  4. Dateimanager aus VIS lässt keine Uploads zu
    3.2k
31 Beiträge 7 Kommentatoren 1.1k Aufrufe 5 Beobachtet
  • 2 2U1C1D3
    Hallo @Glasfaser ,
    ich bitte zu entschuldigen, deine Forderung nach der Ausgabe von iob_diag habe ich überlesen - mea culpa :) Als iobroker-Rookie habe ich jetzt auch erst mal experimentieren müssen, wie ich diese Ausgabe erreiche... Da ist sie:
    /opt/iobroker$ ./iob_diag
    TERM environment variable not set.
    Skript v.2023-04-15
    107*** BASE SYSTEM ***
    Model        : Raspberry Pi 4 Model B Rev 1.4
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID:    Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:    11
    Codename:    bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
    16:36:09 up 5 days,  1:00,  0 users,  load average: 0.52, 0.31, 0.22
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=41.3'C
    volt=0.9260V
    107*** Time and Time Zones ***
                   Local time: Sun 2023-04-16 16:36:09 BST
               Universal time: Sun 2023-04-16 15:36:09 UTC
                     RTC time: n/a
                    Time zone: Europe/London (BST, +0100)
                  NTP service: active
              RTC in local TZ: no
    107*** User and Groups ***
    iobroker
    /home/iobroker
    iobroker tty dialout audio video bluetooth gpio i2c
    107*** X-Server-Setup ***
    X-Server:     false
    Desktop:
    Terminal:     unspecified
    Boot Target:     multi-user.target
    107*** MEMORY ***
    Mem:            7.9G        1.3G        5.9G        1.0M        671M        6.8G
    Swap:            99M          0B         99M
    Total:          8.0G        1.3G        6.0G
             7862 M total memory
             1263 M used memory
             1033 M active memory
              752 M inactive memory
             5927 M free memory
              105 M buffer memory
              565 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    107*** FILESYSTEM ***
    /dev/root      ext4       29G  2.8G   25G  10% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
    /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
    tmpfs          tmpfs     787M     0  787M   0% /run/user/1001
    We trust you have received the usual lecture from the local System
    Administrator. It usually boils down to these three things:
        #1) Respect the privacy of others.
        #2) Think before you type.
        #3) With great power comes great responsibility.
    sudo: a terminal is required to read the password; either use the -S option to read from standard input or configure an askpass helper
    sudo: a password is required
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    9.0M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    192M    /opt/iobroker/iobroker-data/
    153M    /opt/iobroker/iobroker-data/files
    51M    /opt/iobroker/iobroker-data/files/javascript.admin
    32M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    19M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
    11M    /opt/iobroker/iobroker-data/files/s7.admin/static/js/main.05e58ebd.js.map
    8.1M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js
    7.0M    /opt/iobroker/iobroker-data/states.jsonl
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
    107*** NodeJS-Installation ***
    ./iob_diag: line 166: nodejs: command not found
    /usr/bin/node         v16.19.1
    /usr/bin/npm         8.19.3
    /usr/bin/npx         8.19.3
    ./iob_diag: line 175: nodejs: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 16.19.1-deb-1nodesource1
      Candidate: 16.19.1-deb-1nodesource1
      Version table:
    *** 16.19.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u3 500
    No problems detected
    107*** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:     4.0.24
    admin:         6.3.5
    javascript:     6.1.4
    Adapters from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.backitup.0               : backitup              : iobroker-pi                              - disabled
    + system.adapter.cloud.0                  : cloud                 : iobroker-pi                              -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
    + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker-pi                              -  enabled
    + system.adapter.ecovacs-deebot.1         : ecovacs-deebot        : iobroker-pi                              -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : iobroker-pi                              -  enabled
    + system.adapter.hue.0                    : hue                   : iobroker-pi                              -  enabled, port: 443
      system.adapter.iot.0                    : iot                   : iobroker-pi                              - disabled
    + system.adapter.iqontrol.0               : iqontrol              : iobroker-pi                              -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
    + system.adapter.landroid.0               : landroid              : iobroker-pi                              -  enabled
    + system.adapter.net-tools.0              : net-tools             : iobroker-pi                              -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker-pi                              -  enabled
    + system.adapter.s7.0                     : s7                    : iobroker-pi                              -  enabled
    + system.adapter.s7.1                     : s7                    : iobroker-pi                              -  enabled
    + system.adapter.s7.2                     : s7                    : iobroker-pi                              -  enabled
    + system.adapter.s7.3                     : s7                    : iobroker-pi                              -  enabled
    + system.adapter.synology.0               : synology              : iobroker-pi                              -  enabled, port: 5001
    + system.adapter.terminal.0               : terminal              : iobroker-pi                              -  enabled, port: 8088, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.vis.0                    : vis                   : iobroker-pi                              -  enabled
    + system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.6.16   , installed 2.6.16
    Adapter    "cloud"        : 4.3.0    , installed 4.3.0
    Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "hue"          : 3.7.1    , installed 3.7.1
    Adapter    "iot"          : 1.14.2   , installed 1.14.2
    Adapter    "iqontrol"     : 2.1.0    , installed 2.1.0
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "landroid"     : 1.0.3    , installed 1.0.3
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "s7"           : 1.3.14   , installed 1.3.14
    Adapter    "synology"     : 2.1.13   , installed 2.1.13
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Objects and States
    Objects:     2113
    States:     1654
    107*** OS-Repositories and Updates ***
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists...
    Pending Updates: 10
    107*** Listening Ports ***
    107*** Log File - Last 25 Lines ***
    2023-04-16 16:23:56.037  - warn: s7.3 (18819) Poll error count: 1 code: 0xa006e
    2023-04-16 16:23:56.037  - warn: s7.3 (18819) Poll error Last-Error Info: 655470:  ISO : An error occurred during recv TCP : Connection timed out
    2023-04-16 16:23:56.038  - error: s7.3 (18819) try reconnection: Disconnect successful: true
    2023-04-16 16:24:56.039  - info: s7.3 (18819) Connect in S7 mode to 0 / 0
    2023-04-16 16:24:56.059  - info: s7.3 (18819) Successfully connected in S7 mode
    2023-04-16 16:26:31.812  - warn: s7.3 (18819) DBRead error[DB 2:1064 - 1065]: code: 0xa006e
    2023-04-16 16:26:31.813  - warn: s7.3 (18819) Poll error count: 1 code: 0xa006e
    2023-04-16 16:26:31.814  - warn: s7.3 (18819) Poll error Last-Error Info: 0: OK
    2023-04-16 16:26:31.814  - error: s7.3 (18819) try reconnection: Disconnect successful: true
    2023-04-16 16:26:34.812  - warn: s7.3 (18819) DBRead error[DB 1:400 - 1108]: code: 0xa006e
    2023-04-16 16:27:31.815  - info: s7.3 (18819) Connect in S7 mode to 0 / 0
    2023-04-16 16:27:31.831  - info: s7.3 (18819) Successfully connected in S7 mode
    2023-04-16 16:33:24.146  - warn: s7.3 (18819) DBRead error[DB 1:400 - 1108]: code: 0xa006e
    2023-04-16 16:33:24.146  - warn: s7.3 (18819) Poll error count: 1 code: 0xa006e
    2023-04-16 16:33:24.146  - warn: s7.3 (18819) Poll error Last-Error Info: 655470:  ISO : An error occurred during recv TCP : Connection timed out
    2023-04-16 16:33:24.147  - error: s7.3 (18819) try reconnection: Disconnect successful: true
    2023-04-16 16:33:25.432  - info: admin.0 (850) failed connection to socket.io from ::ffff:10.10.10.110: Passport was not initialized
    2023-04-16 16:33:59.460  - info: admin.0 (850) ==> Connected system.user.admin from ::ffff:10.10.10.110
    2023-04-16 16:34:24.148  - info: s7.3 (18819) Connect in S7 mode to 0 / 0
    2023-04-16 16:34:24.171  - info: s7.3 (18819) Successfully connected in S7 mode
    2023-04-16 16:36:48.776  - warn: s7.3 (18819) DBRead error[DB 2:1064 - 1065]: code: 0xa006e
    2023-04-16 16:36:48.777  - warn: s7.3 (18819) Poll error count: 1 code: 0xa006e
    2023-04-16 16:36:48.777  - warn: s7.3 (18819) Poll error Last-Error Info: 0: OK
    2023-04-16 16:36:48.777  - error: s7.3 (18819) try reconnection: Disconnect successful: true
    2023-04-16 16:36:51.777  - warn: s7.3 (18819) DBRead error[DB 1:400 - 1108]: code: 0xa006e
    iob diag has finished.
    Press any key for a summary
    Copy text starting here:
                 v.2023-04-15
    Operatingsystem:     Raspbian GNU/Linux 11 (bullseye)
    Kernel:         6.1.19-v8+
    Installation:         Native
    Timezone:         Europe/London (BST, +0100)
    User-ID:         1001
    X-Server:         false
    Pending OS-Updates:     10
    Pending iob updates:     0
    ./iob_diag: line 340: nodejs: command not found
    Nodejs-Installation:
                /usr/bin/npm         8.19.3
                /usr/bin/npx         8.19.3
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            7.9G        1.3G        5.8G        1.0M        791M        6.8G
    Swap:            99M          0B         99M
    Total:          8.0G        1.3G        5.9G
    Active iob-Instances:     20
    ioBroker Core:         js-controller         4.0.24
                admin             6.3.5
    ioBroker Status:     iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects:         2113
    States:         1654
    Size of iob-Database:
    7.4M    /opt/iobroker/iobroker-data/objects.jsonl
    7.1M    /opt/iobroker/iobroker-data/states.jsonl
    @Homoran :
    Auf deine Frage wo das PNG ist: Es ist eben nicht auf dem Screenshot zu sehen, weil ich es nicht hochladen kann. Wenn du mit deiner Frage meintest, dass ich das PNG an sich hier im Forum online stellen soll, dann ein klares NEIN.
    Tut mir leid, ich will hier nicht patzig sein, weil ich mir ja von euch Hilfe erwarte. Aber
    1. werde ich aus nachvollziehbaren Gründen den Inhalt des PNGs nicht publik machen, da sowohl personenbezogene Daten in dem Hintergrundbild enthalten sind, als auch geografische Referenzen welche eine eindeutige Zuordnung ermöglichen und
    2. ich ja bereits von mir gegeben habe, dass es nicht an diesem einen Bild liegt, sondern dass es überhaupt nicht geht, also dateiunabhängig ist.
    Zu "mit root verbogen": Ich bin gerne als Root unterwegs und habe mir dabei auch schon das eine oder andere System gekillt :) Allerdings ist iobroker, wie schon erwähnt, für mich totales Neuland. Und ich habe eben den allerersten Befehl auf der Konsole des iobrokers eingegeben (./iob_diag). Also hier auch NEIN, "I didn't root and drink" :)
    BTW, auch wenn oT: Wie komme ich den via Terminal von meinem Desktop auf den ioBroker? Alles an PWs und User aus diversen Posts verläuft negativ und mein Terminal gibt mir auch mal ganz klar zur Antwort, ich solle gefälligst erst mal nen ssh-User anlegen. Gerne, aber wo im Admin-Interface?
    HomoranH Offline
    HomoranH Offline
    @2u1c1d3 sagte in Dateimanager aus VIS lässt keine Uploads zu:
    du wohnst in London?
    klingt auch nicht gut.
    und der Systemuser iobroker darf dann ggf. nicht auf das zugreifen was du als root angelegt hast.
    iobroker
    /home/iobroker
    ist das der Systemuser, oder heisst dein user auch iobroker?
      iobroker
      /home/iobroker
      Da stimmt eh was mit den usern nicht.
      Die vielen Meldungen zu sudo tauchen in einem regulären Raspberry OS nicht auf. Vermutlich doch durch zuviel 'root & drink' was kaputt gemacht.
      2 1 Antwort Letzte Antwort
        2 Offline
        2 Offline
        2U1C1D3
        Hey, nein, um Gottes Willen! So war das nicht gemeint!
        Ich war auf dem RasPi / ioBroker noch gar nicht als root oder sowas unterwegs!
        Ich hab da bei "don't drink & root" von meinem PC gesprochen! :)
        Ich denke, wenn da einiges im Argen liegt, dann werde ich einfach mal mit einer Neuinstallation des Images auf der SD anfangen. Da ich wirklich noch nichts als root auf dem System gemacht habe, bzw. nichts bei dem ich mich bewusst als root ausgeben musste, wird wohl das Problem nicht im Nachgang verursacht worden sein.
        Oder gibt es eurerseits andere Vorschläge als noch mal von vorne anzufangen?
        • 2 2U1C1D3
          @2u1c1d3
          Dann leg dir zunächst einen ordentlichen user an und stopf den mindestens in die Gruppe 'sudo' und 'iobroker'.
            @2u1c1d3
            2 Offline
            2 Offline
            2U1C1D3
            schrieb am zuletzt editiert von 2U1C1D3
            Also, etz bin ich a bisserl weiter, für mich persönlich ist das Problem jedoch gelöst.
            @Thomas-Braun
            Einen User konnte ich sowohl über die Adminoberfläche anlegen, als auch über den Terminaladapter. Eine Mitgliedschaft in der Gruppe ioBroker war jedoch nicht möglich. Wird weder angezeigt, noch dass das Terminal mich dort einen User hinzufügen ließ.
            Ich habe den RasPi daraufhin flach gemacht, das Image neu gezogen und auf die SD-Karte geschoben. Bei dem anschließenden Start zur Installation gab es keine Fehlermeldungen. Lediglich beim ersten Start des ioBrokers kamen Fehlermeldungen. Er erkannte sowohl nicht alle Adapter (fronius und synology fehlten wieder), als auch das er wegen einem fehlenden node.js meckerte und hier wohl nachinstallierte. Bei vis zeigte sich genau das gleiche Problem wieder.
            Ich habe nun die SD über den Imager mit Bullseye versehen und dann den ioBroker via Terminal nachinstalliert. Jetzt erkennt er bereits beim ersten Start die beiden Adapter (wobei fronius nicht funktioniert - andere Baustelle), als auch dass der Dateimanager im vis so funktioniert wie er soll. Von node.js war nichts mehr zu lesen.
            Für mich somit eigentlich erledigt. Ob das jetzt von einer fehlerhaften Installation des Images kam, oder von einem Fehler im Image selbst, sei dahingestellt. Letzteres vermute ich jedoch weniger, da sich sonst wahrscheinlich noch andere User gemeldet hätten.
            Vielen Dank und sorry nochmal, dass das so schleppend mit den Infos angelaufen ist!
            GTX
            Stefan
            • 2 2U1C1D3
              @Thomas-Braun
              GTX
              Stefan
              Eine Mitgliedschaft in der Gruppe ioBroker war jedoch nicht möglich. Wird weder angezeigt, noch dass das Terminal mich dort einen User hinzufügen lässt.
              Die User-Verwaltung ist vom iobroker unabhängig. Warum sollten absolute Basis-Kommandos nicht funktionieren?
              • 2 2U1C1D3
                @Thomas-Braun
                GTX
                Stefan
                HomoranH Offline
                HomoranH Offline
                Inzwischen nutzen sehr wenige User fertige Images da die "manuelle" Installation nur noch aus einem Befehl besteht.
                  2 Offline
                  2 Offline
                  2U1C1D3
                  Weil ich aus deinem Vorschlag nur durch die Gruppe "sudo" in deinem Post darauf gekommen bin, dass du das OS meinst und nicht die Anwendung. Und auf dem OS war die Gruppe weder vorhanden, noch dass sie sich anlegen ließ.
                  • 2 2U1C1D3
                    @2u1c1d3
                    Die Gruppe wird durch die Installation des ioBrokers angelegt, es ist die Heimatgruppe des Systemusers 'iobroker'.
                    Und zu dieser Gruppe kann man natürlich weitere User bei Bedarf hinzufügen.
                    Passiert aber bei einer regulären Installation ohnehin für den User, der den Installer ausführt.
                    • PeoplesP Offline
                      PeoplesP Offline
                      Peoples
                      Ich hatte das tatsächlich auch, ich konnte keine Bilder mehr hochladen und auch keine neuen Seiten erstellen. Die Lösung bei mir war erschreckend einfach: Ich habe nur den Fixer drüber laufen lassen, dann waren die Rechte wieder OK und alles läuft wieder.
                      Ob das hier hilft kann ich nicht sagen
                        @2u1c1d3
                        2 Offline
                        2 Offline
                        2U1C1D3
                        @thomas-braun said in Dateimanager aus VIS lässt keine Uploads zu:
                        Das ist bei mir eben nicht passiert. Ich hatte lediglich die Gruppe "root" oder "sudo"; welche der beiden weiß ich nicht genau weil ich nicht drauf geachtet habe.
                        Der Broker an sich lief jedoch einwandfrei - mit allen Adaptern, bis auf den Dateimanger vom vis eben...
                        Ich kenn den "Schmarrn" (sorry für den Ausdruck) vom Desktop mit Scannern oder optischen Laufwerken. Biste nicht in der Gruppe, dann findet das System die Geräte zwar, du kannst aber nicht damit arbeiten. Das war aber bei den Image-Installationen nicht der Fall. Du konntest mit dem ioBroker ganz vernünftig arbeiten, obwohl am OS keine Gruppe auffindbar war. Ich will ja nicht sagen, dass die nicht irgendwo versteckt war, aber über cat oder groups wurde nichts dergleichen ausgegeben.
                        • 2 2U1C1D3
                          Dann hast du irgendwas anders als üblich gemacht.
                            2 Offline
                            2 Offline
                            2U1C1D3
                            2x hintereinander bei einer plug&play-Installation?
                            Ich würde das als sehr wahrscheinlich sehen, wenn ich im Verlauf der Installation irgendetwas gefragt werde oder modifizieren könnte.
                            Von hier das Image runter geladen, und zwar für die Neuinstallation erneut runter geladen und nicht das bereits vorhandene Image erneut verwendet, via Linux-Bordmitteln auf die SD-Karte und dann in den RasPi hinein.
                            Der nächste Schritt war dann die Anmeldung beim RasPi auf der GUI.
                            Die Installation via curl auf einem RasPi-OS funktioniert tadellos.
                            • 2 2U1C1D3
                              @2u1c1d3
                              So installiert man das nicht.
                              Raspberry OS Lite mit dem Raspberry Imager installieren und den iobroker mit dem Einzeiler auf das System bringen.
                              Dann stimmen auch die User und Gruppen.
                              Also wie vermutet anders als üblich installiert.
                              Ich mach es immer so:
                              https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht/3
                                @2u1c1d3
                                2 Offline
                                2 Offline
                                2U1C1D3
                                Ich möchte nicht unhöflich sein, aber du liest schon was ich geschrieben habe, oder?
                                1. Habe ich ausgeführt, dass ein Installation via curl auf dem RasPi-OS tadellos funktioniert und
                                2. habe ich deutlich gemacht, dass der Fehler nur bei der Verwendung des ioBroker-Images auftaucht.
                                Jetzt muss ich als Newbie doch hinterfragen, warum ein eigenes PI-Image ioBroker zum Download angeboten wird, wenn man den ioBroker so nicht installiert???
                                Starte ich mit dem Thema als Anfänger, dann mache ich es mir so leicht wie möglich und nehme das, was mir der Entwickler präsentiert. Warum sollte ich von Anfang an irgendwelche Hintertürchen ausprobieren? Das kann ich dann machen, wenn ich advanced oder experience bin!
                                • 2 2U1C1D3
                                  HomoranH Offline
                                  HomoranH Offline
                                  wieso Hintertürchen?
                                  Das ist die offizielle Installationsform.
                                  Steht auch im Kasten auf der Downloadseite!
                                    2 Offline
                                    2 Offline
                                    2U1C1D3
                                    Mea Culpa! Da muss ich mich jetzt bei @Thomas-Braun wirklich entschuldigen! Leider schaut die Site bei mir im Chrome so aus:
                                    Via SmartPhone kommt das so wie bei dir dargestellt 😮
