  4. Probleme bei Installation Logitech Harmony Hub
4 Beiträge 3 Kommentatoren 756 Aufrufe
    Don71
    Hallo Leute,
    ich bin neu hier und hoffe das mir jemand helfen kann.
    Bei der Installation des Harmony Hub bekomme ich jede menge Fehler angezeigt.
    Andere Adapter konnte ich alle installieren.
    Siehe unten.
    Danke vorab :D
    $ ./iobroker add harmony
    npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call)
    npm
    WARN engine harmonyhubjs-client@1.1.10: wanted: {"npm":">=3.0.0"} (current: {"node":"4.8.7","npm":"2.15.11"})
    npm WARN
    addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
    ! npm WARN
    addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm WARN
    addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
    npm
    WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
    npm WARN
    addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5npm
    WARN addRemoteGit
    at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5npm WARN
    addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)npm
    WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128 because of error: { [Error: not found: git] code: 'ENOGIT' }
    npm
    WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https: www.npmjs.com/package/@xmpp/xml="">
    npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128: undefined
    ! npm
    ERR! Linux 4.4.0-116-generic
    npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.8.7
    ! npm ERR! npm v2.15.11npm ERR! code ENOGIT
    ! npm ERR! not found: gitnpm ERR!
    npm
    ERR! Failed using git.npm ERR! This is most likely not a problem with npm itself.
    npm ERR! Please check if you have git installed and in your PATH.
    ! npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
    ! host.SmartHomePC install adapter harmony
    npm
    npm WARN
    npm WARN
    ! npm WARN addRemoteGit
    at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
    npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
    npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
    npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    npm WARN
    addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128 because of error: { [Error: not found: git] code: 'ENOGIT' }
    ! npm
    ERR!
    npm
    undefined
    npm
    npm
    ERR! argv
    npm
    ERR! code ENOGIT
    npm ERR!
    ! npm ERR! Failed using git.npm ERR! This is most likely not a problem with npm itself.
    npm
    ERR!
    npm
    npm
    npm
    WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit
    npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
    npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)
    ! npm
    npm
    npm
    npm ERR! node v4.8.7npm ERR! npm v2.15.11
    npm ERR!
    npm ERR!
    ERROR: host.SmartHomePC Cannot install harmony
    ERROR: process exited with code 13</https:></https:></https:>
    ****geändert: Code in Code-Tags und Spoiler; Homoran (Mod)****
    • wendy2702W Online
      wendy2702W Online
      wendy2702
      Hi und Willkommen im Forum,
      kannst du das Log bitte beim nächsten mal in Spoiler und Code Tags verpacken!
      Jetzt zum Problem:
      Deine NPM Version ist zu alt. Bitte updaten.
        @wendy2702:
        Deine NPM Version ist zu alt. Bitte updaten. `
        nicht nur ;-)
        @Don71:
        Please check if you have git installed and in your PATH. `
        cd /opt/iobroker
        sudo apt-get install git
        Rainer
        • wendy2702W Online
          wendy2702W Online
          wendy2702
          Handy Display ohne Tapatalk ist definitiv zu klein um hier was zu machen :D
          Rainer hat natürlich recht und ich das überlesen.
