  4. IOBroker läuft nicht mehr - Bitte um Unterstützung
52 Beiträge 6 Kommentatoren 5.0k Aufrufe
  • wendy2702W Online
    wendy2702W Online
    sudo fdisk -l
    Hoffe die Karte hast du bei einem halbwegs seriösen Händler gekauft und nicht auf dem Flohmarkt oder so…
    Aufdrucken kann man ja viel.
      Bernd217
      @wendy2702:
      sudo fdisk -l
      Aufdrucken kann man ja viel. `
      ! pi@ioBroker-Pi:~ $ sudo fdisk -l Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram4: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram5: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram6: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram7: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram8: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram9: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram10: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram11: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram12: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram13: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram14: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram15: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/mmcblk0: 14,6 GiB, 15640559616 bytes, 30547968 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0xf1cdf13d ! Device Boot Start End Sectors Size Id Type /dev/mmcblk0p1 8192 93813 85622 41,8M c W95 FAT32 (LBA) /dev/mmcblk0p2 94208 30547967 30453760 14,5G 83 Linux pi@ioBroker-Pi:~ $ !
      bei Amazon gekauft
      Das zeigt er mir nachdem ich nochmals in der config war
      ! pi@ioBroker-Pi:~ $ sudo raspi-config ! Welcome to fdisk (util-linux 2.29.2). Changes will remain in memory only, until you decide to write them. Be careful before using the write command. ! Command (m for help): Disk /dev/mmcblk0: 14,6 GiB, 15640559616 bytes, 30547968 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0xf1cdf13d ! Device Boot Start End Sectors Size Id Type /dev/mmcblk0p1 8192 93813 85622 41,8M c W95 FAT32 (LBA) /dev/mmcblk0p2 94208 3862527 3768320 1,8G 83 Linux ! Command (m for help): Partition number (1,2, default 2): Partition 2 has been deleted. ! Command (m for help): Partition type p primary (1 primary, 0 extended, 3 free) e extended (container for logical partitions) Select (default p): Partition number (2-4, default 2): First sector (2048-30547967, default 2048): Last sector, +sectors or +size{K,M,G,T,P} (94208-30547967, default 30547967): Created a new partition 2 of type 'Linux' and of size 14,5 GiB. Partition #2 contains a ext4 signature. ! Command (m for help): Disk /dev/mmcblk0: 14,6 GiB, 15640559616 bytes, 30547968 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0xf1cdf13d ! Device Boot Start End Sectors Size Id Type /dev/mmcblk0p1 8192 93813 85622 41,8M c W95 FAT32 (LBA) /dev/mmcblk0p2 94208 30547967 30453760 14,5G 83 Linux ! Command (m for help): The partition table has been altered. Calling ioctl() to re-read partition table. Re-reading the partition table failed.: Das Gerät oder die Ressource ist belegt ! The kernel still uses the old table. The new table will be used at the next reboot or after you run partprobe(8) or kpartx(8). !
      Nach einem Reboot zeigt er dennoch nur
      Dateisystem Größe Benutzt Verf. Verw% Eingehängt auf
      /dev/root 1,8G 1,5G 150M 92% /
      an. Das verstehe ich nicht.
      • wendy2702W Online
        wendy2702W Online
        was zeigt zeigt````
        fdisk -l
        Laut config log ändert er die Partition ja…
        Sonst... Backup der SD Karte machen und manuel versuchen:
        [http://www.gtkdb.de/index_36_2140.html](http://www.gtkdb.de/index_36_2140.html)
          Bernd217
          @wendy2702:
          was zeigt zeigt````
          fdisk -l
          [http://www.gtkdb.de/index_36_2140.html](http://www.gtkdb.de/index_36_2140.html) `
          ! pi@ioBroker-Pi:~ $ sudo fdisk -l Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram4: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram5: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram6: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram7: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram8: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram9: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram10: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram11: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram12: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram13: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram14: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/ram15: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes ! Disk /dev/mmcblk0: 14,6 GiB, 15640559616 bytes, 30547968 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0xf1cdf13d ! Device Boot Start End Sectors Size Id Type /dev/mmcblk0p1 8192 93813 85622 41,8M c W95 FAT32 (LBA) /dev/mmcblk0p2 94208 3862527 3768320 1,8G 83 Linux !
          • wendy2702W Online
            wendy2702W Online
            OK.
            Partition Änderung wurde nicht richtig geschrieben.
            Keine Ahnung warum er das nicht macht.
            Läuft auf dem PI noch etwas anderes?
            kannst du mal versuchen das "raspi-config" tool upzudaten?
            Sollte Menü Punkt "8" sein.
            Das würde ich nochmal versuchen, danach nochmal expand filesystem und wenn es immer noch nicht klappt würde ich persönlich das mit dem Backup machen und den manuellen weg versuchen.
              Seltsam, die Diskgröße wird richtig erkannt, aber die Partition hat nur 2GB
              Sieh zu, dass du dir die Daten von ioBroker mit ftp (Filezilla) sicherst, anschließend ioBroker neu aufsetzst und dann die Daten zurückspielst.
                Bernd217
                @wendy2702:
                OK.
                Das würde ich nochmal versuchen, danach nochmal expand filesystem und wenn es immer noch nicht klappt würde ich persönlich das mit dem Backup machen und den manuellen weg versuchen. `
                Danke für Eure Hilfe.
                ich mache jetzt nochmals ein Update - wenn es dann nicht geht, setze ich neu auf. Views habe ich keine - von daher hält sich der Aufwand in Grenzen.
                  Bernd217
                  @Homoran:
                  Rainer `
                  Soll ich dazu eine neu SD - Karte verwenden, oder kann ich dazu auch die bisherige nehmen?
                  Bernd
                    Ich würde definitiv ein neue vorziehen
                    und unmittelbar nach dem resize mit df -h nachsehen ob es geklappt hat
                    • wendy2702W Online
                      wendy2702W Online
                      Wenn du ne zweite Karte hast…
                      spiel doch einfach mal das Backup Image der aktuellen auf die neue und probier dann mal das Expand Filesystem.
                      • paul53P Offline
                        @Bernd217:
                        Views habe ich keine - von daher hält sich der Aufwand in Grenzen. `
                        Das Verzeichnis /opt/iobroker/iobroker-data würde ich mir trotzdem auf den PC sichern.
                          Bernd217
                          Vielen Dank - ich versuche es mal.
                            @Bernd217:
                            bei Amazon gekauft `
                            Das bedeutet leider gar nichts.
                            Da gibt es jede Menge Fälschungen :(
                            https://www.welt.de/wall-street-journal/article127938988/Warum-Amazon-so-oft-Faelschungen-versendet.html
                            • W Online
                              W Online
                              Wildbill
                              nur so zur Sicherheit. Der reboot erfolge aber schon über die console mittels "sudo reboot" und nicht durch bloßes Abstecken des Strims und Wiederanstecken?
                              Nur bei einem sauberen Reboot mit Herunter- und wieder neu hochfahren werden solche Änderungen auch übernommen.
                              Gruss, Jürgen
                              • wendy2702W Online
                                wendy2702W Online
                                @Bernd217:
                                Vielen Dank - ich versuche es mal. `
                                Was ist denn hierbei rausgekommen?
