  4. Täglicher Absturz ioBroker + Zugriff auf Raspi [gelöst]
    5.4k
340 Beiträge 5 Kommentatoren 82.1k Aufrufe 4 Beobachtet
  • S searcher57
    @searcher57 said in Täglicher Absturz ioBroker + Zugriff auf Raspi:
    @glasfaser said in Täglicher Absturz ioBroker + Zugriff auf Raspi:
    @searcher57
    Zeige dann bitte die Langversion von
    iob diag
    Hier die Vollversion. Ohne ein laufendes Script!
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     20:10:13 up 31 min,  1 user,  load average: 0.92, 0.54, 0.44
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=51.1'C
    volt=0.9460V
    *** Time and Time Zones ***
                   Local time: Wed 2023-05-24 20:10:14 CEST
               Universal time: Wed 2023-05-24 18:10:14 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            1.8G        1.1G        155M        1.0M        544M        623M
    Swap:            99M          0B         99M
    Total:          1.9G        1.1G        255M
             1849 M total memory
             1149 M used memory
             1275 M active memory
              295 M inactive memory
              155 M free memory
               56 M buffer memory
              487 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       29G  3.8G   25G  14% /
    devtmpfs       devtmpfs  667M     0  667M   0% /dev
    tmpfs          tmpfs     925M     0  925M   0% /dev/shm
    tmpfs          tmpfs     370M  1.1M  369M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    /dev/sda1      exfat      29G   91M   29G   1% /mnt/usb0
    tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
    [Wed May 24 19:39:04 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:15:C8:D1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b5d4b387-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Wed May 24 19:39:05 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed May 24 19:39:05 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Wed May 24 19:39:07 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET      SOURCE         FSTYPE OPTIONS
    /           /dev/mmcblk0p2 ext4   rw,noatime
    |-/boot     /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/mnt/usb0 /dev/sda1      exfat  rw,nosuid,nodev,noexec,relatime,fmask=0000,dmask=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro
    /var:
    632M    /var/
    194M    /var/log
    179M    /var/cache
    177M    /var/log/journal/330ce8f5ef974364b1563dcde1ee3ca3
    Archived and active journals take up 176.0M in the file system.
    /opt/iobroker/backups:
    43M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    325M    /opt/iobroker/iobroker-data/
    264M    /opt/iobroker/iobroker-data/files
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/telegram.admin
    42M     /opt/iobroker/iobroker-data/files/devices.admin
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    13M     /opt/iobroker/iobroker-data/states.jsonl
    9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   0
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
      system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
    + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
    + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
    + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
      system.adapter.yr.0                     : yr                    : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.6.19   , installed 2.6.19
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "devices"      : 1.1.2    , installed 1.1.2
    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
    Adapter    "iot"          : 1.14.2   , installed 1.14.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "sbfspot"      : 4.1.4    , installed 4.1.4
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "socketio"     : 4.2.0    , installed 6.3.1
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "text2command" : 2.3.0    , installed 2.3.0
    Adapter    "web"          : 4.3.0    , installed 5.3.1
    Adapter    "ws"           : 1.3.0    , installed 2.3.1
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Objects and States
    Objects:        8972
    States:         7462
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://repos.influxdata.com/debian bullseye InRelease
    Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12248      548/sshd: /usr/sbin
    tcp        0      0 192.168.178.38:2001     0.0.0.0:*               LISTEN      1001       15693      941/io.hm-rpc.1
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15449      590/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15421      590/iobroker.js-con
    tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1001       4029       926/io.hm-rpc.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12250      548/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12725      823/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17530      1133/io.web.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       15830      1064/io.simple-api.
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        12609      419/influxd
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       12903      954/io.shelly.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       12984      1001/io.broadlink2.
    udp        0      0 0.0.0.0:33676           0.0.0.0:*                           108        14571      350/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12632      756/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14569      350/avahi-daemon: r
    udp        0      0 0.0.0.0:51494           0.0.0.0:*                           1001       12999      1001/io.broadlink2.
    udp6       0      0 :::546                  :::*                                0          3732       756/dhcpcd
    udp6       0      0 :::44639                :::*                                108        14572      350/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14570      350/avahi-daemon: r
    2023-05-24 19:40:23.860  - info: tankerkoenig.0 (1079) Sync time set to 10 minutes or 600000 ms
    2023-05-24 19:40:25.728  - info: hm-rega.0 (911) State value to set for "hm-rpc.0.00151D899FFDB6.1.SECTION" has to be type "string" but received type "number"
    2023-05-24 19:40:26.235  - info: text2command.0 (1099) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.text2command, node: v18.16.0, js-controller: 4.0.24
    2023-05-24 19:40:27.399  - info: hm-rega.0 (911) Updated all datapoints
    2023-05-24 19:40:27.436  - info: hm-rega.0 (911) got 6 variables
    2023-05-24 19:40:27.650  - info: hm-rega.0 (911) added/updated 6 variables
    2023-05-24 19:40:27.650  - info: hm-rega.0 (911) deleted 0 variables
    2023-05-24 19:40:29.144  - info: alexa2.0 (896) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2023-05-24 19:40:29.219  - info: vis.0 (1114) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.16.0, js-controller: 4.0.24
    2023-05-24 19:40:29.670  - info: vis.0 (1114) vis license is OK.
    2023-05-24 19:40:29.845  - info: host.raspberrypi instance system.adapter.web.0 started with pid 1133
    2023-05-24 19:40:29.857  - info: alexa2.0 (896) Initialization Done ...
    2023-05-24 19:40:30.751  - info: vis.0 (1114) Terminated (NO_ERROR): Without reason
    2023-05-24 19:40:31.397  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
    2023-05-24 19:40:33.788  - info: host.raspberrypi instance system.adapter.echarts.0 started with pid 1144
    2023-05-24 19:40:34.403  - info: web.0 (1133) starting. Version 5.3.1 in /opt/iobroker/node_modules/iobroker.web, node: v18.16.0, js-controller: 4.0.24
    2023-05-24 19:40:35.227  - info: web.0 (1133) socket.io server listening on port 8082
    2023-05-24 19:40:35.236  - info: web.0 (1133) simpleAPI server listening on port 8082
    2023-05-24 19:40:35.237  - info: web.0 (1133) Allow states only when user is owner: false
    2023-05-24 19:40:35.284  - info: web.0 (1133) http server listening on port 8082
    2023-05-24 19:40:37.758  - info: echarts.0 (1144) starting. Version 1.0.12 in /opt/iobroker/node_modules/iobroker.echarts, node: v18.16.0, js-controller: 4.0.24
    2023-05-24 19:40:41.353  - info: tankerkoenig.0 (1079) Start first request
    2023-05-24 19:40:49.296  - info: host.raspberrypi instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-05-24 19:45:13.384  - info: javascript.0 (847) script.js.downloads.Shelly-Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 4 | Reboots korrigiert: 0 | Unveränderte Werte: 8
    2023-05-24 20:00:00.028  - info: javascript.0 (847) script.js.downloads.Shelly-Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 4 | Reboots korrigiert: 0 | Unveränderte Werte: 8
    Sorry, ein Script,was ich herunergeladen habe, "shelly-Verbrauch" lief noch!
    GlasfaserG Offline
    GlasfaserG Offline
    #250
    @searcher57 sagte in Täglicher Absturz ioBroker + Zugriff auf Raspi:
    Schalte alle Adapter aus ,
    natürlich den ADMIN nicht
    Reboote dein System ... dann nochmal
    free -th --mega
    zeigen
    • GlasfaserG Glasfaser
      free -th --mega
      zeigen
      searcher57
      #251
      free -th --mega
      zeigen
      Bitte schön!
      pi@raspberrypi:~ $ free -th --mega
      Mem:            1.8G        398M        1.2G        1.0M        282M        1.4G
      Swap:            99M          0B         99M
      Total:          1.9G        398M        1.3G
      pi@raspberrypi:~ $
        @searcher57
        Das ist kein Absturz. Das ist die normale Anzeige von top, sortiert nach PID. Mit 'q' kommt man da raus.
        #252
        @thomas-braun sagte in Täglicher Absturz ioBroker + Zugriff auf Raspi:
        @searcher57
        bitte nach MEM sortieren, dann sind die Speicherfresser ganz oben
        • S searcher57
          free -th --mega
          zeigen
          Bitte schön!
          Swap:            99M          0B         99M
          pi@raspberrypi:~ $
          GlasfaserG Offline
          GlasfaserG Offline
          #253
          @searcher57
          sieht gut aus ... kannst du so lassen 🤓
          So jetzt nach und nach die Adapter alle wieder einschalten ohne den javascript .
          Wie ist dein
          einegstellt , Abfragezeit
            @searcher57
            Wie ist dein
            searcher57
            #254
            @searcher57
            Wie ist dein
            Das dauert!
            • S searcher57
              @searcher57
              Wie ist dein
              Das dauert!
              searcher57
              #255
              @searcher57
              Wie ist dein
              Das dauert!
              Die Abfrage habe ich von 10 auf 30 Minuten hoch gesetzt. Alle Instanzen laufen, außer Javascript. Die erneute Abfrage:
              Mem:            1.8G        1.0G        488M        1.0M        319M        745M
              Swap:            99M          0B         99M
              Total:          1.9G        1.0G        588M
              pi@raspberrypi:~ $
              • S searcher57
                @searcher57
                Wie ist dein
                Das dauert!
                Swap:            99M          0B         99M
                pi@raspberrypi:~ $
                #256
                @searcher57 und jetzt bitte top sortiert nach MEM
                da sollten die ersten ~20 Zeilen reichen
                Thomas BraunT S 2 Antworten Letzte Antwort
                • S searcher57
                  @searcher57
                  Wie ist dein
                  Das dauert!
                  Swap:            99M          0B         99M
                  pi@raspberrypi:~ $
                  #257
                  @searcher57
                  Warte noch 30 Minuten ob das dann stabil dabei bleibt und dann startest du den Javascript dazu.
                    #258
                    @homoran sagte in Täglicher Absturz ioBroker + Zugriff auf Raspi:
                    Geht mit Shift-M
                      searcher57
                      #259
                      @homoran said in Täglicher Absturz ioBroker + Zugriff auf Raspi:
                      pi@raspberrypi:~ $ top
                      top - 20:43:15 up 19 min,  1 user,  load average: 0.33, 0.38, 0.27
                      Tasks: 165 total,   1 running, 164 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  4.3 us,  0.8 sy,  0.0 ni, 94.6 id,  0.1 wa,  0.0 hi,  0.3 si,  0.0 st
                      MiB Mem :   1849.2 total,    482.9 free,   1043.8 used,    322.6 buff/cache
                      MiB Swap:    100.0 total,    100.0 free,      0.0 used.    742.2 avail Mem
                          PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                          588 iobroker  20   0  739868 171952  40628 S   8.9   9.1   1:56.17 iobroke+
                          955 iobroker  20   0  691312 108032  36152 S   5.0   5.7   0:59.15 io.shel+
                          987 iobroker  20   0  930040  80164  36360 S   3.0   4.2   0:28.35 io.infl+
                         1191 iobroker  20   0  925940  79404  37252 S   1.3   4.2   0:10.97 io.alex+
                          414 influxdb  20   0 1064484 142540  56804 S   0.7   7.5   0:10.24 influxd
                         1003 iobroker  20   0  659540  71036  36532 S   0.7   3.8   0:04.33 io.hm-r+
                          700 iobroker  20   0  957404 115972  42532 S   0.3   6.1   0:19.88 io.admi+
                          940 iobroker  20   0  666004  81804  36256 S   0.3   4.3   0:09.13 io.hm-r+
                         1093 iobroker  20   0  868332  87072  42148 S   0.3   4.6   0:06.97 io.tele+
                         1160 iobroker  20   0  663512  72564  35964 S   0.3   3.8   0:04.68 io.web.0
                         1232 pi        20   0   10192   3196   2732 R   0.3   0.2   0:00.20 top
                            1 root      20   0  165216  10144   7360 S   0.0   0.5   0:02.09 systemd
                            2 root      20   0       0      0      0 S   0.0   0.0   0:00.02 kthreadd
                            3 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_gp
                            4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_par+
                            5 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 slub_fl+
                        Geht mit Shift-M
                        searcher57
                        #260
                        @thomas-braun said in Täglicher Absturz ioBroker + Zugriff auf Raspi:
                        Geht mit Shift-M
                        Du bist soooooooo gut! 😙 😙
                        • S searcher57
                          #261
                          @searcher57 Danke!
                          kannst du das putty Fenster beim nächsten mal breiter machen?
                          alles gut im Moment
                            @searcher57 Danke!
                            alles gut im Moment
                            searcher57
                            #262
                            @searcher57 Danke!
                            alles gut im Moment
                            Entschuldigung die Zeit hatte ich nicht!!
                            • S searcher57
                              @searcher57 Danke!
                              alles gut im Moment
                              GlasfaserG Offline
                              GlasfaserG Offline
                              #263
                              bin Rentner
                              S HomoranH 2 Antworten Letzte Antwort
                                @searcher57 Danke!
                                alles gut im Moment
                                searcher57
                                #264
                                @searcher57 Danke!
                                alles gut im Moment
                                top - 20:47:49 up 23 min,  1 user,  load average: 0.12, 0.28, 0.26
                                Tasks: 166 total,   2 running, 164 sleeping,   0 stopped,   0 zombie
                                %Cpu(s):  3.8 us,  0.7 sy,  0.0 ni, 95.1 id,  0.1 wa,  0.0 hi,  0.2 si,  0.0 st
                                MiB Mem :   1849.2 total,    469.5 free,   1054.2 used,    325.5 buff/cache
                                MiB Swap:    100.0 total,    100.0 free,      0.0 used.    731.7 avail Mem
                                    588 iobroker  20   0  740700 181748  40628 R   7.3   9.6   2:24.79 iobroker.js-con
                                    955 iobroker  20   0  692716 111396  36152 S   4.3   5.9   1:17.21 io.shelly.0
                                    987 iobroker  20   0  931380  81252  36360 S   3.6   4.3   0:36.94 io.influxdb.0
                                    414 influxdb  20   0 1064484 142540  56804 S   1.7   7.5   0:12.95 influxd
                                    103 root       0 -20       0      0      0 I   0.3   0.0   0:00.78 kworker/0:1H-mmc_complete
                                    700 iobroker  20   0  957404 116064  42532 S   0.3   6.1   0:21.74 io.admin.0
                                   1077 iobroker  20   0  793208  78544  37636 S   0.3   4.1   0:08.52 io.tankerkoenig
                                   1191 iobroker  20   0  926468  80632  37252 S   0.3   4.3   0:13.05 io.alexa2.0
                                   1264 pi        20   0   10192   3132   2672 R   0.3   0.2   0:00.15 top
                                      4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_par_gp
                                      5 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 slub_flushwq
                                      6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 netns
                                     10 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 mm_percpu_wq
                                     11 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_kthread
                                  bin Rentner
                                  searcher57
                                  #265
                                  bin Rentner
                                  Eben!!!😇 😇
                                    bin Rentner
                                    #266
                                    @glasfaser aber sooo lange kann er das noch nicht (regulär) sein.
                                    • S searcher57
                                      @searcher57
                                      iob diag
                                      Skript v.2023-04-16
                                      *** BASE SYSTEM ***
                                      Docker          : false
                                      Release:        11
                                      Codename:       bullseye
                                      VERSION_ID="11"
                                      ID=debian
                                      CPU threads: 4
                                      Raspberry only:
                                      throttled=0x0
                                      temp=51.1'C
                                      volt=0.9460V
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      /home/pi
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Swap:            99M          0B         99M
                                               1849 M total memory
                                               1149 M used memory
                                                155 M free memory
                                                 56 M buffer memory
                                                487 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /var:
                                      632M    /var/
                                      194M    /var/log
                                      179M    /var/cache
                                      /usr/bin/npm            9.5.1
                                      /usr/bin/npx            9.5.1
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.3.5
                                      javascript:     6.1.4
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        8972
                                      States:         7462
                                      Pending Updates: 0
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      #267
                                      • system.adapter.influxdb.0 : influxdb : raspberrypi - enabled, port: 8086
                                      Mhh ...
                                      Wofür nutzt du Influxdb ... für Vis oder ...!?
                                        searcher57
                                        #268
                                        Doooooooooch seit 1026 Tagen!!😊 😊
                                          Mhh ...
                                          searcher57
                                          #269
                                          Mhh ...
                                          Ja klar!
                                          S GlasfaserG 2 Antworten Letzte Antwort
