  4. Performance Probleme im iobroker Admin auf pi4
    5.1k
111 Beiträge 6 Kommentatoren 16.3k Aufrufe 5 Beobachtet
    @maxpd
    Schau dir die Langfassung von
    iob diag
    an.
    maxpd
    schrieb am zuletzt editiert von maxpd
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     21:45:23 up 7 days, 4 min,  2 users,  load average: 0.81, 0.62, 0.57
    CPU threads: 4
    Raspberry only:
    throttled=0x50005
    Other values than 0x0 hint to temperature/voltage problems
    temp=56.4'C
    volt=0.8500V
    *** Time and Time Zones ***
                   Local time: Mon 2023-05-22 21:45:23 CEST
               Universal time: Mon 2023-05-22 19:45:23 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c        spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.9G        2.1G        5.4G        0.0K        358M        5.5G
    Swap:            99M          0B         99M
    Total:          8.0G        2.1G        5.5G
             7897 M total memory
             2125 M used memory
              121 M active memory
             2232 M inactive memory
             5412 M free memory
               42 M buffer memory
              316 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/root                        ext4       30G   14G   15G  48% /
    devtmpfs                         devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs                            tmpfs     1.6G  768K  1.6G   1% /run
    tmpfs                            tmpfs     5.0M  4.0K  5.0M   1% /run/lock
    /dev/sda1                        vfat      253M   51M  202M  20% /boot
    tmpfs                            tmpfs     790M     0  790M   0% /run/user/1000
    //192.168.178.38/backup/iobroker cifs      4.6T  1.9T  2.7T  42% /opt/iobroker/b        ackups
    [Mon May 15 21:41:04 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1  smsc95xx.macaddr=E4:5F:01:57:31:D7 vc_mem.mem_base=0x3eb00000 vc_mem        .mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=e52a9d10-0        2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Mon May 15 21:41:06 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Quota mode: none.
    [Mon May 15 21:41:06 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 8:2.
    [Mon May 15 21:41:09 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET                  SOURCE                           FSTYPE OPTIONS
    /                       /dev/sda2                        ext4   rw,noatime,commi        t=600
    |-/boot                 /dev/sda1                        vfat   rw,relatime,fmas        k=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remo        unt-ro
    `-/opt/iobroker/backups //192.168.178.38/backup/iobroker cifs   rw,relatime,vers        =1.0,cache=strict,username=iobroker,uid=1001,noforceuid,gid=1001,noforcegid,addr        =192.168.178.38,soft,unix,posixpaths,serverino,mapposix,acl,rsize=1048576,wsize=        1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
    /var:
    3.5G    /var/
    1.9G    /var/cache/apt/archives
    1.9G    /var/cache/apt
    1.9G    /var/cache
    932M    /var/log
    Archived and active journals take up 928.2M in the file system.
    /opt/iobroker/backups:
    6.8G    /opt/iobroker/backups/
    0       /opt/iobroker/backups/zigbee_0
    /opt/iobroker/iobroker-data:
    2.6G    /opt/iobroker/iobroker-data/
    1.9G    /opt/iobroker/iobroker-data/history
    317M    /opt/iobroker/iobroker-data/files
    247M    /opt/iobroker/iobroker-data/backup-objects
    72M     /opt/iobroker/iobroker-data/files/telegram.admin
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
    28M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
    16M     /opt/iobroker/iobroker-data/states.jsonl
    15M     /opt/iobroker/iobroker-data/objects.json.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.15.0
    /usr/bin/node           v18.15.0
    /usr/bin/npm            9.5.0
    /usr/bin/npx            9.5.0
    nodejs:
      Installed: 18.15.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
         18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
     *** 18.15.0-deb-1nodesource1 100
         12.22.12~dfsg-1~deb11u3 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
    npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
    npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
    npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
    npm ERR! invalid: iobroker.chromecast@3.0.3 /opt/iobroker/node_modules/iobroker.chromecast
    npm ERR! invalid: iobroker.doorbird@0.1.5 /opt/iobroker/node_modules/iobroker.doorbird
    npm ERR! invalid: iobroker.esphome@0.2.4 /opt/iobroker/node_modules/iobroker.esphome
    npm ERR! invalid: iobroker.google-sharedlocations@2.1.5 /opt/iobroker/node_modules/iobroker.google-sharedlocations
    npm ERR! invalid: iobroker.govee@0.0.5 /opt/iobroker/node_modules/iobroker.govee
    npm ERR! invalid: iobroker.sma-em@0.6.4 /opt/iobroker/node_modules/iobroker.sma-em
    npm ERR! invalid: iobroker.sma-speedwire@0.7.0 /opt/iobroker/node_modules/iobroker.sma-speedwire
    npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
    npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
    npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
    npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
    npm ERR!     /home/pi/.npm/_logs/2023-05-22T19_46_33_656Z-debug-0.log
    Adapters from github:   7
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
      system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
      system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
    + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.doorbird.0               : doorbird              : iobroker                                 -  enabled
      system.adapter.esphome.0                : esphome               : iobroker                                 - disabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
      system.adapter.go-e.0                   : go-e                  : iobroker                                 - disabled
    + system.adapter.google-sharedlocations.0 : google-sharedlocations: iobroker                                 -  enabled
      system.adapter.govee.0                  : govee                 : iobroker                                 - disabled
      system.adapter.history.0                : history               : iobroker                                 - disabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.info.0                   : info                  : iobroker                                 - disabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.lgtv.0                   : lgtv                  : iobroker                                 - disabled
      system.adapter.lovelace.0               : lovelace              : iobroker                                 - disabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
      system.adapter.modbus.1                 : modbus                : iobroker                                 - disabled
      system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 - disabled, port: 1884
      system.adapter.mqtt.0                   : mqtt                  : iobroker                                 - disabled, port: 1884, bind: 192.168.178.30
      system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      system.adapter.rpi2.0                   : rpi2                  : iobroker                                 - disabled
    + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled, port: 0
    + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled, port: 0
    + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled, port: 0
    + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled, port: 0
    + system.adapter.sayit.4                  : sayit                 : iobroker                                 -  enabled, port: 0
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
      system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sma-em.0                 : sma-em                : iobroker                                 -  enabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 - disabled
      system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5000
      system.adapter.synology.1               : synology              : iobroker                                 - disabled, port: 5001
      system.adapter.systeminfo.0             : systeminfo            : iobroker                                 - disabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.telegram.2               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.terminal.0               : terminal              : iobroker                                 - disabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
      system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
      system.adapter.tuya.0                   : tuya                  : iobroker                                 - disabled
      system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 - disabled
    + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
    + system.adapter.yeelight-2.0             : yeelight-2            : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100F9Y-if00
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "alias-manager": 1.2.4    , installed 1.2.6
    Adapter    "backitup"     : 2.6.19   , installed 2.6.19
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "cloud"        : 4.3.0    , installed 4.3.0
    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "denon"        : 1.15.0   , installed 1.15.0
    Adapter    "devices"      : 1.1.2    , installed 1.1.2
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "go-e"         : 1.0.27   , installed 1.0.27
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
    Adapter    "iot"          : 1.14.2   , installed 1.14.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
    Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
    Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
    Adapter    "sayit"        : 1.12.3   , installed 1.13.0
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "shuttercontrol": 1.4.29  , installed 1.4.29
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
    Adapter    "synology"     : 2.1.13   , installed 2.1.13
    Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "text2command" : 2.3.0    , installed 2.3.0
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.17 [Updatable]
    Adapter    "tuya"         : 3.13.1   , installed 3.13.1
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "wled"         : 0.6.7    , installed 0.6.7
    Adapter    "yeelight-2"   : 1.1.2    , installed 1.2.1
    Adapter    "youtube"      : 4.1.0    , installed 4.1.0
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        20237
    States:         17333
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:4 https://www.pivccu.de/piVCCU stable InRelease
    Reading package lists...
    Pending Updates: 45
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5019       658/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17435      658/iobroker.js-con
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          688        739/dnsmasq
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4818       697/sshd: /usr/sbin
    tcp        0      0 192.168.178.30:8100     0.0.0.0:*               LISTEN      1001       17158      2065/io.doorbird.0
    tcp        0      0 192.168.178.30:2010     0.0.0.0:*               LISTEN      1001       17999      2140/io.hm-rpc.1
    tcp        0      0 192.168.178.30:2001     0.0.0.0:*               LISTEN      1001       17983      2133/io.hm-rpc.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       37188      2464/io.sonoff.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          4828       697/sshd: /usr/sbin
    tcp6       0      0 :::8083                 :::*                    LISTEN      1001       27332      2694/io.web.1
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15086      1575/io.admin.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       37317      2419/io.shelly.0
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          687        739/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          684        739/dnsmasq
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          546        594/dhclient
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       271612     11932/io.mihome-vac
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       26572      2540/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       16335      2028/io.chromecast.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14031      377/avahi-daemon: r
    udp        0      0 0.0.0.0:34590           0.0.0.0:*                           108        14033      377/avahi-daemon: r
    udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1001       5096580    8670/io.sma-em.0
    udp6       0      0 :::5353                 :::*                                108        14032      377/avahi-daemon: r
    udp6       0      0 :::36253                :::*                                108        14034      377/avahi-daemon: r
    2023-05-22 21:47:54.637  - debug: mihome-vacuum.0 (11932) Message= {"id":712,"method":"get_carpet_mode"}
    2023-05-22 21:47:56.638  - debug: mihome-vacuum.0 (11932) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
    2023-05-22 21:48:01.822  - debug: mihome-vacuum.0 (11932) Receive <<< Helo <<< 21310020fdffffffffffffff646bc6f1ffffffffffffffffffffffffffffffff
    2023-05-22 21:48:12.945  - debug: mihome-vacuum.0 (11932) Receive <<< Helo <<< 21310020fdffffffffffffff646bc6fcffffffffffffffffffffffffffffffff
    2023-05-22 21:48:16.640  - debug: mihome-vacuum.0 (11932) get params for stock Vacuum
    2023-05-22 21:48:16.641  - debug: mihome-vacuum.0 (11932) Message= {"id":713,"method":"get_status"}
    2023-05-22 21:48:18.644  - debug: mihome-vacuum.0 (11932) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
    2023-05-22 21:48:18.645  - debug: mihome-vacuum.0 (11932) Message= {"id":714,"method":"get_network_info"}
    2023-05-22 21:48:20.647  - debug: mihome-vacuum.0 (11932) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
    2023-05-22 21:48:20.648  - debug: mihome-vacuum.0 (11932) Message= {"id":715,"method":"get_sound_volume"}
    2023-05-22 21:48:22.650  - debug: mihome-vacuum.0 (11932) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
    2023-05-22 21:48:22.651  - debug: mihome-vacuum.0 (11932) Message= {"id":716,"method":"get_map_v1"}
    2023-05-22 21:48:22.949  - debug: mihome-vacuum.0 (11932) Receive <<< Helo <<< 21310020fdffffffffffffff646bc706ffffffffffffffffffffffffffffffff
    2023-05-22 21:48:24.652  - debug: mihome-vacuum.0 (11932) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
    2023-05-22 21:48:24.953  - debug: mihome-vacuum.0 (11932) Message= {"id":717,"method":"get_map_v1"}
    2023-05-22 21:48:26.955  - debug: mihome-vacuum.0 (11932) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
    2023-05-22 21:48:27.256  - debug: mihome-vacuum.0 (11932) Message= {"id":718,"method":"get_map_v1"}
    2023-05-22 21:48:29.258  - debug: mihome-vacuum.0 (11932) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
    2023-05-22 21:48:29.559  - debug: mihome-vacuum.0 (11932) Message= {"id":719,"method":"get_map_v1"}
    2023-05-22 21:48:31.561  - debug: mihome-vacuum.0 (11932) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
    2023-05-22 21:48:31.862  - debug: mihome-vacuum.0 (11932) Message= {"id":720,"method":"get_map_v1"}
    2023-05-22 21:48:33.864  - debug: mihome-vacuum.0 (11932) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
    2023-05-22 21:48:34.066  - debug: mihome-vacuum.0 (11932) Receive <<< Helo <<< 21310020fdffffffffffffff646bc711ffffffffffffffffffffffffffffffff
    2023-05-22 21:48:34.165  - debug: mihome-vacuum.0 (11932) Message= {"id":721,"method":"get_carpet_mode"}
    2023-05-22 21:48:36.166  - debug: mihome-vacuum.0 (11932) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
    Ich sehe da nichts. Ok, ich kann wieder ein Update machen. Das letzte ist nicht so lange her. Und ich müsste die Adapter von Github auf npm wechseln.
    maxpd
    • M maxpd
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x50005
      temp=56.4'C
      volt=0.8500V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               7897 M total memory
               2125 M used memory
                121 M active memory
               5412 M free memory
                 42 M buffer memory
                316 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      3.5G    /var/
      1.9G    /var/cache/apt
      1.9G    /var/cache
      932M    /var/log
      /usr/bin/npm            9.5.0
      /usr/bin/npx            9.5.0
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        20237
      States:         17333
      Pending Updates: 45
      @maxpd sagte in Performance Probleme im iobroker Admin auf pi4:
      Raspberry only: throttled=0x50005 Other values than 0x0 hint to temperature/voltage problems temp=56.4'C volt=0.8500V
      Die Kiste wird gethrottled, also eingebremst. Stärkeres Netzteil verwenden und besser kühlen.
        maxpd
        @thomas-braun WOW. Danke!!
        Das originale Netzteil 5V 3A hatte vor einiger Zeit einen Knacks, sodass die externe SSD nicht mehr gelaufen ist.
        Ich habe es gegen ein Handynetzteil 5V 2A getauscht.
        Wirklich gut möglich, dass das Problem seit dem existiert.
        -> Also wieder ein 5V 3A besorgen.
        Gekühlt wird mittels Kühlkernen.
        -> Gehäuse öffnen
        maxpd
        Thomas BraunT HomoranH 3 Antworten Letzte Antwort
        • M maxpd
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:        11
          Codename:       bullseye
          VERSION_ID="11"
          ID=raspbian
          ID_LIKE=debian
          CPU threads: 4
          Raspberry only:
          throttled=0x50005
          temp=56.4'C
          volt=0.8500V
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   7897 M total memory
                   2125 M used memory
                    121 M active memory
                   5412 M free memory
                     42 M buffer memory
                    316 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          3.5G    /var/
          1.9G    /var/cache/apt
          1.9G    /var/cache
          932M    /var/log
          /usr/bin/npm            9.5.0
          /usr/bin/npx            9.5.0
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.3.5
          javascript:     6.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects:        20237
          States:         17333
          Pending Updates: 45
          @maxpd
          Schau dir diese Adapter an:
          Und prune mal den npm tree.
          cd /opt/iobroker
          npm prune
          • M maxpd
            -> Gehäuse öffnen
            Zu wenig. Das originale hat 3,1A.
            Niemals Handy-Ladegeräte als Netzteil missbrauchen.
            • M maxpd
              -> Gehäuse öffnen
              @maxpd
              Pending Updates: 45
              Regelmäßig das System auf Stand halten. Wird offenbar zu selten gemacht.
                @maxpd
                cd /opt/iobroker
                npm prune
                maxpd
                Was meinst du mit Anschauen? Das sind wohl die, die ich aus Github habe. Müsste die vermutlich Löschen und über NPM neu beziehen? Viel Arbeit ^^, da man wohl viele Scripte etc neu anpassen muss.
                Was bedeutet prunen?
                Update ist keine 2 Monate her. Gibts da eine Auto Update Funktion?
                maxpd
                Thomas BraunT 3 Antworten Letzte Antwort
                • M maxpd
                  Nö, zieh die einfach aus einem Repo.
                    maxpd
                    @thomas-braun said in Performance Probleme im iobroker Admin auf pi4:
                    Überall wo "original" dran steht, sind nur 3,0A drin, aber 5,1V. Aber habe auch stärke inoffizielle gefunden.
                    maxpd
                    • M maxpd
                      Räumt das Chaos in deinem npm tree auf.
                      So sollte das eigentlich aussehen:
                      echad@chet:~ $ cd /opt/iobroker/ && npm ls
                      iobroker.inst@3.0.0 /opt/iobroker
                      ├── iobroker.admin@6.4.4
                      ├── iobroker.alexa2@3.23.2
                      ├── iobroker.alias-manager@1.2.6
                      ├── iobroker.awtrix-light@0.0.4 (git+ssh://git@github.com/klein0r/ioBroker.awtrix-light.git#f8286dff6c4c44bccd0a27bd9ebcaa19e1918bb6)
                      ├── iobroker.backitup@2.6.21
                      ├── iobroker.ble@0.13.3
                      ├── iobroker.cloud@4.4.1
                      ├── iobroker.echarts@1.4.15
                      ├── iobroker.firetv@1.0.0
                      ├── iobroker.followthesun@0.4.1
                      ├── iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#384363b87eaf0fa0b66ad2b54f2f51427dbc738d)
                      ├── iobroker.history@2.2.4
                      ├── iobroker.ical@1.13.2
                      ├── iobroker.iceroad@1.2.0
                      ├── iobroker.info@1.9.26
                      ├── iobroker.iot@1.14.6 (git+ssh://git@github.com/ioBroker/ioBroker.iot.git#63327f4da6acbea109939bcb1df64e9d85ff6e53)
                      ├── iobroker.javascript@7.0.3
                      ├── iobroker.js-controller@5.0.1-alpha.0-20230418-efa3e809
                      ├── iobroker.midea@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.midea.git#0d037c0c9a025b193546f881f747c8f998bfc724)
                      ├── iobroker.mihome-cloud@0.1.0
                      ├── iobroker.mihome-vacuum@3.11.0
                      ├── iobroker.mihome@1.4.0
                      ├── iobroker.miio@0.0.13
                      ├── iobroker.nina@0.0.25
                      ├── iobroker.nuki-extended@2.6.5
                      ├── iobroker.nut@1.6.0
                      ├── iobroker.opendtu@0.1.5 (git+ssh://git@github.com/o0shojo0o/ioBroker.opendtu.git#e0582c8b3eb431a03d9f6eb807b3b9520235b8a5)
                      ├── iobroker.parcel@0.0.28 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#b395e0e062c1ab61434b15c132fee6a14d62d7ff)
                      ├── iobroker.rpi2@1.3.2
                      ├── iobroker.sainlogic@0.10.3
                      ├── iobroker.simple-api@2.7.2
                      ├── iobroker.socketio@6.3.5
                      ├── iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#de8c1ad97edafedb16cbbb2c6dc14b032848df8e)
                      ├── iobroker.tado@0.4.8
                      ├── iobroker.tankerkoenig@3.3.7
                      ├── iobroker.tr-064@4.2.18
                      ├── iobroker.tradfri@3.1.3
                      ├── iobroker.trashschedule@2.2.0
                      ├── iobroker.tuya@3.14.2
                      ├── iobroker.web@5.5.3
                      ├── iobroker.whatsapp-cmb@0.2.3
                      └── iobroker.zigbee@1.8.10
                      echad@chet:/opt/iobroker $
                      • M maxpd
                        -> Gehäuse öffnen
                        die versorgt man ja auch extern! oder mit einem aktiven Hub
                        Möglicherweise hat das auch noch was anderes überlastet, was dauerhaften Schaden genommen hat.
                        • M maxpd
                          Nein, wozu auch?
                          Das will ja niemand. Du musst schon sehen was da alles aktualisiert wird. Man will ja keinen Blindflug bei nachträglichem komischen Verhalten des Systems. Daher die Updates in übersichtlichen Häppchen einspielen.
                            maxpd
                            @homoran said in Performance Probleme im iobroker Admin auf pi4:
                            Wow, war mir nicht bekannt.
                            Also 2 Netzteile + aktiven Hub bestellen.
                            maxpd
                            • M maxpd
                              @maxpd Ha(tte)st du die SSD am USB3?
                              läuft alles auf SSD?
                              dann wechsel mal auf USB2
                                maxpd
                                Ja, war am USB3. Jetzt an USB2 ist er auch nicht schneller.
                                Ich habe jetzt bei den Bewertungen zu einem aktiven Hub von Backfeeding gelesen:
                                "Ein weiteres Problem ist aus meiner Sicht das sogenannte "Backfeeding". Die vom externen Netzteil des Hub gelieferten 5V werden nicht nur zur Versorgung der vier angeschlossenen Geräte verwendet, sondern werden auch auf dem Hostanschluss des Hubs ausgegeben. Das ist nicht nur aus elektrotechnischer Sicht sehr unelegant und wäre eigentlich einfach zu vermeiden - das führt mitunter auch zu Problemen. Beispielweise wenn als Host ein Raspberry Pi verwendet wird. Wird der Raspberry Pi neu gestartet und der Hub ist angeschlossen, dann bleibt der Raspberry Pi im Bootvorgang hängen."
                                Gibts da Modellempfehlungen?
                                Andererseits in einem Kommentar eines 5V 4A Netzteils auch gelesen:
                                "Ich betreibe einen iobroker auf dem Raspi 4 mit einer SSD über USB. Nachdem ich in den Verangenheit Abstürze des Systems hatte, obwohl ich bereits ein stärkeres Netzteils verwendete, habe ich dieses Netzteil mit 20W angeschlossen.
                                Seit dem ist der Raspi seit mehreren Wochen nicht mehr abgestürzt."
                                Warum eigentlich? Nutze ich auch für WLED Leisten.
                                Hab gelogen. Meine 2 Vorgänger hatten Kühlkörper. Der pi4 läuft ohne.
                                Soll ich Kühlkörper nutzen oder einen aktiven Lüfter?
                                Bin nicht sicher ob das so funktioniert hat:
                                pi@iobroker:/opt/iobroker $ npm prune
                                npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.s        ma-em.git
                                npm WARN skipping integrity check for git dependency ssh://git@github.com/BuZZy1337/ioBroker.doorbird.git
                                npm WARN skipping integrity check for git dependency ssh://git@github.com/nbuenger/ioBroker.govee.git
                                npm WARN skipping integrity check for git dependency ssh://git@github.com/Garfonso/ioBroker.google-sharedlocatio        ns.git
                                npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.c        hromecast.git
                                npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, w        e will not transfer it over to other users. You may safely remove the package from your dependencies.
                                npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you'v        e depended on crypto, you should switch to the one that's built-in.
                                npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so y        ou do not need this installed.
                                npm WARN deprecated topo@3.0.3: This module has moved and is now available at @hapi/topo. Please update your dep        endencies as this version is no longer maintained an may contain bugs and security issues.
                                npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends        the now deprecated request package, see https://github.com/request/request/issues/3142
                                npm WARN deprecated babel@6.23.0: In 6.x, the babel package has been deprecated in favor of babel-cli. Check htt        ps://opencollective.com/babel to support the Babel maintainers
                                npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprec        ated request package, see https://github.com/request/request/issues/3142
                                npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @hapi/hoek. Please update your dep        endencies as this version is no longer maintained an may contain bugs and security issues.
                                npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                                npm WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, flatted is its successor.
                                npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed se        parately. It is now unmaintained.
                                npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regressio        n when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visio        nmedia/debug/issues/797)
                                npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSear        chParams API instead.
                                npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in        certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3        142
                                npm WARN deprecated joi@14.3.1: This module has moved and is now available at @hapi/joi. Please update your depe        ndencies as this version is no longer maintained an may contain bugs and security issues.
                                npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
                                npm ERR! code 1
                                npm ERR! git dep preparation failed
                                npm ERR! command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.        npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=de        v --include=peer --include=optional --no-package-lock-only --no-dry-run
                                npm ERR! > iobroker.esphome@0.2.4 install
                                npm ERR! > npip install
                                npm ERR!
                                npm ERR! No python_modules directory; installing pip locally if needed.
                                npm ERR! Successfully completed pip check.
                                npm ERR! Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                                npm ERR! Collecting esphome>=2021.8
                                npm ERR!   Downloading https://www.piwheels.org/simple/esphome/esphome-2023.5.3-py2.py3-none-any.whl (2.7 MB)
                                npm ERR!      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 2.7/2.7 MB 3.4 MB/s eta 0:00:00
                                npm ERR! Collecting tornado>=3.2
                                npm ERR!   Downloading tornado-6.3.2.tar.gz (508 kB)
                                npm ERR!      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 508.8/508.8 kB 2.5 MB/s eta 0:00:00
                                npm ERR!   Installing build dependencies: started
                                npm ERR!   Installing build dependencies: finished with status 'done'
                                npm ERR!   Getting requirements to build wheel: started
                                npm ERR!   Getting requirements to build wheel: finished with status 'done'
                                npm ERR!   Preparing metadata (pyproject.toml): started
                                npm ERR!   Preparing metadata (pyproject.toml): finished with status 'done'
                                npm ERR! Collecting voluptuous==0.13.1 (from esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.13.1-py3-none-any.whl (35 kB)
                                npm ERR! Collecting PyYAML==6.0 (from esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/pyyaml/PyYAML-6.0-cp39-cp39-linux_armv7l.whl (45 kB)
                                npm ERR! Collecting paho-mqtt==1.6.1 (from esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)
                                npm ERR! Collecting colorama==0.4.6 (from esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/colorama/colorama-0.4.6-py2.py3-none-any.whl (25 kB)
                                npm ERR!   Downloading tornado-6.3.1.tar.gz (508 kB)
                                npm ERR!      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 508.5/508.5 kB 4.1 MB/s eta 0:00:00
                                npm ERR! Collecting tzlocal==5.0.1 (from esphome>=2021.8)
                                npm ERR!   Downloading https://www.piwheels.org/simple/tzlocal/tzlocal-5.0.1-py3-none-any.whl (20 kB)
                                npm ERR! Collecting tzdata>=2021.1 (from esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/tzdata/tzdata-2023.3-py2.py3-none-any.whl (341 kB)
                                npm ERR! Collecting pyserial==3.5 (from esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
                                npm ERR! Collecting platformio==6.1.6 (from esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/platformio/platformio-6.1.6-py3-none-any.whl (416 kB)
                                npm ERR! Collecting esptool==4.5.1 (from esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/esptool/esptool-4.5.1-py3-none-any.whl (320 kB)
                                npm ERR! Collecting click==8.1.3 (from esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/click/click-8.1.3-py3-none-any.whl (96 kB)
                                npm ERR! Collecting esphome-dashboard==20230516.0 (from esphome>=2021.8)
                                npm ERR!   Downloading https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20230516.0-py3-none-a        ny.whl (1.7 MB)
                                npm ERR!      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.7/1.7 MB 2.5 MB/s eta 0:00:00
                                npm ERR! Collecting aioesphomeapi==13.7.5 (from esphome>=2021.8)
                                npm ERR!   Downloading https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-13.7.5-py2.py3-none-any.whl (        55 kB)
                                npm ERR!      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 55.8/55.8 kB 767.0 kB/s eta 0:00:00
                                npm ERR! Collecting zeroconf==0.60.0 (from esphome>=2021.8)
                                npm ERR!   Downloading https://www.piwheels.org/simple/zeroconf/zeroconf-0.60.0-cp39-cp39-manylinux_2_31_armv7l.        whl (2.1 MB)
                                npm ERR!      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 2.1/2.1 MB 2.3 MB/s eta 0:00:00
                                npm ERR! Collecting kconfiglib==13.7.1 (from esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145 k        B)
                                npm ERR! Collecting pyparsing>=3.0 (from esphome>=2021.8)
                                npm ERR!   Downloading https://www.piwheels.org/simple/pyparsing/pyparsing-3.0.9-py3-none-any.whl (98 kB)
                                npm ERR!      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 98.3/98.3 kB 1.4 MB/s eta 0:00:00
                                npm ERR! Collecting protobuf>=3.19.0 (from aioesphomeapi==13.7.5->esphome>=2021.8)
                                npm ERR!   Downloading https://www.piwheels.org/simple/protobuf/protobuf-4.23.1-cp39-cp39-linux_armv7l.whl (946        kB)
                                npm ERR!      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 946.8/946.8 kB 2.2 MB/s eta 0:00:00
                                npm ERR! Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==13.7.5->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20 k        B)
                                npm ERR! Collecting async-timeout>=4.0 (from aioesphomeapi==13.7.5->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/async-timeout/async_timeout-4.0.2-py3-none-any.whl (5.8        kB)
                                npm ERR! Collecting bitstring>=3.1.6 (from esptool==4.5.1->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/bitstring/bitstring-4.0.2-py3-none-any.whl (46 kB)
                                npm ERR! Collecting cryptography>=2.1.4 (from esptool==4.5.1->esphome>=2021.8)
                                npm ERR!   Downloading cryptography-40.0.2.tar.gz (625 kB)
                                npm ERR!      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 625.6/625.6 kB 4.3 MB/s eta 0:00:00
                                npm ERR! Collecting ecdsa>=0.16.0 (from esptool==4.5.1->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)
                                npm ERR! Collecting reedsolo<=1.6.0,>=1.5.3 (from esptool==4.5.1->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/reedsolo/reedsolo-1.6.0-cp39-cp39-linux_armv7l.whl (897        kB)
                                npm ERR! Collecting bottle==0.12.* (from platformio==6.1.6->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/bottle/bottle-0.12.25-py3-none-any.whl (90 kB)
                                npm ERR! Collecting marshmallow==3.* (from platformio==6.1.6->esphome>=2021.8)
                                npm ERR!   Using cached marshmallow-3.19.0-py3-none-any.whl (49 kB)
                                npm ERR! Collecting pyelftools<1,>=0.27 (from platformio==6.1.6->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB)
                                npm ERR! Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==6.1.6-        >esphome>=2021.8) (2.25.1)
                                npm ERR! Collecting semantic-version==2.10.* (from platformio==6.1.6->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/semantic-version/semantic_version-2.10.0-py2.py3-none-an        y.whl (19 kB)
                                npm ERR! Collecting tabulate==0.9.* (from platformio==6.1.6->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/tabulate/tabulate-0.9.0-py3-none-any.whl (35 kB)
                                npm ERR! Collecting aiofiles==22.1.* (from platformio==6.1.6->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/aiofiles/aiofiles-22.1.0-py3-none-any.whl (14 kB)
                                npm ERR! Collecting ajsonrpc==1.* (from platformio==6.1.6->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)
                                npm ERR! Collecting starlette==0.23.* (from platformio==6.1.6->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/starlette/starlette-0.23.1-py3-none-any.whl (64 kB)
                                npm ERR! Collecting uvicorn==0.20.* (from platformio==6.1.6->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/uvicorn/uvicorn-0.20.0-py3-none-any.whl (56 kB)
                                npm ERR! Collecting wsproto==1.2.* (from platformio==6.1.6->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/wsproto/wsproto-1.2.0-py3-none-any.whl (24 kB)
                                npm ERR! Collecting ifaddr>=0.1.7 (from zeroconf==0.60.0->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)
                                npm ERR! Collecting packaging>=17.0 (from marshmallow==3.*->platformio==6.1.6->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)
                                npm ERR! Collecting anyio<5,>=3.4.0 (from starlette==0.23.*->platformio==6.1.6->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/anyio/anyio-3.6.2-py3-none-any.whl (80 kB)
                                npm ERR! Collecting typing-extensions>=3.10.0 (from starlette==0.23.*->platformio==6.1.6->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.6.0-py3-none-any.w        hl (30 kB)
                                npm ERR! Collecting h11>=0.8 (from uvicorn==0.20.*->platformio==6.1.6->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)
                                npm ERR! Collecting cffi>=1.12 (from cryptography>=2.1.4->esptool==4.5.1->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp39-cp39-linux_armv7l.whl (364 kB)
                                npm ERR! Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->esptoo        l==4.5.1->esphome>=2021.8) (1.16.0)
                                npm ERR! Requirement already satisfied: idna>=2.8 in /usr/lib/python3/dist-packages (from anyio<5,>=3.4.0->starl        ette==0.23.*->platformio==6.1.6->esphome>=2021.8) (2.10)
                                npm ERR! Collecting sniffio>=1.1 (from anyio<5,>=3.4.0->starlette==0.23.*->platformio==6.1.6->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)
                                npm ERR! Collecting pycparser (from cffi>=1.12->cryptography>=2.1.4->esptool==4.5.1->esphome>=2021.8)
                                npm ERR!   Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)
                                npm ERR! Building wheels for collected packages: tornado, cryptography
                                npm ERR!   Building wheel for tornado (pyproject.toml): started
                                npm ERR!   Building wheel for tornado (pyproject.toml): finished with status 'done'
                                npm ERR!   Created wheel for tornado: filename=tornado-6.3.1-cp38-abi3-linux_armv7l.whl size=425267 sha256=57bde        3e582b24effea2a558dbad1ac4dc572cc1a2523e9055efea2e1a40d5b68
                                npm ERR!   Stored in directory: /home/iobroker/.cache/pip/wheels/15/1c/af/c7e1f5553299005688622ce3717fb15558d6b7        0a7c36766ab3
                                npm ERR!   Building wheel for cryptography (pyproject.toml): started
                                npm ERR!   Building wheel for cryptography (pyproject.toml): finished with status 'error'
                                npm ERR! Successfully built tornado
                                npm ERR! Failed to build cryptography
                                npm ERR! npm WARN using --force Recommended protections disabled.
                                npm ERR! npm WARN old lockfile
                                npm ERR! npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                                npm ERR! npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                                npm ERR! npm WARN old lockfile This is a one-time fix-up, please be patient...
                                npm ERR! npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
                                npm ERR! npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                                npm ERR! npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                                npm ERR! npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecat        ed
                                npm ERR! npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to        chokidar 3 with 15x fewer dependencies
                                npm ERR! Cache entry deserialization failed, entry ignored
                                npm ERR!   error: subprocess-exited-with-error
                                npm ERR!
                                npm ERR!   × Building wheel for cryptography (pyproject.toml) did not run successfully.
                                npm ERR!   │ exit code: 1
                                npm ERR!   ╰─> [247 lines of output]
                                npm ERR!       running bdist_wheel
                                npm ERR!       running build
                                npm ERR!       running build_py
                                npm ERR!       creating build
                                npm ERR!       creating build/lib.linux-armv7l-cpython-39
                                npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography
                                npm ERR!       copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-39/cryptography
                                npm ERR!       copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-39/cryptography
                                npm ERR!       copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-39/cryptography
                                npm ERR!       copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-39/cryptography
                                npm ERR!       copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography
                                npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/x509
                                npm ERR!       copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-39/cryptography/x50        9
                                npm ERR!       copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-39/cr        yptography/x509
                                npm ERR!       copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
                                npm ERR!       copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
                                npm ERR!       copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
                                npm ERR!       copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
                                npm ERR!       copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-39/cryptography/x        509
                                npm ERR!       copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
                                npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat
                                npm ERR!       copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat
                                npm ERR!       copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/haz        mat
                                npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings
                                npm ERR!       copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptog        raphy/hazmat/bindings
                                npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends
                                npm ERR!       copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptog        raphy/hazmat/backends
                                npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
                                npm ERR!       copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-39/cr        yptography/hazmat/primitives
                                npm ERR!       copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-39        /cryptography/hazmat/primitives
                                npm ERR!       copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-39/crypt        ography/hazmat/primitives
                                npm ERR!       copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-39/cryptogra        phy/hazmat/primitives
                                npm ERR!       copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-39/cryptogra        phy/hazmat/primitives
                                npm ERR!       copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-39/crypto        graphy/hazmat/primitives
                                npm ERR!       copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-39/cryptog        raphy/hazmat/primitives
                                npm ERR!       copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-39/        cryptography/hazmat/primitives
                                npm ERR!       copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython-        39/cryptography/hazmat/primitives
                                npm ERR!       copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-39/crypto        graphy/hazmat/primitives
                                npm ERR!       copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-39/crypt        ography/hazmat/primitives
                                npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
                                npm ERR!       copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-39/        cryptography/hazmat/bindings/openssl
                                npm ERR!       copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpytho        n-39/cryptography/hazmat/bindings/openssl
                                npm ERR!       copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-39        /cryptography/hazmat/bindings/openssl
                                npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
                                npm ERR!       copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-39/cryp        tography/hazmat/backends/openssl
                                npm ERR!       copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-39/        cryptography/hazmat/backends/openssl
                                npm ERR!       copying src/cryptography/hazmat/backends/openssl/ed448.py -> build/lib.linux-armv7l-cpython-39/cr        yptography/hazmat/backends/openssl
                                npm ERR!       copying src/cryptography/hazmat/backends/openssl/poly1305.py -> build/lib.linux-armv7l-cpython-39        /cryptography/hazmat/backends/openssl
                                npm ERR!       copying src/cryptography/hazmat/backends/openssl/dh.py -> build/lib.linux-armv7l-cpython-39/crypt        ography/hazmat/backends/openssl
                                npm ERR!       copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-39/cry        ptography/hazmat/backends/openssl
                                npm ERR!       copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpython        -39/cryptography/hazmat/backends/openssl
                                npm ERR!       copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-armv7l-cpython-39/cry        ptography/hazmat/backends/openssl
                                npm ERR!       copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-39/crypt        ography/hazmat/backends/openssl
                                npm ERR!       copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-39/cry        ptography/hazmat/backends/openssl
                                npm ERR!       copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-39/cr        yptography/hazmat/backends/openssl
                                npm ERR!       copying src/cryptography/hazmat/backends/openssl/ed25519.py -> build/lib.linux-armv7l-cpython-39/        cryptography/hazmat/backends/openssl
                                npm ERR!       copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-armv7l-cpython-39/c        ryptography/hazmat/backends/openssl
                                npm ERR!       copying src/cryptography/hazmat/backends/openssl/x448.py -> build/lib.linux-armv7l-cpython-39/cry        ptography/hazmat/backends/openssl
                                npm ERR!       copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-armv7l-cpython-39/cryp        tography/hazmat/backends/openssl
                                npm ERR!       copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-39        /cryptography/hazmat/backends/openssl
                                npm ERR!       copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-39/        cryptography/hazmat/backends/openssl
                                npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
                                npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-39/        cryptography/hazmat/primitives/ciphers
                                npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-39/c        ryptography/hazmat/primitives/ciphers
                                npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-39/c        ryptography/hazmat/primitives/ciphers
                                npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython-        39/cryptography/hazmat/primitives/ciphers
                                npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpytho        n-39/cryptography/hazmat/primitives/ciphers
                                npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
                                npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-39        /cryptography/hazmat/primitives/asymmetric
                                npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython-        39/cryptography/hazmat/primitives/asymmetric
                                npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpython        -39/cryptography/hazmat/primitives/asymmetric
                                npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-39/        cryptography/hazmat/primitives/asymmetric
                                npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-cpython-39/        cryptography/hazmat/primitives/asymmetric
                                npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython-        39/cryptography/hazmat/primitives/asymmetric
                                npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-armv7l-cpytho        n-39/cryptography/hazmat/primitives/asymmetric
                                npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-3        9/cryptography/hazmat/primitives/asymmetric
                                npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-39        /cryptography/hazmat/primitives/asymmetric
                                npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-cpytho        n-39/cryptography/hazmat/primitives/asymmetric
                                npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython-        39/cryptography/hazmat/primitives/asymmetric
                                npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpyth        on-39/cryptography/hazmat/primitives/asymmetric
                                npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
                                npm ERR!       copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-39/cry        ptography/hazmat/primitives/kdf
                                npm ERR!       copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-39/cry        ptography/hazmat/primitives/kdf
                                npm ERR!       copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-39/crypt        ography/hazmat/primitives/kdf
                                npm ERR!       copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-39/        cryptography/hazmat/primitives/kdf
                                npm ERR!       copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-39/cr        yptography/hazmat/primitives/kdf
                                npm ERR!       copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-39/cryp        tography/hazmat/primitives/kdf
                                npm ERR!       copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-39/c        ryptography/hazmat/primitives/kdf
                                npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
                                npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-armv7l-cpyth        on-39/cryptography/hazmat/primitives/serialization
                                npm ERR!       copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-armv7l-cpytho        n-39/cryptography/hazmat/primitives/serialization
                                npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-armv7l-cpyt        hon-39/cryptography/hazmat/primitives/serialization
                                npm ERR!       copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-armv7l-cpython        -39/cryptography/hazmat/primitives/serialization
                                npm ERR!       copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-armv7l-cp        ython-39/cryptography/hazmat/primitives/serialization
                                npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
                                npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-cpython-39        /cryptography/hazmat/primitives/twofactor
                                npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-cpython-39        /cryptography/hazmat/primitives/twofactor
                                npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-armv7l-cpytho        n-39/cryptography/hazmat/primitives/twofactor
                                npm ERR!       running egg_info
                                npm ERR!       writing src/cryptography.egg-info/PKG-INFO
                                npm ERR!       writing dependency_links to src/cryptography.egg-info/dependency_links.txt
                                npm ERR!       writing requirements to src/cryptography.egg-info/requires.txt
                                npm ERR!       writing top-level names to src/cryptography.egg-info/top_level.txt
                                npm ERR!       reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
                                npm ERR!       reading manifest template 'MANIFEST.in'
                                npm ERR!       no previously-included directories found matching 'docs/_build'
                                npm ERR!       warning: no previously-included files found matching 'vectors'
                                npm ERR!       warning: no previously-included files matching '*' found under directory 'vectors'
                                npm ERR!       warning: no previously-included files matching '*' found under directory '.github'
                                npm ERR!       warning: no previously-included files found matching 'release.py'
                                npm ERR!       warning: no previously-included files found matching '.readthedocs.yml'
                                npm ERR!       warning: no previously-included files found matching 'ci-constraints-requirements.txt'
                                npm ERR!       warning: no previously-included files found matching 'mypy.ini'
                                npm ERR!       adding license file 'LICENSE'
                                npm ERR!       adding license file 'LICENSE.APACHE'
                                npm ERR!       adding license file 'LICENSE.BSD'
                                npm ERR!       adding license file 'LICENSE.PSF'
                                npm ERR!       writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
                                npm ERR!       /tmp/pip-build-env-wkvu8xbe/overlay/lib/python3.9/site-packages/setuptools/command/build_py.py:20        1: _Warning: Package 'cryptography.hazmat.bindings._rust' is absent from the `packages` configuration.
                                npm ERR!       !!
                                npm ERR!
                                npm ERR!               ********************************************************************************
                                npm ERR!               ############################
                                npm ERR!               # Package would be ignored #
                                npm ERR!               Python recognizes 'cryptography.hazmat.bindings._rust' as an importable package[^1],
                                npm ERR!               but it is absent from setuptools' `packages` configuration.
                                npm ERR!
                                npm ERR!               This leads to an ambiguous overall configuration. If you want to distribute this
                                npm ERR!               package, please make sure that 'cryptography.hazmat.bindings._rust' is explicitly added
                                npm ERR!               to the `packages` configuration field.
                                npm ERR!
                                npm ERR!               Alternatively, you can also rely on setuptools' discovery methods
                                npm ERR!               (for example by using `find_namespace_packages(...)`/`find_namespace:`
                                npm ERR!               instead of `find_packages(...)`/`find:`).
                                npm ERR!
                                npm ERR!               You can read more about "package discovery" on setuptools documentation page:
                                npm ERR!
                                npm ERR!               - https://setuptools.pypa.io/en/latest/userguide/package_discovery.html
                                npm ERR!
                                npm ERR!               If you don't want 'cryptography.hazmat.bindings._rust' to be distributed and are
                                npm ERR!               already explicitly excluding 'cryptography.hazmat.bindings._rust' via
                                npm ERR!               `find_namespace_packages(...)/find_namespace` or `find_packages(...)/find`,
                                npm ERR!               you can try to use `exclude_package_data`, or `include-package-data=False` in
                                npm ERR!               combination with a more fine grained `package-data` configuration.
                                npm ERR!
                                npm ERR!               You can read more about "package data files" on setuptools documentation page:
                                npm ERR!
                                npm ERR!               - https://setuptools.pypa.io/en/latest/userguide/datafiles.html
                                npm ERR!
                                npm ERR!
                                npm ERR!               [^1]: For Python, any directory (with suitable naming) can be imported,
                                npm ERR!                     even if it does not contain any `.py` files.
                                npm ERR!                     On the other hand, currently there is no concept of package data
                                npm ERR!                     directory, all directories are treated like packages.
                                npm ERR!
                                npm ERR!       !!
                                npm ERR!         check.warn(importable)
                                npm ERR!       /tmp/pip-build-env-wkvu8xbe/overlay/lib/python3.9/site-packages/setuptools/command/build_py.py:20        1: _Warning: Package 'cryptography.hazmat.bindings._rust.openssl' is absent from the `packages` configuration.
                                npm ERR!       !!
                                npm ERR!
                                npm ERR!               Python recognizes 'cryptography.hazmat.bindings._rust.openssl' as an importable package[^        1],
                                npm ERR!
                                npm ERR!               package, please make sure that 'cryptography.hazmat.bindings._rust.openssl' is explicitly        added
                                npm ERR!
                                npm ERR!
                                npm ERR!
                                npm ERR!
                                npm ERR!               If you don't want 'cryptography.hazmat.bindings._rust.openssl' to be distributed and are
                                npm ERR!               already explicitly excluding 'cryptography.hazmat.bindings._rust.openssl' via
                                npm ERR!
                                npm ERR!
                                npm ERR!
                                npm ERR!
                                npm ERR!
                                npm ERR!       !!
                                npm ERR!       copying src/cryptography/py.typed -> build/lib.linux-armv7l-cpython-39/cryptography
                                npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
                                npm ERR!       copying src/cryptography/hazmat/bindings/_rust/__init__.pyi -> build/lib.linux-armv7l-cpython-39/        cryptography/hazmat/bindings/_rust
                                npm ERR!       copying src/cryptography/hazmat/bindings/_rust/_openssl.pyi -> build/lib.linux-armv7l-cpython-39/        cryptography/hazmat/bindings/_rust
                                npm ERR!       copying src/cryptography/hazmat/bindings/_rust/asn1.pyi -> build/lib.linux-armv7l-cpython-39/cryp        tography/hazmat/bindings/_rust
                                npm ERR!       copying src/cryptography/hazmat/bindings/_rust/ocsp.pyi -> build/lib.linux-armv7l-cpython-39/cryp        tography/hazmat/bindings/_rust
                                npm ERR!       copying src/cryptography/hazmat/bindings/_rust/pkcs7.pyi -> build/lib.linux-armv7l-cpython-39/cry        ptography/hazmat/bindings/_rust
                                npm ERR!       copying src/cryptography/hazmat/bindings/_rust/x509.pyi -> build/lib.linux-armv7l-cpython-39/cryp        tography/hazmat/bindings/_rust
                                npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
                                npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/__init__.pyi -> build/lib.linux-armv7l-cpy        thon-39/cryptography/hazmat/bindings/_rust/openssl
                                npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/x25519.pyi -> build/lib.linux-armv7l-cpyth        on-39/cryptography/hazmat/bindings/_rust/openssl
                                npm ERR!       running build_ext
                                npm ERR!       running build_rust
                                npm ERR!
                                npm ERR!           =============================DEBUG ASSISTANCE=============================
                                npm ERR!           If you are seeing a compilation error please try the following steps to
                                npm ERR!           successfully install cryptography:
                                npm ERR!           1) Upgrade to the latest pip and try again. This will fix errors for most
                                npm ERR!              users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
                                npm ERR!           2) Read https://cryptography.io/en/latest/installation/ for specific
                                npm ERR!              instructions for your platform.
                                npm ERR!           3) Check our frequently asked questions for more information:
                                npm ERR!              https://cryptography.io/en/latest/faq/
                                npm ERR!           4) Ensure you have a recent Rust toolchain installed:
                                npm ERR!              https://cryptography.io/en/latest/installation/#rust
                                npm ERR!
                                npm ERR!           Python: 3.9.2
                                npm ERR!           platform: Linux-6.1.21-v7l+-armv7l-with-glibc2.31
                                npm ERR!           pip: n/a
                                npm ERR!           setuptools: 67.8.0
                                npm ERR!           setuptools_rust: 1.6.0
                                npm ERR!           rustc: n/a
                                npm ERR!
                                npm ERR!       error: can't find Rust compiler
                                npm ERR!
                                npm ERR!       If you are using an outdated pip version, it is possible a prebuilt wheel is available for this p        ackage but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compile        r.
                                npm ERR!
                                npm ERR!       To update pip, run:
                                npm ERR!
                                npm ERR!           pip install --upgrade pip
                                npm ERR!
                                npm ERR!       and then retry package installation.
                                npm ERR!
                                npm ERR!       If you did intend to build this package from source, try installing a Rust compiler from your sys        tem package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https:        //rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
                                npm ERR!
                                npm ERR!       This package requires Rust >=1.48.0.
                                npm ERR!       [end of output]
                                npm ERR!
                                npm ERR!   note: This error originates from a subprocess, and is likely not a problem with pip.
                                npm ERR!   ERROR: Failed building wheel for cryptography
                                npm ERR! ERROR: Could not build wheels for cryptography, which is required to install pyproject.toml-based proje        cts
                                npm ERR! npm notice
                                npm ERR! npm notice New minor version of npm available! 9.5.0 -> 9.6.7
                                npm ERR! npm notice Changelog: <https://github.com/npm/cli/releases/tag/v9.6.7>
                                npm ERR! npm notice Run `npm install -g npm@9.6.7` to update!
                                npm ERR! npm notice
                                npm ERR! npm ERR! code 1
                                npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-cloneeEUtdf
                                npm ERR! npm ERR! command failed
                                npm ERR! npm ERR! command sh -c npip install
                                npm ERR!
                                npm ERR! npm ERR! A complete log of this run can be found in:
                                npm ERR! npm ERR!     /home/iobroker/.npm/_logs/2023-05-23T19_37_21_129Z-debug-0.log
                                npm ERR!     /home/iobroker/.npm/_logs/2023-05-23T19_32_12_042Z-debug-0.log
                                maxpd
                                Thomas BraunT David G.D 2 Antworten Letzte Antwort
                                • M maxpd
                                  npm ERR! code 1
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!       !!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!       !!
                                  npm ERR!       !!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!       !!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!           pip: n/a
                                  npm ERR!           rustc: n/a
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR! npm notice
                                  npm ERR! npm notice
                                  npm ERR!
                                  Warum nicht? Fragst du ernsthaft in diesem Thread? Weil es zu Problemen führt.
                                    maxpd
                                    schrieb am zuletzt editiert von maxpd
                                    Das die Power nicht ausreicht, habe ich verstanden. War ja eine Notlösung, damit iobroker weiterläuft. Hatte nicht mehr dran gedacht. War auch der Meinung der Pi zieht 6W und das Netzteil liefert 10W. Hat auch funktioniert. Das er gedrosselt läuft war mir nicht bewusst. Es liest sich nur nach einem sehr generischen Verbot.
                                    maxpd
                                    • M maxpd
                                      Ladegeräte haben nicht (unbedingt) eine dauerhaft stabile Versorgung.
                                      Ist für diese Aufgabe ja auch nicht notwendig, für den Pi schon!
                                      • M maxpd
                                        @maxpd
                                        Da hängt auch noch ein Compile in den Seilen.
                                        benötigt ein sehr aktuelles und konsistentes Python3.
                                        Insbesondere halt aktuelle Version von pip inkl rust compiler.
                                        Da kann ich dir aber nur bedingt helfen, bei mir baut der esphome eigentlich ohne Probleme, ich fahre aber auch ein Debian Testing hier.
                                          @maxpd
                                          maxpd
                                          Habe nun ein 5V 3.5 A Netzteil mit einem Metallgehäuse, welches als Kühlkörper fungiert.
                                          Das System ist 10° Kühler und läuft wieder schneller.
                                          SSD und Zigbee hängen nun an USB Hub mit externer Stromversorgung.
                                          maxpd
