  4. stable Adapterupdates
    5.4k
repositoryadapter update
57 Beiträge 6 Kommentatoren 7.0k Aufrufe 5 Beobachtet
  • L Lollo
    @thomas-braun dieses pendig updates: 36.
    Hab bis jetzt immer nur
    iob update
    gemacht.
    Oh. Gott, das wird ja immer peinlicher für mich 🙈
    crunchipC Offline
    crunchipC Offline
    @lollo damir holst du dir ja nur die Info was es neues am Markt gibt, ausgeführt wird da aber nix
    • L Lollo
      *** BASE SYSTEM ***
      Architecture    : x86_64
      Docker          : false
      Virtualization  : lxc
      Distributor ID: Ubuntu
      Description:    Ubuntu 20.04.6 LTS
      Release:        20.04
      Codename:       focal
      NAME="Ubuntu"
      VERSION="20.04.6 LTS (Focal Fossa)"
      ID=ubuntu
      ID_LIKE=debian
      PRETTY_NAME="Ubuntu 20.04.6 LTS"
      VERSION_ID="20.04"
      HOME_URL="https://www.ubuntu.com/"
      SUPPORT_URL="https://help.ubuntu.com/"
      BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
      PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
      VERSION_CODENAME=focal
      UBUNTU_CODENAME=focal
      Systemuptime and Load:
       21:17:41 up 30 days, 11:45,  2 users,  load average: 0.65, 0.77, 0.67
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Wed 2023-05-31 21:17:41 CEST
                 Universal time: Wed 2023-05-31 19:17:41 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           7.8G        2.6G        4.8G        0.0K        497M        5.3G
      Swap:          7.2G        2.1G        5.1G
      Total:          14G        4.7G        9.8G
               7823 M total memory
               2561 M used memory
               2159 M active memory
                717 M inactive memory
               4764 M free memory
                  0 M buffer memory
                497 M swap cache
               7167 M total swap
               2114 M used swap
               5053 M free swap
      *** FILESYSTEM ***
      Filesystem                       Type   Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--103--disk--0 ext4    20G  8.3G   11G  45% /
      none                             tmpfs  492K  4.0K  488K   1% /dev
      tmpfs                            tmpfs  3.9G     0  3.9G   0% /dev/shm
      tmpfs                            tmpfs  783M  136K  783M   1% /run
      tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs  783M     0  783M   0% /run/user/0
      [Wed May 24 02:30:19 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
      [Wed May 24 02:30:19 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
      [Wed May 24 02:32:23 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
      [Wed May 24 02:32:23 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
      [Wed May 24 02:36:55 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
      [Wed May 24 02:36:55 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
      [Fri May 26 02:30:20 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
      [Fri May 26 02:30:20 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
      [Fri May 26 02:32:37 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
      [Fri May 26 02:32:37 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
      [Fri May 26 02:37:10 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
      [Fri May 26 02:37:10 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
      [Sun May 28 02:30:19 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
      [Sun May 28 02:30:19 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
      [Sun May 28 02:32:25 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
      [Sun May 28 02:32:25 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
      [Sun May 28 02:36:57 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
      [Sun May 28 02:36:57 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
      [Mon May 29 02:30:20 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
      [Mon May 29 02:30:20 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
      [Mon May 29 02:34:33 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
      [Mon May 29 02:34:33 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
      [Mon May 29 02:39:04 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
      [Mon May 29 02:39:04 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
      [Wed May 31 02:30:20 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
      [Wed May 31 02:30:20 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
      [Wed May 31 02:32:42 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
      [Wed May 31 02:32:42 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
      [Wed May 31 02:37:13 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
      [Wed May 31 02:37:13 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
      TARGET                    SOURCE                           FSTYPE     OPTIONS
      /                         /dev/mapper/pve-vm--103--disk--0 ext4       rw,relatime,stripe=16
      |-/proc/cpuinfo           lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/diskstats         lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/loadavg           lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/meminfo           lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/slabinfo          lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/stat              lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/swaps             lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/uptime            lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      `-/sys/devices/system/cpu lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      /var:
      2.9G    /var/
      1.9G    /var/log/journal/b354c482f7cc342776f020ee5ea440c3
      1.9G    /var/log
      718M    /var/cache
      Archived and active journals take up 1.8G in the file system.
      /opt/iobroker/backups:
      330M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      691M    /opt/iobroker/iobroker-data/
      461M    /opt/iobroker/iobroker-data/files
      170M    /opt/iobroker/iobroker-data/backup-objects
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      72M     /opt/iobroker/iobroker-data/files/telegram.admin
      33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.4f0a34b4.js.map
      25M     /opt/iobroker/iobroker-data/objects.jsonl
      19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
      15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
      14M     /opt/iobroker/iobroker-data/objects.json.migrated
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.16.0
      /usr/bin/node           v18.16.0
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Installed: 18.16.0-deb-1nodesource1
        Candidate: 18.16.0-deb-1nodesource1
        Version table:
       *** 18.16.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x focal/main amd64 Packages
           10.19.0~dfsg-3ubuntu1 500
              500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     6.1.4
      Adapters from github:   1
      Adapter State
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 80
        system.adapter.devices.0                : devices               : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
        system.adapter.mqtt.0                   : mqtt                  : iobroker                                 - disabled, port: 1886, bind: 0.0.0.0
      + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
      + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1881, bind: 0.0.0.0
        system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 - disabled
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.weishaupt-wem.0          : weishaupt-wem         : iobroker                                 -  enabled
      + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
      + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Installed ioBroker-Instances
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "backitup"     : 2.6.19   , installed 2.6.19
      Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
      Adapter    "devices"      : 1.1.2    , installed 1.1.1  [Updatable]
      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
      Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
      Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
      Adapter    "hue"          : 3.7.1    , installed 3.7.1
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "iot"          : 1.14.2   , installed 1.14.2
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "shelly"       : 6.3.1    , installed 6.3.1
      Adapter    "shuttercontrol": 1.4.29  , installed 1.4.29
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "telegram"     : 1.15.2   , installed 1.15.2
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "tuya"         : 3.13.1   , installed 3.13.1
      Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
      Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Adapter    "weishaupt-wem": 0.0.15   , installed 0.0.15
      Adapter    "wled"         : 0.6.7    , installed 0.6.7
      Adapter    "yahka"        : 0.17.0   , installed 0.17.0
      Objects and States
      Objects:        14811
      States:         13118
      Hit:1 http://archive.ubuntu.com/ubuntu focal InRelease
      Hit:2 https://deb.nodesource.com/node_18.x focal InRelease
      Hit:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
      Hit:4 http://archive.ubuntu.com/ubuntu focal-security InRelease
      Reading package lists...
      Pending Updates: 36
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          60758284   1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          60759546   195/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       60757959   143/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       60760619   143/iobroker.js-con
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        60757577   96/systemd-resolved
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          60760384   323/master
      tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1000       60770477   1032/io.shelly.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       60769562   1081/io.sonoff.0
      tcp        0      0 192.168.178.90:9292     0.0.0.0:*               LISTEN      1000       87757932   53414/io.hm-rpc.1
      tcp        0      0 192.168.178.90:2010     0.0.0.0:*               LISTEN      1000       87757719   53429/io.hm-rpc.0
      tcp        0      0 192.168.178.90:2001     0.0.0.0:*               LISTEN      1000       87757901   53399/io.hm-rpc.2
      tcp6       0      0 :::111                  :::*                    LISTEN      0          60758288   1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          60760385   323/master
      tcp6       0      0 :::22                   :::*                    LISTEN      0          60759557   195/sshd: /usr/sbin
      tcp6       0      0 :::39571                :::*                    LISTEN      1000       60788843   2684/io.yahka.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       60762210   343/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       60784496   2520/io.web.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       60772049   1277/io.deconz.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       60769981   1179/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       60769982   1179/io.tuya.0
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        60757576   96/systemd-resolved
      udp        0      0 192.168.178.90:68       0.0.0.0:*                           105        209191851  81/systemd-networkd
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          60758285   1/init
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       60788844   2684/io.yahka.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       60787198   2618/io.wled.0
      udp6       0      0 :::1900                 :::*                                1000       60772050   1277/io.deconz.0
      udp6       0      0 :::111                  :::*                                0          60758291   1/init
      2023-05-31 21:00:00.009  - info: javascript.0 (457) script.js.Sensorüberwachung.Stromzaehlerüberwachung: Start Stromzaehlerüberwachung
      2023-05-31 21:00:00.021  - info: javascript.0 (457) script.js.Sensorüberwachung.Sensorstatusüberwachung: Start Sensorüberwachung
      2023-05-31 21:15:00.005  - info: javascript.0 (457) script.js.Sensorüberwachung.Stromzaehlerüberwachung: Start Stromzaehlerüberwachung
      Lollo
      @lollo sagte in stable Adapterupdates:
      *** BASE SYSTEM ***
      Docker          : false
      Release:        20.04
      Codename:       focal
      NAME="Ubuntu"
      ID=ubuntu
      ID_LIKE=debian
      VERSION_ID="20.04"
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      root
      /root
      root
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
               7823 M total memory
               2561 M used memory
               4764 M free memory
                  0 M buffer memory
                497 M swap cache
               7167 M total swap
               2114 M used swap
               5053 M free swap
      *** FILESYSTEM ***
      /var:
      2.9G    /var/
      1.9G    /var/log
      718M    /var/cache
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        14811
      States:         13118
      Pending Updates: 36
      @crunchip @Thomas-Braun sorry wenn ich nochmal frage, aber mach ich mich mit so einer Offenlegung des Systems angreifbar ? Kann da jetzt auch keiner Blödsinn mit machen ?
      GlasfaserG Thomas BraunT DJMarc75D 6 Antworten Letzte Antwort
      • L Lollo
        *** BASE SYSTEM ***
        Docker          : false
        Release:        20.04
        Codename:       focal
        NAME="Ubuntu"
        ID=ubuntu
        ID_LIKE=debian
        VERSION_ID="20.04"
        CPU threads: 4
                         RTC time: n/a
                  RTC in local TZ: no
        root
        /root
        root
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
                 7823 M total memory
                 2561 M used memory
                 4764 M free memory
                    0 M buffer memory
                  497 M swap cache
                 7167 M total swap
                 2114 M used swap
                 5053 M free swap
        *** FILESYSTEM ***
        /var:
        2.9G    /var/
        1.9G    /var/log
        718M    /var/cache
        /usr/bin/npm            9.5.1
        /usr/bin/npx            9.5.1
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.3.5
        javascript:     6.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        14811
        States:         13118
        Pending Updates: 36
        GlasfaserG Offline
        GlasfaserG Offline
        Nein ...
        Nur darauf achten , das am Ende ioBroker Log das keine Privatdaten mit angezeigt werden ( Logindaten , Hausadressen im Script usw. )
        • L Lollo
          *** BASE SYSTEM ***
          Docker          : false
          Release:        20.04
          Codename:       focal
          NAME="Ubuntu"
          ID=ubuntu
          ID_LIKE=debian
          VERSION_ID="20.04"
          CPU threads: 4
                           RTC time: n/a
                    RTC in local TZ: no
          root
          /root
          root
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
                   7823 M total memory
                   2561 M used memory
                   4764 M free memory
                      0 M buffer memory
                    497 M swap cache
                   7167 M total swap
                   2114 M used swap
                   5053 M free swap
          *** FILESYSTEM ***
          /var:
          2.9G    /var/
          1.9G    /var/log
          718M    /var/cache
          /usr/bin/npm            9.5.1
          /usr/bin/npx            9.5.1
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.3.5
          javascript:     6.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects:        14811
          States:         13118
          Pending Updates: 36
          root
          Damit greifst du dich nur selber an. Nutz einen Standarduser, KEINEN root login!!!
          • L Lollo
            *** BASE SYSTEM ***
            Docker          : false
            Release:        20.04
            Codename:       focal
            NAME="Ubuntu"
            ID=ubuntu
            ID_LIKE=debian
            VERSION_ID="20.04"
            CPU threads: 4
                             RTC time: n/a
                      RTC in local TZ: no
            root
            /root
            root
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
                     7823 M total memory
                     2561 M used memory
                     4764 M free memory
                        0 M buffer memory
                      497 M swap cache
                     7167 M total swap
                     2114 M used swap
                     5053 M free swap
            *** FILESYSTEM ***
            /var:
            2.9G    /var/
            1.9G    /var/log
            718M    /var/cache
            /usr/bin/npm            9.5.1
            /usr/bin/npx            9.5.1
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.3.5
            javascript:     6.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        14811
            States:         13118
            Pending Updates: 36
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            root
            Warum ?
            Lehrling seit 1975 !!!
            • L Lollo
              @glasfaser, OK... fühle mich belehrt und zurechtgewiesen... löst mein Problem aber nicht
              GlasfaserG Offline
              GlasfaserG Offline
              zu root ..
              Das hatten wir dir schon geschrieben ...
              • L Lollo
                *** BASE SYSTEM ***
                Docker          : false
                Release:        20.04
                Codename:       focal
                NAME="Ubuntu"
                ID=ubuntu
                ID_LIKE=debian
                VERSION_ID="20.04"
                CPU threads: 4
                                 RTC time: n/a
                          RTC in local TZ: no
                root
                /root
                root
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                         7823 M total memory
                         2561 M used memory
                         4764 M free memory
                            0 M buffer memory
                          497 M swap cache
                         7167 M total swap
                         2114 M used swap
                         5053 M free swap
                *** FILESYSTEM ***
                /var:
                2.9G    /var/
                1.9G    /var/log
                718M    /var/cache
                /usr/bin/npm            9.5.1
                /usr/bin/npx            9.5.1
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.3.5
                javascript:     6.1.4
                Adapter State
                + instance is alive
                Objects and States
                Objects:        14811
                States:         13118
                Pending Updates: 36
                Da stimmt auch was in der Nacht nicht. Backup-Vorgang? Da wird wohl irgendwas schräg gemounted.
                • L Lollo
                  *** BASE SYSTEM ***
                  Docker          : false
                  Release:        20.04
                  Codename:       focal
                  NAME="Ubuntu"
                  ID=ubuntu
                  ID_LIKE=debian
                  VERSION_ID="20.04"
                  CPU threads: 4
                                   RTC time: n/a
                            RTC in local TZ: no
                  root
                  /root
                  root
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                           7823 M total memory
                           2561 M used memory
                           4764 M free memory
                              0 M buffer memory
                            497 M swap cache
                           7167 M total swap
                           2114 M used swap
                           5053 M free swap
                  *** FILESYSTEM ***
                  /var:
                  2.9G    /var/
                  1.9G    /var/log
                  718M    /var/cache
                  /usr/bin/npm            9.5.1
                  /usr/bin/npx            9.5.1
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.3.5
                  javascript:     6.1.4
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        14811
                  States:         13118
                  Pending Updates: 36
                  Umlaute und sonstige Sonderzeichen sind auch zu vermeiden wo es nur geht.
                  • L Lollo
                    *** BASE SYSTEM ***
                    Docker          : false
                    Release:        20.04
                    Codename:       focal
                    NAME="Ubuntu"
                    ID=ubuntu
                    ID_LIKE=debian
                    VERSION_ID="20.04"
                    CPU threads: 4
                                     RTC time: n/a
                              RTC in local TZ: no
                    root
                    /root
                    root
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                             7823 M total memory
                             2561 M used memory
                             4764 M free memory
                                0 M buffer memory
                              497 M swap cache
                             7167 M total swap
                             2114 M used swap
                             5053 M free swap
                    *** FILESYSTEM ***
                    /var:
                    2.9G    /var/
                    1.9G    /var/log
                    718M    /var/cache
                    /usr/bin/npm            9.5.1
                    /usr/bin/npx            9.5.1
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.3.5
                    javascript:     6.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        14811
                    States:         13118
                    Pending Updates: 36
                    Pending Updates: 36
                    Updaten...
                      Pending Updates: 36
                      Updaten...
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @Lollo
                      Bevor @Thomas-Braun noch mehr findet ....
                      Nur eine Frage ... warum zeigst du uns jetzt ein alte Ausgabe von gestern !?
                      https://forum.iobroker.net/post/998166
                      Zeige uns doch eine aktuelle Ausgabe !?
                      • GlasfaserG Glasfaser
                        @Lollo
                        @glasfaser
                        Arrgh. Stimmt...
                        L 1 Antwort Letzte Antwort
                          @glasfaser
                          Arrgh. Stimmt...
                          Lollo
                          @thomas-braun @crunchip
                          *** BASE SYSTEM ***
                          Docker          : false
                          Release:        20.04
                          Codename:       focal
                          NAME="Ubuntu"
                          ID=ubuntu
                          ID_LIKE=debian
                          VERSION_ID="20.04"
                           16:51:26 up 47 min,  2 users,  load average: 0.70, 0.67, 0.60
                          CPU threads: 4
                                         Local time: Thu 2023-06-01 16:51:26 CEST
                                     Universal time: Thu 2023-06-01 14:51:26 UTC
                                           RTC time: n/a
                                    RTC in local TZ: no
                          root
                          /root
                          root
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:           7.8G        2.2G        4.9G        0.0K        636M        5.6G
                          Swap:          7.2G          0B        7.2G
                          Total:          14G        2.2G         12G
                                   7823 M total memory
                                   2249 M used memory
                                    388 M active memory
                                   2321 M inactive memory
                                   4937 M free memory
                                      0 M buffer memory
                                    636 M swap cache
                                   7167 M total swap
                                      0 M used swap
                                   7167 M free swap
                          *** FILESYSTEM ***
                          [Thu Jun  1 16:04:17 2023] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                          /var:
                          2.9G    /var/
                          1.9G    /var/log
                          718M    /var/cache
                          705M    /opt/iobroker/iobroker-data/
                          29M     /opt/iobroker/iobroker-data/objects.jsonl
                          /usr/bin/npm            9.5.1
                          /usr/bin/npx            9.5.1
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.3.5
                          javascript:     6.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        14811
                          States:         13118
                          Hit:1 https://deb.nodesource.com/node_18.x focal InRelease
                          Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
                          Pending Updates: 0
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       213249635  885/io.sonoff.0
                          tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1000       213248489  870/io.shelly.0
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          213226483  191/sshd: /usr/sbin
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          213225571  1/init
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       213241422  627/iobroker.js-con
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       213241418  627/iobroker.js-con
                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          213227623  323/master
                          tcp        0      0 192.168.178.90:2010     0.0.0.0:*               LISTEN      1000       213247270  780/io.hm-rpc.0
                          tcp        0      0 192.168.178.90:2001     0.0.0.0:*               LISTEN      1000       213249254  810/io.hm-rpc.2
                          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        213226819  96/systemd-resolved
                          tcp        0      0 192.168.178.90:9292     0.0.0.0:*               LISTEN      1000       213248140  795/io.hm-rpc.1
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          213226485  191/sshd: /usr/sbin
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          213226517  1/init
                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          213227624  323/master
                          tcp6       0      0 :::33587                :::*                    LISTEN      1000       213255249  1491/io.yahka.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       213252880  1446/io.web.0
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       213242398  648/io.admin.0
                          udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        213226818  96/systemd-resolved
                          udp        0      0 192.168.178.90:68       0.0.0.0:*                           105        213224873  81/systemd-networkd
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          213223570  1/init
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       213255250  1491/io.yahka.0
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       213253745  1476/io.wled.0
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       213247930  960/io.deconz.0
                          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       213250373  915/io.tuya.0
                          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       213250374  915/io.tuya.0
                          udp6       0      0 :::111                  :::*                                0          213225574  1/init
                          udp6       0      0 :::1900                 :::*                                1000       213247931  960/io.deconz.0
                          2023-06-01 16:15:00.055  - info: javascript.0 (690) script.js.Sensorüberwachung.Stromzaehlerüberwachung: Start Stromzaehlerüberwachung
                          2023-06-01 16:30:00.019  - info: javascript.0 (690) script.js.Sensorüberwachung.Stromzaehlerüberwachung: Start Stromzaehlerüberwachung
                          2023-06-01 16:45:00.022  - info: javascript.0 (690) script.js.Sensorüberwachung.Stromzaehlerüberwachung: Start Stromzaehlerüberwachung
                          So, hier die aktuelle iob diag. Hab es nach der Anleitung von Thomas durchgeführt. Kann ich im Nachhinein einen User anlegen/ändern, oder besser ubuntu und iob neu installieren?
                          Vielen Dank übrigens für eure Geduld 👍
                          Thomas BraunT DJMarc75D 2 Antworten Letzte Antwort
                          • L Lollo
                            *** BASE SYSTEM ***
                            Docker          : false
                            Release:        20.04
                            Codename:       focal
                            NAME="Ubuntu"
                            ID=ubuntu
                            ID_LIKE=debian
                            VERSION_ID="20.04"
                            CPU threads: 4
                                             RTC time: n/a
                                      RTC in local TZ: no
                            root
                            /root
                            root
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:          7.2G          0B        7.2G
                            Total:          14G        2.2G         12G
                                     7823 M total memory
                                     2249 M used memory
                                      388 M active memory
                                     4937 M free memory
                                        0 M buffer memory
                                      636 M swap cache
                                     7167 M total swap
                                        0 M used swap
                                     7167 M free swap
                            *** FILESYSTEM ***
                            /var:
                            2.9G    /var/
                            1.9G    /var/log
                            718M    /var/cache
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.3.5
                            javascript:     6.1.4
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        14811
                            States:         13118
                            Pending Updates: 0
                            Natürlich geht das. Wäre ja behämmert wenn man sein OS für jeden neuen user neu aufsetzen müsste.
                            • L Lollo
                              *** BASE SYSTEM ***
                              Docker          : false
                              Release:        20.04
                              Codename:       focal
                              NAME="Ubuntu"
                              ID=ubuntu
                              ID_LIKE=debian
                              VERSION_ID="20.04"
                              CPU threads: 4
                                               RTC time: n/a
                                        RTC in local TZ: no
                              root
                              /root
                              root
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:          7.2G          0B        7.2G
                              Total:          14G        2.2G         12G
                                       7823 M total memory
                                       2249 M used memory
                                        388 M active memory
                                       4937 M free memory
                                          0 M buffer memory
                                        636 M swap cache
                                       7167 M total swap
                                          0 M used swap
                                       7167 M free swap
                              *** FILESYSTEM ***
                              /var:
                              2.9G    /var/
                              1.9G    /var/log
                              718M    /var/cache
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.3.5
                              javascript:     6.1.4
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        14811
                              States:         13118
                              Pending Updates: 0
                              DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              @lollo immernoch ROOT
                              • DJMarc75D DJMarc75
                                Lollo
                                @djmarc75 @Thomas-Braun jetzt müsste es passen, oder ? Hab einen user angelegt.
                                *** BASE SYSTEM ***
                                Docker          : false
                                Release:        20.04
                                Codename:       focal
                                NAME="Ubuntu"
                                ID=ubuntu
                                ID_LIKE=debian
                                VERSION_ID="20.04"
                                 17:16:20 up  1:12,  2 users,  load average: 0.39, 0.50, 0.52
                                CPU threads: 4
                                               Local time: Thu 2023-06-01 17:16:20 CEST
                                           Universal time: Thu 2023-06-01 15:16:20 UTC
                                                 RTC time: n/a
                                          RTC in local TZ: no
                                lollo
                                /home/lollo
                                lollo sudo
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:           7.8G        2.3G        4.9G        0.0K        648M        5.5G
                                Swap:          7.2G          0B        7.2G
                                Total:          14G        2.3G         12G
                                         7823 M total memory
                                         2321 M used memory
                                          405 M active memory
                                         2387 M inactive memory
                                         4853 M free memory
                                            0 M buffer memory
                                          648 M swap cache
                                         7167 M total swap
                                            0 M used swap
                                         7167 M free swap
                                *** FILESYSTEM ***
                                tmpfs                            tmpfs  783M  148K  783M   1% /run
                                tmpfs                            tmpfs  783M     0  783M   0% /run/user/1001
                                /var:
                                2.9G    /var/
                                1.9G    /var/log
                                718M    /var/cache
                                Archived and active journals take up 8.0M in the file system.
                                709M    /opt/iobroker/iobroker-data/
                                17M     /opt/iobroker/iobroker-data/states.jsonl
                                /usr/bin/npm            9.5.1
                                /usr/bin/npx            9.5.1
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.3.5
                                javascript:     6.1.4
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        14811
                                States:         13118
                                Pending Updates: 0
                                2023-06-01 17:00:00.013  - info: javascript.0 (690) script.js.Sensorüberwachung.Stromzaehlerüberwachung: Start Stromzaehlerüberwachung
                                2023-06-01 17:15:00.013  - info: javascript.0 (690) script.js.Sensorüberwachung.Stromzaehlerüberwachung: Start Stromzaehlerüberwachung
                                GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                                • L Lollo
                                  *** BASE SYSTEM ***
                                  Docker          : false
                                  Release:        20.04
                                  Codename:       focal
                                  NAME="Ubuntu"
                                  ID=ubuntu
                                  ID_LIKE=debian
                                  VERSION_ID="20.04"
                                  CPU threads: 4
                                                   RTC time: n/a
                                            RTC in local TZ: no
                                  lollo
                                  /home/lollo
                                  lollo sudo
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:          7.2G          0B        7.2G
                                  Total:          14G        2.3G         12G
                                           7823 M total memory
                                           2321 M used memory
                                            405 M active memory
                                           4853 M free memory
                                              0 M buffer memory
                                            648 M swap cache
                                           7167 M total swap
                                              0 M used swap
                                           7167 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  2.9G    /var/
                                  1.9G    /var/log
                                  718M    /var/cache
                                  /usr/bin/npm            9.5.1
                                  /usr/bin/npx            9.5.1
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.3.5
                                  javascript:     6.1.4
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        14811
                                  States:         13118
                                  Pending Updates: 0
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  nicht ganz :
                                  aber da kann @Thomas-Braun mehr zu sagen
                                  • L Lollo
                                    *** BASE SYSTEM ***
                                    Docker          : false
                                    Release:        20.04
                                    Codename:       focal
                                    NAME="Ubuntu"
                                    ID=ubuntu
                                    ID_LIKE=debian
                                    VERSION_ID="20.04"
                                    CPU threads: 4
                                                     RTC time: n/a
                                              RTC in local TZ: no
                                    lollo
                                    /home/lollo
                                    lollo sudo
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:          7.2G          0B        7.2G
                                    Total:          14G        2.3G         12G
                                             7823 M total memory
                                             2321 M used memory
                                              405 M active memory
                                             4853 M free memory
                                                0 M buffer memory
                                              648 M swap cache
                                             7167 M total swap
                                                0 M used swap
                                             7167 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    2.9G    /var/
                                    1.9G    /var/log
                                    718M    /var/cache
                                    /usr/bin/npm            9.5.1
                                    /usr/bin/npx            9.5.1
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.3.5
                                    javascript:     6.1.4
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        14811
                                    States:         13118
                                    Pending Updates: 0
                                    @lollo
                                    Den User würde ich jetzt mindestens noch in die Gruppen adm und iobroker packen.
                                      @lollo
                                      Lollo
                                      @thomas-braun so?
                                      Skript v.2023-04-16
                                      *** BASE SYSTEM ***
                                      Docker          : false
                                      Release:        20.04
                                      Codename:       focal
                                      NAME="Ubuntu"
                                      ID=ubuntu
                                      ID_LIKE=debian
                                      VERSION_ID="20.04"
                                      PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-poli        cy"
                                       18:21:04 up  2:17,  2 users,  load average: 0.45, 0.48, 0.45
                                      CPU threads: 4
                                                     Local time: Thu 2023-06-01 18:21:04 CEST
                                                 Universal time: Thu 2023-06-01 16:21:04 UTC
                                                       RTC time: n/a
                                                RTC in local TZ: no
                                      lollo
                                      /home/lollo
                                      lollo sudo
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:           7.8G        2.4G        4.8G        0.0K        653M        5.4G
                                      Swap:          7.2G          0B        7.2G
                                      Total:          14G        2.4G         11G
                                               7823 M total memory
                                               2416 M used memory
                                                404 M active memory
                                               2486 M inactive memory
                                               4754 M free memory
                                                  0 M buffer memory
                                                653 M swap cache
                                               7167 M total swap
                                                  0 M used swap
                                               7167 M free swap
                                      *** FILESYSTEM ***
                                      [Fri May 26 02:30:20 2023] EXT4-fs (dm-9): write access unavailable, skipping or        phan cleanup
                                      [Fri May 26 02:30:20 2023] EXT4-fs (dm-9): mounted filesystem without journal. O        pts: noload. Quota mode: none.
                                      [Fri May 26 02:32:37 2023] EXT4-fs (dm-9): write access unavailable, skipping or        phan cleanup
                                      [Fri May 26 02:32:37 2023] EXT4-fs (dm-9): mounted filesystem without journal. O        pts: noload. Quota mode: none.
                                      [Fri May 26 02:37:10 2023] EXT4-fs (dm-9): write access unavailable, skipping or        phan cleanup
                                      [Fri May 26 02:37:10 2023] EXT4-fs (dm-9): mounted filesystem without journal. O        pts: noload. Quota mode: none.
                                      [Sun May 28 02:30:19 2023] EXT4-fs (dm-9): write access unavailable, skipping or        phan cleanup
                                      [Sun May 28 02:30:19 2023] EXT4-fs (dm-9): mounted filesystem without journal. O        pts: noload. Quota mode: none.
                                      [Sun May 28 02:32:25 2023] EXT4-fs (dm-9): write access unavailable, skipping or        phan cleanup
                                      [Sun May 28 02:32:25 2023] EXT4-fs (dm-9): mounted filesystem without journal. O        pts: noload. Quota mode: none.
                                      [Sun May 28 02:36:57 2023] EXT4-fs (dm-9): write access unavailable, skipping or        phan cleanup
                                      [Sun May 28 02:36:57 2023] EXT4-fs (dm-9): mounted filesystem without journal. O        pts: noload. Quota mode: none.
                                      [Mon May 29 02:30:20 2023] EXT4-fs (dm-9): write access unavailable, skipping or        phan cleanup
                                      [Mon May 29 02:30:20 2023] EXT4-fs (dm-9): mounted filesystem without journal. O        pts: noload. Quota mode: none.
                                      [Mon May 29 02:34:33 2023] EXT4-fs (dm-9): write access unavailable, skipping or        phan cleanup
                                      [Mon May 29 02:34:33 2023] EXT4-fs (dm-9): mounted filesystem without journal. O        pts: noload. Quota mode: none.
                                      [Mon May 29 02:39:04 2023] EXT4-fs (dm-9): write access unavailable, skipping or        phan cleanup
                                      [Mon May 29 02:39:04 2023] EXT4-fs (dm-9): mounted filesystem without journal. O        pts: noload. Quota mode: none.
                                      [Wed May 31 02:30:20 2023] EXT4-fs (dm-9): write access unavailable, skipping or        phan cleanup
                                      [Wed May 31 02:30:20 2023] EXT4-fs (dm-9): mounted filesystem without journal. O        pts: noload. Quota mode: none.
                                      [Wed May 31 02:32:42 2023] EXT4-fs (dm-9): write access unavailable, skipping or        phan cleanup
                                      [Wed May 31 02:32:42 2023] EXT4-fs (dm-9): mounted filesystem without journal. O        pts: noload. Quota mode: none.
                                      [Wed May 31 02:37:13 2023] EXT4-fs (dm-9): write access unavailable, skipping or        phan cleanup
                                      [Wed May 31 02:37:13 2023] EXT4-fs (dm-9): mounted filesystem without journal. O        pts: noload. Quota mode: none.
                                      /                         /dev/mapper/pve-vm--103--disk--0 ext4       rw,relatim        e,stripe=16
                                      |-/proc/cpuinfo           lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,        nodev,relatime,user_id=0,group_id=0,allow_other
                                      |-/proc/diskstats         lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,        nodev,relatime,user_id=0,group_id=0,allow_other
                                      |-/proc/loadavg           lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,        nodev,relatime,user_id=0,group_id=0,allow_other
                                      |-/proc/meminfo           lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,        nodev,relatime,user_id=0,group_id=0,allow_other
                                      |-/proc/slabinfo          lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,        nodev,relatime,user_id=0,group_id=0,allow_other
                                      |-/proc/stat              lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,        nodev,relatime,user_id=0,group_id=0,allow_other
                                      |-/proc/swaps             lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,        nodev,relatime,user_id=0,group_id=0,allow_other
                                      |-/proc/uptime            lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,        nodev,relatime,user_id=0,group_id=0,allow_other
                                      `-/sys/devices/system/cpu lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,        nodev,relatime,user_id=0,group_id=0,allow_other
                                      /var:
                                      2.9G    /var/
                                      1.9G    /var/log
                                      718M    /var/cache
                                      697M    /opt/iobroker/iobroker-data/
                                      33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.4f0a34b4.        js.map
                                      19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.m        ap
                                      15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors        -node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modu        les_io-1d9f06.44fe4a3f.chunk.js.map
                                      /usr/bin/npm            9.5.1
                                      /usr/bin/npx            9.5.1
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.3.5
                                      javascript:     6.1.4
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        14811
                                      States:         13118
                                      Pending Updates: 7
                                      2023-06-01 17:20:00.005  - warn: javascript.0 (690) script.js.PV-Anlage.Überschuss_in_POOLPUMPE_einfach_state: Variable auf  1 gesetzt
                                      2023-06-01 17:30:00.031  - info: javascript.0 (690) script.js.Sensorüberwachung.Stromzaehlerüberwachung: Start Stromzaehlerüberwachung
                                      2023-06-01 17:45:00.015  - info: javascript.0 (690) script.js.Sensorüberwachung.Stromzaehlerüberwachung: Start Stromzaehlerüberwachung
                                      2023-06-01 18:00:00.016  - info: javascript.0 (690) script.js.Sensorüberwachung.Stromzaehlerüberwachung: Start Stromzaehlerüberwachung
                                      2023-06-01 18:00:00.036  - info: javascript.0 (690) script.js.Sensorüberwachung.Sensorstatusüberwachung: Start Sensorüberwachung
                                      2023-06-01 18:15:00.016  - info: javascript.0 (690) script.js.Sensorüberwachung.Stromzaehlerüberwachung: Start Stromzaehlerüberwachung
                                      • L Lollo
                                        @thomas-braun so?
                                        Skript v.2023-04-16
                                        *** BASE SYSTEM ***
                                        Docker          : false
                                        Release:        20.04
                                        Codename:       focal
                                        NAME="Ubuntu"
                                        ID=ubuntu
                                        ID_LIKE=debian
                                        VERSION_ID="20.04"
                                        CPU threads: 4
                                                         RTC time: n/a
                                                  RTC in local TZ: no
                                        lollo
                                        /home/lollo
                                        lollo sudo
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Swap:          7.2G          0B        7.2G
                                        Total:          14G        2.4G         11G
                                                 7823 M total memory
                                                 2416 M used memory
                                                  404 M active memory
                                                 4754 M free memory
                                                    0 M buffer memory
                                                  653 M swap cache
                                                 7167 M total swap
                                                    0 M used swap
                                                 7167 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        2.9G    /var/
                                        1.9G    /var/log
                                        718M    /var/cache
                                        /usr/bin/npm            9.5.1
                                        /usr/bin/npx            9.5.1
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.3.5
                                        javascript:     6.1.4
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        14811
                                        States:         13118
                                        Pending Updates: 7
                                        @lollo
                                        Nö.
                                        User einmal aus und wieder einloggen, wenn Gruppen neuzugewiesen wurden.
                                          @lollo
                                          Nö.
                                          mcm1957M Offline
                                          mcm1957M Offline
                                          mcm1957
                                          Hab das jetzt nicht alles durchgelesen. Aber wenn wer wissen will ob sich was im Stable Repo getan hat einfach die commits ansehen:
                                          https://github.com/ioBroker/ioBroker.repositories/commits/master/sources-dist-stable.json
                                          Und ja,
                                          vor ein paar Wochen gab es sehr vile stable updates, derzeit eher wenig.
                                          Support Repositoryverwaltung.
                                          LESEN - gute Forenbeitrage
