  3. Entwicklung
  4. [gelöst] Hue Motion Sensor Daten auslesen und verarbeiten
    2.6k
    4.6k
    4.0k
287 Beiträge 17 Kommentatoren 72.9k Aufrufe 7 Beobachtet
  • mickymM mickym
    @bag-stg-kft
    Hier zeige ich Dir, wie man Node Red Nodes exportiert und hier postet.
    Erst mal der Spoiler:
    Darin kommt dann der Text in Code Tags
            "id": "1c91eb2a.6924b5",
            "type": "change",
            "z": "6442fb39.022744",
            "name": "extrahiere Celsius",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "payload.celsius",
                    "tot": "msg"
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "$number(payload)\t",
                    "tot": "jsonata"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 810,
            "y": 1120,
            "wires": [
            "id": "6004d3b4.3bff3c",
            "type": "json",
            "name": "",
            "property": "payload",
            "action": "",
            "pretty": false,
            "x": 630,
            "y": 1140,
            "wires": [
                    "1c91eb2a.6924b5",
                    "1b30a759.0bdcb9"
            "id": "1b30a759.0bdcb9",
            "type": "debug",
            "name": "",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "false",
            "statusVal": "",
            "statusType": "auto",
            "x": 790,
            "y": 1200,
            "wires": []
    Nun sind die Nodes exportiert.
    Zum Importieren ....
    BAG-STG -KFTB Offline
    BAG-STG -KFT
    #161
    @mickym ich kann von Node Red exportieren/importieren....... aber hier? muss noch lesen.........
    das ist von Node Red:
    [{"id":"89554c5d.fc87d","type":"inject","z":"b66a6350.12eee","name":"Outdoor","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"Outdoor","payloadType":"str","x":90,"y":80,"wires":[["6ea3eb57.5cc664"]]}]
    • mickymM mickym
      @bag-stg-kft
              "type": "change",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "tot": "msg"
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 810,
              "y": 1120,
              "wires": [
              "type": "json",
              "name": "",
              "action": "",
              "pretty": false,
              "x": 630,
              "y": 1140,
              "wires": [
                      "1c91eb2a.6924b5",
                      "1b30a759.0bdcb9"
              "type": "debug",
              "name": "",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 790,
              "y": 1200,
              "wires": []
      BAG-STG -KFT
      #162
      wie und von wo hierher importieren? bzw. von wo exportieren?
      • BAG-STG -KFTB BAG-STG -KFT
        mickymM Offline
        mickymM Offline
        mickym
        #163
        @bag-stg-kft Hast Du das Video geschaut?
        Das was Du hier von Node Red gepostet hast in den Spoiler und in Code Tags.
        BAG-STG -KFTB 2 Antworten Letzte Antwort
        • mickymM mickym
          BAG-STG -KFT
          #164
          @mickym
            @mickym
            mickymM Offline
            mickymM Offline
            mickym
            #165
            @bag-stg-kft
            Klasse:
            Du siehst ich konnte die Node erfolgreich exportieren.
            • mickymM mickym
              BAG-STG -KFT
              #166
              @mickym
              ich hoffe, habe richtig gemacht........
              1. Auge
              2. Code
              3. Einfügen (vorher export in Zwischenablage in Node Red)
              4. Spoiler klicken
              5. senden
              • mickymM mickym
                @bag-stg-kft
                Klasse:
                BAG-STG -KFT
                #167
                @mickym
                [{"id":"89554c5d.fc87d","type":"inject","z":"b66a6350.12eee","name":"Outdoor","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"Outdoor","payloadType":"str","x":90,"y":80,"wires":[["6ea3eb57.5cc664"]]},{"id":"6ea3eb57.5cc664","type":"mqtt out","z":"b66a6350.12eee","name":"/outdoorsensor/temperature","topic":"/outdoorsensor/temperature","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"88095ea7.00c13","x":320,"y":80,"wires":[]},{"id":"88095ea7.00c13","type":"mqtt-broker","name":"Outdoorsensor","broker":"192.168.1.170","port":"1883","clientid":"","usetls":false,"protocolVersion":"3","keepalive":"60","cleansession":true,"birthTopic":"/outdoorsensor/temperature","birthQos":"1","birthRetain":"true","birthPayload":"/outdoorsensor/temperature","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
                • mickymM mickym
                  @bag-stg-kft
                  Klasse:
                  BAG-STG -KFT
                  #168
                  @mickym nur, was bringt dir das, wenn es je nicht funktioniert?
                  Bei mir ist es gar nicht, wie bei dir, mit "laufender Linie"
                    @mickym
                    mickymM Offline
                    mickymM Offline
                    mickym
                    #169
                    @bag-stg-kft
                    Auch das funktioniert hervorragend:
                    Das liegt aber nicht an den Nodes.
                    Hast Du irgendeinen Fehler oder die Nodes ggf. deaktiviert?
                    BAG-STG -KFTB 3 Antworten Letzte Antwort
                    • mickymM mickym
                      @bag-stg-kft
                      BAG-STG -KFT
                      #170
                      @mickym Ich weiß schon!!!!!!!!!!!!!!!!!!!!!!
                      Ich habe herum experementiert und flow2 deaktiviert....... nun jetzt muss suchen, wo ich es wieder aktiviere....... :)
                      • mickymM mickym
                        @bag-stg-kft
                        BAG-STG -KFT
                        #171
                        @mickym jetzt funkzt, nur keine Werte.....
                        • mickymM mickym
                          @bag-stg-kft
                          BAG-STG -KFT
                          #172
                          @mickym
                          [{"id":"89554c5d.fc87d","type":"inject","z":"b66a6350.12eee","name":"Outdoor","props":[{"p":"payload"}],"repeat":"5","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"Outdoor","payloadType":"str","x":90,"y":80,"wires":[["6ea3eb57.5cc664"]]},{"id":"6ea3eb57.5cc664","type":"mqtt out","z":"b66a6350.12eee","name":"/outdoorsensor/temperature","topic":"/outdoorsensor/temperature","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"88095ea7.00c13","x":320,"y":80,"wires":[]},{"id":"88095ea7.00c13","type":"mqtt-broker","name":"Outdoorsensor","broker":"192.168.1.170","port":"1883","clientid":"","usetls":false,"protocolVersion":"3","keepalive":"60","cleansession":true,"birthTopic":"/outdoorsensor/temperature","birthQos":"1","birthRetain":"true","birthPayload":"/outdoorsensor/temperature","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #173
                            @bag-stg-kft
                            Du sollst doch erst mal schauen, ob nun Outdoor als String so in Deinem ESP angezeigt wird, wie Du es da reingeschrieben hast und mach das bitte wieder aus, das automatisch Injected wird - das soll doch nur funktionieren indem Du auf die Schaltfläche klickst.
                            Dann sollte in Deinem ESP jetzt Outdoor stehen.
                            Da sollte ja jetzt nicht mehr der JSON String sondern einfach nur Outdoor drin stehen.
                            BAG-STG -KFTB mickymM 2 Antworten Letzte Antwort
                            • mickymM mickym
                              @bag-stg-kft
                              BAG-STG -KFT
                              #174
                              @mickym Also im ESP (und allgemein) ist der Name "Draußentemperatur"
                              Der Sensorname (von HUE) automatisch als "outdoorsensor" und das wollte nie umschreiben, wegen HUE-Bridge und sonstige APPS, bevor nicht alle fix ist, weil ich Angst hatte, dass es nicht mehr gefunden wird.......
                              Selbst in HASSIO habe ich in Konfigurationsdatei als Sensor "Draußentemperatur" hingefügt gehabt, nur bekam keine Werte angezeigt. Deshalb habe ich angefangen nach Lösungen zu suchen, und so kam ich eigentlich zu Node Red, was für mich ziemlich kompliziert ist, obwohl es mit grafisches Zeichen relative einfach scheint, nur diese JSON, Value, Topic etc habe 0 Ahnung........ Ich habe die Plex und Kodi (xmbc) auch auf Windows installiert, weil ich 0 Ahnung zu "Elek" und "Himbeer" habe
                              so ist die Einstellung in ESP als MQTT import:
                              • mickymM mickym
                                @bag-stg-kft
                                mickymM Offline
                                mickymM Offline
                                mickym
                                #175
                                @mickym Ok Ja das habe ich alles verstanden - auch wenn Du jetzt keine Werte sieht, sieht Du jetzt das Wort Outdoor als Wert in Deinem ESP zu sehen, wenn Du die Inject Node drückst.
                                Das da noch keine Werte drin stehen ist vollig klar. Da sollte das drin stehen, was wir mit der Inject Node injizieren. Zu den Werten kommen wir gleich.
                                Wenn das soweit hinhaut, dann hängst Du bitte ein Debug Node an Deine HUE Node und postest als Screenshot erst mal
                                Dein Debugfenster mit dem Output.
                                Das sollte dann ungefähr so aussehen:
                                • mickymM mickym
                                  BAG-STG -KFT
                                  #176
                                  @mickym öhhhhm....
                                  wie bitte?
                                  also im ESP steht es, wie vorhin gezeigt.....
                                  Als "Wert" verlangt es nach irgendwelchem "Value", wovon ich ß Ahnung habe, was das sein soll......
                                  Im HASSIO schaue gleich und poste short......
                                    @mickym öhhhhm....
                                    wie bitte?
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    #177
                                    @bag-stg-kft
                                    Isolier mal die HUE Node - das die zwischenzeitlich nichts in den MQTT Datenpunkt schreibt.
                                    BAG-STG -KFTB 1 Antwort Letzte Antwort
                                    • mickymM mickym
                                      BAG-STG -KFT
                                      schrieb am zuletzt editiert von BAG-STG -KFT
                                      #178
                                      @mickym Wir kommen näher!!!!!!!!!!!!!!!!!!!!!
                                      Also als Sensor ist ja mal schon in HASSIO
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        #179
                                        @bag-stg-kft Na super langsam kommen wir der Sache näher. Es sind also doch so aus als ob nur der nummerische Wert verlangt wird.
                                        So stell einfach mal die Inject Node auf nummerisch um und gibt einer Zahl ein zum Beispiel 23.3
                                        Darauf achten, dass hier numerisch steht (hab es markiert)
                                        • mickymM mickym
                                          @bag-stg-kft
                                          BAG-STG -KFT
                                          #180
                                          @mickym na bitte langsam.......
                                          was bedeutet bitte "isolieren"????? soll ich was ausschalten? Deaktivieren?
