  4. InfluxDB 2.7 Totalabsturz - BackItUp mit Fehler
    5.4k
28 Beiträge 5 Kommentatoren 3.3k Aufrufe 4 Beobachtet
  • Marc BergM Marc Berg
    @akuhnsh sagte in InfluxDB 2.7 Totalabsturz - BackItUp mit Fehler:
    @marc-berg @thomas-braun
    @akuhnsh said in InfluxDB 2.7 Totalabsturz - BackItUp mit Fehler:
    Ich habe das System neu aufgesetzt, um zu sehen, ob sich die Backups dann einspielen lassen und nach wie vor keine Chance die Datenbank aus dem Backup wiederherzustellen:
    [ERROR] [influxDB] - Error: failed to check existence of organization "privat": 401 Unauthorized: unauthorized access
    zeig mal bitte die Ausgabe von
    influx auth list --json
    und
    influx organization list
    akuhnshA Offline
    akuhnshA Offline
    akuhnsh
    @marc-berg said in InfluxDB 2.7 Totalabsturz - BackItUp mit Fehler:
    		"id": "0b28411ba4dca000",
    		"description": "admin's Token",
    		"token": "wljQN6vtZ1a4hNNORVh55RM2u0o1V3XXh708y7yKPmtdBIV5tG5hxucGRGnBX1IdQoYh9Mnd5dsbBBV551nDUw==",
    		"status": "active",
    		"userName": "admin",
    		"userID": "0b28411b6b9ca000",
    		"permissions": [
    			"read:/authorizations",
    			"write:/authorizations",
    			"read:/buckets",
    			"write:/buckets",
    			"read:/dashboards",
    			"write:/dashboards",
    			"read:/orgs",
    			"write:/orgs",
    			"read:/sources",
    			"write:/sources",
    			"read:/tasks",
    			"write:/tasks",
    			"read:/telegrafs",
    			"write:/telegrafs",
    			"read:/users",
    			"write:/users",
    			"read:/variables",
    			"write:/variables",
    			"read:/scrapers",
    			"write:/scrapers",
    			"read:/secrets",
    			"write:/secrets",
    			"read:/labels",
    			"write:/labels",
    			"read:/views",
    			"write:/views",
    			"read:/documents",
    			"write:/documents",
    			"read:/notificationRules",
    			"write:/notificationRules",
    			"read:/notificationEndpoints",
    			"write:/notificationEndpoints",
    			"read:/checks",
    			"write:/checks",
    			"read:/dbrp",
    			"write:/dbrp",
    			"read:/notebooks",
    			"write:/notebooks",
    			"read:/annotations",
    			"write:/annotations",
    			"read:/remotes",
    			"write:/remotes",
    			"read:/replications",
    			"write:/replications"
    		"id": "0b2852f1fbdca000",
    		"description": "admin's Token (cloned at 2023-05-06 13:44:19)",
    		"token": "uZKGetlcGZSZbteI1gwpkJwsCIHpj0bI5ZLdRTvEuDqds7B9X04Q8LKhPYQArrWRJ3nnQS3xfQcwDkwhOKKoCw==",
    		"status": "active",
    		"permissions": [
    			"read:/buckets",
    			"write:/buckets",
    			"read:/dashboards",
    			"read:/orgs",
    			"write:/orgs",
    			"read:/sources",
    			"write:/sources",
    			"read:/tasks",
    			"write:/tasks",
    			"read:/telegrafs",
    			"write:/telegrafs",
    			"read:/users",
    			"write:/users",
    			"read:/variables",
    			"write:/variables",
    			"read:/scrapers",
    			"write:/scrapers",
    			"read:/secrets",
    			"write:/secrets",
    			"read:/labels",
    			"write:/labels",
    			"read:/views",
    			"write:/views",
    			"read:/documents",
    			"write:/documents",
    			"read:/checks",
    			"write:/checks",
    			"read:/dbrp",
    			"write:/dbrp",
    			"read:/notebooks",
    			"write:/notebooks",
    			"read:/remotes",
    			"write:/remotes",
    und
    ID			Name
    2ecf2d695d1722e9	privat
    akuhnshA 1 Antwort Letzte Antwort
    • akuhnshA akuhnsh
      		"status": "active",
      		"permissions": [
      			"read:/buckets",
      			"write:/buckets",
      			"read:/dashboards",
      			"read:/orgs",
      			"write:/orgs",
      			"read:/sources",
      			"write:/sources",
      			"read:/tasks",
      			"write:/tasks",
      			"read:/telegrafs",
      			"write:/telegrafs",
      			"read:/users",
      			"write:/users",
      			"read:/variables",
      			"write:/variables",
      			"read:/scrapers",
      			"write:/scrapers",
      			"read:/secrets",
      			"write:/secrets",
      			"read:/labels",
      			"write:/labels",
      			"read:/views",
      			"write:/views",
      			"read:/documents",
      			"write:/documents",
      			"read:/checks",
      			"write:/checks",
      			"read:/dbrp",
      			"write:/dbrp",
      			"read:/notebooks",
      			"write:/notebooks",
      			"read:/remotes",
      			"write:/remotes",
      		"status": "active",
      		"permissions": [
      			"read:/buckets",
      			"write:/buckets",
      			"read:/dashboards",
      			"read:/orgs",
      			"write:/orgs",
      			"read:/sources",
      			"write:/sources",
      			"read:/tasks",
      			"write:/tasks",
      			"read:/telegrafs",
      			"write:/telegrafs",
      			"read:/users",
      			"write:/users",
      			"read:/variables",
      			"write:/variables",
      			"read:/scrapers",
      			"write:/scrapers",
      			"read:/secrets",
      			"write:/secrets",
      			"read:/labels",
      			"write:/labels",
      			"read:/views",
      			"write:/views",
      			"read:/documents",
      			"write:/documents",
      			"read:/checks",
      			"write:/checks",
      			"read:/dbrp",
      			"write:/dbrp",
      			"read:/notebooks",
      			"write:/notebooks",
      			"read:/remotes",
      			"write:/remotes",
      und
      ID			Name
      akuhnshA Offline
      akuhnshA Offline
      akuhnsh
      @Marc-Berg @Thomas-Braun
      An die alten Tokens aus dem Backup komme ich über die *.bolt Datei ran:
      influxd recovery auth list --bolt-path /opt/iobroker/backups/20230503T213019Z.bolt
      2023-05-06T14:09:35.271809Z	info	Resources opened	{"log_id": "0hdMBf9l000", "system": "bolt-kvstore", "path": "/opt/iobroker/backups/20230503T213019Z.bolt"}
      ID			User Name	User ID			Description						Token							Permissions
      0ab87d8e68295000	admin		0ab87d8e29e95000	admin's Token						lGhesEEm7Osc8iF3Atk0ukEZhEOLdg98AQXojtHwao1MrEOYiv0uaa3BrxS-QXp3T54dXJgDECIu7zuByns0Ug==	[read:authorizations write:authorizations read:buckets write:buckets read:dashboards write:dashboards read:orgs write:orgs read:sources write:sources read:tasks write:tasks read:telegrafs write:telegrafs read:users write:users read:variables write:variables read:scrapers write:scrapers read:secrets write:secrets read:labels write:labels read:views write:views read:documents write:documents read:notificationRules write:notificationRules read:notificationEndpoints write:notificationEndpoints read:checks write:checks read:dbrp write:dbrp read:notebooks write:notebooks read:annotations write:annotations read:remotes write:remotes read:replications write:replications]
      0b07e2e2b57cb000	admin		0ab87d8e29e95000	admin's Token (cloned at 2023-04-11 09:03:19)		06eJGdVPZPMsCad0sRvWS32YvB-F3Fifn3nTCM0oNBzDaY5I7Q0n-St-82r9vj1dZRnOONeIiWmTFDYIZoe3Gg==	[read:authorizations write:authorizations read:buckets write:buckets read:dashboards write:dashboards read:orgs write:orgs read:sources write:sources read:tasks write:tasks read:telegrafs write:telegrafs read:users write:users read:variables write:variables read:scrapers write:scrapers read:secrets write:secrets read:labels write:labels read:views write:views read:documents write:documents read:notificationRules write:notificationRules read:notificationEndpoints write:notificationEndpoints read:checks write:checks read:dbrp write:dbrp read:notebooks write:notebooks read:annotations write:annotations read:remotes write:remotes read:replications write:replications]
      0b07e9d2857cb000	admin		0ab87d8e29e95000	admin's Token BackItUp (cloned at 2023-04-11 09:33:38)	Tvm2bJ9-WsIoyNowWCasjc2ukqsFTIj3xQjp_q_1U-sPb6sH21n35nUzV99EOJ3JE2vLKKwCPIrN8jtT4xcT4A==	[read:authorizations write:authorizations read:buckets write:buckets read:dashboards write:dashboards read:orgs write:orgs read:sources write:sources read:tasks write:tasks read:telegrafs write:telegrafs read:users write:users read:variables write:variables read:scrapers write:scrapers read:secrets write:secrets read:labels write:labels read:views write:views read:documents write:documents read:notificationRules write:notificationRules read:notificationEndpoints write:notificationEndpoints read:checks write:checks read:dbrp write:dbrp read:notebooks write:notebooks read:annotations write:annotations read:remotes write:remotes read:replications write:replications]
      0b07f463437cb000	admin		0ab87d8e29e95000	admin's Token Grafana (cloned at 2023-04-11 10:19:47)	AQLf8Jld1fY0LYd3Cs0Pt4hKtzMbXK0t0_kMdh6eXzBxHiPJWR1t5OYHr7Qvx4-4zf1Q4ETOfII5W1oNCKvR5w==	[read:authorizations write:authorizations read:buckets write:buckets read:dashboards write:dashboards read:orgs write:orgs read:sources write:sources read:tasks write:tasks read:telegrafs write:telegrafs read:users write:users read:variables write:variables read:scrapers write:scrapers read:secrets write:secrets read:labels write:labels read:views write:views read:documents write:documents read:notificationRules write:notificationRules read:notificationEndpoints write:notificationEndpoints read:checks write:checks read:dbrp write:dbrp read:notebooks write:notebooks read:annotations write:annotations read:remotes write:remotes read:replications write:replications]
      Aber wie soll ich über das GUI einen alten Token rekonstruieren?
      • akuhnshA akuhnsh
        Marc BergM Offline
        Marc BergM Offline
        Marc Berg
        Das würde nur Sinn ergeben, wenn die alte Datenbank noch vorhanden ist. Hast du bei der Neuinstallation die Datenverzeichnisse gelöscht? Nicht, dass da noch Überbleibsel stören.
          akuhnshA Offline
          akuhnshA Offline
          akuhnsh
          Die alten token sind halt im Backup hinterlegt. Wenn die abgefragt werden, passen sie halt nicht zum neuen admin token. Deshalb dachte ich an die Rolle Rückwärts. Erst die alten token wieder herstellen in der neuen influxdb und dann das Backup mit denselben token wieder herstellen. Denke da liegt der Hase im Pfeffer.
          Hab ein frisches Image auf die SD geschrieben und iobroker, influxdb und grafana neu installiert, wie sonst auch schon mal. Da sollte alles überschrieben worden sein.
          • akuhnshA akuhnsh
            Marc BergM Offline
            Marc BergM Offline
            Marc Berg
            nein. Du brauchst nach einer Neuinstallation für das Restore die neuen Token.
            akuhnshA 2 Antworten Letzte Antwort
              akuhnshA Offline
              akuhnshA Offline
              akuhnsh
              @marc-berg
              Okay verstanden. Vielleicht liegt es daran, dass das Backup aus einem Upgrade von 1.8 auf 2.7 stammt? Ich bekomme eine ähnliche Fehlermeldung, wenn ich in dem Reiter bei "Sicherung mehrerer Systeme" raus nehme und nur den einen bucket angebe, der auch zur Wiederherstellung ausgewählt wird:
              Started restore ...
              [DEBUG] [influxDB] - Created tmp directory
              [DEBUG] [influxDB] - Start infuxDB Restore ...
              [ERROR] [influxDB] - 2023/05/06 16:49:17 INFO: Restoring bucket "0db467ecf59e0de1" as "iobroker"
              Error: failed to restore bucket "iobroker": 401 Unauthorized: read:authorizations is unauthorized
              [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
              [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
              [DEBUG] [influxDB] - infuxDB Restore completed successfully
              [EXIT] influxDB restore done
              Muss der neue token noch irgendwo anders eingetragen werden als unter dem Reiter influxdb in BackItUp?
                akuhnshA Offline
                akuhnshA Offline
                akuhnsh
                @marc-berg
                Wenn ich den bucket vorher anlege kommt folgende Meldung:
                Started restore ...
                [ERROR] [influxDB] - 2023/05/06 16:52:54 INFO: Restoring bucket "0db467ecf59e0de1" as "iobroker"
                Error: failed to restore bucket "iobroker": 422 Unprocessable Entity: bucket with name iobroker already exists
                • akuhnshA akuhnsh
                  @marc-berg
                  Started restore ...
                  Marc BergM Offline
                  Marc BergM Offline
                  Marc Berg
                  Das verstehe ich nicht. Das Backup wurde doch aber nach dem Upgrade aus der 2.7 gezogen, oder?
                  Ganz sicher, dass der Token, der auch über "influx auth list" sichtbar ist, korrekt und ohne Leerzeichen im Backitip-Adapter eingetragen ist? An eine andere Stelle muss der für den reinen Rstore nicht eingetragen werden.
                    akuhnshA Offline
                    akuhnshA Offline
                    akuhnsh
                    Das ist jetzt neu. Funktionierte doch vorhin noch einwandfrei...
                    pi@raspberrypi:~ $ influx auth list --json
                    Error: could not find authorization with given parameters: 401 Unauthorized: unauthorized access
                    • akuhnshA akuhnsh
                      Marc BergM Offline
                      Marc BergM Offline
                      Marc Berg
                      Ja, was soll man dazu noch sagen? Ein System, welches sich mehrfach "von selbst" vergisst ...
                      Ist das noch die selbe SD Card?
                        akuhnshA Offline
                        akuhnshA Offline
                        akuhnsh
                        Genau um den Punkt drehten sich die Überlegungen die letzten Tage und ich habe eine Lösung gefunden. Die alte SD-Karte habe ich zwar auf Herz und Nieren geprüft und keine defekten Sektoren gefunden, aber die Wiederherstellung auf dieser Karte funktionierte für die InfluxDB 2 nicht mehr. Dann habe ich die Wiederherstellung mit einem USB-Stick vorgenommen und siehe da, alles wieder im grünen Bereich.
                        Da dies aber ebenfalls keine Dauerlösung war und der Stick zudem füchterlich heiß wurde, habe ich mir ein neues Gehäuse samt aktivem Kühler für den Raspi zugelegt und ein Board für eine M.2 SSD lag ebenfalls bei, das nun mit einer 256GB SSD bestückt ist. Den USB-Stick habe ich einfach mit Balena Etcher darauf geklont und dann später über die raspi-config mit einem Klick bis zur vollen Größe erweitert.
                        Damit läuft nun alles wieder einwandfrei und hoffentlich auch störungsfrei in die Zukunft.
                        Danke für eure Hilfe und beste Grüße, Alex...
