  4. Can not start inMem-objects on port 9001
    5.4k
55 Beiträge 5 Kommentatoren 6.2k Aufrufe 5 Beobachtet
  • M maxpd
    @thomas-braun ahja, schön. danke
    pi@iobroker:~ $ sudo du -h /var/ | sort -rh | head -5
    19G     /var/
    17G     /var/log
    1,9G    /var/cache/apt/archives
    1,9G    /var/cache/apt
    1,9G    /var/cache
    @maxpd
    journalctl --vacuum-time=2d
    Und dann mal reinschauen, was da alles reinläuft.
      @maxpd
      maxpd
      @thomas-braun said in Can not start inMem-objects on port 9001:
      @maxpd sagte in Can not start inMem-objects on port 9001:
      Da eine 120gb SSD dran hängt.
      Nutzt dir aber nix, wenn davon nur ein Bruchteil verwendet wird.
      Ja, daher die Idee, zu erweitern.
      @maxpd
      19G     /var/
      17G     /var/log
      1,9G    /var/cache/apt
      1,9G    /var/cache
      pi@iobroker:~ $ sudo apt clean
      pi@iobroker:~ $ journalctl --disk-usage
      Archived and active journals take up 1.2G in the file system.
      17G     /var/log
      17G     /var/
      1,3G    /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d
      625M    /var/lib
      pi@iobroker:~ $ journalctl --vacuum-time=2d
      Vacuuming done, freed 0B of archived journals from /var/log/journal.
      Vacuuming done, freed 0B of archived journals from /run/log/journal.
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-0000000000010117-0005e408a1df0f77.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005e89d6a5d2a79-2861ec25b5045d41.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-0000000000013cad-0005e6783ef4ca05.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1001@858799755e2c407eb068a2048b2fcae7-0000000000013c5c-0005e6750014925d.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@f0f025e56ab4469e84619e39a5ca161d-0000000000000001-0005e88559d54028.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@c7576d79f9ee4564a173427f29d9a8a6-0000000000000001-0005e89d6a57f181.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1001@858799755e2c407eb068a2048b2fcae7-0000000000018198-0005e8d9c951e401.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005e8ecbb16546d-21eed0e8c7d4bcb8.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-00000000000184ca-0005e8e7dc09966f.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005e91b395c090c-b565e0da2a5debcb.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@fac2789e436346338b52bbdddb8e4515-0000000000000001-0005e91b39582ddb.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005ebb94302b96e-66471907129bfe61.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1001@858799755e2c407eb068a2048b2fcae7-0000000000021c21-0005eb435b43fc6a.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-0000000000021c23-0005eb435b4641ad.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005ebcaa3072f9c-2a7774b5e3e76fb7.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005ebdf6d1ab90c-51d11d451275d637.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005ebf3c1aa2f64-2a5a2fa8a991821a.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005ec131ff54138-a2a167cfa6edd883.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005ec1e05eed0a2-5316f7687fd41d66.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005ec3277389720-5b97d6611060fb1a.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005ed87c320eaec-cd7c66a3a287beea.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@963b9928563f4214ba32c41919b15cc0-0000000000000001-0005ed87c319872d.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005edcc160d229b-21b18f6b2ded1345.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1001@858799755e2c407eb068a2048b2fcae7-000000000002baca-0005edae43ad2d87.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-000000000002bc25-0005edb3cef268f0.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005edcc6d205fdb-60912bea039478de.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@81c61c1c46264dc9aaadb65effd72f4b-0000000000000001-0005edcc6d18b3f6.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f21d816327eb-5b198852c0e58b68.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1001@858799755e2c407eb068a2048b2fcae7-0000000000032209-0005f012ab55f12b.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-000000000003248e-0005f0236c0274f1.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@aed779d83ac94f4096c500ebfc7f7f13-0000000000000001-0005f21d81624af6.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f21d81687926-38cc8718ed14d121.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f42ed9ef33d7-b5abf21c08aea63b.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1001@858799755e2c407eb068a2048b2fcae7-000000000003865a-0005f27eeb41edca.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-000000000003865c-0005f27eeb459234.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@af3142f46d524381a4531cf0a30e5789-0000000000000001-0005f42ed9e970b6.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1001@858799755e2c407eb068a2048b2fcae7-000000000003e6d8-0005f4e401d8c029.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f5b314280799-0dc5be0550532efe.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-000000000003e861-0005f4ee8855c6d7.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@85c4e4fad6844bc6a3b473fb6a3bb86e-0000000000000001-0005f5b31420dc0a.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f89417cebe4f-542e44740f9b8371.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1001@858799755e2c407eb068a2048b2fcae7-0000000000044a9b-0005f74a07912ec8.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-0000000000044a9d-0005f74a0794920e.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f8a5a33dafb9-a1ac876c63cf6860.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f8a658ad9f53-c4ab53ced8880d59.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f8a6ba31c1a2-179f67ee326a45d6.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f8a6e9e00c1d-6a1f02044e032ba3.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f8a76f447234-80192ef8f6bfcc6f.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f8a957babff5-cc91941321fd7812.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f935997406b4-0cd81a3fb07c560d.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@a37a001c516946f88780ef4b42847cb3-0000000000000001-0005f935996cb79f.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005fa69587b82b8-ca40a777ae21114b.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1001@858799755e2c407eb068a2048b2fcae7-000000000004b860-0005f9ae5b4baa45.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-000000000004b9e8-0005f9b8ce13fb12.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005fbc0a1d366d5-f1d3155b7b7ebf48.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@fd651a2e06be4a8d91a9c3ad6c6266d4-0000000000000001-0005fbc0a1c97aa1.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005fc61036a4390-150ea5c93b14b0d2.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-0000000000051ea9-0005fc144d54d2ee.journal: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1001@0005fca6cd3c3087-84b7b6651a93a19a.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005fc746e119a30-132977fffbe57697.journal~: Keine Berechtigung
      Failed to delete archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005fca6cd37cd77-831ed6efea5a3069.journal~: Keine Berechtigung
      Vacuuming done, freed 0B of archived journals from /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d.
      maxpd
      • M maxpd
        @maxpd
        19G     /var/
        17G     /var/log
        1,9G    /var/cache/apt
        1,9G    /var/cache
        17G     /var/log
        17G     /var/
        625M    /var/lib
        sudo journalctl --vacuum-time=2d
          maxpd
          pi@iobroker:~ $ sudo journalctl --vacuum-time=2d
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-0000000000010117-0005e408a1df0f77.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005e89d6a5d2a79-2861ec25b5045d41.journal~ (24.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-0000000000013cad-0005e6783ef4ca05.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1001@858799755e2c407eb068a2048b2fcae7-0000000000013c5c-0005e6750014925d.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@f0f025e56ab4469e84619e39a5ca161d-0000000000000001-0005e88559d54028.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@c7576d79f9ee4564a173427f29d9a8a6-0000000000000001-0005e89d6a57f181.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1001@858799755e2c407eb068a2048b2fcae7-0000000000018198-0005e8d9c951e401.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005e8ecbb16546d-21eed0e8c7d4bcb8.journal~ (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-00000000000184ca-0005e8e7dc09966f.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005e91b395c090c-b565e0da2a5debcb.journal~ (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@fac2789e436346338b52bbdddb8e4515-0000000000000001-0005e91b39582ddb.journal (40.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005ebb94302b96e-66471907129bfe61.journal~ (16.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1001@858799755e2c407eb068a2048b2fcae7-0000000000021c21-0005eb435b43fc6a.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-0000000000021c23-0005eb435b4641ad.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005ebcaa3072f9c-2a7774b5e3e76fb7.journal~ (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005ebdf6d1ab90c-51d11d451275d637.journal~ (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005ebf3c1aa2f64-2a5a2fa8a991821a.journal~ (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005ec131ff54138-a2a167cfa6edd883.journal~ (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005ec1e05eed0a2-5316f7687fd41d66.journal~ (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005ec3277389720-5b97d6611060fb1a.journal~ (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005ed87c320eaec-cd7c66a3a287beea.journal~ (32.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@963b9928563f4214ba32c41919b15cc0-0000000000000001-0005ed87c319872d.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005edcc160d229b-21b18f6b2ded1345.journal~ (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1001@858799755e2c407eb068a2048b2fcae7-000000000002baca-0005edae43ad2d87.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-000000000002bc25-0005edb3cef268f0.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005edcc6d205fdb-60912bea039478de.journal~ (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@81c61c1c46264dc9aaadb65effd72f4b-0000000000000001-0005edcc6d18b3f6.journal (32.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f21d816327eb-5b198852c0e58b68.journal~ (24.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1001@858799755e2c407eb068a2048b2fcae7-0000000000032209-0005f012ab55f12b.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-000000000003248e-0005f0236c0274f1.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@aed779d83ac94f4096c500ebfc7f7f13-0000000000000001-0005f21d81624af6.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f21d81687926-38cc8718ed14d121.journal~ (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f42ed9ef33d7-b5abf21c08aea63b.journal~ (24.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1001@858799755e2c407eb068a2048b2fcae7-000000000003865a-0005f27eeb41edca.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-000000000003865c-0005f27eeb459234.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@af3142f46d524381a4531cf0a30e5789-0000000000000001-0005f42ed9e970b6.journal (16.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1001@858799755e2c407eb068a2048b2fcae7-000000000003e6d8-0005f4e401d8c029.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f5b314280799-0dc5be0550532efe.journal~ (16.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-000000000003e861-0005f4ee8855c6d7.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@85c4e4fad6844bc6a3b473fb6a3bb86e-0000000000000001-0005f5b31420dc0a.journal (24.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f89417cebe4f-542e44740f9b8371.journal~ (16.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1001@858799755e2c407eb068a2048b2fcae7-0000000000044a9b-0005f74a07912ec8.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-0000000000044a9d-0005f74a0794920e.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f8a5a33dafb9-a1ac876c63cf6860.journal~ (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f8a658ad9f53-c4ab53ced8880d59.journal~ (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f8a6ba31c1a2-179f67ee326a45d6.journal~ (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f8a6e9e00c1d-6a1f02044e032ba3.journal~ (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f8a76f447234-80192ef8f6bfcc6f.journal~ (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f8a957babff5-cc91941321fd7812.journal~ (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005f935997406b4-0cd81a3fb07c560d.journal~ (16.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@a37a001c516946f88780ef4b42847cb3-0000000000000001-0005f935996cb79f.journal (16.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005fa69587b82b8-ca40a777ae21114b.journal~ (16.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1001@858799755e2c407eb068a2048b2fcae7-000000000004b860-0005f9ae5b4baa45.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-000000000004b9e8-0005f9b8ce13fb12.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005fbc0a1d366d5-f1d3155b7b7ebf48.journal~ (24.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@fd651a2e06be4a8d91a9c3ad6c6266d4-0000000000000001-0005fbc0a1c97aa1.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005fc61036a4390-150ea5c93b14b0d2.journal~ (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1000@ce9d7eea49e14b65a02467b30af60c5d-0000000000051ea9-0005fc144d54d2ee.journal (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/user-1001@0005fca6cd3c3087-84b7b6651a93a19a.journal~ (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005fc746e119a30-132977fffbe57697.journal~ (8.0M).
          Deleted archived journal /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d/system@0005fca6cd37cd77-831ed6efea5a3069.journal~ (8.0M).
          Vacuuming done, freed 704.1M of archived journals from /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d.
          16G     /var/log
          16G     /var/
          625M    /var/lib
          593M    /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d
          pi@iobroker:~ $
          Die 2 Files gehen stark ab:
          maxpd
          • M maxpd
            16G     /var/log
            16G     /var/
            625M    /var/lib
            pi@iobroker:~ $
            @maxpd
            Bitte keine Screenshots.
            Dann wird es wohl irgendeinen Grund für die Größe der Dateien geben.
            Bei mir sind die nämlich sehr viel kleiner:
            echad@chet:~/iob_diag $ ls -lAh /var/log/ | grep 'kern\|syslog'
            -rw-r-----  1 root adm             525K May 20 17:49 kern.log
            -rw-r-----  1 root adm             182K May 13 23:56 kern.log.1
            -rw-r-----  1 root adm              25K May  6 23:59 kern.log.2.gz
            -rw-r-----  1 root adm              25K Apr 29 23:55 kern.log.3.gz
            -rw-r-----  1 root adm              16K Apr 22 23:54 kern.log.4.gz
            -rw-r-----  1 root adm              13M May 20 23:17 syslog
            -rw-r-----  1 root adm              11M May 14 00:00 syslog.1
            -rw-r-----  1 root adm             298K May  7 00:00 syslog.2.gz
            -rw-r-----  1 root adm             285K Apr 30 00:00 syslog.3.gz
            -rw-r-----  1 root adm             354K Apr 23 00:00 syslog.4.gz
            • M maxpd
              16G     /var/log
              16G     /var/
              625M    /var/lib
              pi@iobroker:~ $
              @maxpd
              Haste jetzt wieder Luft zum atmen auf der Kiste?
              df -h
              Und dann dringend deinen Paketmanager wieder in Schwung bringen, da gibt es wohl einiges zu tun.
              iob stop
              iob fix
              iob start
              iob diag
                @maxpd
                maxpd
                @thomas-braun sorry, war aus winscp
                ich lad mir die morgen mal runter und gucke rein.
                Danke soweit für die krasse Hilfe!
                maxpd
                • M maxpd
                  Wofür runterladen? Schau doch direkt auf der Kiste rein...
                  less /var/log/kern.log
                    maxpd
                    pi@iobroker:~ $ less /var/log/kern.log
                    May 28 02:00:20 iobroker kernel: [60326.314063] Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
                    May 28 02:00:20 iobroker kernel: [60326.314094] CIFS: Attempting to mount \\192.168.178.38\backup
                    May 28 11:17:04 iobroker kernel: [    0.000000] Booting Linux on physical CPU 0x0
                    May 28 11:17:04 iobroker kernel: [    0.000000] Linux version 6.1.21-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP Mon Apr  3 17:22:30 BST 2023
                    May 28 11:17:04 iobroker kernel: [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
                    May 28 11:17:04 iobroker kernel: [    0.000000] CPU: div instructions available: patching division code
                    May 28 11:17:04 iobroker kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
                    May 28 11:17:04 iobroker kernel: [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
                    May 28 11:17:04 iobroker kernel: [    0.000000] random: crng init done
                    May 28 11:17:04 iobroker kernel: [    0.000000] Memory policy: Data cache writealloc
                    May 28 11:17:04 iobroker kernel: [    0.000000] Reserved memory: created CMA memory pool at 0x000000000ec00000, size 512 MiB
                    May 28 11:17:04 iobroker kernel: [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
                    May 28 11:17:04 iobroker kernel: [    0.000000] Zone ranges:
                    May 28 11:17:04 iobroker kernel: [    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
                    May 28 11:17:04 iobroker kernel: [    0.000000]   Normal   empty
                    May 28 11:17:04 iobroker kernel: [    0.000000]   HighMem  [mem 0x0000000030000000-0x00000001ffffffff]
                    May 28 11:17:04 iobroker kernel: [    0.000000] Movable zone start for each node
                    May 28 11:17:04 iobroker kernel: [    0.000000] Early memory node ranges
                    May 28 11:17:04 iobroker kernel: [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b2fffff]
                    May 28 11:17:04 iobroker kernel: [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
                    May 28 11:17:04 iobroker kernel: [    0.000000]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
                    May 28 11:17:04 iobroker kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
                    May 28 11:17:04 iobroker kernel: [    0.000000] On node 0, zone HighMem: 256 pages in unavailable ranges
                    May 28 11:17:04 iobroker kernel: [    0.000000] percpu: Embedded 17 pages/cpu s36884 r8192 d24556 u69632
                    May 28 11:17:04 iobroker kernel: [    0.000000] pcpu-alloc: s36884 r8192 d24556 u69632 alloc=17*4096
                    May 28 11:17:04 iobroker kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                    May 28 11:17:04 iobroker kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2059328
                    May 28 11:17:04 iobroker kernel: [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:57:31:D7 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=e52a9d10-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                    May 28 11:17:04 iobroker kernel: [    0.000000] Kernel parameter elevator= does not have any effect anymore.
                    May 28 11:17:04 iobroker kernel: [    0.000000] Please use sysfs to set IO scheduler for individual devices.
                    May 28 11:17:04 iobroker kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
                    May 28 11:17:04 iobroker kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
                    May 28 11:17:04 iobroker kernel: [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
                    May 28 11:17:04 iobroker kernel: [    0.000000] software IO TLB: area num 4.
                    May 28 11:17:04 iobroker kernel: [    0.000000] software IO TLB: mapped [mem 0x0000000006400000-0x000000000a400000] (64MB)
                    May 28 11:17:04 iobroker kernel: [    0.000000] Memory: 7560572K/8244224K available (10240K kernel code, 1502K rwdata, 3128K rodata, 2048K init, 634K bss, 159364K reserved, 524288K cma-reserved, 7457792K highmem)
                    May 28 11:17:04 iobroker kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                    May 28 11:17:04 iobroker kernel: [    0.000000] ftrace: allocating 37084 entries in 109 pages
                    May 28 11:17:04 iobroker kernel: [    0.000000] ftrace: allocated 109 pages with 5 groups
                    May 28 11:17:04 iobroker kernel: [    0.000000] trace event string verifier disabled
                    May 28 11:17:04 iobroker kernel: [    0.000000] rcu: Hierarchical RCU implementation.
                    May 28 11:17:04 iobroker kernel: [    0.000000]         Rude variant of Tasks RCU enabled.
                    May 28 11:17:04 iobroker kernel: [    0.000000]         Tracing variant of Tasks RCU enabled.
                    May 28 11:17:04 iobroker kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
                    May 28 11:17:04 iobroker kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                    May 28 11:17:04 iobroker kernel: [    0.000000] GIC: Using split EOI/Deactivate mode
                    May 28 11:17:04 iobroker kernel: [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
                    May 28 11:17:04 iobroker kernel: [    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                    May 28 11:17:04 iobroker kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                    May 28 11:17:04 iobroker kernel: [    0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
                    May 28 11:17:04 iobroker kernel: [    0.000007] Switching to timer-based delay loop, resolution 18ns
                    May 28 11:17:04 iobroker kernel: [    0.000156] Console: colour dummy device 80x30
                    May 28 11:17:04 iobroker kernel: [    0.000385] printk: console [tty1] enabled
                    May 28 11:17:04 iobroker kernel: [    0.000414] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
                    May 28 11:17:04 iobroker kernel: [    0.000431] pid_max: default: 32768 minimum: 301
                    May 28 11:17:04 iobroker kernel: [    0.000483] LSM: Security Framework initializing
                    May 28 11:17:04 iobroker kernel: [    0.000569] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                    May 28 11:17:04 iobroker kernel: [    0.000586] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                    May 28 11:17:04 iobroker kernel: [    0.001149] cgroup: Disabling memory control group subsystem
                    May 28 11:17:04 iobroker kernel: [    0.001248] CPU: Testing write buffer coherency: ok
                    pi@iobroker:~ $ less /var/log/syslog
                    May 28 00:00:25 iobroker systemd[1]: rsyslog.service: Sent signal SIGHUP to main process 396 (rsyslogd) on client request.
                    May 28 00:00:25 iobroker systemd[1]: logrotate.service: Succeeded.
                    May 28 00:00:25 iobroker systemd[1]: Finished Rotate log files.
                    May 28 00:00:26 iobroker systemd[1]: man-db.service: Succeeded.
                    May 28 00:00:26 iobroker systemd[1]: Finished Daily man-db regeneration.
                    May 28 00:09:01 iobroker CRON[14268]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
                    May 28 00:09:01 iobroker systemd[1]: Starting Clean php session files...
                    May 28 00:09:01 iobroker systemd[1]: phpsessionclean.service: Succeeded.
                    May 28 00:09:01 iobroker systemd[1]: Finished Clean php session files.
                    May 28 00:10:25 iobroker rsyslogd: [origin software="rsyslogd" swVersion="8.2102.0" x-pid="396" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
                    May 28 00:15:01 iobroker rngd[463]: stats: bits received from HRNG source: 500064
                    May 28 00:15:01 iobroker rngd[463]: stats: bits sent to kernel pool: 450240
                    May 28 00:15:01 iobroker rngd[463]: stats: entropy added to kernel pool: 450240
                    May 28 00:15:01 iobroker rngd[463]: stats: FIPS 140-2 successes: 25
                    May 28 00:15:01 iobroker rngd[463]: stats: FIPS 140-2 failures: 0
                    May 28 00:15:01 iobroker rngd[463]: stats: FIPS 140-2(2001-10-10) Monobit: 0
                    May 28 00:15:01 iobroker rngd[463]: stats: FIPS 140-2(2001-10-10) Poker: 0
                    May 28 00:15:01 iobroker rngd[463]: stats: FIPS 140-2(2001-10-10) Runs: 0
                    May 28 00:15:01 iobroker rngd[463]: stats: FIPS 140-2(2001-10-10) Long run: 0
                    /var/log/syslog
                    @maxpd
                    df -h
                    Ja, ging nur nicht mit einem iobroker start, sondern musste die ganze kiste rebooten.
                    maxpd
                    • M maxpd
                      /var/log/syslog
                      @maxpd
                      df -h
                      @maxpd
                      Mit den ersten 15 Zeilen kann man natürlich nix anfangen, wenn die Datei tausende Zeilen hat.
                      Jag jetzt nochmal
                      iob diag
                      drüber.
                      Hast du die Quellen für den Paketmanager aufgeräumt?
                        @maxpd
                        Jag jetzt nochmal
                        iob diag
                        drüber.
                        maxpd
                        @thomas-braun Ja, deswegen wollte ich das gesamte File mal runterladen, zum besseren Durchwühlen. Aber das dauert, der hat nur 800KB/s Speed drauf. Warum auch immer.
                        Danach räume ich auf.
                        maxpd
                        • M maxpd
                          less ist ein Pager und genau dafür gedacht...
                          Die 'Seite runter' Taste ist dein Freund.
                            maxpd
                            schrieb am zuletzt editiert von maxpd
                            @thomas-braun der scheint gestern so voll gelaufen zu sein. sieht in beiden files unendlich mal so aus:
                            kern.log
                            May 28 12:46:34 iobroker kernel: [ 2799.497927] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                            syslog
                            May 28 12:46:31 iobroker kernel: [ 2796.704568] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                            Ich würde die Files mal Löschen. Denke das System legt die dann neu an bei Bedarf.
                            iob diag:
                            Skript v.2023-04-16
                            *** BASE SYSTEM ***
                            Model           : Raspberry Pi 4 Model B Rev 1.4
                            Architecture    : armv7l
                            Docker          : false
                            Virtualization  : none
                            Distributor ID: Raspbian
                            Description:    Raspbian GNU/Linux 11 (bullseye)
                            Release:        11
                            Codename:       bullseye
                            PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
                            NAME="Raspbian GNU/Linux"
                            VERSION_ID="11"
                            VERSION="11 (bullseye)"
                            VERSION_CODENAME=bullseye
                            ID=raspbian
                            ID_LIKE=debian
                            HOME_URL="http://www.raspbian.org/"
                            SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                            BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                            Systemuptime and Load:
                             12:25:07 up 18 min,  2 users,  load average: 0.35, 1.09, 1.05
                            CPU threads: 4
                            Raspberry only:
                            throttled=0x0
                            Other values than 0x0 hint to temperature/voltage problems
                            temp=46.7'C
                            volt=0.8600V
                            *** Time and Time Zones ***
                                           Local time: Mon 2023-05-29 12:25:07 CEST
                                       Universal time: Mon 2023-05-29 10:25:07 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            *** User and Groups ***
                            pi
                            /home/pi
                            pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c        spi iobroker
                            *** X-Server-Setup ***
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            Boot Target:    multi-user.target
                            *** MEMORY ***
                            Mem:            7.9G        391M        7.2G        0.0K        275M        7.3G
                            Swap:            99M          0B         99M
                            Total:          8.0G        391M        7.3G
                                     7897 M total memory
                                      391 M used memory
                                      116 M active memory
                                      478 M inactive memory
                                     7230 M free memory
                                       56 M buffer memory
                                      219 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /dev/root      ext4       30G   26G  2.0G  94% /
                            devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
                            tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                            tmpfs          tmpfs     1.6G  796K  1.6G   1% /run
                            /dev/sda1      vfat      253M   51M  202M  20% /boot
                            tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
                            [Mon May 29 12:06:13 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1  smsc95xx.macaddr=E4:5F:01:57:31:D7 vc_mem.mem_base=0x3eb00000 vc_mem        .mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=e52a9d10-0        2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                            [Mon May 29 12:06:15 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Quota mode: none.
                            [Mon May 29 12:06:15 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 8:2.
                            [Mon May 29 12:06:16 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                            TARGET  SOURCE    FSTYPE OPTIONS
                            /       /dev/sda2 ext4   rw,noatime,commit=600
                            `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharse        t=ascii,shortname=mixed,flush,errors=remount-ro
                            /var:
                            17G     /var/
                            16G     /var/log
                            633M    /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d
                            624M    /var/lib
                            Archived and active journals take up 632.1M in the file system.
                            /opt/iobroker/backups:
                            72M     /opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            2.6G    /opt/iobroker/iobroker-data/
                            1.9G    /opt/iobroker/iobroker-data/history
                            317M    /opt/iobroker/iobroker-data/files
                            248M    /opt/iobroker/iobroker-data/backup-objects
                            72M     /opt/iobroker/iobroker-data/files/telegram.admin
                            33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
                            23M     /opt/iobroker/iobroker-data/objects.jsonl
                            19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
                            15M     /opt/iobroker/iobroker-data/objects.json.migrated
                            15M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs         v18.16.0
                            /usr/bin/node           v18.16.0
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
                            nodejs:
                              Installed: 18.16.0-deb-1nodesource1
                              Candidate: 18.16.0-deb-1nodesource1
                              Version table:
                             *** 18.16.0-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
                                 12.22.12~dfsg-1~deb11u4 500
                            No problems detected
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Core adapters versions
                            js-controller:  4.0.24
                            admin:          6.3.5
                            javascript:     6.1.4
                            npm ERR! code ELSPROBLEMS
                            npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
                            npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
                            npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
                            npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                            npm ERR! invalid: iobroker.chromecast@3.0.3 /opt/iobroker/node_modules/iobroker.chromecast
                            npm ERR! invalid: iobroker.doorbird@0.1.5 /opt/iobroker/node_modules/iobroker.doorbird
                            npm ERR! invalid: iobroker.esphome@0.2.4 /opt/iobroker/node_modules/iobroker.esphome
                            npm ERR! invalid: iobroker.google-sharedlocations@2.1.5 /opt/iobroker/node_modules/iobroker.google-sharedlocations
                            npm ERR! invalid: iobroker.govee@0.0.5 /opt/iobroker/node_modules/iobroker.govee
                            npm ERR! invalid: iobroker.sma-em@0.6.4 /opt/iobroker/node_modules/iobroker.sma-em
                            npm ERR! invalid: iobroker.sma-speedwire@0.7.0 /opt/iobroker/node_modules/iobroker.sma-speedwire
                            npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
                            npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                            npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
                            npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                            npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                            npm ERR!     /home/pi/.npm/_logs/2023-05-29T10_26_02_865Z-debug-0.log
                            Adapters from github:   7
                            Adapter State
                              system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                              system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                            + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                              system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
                              system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker                                 -  enabled
                              system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                              system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
                              system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                              system.adapter.doorbird.0               : doorbird              : iobroker                                 -  enabled
                              system.adapter.esphome.0                : esphome               : iobroker                                 - disabled
                              system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                              system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                              system.adapter.go-e.0                   : go-e                  : iobroker                                 - disabled
                            + system.adapter.google-sharedlocations.0 : google-sharedlocations: iobroker                                 -  enabled
                              system.adapter.govee.0                  : govee                 : iobroker                                 - disabled
                              system.adapter.history.0                : history               : iobroker                                 - disabled
                            + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                              system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                            + system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                              system.adapter.info.0                   : info                  : iobroker                                 - disabled
                              system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                              system.adapter.lgtv.0                   : lgtv                  : iobroker                                 - disabled
                              system.adapter.lovelace.0               : lovelace              : iobroker                                 - disabled, port: 8091, bind: 0.0.0.0, run as: admin
                            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                            + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                              system.adapter.modbus.1                 : modbus                : iobroker                                 - disabled
                              system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 - disabled, port: 1884
                              system.adapter.mqtt.0                   : mqtt                  : iobroker                                 - disabled, port: 1884, bind: 192.168.178.30
                              system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
                            + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                              system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                              system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled, port: 0
                              system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled, port: 0
                              system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled, port: 0
                              system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled, port: 0
                              system.adapter.sayit.4                  : sayit                 : iobroker                                 -  enabled, port: 0
                            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                              system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                              system.adapter.simple-api.0             : simple-api            : iobroker                                 - disabled, port: 8087, bind: 0.0.0.0, run as: admin
                              system.adapter.sma-em.0                 : sma-em                : iobroker                                 -  enabled
                            + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                              system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 - disabled
                              system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5000
                              system.adapter.synology.1               : synology              : iobroker                                 - disabled, port: 5001
                              system.adapter.systeminfo.0             : systeminfo            : iobroker                                 - disabled
                            + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                            + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                              system.adapter.telegram.2               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
                              system.adapter.terminal.0               : terminal              : iobroker                                 - disabled, port: 8088, bind: 0.0.0.0, run as: admin
                              system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                              system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                              system.adapter.tuya.0                   : tuya                  : iobroker                                 - disabled
                              system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                              system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                              system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 - disabled
                            + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
                              system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                              system.adapter.yeelight-2.0             : yeelight-2            : iobroker                                 -  enabled
                            + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100F9Y-if00
                            + instance is alive
                            + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                            ioBroker-Repositories
                            Active repo(s): stable
                            Installed ioBroker-Instances
                            Used repository: stable
                            Adapter    "alias-manager": 1.2.4    , installed 1.2.6
                            Adapter    "backitup"     : 2.6.19   , installed 2.6.19
                            Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                            Adapter    "cloud"        : 4.3.0    , installed 4.3.0
                            Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                            Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
                            Adapter    "denon"        : 1.15.0   , installed 1.15.0
                            Adapter    "devices"      : 1.1.2    , installed 1.1.2
                            Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                            Adapter    "flot"         : 1.11.0   , installed 1.11.0
                            Adapter    "go-e"         : 1.0.27   , installed 1.0.27
                            Adapter    "history"      : 2.2.4    , installed 2.2.4
                            Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
                            Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
                            Adapter    "iot"          : 1.14.2   , installed 1.14.2
                            Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                            Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
                            Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                            Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
                            Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                            Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                            Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
                            Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                            Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
                            Adapter    "sayit"        : 1.12.3   , installed 1.13.0
                            Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                            Adapter    "shuttercontrol": 1.4.29  , installed 1.4.29
                            Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                            Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
                            Adapter    "synology"     : 2.1.13   , installed 2.1.13
                            Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
                            Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                            Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                            Adapter    "text2command" : 2.3.0    , installed 2.3.0
                            Adapter    "tr-064"       : 4.2.18   , installed 4.2.17 [Updatable]
                            Adapter    "tuya"         : 3.13.1   , installed 3.13.1
                            Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                            Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                            Adapter    "wled"         : 0.6.7    , installed 0.6.7
                            Adapter    "yeelight-2"   : 1.1.2    , installed 1.2.1
                            Adapter    "youtube"      : 4.1.0    , installed 4.1.0
                            Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                            Objects and States
                            Objects:        20419
                            States:         17455
                            Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                            Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                            Hit:4 https://apt.pivccu.de/piVCCU stable InRelease
                            Reading package lists...
                            Pending Updates: 0
                            *** Listening Ports ***
                            tcp        0      0 192.168.178.30:2010     0.0.0.0:*               LISTEN      1001       31387      4068/io.hm-rpc.1
                            tcp        0      0 192.168.178.30:2001     0.0.0.0:*               LISTEN      1001       28518      3788/io.hm-rpc.0
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       30181      3569/iobroker.js-co
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       28957      3569/iobroker.js-co
                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       28592      3855/io.sonoff.0
                            tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          12920      877/dnsmasq
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14293      853/sshd: /usr/sbin
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       30942      3599/io.admin.0
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          14295      853/sshd: /usr/sbin
                            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       29470      3925/io.shelly.0
                            udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          12919      877/dnsmasq
                            udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          12916      877/dnsmasq
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1825       728/dhclient
                            udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       31119      3802/io.mihome-vacu
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       36356      4609/node
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       29509      4036/io.chromecast.
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1655       374/avahi-daemon: r
                            udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1001       34007      4315/io.sma-em.0
                            udp        0      0 0.0.0.0:41312           0.0.0.0:*                           108        1657       374/avahi-daemon: r
                            udp6       0      0 :::46113                :::*                                108        1658       374/avahi-daemon: r
                            udp6       0      0 :::5353                 :::*                                108        1656       374/avahi-daemon: r
                            2023-05-29 12:27:24.062  - info: denon.0 (4400) [CONNECT] Trying to connect to 192.168.178.62:23
                            2023-05-29 12:27:24.320  - info: denon.0 (4400) [CONNECT] Adapter connected to DENON-AVR: 192.168.178.62:23
                            2023-05-29 12:27:24.433  - info: backitup.0 (4339) [iobroker] backup will be activated at 02:00 every 1 day(s)
                            2023-05-29 12:27:25.819  - debug: mihome-vacuum.0 (3802) get params for stock Vacuum
                            2023-05-29 12:27:25.820  - debug: mihome-vacuum.0 (3802) Message= {"id":70,"method":"get_status"}
                            2023-05-29 12:27:25.829  - debug: mihome-vacuum.0 (3802) MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":1239,"state":8,"battery":100,"clean_time":2070,"clean_area":31762500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":70}
                            2023-05-29 12:27:25.830  - debug: mihome-vacuum.0 (3802) setGetStatus {"msg_ver":3,"msg_seq":1239,"state":8,"battery":100,"clean_time":2070,"clean_area":31762500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
                            2023-05-29 12:27:25.832  - debug: mihome-vacuum.0 (3802) Message= {"id":71,"method":"get_network_info"}
                            2023-05-29 12:27:25.856  - debug: mihome-vacuum.0 (3802) MIIO RECIVE: {"result":{"ssid":"Miss","ip":"192.168.178.33","mac":"7c:49:eb:9d:95:02","bssid":"44:4e:6d:b5:85:48","rssi":-47},"id":71}
                            2023-05-29 12:27:26.549  - debug: mihome-vacuum.0 (3802) Message= {"id":72,"method":"get_sound_volume"}
                            2023-05-29 12:27:26.561  - debug: mihome-vacuum.0 (3802) MIIO RECIVE: {"result":[56],"id":72}
                            2023-05-29 12:27:26.562  - debug: mihome-vacuum.0 (3802) Message= {"id":73,"method":"get_map_v1"}
                            2023-05-29 12:27:26.570  - debug: mihome-vacuum.0 (3802) MIIO RECIVE: {"result":["retry"],"id":73}
                            2023-05-29 12:27:26.871  - debug: mihome-vacuum.0 (3802) Message= {"id":74,"method":"get_map_v1"}
                            2023-05-29 12:27:26.880  - debug: mihome-vacuum.0 (3802) MIIO RECIVE: {"result":["retry"],"id":74}
                            2023-05-29 12:27:27.097  - info: host.iobroker instance system.adapter.web.1 started with pid 4864
                            2023-05-29 12:27:27.182  - debug: mihome-vacuum.0 (3802) Message= {"id":75,"method":"get_map_v1"}
                            2023-05-29 12:27:27.189  - debug: mihome-vacuum.0 (3802) MIIO RECIVE: {"result":["retry"],"id":75}
                            2023-05-29 12:27:24.816  - info: backitup.0 (4339) [ccu] backup will be activated at 01:30 every 1 day(s)
                            2023-05-29 12:27:27.492  - debug: mihome-vacuum.0 (3802) Message= {"id":76,"method":"get_map_v1"}
                            2023-05-29 12:27:27.509  - debug: mihome-vacuum.0 (3802) MIIO RECIVE: {"result":["retry"],"id":76}
                            2023-05-29 12:27:27.812  - debug: mihome-vacuum.0 (3802) Message= {"id":77,"method":"get_map_v1"}
                            2023-05-29 12:27:27.819  - debug: mihome-vacuum.0 (3802) MIIO RECIVE: {"result":["retry"],"id":77}
                            2023-05-29 12:27:28.120  - debug: mihome-vacuum.0 (3802) Message= {"id":78,"method":"get_carpet_mode"}
                            2023-05-29 12:27:28.128  - debug: mihome-vacuum.0 (3802) MIIO RECIVE: {"result":[{"enable":0,"current_integral":0,"current_high":0,"current_low":0,"stall_time":0}],"id":78}
                            maxpd
                            GlasfaserG Thomas BraunT 3 Antworten Letzte Antwort
                            • M maxpd
                              kern.log
                              syslog
                              iob diag:
                              Skript v.2023-04-16
                              *** BASE SYSTEM ***
                              Docker          : false
                              Release:        11
                              Codename:       bullseye
                              VERSION_ID="11"
                              ID=raspbian
                              ID_LIKE=debian
                              CPU threads: 4
                              Raspberry only:
                              throttled=0x0
                              temp=46.7'C
                              volt=0.8600V
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              /home/pi
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:            99M          0B         99M
                                       7897 M total memory
                                        391 M used memory
                                        116 M active memory
                                       7230 M free memory
                                         56 M buffer memory
                                        219 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /var:
                              17G     /var/
                              16G     /var/log
                              624M    /var/lib
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.3.5
                              javascript:     6.1.4
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        20419
                              States:         17455
                              Pending Updates: 0
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Stelle mal die Logstufe um ... der flutet gerade dein LOG
                              • M maxpd
                                kern.log
                                syslog
                                iob diag:
                                Skript v.2023-04-16
                                *** BASE SYSTEM ***
                                Docker          : false
                                Release:        11
                                Codename:       bullseye
                                VERSION_ID="11"
                                ID=raspbian
                                ID_LIKE=debian
                                CPU threads: 4
                                Raspberry only:
                                throttled=0x0
                                temp=46.7'C
                                volt=0.8600V
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                /home/pi
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:            99M          0B         99M
                                         7897 M total memory
                                          391 M used memory
                                          116 M active memory
                                         7230 M free memory
                                           56 M buffer memory
                                          219 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /var:
                                17G     /var/
                                16G     /var/log
                                624M    /var/lib
                                /usr/bin/npm            9.5.1
                                /usr/bin/npx            9.5.1
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.3.5
                                javascript:     6.1.4
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        20419
                                States:         17455
                                Pending Updates: 0
                                NEIN! Logfiles löscht man nicht einfach so.
                                • M maxpd
                                  kern.log
                                  syslog
                                  iob diag:
                                  Skript v.2023-04-16
                                  *** BASE SYSTEM ***
                                  Docker          : false
                                  Release:        11
                                  Codename:       bullseye
                                  VERSION_ID="11"
                                  ID=raspbian
                                  ID_LIKE=debian
                                  CPU threads: 4
                                  Raspberry only:
                                  throttled=0x0
                                  temp=46.7'C
                                  volt=0.8600V
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  /home/pi
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:            99M          0B         99M
                                           7897 M total memory
                                            391 M used memory
                                            116 M active memory
                                           7230 M free memory
                                             56 M buffer memory
                                            219 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /var:
                                  17G     /var/
                                  16G     /var/log
                                  624M    /var/lib
                                  /usr/bin/npm            9.5.1
                                  /usr/bin/npx            9.5.1
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.3.5
                                  javascript:     6.1.4
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        20419
                                  States:         17455
                                  Pending Updates: 0
                                  @maxpd
                                  volt=0.8600V
                                  Deine Spannungsversorgung scheint mir ein wenig wackelig. Könnte früher oder später zu Problemen führen.
                                  Installier die nochmal:
                                  Und prune mal den npm tree:
                                  cd /opt/iobroker
                                  npm prune
                                    @maxpd
                                    volt=0.8600V
                                    cd /opt/iobroker
                                    npm prune
                                    maxpd
                                    @thomas-braun Ich habe die Festplatte wieder direkt an den Raspi gehangen, um ein Backfeeding vom USB Hub auszuschließen. Und ich habe das Netzteil ausgetauscht gegen ein Laptop-Markennetzteil mit verschiedenen Spannungsvarianten, darunter auch 5V 3A. In allen Fällen schmeißt die Diagnose 0.8600V aus.
                                    maxpd
