  4. stable Adapterupdates
    5.4k
repositoryadapter update
57 Beiträge 6 Kommentatoren 7.0k Aufrufe 5 Beobachtet
  • L Lollo
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : lxc
    Distributor ID: Ubuntu
    Description:    Ubuntu 20.04.6 LTS
    Release:        20.04
    Codename:       focal
    NAME="Ubuntu"
    VERSION="20.04.6 LTS (Focal Fossa)"
    ID=ubuntu
    ID_LIKE=debian
    PRETTY_NAME="Ubuntu 20.04.6 LTS"
    VERSION_ID="20.04"
    HOME_URL="https://www.ubuntu.com/"
    SUPPORT_URL="https://help.ubuntu.com/"
    BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
    PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
    VERSION_CODENAME=focal
    UBUNTU_CODENAME=focal
    Systemuptime and Load:
     21:17:41 up 30 days, 11:45,  2 users,  load average: 0.65, 0.77, 0.67
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Wed 2023-05-31 21:17:41 CEST
               Universal time: Wed 2023-05-31 19:17:41 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           7.8G        2.6G        4.8G        0.0K        497M        5.3G
    Swap:          7.2G        2.1G        5.1G
    Total:          14G        4.7G        9.8G
             7823 M total memory
             2561 M used memory
             2159 M active memory
              717 M inactive memory
             4764 M free memory
                0 M buffer memory
              497 M swap cache
             7167 M total swap
             2114 M used swap
             5053 M free swap
    *** FILESYSTEM ***
    Filesystem                       Type   Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--103--disk--0 ext4    20G  8.3G   11G  45% /
    none                             tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                            tmpfs  3.9G     0  3.9G   0% /dev/shm
    tmpfs                            tmpfs  783M  136K  783M   1% /run
    tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs  783M     0  783M   0% /run/user/0
    [Wed May 24 02:30:19 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
    [Wed May 24 02:30:19 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
    [Wed May 24 02:32:23 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
    [Wed May 24 02:32:23 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
    [Wed May 24 02:36:55 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
    [Wed May 24 02:36:55 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
    [Fri May 26 02:30:20 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
    [Fri May 26 02:30:20 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
    [Fri May 26 02:32:37 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
    [Fri May 26 02:32:37 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
    [Fri May 26 02:37:10 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
    [Fri May 26 02:37:10 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
    [Sun May 28 02:30:19 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
    [Sun May 28 02:30:19 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
    [Sun May 28 02:32:25 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
    [Sun May 28 02:32:25 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
    [Sun May 28 02:36:57 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
    [Sun May 28 02:36:57 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
    [Mon May 29 02:30:20 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
    [Mon May 29 02:30:20 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
    [Mon May 29 02:34:33 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
    [Mon May 29 02:34:33 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
    [Mon May 29 02:39:04 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
    [Mon May 29 02:39:04 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
    [Wed May 31 02:30:20 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
    [Wed May 31 02:30:20 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
    [Wed May 31 02:32:42 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
    [Wed May 31 02:32:42 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
    [Wed May 31 02:37:13 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
    [Wed May 31 02:37:13 2023] EXT4-fs (dm-9): mounted filesystem without journal. Opts: noload. Quota mode: none.
    TARGET                    SOURCE                           FSTYPE     OPTIONS
    /                         /dev/mapper/pve-vm--103--disk--0 ext4       rw,relatime,stripe=16
    |-/proc/cpuinfo           lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/diskstats         lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/loadavg           lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/meminfo           lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/slabinfo          lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/stat              lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/swaps             lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/uptime            lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    `-/sys/devices/system/cpu lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    /var:
    2.9G    /var/
    1.9G    /var/log/journal/b354c482f7cc342776f020ee5ea440c3
    1.9G    /var/log
    718M    /var/cache
    Archived and active journals take up 1.8G in the file system.
    /opt/iobroker/backups:
    330M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    691M    /opt/iobroker/iobroker-data/
    461M    /opt/iobroker/iobroker-data/files
    170M    /opt/iobroker/iobroker-data/backup-objects
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    72M     /opt/iobroker/iobroker-data/files/telegram.admin
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.4f0a34b4.js.map
    25M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    14M     /opt/iobroker/iobroker-data/objects.json.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x focal/main amd64 Packages
         10.19.0~dfsg-3ubuntu1 500
            500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   1
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
    + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 80
      system.adapter.devices.0                : devices               : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
      system.adapter.mqtt.0                   : mqtt                  : iobroker                                 - disabled, port: 1886, bind: 0.0.0.0
    + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1881, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 - disabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.weishaupt-wem.0          : weishaupt-wem         : iobroker                                 -  enabled
    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
    + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.6.19   , installed 2.6.19
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "devices"      : 1.1.2    , installed 1.1.1  [Updatable]
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
    Adapter    "hue"          : 3.7.1    , installed 3.7.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "iot"          : 1.14.2   , installed 1.14.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "shuttercontrol": 1.4.29  , installed 1.4.29
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tuya"         : 3.13.1   , installed 3.13.1
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "weishaupt-wem": 0.0.15   , installed 0.0.15
    Adapter    "wled"         : 0.6.7    , installed 0.6.7
    Adapter    "yahka"        : 0.17.0   , installed 0.17.0
    Objects and States
    Objects:        14811
    States:         13118
    Hit:1 http://archive.ubuntu.com/ubuntu focal InRelease
    Hit:2 https://deb.nodesource.com/node_18.x focal InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
    Hit:4 http://archive.ubuntu.com/ubuntu focal-security InRelease
    Reading package lists...
    Pending Updates: 36
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          60758284   1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          60759546   195/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       60757959   143/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       60760619   143/iobroker.js-con
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        60757577   96/systemd-resolved
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          60760384   323/master
    tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1000       60770477   1032/io.shelly.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       60769562   1081/io.sonoff.0
    tcp        0      0 192.168.178.90:9292     0.0.0.0:*               LISTEN      1000       87757932   53414/io.hm-rpc.1
    tcp        0      0 192.168.178.90:2010     0.0.0.0:*               LISTEN      1000       87757719   53429/io.hm-rpc.0
    tcp        0      0 192.168.178.90:2001     0.0.0.0:*               LISTEN      1000       87757901   53399/io.hm-rpc.2
    tcp6       0      0 :::111                  :::*                    LISTEN      0          60758288   1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          60760385   323/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          60759557   195/sshd: /usr/sbin
    tcp6       0      0 :::39571                :::*                    LISTEN      1000       60788843   2684/io.yahka.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       60762210   343/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       60784496   2520/io.web.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       60772049   1277/io.deconz.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       60769981   1179/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       60769982   1179/io.tuya.0
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        60757576   96/systemd-resolved
    udp        0      0 192.168.178.90:68       0.0.0.0:*                           105        209191851  81/systemd-networkd
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          60758285   1/init
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       60788844   2684/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       60787198   2618/io.wled.0
    udp6       0      0 :::1900                 :::*                                1000       60772050   1277/io.deconz.0
    udp6       0      0 :::111                  :::*                                0          60758291   1/init
    2023-05-31 21:00:00.009  - info: javascript.0 (457) script.js.Sensorüberwachung.Stromzaehlerüberwachung: Start Stromzaehlerüberwachung
    2023-05-31 21:00:00.021  - info: javascript.0 (457) script.js.Sensorüberwachung.Sensorstatusüberwachung: Start Sensorüberwachung
    2023-05-31 21:15:00.005  - info: javascript.0 (457) script.js.Sensorüberwachung.Stromzaehlerüberwachung: Start Stromzaehlerüberwachung
    crunchipC Offline
    crunchipC Offline
    @lollo sagte in stable Adapterupdates:
    bekomme ich keine Adapterupdates (stable) mehr angezeigt.
    L 1 Antwort Letzte Antwort
      @lollo
      Zuerst: Es wird nicht als root herumgehampelt.
      Nicht unter Ubuntu und auch nicht in einem LXC.
      Einfach gar nicht.
      Lollo
      @thomas-braun hab das mal vor Jahren nach einem Video gemacht. HAb schon oft gehört, dass man das nicht macht. Traue mich aber nicht es zu verändern ... "never change a running system"
      Bin absoluter Leihe
      DJMarc75D GlasfaserG Thomas BraunT 4 Antworten Letzte Antwort
      • L Lollo
        Bin absoluter Leihe
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        Quatsch
        Lehrling seit 1975 !!!
        • L Lollo
          Bin absoluter Leihe
          GlasfaserG Offline
          GlasfaserG Offline
          Nur zur Info ... falsche Einstellung dazu !!
            Lollo
            @crunchip den habe ich wieder downgegradet, da die aktuelle stable Version bei mir fehlerbehaftet ist
            • GlasfaserG Glasfaser
              Lollo
              @glasfaser, OK... fühle mich belehrt und zurechtgewiesen... löst mein Problem aber nicht
              crunchipC Thomas BraunT GlasfaserG 3 Antworten Letzte Antwort
              • L Lollo
                Bin absoluter Leihe
                GlasfaserG Offline
                GlasfaserG Offline
                Ubuntu 20.04.6 LTS
                Die Version ist doch nicht vor ein paar Jahren ...
                OK zum Thema .. es wird dir doch alles angezeigt . was soll denn fehlen !?
                • L Lollo
                  Bin absoluter Leihe
                  @lollo
                  Und gerade 'absolute Laien' machen das erst Recht nicht. root wird wenn überhaupt nur von Leuten verwendet, die absolut genau wissen was sie da warum und wie machen.
                  Diese Leute verwenden aber auch sudo, weil sie genau wissen wie gefährlich das herumhüpfen als root sein kann. Ein Feuerwehrmann trägt ja auch seine Schutzausrüstung, wenn er an einem Brand steht. Nur der Laie rennt in Badeschlappen durch die brennende Bude...
                  • L Lollo
                    crunchipC Offline
                    crunchipC Offline
                    @lollo hab jetzt nicht alle Versionen durchgesehen, aber aktuell gibt es nun mal weniger updates, kann also gut möglich sein, das ne Zeitlang mal nichts gibt
                      Lollo
                      @crunchip das war auch meine Vermutung. Dachte nur das es evtl wirklich einen repo bug o.ä. gibt.
                      Danke an alle.
                      Vielleicht sollte ich mich jetzt doch nochmal mit einer neuinstalltion beschäftigen.
                      Der iob läßt sich ja jetzt relativ einfach installieren. Aber diese linux mag mich einfach nicht.
                      Ich bekomme bei der Installation immer irgendwelche Meldungen, die in den Anleitungen nicht auftauchen ...
                      • L Lollo
                        Danke an alle.
                        crunchipC Offline
                        crunchipC Offline
                        https://www.iobroker.net/#de/documentation/install/proxmox.md
                        • L Lollo
                          @lollo
                          Dann hau die Updates die da in der Pipeline hängen noch rein. Auch wenn das dein 'running system changed'.
                          Updates des OS werden nicht aus Jux und Dollerei veröffentlicht.
                          Dein im ersten Posting beobachtete 'Problem' sehe ich aber nicht. Der iobroker ist bis auf den einen Adapter da doch auf Stand. Im stable geht es naturgemäß etwas gemächlicher zu.
                          • L Lollo
                            *** BASE SYSTEM ***
                            Docker          : false
                            Release:        20.04
                            Codename:       focal
                            NAME="Ubuntu"
                            ID=ubuntu
                            ID_LIKE=debian
                            VERSION_ID="20.04"
                            CPU threads: 4
                                             RTC time: n/a
                                      RTC in local TZ: no
                            root
                            /root
                            root
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                                     7823 M total memory
                                     2561 M used memory
                                     4764 M free memory
                                        0 M buffer memory
                                      497 M swap cache
                                     7167 M total swap
                                     2114 M used swap
                                     5053 M free swap
                            *** FILESYSTEM ***
                            /var:
                            2.9G    /var/
                            1.9G    /var/log
                            718M    /var/cache
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.3.5
                            javascript:     6.1.4
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        14811
                            States:         13118
                            Pending Updates: 36
                            GlasfaserG Offline
                            GlasfaserG Offline
                            finde den nicht in der Ausgabe ...
                            kannst du mal das zeigen :
                            cd /opt/iobroker && npm ls | grep 'git'
                              @lollo
                              Lollo
                              @thomas-braun updates mach ich natürlich schön, habe es aber auch schleifen lassen.
                              @crunchip danke für den link
                                Lollo
                                @glasfaser sagte in stable Adapterupdates:
                                +-- iobroker.vis-materialdesign@0.2.54 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#811fa9baf9af44dccd5f7c21db4742dc0c714937)
                                • L Lollo
                                  @lollo
                                  Das sehe ich:
                                  Pending Updates: 36
                                  • L Lollo
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    .... der ist ja noch aus der Steinzeit ..
                                    War wohl mal ein Versuch !?
                                    • Thomas BraunT Online
                                      @glasfaser
                                      github:	0.5.94
                                      latest:	0.5.9 for 23 months
                                      Das muss wirklich frühes Neolithikum sein.
                                        @glasfaser
                                        github:	0.5.94
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @thomas-braun sagte in stable Adapterupdates:
                                        Jipp .. im Versuchsstadium , noch nicht mal aufgeführt .
                                        über 3 - 4 Jahre her
                                          @glasfaser
                                          'never change a running flintstone'
