  4. Fehler history
Fehler history
2 Beiträge 2 Kommentatoren 544 Aufrufe
  • sissiwupS Offline
    sissiwupS Offline
    sissiwup
    Merkwürdiger Fehler im history Adapter:
    2015-09-29 04:14:27.545  - error: uncaught exception: Cannot read property 'ts' of null
    2015-09-29 04:14:27.563  - error: TypeError: Cannot read property 'ts' of null
        at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.history/history.js:105:33)
        at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
        at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
        at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
        at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
        at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
        at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
        at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
        at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
        at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:291:16)
    2015-09-29 04:14:27.893  - error: host.raspberrypi instance system.adapter.history.0 terminated with code 6 (uncaught exception)
    2015-09-29 04:14:27.894  - info: host.raspberrypi Restart adapter system.adapter.history.0 because enabled
    2015-09-29 04:14:57.941  - info: host.raspberrypi instance system.adapter.history.0 started with pid 16949
    2015-09-29 04:15:00.196  - info: history.0 starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.history</anonymous></anonymous></anonymous>
    MfG
    Sissi
    • BluefoxB Offline
      BluefoxB Offline
      @sissiwup:
      Vielleicht wurde irgendeinen Datenpunkt gelöscht. Werde Prüfung einbauen.
