  4. Kein Start mehr nach reboot vom PI
6 Beiträge 3 Kommentatoren 1.1k Aufrufe
  • sissiwupS Offline
    sissiwupS Offline
    sissiwup
    mein iobroker wollte nach einem Neustart des PI nicht mehr hochfahren:
    2015-09-29 18:28:36.992  - info: host.raspberrypi ioBroker.js-controller version 0.7.11 js-controller starting
    2015-09-29 18:28:37.008  - info: host.raspberrypi Copyright (c) 2014-2015 bluefox, hobbyquaker
    2015-09-29 18:28:37.010  - info: host.raspberrypi hostname: raspberrypi
    2015-09-29 18:28:37.011  - info: host.raspberrypi ip addresses: 192.168.1.12 192.168.1.185
    2015-09-29 18:28:45.019  - info: inMem-states listening on port 9000
    2015-09-29 18:28:45.615  - info: inMem-objects listening on port 9001
    2015-09-29 18:28:45.630  - info: host.raspberrypi InMemoryDB connected
    2015-09-29 18:28:45.671  - info: host.raspberrypi 26 instances found
    2015-09-29 18:28:45.675  - warn: host.raspberrypi does not start any instances on this host
    2015-09-29 18:30:27.520  - info: host.raspberrypi received SIGTERM
    2015-09-29 18:30:27.619  - info: host.raspberrypi terminated
    2015-09-29 18:30:28.523  - info: host.raspberrypi received SIGTERM
    2015-09-29 18:30:28.610  - info: host.raspberrypi terminated
    2015-09-29 18:30:36.981  - info: host.raspberrypi ioBroker.js-controller version 0.7.11 js-controller starting
    2015-09-29 18:30:36.993  - info: host.raspberrypi Copyright (c) 2014-2015 bluefox, hobbyquaker
    2015-09-29 18:30:36.994  - info: host.raspberrypi hostname: raspberrypi
    2015-09-29 18:30:36.994  - info: host.raspberrypi ip addresses: 192.168.1.12 192.168.1.185
    2015-09-29 18:30:45.044  - info: inMem-states listening on port 9000
    2015-09-29 18:30:45.654  - info: inMem-objects listening on port 9001
    2015-09-29 18:30:45.668  - info: host.raspberrypi InMemoryDB connected
    2015-09-29 18:30:45.709  - info: host.raspberrypi 26 instances found
    2015-09-29 18:30:45.713  - warn: host.raspberrypi does not start any instances on this host
    2015-09-29 18:32:41.736  - info: host.raspberrypi received SIGTERM
    2015-09-29 18:32:41.742  - info: host.raspberrypi stopInstance system.adapter.admin.0
    2015-09-29 18:32:41.743  - warn: host.raspberrypi stopInstance system.adapter.admin.0 not running
    2015-09-29 18:32:41.743  - info: host.raspberrypi stopInstance system.adapter.web.0
    2015-09-29 18:32:41.744  - warn: host.raspberrypi stopInstance system.adapter.web.0 not running
    2015-09-29 18:32:41.744  - info: host.raspberrypi stopInstance system.adapter.vis.0
    2015-09-29 18:32:41.744  - info: host.raspberrypi stopInstance system.adapter.vis-metro.0
    2015-09-29 18:32:41.744  - info: host.raspberrypi stopInstance system.adapter.vis-lcars.0
    2015-09-29 18:32:41.745  - info: host.raspberrypi stopInstance system.adapter.vis-hqwidgets.0
    2015-09-29 18:32:41.745  - info: host.raspberrypi stopInstance system.adapter.vis-bars.0
    2015-09-29 18:32:41.745  - info: host.raspberrypi stopInstance system.adapter.vis-plumb.0
    2015-09-29 18:32:41.745  - info: host.raspberrypi stopInstance system.adapter.hm-rpc.0
    2015-09-29 18:32:41.745  - warn: host.raspberrypi stopInstance system.adapter.hm-rpc.0 not running
    2015-09-29 18:32:41.745  - info: host.raspberrypi stopInstance system.adapter.hm-rega.0
    2015-09-29 18:32:41.746  - warn: host.raspberrypi stopInstance system.adapter.hm-rega.0 not running
    2015-09-29 18:32:41.746  - info: host.raspberrypi stopInstance system.adapter.hm-rpc.1
    2015-09-29 18:32:41.746  - warn: host.raspberrypi stopInstance system.adapter.hm-rpc.1 not running
    2015-09-29 18:32:41.746  - info: host.raspberrypi stopInstance system.adapter.vis-colorpicker.0
    2015-09-29 18:32:41.746  - info: host.raspberrypi stopInstance system.adapter.fritzbox.0
    2015-09-29 18:32:41.747  - warn: host.raspberrypi stopInstance system.adapter.fritzbox.0 not running
    2015-09-29 18:32:41.747  - info: host.raspberrypi stopInstance system.adapter.javascript.0
    2015-09-29 18:32:41.747  - warn: host.raspberrypi stopInstance system.adapter.javascript.0 not running
    2015-09-29 18:32:41.747  - info: host.raspberrypi stopInstance system.adapter.yr.0
    2015-09-29 18:32:41.747  - warn: host.raspberrypi stopInstance system.adapter.yr.0 not scheduled
    2015-09-29 18:32:41.747  - info: host.raspberrypi stopInstance system.adapter.node-red.0
    2015-09-29 18:32:41.749  - warn: host.raspberrypi stopInstance system.adapter.node-red.0 not running
    2015-09-29 18:32:41.750  - info: host.raspberrypi stopInstance system.adapter.history.0
    2015-09-29 18:32:41.750  - warn: host.raspberrypi stopInstance system.adapter.history.0 not running
    2015-09-29 18:32:41.750  - info: host.raspberrypi stopInstance system.adapter.ping.0
    2015-09-29 18:32:41.750  - warn: host.raspberrypi stopInstance system.adapter.ping.0 not running
    2015-09-29 18:32:41.842  - info: host.raspberrypi terminated
    2015-09-29 18:32:42.740  - info: host.raspberrypi received SIGTERM
    2015-09-29 18:32:56.633  - info: host.raspberrypi ioBroker.js-controller version 0.7.11 js-controller starting
    2015-09-29 18:32:56.644  - info: host.raspberrypi Copyright (c) 2014-2015 bluefox, hobbyquaker
    2015-09-29 18:32:56.646  - info: host.raspberrypi hostname: raspberrypi
    2015-09-29 18:32:56.646  - info: host.raspberrypi ip addresses: 192.168.1.12
    2015-09-29 18:33:18.610  - info: inMem-states listening on port 9000
    2015-09-29 18:33:19.317  - info: inMem-objects listening on port 9001
    2015-09-29 18:33:19.330  - info: host.raspberrypi InMemoryDB connected
    2015-09-29 18:33:19.372  - info: host.raspberrypi 26 instances found
    2015-09-29 18:33:19.376  - warn: host.raspberrypi does not start any instances on this host
    2015-09-29 18:37:46.599  - info: host.raspberrypi received SIGTERM
    Kann man am Log sehen, wo es hakt?
    Ich habe das Backup des Data-Ordners von heute Nacht eingespielt, danach lief alles wieder.
    MfG
    Sissi
    • BluefoxB Offline
      BluefoxB Offline
      @sissiwup:
      Ich habe das Backup des Data-Ordners von heute Nacht eingespielt, danach lief alles wieder. `
      Name von raspberry host wurde geändert.
      • sissiwupS Offline
        sissiwupS Offline
        sissiwup
        nachdem ich das Backup (von iobroker) von der Nacht wieder eingespielt hatte, lief alles wieder.
        Wo kann ich denn den Hostnamen ändern?
        MfG
        Sissi
          über die Konsole mit raspi-config
          Rainer
          • sissiwupS Offline
            sissiwupS Offline
            sissiwup
            Danke. Da habe ich aber nichts gemacht. Hostname ist geblieben wie vorher.
            MfG
            Sissi
            • BluefoxB Offline
              BluefoxB Offline
              ` > 2015-09-29 18:28:45.671 - info: host.raspberrypi 26 instances found
              2015-09-29 18:28:45.675 - warn: host.raspberrypi does not start any instances on this host `
              Sagt, dass Adapter Instanzen existieren, aber nicht für diesen Host.
              Nächstes Mal
              iobroker o get "system.adapter.admin.0" --pretty
              Aufrufen und schauen "common.host" Wert.
