  4. ioB funktioniert plötzlich nicht mehr
    5.4k
18 Beiträge 6 Kommentatoren 1.3k Aufrufe 5 Beobachtet
    @docadams https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host
    docadamsD Offline
    docadamsD Offline
    docadams
    schrieb am zuletzt editiert von docadams
    pi@iobroker4:~ $ ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep objects
    -rw-rw-r--+ 1 iobroker iobroker 4,5M Apr 11 09:19 2023-04-11_09-19_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 4,5M Apr 11 11:20 2023-04-11_11-20_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 4,5M Apr 11 13:21 2023-04-11_13-21_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 4,5M Apr 11 15:23 2023-04-11_15-23_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 4,5M Apr 11 17:28 2023-04-11_17-28_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 4,5M Apr 11 19:28 2023-04-11_19-28_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 4,5M Apr 11 21:30 2023-04-11_21-30_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 4,5M Apr 11 23:30 2023-04-11_23-30_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 4,5M Apr 12 01:32 2023-04-12_01-31_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 4,5M Apr 12 03:32 2023-04-12_03-32_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 4,5M Apr 12 05:13 2023-04-12_05-13_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 4,5M Apr 12 07:15 2023-04-12_07-15_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 4,5M Apr 12 09:15 2023-04-12_09-15_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 4,5M Apr 12 11:15 2023-04-12_11-15_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 4,5M Apr 12 13:15 2023-04-12_13-15_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 4,5M Apr 12 15:05 2023-04-12_15-05_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 4,5M Apr 12 17:08 2023-04-12_17-08_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 4,5M Apr 12 19:08 2023-04-12_19-08_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 3,5K Apr 12 20:17 2023-04-12_20-17_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 3,5K Apr 12 20:59 2023-04-12_20-59_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 3,5K Apr 12 21:27 2023-04-12_21-27_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 3,5K Apr 12 21:39 2023-04-12_21-39_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 3,5K Apr 12 22:21 2023-04-12_22-21_objects.json.gz
    -rw-rw-r--+ 1 iobroker iobroker 3,5K Apr 13 07:48 2023-04-13_07-48_objects.json.gz
    pi@iobroker4:~ $
    wäre das dann bei mir zwischen 19.08 Uhr und 20.17 Uhr? Und states sind überhaupt nicht dabei, wie im Beispiel.
    @Codierknecht
    Ja, er läuft auf SD-Karte, die History-Dateien liegen auf einem (teuren) USB-Stick.
    • docadamsD docadams
      pi@iobroker4:~ $
      @Codierknecht
      @docadams sagte in ioB funktioniert plötzlich nicht mehr:
      Ja.
      ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep states
      docadamsD 1 Antwort Letzte Antwort
        Ja.
        docadamsD Offline
        docadamsD Offline
        docadams
        Die größe der states schwankt zwischen 444K und 448K, vergrößert sich also nicht kontinuierlich. Das ist sicher normal, oder?
        Wenn ich jetzt die objects.json.gz tausche, sollte ich lieber die älteste vorhandene Datei nehmen, weil da zumindest noch keine unregelmäßigkeiten beobachtet wurden, oder wirklich die letzte vor der Verkleinerung?
        Reicht die objekts oder sollte die ähnlich alte states ebenfalls getauscht werden?
        Vorher mache ich noch ein SD-Abbild mit win32diskmanager.
          crunchipC Offline
          crunchipC Offline
          damit du den letzten funktionierenden Ist Stand hast
          ich würde die states ebenfalls zum gleichen Datum/Zeit korrigieren
            docadamsD Offline
            docadamsD Offline
            docadams
            @crunchip Datenstand oder Programmstand?
            Zu diesem Zeitpunkt war der nicht von mir initiierte Neustart und die zähe Bedienoberfläche schon gewesen. Darum frage ich. Irgend eine Ursache muss es ja haben. ioB läuft schon einige Jahre, hatte das Problem noch nie.
            Wenn es wieder läuft, möchte ich auf eine andere SD umziehen. Dann ist aber wieder das Problem mit der exakten SD-Größe. aber soweit bin ich noch nicht.
            crunchipC Thomas BraunT 2 Antworten Letzte Antwort
              crunchipC Offline
              crunchipC Offline
              Datenstand
              wie du ja schreibst, hast du nichts am iob geändert
              wie oben schon erwähnt
              @codierknecht sagte in ioB funktioniert plötzlich nicht mehr:
              Dateisystem
              solltest du, kosten ja kaum was
                Die Größe spielt doch gar keine Rolle.
                Auf neuer Karte das OS und den ioBroker installieren, Backup einspielen, fertig. Komplett unabhängig von der Größe des Dateisystems.
                  docadamsD Offline
                  docadamsD Offline
                  docadams
                  Ja, wenn ich Luft habe, werde ich es so machen und auf eine 16 GB SD umsteigen. Dann icht mein System dann endlich auch wieder aktuell.
                  Allerdings habe ich noch die Phoscon-App laufen und da habe ich noch keine Idee, wie ich die Daten für die ioBroker rüber retten kann. Ich habe da 2 farbige Signal-Lampen und fast 30 Sensoren (Taster, Kontakte, Temperaturfühler usw.) eingebunden. Da möchte ich nicht wieder bei Null anfangen...
                  FabioF 1 Antwort Letzte Antwort
                    FabioF Offline
                    FabioF Offline
                    Fabio
                    @docadams du kannst doch ganz einfach über die Phocon App ein Backup erstellen und das dann zurück spielen. https://phoscon.de/de/app/doc#settings-gateway-general-de
                    Grüße Fabio
                    Iobroker:
                    • Matter over Thread Hilfe
                    • FabioF Fabio
                      Grüße Fabio
                      docadamsD Offline
                      docadamsD Offline
                      docadams
                      @fa-bio
                      Mannnnn, im Gateway, da war ich lange nicht... Danke.
                        @fa-bio
                        FabioF Offline
                        FabioF Offline
                        Fabio
                        @docadams bitte 👍
                        Iobroker:
