host.tinkerboard	2018-05-20 10:07:34.336	error	Caught by controller[13]: at loadLeV01 (/opt/iobroker/node_modules/greenlock/index.js:185:14)
    host.tinkerboard	2018-05-20 10:07:34.336	error	Caught by controller[13]: at require (internal/module.js:11:18)
    host.tinkerboard	2018-05-20 10:07:34.336	error	Caught by controller[13]: at Module.require (module.js:596:17)
    host.tinkerboard	2018-05-20 10:07:34.336	error	Caught by controller[13]: at Function.Module._load (module.js:474:25)
    host.tinkerboard	2018-05-20 10:07:34.336	error	Caught by controller[13]: at Function.Module._resolveFilename (module.js:547:15)
    host.tinkerboard	2018-05-20 10:07:34.336	error	Caught by controller[13]: { Error: Cannot find module 'le-acme-core'
    host.tinkerboard	2018-05-20 10:07:34.336	error	Caught by controller[12]: Let's Encrypt v1 is deprecated. Please update to Let's Encrypt v2 (ACME draft 11)
    host.tinkerboard	2018-05-20 10:07:34.336	error	Caught by controller[11]: === WARNING ===
    host.tinkerboard	2018-05-20 10:07:34.335	error	Caught by controller[9]: Detected Let's Encrypt v01 URL (deprecated). Changing version to v01.
    host.tinkerboard	2018-05-20 10:07:34.335	error	Caught by controller[7]: ====================================================================
    host.tinkerboard	2018-05-20 10:07:34.335	error	Caught by controller[6]: == this will be required from version v2.3 forward ==
    host.tinkerboard	2018-05-20 10:07:34.335	error	Caught by controller[6]: ====================================================================
    host.tinkerboard	2018-05-20 10:07:34.335	error	Caught by controller[5]: 'v01' for Let's Encrypt v1 (deprecated)
    host.tinkerboard	2018-05-20 10:07:34.335	error	Caught by controller[4]: or
    host.tinkerboard	2018-05-20 10:07:34.335	error	Caught by controller[3]: ('v02' is an alias of 'draft-11'
    host.tinkerboard	2018-05-20 10:07:34.335	error	Caught by controller[3]: 'draft-11' for Let's Encrypt v2 and ACME draft 11
    host.tinkerboard	2018-05-20 10:07:34.334	error	Caught by controller[2]: Please specify 'version' option:
    host.tinkerboard	2018-05-20 10:07:34.334	error	Caught by controller[1]: ====================================================================
    host.tinkerboard	2018-05-20 10:07:34.334	error	Caught by controller[1]: == greenlock.js (v2.2.0+) ==
    socketio.0	2018-05-20 10:07:34.049	info	starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.socketio, node: v8.11.2</anonymous>
    Gruß Stephan
    • apollon77A Offline
      Bitte dazu beim js-Controller mal ein issue im github auf machen.
        speedy
        gib es dazu eine Lösung?
        Ich habe selbes Problem…
        System wurde aber erst vor rund 2 Wochen installiert und ist auch aktuell....
        ioBroker - Neuling ;)
          Man müsste js-controller vom Github installieren ode rnoch ein paar Tage warten bis 1.5.0 in "latest" ist. Da ist es dann drin
