  4. HTTP und Blockly dreht durch….
    1.0k
    6.1k
4 Beiträge 2 Kommentatoren 850 Aufrufe
    Blackeye
    bin noch etwas unerfahren und versuche mich an Blockly…
    Ein paar Regeln habe ich schon und die funktionieren sogar, nur hier habe ich ein paar Probleme:
    14:00:03.774	[error]	javascript.0 ReferenceError: e is not defined at Request. (script.js.common.Aktion_aus_wenn_nicht_gebraucht:4:116) at emitOne (events.js:96:13) at Request.emit (events.js:188:7) at Request.onRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:878:8) at emitOne (events.js:96:13) at ClientRequest.emit (events.js:188:7) at Socket.socketErrorListener (_http_client.js:309:9) at emitOne (events.js:96:13) at Socket.emit (events.js:188:7) at emitErrorNT (net.js:1277:8)
    14:00:03.774	[error]	javascript.0 ReferenceError: e is not defined at Request. (script.js.common.Aktion_aus_wenn_nicht_gebraucht:4:116) at emitOne (events.js:96:13) at Request.emit (events.js:188:7) at Request.onRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:878:8) at emitOne (events.js:96:13) at ClientRequest.emit (events.js:188:7) at Socket.socketCloseListener (_http_client.js:285:9) at emitOne (events.js:101:20) at Socket.emit (events.js:188:7) at TCP._handle.close [as _onclose] (net.js:497:12)
    14:00:38.603	[info]	javascript.0 Start javascript script.js.common.Aktion_aus_wenn_nicht_gebraucht
    14:00:38.604	[info]	javascript.0 script.js.common.Aktion_aus_wenn_nicht_gebraucht: registered 0 subscriptions and 1 schedule
    14:05:03.772	[error]	javascript.0 ReferenceError: e is not defined at Request. (script.js.common.Aktion_aus_wenn_nicht_gebraucht:4:116) at emitOne (events.js:96:13) at Request.emit (events.js:188:7) at Request.onRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:878:8) at emitOne (events.js:96:13) at ClientRequest.emit (events.js:188:7) at Socket.socketErrorListener (_http_client.js:309:9) at emitOne (events.js:96:13) at Socket.emit (events.js:188:7) at emitErrorNT (net.js:1277:8)
    14:05:03.773	[error]	javascript.0 ReferenceError: e is not defined at Request. (script.js.common.Aktion_aus_wenn_nicht_gebraucht:4:116) at emitOne (events.js:96:13) at Request.emit (events.js:188:7) at Request.onRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:878:8) at emitOne (events.js:96:13) at ClientRequest.emit (events.js:188:7) at Socket.socketCloseListener (_http_client.js:285:9) at emitOne (events.js:101:20) at Socket.emit (events.js:188:7) at TCP._handle.close [as _onclose] (net.js:497:12)
    und noch eine Frage….
    Wenn ich sehr viele Bedingungen habe die abgeprüft werden sollen, klappt das nur wenn ich alles nur in einem String klicke oder kann ich es auch untereinander machen?
    Wenn ich jetzt hier noch 3 Bedingungen mehr habe, wird es für mich was unübersichtlich….
    Lars
    • DutchmanD Offline
      DutchmanD Offline
      Dutchman
      steure mit sollte ein text sein kein mathematische nummer.
      Warum willst du uebrigens den TV per script ausschalten dafuer hat man doch in harmony die activitaeten ?
      zur 2ten frage, geht auch so (rechter mausklik auf die abfrage und dan externe eingaenge):
        Blackeye
        teilweise springt der Fernseher automatisch an und dann soll er gefälligst auch wieder ausgehen.
        Und mit dem Text… Es gab Fehlereinträge im Log, das es sich um Typ Boolean handelt und daher bin ich auf Nummern gegangen.
        Habe es jetzt geändert und jetzt kommt das:
        javascript.0	2017-10-08 15:26:00.921	warn	at Object. (script.js.common.Aktion_aus_wenn_nicht_gebraucht:8:5)
        javascript.0	2017-10-08 15:26:00.919	warn	Wrong type of harmony.0.Stube.Sony-Fernseher.PowerOff: "string". Please fix, while deprecated and will not work in next versions.
        javascript.0	2017-10-08 15:25:00.946	warn	at Object. (script.js.common.Aktion_aus_wenn_nicht_gebraucht:8:5)
        javascript.0	2017-10-08 15:25:00.920	warn	Wrong type of harmony.0.Stube.Sony-Fernseher.PowerOff: "string". Please fix, while deprecated and will not work in next versions.
        Aber dieses Mal nur Warnungen und keine Fehler mehr
        Und die externen Eingänge, trotzdem gehen doch nur 2 Bedingungen, oder?
        • DutchmanD Offline
          DutchmanD Offline
          Dutchman
          @Blackeye:
          Danke `
          komt drauf af was du meinst es gehen soviele bedinungen wie du willst, sowas z.b.
          oder so
          sonst wen gibts aber auch ?
