  4. [Neuer Adapter] ioBroker.places
    2.5k
    4.4k
99 Beiträge 28 Kommentatoren 30.2k Aufrufe 4 Beobachtet
    Mitch
    #81
    ich bekomme jede Minute eine Warnung des Adapters angezeigt:
    Ignoring incomplete message!
    Habt ihr das auch?
    Wie kann ich das Problem beseitigen?
    Ansonsten scheint der Adapter normal zu funktionieren.
    EDIT: Das Problem scheint in Abhängigkeit zu google-schared-location adapter zu bestehen:
    places.0	2018-11-03 23:09:53.697	warn	Ignoring incomplete message!
    google-sharedlocations.0	2018-11-03 23:09:53.621	info	Checking fences.
    google-sharedlocations.0	2018-11-03 23:09:51.458	info	Starting google shared locations adapter
    google-sharedlocations.0	2018-11-03 23:09:51.418	info	starting. Version 1.5.2 in /opt/iobroker/node_modules/iobroker.google-sharedlocations, node: v6.14.4
    host.iobroker	2018-11-03 23:09:49.530	info	instance system.adapter.google-sharedlocations.0 started with pid 1167
    host.iobroker	2018-11-03 23:09:49.500	info	object change system.adapter.google-sharedlocations.0
    fritzdect.0	2018-11-03 23:07:38.028	debug	system.adapter.admin.0: logging true
    fritzdect.0	2018-11-03 23:07:36.720	debug	system.adapter.admin.0: logging false
    host.iobroker	2018-11-03 23:07:36.265	info	instance system.adapter.google-sharedlocations.0 terminated with code 0 (OK)
    google-sharedlocations.0	2018-11-03 23:07:36.232	info	terminating
    host.iobroker	2018-11-03 23:07:35.719	info	stopInstance system.adapter.google-sharedlocations.0 killing pid 1114
    host.iobroker	2018-11-03 23:07:35.717	info	"system.adapter.google-sharedlocations.0" disabled
    google-sharedlocations.0	2018-11-03 23:07:35.722	info	cleaned everything up...
    host.iobroker	2018-11-03 23:07:35.712	info	object change system.adapter.google-sharedlocations.0
    places.0	2018-11-03 23:06:47.494	warn	Ignoring incomplete message!
    google-sharedlocations.0	2018-11-03 23:06:47.473	info	Checking fences.
    google-sharedlocations.0	2018-11-03 23:06:45.483	info	Starting google shared locations adapter
    google-sharedlocations.0	2018-11-03 23:06:45.438	info	starting. Version 1.5.2 in /opt/iobroker/node_modules/iobroker.google-sharedlocations, node: v6.14.4
    host.iobroker	2018-11-03 23:06:43.605	info	instance system.adapter.google-sharedlocations.0 started with pid 1114
    host.iobroker	2018-11-03 23:06:41.624	info	instance system.adapter.google-sharedlocations.0 terminated with code 0 (OK)
    google-sharedlocations.0	2018-11-03 23:06:41.590	info	terminating
    fritzdect.0	2018-11-03 23:06:41.126	debug	system.adapter.admin.0: logging true
    host.iobroker	2018-11-03 23:06:41.079	info	stopInstance system.adapter.google-sharedlocations.0 killing pid 1082
    host.iobroker	2018-11-03 23:06:41.078	info	stopInstance system.adapter.google-sharedlocations.0
    google-sharedlocations.0	2018-11-03 23:06:41.081	info	cleaned everything up...
    host.iobroker	2018-11-03 23:06:41.072	info	object change system.adapter.google-sharedlocations.0
    places.0	2018-11-03 23:06:29.883	warn	Ignoring incomplete message!
    google-sharedlocations.0	2018-11-03 23:06:29.806	info	Checking fences.
    google-sharedlocations.0	2018-11-03 23:06:29.284	info	Polling locations.
    fritzdect.0	2018-11-03 23:06:28.082	debug	polling! fritzdect is alive
    fritzdect.0	2018-11-03 23:05:50.670	debug	system.adapter.admin.0: logging false
    places.0	2018-11-03 23:05:29.977	warn	Ignoring incomplete message!
    google-sharedlocations.0	2018-11-03 23:05:29.933	info	Checking fences.
    google-sharedlocations.0	2018-11-03 23:05:27.842	info	Starting google shared locations adapter
    google-sharedlocations.0	2018-11-03 23:05:27.804	info	starting. Version 1.5.2 in /opt/iobroker/node_modules/iobroker.google-sharedlocations, node: v6.14.4
      BasGo
      #82
      Moin,
      der Adapter gibt diese Fehlermeldung, sofern einer der folgenden Werte in einer empfangenen Nachricht fehlt:
      • User
      • Latitude
      • Longitude
      • Timestamp
          if (!obj.message.user || !obj.message.latitude || !obj.message.longitude || !obj.message.timestamp) {
              adapter.log.warn('Ignoring incomplete message!');
              return;
      Ich kann gerne die empfangene Nachricht mit ins Log aufnehmen bzw. dort ebenfalls ausgeben, würde das helfen? :)
        Mitch
        #83
        Jetzt der Fehler von alleine Weg gegangen. Dafür macht google shared locations Probleme mit dem Login…
        • lobomauL Offline
          lobomauL Offline
          lobomau
          #84
          Ich habe nun bei tasker die Einstellungen vorgenommen, dass die GPS-Koordinaten bei Services vom iot-Adapter abgelegt werden.
          Dann wäre es doch schön, wenn ich beim places-Adapter unter Integration nicht nur cloud-Instanz auswählen kann, sondern auch eine iot-Instanz!? Oder wie mache es hierbei am besten?
          Edit.: habe es nun über cloud eingestellt bekommen. Bin irgendwie verwirrt. Es funktioniert theoretisch mit iot- oder cloud-Adapter.
          Host: NUC8i3 mit Proxmox:
          • Slave: Pi4
            andyb
            #85
            Ich hab da ein Problem….bei mir legt es immer einen "Dummy" an.
            Ich hab schon die Objekte gelöscht, aber er legt es immer wieder an. Blöd auch, weil der immer zuhause ist.
            Konfiguriert sind 2 Handy mit owntracks welche über cloud-Adapter über http schicken.
            F 1 Antwort Letzte Antwort
            • lobomauL Offline
              lobomauL Offline
              lobomau
              #86
              Ich hab auch den Dummy! :-) Hab das ganze heute erst zum Laufen bekommen mit owncloud. Vorher habe ich mit tasker rumprobiert.
              Du brauchst aber Home nicht extra beschreiben. Der places-Adapter nimmt sich die Koordinaten aus den Admin-Einstellungen. Oder hast du diese nicht eingepflegt? Benutzernamen muss man auch nicht machen, wenn die sich nicht unterscheiden; ersetze "x" mit "x" ändert nichts. Jedenfalls habe ich beides nicht eingepflegt, habe nur Ort "work" und das funktioniert auch soweit mit "work" und "home".
              Ich benutze auch owncloud auf dem Handy. Ich habe cloud-pro-Zugang und folgende Einstellungen in owncloud vorgenommen. Vielleicht ist hier irgendwo der Fehler:
              Einstellungen:
              • Verbindung
              –HTTP Privat
              -- Host: https://iobroker.pro/service/custom_own ... 56789/%LOC
              -- Identification: Frage: das Passwort macht doch hier keinen Sinn, oder? Nur wenn ich den owncloud-Adapter verwenden würde.
              • Freunde: taucht nur mein einer user auf.... kein Dummy
              • Slave: Pi4
                andyb
                #87
                Danke, aber wenn du den Dummy User auch hast, dann läuft doch da was komisch.
                Mir wäre der Dummy ja egal, aber nicht wenn er die ganze Zeit bei mir Zuhause ist :lol: und deshalb nie die places.0.anybodyAtHome auf null geht sondern immer auf 1 bleibt, weil ja Dummy zuhause ist :roll:
                Dummy ist allerdings z.B. gerade 1,3km weg von zuhause, wobei mein Handy 10km weg ist und meine Frau zuhause!?
                • lobomauL Offline
                  lobomauL Offline
                  lobomau
                  #88
                  @Bluefox:
                  Kann Adapter auch aus einem Datenpunkt gefüttert werden "7.5567,49.7845356" oder "7.5567;49.7845356" ? `
                  Kann jemand für diesen einfachen Fall ein Script angeben? Ich teste es jetzt mit Hilfe von tasker. Es wird dann unter dem Objekt "cloud.0.services.custom_xyz" der Wert "7.5567,49.7845356" abgelegt. User kann ich ja fest vorgeben.
                  Ich würde dann bei Bedarf für zweite Person einen zweiten Service xyz2 erstellen.
                  Bisher habe ich erfolgreich egigeozone Handy-App und egigeozone-Adapter benutzt gehabt. Aber ich hatte hier offene Ports und möchte sicherer werden.
                  Ich hatte auch owntracks als Handy-App im Einsatz. Funktioniert sehr gut mit places-Adapter. Aber leider war mein Akku zu schnell leer.
                  Jetzt probiere ich deswegen mit tasker.
                  • Slave: Pi4
                    andyb
                    #89
                    Neuerdings hab ich das im Log, funktionieren tut aber eigentlich alles
                    places.0 2018-12-29 09:06:48.152 error Error while requesting route: "timeout"
                    places.0 2018-12-29 09:05:53.153 error Error while requesting route: "timeout"
                    places.0 2018-12-29 09:05:48.144 error Error while requesting elevation: "timeout"
                    places.0 2018-12-29 09:04:53.152 error Error while requesting elevation: "timeout"
                    places.0 2018-12-29 09:04:48.137 error Error while requesting address: "timeout"
                    places.0 2018-12-29 09:03:53.150 error Error while requesting address: "timeout"
                    places.0 2018-12-29 09:02:35.887 error Error while requesting route: "timeout"
                    places.0 2018-12-29 09:00:31.701 error Error while requesting route: "timeout"
                    places.0 2018-12-29 08:59:31.699 error Error while requesting elevation: "timeout"
                    places.0 2018-12-29 08:59:02.983 error Error while requesting elevation: "timeout"
                    places.0 2018-12-29 08:58:31.696 error Error while requesting address: "timeout"
                    places.0 2018-12-29 08:58:02.980 error Error while requesting address: "timeout"
                    places.0 2018-12-29 08:44:28.033 error Error while requesting route: "timeout"
                    places.0 2018-12-29 08:44:27.158 error Error while requesting route: "timeout"
                    places.0 2018-12-29 08:43:28.030 error Error while requesting elevation: "timeout"
                    places.0 2018-12-29 08:43:27.156 error Error while requesting elevation: "timeout"
                    places.0 2018-12-29 08:42:28.028 error Error while requesting address: "timeout"
                    places.0 2018-12-29 08:42:27.155 error Error while requesting address: "timeout"
                    places.0 2018-12-29 08:31:50.326 error Error while requesting route: "timeout"
                    places.0 2018-12-29 08:31:50.204 error Error while requesting route: "timeout"
                    places.0 2018-12-29 08:30:50.324 error Error while requesting elevation: "timeout"
                    places.0 2018-12-29 08:30:50.196 error Error while requesting elevation: "timeout"
                    places.0 2018-12-29 08:29:50.324 error Error while requesting address: "timeout"
                    places.0 2018-12-29 08:29:50.187 error Error while requesting address: "timeout"
                    places.0 2018-12-29 08:25:38.581 error Error while requesting route: "timeout"
                    places.0 2018-12-29 08:24:38.564 error Error while requesting elevation: "timeout"
                    places.0 2018-12-29 08:23:38.556 error Error while requesting address: "timeout"
                    places.0 2018-12-29 08:19:25.300 info starting. Version 0.6.2 in /opt/iobroker/node_modules/iobroker.places, node: v8.14.0
                      andyb
                      #90
                      keiner ausser mir?
                      • N Offline
                        N Offline
                        Nikoxx
                        #91
                        Doch, bei mir auch.
                        • pokemon81P Offline
                          pokemon81P Offline
                          pokemon81
                          #92
                          Kann der Entwikler ggf. noch die Option für die neue iot Cloud mit aufnehmen ?
                          LG
                            SchuetzeSchulz
                            #93
                            hier ein Beispiel-Script wie man den Places-Adapter aus einem Datenpunkt füttert.
                            In meinem Beispiel sende ich die Koordinaten in die Cloud und hole mir aus dem Datenpunkt diese ins Script und tausche Längen- und Breitengrad (da Tasker die scheinbar "falsch rum" sendet:
                            on({id: "cloud.0.services.custom_position_Basti", change: "ne"}, function (obj)
                                var LocationString = obj.state.val;
                                var res = LocationString.split(",");
                                var lat = res[0];
                                var lon = res[1];
                                sendTo('places.0',
                                    user:       "Basti",
                                    latitude:   lat,
                                    longitude:  lon,
                                    timestamp:  obj.state.ts
                                }, function (res) { log(JSON.stringify(res)); });
                            @pokemon81:
                            Kann der Entwikler ggf. noch die Option für die neue iot Cloud mit aufnehmen ? `
                            Das wäre super!
                            Und eventuell noch ne Möglichkeit, mehrere Cloud Custom-Services (ich nutze eine pro Person) abzufragen.
                              BasGo
                              #94
                              @pokemon81:
                              LG `
                              Hat er gemacht 8-)
                              Im Moment ist die Änderung aber nur im https://github.com/BasGo/ioBroker.places, vor dort kann/darf/soll es gerne getestet werden. Wenn soweit alles funktioniert, erstelle ich das NPM-Paket und es wäre im latest-Repository für alle verfügbar.
                              Und wegen der Frage nach mehreren Services: dieses Feature gehe ich gerne nach einem erfolgreichen Test der jetzigen Version an ;)
                              VG
                              Bastian
                                ronnyw
                                #95
                                Ich scheitere irgendwie schon an den Basics.
                                Habe den Adapter installiert. API-Key von Google Maps geholt. Einen Home-Radius eingerichtet.
                                Im Debug Log passiert folgendes (habe die Koordinaten ausgetauscht):
                                `Current configuration: {"radius":"100","homeName":"Zu Hause","places":[{"name":"Zu Hause","latitude":"12.34567","longitude":"12.34567","radius":"172"}],"users":[],"googleApiKey":"AIz[/code]`
                                Dann folgendes Testscript:
                                `~~[code]~~sendTo('places.0', {
                                        user: "Auto",
                                        latitude: 12.34567,
                                        longitude: 12.34567,
                                        timestamp: 1549276723
                                }, function (res) { log(JSON.stringify(res)); });[/code]`
                                Daraufhin im Log:
                                `~~[code]~~Processing message: {"user":"Auto","latitude":12.34567,"longitude":12.34567,"timestamp":1549276723000,"date":"2019-02-04 11:38:43"}[/code]`
                                Die Google Cloud Platform zeigt auch API Aufrufe, die alle mit einem 200 quittiert sind, also wohl okay.
                                Aber die default gesetzten Datenpunkte in ioBroker (anybodyAthome etc) ändern sich nicht und ich bekomme keinen Response vom SendTo bzw. keinen Log-Output mit dem Script  :cry:
                                • lobomauL Offline
                                  lobomauL Offline
                                  lobomau
                                  #96
                                  @SchuetzeSchulz:
                                      var lat = res[0];
                                      var lon = res[1];
                                      sendTo('places.0',
                                          user:       "Basti",
                                          latitude:   lat,
                                          longitude:  lon,
                                  @pokemon81:
                                  Das wäre super!
                                  Und eventuell noch ne Möglichkeit, mehrere Cloud Custom-Services (ich nutze eine pro Person) abzufragen. `
                                  Habe das Script eben erst gesehen und nun in Verwendung. Macht genau das was es soll. Danke!
                                  • Slave: Pi4
                                    mguenther
                                    schrieb am zuletzt editiert von mguenther
                                    #97
                                    ich bin irgendwie zu blöd, den Adapter richtig einzurichten... Ich frage mich allerdings auch, ob ich ggf. auf dem Holzweg bin. Ich würde gerne, sobald mein Auto sich unseren Home-Koordinaten aus dem ADMIN nähert, eine Variable auf true setzen, bzw. eben auf false, wenn ich mich aus dem Radius herausbewege. Jetzt sendet bei mir mein Auto meine Koordinaten und diese werden auch in iobroker eingelesen. Wie muss ich nun places einrichten? Ich kapier es nicht so wirklich...
                                    hier die Daten, die z.B. mein Auto sendet:
                                    Vielen Dank
                                    Marcus
                                    Tante Edit sagt mir gerade, dass mein Auto immer nur bei Klemmenwechsel sendet - somit nützt mir das so nix... :(
                                    • A andyb
                                      FabianFranz
                                      schrieb am zuletzt editiert von FabianFranz
                                      #98
                                      @andyb Konntest du das Problem mit dem dummy User beheben? Ich nutze den Adapter mit 2 Nutzern. Und hin und wieder tauscht immer der ominöse dummy user auf :-(
                                      L 1 Antwort Letzte Antwort
                                      • F FabianFranz
                                        lxs
                                        #99
                                        @FabianFranz Hi, Ich glaube ich habe das Problem gefunden. Wenn du in der owntracks App auch noch zusätzlich zum Places Adapter eigene Orte definierst, dann werden hier Events an den Places adapter beim betreten und verlassen der Zone geschickt. Diese kann der places-adapter nicht zuordnen und erstellt dann einen Dummy user. Nachdem ich bei mir die Orte in der Owntracks App gelöscht habe kam kein Dummy mehr...
                                        Viele Grüße,
                                        Alexander
