  4. [How-to] Node.js für ioBroker richtig updaten
    6.7k
installationlinuxnodenode.jsnodejswindows
1.1k Beiträge 106 Kommentatoren 881.0k Aufrufe 112 Beobachtet
  • G grazer75
    @thomas-braun mit 18 wieder viele Meldungen
    erstmal iob diag
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     20:41:31 up 2 min,  2 users,  load average: 3.46, 1.59, 0.61
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=54.0'C
    volt=0.9460V
    *** Time and Time Zones ***
                   Local time: Sun 2023-04-16 20:41:32 CEST
               Universal time: Sun 2023-04-16 18:41:32 UTC
                     RTC time: n/a
                    Time zone: Europe/Vienna (CEST, +0200)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    andreas
    /home/andreas
    andreas adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.8G        2.2G        5.2G        6.0M        409M        5.5G
    Swap:            99M          0B         99M
    Total:          7.9G        2.2G        5.3G
             7811 M total memory
             2207 M used memory
             2290 M active memory
              198 M inactive memory
             5194 M free memory
               51 M buffer memory
              357 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      118G  6.3G  107G   6% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  924K  1.6G   1% /run
    /dev/sda1      vfat      253M   31M  222M  13% /boot
    tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
    [Sun Apr 16 20:39:09 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:C5:38:E2 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=270f37e4-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Apr 16 20:39:11 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Apr 16 20:39:11 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sun Apr 16 20:39:12 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    2.2G    /var/
    1.6G    /var/log
    1.4G    /var/log/journal/deee1983c79b418b90418f11a8f1c85d
    317M    /var/cache
    Archived and active journals take up 1.3G in the file system.
    /opt/iobroker/backups:
    395M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    452M    /opt/iobroker/iobroker-data/
    333M    /opt/iobroker/iobroker-data/files
    87M     /opt/iobroker/iobroker-data/backup-objects
    72M     /opt/iobroker/iobroker-data/files/telegram.admin
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
    23M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    15M     /opt/iobroker/iobroker-data/files/meteoalarm.admin/geocodes.json
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         16.19.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
            throw e;
    Error: Connection is closed.
        at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
        at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
        at Object.onceWrapper (node:events:628:26)
        at Socket.emit (node:events:513:28)
        at TCP.<anonymous> (node:net:322:12)
    Emitted 'error' event on ScanStream instance at:
        at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
        at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
        at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
        at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    Node.js v18.16.0
            throw e;
        at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
        at Redis.scan (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
        at ScanStream._read (/opt/iobroker/node_modules/ioredis/built/ScanStream.js:36:41)
        at Readable.read (node:internal/streams/readable:496:12)
        at resume_ (node:internal/streams/readable:999:12)
        at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
    Node.js v18.16.0
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     7.0.3
    Adapters from github:   4
    Adapter State
      system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
      system.adapter.benchmark.0              : benchmark             : raspberrypi                              - disabled
    + system.adapter.bmw.0                    : bmw                   : raspberrypi                              -  enabled
      system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              - disabled
      system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
      system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
    + system.adapter.coronavirus-statistics.0 : coronavirus-statistics: raspberrypi                              -  enabled
    + system.adapter.countdown.0              : countdown             : raspberrypi                              -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
      system.adapter.devices.0                : devices               : raspberrypi                              - disabled
      system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
    + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
    + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
      system.adapter.fb-checkpresence.1       : fb-checkpresence      : raspberrypi                              - disabled
    + system.adapter.firetv.0                 : firetv                : raspberrypi                              -  enabled
      system.adapter.followthesun.0           : followthesun          : raspberrypi                              -  enabled
      system.adapter.foobar2000.0             : foobar2000            : raspberrypi                              - disabled, port: 8888
    + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
      system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              - disabled
    + system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : raspberrypi                              -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
      system.adapter.lgtv11.0                 : lgtv11                : raspberrypi                              -  enabled, port: 8080
      system.adapter.life360.0                : life360               : raspberrypi                              - disabled
      system.adapter.linkeddevices.0          : linkeddevices         : raspberrypi                              -  enabled
      system.adapter.linux-control.0          : linux-control         : raspberrypi                              -  enabled
      system.adapter.logparser.0              : logparser             : raspberrypi                              -  enabled
    + system.adapter.luftdaten.0              : luftdaten             : raspberrypi                              -  enabled
      system.adapter.meteoalarm.0             : meteoalarm            : raspberrypi                              -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
      system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
      system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
    + system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi                              -  enabled
      system.adapter.netatmo-energy.0         : netatmo-energy        : raspberrypi                              -  enabled
    + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
    + system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              -  enabled
      system.adapter.nuki.0                   : nuki                  : raspberrypi                              -  enabled
      system.adapter.nut.0                    : nut                   : raspberrypi                              - disabled
      system.adapter.onvif.0                  : onvif                 : raspberrypi                              -  enabled
      system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
    + system.adapter.owntracks.0              : owntracks             : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
      system.adapter.paw.0                    : paw                   : raspberrypi                              - disabled, port: 8898
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
    + system.adapter.pushbullet.0             : pushbullet            : raspberrypi                              -  enabled
      system.adapter.radar2.0                 : radar2                : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
      system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
      system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled
      system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1884, bind: 192.168.1.139
      system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              - disabled
    + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
      system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      system.adapter.tr-064.1                 : tr-064                : raspberrypi                              - disabled
      system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
      system.adapter.virtualpowermeter.0      : virtualpowermeter     : raspberrypi                              -  enabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
      system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
    + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
      system.adapter.windows-control.0        : windows-control       : raspberrypi                              -  enabled
      system.adapter.withings.0               : withings              : raspberrypi                              -  enabled
      system.adapter.xbox.0                   : xbox                  : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
    + instance is alive
    + system.adapter.lgtv11.0                 : lgtv11                : raspberrypi                              -  enabled, port: 8080
    + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
    Adapter    "alarm"        : 3.3.9    , installed 3.3.9
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.6.16   , installed 2.6.16
    Adapter    "benchmark"    : 1.1.4    , installed 1.1.4
    Adapter    "bmw"          : 2.5.7    , installed 2.5.7
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "cloud"        : 4.3.0    , installed 4.3.0
    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
    Adapter    "countdown"    : 1.2.5    , installed 1.2.5
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "devices"      : 1.1.2    , installed 1.1.2
    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
    Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
    Adapter    "email"        : 1.1.4    , installed 1.1.4
    Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
    Adapter    "firetv"       : 1.0.0    , installed 1.0.0
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "followthesun" : 0.4.1    , installed 0.4.1
    Adapter    "foobar2000"   : 2.0.4    , installed 2.0.4
    Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
    Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
    Adapter    "fuelpricemonitor": 0.3.4 , installed 0.3.4
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hmip"         : 1.20.0   , installed 1.20.0
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.14.2   , installed 1.14.2
    Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
    Adapter    "javascript"   : 6.1.4    , installed 7.0.3
    Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
    Adapter    "linux-control": 1.1.3    , installed 1.1.3
    Adapter    "logparser"    : 2.1.1    , installed 2.1.1
    Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
    Adapter    "meteoalarm"   : 2.3.5    , installed 2.3.5
    Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "netatmo-energy": 2.3.1   , installed 2.3.1
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "onvif"        : 1.0.4    , installed 1.0.4
    Adapter    "openweathermap": 0.3.3   , installed 0.3.3
    Adapter    "owntracks"    : 1.0.5    , installed 1.0.5
    Adapter    "parser"       : 1.1.8    , installed 1.1.8
    Adapter    "paw"          : 0.3.2    , installed 0.3.2
    Adapter    "pushbullet"   : 0.0.11   , installed 0.0.11
    Adapter    "radar2"       : 2.0.3    , installed 2.0.3
    Adapter    "sayit"        : 1.12.3   , installed 1.12.3
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "smartcontrol" : 1.3.2    , installed 1.3.2
    Adapter    "snmp"         : 2.4.6    , installed 2.4.6
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
    Adapter    "statistics"   : 2.3.0    , installed 2.3.0
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tuya"         : 3.13.1   , installed 3.13.1
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "windows-control": 0.1.5  , installed 0.1.5
    Adapter    "withings"     : 0.0.13   , installed 0.0.13
    Adapter    "xbox"         : 1.0.2    , installed 1.0.2
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        29904
    States:         24682
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://packages.sury.org/php bullseye InRelease
    Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:7 http://archive.raspberrypi.org/debian bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15749      514/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15742      514/iobroker.js-con
    tcp        0      0 192.168.1.139:1884      0.0.0.0:*               LISTEN      1001       14194      1063/io.sonoff.0
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       23895      1756/io.jarvis.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11929      562/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       13956      1009/io.owntracks.0
    tcp6       0      0 :::51989                :::*                    LISTEN      1001       17211      1210/io.nuki-extend
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15209      765/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       26807      2137/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       24036      2065/io.socketio.0
    tcp6       0      0 :::80                   :::*                    LISTEN      0          15000      573/apache2
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11931      562/sshd: /usr/sbin
    tcp6       0      0 :::9999                 :::*                    LISTEN      0          15004      573/apache2
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       17814      1161/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       17815      1161/io.tuya.0
    udp        0      0 0.0.0.0:44617           0.0.0.0:*                           1001       26831      2048/io.snmp.0
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       22280      2003/io.radar2.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13240      827/dhcpcd
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       16758      964/io.mihome-vacuu
    udp        0    768 0.0.0.0:46003           0.0.0.0:*                           1001       32789      2241/io.xbox.0
    udp        0      0 0.0.0.0:42092           0.0.0.0:*                           1001       26718      2091/io.upnp.0
    udp        0      0 192.168.1.139:5353      0.0.0.0:*                           1001       17759      1144/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12881      397/avahi-daemon: r
    udp        0      0 0.0.0.0:38559           0.0.0.0:*                           1001       16663      857/io.javascript.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       25730      2091/io.upnp.0
    udp        0      0 0.0.0.0:59680           0.0.0.0:*                           108        12883      397/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        12882      397/avahi-daemon: r
    udp6       0      0 :::51466                :::*                                108        12884      397/avahi-daemon: r
    2023-04-16 20:43:57.659  - info: radar2.0 (2003) first scan took 18.02 seconds
    2023-04-16 20:43:57.660  - info: radar2.0 (2003) will scan external network every  60  minutes
    2023-04-16 20:43:57.713  - info: followthesun.0 (2396) Started with JSON-Explorer version 0.1.10
    2023-04-16 20:43:57.716  - info: followthesun.0 (2396) Sun position calculation will be done every 120 seconds
    2023-04-16 20:43:57.722  - info: followthesun.0 (2396) Daily sun parameter calculation scheduled for 00:00:33
    2023-04-16 20:43:58.289  - info: radar2.0 (2003) Adapter initialization finished!
    2023-04-16 20:43:58.390  - info: netatmo-crawler.0 (1845) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2023-04-16 20:44:02.779  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-04-16 20:44:03.617  - info: info.0 (1670) starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v18.16.0, js-controller: 4.0.24
    2023-04-16 20:44:04.083  - info: info.0 (1670) Reading/updating systemdata.
    2023-04-16 20:44:05.316  - info: xbox.0 (2241) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.xbox, node: v18.16.0, js-controller: 4.0.24
    2023-04-16 20:44:06.014  - info: xbox.0 (2241) Successfully loaded token
    2023-04-16 20:44:06.717  - info: xbox.0 (2241) Xbox login url available at: https://login.live.com/oauth20_authorize.srf?client_id=5e5ead27-ed60-482d-b3fc-702b28a97404&response_type=code&approval_prompt=auto&scope=XboxLive.signin%20XboxLive.offline_access&redirect_uri=http%3A%2F%2Flocalhost%3A8080%2Fauth%2Fcallback
    2023-04-16 20:44:06.720  - info: xbox.0 (2241) Copy the token (value after code=) after login into "apiToken" of the adapter config to enable the Xbox api
    2023-04-16 20:44:06.762  - warn: xbox.0 (2241) Could not poll API: "No oauth token found. Run authentication flow first"
    2023-04-16 20:44:07.626  - info: info.0 (1670) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
    2023-04-16 20:44:08.460  - info: info.0 (1670) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
    2023-04-16 20:44:08.814  - info: smartcontrol.0 (2036) Subscribing to all target devices and trigger states. 4 trigger schedules activated...
    2023-04-16 20:44:09.510  - info: info.0 (1670) cpu Temp res = {"main":55.504,"cores":[],"max":55.504,"socket":[],"chipset":null}
    2023-04-16 20:44:28.270  - info: netatmo-energy.0 (1948) API-Anfrage starten: homestatus
    2023-04-16 20:44:32.394  - info: coronavirus-statistics.0 (1281) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-04-16 20:44:33.280  - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-04-16 20:44:41.850  - info: fuelpricemonitor.0 (1616) Terminated (NO_ERROR): Without reason
    2023-04-16 20:44:42.436  - info: fuelpricemonitor.0 (1616) cleaned everything up...
    2023-04-16 20:44:42.680  - info: host.raspberrypi instance system.adapter.fuelpricemonitor.0 terminated with code 0 (NO_ERROR)
    Summary
                         v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
    Kernel:                 6.1.21-v8+
    Installation:           Native
    Timezone:               Europe/Vienna (CEST, +0200)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            7.8G        2.9G        4.1G        6.0M        797M        4.8G
    Swap:            99M          0B         99M
    Total:          7.9G        2.9G        4.2G
    Active iob-Instances:   57
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                29904
    States:                 24682
    Size of iob-Database:
    27M     /opt/iobroker/iobroker-data/objects.jsonl
    14M     /opt/iobroker/iobroker-data/states.jsonl
    Iobroker log
    javascript.0
    2023-04-16 20:48:57.954	warn	Read-only state "javascript.0.MiHomeAll.lumi.158d0002a3299c.info.rssi" has been written without ack-flag with value "0"
    javascript.0
    2023-04-16 20:48:57.946	warn	Read-only state "javascript.0.MiHomeAll.396976417.info.rssi" has been written without ack-flag with value "-55"
    javascript.0
    2023-04-16 20:48:57.943	warn	Read-only state "javascript.0.MiHomeAll.lumi.158d0004ac0836.info.rssi" has been written without ack-flag with value "0"
    javascript.0
    2023-04-16 20:48:57.939	warn	Read-only state "javascript.0.MiHomeAll.408471265.info.rssi" has been written without ack-flag with value "-46"
    javascript.0
    2023-04-16 20:48:57.717	warn	script.js.XiaomiGeraeteCN: No supported Devices found!
    tuya.0
    2023-04-16 20:49:52.026	warn	80157022e0980602099a: Error on Reconnect (1): connect ECONNRESET 192.168.1.212:6668
    tuya.0
    2023-04-16 20:49:52.016	warn	80248051e098069e47eb: Error on Reconnect (1): connect ECONNRESET 192.168.1.167:6668
    tuya.0
    2023-04-16 20:49:51.953	warn	47804507a4cf12ccd3ef: Error on Reconnect (1): connect ECONNRESET 192.168.1.161:6668
    tuya.0
    2023-04-16 20:49:51.820	warn	80157022e09806010425: Error on Reconnect (1): connect ECONNRESET 192.168.1.194:6668
    wifilight.0
    2023-04-16 20:49:51.495	error	wrong device type. not yet supported!
    wifilight.0
    2023-04-16 20:49:51.492	error	config.device.type "" (HF-LPT120) is not a known device type. Skipping this device! Known types are: LW12, LD382A, LD686, LD382, UFO, MiLight, MiLightRGB, MiLightW
    rpi2.0
    2023-04-16 20:49:30.607	error	No Value found for cpu_frequency
    netatmo.0
    2023-04-16 20:49:17.457	warn	API Error: Please Authenticate manually once using the Admin UI of this instance.
    backitup.0
    2023-04-16 20:50:13.179	error	Dropbox: "expired_access_token/."
    backitup.0
    2023-04-16 20:50:13.160	error	Dropbox: "expired_access_token/."
    nuki-extended.0
    2023-04-16 20:50:05.279	warn	getWebApi(): Error retrieving smartlocks: Cannot read properties of undefined (reading 'toLowerCase')
    zigbee.0
    2023-04-16 20:50:05.063	warn	Extended PAN ID is reversed (expected=51b8a11c004b1200, actual=00124b001ca1b851)
    nuki-extended.0
    2023-04-16 20:50:03.493	warn	Failed retrieving /list from Nuki Bridge with name Schiess Nuki Bridge (forcePlainToken: false)!
    firetv.0
    2023-04-16 20:50:33.728	error	can not connect to 192.168.1.208 Error=spawn adb ENOENT
    firetv.0
    2023-04-16 20:50:33.634	error	adb executable not found. undefined
    zigbee.0
    2023-04-16 20:50:49.101	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x003c84fffeb3dbf7 TS0044 (Error: Read 0x003c84fffeb3dbf7/1 genBasic(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC transaction expired' (240)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32))
    onvif.0
    2023-04-16 20:51:56.636	error	Error during discovery: Error: Wrong ONVIF SOAP response,Error: Wrong ONVIF SOAP response,Error: Wrong ONVIF SOAP response,TypeError: Cannot read properties of undefined (reading 'endpointReference'),TypeError: Cannot read properties of undefined (reading 'endpointReference')
    onvif.0
    2023-04-16 20:51:52.776	error	Error Error: ONVIF SOAP Fault: The action requested requires authorization and the sender is not authorized
    onvif.0
    2023-04-16 20:51:52.775	error	Failed to login to 192.168.1.218:8000 with admin:$*****************************************************************************7
    onvif.0
    2023-04-16 20:51:52.539	error	Error Error: ONVIF SOAP Fault: The action requested requires authorization and the sender is not authorized
    onvif.0
    2023-04-16 20:51:52.538	error	Failed to login to 192.168.1.211:8000 with admin:$*****************************************************************************7
    onvif.0
    2023-04-16 20:51:52.320	error	undefined
    onvif.0
    2023-04-16 20:51:52.320	error	<?xml version="1.0" ?> <soap:Envelope > <soap:Header> <wsa:Action>http://schemas.xmlsoap.org/ws/2005/04/discovery/ProbeMatches</wsa:Action> <wsa:MessageID>urn:uuid:0eaaa933-a101-4933-86f1-3ce46179ab26</wsa:MessageID> <wsa:RelatesTo>urn:uuid:8d65c8dd-fa75-977b-db4d-fc1d23082a1c</wsa:RelatesTo> <wsa:To>http://schemas.xmlsoap.org/ws/2004/08/addressing/role/anonymous</wsa:To> <wsd:AppSequence InstanceId="1170846535" MessageNumber="1"/> </soap:Header> <soap:Body> <wsd:ProbeMatches/> </soap:Body> </soap:Envelope>
    onvif.0
    2023-04-16 20:51:52.319	error	Discovery error Wrong SOAP message from 192.168.1.135:35191
    onvif.0
    2023-04-16 20:51:52.222	error	undefined
    onvif.0
    2023-04-16 20:51:52.221	error	<?xml version="1.0" ?> <soap:Envelope > <soap:Header> <wsa:Action>http://schemas.xmlsoap.org/ws/2005/04/discovery/ProbeMatches</wsa:Action> <wsa:MessageID>urn:uuid:0eaaa933-a101-4933-86f1-3ce46179ab26</wsa:MessageID> <wsa:RelatesTo>urn:uuid:8d65c8dd-fa75-977b-db4d-fc1d23082a1c</wsa:RelatesTo> <wsa:To>http://schemas.xmlsoap.org/ws/2004/08/addressing/role/anonymous</wsa:To> <wsd:AppSequence InstanceId="1170846535" MessageNumber="1"/> </soap:Header> <soap:Body> <wsd:ProbeMatches/> </soap:Body> </soap:Envelope>
    onvif.0
    2023-04-16 20:51:52.219	error	Discovery error Wrong SOAP message from 192.168.1.135:35191
    onvif.0
    2023-04-16 20:51:52.137	error	Error Error: connect ECONNREFUSED 192.168.1.115:8000
    onvif.0
    2023-04-16 20:51:52.136	error	Failed to login to 192.168.1.115:8000 with admin:$*****************************************************************************7
    onvif.0
    2023-04-16 20:51:51.863	error	undefined
    onvif.0
    2023-04-16 20:51:51.862	error
    onvif.0
    2023-04-16 20:51:51.862	error	Discovery error Wrong SOAP message from 192.168.1.211:3702
    onvif.0
    2023-04-16 20:51:51.848	error	undefined
    onvif.0
    2023-04-16 20:51:51.847	error
    onvif.0
    2023-04-16 20:51:51.846	error	Discovery error Wrong SOAP message from 192.168.1.218:3702
    onvif.0
    2023-04-16 20:51:51.816	error	undefined
    onvif.0
    2023-04-16 20:51:51.814	error
    onvif.0
    2023-04-16 20:51:51.813	error	Discovery error Wrong SOAP message from 192.168.1.115:3702
    linux-control.0
    2023-04-16 20:51:44.647	warn	This object will not be created in future versions. Please report this to the developer.
    linux-control.0
    2023-04-16 20:51:44.645	warn	Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    linux-control.0
    2023-04-16 20:51:40.863	warn	This object will not be created in future versions. Please report this to the developer.
    linux-control.0
    2023-04-16 20:51:40.855	warn	Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    Werde daher wieder auf 16 gehen, außer ihr wisst eine Lösung für die Fehler
    Mein aktueller Status
    which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.19.1
    v16.19.1
    8.19.3
    nodejs:
      Installed: 16.19.1-deb-1nodesource1
      Version table:
     *** 16.19.1-deb-1nodesource1 500
    #995
    @grazer75 sagte in [How-to] Node.js für ioBroker richtig updaten:
    Du musst auch schon die Chance lassen den Output auch zu lesen...
    G 1 Antwort Letzte Antwort
      grazer75
      #996
      @thomas-braun ich bin auf 16 zurück allerdings sind die Fehler noch da
      zigbee.0
      2023-04-16 21:07:43.024	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x003c84fffeb3dbf7 TS0044 (Error: Read 0x003c84fffeb3dbf7/1 genBasic(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC transaction expired' (240)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32))
      firetv.0
      2023-04-16 21:07:32.731	error	can not connect to 192.168.1.208 Error=spawn adb ENOENT
      firetv.0
      2023-04-16 21:07:32.614	error	adb executable not found. undefined
      2023-04-16 21:07:14.106	warn	Hospital Data Warning: Error: Cannot get german hospital data from divi: TypeError: Cannot read properties of undefined (reading 'toLowerCase')
      backitup.0
      2023-04-16 21:07:13.950	error	Dropbox: "expired_access_token/.."
      backitup.0
      2023-04-16 21:07:13.948	error	Dropbox: "expired_access_token/.."
      2023-04-16 21:07:09.893	warn	This object will not be created in future versions. Please report this to the developer.
      2023-04-16 21:07:09.888	warn	Object coronavirus-statistics.0.countryTranslator is invalid: Default value has to be type "string" but received type "number"
      zigbee.0
      2023-04-16 21:06:59.736	warn	Extended PAN ID is reversed (expected=51b8a11c004b1200, actual=00124b001ca1b851)
      nuki-extended.0
      2023-04-16 21:06:58.499	warn	getWebApi(): Error retrieving smartlocks: Cannot read properties of undefined (reading 'toLowerCase')
      nuki-extended.0
      2023-04-16 21:06:56.839	warn	Failed retrieving /list from Nuki Bridge with name Schiesstattgasse Nuki Bridge (forcePlainToken: false)!
      tuya.0
      2023-04-16 21:06:52.531	warn	47804507a4cf12ccd3ef: Error on Reconnect (1): connect ECONNRESET 192.168.1.161:6668
      tuya.0
      2023-04-16 21:06:52.501	warn	80248051e098069e47eb: Error on Reconnect (1): connect ECONNRESET 192.168.1.167:6668
      tuya.0
      2023-04-16 21:06:51.754	warn	80157022e0980602099a: Error on Reconnect (1): connect ECONNRESET 192.168.1.212:6668
      tuya.0
      2023-04-16 21:06:51.625	warn	43024001f4cfa2de874f: Error on Reconnect (1): connect ECONNRESET 192.168.1.249:6668
      tuya.0
      2023-04-16 21:06:51.455	warn	80157022e09806010425: Error on Reconnect (1): connect ECONNRESET 192.168.1.194:6668
      wifilight.0
      2023-04-16 21:06:43.474	error	wrong device type. not yet supported!
      wifilight.0
      2023-04-16 21:06:43.470	error	config.device.type "" (HF-LPT120) is not a known device type. Skipping this device!Known types are: LW12, LD382A, LD686, LD382, UFO, MiLight, MiLightRGB, MiLightW
      rpi2.0
      2023-04-16 21:06:18.496	error	No Value found for cpu_frequency
      mihome-vacuum.0
      2023-04-16 21:06:09.094	warn	No Answer for DeviceModel use model from Config
      mihome-vacuum.0
      2023-04-16 21:06:09.092	warn	No Answer for DeviceModel use old one
      mihome-vacuum.0
      2023-04-16 21:06:09.090	error	YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
      netatmo.0
      2023-04-16 21:06:07.174	warn	API Error: Please Authenticate manually once using the Admin UI of this instance.
      Gestern hatte ich es geschafft das wieder weg geht.
      Eventuell Cache purge bzw npm rebuild?
      Überall alles neu machen, hab ich nicht wirklich Zeit.
      Mit einem zurück auf 16 gestern ging es ohne das ich weiter was anpassen musste
      • G grazer75
        zigbee.0
        firetv.0
        firetv.0
        backitup.0
        backitup.0
        zigbee.0
        nuki-extended.0
        nuki-extended.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        wifilight.0
        wifilight.0
        rpi2.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        netatmo.0
        #997
        @grazer75
        Alles keine Dinge die ich primär auf nodejs schieben würde.
        • G Offline
          grazer75
          #998
          @thomas-braun wie gesagt gestern hab ich mehrere Sachen probiert, ohne das ich ein Backup zurück restored habe
          und dann waren die Fehler weg und ich zurück auf Version 16
          Nun bin ich auf 16, krieg schon wieder die Fehler nicht weg
          host.raspberrypi
          2023-04-16 21:20:00.149	warn	instance system.adapter.netatmo-crawler.0 already running with pid 1571
          zigbee.0
          2023-04-16 21:19:34.992	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x003c84fffeb3dbf7 TS0044 (Error: Read 0x003c84fffeb3dbf7/1 genBasic(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC transaction expired' (240)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32))
          firetv.0
          2023-04-16 21:19:09.339	error	can not connect to 192.168.1.208 Error=spawn adb ENOENT
          firetv.0
          2023-04-16 21:19:09.136	error	adb executable not found. undefined
          2023-04-16 21:19:06.257	warn	Hospital Data Warning: Error: Cannot get german hospital data from divi: TypeError: Cannot read properties of undefined (reading 'toLowerCase')
          zigbee.0
          2023-04-16 21:18:54.487	warn	DeviceAvailability:Failed to ping 0x5c0272fffe5b8c0e TRADFRI Signal Repeater
          backitup.0
          2023-04-16 21:18:53.396	error	Dropbox: "expired_access_token/."
          backitup.0
          2023-04-16 21:18:53.395	error	Dropbox: "expired_access_token/."
          2023-04-16 21:18:51.607	warn	This object will not be created in future versions. Please report this to the developer.
          2023-04-16 21:18:51.603	warn	Object coronavirus-statistics.0.countryTranslator is invalid: Default value has to be type "string" but received type "number"
          zigbee.0
          2023-04-16 21:18:49.027	warn	Extended PAN ID is reversed (expected=51b8a11c004b1200, actual=00124b001ca1b851)
          nuki-extended.0
          2023-04-16 21:18:43.554	warn	getWebApi(): Error retrieving smartlocks: Cannot read properties of undefined (reading 'toLowerCase')
          nuki-extended.0
          2023-04-16 21:18:42.175	warn	Failed retrieving /list from Nuki Bridge with name Schiesstattgasse Nuki Bridge (forcePlainToken: false)!
          wifilight.0
          2023-04-16 21:18:26.393	error	wrong device type. not yet supported!
          wifilight.0
          2023-04-16 21:18:26.388	error	config.device.type "" (HF-LPT120) is not a known device type. Skipping this device!Known types are: LW12, LD382A, LD686, LD382, UFO, MiLight, MiLightRGB, MiLightW
          rpi2.0
          2023-04-16 21:18:03.613	error	No Value found for cpu_frequency
          netatmo.0
          2023-04-16 21:17:51.067	warn	API Error: Please Authenticate manually once using the Admin UI of this instance.
          wie komm ich wieder zu einer funktionierenden 16 Version außer jetzt wieder alles mögliche wie gestern zu probieren?`
          Thomas BraunT DJMarc75D 2 Antworten Letzte Antwort
          • G grazer75
            host.raspberrypi
            zigbee.0
            firetv.0
            firetv.0
            zigbee.0
            backitup.0
            backitup.0
            zigbee.0
            nuki-extended.0
            nuki-extended.0
            wifilight.0
            wifilight.0
            rpi2.0
            netatmo.0
            #999
            @grazer75
            Du wirst dir die einzelnen Adapter und deren Einstellungen anschauen müssen.
            War der iobroker eigentlich heruntergefahren, als du nodejs upgedated hast?
            • G grazer75
              host.raspberrypi
              zigbee.0
              firetv.0
              firetv.0
              zigbee.0
              backitup.0
              backitup.0
              zigbee.0
              nuki-extended.0
              nuki-extended.0
              wifilight.0
              wifilight.0
              rpi2.0
              netatmo.0
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              #1000
              warum nicht ein sauberes/frisches System aufsetzen und wenn alles aktuell ist iobroker und ein Backup einspielen ?
              Der Beitrag wird ja sonst weiter aufgebläht ...
              Lehrling seit 1975 !!!
              • G Offline
                grazer75
                #1001
                @djmarc75 weil auch andere Sachen auf dem pi habe?
                Tasmotaadmin etc
                  @grazer75
                  grazer75
                  schrieb am zuletzt editiert von grazer75
                  #1002
                  @thomas-braun war er, iob stop
                  Wie gesagt gestern war das gleiche mit dem Update auf 18, waren dann Fehler auch nach dem downgrade auf 16.
                  Hab dann alles mögliche probiert und dann ging es wieder.
                  Leider nichts mitgeschrieben, sondern nur in panik google durchsucht.
                   sudo npm cache clean --force
                  sudo -H -u iobroker npm install iobroker.js-controller
                  iob fix
                  probiert.
                  Und jetzt hab ich es wieder geschafft das es geht ...
                  BLE Adapter installiert und danach wieder gelöscht und die Fehler sind weg.
                  Versteh ich irgendwie nicht ganz.
                  16er läuft wieder
                  • G grazer75
                    Tasmotaadmin etc
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    #1003
                    kann ja nicht hellsehen - dann viel Glück
                    • G grazer75
                      iob fix
                      probiert.
                      16er läuft wieder
                      #1004
                      Das ist schlecht. Also Panik.
                      Ich würde auf 18 gehen und mir dann die jeweiligen Adapter/Instanzen Stück für Stück anschauen.
                        grazer75
                        #1005
                        @thomas-braun 16er läuft wieder, weiß nicht ob es nur ble Adapter installieren und löschen war und deshalb alles wieder geht. Fehler sind alle wieder weg.
                        • G grazer75
                          iob fix
                          probiert.
                          16er läuft wieder
                          #1006
                          Du weißt schon, dass gerade der BLE-Adapter neugebaut wird? Geht i.d.R. automatisch.
                            grazer75
                            #1007
                            @thomas-braun aber das installieren von ble und deinstallieren hat die Fehler bereinigt irgendwie
                            Es geht wieder mit 16.x weiß nicht ob ich den Trick auf mit 18.x probieren sollte oder lieber froh sein das ich wieder einen funktionierenden iobroker hab ohne Fehler 🐶
                            • G grazer75
                              #1008
                              @grazer75 Hi,
                              also ich kann es nur nochmals wiederholen ... alle Fehler aus dem ioBroker Log haben NICHTS mit der Node.js Version zu tun!! Da die plötzlich bei node.js 16 weg sind und bei 18 da sind ist aber mal soooowas von unerklärbar!
                              1.) Javascript "Read-only state "javascript.0.MiHomeAll.lumi.158d0002a3299c.info.rssi" has been written ..." ist ein Fehler in einem deiner Skripte. Ein Objekt mit write:false darf nur mit ack=true beschrieben werden. Dieser Fehler KANN NICHT mit der Nodejs version zu tun haben, tut aber auch erstmal nicht weh
                              2.) Tuya connect ECONNRESET bedeutet das das Tuya-Gerät die Verbindung resettet/abgelehnt/abgebrochen hat. Kann ebenso NICHTS mit Nodejs zu tun haben
                              3.) Wifilight "(HF-LPT120) is not a known device type. Skipping this device!" ... die Meldung spricht auch für sich.
                              4.) firetv "adb executable not found. undefined" sagt das ein executable nicht da ist ...
                              ALso Wenn da vorher was tat und nach nodejs 18 nicht mehr dann ist das schon eher komisch und seehr unerklärlich. Da solltest Du denke ich mit etwas Zeit mal das Gesamtsysteme aus einem Backup restoren und neu aufsetzen und alles sauber wieder zum Laufen bekommen
                              AtifanA 1 Antwort Letzte Antwort
                              • apollon77A apollon77
                                @grazer75 Hi,
                                AtifanA Offline
                                AtifanA Offline
                                Atifan
                                schrieb am zuletzt editiert von Atifan
                                #1009
                                Hi. irgendwie komme ich nicht auf node.js 18.16.0
                                Ich mache " curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash -"
                                Danach "sudo apt-get install -y nodejs`"
                                Es ist zwar dann 18.16.0 installiert. Aber wenn ich "node -v" eingebe, dann sagt er 16.19.0
                                • AtifanA Atifan
                                  #1010
                                  @atifan
                                  Wie immer:
                                  Keine Screenshots aus der Konsole.
                                    @atifan
                                    Wie immer:
                                    AtifanA Offline
                                    AtifanA Offline
                                    Atifan
                                    #1011
                                    @thomas-braun sagte in [How-to] Node.js für ioBroker richtig updaten:
                                    @atifan
                                    Wie immer:
                                    Hm, wieso das denn? Ist das verboten? Wusste ich nicht. Aber wieso keine Screens von Console?
                                    • AtifanA Atifan
                                      @atifan
                                      Wie immer:
                                      #1012
                                      @atifan
                                      Weil man die nicht immer lesen kann, man nicht daraus kopieren kann, der Text als Bild nicht von der Suchfunktion erfasst werden kann, ein Bild fetter ist als der reine Text, usw...
                                      • AtifanA Atifan
                                        @atifan
                                        Wie immer:
                                        #1013
                                        @atifan
                                        Kannste jetzt gleich mit der Ausgabe zu
                                        sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                        uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                        üben. Ich vermute aber stark, dass da die Pfade falsch sein werden.
                                          @atifan
                                          AtifanA Offline
                                          AtifanA Offline
                                          Atifan
                                          #1014
                                          OK :) Dann hier meine Console als Code.
                                          iobroker@iobroker:~$ node -v
                                          v16.19.0
                                          iobroker@iobroker:~$ curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash
                                          ## Installing the NodeSource Node.js 18.x repo...
                                          ## Populating apt-get cache...
                                          + apt-get update
                                          Hit:1 http://ftp.debian.org/debian bullseye InRelease
                                          Hit:2 http://security.debian.org bullseye-security InRelease
                                          Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                                          Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
                                          Hit:5 https://dl.yarnpkg.com/debian stable InRelease
                                          Reading package lists... Done
                                          ## Confirming "bullseye" is supported...
                                          + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_18.x/dists/bullseye/Release'
                                          ## Adding the NodeSource signing key to your keyring...
                                          + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
                                          ## Creating apt sources list file for the NodeSource Node.js 18.x repo...
                                          + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye main' > /etc/apt/sources.list.d/nodesource.list
                                          + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list
                                          ## Running `apt-get update` for you...
                                          + apt-get update
                                          Hit:1 http://security.debian.org bullseye-security InRelease
                                          Hit:2 http://ftp.debian.org/debian bullseye InRelease
                                          Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                                          Hit:4 http://ftp.debian.org/debian bullseye-updates InRelease
                                          ## Run `sudo apt-get install -y nodejs` to install Node.js 18.x and npm
                                          ## You may also need development tools to build native addons:
                                               sudo apt-get install gcc g++ make
                                          ## To install the Yarn package manager, run:
                                               curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                                               echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                                               sudo apt-get update && sudo apt-get install yarn
                                          iobroker@iobroker:~$ sudo apt-get install -y nodejs
                                          nodejs is already the newest version (18.16.0-deb-1nodesource1).
                                          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                          v16.19.0
