  4. IOBroker läuft nicht mehr - Bitte um Unterstützung
52 Beiträge 6 Kommentatoren 5.0k Aufrufe
    Bernd217
    #41
    @wendy2702:
    was zeigt zeigt````
    fdisk -l
    Laut config log ändert er die Partition ja…
    Sonst... Backup der SD Karte machen und manuel versuchen:
    [http://www.gtkdb.de/index_36_2140.html](http://www.gtkdb.de/index_36_2140.html) `
    ! pi@ioBroker-Pi:~ $ sudo fdisk -l Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram4: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram5: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram6: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram7: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram8: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram9: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram10: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram11: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram12: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram13: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram14: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram15: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/mmcblk0: 14,6 GiB, 15640559616 bytes, 30547968 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0xf1cdf13d ! Device Boot Start End Sectors Size Id Type /dev/mmcblk0p1 8192 93813 85622 41,8M c W95 FAT32 (LBA) /dev/mmcblk0p2 94208 3862527 3768320 1,8G 83 Linux !
    • wendy2702W Online
      wendy2702W Online
      wendy2702
      #42
      OK.
      Partition Änderung wurde nicht richtig geschrieben.
      Keine Ahnung warum er das nicht macht.
      Läuft auf dem PI noch etwas anderes?
      kannst du mal versuchen das "raspi-config" tool upzudaten?
      Sollte Menü Punkt "8" sein.
      Das würde ich nochmal versuchen, danach nochmal expand filesystem und wenn es immer noch nicht klappt würde ich persönlich das mit dem Backup machen und den manuellen weg versuchen.
        #43
        Seltsam, die Diskgröße wird richtig erkannt, aber die Partition hat nur 2GB
        Sieh zu, dass du dir die Daten von ioBroker mit ftp (Filezilla) sicherst, anschließend ioBroker neu aufsetzst und dann die Daten zurückspielst.
        Rainer
          Bernd217
          #44
          @wendy2702:
          OK.
          Das würde ich nochmal versuchen, danach nochmal expand filesystem und wenn es immer noch nicht klappt würde ich persönlich das mit dem Backup machen und den manuellen weg versuchen. `
          Danke für Eure Hilfe.
          ich mache jetzt nochmals ein Update - wenn es dann nicht geht, setze ich neu auf. Views habe ich keine - von daher hält sich der Aufwand in Grenzen.
            Bernd217
            #45
            @Homoran:
            Rainer `
            Soll ich dazu eine neu SD - Karte verwenden, oder kann ich dazu auch die bisherige nehmen?
            VG
            Bernd
              #46
              Ich würde definitiv ein neue vorziehen
              und unmittelbar nach dem resize mit df -h nachsehen ob es geklappt hat
              Rainer
              • wendy2702W Online
                wendy2702W Online
                wendy2702
                #47
                Wenn du ne zweite Karte hast…
                spiel doch einfach mal das Backup Image der aktuellen auf die neue und probier dann mal das Expand Filesystem.
                • paul53P Offline
                  #48
                  @Bernd217:
                  Views habe ich keine - von daher hält sich der Aufwand in Grenzen. `
                  Das Verzeichnis /opt/iobroker/iobroker-data würde ich mir trotzdem auf den PC sichern.
                    Bernd217
                    #49
                    Vielen Dank - ich versuche es mal.
                      #50
                      @Bernd217:
                      bei Amazon gekauft `
                      Das bedeutet leider gar nichts.
                      Da gibt es jede Menge Fälschungen :(
                      https://www.welt.de/wall-street-journal/article127938988/Warum-Amazon-so-oft-Faelschungen-versendet.html
                      Rainer
                      • W Online
                        W Online
                        Wildbill
                        #51
                        nur so zur Sicherheit. Der reboot erfolge aber schon über die console mittels "sudo reboot" und nicht durch bloßes Abstecken des Strims und Wiederanstecken?
                        Nur bei einem sauberen Reboot mit Herunter- und wieder neu hochfahren werden solche Änderungen auch übernommen.
                        Gruss, Jürgen
                        • wendy2702W Online
                          wendy2702W Online
                          wendy2702
                          #52
                          @Bernd217:
                          Vielen Dank - ich versuche es mal. `
                          Was ist denn hierbei rausgekommen?
