  4. Datenbank läuft nicht
    5.4k
20 Beiträge 4 Kommentatoren 1.2k Aufrufe 3 Beobachtet
  • B Biber
    Sorry, ich dachte die Farben bei den Log-Leveln kommen dann besser heraus :-)
    2023-05-10 12:54:47.562  - info: host.pirage iobroker _restart
    2023-05-10 12:54:48.327  - info: host.pirage connected to Objects and States
    2023-05-10 12:54:48.486  - info: host.pirage added notifications configuration of host
    2023-05-10 12:54:56.777  - info: host.pirage iobroker.js-controller version 4.0.23 js-controller starting
    2023-05-10 12:54:56.802  - info: host.pirage Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-05-10 12:54:56.805  - info: host.pirage hostname: pirage, node: v18.2.0
    2023-05-10 12:54:56.809  - info: host.pirage ip addresses: 10.0.0.3 2a00:6020:401b:a00:168:b7b9:705b:9461 fe80::49ee:4545:74f4:27a1
    2023-05-10 12:55:26.654  - info: host.pirage connected to Objects and States
    2023-05-10 12:55:26.824  - info: host.pirage added notifications configuration of host
    2023-05-10 12:55:28.381  - info: host.pirage 13 instances found
    2023-05-10 12:55:28.494  - info: host.pirage starting 10 instances
    2023-05-10 12:55:28.513  - warn: host.pirage startInstance cannot find adapter "telegram@1.15.2". Try to install it... 1 attempt
    2023-05-10 12:55:28.516  - info: host.pirage iobroker install telegram@1.15.2 using installedFrom
    2023-05-10 12:55:28.943  - info: host.pirage instance system.adapter.admin.0 started with pid 4809
    2023-05-10 12:55:38.930  - info: admin.0 (4809) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.2.0, js-controller: 4.0.23
    2023-05-10 12:55:39.131  - info: admin.0 (4809) requesting all states
    2023-05-10 12:55:39.134  - info: admin.0 (4809) requesting all objects
    2023-05-10 12:55:43.227  - info: admin.0 (4809) received all objects
    2023-05-10 12:55:43.424  - info: host.pirage iobroker npm-install: NPM version: 8.9.0
    2023-05-10 12:55:43.470  - info: host.pirage iobroker npm-install: Installing iobroker.telegram@1.15.2... (System call)
    2023-05-10 12:55:44.483  - info: admin.0 (4809) Request actual repository...
    2023-05-10 12:55:44.615  - info: admin.0 (4809) http server listening on port 8081
    2023-05-10 12:55:44.619  - info: admin.0 (4809) Use link "http://localhost:8081" to configure.
    2023-05-10 12:55:44.678  - info: admin.0 (4809) socket.io server listening on port 8081
    2023-05-10 12:55:45.177  - info: host.pirage instance system.adapter.discovery.0 started with pid 4862
    2023-05-10 12:55:47.466  - info: host.pirage Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-05-10 12:55:54.763  - error: admin.0 (4809) States database error: read ECONNRESET
    2023-05-10 12:55:54.796  - info: admin.0 (4809) terminating http server on port 8081
    2023-05-10 12:55:55.282  - info: discovery.0 (4862) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-05-10 12:55:56.312  - info: admin.0 (4809) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-05-10 12:55:59.805  - warn: admin.0 (4809) get state error: Connection is closed.
    2023-05-10 12:55:59.809  - warn: admin.0 (4809) get state error: DB closed
    2023-05-10 12:55:59.818  - warn: admin.0 (4809) get state error: DB closed
    2023-05-10 12:55:59.820  - warn: admin.0 (4809) get state error: DB closed
    2023-05-10 12:55:59.822  - warn: admin.0 (4809) get state error: DB closed
    2023-05-10 12:55:59.823  - warn: admin.0 (4809) get state error: DB closed
    2023-05-10 12:55:59.824  - warn: admin.0 (4809) get state error: DB closed
    2023-05-10 12:55:59.825  - warn: admin.0 (4809) get state error: DB closed
    2023-05-10 12:55:59.826  - warn: admin.0 (4809) get state error: DB closed
    2023-05-10 12:55:59.829  - warn: admin.0 (4809) get state error: DB closed
    2023-05-10 12:55:59.830  - warn: admin.0 (4809) get state error: DB closed
    2023-05-10 12:55:59.831  - warn: admin.0 (4809) get state error: DB closed
    2023-05-10 12:55:59.832  - warn: admin.0 (4809) get state error: DB closed
    2023-05-10 12:56:07.898  - info: host.pirage iobroker.js-controller version 4.0.23 js-controller starting
    2023-05-10 12:56:07.922  - info: host.pirage Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-05-10 12:56:07.926  - info: host.pirage hostname: pirage, node: v18.2.0
    2023-05-10 12:56:07.930  - info: host.pirage ip addresses: 10.0.0.3 2a00:6020:401b:a00:168:b7b9:705b:9461 fe80::49ee:4545:74f4:27a1
    2023-05-10 12:56:38.012  - error: host.pirage No connection to databases possible, restart
    Biber
    Ui, das sieht ja noch besser aus!
    • B Biber
      @biber
      Da scheint mir auch noch mehr krumm zu sein.
      iob stop
      iob fix
      iob start
      Und dann die Ausgabe von
      iob diag
      in der Langform posten.
        @biber
        iob stop
        iob fix
        iob start
        iob diag
        Biber
        Cool, danke. Läuft wieder.
        Aber nur zur Info:
        Gestern abend habe ich das (iob fix) schon einmal gemacht, das hat aber nicht funktioniert, es gab irgendwelche Fehler bei der states.jsonl. Ich habe die gelöscht und die wurde dann neu (aber leer) erstellt. Dann habe ich den Inhalt der alten states.jsonl an die neu erstelle, leere angehängt.
        Danach scheint der Fix zu funktionieren.
        • B Biber
          Aber nur zur Info:
          @biber sagte in Datenbank läuft nicht:
          und dann winderst du dich dass iob darauf nicht zugreifen kann?
          • B Biber
            Aber nur zur Info:
            Du darfst dennoch die Ausgabe von iob diag bekannt geben, da dürften noch ein paar Kinken vorhanden sein, wage ich mal zu prognostizieren.
              Biber
              Das ging ja vorher nicht,....obwohl die Datei da war
              • B Biber
                da ist natürlich eine Fehlerbeschreibung wie
                nicht gerade hilfreich.
                Möglicherweise hast du einiges zerschossen, deswegen ist der Aufruf von @Thomas-Braun gut zu verstehen, dass du wenigstens jetzt mal ausführlichere Informationen bereitstellst
                  Biber
                  Hier das Summary von "iob diag"
                                       v.2023-04-16
                  Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
                  Kernel:                 5.15.32-v7+
                  Installation:           Native
                  User-ID:                0
                  X-Server:               true
                  Pending OS-Updates:     305
                  Pending iob updates:    4
                  Nodejs-Installation:    /usr/bin/nodejs         v18.2.0
                                          /usr/bin/node           v18.2.0
                                          /usr/bin/npm            8.9.0
                                          /usr/bin/npx            8.9.0
                  Recommended versions are nodejs 18.x.y and npm 9.x.y
                  MEMORY:
                  Mem:            923M        467M         50M        0.0K        404M        391M
                  Swap:            99M         99M          0B
                  Total:          1.0G        567M         50M
                  Active iob-Instances:   4
                  Active repo(s): stable
                  ioBroker Core:          js-controller           4.0.23
                                          admin                   6.3.5
                  Objects type: jsonl
                  States  type: jsonl
                  + system.adapter.admin.0                  : admin                 : pirage                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    system.adapter.web.0                    : web                   : pirage                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  Objects:                2658
                  States:                 2755
                  Size of iob-Database:
                  7.5M    /opt/iobroker/iobroker-data/objects.jsonl
                  696K    /opt/iobroker/iobroker-data/states.jsonl
                  592K    /opt/iobroker/iobroker-data/_states.jsonl
                  4.0K    /opt/iobroker/iobroker-data/states.json.migrated
                  4.0K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                  Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                  • B Biber
                                         v.2023-04-16
                    Kernel:                 5.15.32-v7+
                    User-ID:                0
                    X-Server:               true
                                            /usr/bin/npm            8.9.0
                                            /usr/bin/npx            8.9.0
                    MEMORY:
                    Swap:            99M         99M          0B
                                            admin                   6.3.5
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                2658
                    States:                 2755
                    @biber
                    Wie vermutet...
                    X-Server: true
                    Boot Target: graphical.target
                    Auf einem Server läuft kein X/Desktop.
                    Gerade mit mageren 1GB Ram nicht.
                    Schalt das aus.
                    So ab und an sollte man das System auch mal pflegen. Ich glaube mit 300 verpassten Updates bist du der bisherige Spitzenreiter. Pack das an!
                    Und man hampelt auch nicht als root durch das System. Log dich als user ein, nicht als root!
                      @biber
                      Wie vermutet...
                      X-Server: true
                      Schalt das aus.
                      Biber
                      @thomas-braun said in Datenbank läuft nicht:
                      @biber
                      Wie vermutet...
                      X-Server: true
                      Schalt das aus.
                      Jau, werde den runlevel ändern, aber das hat m. W. nichts mit dem iob-Fehler zu tun.
                      X braucht nur ein wenig Speicher, davon hatte ich vor iobroker genug :-)
                      Hatte ich gar nicht mehr auf dem Schirm...
                      Naja, ich habe alle verpasst, habe noch nie eins ausgeführt.
                      Auf dem Rpi läuft nur eine selbst gebaute Tor/Garagentorsteuerung mit Nodejs,... habe es nicht als wichtig angesehen...
                      Das mache ich seit 30 Jahren, und werde ich auch nicht ändern... ich finde es zu gefährlich als user zu arbeiten, mit vielen sudos in der history....
                      Danke für die Hilfe!
                      • B Biber
                        @biber
                        Wie vermutet...
                        X-Server: true
                        Schalt das aus.
                        dann vergiss iobroker!
                        du verbiegst damit die Rechte und der Systemuser iobroker kann möglicherweise nicht mehr auf alles notwendige zugreifen
                        • B Biber
                          @biber
                          Wie vermutet...
                          X-Server: true
                          Schalt das aus.
                          Nee, das ist ein grundsätzlicher Fehler.
                          Nein, dein Speicher geht dir aus. Siehe SWAP mit 100%.
                          Falsche Ansicht.
                          Äh, nee, ist klar... Gerade mit dem root-Login baust du dir tendenziell genau solche Probleme:
                          • B Biber
                                                 v.2023-04-16
                            Kernel:                 5.15.32-v7+
                            User-ID:                0
                            X-Server:               true
                                                    /usr/bin/npm            8.9.0
                                                    /usr/bin/npx            8.9.0
                            MEMORY:
                            Swap:            99M         99M          0B
                                                    admin                   6.3.5
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                2658
                            States:                 2755
                            GlasfaserG Offline
                            GlasfaserG Offline
                            /usr/bin/npm 8.9.0
                            /usr/bin/npx 8.9.0
                            Wie kommst du an diese alte Versionen , würde ich mal auf aktuellen Stand bringen !?
                            • GlasfaserG Glasfaser
                              /usr/bin/npm 8.9.0
                              /usr/bin/npx 8.9.0
                              @glasfaser
                              Halt noch nie Updates ausgeführt:
                                @glasfaser
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Jipp , gerade gelesen ... Schmunzel ... 🙄
                                  Biber
                                  schrieb am zuletzt editiert von Biber
                                  Ja, habs ja kapiert, besser?
                                                       v.2023-04-16
                                  Kernel:                 6.1.21-v7+
                                  User-ID:                0
                                  X-Server:               false
                                  Boot Target:            multi-user.target
                                  Pending OS-Updates:     0
                                  Pending iob updates:    0
                                  Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                                                          /usr/bin/node           v18.16.0
                                                          /usr/bin/npm            9.5.1
                                                          /usr/bin/npx            9.5.1
                                  MEMORY:
                                  Mem:            921M        414M        157M        1.0M        350M        446M
                                  Swap:            99M        1.0M         98M
                                  Total:          1.0G        415M        256M
                                  Active iob-Instances:   9
                                  ioBroker Core:          js-controller           4.0.24
                                                          admin                   6.3.5
                                  Objects type: jsonl
                                  States  type: jsonl
                                  + system.adapter.web.0                    : web                   : pirage                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  Objects:                2716
                                  States:                 2806
                                  12M     /opt/iobroker/iobroker-data/objects.jsonl
                                  3.7M    /opt/iobroker/iobroker-data/states.jsonl
                                  Aber immer die neueste Version haben zu müssen ist auch nicht immer optimal. Ich habe das letzte Update unserer 3cx-Telefonalage glücklicherweise noch nicht eingespielt, sonst hätte ich arge Probleme bekommen, Stichwort "3CX sideloading".
                                  Als root-Benutzer bin ich nur unterwegs, wenn ich etwas zu administrieren habe, ansonsten natürlich als normaler Benutzer.....
                                  • B Biber
                                                         v.2023-04-16
                                    Kernel:                 6.1.21-v7+
                                    User-ID:                0
                                    X-Server:               false
                                                            /usr/bin/npm            9.5.1
                                                            /usr/bin/npx            9.5.1
                                    MEMORY:
                                    Swap:            99M        1.0M         98M
                                                            admin                   6.3.5
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects:                2716
                                    States:                 2806
                                    @biber
                                    Und was hast du gerade beim Aufruf des Skripts zu administrieren gehabt? iob_diag wird als User aufgerufen, nicht als root.
                                    Meld dich einfach als stinknormalen User für die alltäglichen Dinge an, den iobroker kannste z.B. komplett ohne root-Rechte verwalten. Und NUR bei den Befehlen die unbedingt root-Rechte erfordern setzt du halt ein 'sudo' davor und fällst dann sofort wieder in die user-Rolle zurück. So verfummelst du auch nicht so leicht das System.
                                    So wird das auch schon seit Jahrzehnten praktiziert, eine root Shell ist ein Ding aus dem letzten Jahrtausend. Gewöhn dir den Quatsch ab.
