  4. Node.red funktioniert unter Windows nicht
5 Beiträge 3 Kommentatoren 778 Aufrufe
  • H Offline
    Hc-Yami
    Guten Tag,
    leider läuft meine node.red Instanz nicht. Bzw. läuft sie, aber Alexa findet keine Geräte unter alexa.local:
    node-red.0	2018-03-25 15:12:54.513	info	Save C:/ioBroker/iobroker-data/node-red/flows.json
    node-red.0	2018-03-25 15:12:54.013	error
    node-red.0	2018-03-25 15:12:54.013	error	at Flow.start (C:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\red\runtime\nodes\flows\Flow.js:89:35)
    node-red.0	2018-03-25 15:12:54.013	error	at createNode (C:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\red\runtime\nodes\flows\Flow.js:305:18)
    node-red.0	2018-03-25 15:12:54.013	error	at new AlexaLocalNode (C:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red-contrib-alexa-local\index.js:29:25)
    node-red.0	2018-03-25 15:12:54.013	error	at require (internal/module.js:12:17)
    node-red.0	2018-03-25 15:12:54.013	error	at Module.require (module.js:353:17)
    node-red.0	2018-03-25 15:12:54.013	error	at Function.Module._load (module.js:300:12)
    node-red.0	2018-03-25 15:12:54.013	error	at Module.load (module.js:343:32)
    node-red.0	2018-03-25 15:12:54.013	error	at Object.Module._extensions..js (module.js:416:10)
    node-red.0	2018-03-25 15:12:54.013	error	at Module._compile (module.js:373:25)
    node-red.0	2018-03-25 15:12:54.013	error	at exports.runInThisContext (vm.js:53:16)
    node-red.0	2018-03-25 15:12:54.013	error	25 Mar 15:12:54 - [error] [alexa-local:be811848.8589e8] SyntaxError: Unexpected token =
    node-red.0	2018-03-25 15:12:27.904	error
    node-red.0	2018-03-25 15:12:27.904	error	at Flow.start (C:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\red\runtime\nodes\flows\Flow.js:89:35)
    node-red.0	2018-03-25 15:12:27.904	error	at createNode (C:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\red\runtime\nodes\flows\Flow.js:305:18)
    node-red.0	2018-03-25 15:12:27.904	error	at new AlexaLocalNode (C:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red-contrib-alexa-local\index.js:29:25)
    node-red.0	2018-03-25 15:12:27.904	error	at require (internal/module.js:12:17)
    node-red.0	2018-03-25 15:12:27.904	error	at Module.require (module.js:353:17)
    node-red.0	2018-03-25 15:12:27.904	error	at Function.Module._load (module.js:300:12)
    node-red.0	2018-03-25 15:12:27.904	error	at Module.load (module.js:343:32)
    node-red.0	2018-03-25 15:12:27.904	error	at Object.Module._extensions..js (module.js:416:10)
    node-red.0	2018-03-25 15:12:27.904	error	at Module._compile (module.js:373:25)
    node-red.0	2018-03-25 15:12:27.904	error	at exports.runInThisContext (vm.js:53:16)
    node-red.0	2018-03-25 15:12:27.904	error	25 Mar 15:12:27 - [error] [alexa-local:be811848.8589e8] SyntaxError: Unexpected token =
    node-red.0	2018-03-25 15:12:27.763	warn
    node-red.0	2018-03-25 15:12:27.763	warn	25 Mar 15:12:27 - [info] Flows file : C:\ioBroker\iobroker-data\node-red\flows.json
    node-red.0	2018-03-25 15:12:27.763	warn	25 Mar 15:12:27 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    node-red.0	2018-03-25 15:12:27.763	warn	25 Mar 15:12:27 - [warn] ------------------------------------------------------
    node-red.0	2018-03-25 15:12:27.763	warn	25 Mar 15:12:27 - [warn] [node-red/tail] Not currently supported on Windows.
    node-red.0	2018-03-25 15:12:27.763	warn	25 Mar 15:12:27 - [warn] [node-red/rpi-gpio] Info : Ignoring Raspberry Pi specific node
    node-red.0	2018-03-25 15:12:15.685	info	Starting node-red: --max-old-space-size=128 C:\ioBroker\node_modules\iobroker.node-red/node_modules/node-red/red.js -v --settings C:/ioBroker/iobroker-data/node-red/settings.js
    node-red.0	2018-03-25 15:12:15.591	info	starting. Version 1.5.1 in C:/ioBroker/node_modules/iobroker.node-red, node: v4.5.0
    host.Server	2018-03-25 15:12:14.686	info	instance system.adapter.node-red.0 started with pid 8220
    Hat jemand eine Idee dazu?
    • apollon77A Offline
      Was ist "alexa-local"? Hast Du irgendwelche zusätzliches Module/Nodes angegeben/Installiert?
      • H Offline
        Hc-Yami
        tatsächlich habe ich das getan.
        Um Alexa lokal anzusteuern, benötigt man ja das Alexa.local plugin:
        https://www.npmjs.com/package/node-red- … lexa-local
        Das habe ich ganz einfach über die node.red Oberfläche getan.
          Und genau das verursacht deine Probleme:
          Da musst Du jetzt selbst schauen was kaputt ist. Kein ioBroker Problem.
            @Hc-Yami:
            Das habe ich ganz einfach über die node.red Oberfläche getan. `
            Wie denn das?
            oder geht es hier um node-red standalone?
            ganz einfach geht anders:
            npm-modul ganz einfach da eintragen und Instanz neu starten ;-)
            Rainer
