  4. Mqtt - Fehler im Log
6 Beiträge 3 Kommentatoren 959 Aufrufe
  • L Online
    L Online
    Linedancer
    Hallo Gemeinde,
    ich habe seit gestern den mqtt Adapter am laufen. Datenquellen sind 2x Sonoff mit Tasmota und ein Wemos mit Easy ESP.
    Der Datenempfang funktioniert problemlos, allerdings müllt mir der mqtt Adapter des Log voll:
    ! mqtt.0 18.01.2018 16:19 warn Cannot resolve topic name for ID: system.adapter.sayit.0.inputCount (object not found) mqtt.0 18.01.2018 16:19 warn Cannot resolve topic name for ID: system.adapter.hue.0.outputCount (object not found) mqtt.0 18.01.2018 16:19 warn Cannot resolve topic name for ID: system.adapter.hue.0.inputCount (object not found) mqtt.0 18.01.2018 16:19 warn Cannot resolve topic name for ID: system.adapter.tr-064.0.outputCount (object not found) mqtt.0 18.01.2018 16:19 warn Cannot resolve topic name for ID: system.adapter.tr-064.0.inputCount (object not found) mqtt.0 18.01.2018 16:19 warn Cannot resolve topic name for ID: system.adapter.scenes.0.outputCount (object not found) mqtt.0 18.01.2018 16:19 warn Cannot resolve topic name for ID: system.adapter.scenes.0.inputCount (object not found) mqtt.0 18.01.2018 16:19 warn Cannot resolve topic name for ID: system.adapter.simple-api.0.outputCount (object not found) mqtt.0 18.01.2018 16:19 warn Cannot resolve topic name for ID: system.adapter.simple-api.0.inputCount (object not found) mqtt.0 18.01.2018 16:19 warn Cannot resolve topic name for ID: system.adapter.sayit.4.outputCount (object not found) mqtt.0 18.01.2018 16:19 warn Cannot resolve topic name for ID: system.adapter.sayit.4.inputCount (object not found) mqtt.0 18.01.2018 16:19 warn Cannot resolve topic name for ID: system.adapter.sonos.0.outputCount (object not found) mqtt.0 18.01.2018 16:19 warn Cannot resolve topic name for ID: system.adapter.sonos.0.inputCount (object not found) mqtt.0 18.01.2018 16:19 warn Cannot resolve topic name for ID: system.adapter.history.0.outputCount (object not found) mqtt.0 18.01.2018 16:19 warn Cannot resolve topic name for ID: system.adapter.history.0.inputCount (object not found) mqtt.0 18.01.2018 16:19 warn Cannot resolve topic name for ID: system.adapter.telegram.0.outputCount (object not found) mqtt.0 18.01.2018 16:19 warn Cannot resolve topic name for ID: system.adapter.telegram.0.inputCount (object not found) mqtt.0 18.01.2018 16:19 warn Cannot resolve topic name for ID: system.adapter.telegram.1.outputCount (object not found) mqtt.0 18.01.2018 16:19 warn Cannot resolve topic name for ID: system.adapter.telegram.1.inputCount (object not found) mqtt.0 2018-01-18 16:19:46.018 warn Cannot resolve topic name for ID: system.adapter.sayit.2.outputCount (object not found) mqtt.0 2018-01-18 16:19:46.018 warn Cannot resolve topic name for ID: system.adapter.sayit.2.inputCount (object not found) mqtt.0 2018-01-18 16:19:46.017 warn Cannot resolve topic name for ID: system.adapter.fritzbox.0.outputCount (object not found) !
    Hier die Enstellungen des Adapters:
    Gibt's Vorschlage wie ich das abstellen kann?
    Ciao, Gerhard
    • apollon77A Offline
      Brauchst Du echt "*" als zu veröffentlichte Datenpunkte? Willst DU überhaupt das iobroker Daten raus sendet? Oder nur empfangen?
      • L Online
        L Online
        Linedancer
        Nö, ich will nix raus senden.
        Ich vermute die meinst den Eintrag "Maske für Bekanntgeben von eigenen States:"
        Den hatte ich in Verdacht, weiss aber nicht wirklich was ich da eintragen muss. Das rausnehmen des "*" hat nix geändert. Dire Doku des Adapters hat mich auch nicht wirklich weiter gebracht.
        Ciao, Gerhard
          Alveran
          Kann dein MQTT Adpater auf dem IOBroker daten senden?
          • L Online
            L Online
            Linedancer
            Mit dem Senden habe ich mich noch nicht beschäftigt. Müsste erstmal schauen wie das überhaupt läuft.
            Ciao, Gerhard
              Alveran
              Probier mal bitte. Meiner sendet nicht.
