  4. DCM230 und SDM230-Zähler arbeiten nicht am IOBroker Modbus
    5.3k
19 Beiträge 4 Kommentatoren 2.0k Aufrufe 2 Beobachtet
  • H helmut1963
    Ok. Sorry. Soll das so sein?
    modbus.1
    2023-04-14 20:56:46.976	info	starting. Version 3.4.17 in /opt/iobroker/node_modules/iobroker.modbus, node: v12.22.5, js-controller: 3.3.15
    host.iobroker-main-master
    2023-04-14 20:56:46.514	info	instance system.adapter.modbus.1 started with pid 3555546
    2023-04-14 20:56:45.469	info	Restart adapter system.adapter.modbus.1 because enabled
    2023-04-14 20:56:45.467	info	instance system.adapter.modbus.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    modbus.1
    2023-04-14 20:56:44.889	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    modbus.1
    2023-04-14 20:56:44.888	error	Reconnect did not help, restart adapter
    modbus.1
    2023-04-14 20:56:44.887	warn	Poll error count: 13 code: {"err":"timeout","timeout":5000}
    modbus.1
    2023-04-14 20:56:44.887	error	Client in error state.
    modbus.1
    2023-04-14 20:56:44.886	error	Request timed out.
    modbus.1
    2023-04-14 20:56:44.885	warn	Error: undefined
    modbus.1
    2023-04-14 20:56:39.883	info	Connected to slave
    modbus.1
    2023-04-14 20:56:33.882	info	Disconnected from slave 192.168.10.241
    modbus.1
    2023-04-14 20:56:32.881	warn	Poll error count: 12 code: {"err":"timeout","timeout":5000}
    modbus.1
    2023-04-14 20:56:32.881	error	Client in error state.
    modbus.1
    2023-04-14 20:56:32.880	error	Request timed out.
    modbus.1
    2023-04-14 20:56:32.880	warn	Error: undefined
    modbus.1
    2023-04-14 20:56:27.907	error	Wrong CRC for frame: 1,4,4,49,0,2,58,8,1
    modbus.1
    2023-04-14 20:56:27.878	info	Connected to slave
    modbus.1
    2023-04-14 20:56:21.876	info	Disconnected from slave 192.168.10.241
    GlasfaserG Offline
    GlasfaserG Offline
    @helmut1963 sagte in DCM230 und SDM230-Zähler arbeiten nicht am IOBroker Modbus:
    MODBUS Version 3.4.17
    Upps ...
    da ist ja alles sehr alt !
    • GlasfaserG Glasfaser
      Upps ...
      @glasfaser sagte in DCM230 und SDM230-Zähler arbeiten nicht am IOBroker Modbus:
      deswegen gibt es wahrscheinlich auch kein diag
        GlasfaserG Offline
        GlasfaserG Offline
        @homoran sagte in DCM230 und SDM230-Zähler arbeiten nicht am IOBroker Modbus:
        den hast du ja in diesem Thread ja noch nicht angefragt ... nur im neben Thread ( Vis ... Dateimanger ) :)
        H 1 Antwort Letzte Antwort
          helmut1963
          @glasfaser
          Ja, ich weiß, müsste alles mal aktualisiert werden. Aber alles andere läuft so schön stabil, wenn ich jetzt wieder in der Installation rumfummele, ist der Stress vorprogrammiert. 🙄
          Der Gleichstromzähler mit 75 mV-Shunt-Eingang wird gerade mit Spannung 0-75mV zum Simulieren befeuert. Zeigt damit absolut korrekte Werte im Display an.... 20 echte Ampere sind schwerer zu simulieren....
          HomoranH GlasfaserG Thomas BraunT 3 Antworten Letzte Antwort
          • H helmut1963
            @glasfaser
            wirklich?
            was sagt denn iob diag?
            Bitte die Vollversion!
            was hängt denn alles am Bus?
            im log ist ja der Zähler nicht zu identifizieren
            • H helmut1963
              @glasfaser
              GlasfaserG Offline
              GlasfaserG Offline
              den Gedanken würde ich mal langsam bei Seite legen ...
              dein ioBroker ist wie schon erwähnt .. sehr alt .
              • H helmut1963
                @glasfaser
                Wenn du es nicht aktuell hältst gibt es auch Stress. Früher oder später. Und je größer die Kluft zwischen den Versionen wird umso größer wird auch dieser Stress werden.
                  wirklich?
                  helmut1963
                  So, ich hab den Schritt gewagt und alles auf ich denke halbwegs aktuellen Stand gebracht, dabei Blut und Wasser geschwitzt... Zuerst lief das Log in orange und rot über.....Alle Datenpunkte des Wechselrichter-Modbus mussten überall neu verdrahtet werden....Ich hoffe nun ist alles erstmal in Reihe.
                  Das Ursprungsproblem löste dieses Aktion aber leider nicht....Die Einträge im Log für Instanz modbus.1 sind exact die gleichen....
                  Am Bus (verdrilltes Kabel, A+ / B+, 30 cm) nach dem Konverter hängt nur der Zähler (abwechselnd beide zum Testen) abgeschlossen mit 120 Ohm.
                  iob diag? Meinst Du damit dies: ? (Für mich das meiste Chinesisch.....)
                  Halt. Beim Einfügen des ellenlangen Textes sagt System: ERROR - Forbidden... Keine Ahnung warum. Ich versuchs morgen nochmal. Konzentration ist für heute dahin....
                  H Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                  • H helmut1963
                    helmut1963
                    Skript v.2023-04-02
                    *** BASE SYSTEM ***
                    Architecture    : x86_64
                    Docker          : false
                    Virtualization  : lxc
                    Distributor ID: Debian
                    Description:    Debian GNU/Linux 10 (buster)
                    Release:        10
                    Codename:       buster
                    PRETTY_NAME="Debian GNU/Linux 10 (buster)"
                    NAME="Debian GNU/Linux"
                    VERSION_ID="10"
                    VERSION="10 (buster)"
                    VERSION_CODENAME=buster
                    ID=debian
                    HOME_URL="https://www.debian.org/"
                    SUPPORT_URL="https://www.debian.org/support"
                    BUG_REPORT_URL="https://bugs.debian.org/"
                    Systemuptime and Load:
                     21:14:41 up 79 days, 13:59,  1 user,  load average: 0.73, 0.50, 0.48
                    CPU threads: 4
                    *** Time and Time Zones ***
                                   Local time: Fri 2023-04-14 21:14:41 UTC
                               Universal time: Fri 2023-04-14 21:14:41 UTC
                                     RTC time: n/a
                                    Time zone: Etc/UTC (UTC, +0000)
                                  NTP service: inactive
                              RTC in local TZ: no
                    *** User and Groups ***
                    root
                    /root
                    root
                    *** X-Server-Setup ***
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:           7.9G        1.2G        6.2G         23M        520M        6.7G
                    Swap:            0B          0B          0B
                    Total:         7.9G        1.2G        6.2G
                             7879 M total memory
                             1172 M used memory
                              357 M active memory
                             1214 M inactive memory
                             6186 M free memory
                                0 M buffer memory
                              520 M swap cache
                                0 M total swap
                                0 M used swap
                                0 M free swap
                    *** FILESYSTEM ***
                    Filesystem                       Type      Size  Used Avail Use% Mounted on
                    /dev/mapper/pve-vm--100--disk--1 ext4       24G   11G   13G  47% /
                    none                             tmpfs     492K  4.0K  488K   1% /dev
                    udev                             devtmpfs  3.9G     0  3.9G   0% /dev/tty
                    tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
                    tmpfs                            tmpfs     3.9G   25M  3.9G   1% /run
                    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                    tmpfs                            tmpfs     788M     0  788M   0% /run/user/0
                    dmesg: read kernel buffer failed: Operation not permitted
                    TARGET                           SOURCE                                FSTYPE     OPTIONS
                    /                                /dev/mapper/pve-vm--100--disk--1      ext4       rw,relatime,stripe=16
                    |-/proc/cpuinfo                  lxcfs[/proc/cpuinfo]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    |-/proc/diskstats                lxcfs[/proc/diskstats]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    |-/proc/loadavg                  lxcfs[/proc/loadavg]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    |-/proc/meminfo                  lxcfs[/proc/meminfo]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    |-/proc/stat                     lxcfs[/proc/stat]                     fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    |-/proc/swaps                    lxcfs[/proc/swaps]                    fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    |-/proc/uptime                   lxcfs[/proc/uptime]                   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    `-/sys/devices/system/cpu/online lxcfs[/sys/devices/system/cpu/online] fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    /var:
                    407M    /var/
                    207M    /var/cache
                    203M    /var/cache/apt
                    179M    /var/lib
                    141M    /var/cache/apt/archives
                    /opt/iobroker/backups:
                    4.8G    /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    2.6G    /opt/iobroker/iobroker-data/
                    2.3G    /opt/iobroker/iobroker-data/history
                    197M    /opt/iobroker/iobroker-data/files
                    64M     /opt/iobroker/iobroker-data/backup-objects
                    53M     /opt/iobroker/iobroker-data/files/javascript.admin
                    20M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.map
                    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                    14M     /opt/iobroker/iobroker-data/influxdata.json
                    13M     /opt/iobroker/iobroker-data/objects.jsonl
                    12M     /opt/iobroker/iobroker-data/objects.json.migrated
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v14.21.3
                    /usr/bin/node           v14.21.3
                    /usr/bin/npm            6.14.18
                    /usr/bin/npx            6.14.18
                    nodejs:
                      Installed: 14.21.3-deb-1nodesource1
                      Candidate: 14.21.3-deb-1nodesource1
                      Version table:
                     *** 14.21.3-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_14.x buster/main amd64 Packages
                         10.24.0~dfsg-1~deb10u3 500
                            500 http://security.debian.org buster/updates/main amd64 Packages
                         10.24.0~dfsg-1~deb10u1 500
                            500 http://ftp.debian.org/debian buster/main amd64 Packages
                    No problems detected
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Core adapters versions
                    js-controller:  4.0.24
                    admin:          6.4.3
                    javascript:     7.0.3
                    npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1
                    npm ERR! peer dep missing: onvif@^0.5.5, required by onvif-snapshot@1.0.3
                    Adapters from github:   3
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : iobroker-main-master                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      system.adapter.alexa2.0                 : alexa2                : iobroker-main-master                     - disabled
                    + system.adapter.backitup.0               : backitup              : iobroker-main-master                     -  enabled
                      system.adapter.daswetter.0              : daswetter             : iobroker-main-master                     -  enabled
                    + system.adapter.discovery.0              : discovery             : iobroker-main-master                     -  enabled
                      system.adapter.dwd.0                    : dwd                   : iobroker-main-master                     -  enabled
                      system.adapter.email.0                  : email                 : iobroker-main-master                     - disabled
                      system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-main-master                     - disabled
                      system.adapter.flot.0                   : flot                  : iobroker-main-master                     - disabled
                    + system.adapter.fritzbox.0               : fritzbox              : iobroker-main-master                     -  enabled
                    + system.adapter.history.0                : history               : iobroker-main-master                     -  enabled
                    + system.adapter.hm-rega.0                : hm-rega               : iobroker-main-master                     -  enabled
                    + system.adapter.hm-rega.1                : hm-rega               : iobroker-main-master                     -  enabled
                    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-main-master                     -  enabled, port: 0
                    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-main-master                     -  enabled, port: 0
                    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-main-master                     -  enabled, port: 0
                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-main-master                     -  enabled
                      system.adapter.influxdb.0               : influxdb              : iobroker-main-master                     - disabled, port: 8086
                      system.adapter.iot.0                    : iot                   : iobroker-main-master                     - disabled
                    + system.adapter.javascript.0             : javascript            : iobroker-main-master                     -  enabled
                      system.adapter.mbus.0                   : mbus                  : iobroker-main-master                     - disabled, port: 502
                    + system.adapter.modbus.0                 : modbus                : iobroker-main-master                     -  enabled
                    + system.adapter.modbus.1                 : modbus                : iobroker-main-master                     -  enabled
                      system.adapter.nina.0                   : nina                  : iobroker-main-master                     - disabled
                      system.adapter.nut.0                    : nut                   : iobroker-main-master                     - disabled
                      system.adapter.odl.0                    : odl                   : iobroker-main-master                     - disabled
                      system.adapter.onvif.0                  : onvif                 : iobroker-main-master                     - disabled
                    + system.adapter.proxmox.0                : proxmox               : iobroker-main-master                     -  enabled, port: 8006
                      system.adapter.ring.0                   : ring                  : iobroker-main-master                     - disabled
                    + system.adapter.shelly.0                 : shelly                : iobroker-main-master                     -  enabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.socketio.0               : socketio              : iobroker-main-master                     -  enabled, port: 8084, bind: 192.168.10.219, run as: admin
                    + system.adapter.telegram.0               : telegram              : iobroker-main-master                     -  enabled, port: 8443, bind: 0.0.0.0
                      system.adapter.tr-064.0                 : tr-064                : iobroker-main-master                     - disabled
                      system.adapter.tradfri.0                : tradfri               : iobroker-main-master                     - disabled
                      system.adapter.trashschedule.0          : trashschedule         : iobroker-main-master                     - disabled
                      system.adapter.unifi-protect.0          : unifi-protect         : iobroker-main-master                     - disabled
                      system.adapter.vis-history.0            : vis-history           : iobroker-main-master                     - disabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-main-master                     - disabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-main-master                     - disabled
                      system.adapter.vis.0                    : vis                   : iobroker-main-master                     -  enabled
                    + system.adapter.web.0                    : web                   : iobroker-main-master                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + instance is alive
                    ioBroker-Repositories
                    Active repo(s): beta
                    Installed ioBroker-Instances
                    Used repository: beta
                    Adapter    "admin"        : 6.4.3    , installed 6.4.3
                    Adapter    "alexa2"       : 3.23.2   , installed 3.3.1  [Updatable]
                    Adapter    "backitup"     : 2.6.17   , installed 2.6.17
                    Adapter    "daswetter"    : 3.1.8    , installed 3.0.1  [Updatable]
                    Adapter    "discovery"    : 3.1.0    , installed 2.7.0  [Updatable]
                    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                    Adapter    "email"        : 1.1.4    , installed 1.0.7  [Updatable]
                    Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
                    Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
                    Adapter    "history"      : 2.2.4    , installed 2.2.4
                    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
                    Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
                    Adapter    "iot"          : 1.14.5   , installed 1.14.5
                    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
                    Adapter    "mbus"         : 2.4.0    , installed 2.4.0
                    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                    Adapter    "nina"         : 0.0.25   , installed 0.0.22 [Updatable]
                    Adapter    "nut"          : 1.6.0    , installed 1.6.0
                    Adapter    "odl"          : 2.0.5    , installed 1.0.5  [Updatable]
                    Adapter    "onvif"        : 1.0.5    , installed 0.0.2  [Updatable]
                    Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
                    Adapter    "ring"         : 3.3.0    , installed 1.1.3  [Updatable]
                    Adapter    "shelly"       : 6.4.0    , installed 4.0.8  [Updatable]
                    Adapter    "socketio"     : 6.3.5    , installed 6.3.5
                    Adapter    "telegram"     : 1.15.6   , installed 1.15.6
                    Adapter    "tradfri"      : 3.1.3    , installed 3.1.2  [Updatable]
                    Adapter    "trashschedule": 2.2.0    , installed 0.0.11 [Updatable]
                    Adapter    "unifi-protect": 0.0.13   , installed 0.0.11 [Updatable]
                    Adapter    "vis-hqwidgets": 1.3.1    , installed 1.3.1
                    Adapter    "web"          : 5.5.3    , installed 5.5.3
                    Adapter    "ws"           : 2.3.6    , installed 2.3.6
                    Objects and States
                    Objects:        8857
                    States:         7354
                    Hit:1 http://security.debian.org buster/updates InRelease
                    Hit:2 http://ftp.debian.org/debian buster InRelease
                    Hit:3 http://ftp.debian.org/debian buster-updates InRelease
                    Hit:4 https://deb.nodesource.com/node_14.x buster InRelease
                    Reading package lists...
                    Pending Updates: 0
                    *** Listening Ports ***
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       199270240  3585075/iobroker.js
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       199270233  3585075/iobroker.js
                    tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      105        199235807  3575373/systemd-res
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          30286      1/systemd
                    tcp        0      0 192.168.10.219:2000     0.0.0.0:*               LISTEN      1000       199274100  3585209/io.hm-rpc.1
                    tcp        0      0 192.168.10.219:2001     0.0.0.0:*               LISTEN      1000       199272164  3585194/io.hm-rpc.0
                    tcp        0      0 192.168.10.219:2002     0.0.0.0:*               LISTEN      1000       199274194  3585239/io.hm-rpc.2
                    tcp        0      0 192.168.10.219:8084     0.0.0.0:*               LISTEN      1000       199276621  3585359/io.socketio
                    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      105        199235813  3575373/systemd-res
                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          199238426  3577902/master
                    tcp6       0      0 :::5355                 :::*                    LISTEN      105        199235810  3575373/systemd-res
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          30288      1/systemd
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       199270313  3585096/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       199276671  3585374/io.web.0
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          30464      1/systemd
                    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          199238427  3577902/master
                    udp        0      0 127.0.0.53:53           0.0.0.0:*                           105        199235812  3575373/systemd-res
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          30287      1/systemd
                    udp        0      0 0.0.0.0:5355            0.0.0.0:*                           105        199235806  3575373/systemd-res
                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       199273427  3585329/io.shelly.0
                    udp6       0      0 :::111                  :::*                                0          30289      1/systemd
                    udp6       0      0 :::5355                 :::*                                105        199235809  3575373/systemd-res
                    2023-04-14 21:14:30.976  - info: modbus.1 (3589548) Disconnected from slave 192.168.10.241
                    2023-04-14 21:14:36.978  - info: modbus.1 (3589548) Connected to slave
                    2023-04-14 21:14:41.980  - warn: modbus.1 (3589548) Error: undefined
                    2023-04-14 21:14:41.981  - error: modbus.1 (3589548) Request timed out.
                    2023-04-14 21:14:41.981  - error: modbus.1 (3589548) Client in error state.
                    2023-04-14 21:14:41.981  - warn: modbus.1 (3589548) Poll error count: 9 code: {"err":"timeout","timeout":5000}
                    2023-04-14 21:14:42.981  - info: modbus.1 (3589548) Disconnected from slave 192.168.10.241
                    2023-04-14 21:14:48.982  - info: modbus.1 (3589548) Connected to slave
                    2023-04-14 21:14:49.010  - error: modbus.1 (3589548) Wrong CRC for frame: 1,4,4,49,0,2,58,8,1
                    2023-04-14 21:14:53.983  - warn: modbus.1 (3589548) Error: undefined
                    2023-04-14 21:14:53.984  - error: modbus.1 (3589548) Request timed out.
                    2023-04-14 21:14:53.984  - error: modbus.1 (3589548) Client in error state.
                    2023-04-14 21:14:53.985  - warn: modbus.1 (3589548) Poll error count: 10 code: {"err":"timeout","timeout":5000}
                    2023-04-14 21:14:54.984  - info: modbus.1 (3589548) Disconnected from slave 192.168.10.241
                    2023-04-14 21:15:00.030  - info: host.iobroker-main-master instance system.adapter.dwd.0 started with pid 3589829
                    2023-04-14 21:15:00.640  - info: dwd.0 (3589829) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.21.3, js-controller: 4.0.24
                    2023-04-14 21:15:00.665  - warn: dwd.0 (3589829) No geo coordinates found in iobroker system configuration. Disable Rain Radar.
                    2023-04-14 21:15:00.986  - info: modbus.1 (3589548) Connected to slave
                    2023-04-14 21:15:01.058  - info: dwd.0 (3589829) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-04-14 21:15:01.585  - info: host.iobroker-main-master instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-04-14 21:15:04.043  - info: host.iobroker-main-master instance system.adapter.daswetter.0 started with pid 3590135
                    2023-04-14 21:15:04.652  - info: daswetter.0 (3590135) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.21.3, js-controller: 4.0.24
                    2023-04-14 21:15:04.668  - info: daswetter.0 (3590135) Terminated (NO_ERROR): Without reason
                    2023-04-14 21:15:05.175  - info: daswetter.0 (3590135) cleaned everything up...
                    2023-04-14 21:15:05.180  - info: host.iobroker-main-master instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                    • H helmut1963
                      F5 drücken, dann geht es.
                        helmut1963
                        ...habs gerade gemerkt und nachgeschoben.
                        • H helmut1963
                          Skript v.2023-04-02
                          *** BASE SYSTEM ***
                          Docker          : false
                          Release:        10
                          Codename:       buster
                          VERSION_ID="10"
                          ID=debian
                          CPU threads: 4
                                           RTC time: n/a
                                    RTC in local TZ: no
                          root
                          /root
                          root
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:            0B          0B          0B
                                   7879 M total memory
                                   1172 M used memory
                                    357 M active memory
                                   6186 M free memory
                                      0 M buffer memory
                                    520 M swap cache
                                      0 M total swap
                                      0 M used swap
                                      0 M free swap
                          *** FILESYSTEM ***
                          /var:
                          407M    /var/
                          207M    /var/cache
                          203M    /var/cache/apt
                          179M    /var/lib
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.4.3
                          javascript:     7.0.3
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        8857
                          States:         7354
                          Pending Updates: 0
                          buster
                          Ist nicht mehr aktuell, das wäre 'bullseye'.
                          Keine Zeitzone gesetzt.
                          root
                          Nicht als root herumkaspern, man verwendet einen Standarduser.
                          nodejs v14.21.3
                          Zwar richtig installiert, die empfohlene Version wäre allerdings v18.
                          Dürfte sich auch mit nodejs v18 ergeben.
                          Bring die ganzen Adapter auf Stand. Ich würde dir allerdings vom Beta-Repository abraten und stable empfehlen. Da muss man auch weniger Updates einspielen.
                          • H helmut1963
                            und den hast du mal vollständig stromlos gemacht?
                            nimm mal nur den SDM und lass den Widerstand weg.
                            Waveshare RS485 / TCP) Adapter mit IP
                            den kenn ich nicht. weiss nicht was da zu konfigurieren ist.
                              helmut1963
                              So Leute, an alle die mitgeholfen haben: Vielen Dank !
                              Nach einer halb schlaflosen Nacht, den ganzen Updates und viel Herumprobiererei spricht zumindest mal der AC-Zähler auf einem Datenpunkt mit mir, Dh. der Iobroker hält nun die Verbindung und fragt in den eingestellten Abständen den Zähler ab und liefert sogar den richtigen Wert.... ("Spannung_DC-Panel" stammt noch vom Probieren, wird noch geändert...)
                              Das Datenformat ist übrigens "Float (Big Endian)...
                              Da ich keinen anderen Grund erkennen kann, bleibt als Ursache tatsächlich nur die veraltete Installation.
                              Danke für`s Anstacheln, das Update endlich anzupacken. Liegt mir schon lange auf dem Magen.
                              Ich denke da wird die endgültige Installation in der Backup-PV-Anlage mit den restlichen Datenpunkten schon irgendwie funktionieren. Ansonsten hört Ihr wieder von mir ;-)
                              Wen`s interessiert: https://www.qrz.com/db/DL1HJA und ein bisschen runterscrollen bis zum PV-Beitrag.
                              Grüße, Helmut
