    6.4k
7.5k Beiträge 335 Kommentatoren 11.6m Aufrufe 254 Beobachtet
  • F firebowl
    @firebowl Hmm, etz bringt die stable auch die Loops. Bei mir hat sich aber nicht wirklich was geändert.
    somansch
    #5595
    @simatec ,
    habe gestern auch die 1.4.25 eingespielt, leider auch Absturz des Adapters:
    host.iobroker
    2023-04-14 07:45:02.809	error	instance system.adapter.shuttercontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.iobroker
    2023-04-14 07:45:02.809	error	Caught by controller[1]: at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:843:92)
    host.iobroker
    2023-04-14 07:45:02.809	error	Caught by controller[1]: TypeError: Cannot read properties of null (reading 'val')
    host.iobroker
    2023-04-14 07:45:02.808	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    shuttercontrol.0
    2023-04-14 07:45:02.219	error	Cannot read properties of null (reading 'val')
    shuttercontrol.0
    2023-04-14 07:45:02.219	error	TypeError: Cannot read properties of null (reading 'val') at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:843:92)
    shuttercontrol.0
    2023-04-14 07:45:02.216	error	unhandled promise rejection: Cannot read properties of null (reading 'val')
    shuttercontrol.0
    2023-04-14 07:45:02.215	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.iobroker
    2023-04-14 07:40:02.896	error	instance system.adapter.shuttercontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.iobroker
    2023-04-14 07:40:02.896	error	Caught by controller[0]: at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:843:92)
    host.iobroker
    2023-04-14 07:40:02.896	error	Caught by controller[0]: TypeError: Cannot read properties of null (reading 'val')
    host.iobroker
    2023-04-14 07:40:02.895	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    shuttercontrol.0
    2023-04-14 07:40:02.285	error	Cannot read properties of null (reading 'val')
    shuttercontrol.0
    2023-04-14 07:40:02.285	error	TypeError: Cannot read properties of null (reading 'val') at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:843:92)
    shuttercontrol.0
    2023-04-14 07:40:02.281	error	unhandled promise rejection: Cannot read properties of null (reading 'val')
    shuttercontrol.0
    2023-04-14 07:40:02.280	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.iobroker
    2023-04-14 07:35:03.397	error	instance system.adapter.shuttercontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.iobroker
    2023-04-14 07:35:03.397	error	Caught by controller[0]: at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:843:92)
    host.iobroker
    2023-04-14 07:35:03.397	error	Caught by controller[0]: TypeError: Cannot read properties of null (reading 'val')
    host.iobroker
    2023-04-14 07:35:03.397	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    shuttercontrol.0
    2023-04-14 07:35:02.806	error	Cannot read properties of null (reading 'val')
    shuttercontrol.0
    2023-04-14 07:35:02.806	error	TypeError: Cannot read properties of null (reading 'val') at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:843:92)
    shuttercontrol.0
    2023-04-14 07:35:02.770	error	unhandled promise rejection: Cannot read properties of null (reading 'val')
    shuttercontrol.0
    2023-04-14 07:35:02.727	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Wie kann ich auf die 1.4.22 zurückwechseln?
    W simatecS 2 Antworten Letzte Antwort
    • S somansch
      @simatec ,
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      W Offline
      W Offline
      WeiserWolf
      #5596
      @somansch Du kannst über Adapter --> die drei blauen Punkte --> das Icon unten rechts "eine besteimmte Version installieren" auswählen und dort dann die 1.4.22 "drüberbügeln"
      • S somansch
        @simatec ,
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        simatecS Offline
        simatecS Offline
        simatec
        #5597
        @somansch @firebowl Bitte die v1.4.26 nehmen .. in der 25 hat sich ein fehler eingeschlichen ...
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
          MartyBr
          #5598
          @simatec
          Hallo @simatec , auf meinem Produktivsystem fahre ich die Version 1.4.18, die einwandfrei läuft.
          Auf dem Testsystem habe ich nun die 1.4.26 installiert. Dort habe ich die gleichen Fehler wie mit den Versionen auf der 1.4.23.
          Ich habe dort keinen Aktor sondern nur einen Datenpunkt eingetragen. Damit dürfte dort keine Veränderung durch einen Aktor erfolgen. Trotzdem spring die Anzeige immer auf Manu_mode:
          Hier das Log:
          shuttercontrol.0
          2023-04-14 11:35:02.183	debug	Sunprotect Rollos.Rollo1 old height: 100% new height: 50%
          shuttercontrol.0
          2023-04-14 11:35:02.183	debug	last automatic Action for Rollos.Rollo1: down_Sunprotect
          shuttercontrol.0
          2023-04-14 11:35:02.183	debug	RangeMinus: 135 < 148.1RangePlus: 225 > 148.1
          shuttercontrol.0
          2023-04-14 11:35:02.182	debug	Sunprotect for Rollos.Rollo1 is active
          shuttercontrol.0
          2023-04-14 11:35:02.141	debug	Rollos.Rollo1 drived manually to 50. Old value = 100. New value = 50
          shuttercontrol.0
          2023-04-14 11:35:02.140	debug	Rollos.Rollo1 Updated trigger action to Manu_Mode to prevent moving after window close
          shuttercontrol.0
          2023-04-14 11:35:02.089	debug	#2 currentShutterStateTime: 5 seconds
          shuttercontrol.0
          2023-04-14 11:35:02.089	debug	#2 currentShutterState: disabled
          shuttercontrol.0
          2023-04-14 11:35:02.089	debug	#2 oldHeight: 100 %
          shuttercontrol.0
          2023-04-14 11:35:02.089	debug	#2 currentHeight: 50 %
          shuttercontrol.0
          2023-04-14 11:35:02.088	debug	#2 triggerAction: Manu_Mode
          shuttercontrol.0
          2023-04-14 11:35:02.088	debug	#2 currentAction: Manu_Mode
          shuttercontrol.0
          2023-04-14 11:35:02.088	debug	#2 shutterState: 50 %
          shuttercontrol.0
          2023-04-14 11:35:02.088	debug	#2 shutterName: Rollos.Rollo1
          shuttercontrol.0
          2023-04-14 11:35:02.088	debug	Shutter state changed: Rollos.Rollo1 old value = 100 new value = 50
          shuttercontrol.0
          2023-04-14 11:35:02.087	debug	#0 wait for shutter check end
          shuttercontrol.0
          2023-04-14 11:35:02.076	debug	#0 wait for shutter check started
          shuttercontrol.0
          2023-04-14 11:35:02.030	info	Sunprotect #416 Set ID: Rollos.Rollo1 value: 50%
          shuttercontrol.0
          2023-04-14 11:35:02.030	debug	Rollos.Rollo1: Check basis for sunprotect. Height:100 > HeightDownSun: 50 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
          shuttercontrol.0
          2023-04-14 11:35:00.013	debug	Sun Elevation: 42.7°
          shuttercontrol.0
          2023-04-14 11:35:00.013	debug	Sun Azimut: 148.1°
          shuttercontrol.0
          2023-04-14 11:35:00.013	debug	calculate astrodata ...
          shuttercontrol.0
          2023-04-14 11:32:35.719	debug	Shuttercontrol save all shutter states
          shuttercontrol.0
          2023-04-14 11:32:25.717	debug	shutterUpButton Rollos.Rollo1 old height: 100% new height: 100%
          shuttercontrol.0
          2023-04-14 11:32:25.670	debug	#0 wait for shutter check end
          shuttercontrol.0
          2023-04-14 11:32:25.660	debug	#0 wait for shutter check started
          shuttercontrol.0
          2023-04-14 11:32:25.616	info	Button openAll Set ID: Rollos.Rollo1 value: 100%
          shuttercontrol.0
          2023-04-14 11:32:25.614	debug	start buttonAction
          shuttercontrol.0
          2023-04-14 11:31:52.071	debug	complete down at 22:00
          shuttercontrol.0
          2023-04-14 11:31:52.070	debug	Shutdown shutters sleep area: 20:03 debug 4
          shuttercontrol.0
          2023-04-14 11:31:52.068	debug	Shutdown shutters children area: 20:03 debug 4
          shuttercontrol.0
          2023-04-14 11:31:52.067	debug	shutterDownLiving
          shuttercontrol.0
          2023-04-14 11:31:52.067	debug	Shutdown shutters living area: 20:03 debug 4
          shuttercontrol.0
          2023-04-14 11:31:52.067	debug	yes, IsLater : 21:15 20:03
          shuttercontrol.0
          2023-04-14 11:31:52.067	debug	check IsLater : 21:15 20:03
          shuttercontrol.0
          2023-04-14 11:31:52.067	debug	check IsEarlier : 21:15 20:03
          shuttercontrol.0
          2023-04-14 11:31:52.064	debug	Starting up shutters children area: 06:13 debug 5
          shuttercontrol.0
          2023-04-14 11:31:52.064	debug	yes, IsEarlier : 06:13 06:30
          shuttercontrol.0
          2023-04-14 11:31:52.064	debug	check IsEarlier : 06:13 06:30
          shuttercontrol.0
          2023-04-14 11:31:52.064	debug	yes, IsLater : 06:13 06:00
          shuttercontrol.0
          2023-04-14 11:31:52.064	debug	check IsLater : 06:13 06:00
          shuttercontrol.0
          2023-04-14 11:31:52.063	debug	check IsLater : 06:13 06:30
          shuttercontrol.0
          2023-04-14 11:31:52.061	debug	Starting up shutters sleep area: 06:13 debug 5
          shuttercontrol.0
          2023-04-14 11:31:52.061	debug	yes, IsEarlier : 06:13 06:30
          shuttercontrol.0
          2023-04-14 11:31:52.061	debug	check IsEarlier : 06:13 06:30
          shuttercontrol.0
          2023-04-14 11:31:52.061	debug	yes, IsLater : 06:13 06:00
          shuttercontrol.0
          2023-04-14 11:31:52.061	debug	check IsLater : 06:13 06:00
          shuttercontrol.0
          2023-04-14 11:31:52.060	debug	check IsLater : 06:13 06:30
          shuttercontrol.0
          2023-04-14 11:31:52.059	debug	Starting up shutters living area: 07:00 debug 8
          shuttercontrol.0
          2023-04-14 11:31:52.058	debug	yes, IsEarlier : 06:13 07:00
          shuttercontrol.0
          2023-04-14 11:31:52.058	debug	check IsEarlier : 06:13 07:00
          shuttercontrol.0
          2023-04-14 11:31:52.058	debug	check IsEqual : 06:13 09:00
          shuttercontrol.0
          2023-04-14 11:31:52.058	debug	check IsEqual : 07:00 09:00
          shuttercontrol.0
          2023-04-14 11:31:52.058	debug	check IsLater : 06:13 07:00
          shuttercontrol.0
          2023-04-14 11:31:52.057	debug	check IsLater : 06:13 09:00
          shuttercontrol.0
          2023-04-14 11:31:52.047	debug	Shutdown shutters Sunset area: 20:03
          shuttercontrol.0
          2023-04-14 11:31:52.047	debug	Starting up shutters Sunrise area: 06:13
          shuttercontrol.0
          2023-04-14 11:31:52.046	debug	Shutdown shutters GoldenHour area: 19:17
          shuttercontrol.0
          2023-04-14 11:31:52.046	debug	Starting up shutters GoldenHour area: 06:59
          shuttercontrol.0
          2023-04-14 11:31:52.046	debug	Sunset today: 20:03
          shuttercontrol.0
          2023-04-14 11:31:52.046	debug	Sunrise today: 06:13
          shuttercontrol.0
          2023-04-14 11:31:52.046	debug	current day: 5
          shuttercontrol.0
          2023-04-14 11:31:52.045	debug	goldenHour today: 19:17
          shuttercontrol.0
          2023-04-14 11:31:52.045	debug	goldenHourEnd today: 06:59
          shuttercontrol.0
          2023-04-14 11:31:52.045	debug	calculate astrodata ...
          shuttercontrol.0
          2023-04-14 11:31:52.044	debug	Travel times of the shutters are calculated
          shuttercontrol.0
          2023-04-14 11:31:48.846	debug	Rollos_Rollo1: save settings
          shuttercontrol.0
          2023-04-14 11:31:48.836	debug	Shutter State: 0_userdata.0.Rollos.Rollo1
          shuttercontrol.0
          2023-04-14 11:31:48.834	debug	shutter Config Check successfully completed
          shuttercontrol.0
          2023-04-14 11:31:48.834	debug	shutter Config Check started
          shuttercontrol.0
          2023-04-14 11:31:48.819	info	starting. Version 1.4.26 (non-npm: simatec/ioBroker.shuttercontrol) in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.16.0, js-controller: 4.0.24
          shuttercontrol.0
          2023-04-14 11:31:48.539	debug	Plugin sentry Initialize Plugin (enabled=true)
          shuttercontrol.0
          2023-04-14 11:31:48.448	debug	States connected to redis: 127.0.0.1:9000
          shuttercontrol.0
          2023-04-14 11:31:48.376	debug	States create User PubSub Client
          shuttercontrol.0
          2023-04-14 11:31:48.375	debug	States create System PubSub Client
          shuttercontrol.0
          2023-04-14 11:31:48.361	debug	Redis States: Use Redis connection: 127.0.0.1:9000
          shuttercontrol.0
          2023-04-14 11:31:48.340	debug	Objects connected to redis: 127.0.0.1:9001
          shuttercontrol.0
          2023-04-14 11:31:48.337	debug	Objects client initialize lua scripts
          shuttercontrol.0
          2023-04-14 11:31:48.296	debug	Objects create User PubSub Client
          shuttercontrol.0
          2023-04-14 11:31:48.295	debug	Objects create System PubSub Client
          shuttercontrol.0
          2023-04-14 11:31:48.295	debug	Objects client ready ... initialize now
          shuttercontrol.0
          2023-04-14 11:31:48.268	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
          Hier die JSON:
          system.adapter.shuttercontrol.0.json
          Martin
          Homematic und Homematic IP
          • simatecS simatec
            @radi So geht es auch ... Man kann nie mit einem Adapter dieser Art alle Userwünsche erschlagen. Irgendwann ist er nicht mehr Bedienbar ...
            Dafür gibt es den Javascript Adapter. Hier kann jeder alles nach seinen Wünschen anpassen und Shuttercontrol bietet dafür genug Schnittstellen
            SchmakusS Offline
            SchmakusS Offline
            Schmakus
            #5599
            @simatec Vielleicht wäre es von Vorteil, wenn die Werte anstatt über die GUI, als Datenpunkte vorhanden wären. So könnte man mit eigenen Zeitplänen und Scripte vieles individuell gestalten. So mache ich es auch beim LightControl.
            So ließe sich z.b. die Behanghöhe in Abhängigkeit der Anwesenheit einstellen, usw.
            Das würde aber bedeuten, dass einiges am Code geändert werden müsste, was vielleicht für eine 3.0 sprechen würde.
            Dev of LightControl Adapter, Contributor of HUE and DoorBird Adapter
            • SchmakusS Schmakus
              simatecS Offline
              simatecS Offline
              simatec
              #5600
              @schmakus Ist nicht so gplant, da das Konzept von Shuttercontrol ein anderes ist.
              Über Datenpunkte verliert man meiner Meinung nach an Userfreundlichkeit. Ist aber ne Geschmackssache
              • M MartyBr
                @simatec
                Hier das Log:
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                Hier die JSON:
                simatecS Offline
                simatecS Offline
                simatec
                #5601
                @martybr Verstehe deine Konstellation nicht und der Log ist leider unvollständig ... Ich sehe nicht die eigentlich Fahrt auf 50% in den Sonnenschutz
                • simatecS simatec
                  MartyBr
                  #5602
                  @simatec
                  Die Konstellation im Test-System ist recht einfach: Ich habe dort keinen echten Aktor sondern beschreibe einen DP mit dem Level.
                  Da dort kein weiterer Prozess zugreift, dürfte sich der DP nicht ändern und damit Shuttercontrol niemals in den Modus "manu_mode" gelangen.
                  Sunprotect lasse ich einfach per Azimuth schalten "180° plus/minus".
                  Er ist auch in den Modus "Sonnenschutz==50%) gefahren, hat aber sofort auch manu_mode gewechselt.
                  Ich setze den Sonnenschutz neu und lege dann die Log bei.
                  Martin
                  • M MartyBr
                    @simatec
                    MartyBr
                    #5603
                    @martybr
                    Log 1:
                    Start Shutter:
                    shuttercontrol.0
                    2023-04-14 13:38:56.911	debug	complete down at 22:00
                    shuttercontrol.0
                    2023-04-14 13:38:56.909	debug	Shutdown shutters sleep area: 20:03 debug 4
                    shuttercontrol.0
                    2023-04-14 13:38:56.907	debug	Shutdown shutters children area: 20:03 debug 4
                    shuttercontrol.0
                    2023-04-14 13:38:56.905	debug	shutterDownLiving
                    shuttercontrol.0
                    2023-04-14 13:38:56.905	debug	Shutdown shutters living area: 20:03 debug 4
                    shuttercontrol.0
                    2023-04-14 13:38:56.905	debug	yes, IsLater : 21:15 20:03
                    shuttercontrol.0
                    2023-04-14 13:38:56.905	debug	check IsLater : 21:15 20:03
                    shuttercontrol.0
                    2023-04-14 13:38:56.904	debug	check IsEarlier : 21:15 20:03
                    shuttercontrol.0
                    2023-04-14 13:38:56.901	debug	Starting up shutters children area: 06:13 debug 5
                    shuttercontrol.0
                    2023-04-14 13:38:56.900	debug	yes, IsEarlier : 06:13 06:30
                    shuttercontrol.0
                    2023-04-14 13:38:56.900	debug	check IsEarlier : 06:13 06:30
                    shuttercontrol.0
                    2023-04-14 13:38:56.900	debug	yes, IsLater : 06:13 06:00
                    shuttercontrol.0
                    2023-04-14 13:38:56.900	debug	check IsLater : 06:13 06:00
                    shuttercontrol.0
                    2023-04-14 13:38:56.900	debug	check IsLater : 06:13 06:30
                    shuttercontrol.0
                    2023-04-14 13:38:56.896	debug	Starting up shutters sleep area: 06:13 debug 5
                    shuttercontrol.0
                    2023-04-14 13:38:56.896	debug	yes, IsEarlier : 06:13 06:30
                    shuttercontrol.0
                    2023-04-14 13:38:56.896	debug	check IsEarlier : 06:13 06:30
                    shuttercontrol.0
                    2023-04-14 13:38:56.896	debug	yes, IsLater : 06:13 06:00
                    shuttercontrol.0
                    2023-04-14 13:38:56.895	debug	check IsLater : 06:13 06:00
                    shuttercontrol.0
                    2023-04-14 13:38:56.895	debug	check IsLater : 06:13 06:30
                    shuttercontrol.0
                    2023-04-14 13:38:56.892	debug	Starting up shutters living area: 07:00 debug 8
                    shuttercontrol.0
                    2023-04-14 13:38:56.892	debug	yes, IsEarlier : 06:13 07:00
                    shuttercontrol.0
                    2023-04-14 13:38:56.892	debug	check IsEarlier : 06:13 07:00
                    shuttercontrol.0
                    2023-04-14 13:38:56.892	debug	check IsEqual : 06:13 09:00
                    shuttercontrol.0
                    2023-04-14 13:38:56.891	debug	check IsEqual : 07:00 09:00
                    shuttercontrol.0
                    2023-04-14 13:38:56.891	debug	check IsLater : 06:13 07:00
                    shuttercontrol.0
                    2023-04-14 13:38:56.891	debug	check IsLater : 06:13 09:00
                    shuttercontrol.0
                    2023-04-14 13:38:56.879	debug	Shutdown shutters Sunset area: 20:03
                    shuttercontrol.0
                    2023-04-14 13:38:56.879	debug	Starting up shutters Sunrise area: 06:13
                    shuttercontrol.0
                    2023-04-14 13:38:56.879	debug	Shutdown shutters GoldenHour area: 19:17
                    shuttercontrol.0
                    2023-04-14 13:38:56.879	debug	Starting up shutters GoldenHour area: 06:59
                    shuttercontrol.0
                    2023-04-14 13:38:56.878	debug	Sunset today: 20:03
                    shuttercontrol.0
                    2023-04-14 13:38:56.878	debug	Sunrise today: 06:13
                    shuttercontrol.0
                    2023-04-14 13:38:56.878	debug	current day: 5
                    shuttercontrol.0
                    2023-04-14 13:38:56.878	debug	goldenHour today: 19:17
                    shuttercontrol.0
                    2023-04-14 13:38:56.878	debug	goldenHourEnd today: 06:59
                    shuttercontrol.0
                    2023-04-14 13:38:56.877	debug	calculate astrodata ...
                    shuttercontrol.0
                    2023-04-14 13:38:56.877	debug	Travel times of the shutters are calculated
                    shuttercontrol.0
                    2023-04-14 13:38:53.694	debug	Rollos_Rollo1: save settings
                    shuttercontrol.0
                    2023-04-14 13:38:53.682	debug	Shutter State: 0_userdata.0.Rollos.Rollo1
                    shuttercontrol.0
                    2023-04-14 13:38:53.681	debug	shutter Config Check successfully completed
                    shuttercontrol.0
                    2023-04-14 13:38:53.680	debug	shutter Config Check started
                    shuttercontrol.0
                    2023-04-14 13:38:53.665	info	starting. Version 1.4.26 (non-npm: simatec/ioBroker.shuttercontrol) in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.16.0, js-controller: 4.0.24
                    shuttercontrol.0
                    2023-04-14 13:38:53.407	debug	Plugin sentry Initialize Plugin (enabled=true)
                    shuttercontrol.0
                    2023-04-14 13:38:53.299	debug	States connected to redis: 127.0.0.1:9000
                    shuttercontrol.0
                    2023-04-14 13:38:53.224	debug	States create User PubSub Client
                    shuttercontrol.0
                    2023-04-14 13:38:53.223	debug	States create System PubSub Client
                    shuttercontrol.0
                    2023-04-14 13:38:53.206	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                    shuttercontrol.0
                    2023-04-14 13:38:53.180	debug	Objects connected to redis: 127.0.0.1:9001
                    shuttercontrol.0
                    2023-04-14 13:38:53.176	debug	Objects client initialize lua scripts
                    shuttercontrol.0
                    2023-04-14 13:38:53.115	debug	Objects create User PubSub Client
                    shuttercontrol.0
                    2023-04-14 13:38:53.114	debug	Objects create System PubSub Client
                    shuttercontrol.0
                    2023-04-14 13:38:53.113	debug	Objects client ready ... initialize now
                    shuttercontrol.0
                    2023-04-14 13:38:53.071	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                    host.iobroker-test
                    2023-04-14 13:38:52.492	info	instance system.adapter.shuttercontrol.0 started with pid 3022
                    Martin
                    • M MartyBr
                      @martybr
                      Log 1:
                      Start Shutter:
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      shuttercontrol.0
                      host.iobroker-test
                      MartyBr
                      schrieb am zuletzt editiert von MartyBr
                      #5604
                      @martybr
                      Ich habe den Adapter neu gestartet:
                      	2023-04-14 13:45:45.809	debug	complete down at 22:00
                      shuttercontrol.0
                      2023-04-14 13:45:45.807	debug	Shutdown shutters sleep area: 20:03 debug 4
                      shuttercontrol.0
                      2023-04-14 13:45:45.805	debug	Shutdown shutters children area: 20:03 debug 4
                      shuttercontrol.0
                      2023-04-14 13:45:45.803	debug	shutterDownLiving
                      shuttercontrol.0
                      2023-04-14 13:45:45.803	debug	Shutdown shutters living area: 20:03 debug 4
                      shuttercontrol.0
                      2023-04-14 13:45:45.803	debug	yes, IsLater : 21:15 20:03
                      shuttercontrol.0
                      2023-04-14 13:45:45.803	debug	check IsLater : 21:15 20:03
                      shuttercontrol.0
                      2023-04-14 13:45:45.803	debug	check IsEarlier : 21:15 20:03
                      shuttercontrol.0
                      2023-04-14 13:45:45.799	debug	Starting up shutters children area: 06:13 debug 5
                      shuttercontrol.0
                      2023-04-14 13:45:45.799	debug	yes, IsEarlier : 06:13 06:30
                      shuttercontrol.0
                      2023-04-14 13:45:45.799	debug	check IsEarlier : 06:13 06:30
                      shuttercontrol.0
                      2023-04-14 13:45:45.798	debug	yes, IsLater : 06:13 06:00
                      shuttercontrol.0
                      2023-04-14 13:45:45.798	debug	check IsLater : 06:13 06:00
                      shuttercontrol.0
                      2023-04-14 13:45:45.798	debug	check IsLater : 06:13 06:30
                      shuttercontrol.0
                      2023-04-14 13:45:45.795	debug	Starting up shutters sleep area: 06:13 debug 5
                      shuttercontrol.0
                      2023-04-14 13:45:45.795	debug	yes, IsEarlier : 06:13 06:30
                      shuttercontrol.0
                      2023-04-14 13:45:45.795	debug	check IsEarlier : 06:13 06:30
                      shuttercontrol.0
                      2023-04-14 13:45:45.794	debug	yes, IsLater : 06:13 06:00
                      shuttercontrol.0
                      2023-04-14 13:45:45.794	debug	check IsLater : 06:13 06:00
                      shuttercontrol.0
                      2023-04-14 13:45:45.794	debug	check IsLater : 06:13 06:30
                      shuttercontrol.0
                      2023-04-14 13:45:45.792	debug	Starting up shutters living area: 07:00 debug 8
                      shuttercontrol.0
                      2023-04-14 13:45:45.792	debug	yes, IsEarlier : 06:13 07:00
                      shuttercontrol.0
                      2023-04-14 13:45:45.791	debug	check IsEarlier : 06:13 07:00
                      shuttercontrol.0
                      2023-04-14 13:45:45.791	debug	check IsEqual : 06:13 09:00
                      shuttercontrol.0
                      2023-04-14 13:45:45.791	debug	check IsEqual : 07:00 09:00
                      shuttercontrol.0
                      2023-04-14 13:45:45.791	debug	check IsLater : 06:13 07:00
                      shuttercontrol.0
                      2023-04-14 13:45:45.791	debug	check IsLater : 06:13 09:00
                      shuttercontrol.0
                      2023-04-14 13:45:45.776	debug	Shutdown shutters Sunset area: 20:03
                      shuttercontrol.0
                      2023-04-14 13:45:45.776	debug	Starting up shutters Sunrise area: 06:13
                      shuttercontrol.0
                      2023-04-14 13:45:45.776	debug	Shutdown shutters GoldenHour area: 19:17
                      shuttercontrol.0
                      2023-04-14 13:45:45.776	debug	Starting up shutters GoldenHour area: 06:59
                      shuttercontrol.0
                      2023-04-14 13:45:45.776	debug	Sunset today: 20:03
                      shuttercontrol.0
                      2023-04-14 13:45:45.776	debug	Sunrise today: 06:13
                      shuttercontrol.0
                      2023-04-14 13:45:45.775	debug	current day: 5
                      shuttercontrol.0
                      2023-04-14 13:45:45.775	debug	goldenHour today: 19:17
                      shuttercontrol.0
                      2023-04-14 13:45:45.775	debug	goldenHourEnd today: 06:59
                      shuttercontrol.0
                      2023-04-14 13:45:45.775	debug	calculate astrodata ...
                      shuttercontrol.0
                      2023-04-14 13:45:45.774	debug	Travel times of the shutters are calculated
                      shuttercontrol.0
                      2023-04-14 13:45:42.635	debug	Rollos_Rollo1: save settings
                      shuttercontrol.0
                      2023-04-14 13:45:42.620	debug	Shutter State: 0_userdata.0.Rollos.Rollo1
                      shuttercontrol.0
                      2023-04-14 13:45:42.619	debug	shutter Config Check successfully completed
                      shuttercontrol.0
                      2023-04-14 13:45:42.618	debug	shutter Config Check started
                      shuttercontrol.0
                      2023-04-14 13:45:42.604	info	starting. Version 1.4.26 (non-npm: simatec/ioBroker.shuttercontrol) in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.16.0, js-controller: 4.0.24
                      shuttercontrol.0
                      2023-04-14 13:45:42.349	debug	Plugin sentry Initialize Plugin (enabled=true)
                      shuttercontrol.0
                      2023-04-14 13:45:42.256	debug	States connected to redis: 127.0.0.1:9000
                      shuttercontrol.0
                      2023-04-14 13:45:42.187	debug	States create User PubSub Client
                      shuttercontrol.0
                      2023-04-14 13:45:42.186	debug	States create System PubSub Client
                      shuttercontrol.0
                      2023-04-14 13:45:42.171	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                      shuttercontrol.0
                      2023-04-14 13:45:42.150	debug	Objects connected to redis: 127.0.0.1:9001
                      shuttercontrol.0
                      2023-04-14 13:45:42.147	debug	Objects client initialize lua scripts
                      shuttercontrol.0
                      2023-04-14 13:45:42.098	debug	Objects create User PubSub Client
                      shuttercontrol.0
                      2023-04-14 13:45:42.098	debug	Objects create System PubSub Client
                      shuttercontrol.0
                      2023-04-14 13:45:42.097	debug	Objects client ready ... initialize now
                      shuttercontrol.0
                      2023-04-14 13:45:42.070	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                      host.iobroker-test
                      2023-04-14 13:45:41.582	info	instance system.adapter.shuttercontrol.0 started with pid 3093
                      Hier der DP vom "Aktor":
                        "common": {
                          "name": "Rollos.Rollo1",
                          "desc": "Manuell erzeugt",
                          "role": "state",
                          "type": "number",
                          "read": true,
                          "write": true,
                          "unit": "%",
                          "def": 0
                        "type": "state",
                        "_id": "0_userdata.0.Rollos.Rollo1",
                        "acl": {
                          "object": 1636,
                          "state": 1636,
                          "owner": "system.user.admin",
                        "user": "system.user.admin",
                        "ts": 1652549426642
                      Hier das Log nach Sunprotect:
                      Der State steht wieder auf manu_mode.
                      shuttercontrol.0
                      2023-04-14 13:50:02.191	debug	Sunprotect Rollos.Rollo1 old height: 100% new height: 50%
                      shuttercontrol.0
                      2023-04-14 13:50:02.191	debug	last automatic Action for Rollos.Rollo1: down_Sunprotect
                      shuttercontrol.0
                      2023-04-14 13:50:02.191	debug	RangeMinus: 195 < 195.1RangePlus: 215 > 195.1
                      shuttercontrol.0
                      2023-04-14 13:50:02.191	debug	Sunprotect for Rollos.Rollo1 is active
                      shuttercontrol.0
                      2023-04-14 13:50:02.148	debug	Rollos.Rollo1 drived manually to 50. Old value = 100. New value = 50
                      shuttercontrol.0
                      2023-04-14 13:50:02.148	debug	Rollos.Rollo1 Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0
                      2023-04-14 13:50:02.100	debug	#2 currentShutterStateTime: 5 seconds
                      shuttercontrol.0
                      2023-04-14 13:50:02.100	debug	#2 currentShutterState: disabled
                      shuttercontrol.0
                      2023-04-14 13:50:02.100	debug	#2 oldHeight: 100 %
                      shuttercontrol.0
                      2023-04-14 13:50:02.100	debug	#2 currentHeight: 50 %
                      shuttercontrol.0
                      2023-04-14 13:50:02.099	debug	#2 triggerAction: Manu_Mode
                      shuttercontrol.0
                      2023-04-14 13:50:02.099	debug	#2 currentAction: Manu_Mode
                      shuttercontrol.0
                      2023-04-14 13:50:02.099	debug	#2 shutterState: 50 %
                      shuttercontrol.0
                      2023-04-14 13:50:02.099	debug	#2 shutterName: Rollos.Rollo1
                      shuttercontrol.0
                      2023-04-14 13:50:02.099	debug	Shutter state changed: Rollos.Rollo1 old value = 100 new value = 50
                      shuttercontrol.0
                      2023-04-14 13:50:02.098	debug	#0 wait for shutter check end
                      shuttercontrol.0
                      2023-04-14 13:50:02.088	debug	#0 wait for shutter check started
                      shuttercontrol.0
                      2023-04-14 13:50:02.042	info	Sunprotect #416 Set ID: Rollos.Rollo1 value: 50%
                      shuttercontrol.0
                      2023-04-14 13:50:02.041	debug	Rollos.Rollo1: Check basis for sunprotect. Height:100 > HeightDownSun: 50 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                      Martin
                      F 1 Antwort Letzte Antwort
                      • M MartyBr
                        @martybr
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        host.iobroker-test
                          "common": {
                            "role": "state",
                            "type": "number",
                            "read": true,
                            "write": true,
                            "unit": "%",
                            "def": 0
                          "type": "state",
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "ts": 1652549426642
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        shuttercontrol.0
                        firebowl
                        schrieb am zuletzt editiert von firebowl
                        #5605
                        @martybr Öhm, der Adapter verhält sich bei mir komischer als gedacht. Ich öffne morgens alle Rollos mit einem openAll, damit wirklich alle auf Auto stehen. Die meisten meiner Rollos stehen aber auf Manu_Mode, inkl. dem, der heute nicht aus dem Sonnenschutz gekommen ist.
                        2023-04-14 05:32:54.135  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Kinderzimmer.ShutterControl.level value: 0%
                        2023-04-14 05:32:58.289  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Badezimmer.ShutterControl.level value: 0%
                        2023-04-14 05:33:00.414  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rolllo Treppenhaus OG.ShutterControl.level value: 0%
                        2023-04-14 05:33:02.492  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Büro Steffi.ShutterControl.level value: 0%
                        2023-04-14 05:33:04.598  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Büro Mike.ShutterControl.level value: 0%
                        2023-04-14 05:33:06.669  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Wohnzimmer.ShutterControl.level value: 0%
                        2023-04-14 05:33:08.885  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Esszimmer.ShutterControl.level value: 0%
                        2023-04-14 05:33:10.978  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rolllo Treppenhaus EG.ShutterControl.level value: 0%
                        2023-04-14 05:33:13.104  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Küchenfenster.ShutterControl.level value: 0%
                        2023-04-14 05:33:15.161  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Terrassentür.ShutterControl.level value: 0%
                        2023-04-14 13:00:55.709  - info: shuttercontrol.0 (1043851) Sunprotect #414 Set ID: Rollo Schlafzimmer.ShutterControl.level value: 74%
                        Es gibt zwar dank debug Einstellungen mehr Einträge im Log aber die sind wohl irrelevant, es wird halt jede Änderung protokolliert am Sonnenstand oder Licht bzw. Temperatur.
                        Was ich nicht verstehe, der Rollo im Schlafzimmer wurde gestern Abend manuell geöffnet aber durch den openAll heut früh sollte der doch wie alle anderen auf Auto stehen. Er steht aber wie viele andere auf Manu_Mode und ich habe heute garantiert keinen der Rollos betätigt weil es nicht wirklich sonnig war. Nur heute morgen der openAll.
                        Nach druck auf openAll sieht das jetzt so aus:
                        shuttercontrol.0 2023-04-14 14:50:34.972	info	Button openAll Set ID: Rollo Schlafzimmer.ShutterControl.level value: 0%
                        M simatecS HomoranH 3 Antworten Letzte Antwort
                        • F firebowl
                          MartyBr
                          #5606
                          @firebowl
                          Das Verhalten habe ich auch bei den "neuen" Versionen 1.4.23 bis 1.4.26.
                          Ich benutze daher auf meinem Produktiv-System die 1.4.18, die läuft für meine Zwecke einwandfrei. Ich nutze den Helligkeitssensor nicht.
                          Ansonsten ist hier der große Meister @simatec gefragt, ich bin nur ein "kleiner" User.
                          Martin
                          • F firebowl
                            simatecS Offline
                            simatecS Offline
                            simatec
                            #5607
                            @firebowl bitte poste den vollständigen Debuglog. Irgendwo muss ja der Manu_Mode geloggt sein
                            • F firebowl
                              HomoranH Offline
                              HomoranH Offline
                              #5608
                              @firebowl sagte in Test Adapter shuttercontrol v1.4.x:
                              welche Aktoren?
                              Position erst später bestimmen korrekt konfiguriert?
                              • simatecS simatec
                                firebowl
                                #5609
                                @simatec sagte in Test Adapter shuttercontrol v1.4.x:
                                Sieht leider etwas wüst aus weil ich ja die loops hatte und nen Downgrade gemacht hab.
                                Zeile   367: 2023-04-14 05:32:54.135  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Kinderzimmer.ShutterControl.level value: 0%
                                	Zeile   372: 2023-04-14 05:32:58.289  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Badezimmer.ShutterControl.level value: 0%
                                	Zeile   373: 2023-04-14 05:33:00.414  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rolllo Treppenhaus OG.ShutterControl.level value: 0%
                                	Zeile   374: 2023-04-14 05:33:02.492  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Büro Steffi.ShutterControl.level value: 0%
                                	Zeile   375: 2023-04-14 05:33:04.598  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Büro Mike.ShutterControl.level value: 0%
                                	Zeile   376: 2023-04-14 05:33:06.669  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Wohnzimmer.ShutterControl.level value: 0%
                                	Zeile   377: 2023-04-14 05:33:08.885  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Esszimmer.ShutterControl.level value: 0%
                                	Zeile   378: 2023-04-14 05:33:10.978  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rolllo Treppenhaus EG.ShutterControl.level value: 0%
                                	Zeile   379: 2023-04-14 05:33:13.104  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Küchenfenster.ShutterControl.level value: 0%
                                	Zeile   380: 2023-04-14 05:33:15.161  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Terrassentür.ShutterControl.level value: 0%
                                	Zeile   447: 2023-04-14 06:15:50.734  - info: host.iobroker iobroker url https://github.com/simatec/ioBroker.shuttercontrol --host iobroker --debug
                                	Zeile   448: 2023-04-14 06:15:52.274  - info: host.iobroker iobroker install simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236
                                	Zeile   449: 2023-04-14 06:15:53.508  - info: host.iobroker iobroker NPM version: 9.5.0Installing simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236... (System call)
                                	Zeile   450: 2023-04-14 06:16:01.820  - info: host.iobroker iobroker npm WARN skipping integrity check for git dependency ssh://git@github.com/simatec/ioBroker.shuttercontrol.git
                                	Zeile   455: 2023-04-14 06:16:03.206  - info: host.iobroker iobroker upload [5] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/img/info-big.png img/info-big.png image/png
                                	Zeile   456: 2023-04-14 06:16:03.246  - info: host.iobroker iobroker upload [4] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.html index_m.html text/html
                                	Zeile   457: 2023-04-14 06:16:03.252  - info: host.iobroker iobroker upload [3] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.js index_m.js application/javascript
                                	Zeile   458: 2023-04-14 06:16:03.258  - info: host.iobroker iobroker upload [2] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/shuttercontrol.png shuttercontrol.png image/png
                                	Zeile   459: 2023-04-14 06:16:03.263  - info: host.iobroker iobroker upload [1] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/style.css style.css text/css
                                	Zeile   460: 2023-04-14 06:16:03.268  - info: host.iobroker iobroker upload [0] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/words.js words.js application/javascript
                                	Zeile   461: 2023-04-14 06:16:03.400  - info: host.iobroker iobroker Update "system.adapter.shuttercontrol.0"
                                	Zeile   462: 2023-04-14 06:16:03.540  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
                                	Zeile   464: 2023-04-14 06:16:03.570  - info: shuttercontrol.0 (832342) Got terminate signal TERMINATE_YOURSELF
                                	Zeile   465: 2023-04-14 06:16:03.578  - info: shuttercontrol.0 (832342) cleaned everything up...
                                	Zeile   466: 2023-04-14 06:16:03.579  - info: shuttercontrol.0 (832342) terminating
                                	Zeile   467: 2023-04-14 06:16:03.583  - info: shuttercontrol.0 (832342) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                	Zeile   468: 2023-04-14 06:16:03.743  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 send kill signal
                                	Zeile   469: 2023-04-14 06:16:04.350  - info: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                	Zeile   471: 2023-04-14 06:16:06.778  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1025342
                                	Zeile   472: 2023-04-14 06:16:10.575  - info: shuttercontrol.0 (1025342) starting. Version 1.4.25 (non-npm: simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236) in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.15.0, js-controller: 4.0.23
                                	Zeile   550: 2023-04-14 06:58:21.788  - info: shuttercontrol.0 (1025342) cleaned everything up...
                                	Zeile   625: 2023-04-14 06:58:22.057  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
                                	Zeile   684: 2023-04-14 06:58:23.283  - info: shuttercontrol.0 (1025342) Got terminate signal TERMINATE_YOURSELF
                                	Zeile   704: 2023-04-14 06:58:23.428  - info: shuttercontrol.0 (1025342) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                	Zeile   797: 2023-04-14 06:58:24.107  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 send kill signal
                                	Zeile   988: 2023-04-14 06:58:27.273  - info: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                	Zeile  1491: 2023-04-14 07:02:42.398  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1029545
                                	Zeile  1494: 2023-04-14 07:02:46.278  - info: shuttercontrol.0 (1029545) starting. Version 1.4.25 (non-npm: simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236) in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.15.0, js-controller: 4.0.24
                                	Zeile  1683: 2023-04-14 07:06:56.752  - info: shuttercontrol.0 (1029545) cleaned everything up...
                                	Zeile  1763: 2023-04-14 07:06:57.070  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
                                	Zeile  1809: 2023-04-14 07:06:57.662  - info: shuttercontrol.0 (1029545) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                	Zeile  1842: 2023-04-14 07:06:58.002  - info: shuttercontrol.0 (1029545) Got terminate signal TERMINATE_YOURSELF
                                	Zeile  1944: 2023-04-14 07:06:58.547  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 send kill signal
                                	Zeile  2028: 2023-04-14 07:07:00.593  - info: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                	Zeile  2502: 2023-04-14 07:08:54.817  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1032326
                                	Zeile  2503: 2023-04-14 07:08:55.926  - info: shuttercontrol.0 (1032326) starting. Version 1.4.25 (non-npm: simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236) in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.16.0, js-controller: 4.0.24
                                	Zeile  2751: 2023-04-14 07:40:12.191  - error: shuttercontrol.0 (1032326) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                	Zeile  2752: 2023-04-14 07:40:12.193  - error: shuttercontrol.0 (1032326) unhandled promise rejection: Cannot read properties of null (reading 'val')
                                	Zeile  2753: 2023-04-14 07:40:12.201  - error: shuttercontrol.0 (1032326) TypeError: Cannot read properties of null (reading 'val')
                                	Zeile  2754:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile  2755: 2023-04-14 07:40:12.201  - error: shuttercontrol.0 (1032326) Cannot read properties of null (reading 'val')
                                	Zeile  2756: 2023-04-14 07:40:12.210  - info: shuttercontrol.0 (1032326) cleaned everything up...
                                	Zeile  2757: 2023-04-14 07:40:12.211  - info: shuttercontrol.0 (1032326) terminating
                                	Zeile  2758: 2023-04-14 07:40:12.211  - warn: shuttercontrol.0 (1032326) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                	Zeile  2761: 2023-04-14 07:40:12.764  - error: host.iobroker Caught by controller[1]:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile  2762: 2023-04-14 07:40:12.764  - error: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                	Zeile  2763: 2023-04-14 07:40:12.764  - info: host.iobroker Restart adapter system.adapter.shuttercontrol.0 because enabled
                                	Zeile  2766: 2023-04-14 07:40:42.780  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1034247
                                	Zeile  2767: 2023-04-14 07:40:44.258  - info: shuttercontrol.0 (1034247) starting. Version 1.4.25 (non-npm: simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236) in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.16.0, js-controller: 4.0.24
                                	Zeile  2785: 2023-04-14 07:45:12.272  - error: shuttercontrol.0 (1034247) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                	Zeile  2786: 2023-04-14 07:45:12.273  - error: shuttercontrol.0 (1034247) unhandled promise rejection: Cannot read properties of null (reading 'val')
                                	Zeile  2787: 2023-04-14 07:45:12.275  - error: shuttercontrol.0 (1034247) TypeError: Cannot read properties of null (reading 'val')
                                	Zeile  2788:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile  2789: 2023-04-14 07:45:12.275  - error: shuttercontrol.0 (1034247) Cannot read properties of null (reading 'val')
                                	Zeile  2790: 2023-04-14 07:45:12.284  - info: shuttercontrol.0 (1034247) cleaned everything up...
                                	Zeile  2791: 2023-04-14 07:45:12.284  - info: shuttercontrol.0 (1034247) terminating
                                	Zeile  2792: 2023-04-14 07:45:12.285  - warn: shuttercontrol.0 (1034247) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                	Zeile  2795: 2023-04-14 07:45:12.837  - error: host.iobroker Caught by controller[1]:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile  2796: 2023-04-14 07:45:12.837  - error: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                	Zeile  2797: 2023-04-14 07:45:12.837  - info: host.iobroker Restart adapter system.adapter.shuttercontrol.0 because enabled
                                	Zeile  2798: 2023-04-14 07:45:42.854  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1034482
                                	Zeile  2799: 2023-04-14 07:45:44.189  - info: shuttercontrol.0 (1034482) starting. Version 1.4.25 (non-npm: simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236) in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.16.0, js-controller: 4.0.24
                                	Zeile  2814: 2023-04-14 07:50:12.205  - error: shuttercontrol.0 (1034482) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                	Zeile  2815: 2023-04-14 07:50:12.207  - error: shuttercontrol.0 (1034482) unhandled promise rejection: Cannot read properties of null (reading 'val')
                                	Zeile  2816: 2023-04-14 07:50:12.210  - error: shuttercontrol.0 (1034482) TypeError: Cannot read properties of null (reading 'val')
                                	Zeile  2817:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile  2818: 2023-04-14 07:50:12.210  - error: shuttercontrol.0 (1034482) Cannot read properties of null (reading 'val')
                                	Zeile  2819: 2023-04-14 07:50:12.219  - info: shuttercontrol.0 (1034482) cleaned everything up...
                                	Zeile  2820: 2023-04-14 07:50:12.220  - info: shuttercontrol.0 (1034482) terminating
                                	Zeile  2821: 2023-04-14 07:50:12.220  - warn: shuttercontrol.0 (1034482) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                	Zeile  2824: 2023-04-14 07:50:12.792  - error: host.iobroker Caught by controller[1]:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile  2825: 2023-04-14 07:50:12.792  - error: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                	Zeile  2826: 2023-04-14 07:50:12.792  - info: host.iobroker Restart adapter system.adapter.shuttercontrol.0 because enabled
                                	Zeile  2827: 2023-04-14 07:50:12.792  - warn: host.iobroker Do not restart adapter system.adapter.shuttercontrol.0 because restart loop detected
                                	Zeile  2849: 2023-04-14 07:54:22.743  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1035403
                                	Zeile  2852: 2023-04-14 07:54:25.215  - info: shuttercontrol.0 (1035403) starting. Version 1.4.25 (non-npm: simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236) in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.16.0, js-controller: 4.0.24
                                	Zeile  2853: 2023-04-14 07:55:12.608  - error: shuttercontrol.0 (1035403) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                	Zeile  2854: 2023-04-14 07:55:12.608  - error: shuttercontrol.0 (1035403) unhandled promise rejection: Cannot read properties of null (reading 'val')
                                	Zeile  2855: 2023-04-14 07:55:12.610  - error: shuttercontrol.0 (1035403) TypeError: Cannot read properties of null (reading 'val')
                                	Zeile  2856:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile  2857: 2023-04-14 07:55:12.610  - error: shuttercontrol.0 (1035403) Cannot read properties of null (reading 'val')
                                	Zeile  2858: 2023-04-14 07:55:12.640  - info: shuttercontrol.0 (1035403) cleaned everything up...
                                	Zeile  2859: 2023-04-14 07:55:12.641  - info: shuttercontrol.0 (1035403) terminating
                                	Zeile  2860: 2023-04-14 07:55:12.641  - warn: shuttercontrol.0 (1035403) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                	Zeile  2863: 2023-04-14 07:55:13.202  - error: host.iobroker Caught by controller[1]:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile  2864: 2023-04-14 07:55:13.202  - error: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                	Zeile  2865: 2023-04-14 07:55:13.202  - info: host.iobroker Restart adapter system.adapter.shuttercontrol.0 because enabled
                                	Zeile  2868: 2023-04-14 07:55:43.217  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1035493
                                	Zeile  2869: 2023-04-14 07:55:44.606  - info: shuttercontrol.0 (1035493) starting. Version 1.4.25 (non-npm: simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236) in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.16.0, js-controller: 4.0.24
                                	Zeile  2888: 2023-04-14 07:59:49.375  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
                                	Zeile  2889: 2023-04-14 07:59:49.434  - info: shuttercontrol.0 (1035493) Got terminate signal TERMINATE_YOURSELF
                                	Zeile  2890: 2023-04-14 07:59:49.438  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 send kill signal
                                	Zeile  2891: 2023-04-14 07:59:49.436  - info: shuttercontrol.0 (1035493) cleaned everything up...
                                	Zeile  2892: 2023-04-14 07:59:49.437  - info: shuttercontrol.0 (1035493) terminating
                                	Zeile  2893: 2023-04-14 07:59:49.437  - info: shuttercontrol.0 (1035493) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                	Zeile  2894: 2023-04-14 07:59:49.997  - info: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                	Zeile  2895: 2023-04-14 07:59:52.464  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1035724
                                	Zeile  2897: 2023-04-14 07:59:53.831  - info: shuttercontrol.0 (1035724) starting. Version 1.4.25 (non-npm: simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236) in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.16.0, js-controller: 4.0.24
                                	Zeile  2907: 2023-04-14 08:00:12.487  - error: shuttercontrol.0 (1035724) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                	Zeile  2908: 2023-04-14 08:00:12.489  - error: shuttercontrol.0 (1035724) unhandled promise rejection: Cannot read properties of null (reading 'val')
                                	Zeile  2909: 2023-04-14 08:00:12.491  - error: shuttercontrol.0 (1035724) TypeError: Cannot read properties of null (reading 'val')
                                	Zeile  2910:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile  2911: 2023-04-14 08:00:12.491  - error: shuttercontrol.0 (1035724) Cannot read properties of null (reading 'val')
                                	Zeile  2912: 2023-04-14 08:00:12.498  - info: shuttercontrol.0 (1035724) cleaned everything up...
                                	Zeile  2913: 2023-04-14 08:00:12.499  - info: shuttercontrol.0 (1035724) terminating
                                	Zeile  2914: 2023-04-14 08:00:12.499  - warn: shuttercontrol.0 (1035724) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                	Zeile  2917: 2023-04-14 08:00:13.054  - error: host.iobroker Caught by controller[1]:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile  2918: 2023-04-14 08:00:13.054  - error: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                	Zeile  2919: 2023-04-14 08:00:13.054  - info: host.iobroker Restart adapter system.adapter.shuttercontrol.0 because enabled
                                	Zeile  2922: 2023-04-14 08:00:43.087  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1035823
                                	Zeile  2923: 2023-04-14 08:00:44.584  - info: shuttercontrol.0 (1035823) starting. Version 1.4.25 (non-npm: simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236) in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.16.0, js-controller: 4.0.24
                                	Zeile  2940: 2023-04-14 08:05:12.164  - error: shuttercontrol.0 (1035823) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                	Zeile  2941: 2023-04-14 08:05:12.166  - error: shuttercontrol.0 (1035823) unhandled promise rejection: Cannot read properties of null (reading 'val')
                                	Zeile  2942: 2023-04-14 08:05:12.167  - error: shuttercontrol.0 (1035823) TypeError: Cannot read properties of null (reading 'val')
                                	Zeile  2943:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile  2944: 2023-04-14 08:05:12.168  - error: shuttercontrol.0 (1035823) Cannot read properties of null (reading 'val')
                                	Zeile  2945: 2023-04-14 08:05:12.178  - info: shuttercontrol.0 (1035823) cleaned everything up...
                                	Zeile  2946: 2023-04-14 08:05:12.179  - info: shuttercontrol.0 (1035823) terminating
                                	Zeile  2947: 2023-04-14 08:05:12.180  - warn: shuttercontrol.0 (1035823) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                	Zeile  2950: 2023-04-14 08:05:12.732  - error: host.iobroker Caught by controller[1]:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile  2951: 2023-04-14 08:05:12.732  - error: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                	Zeile  2952: 2023-04-14 08:05:12.732  - info: host.iobroker Restart adapter system.adapter.shuttercontrol.0 because enabled
                                	Zeile  2953: 2023-04-14 08:05:12.732  - warn: host.iobroker Do not restart adapter system.adapter.shuttercontrol.0 because restart loop detected
                                	Zeile  2980: 2023-04-14 08:11:36.341  - info: host.iobroker iobroker upgrade shuttercontrol@1.4.23 --debug
                                	Zeile  2981: 2023-04-14 08:11:38.453  - info: host.iobroker iobroker Update shuttercontrol from @1.4.25 to @1.4.23
                                	Zeile  2982: 2023-04-14 08:11:38.469  - info: host.iobroker iobroker host.iobroker Adapter "system.adapter.shuttercontrol.0" is stopped.
                                	Zeile  2983: 2023-04-14 08:11:38.533  - info: host.iobroker "system.adapter.shuttercontrol.0" disabled
                                	Zeile  2984: 2023-04-14 08:11:40.126  - info: host.iobroker iobroker NPM version: 9.5.1Installing iobroker.shuttercontrol@1.4.23... (System call)
                                	Zeile  2990: 2023-04-14 08:11:46.767  - info: host.iobroker iobroker Update "system.adapter.shuttercontrol.0"
                                	Zeile  2991: 2023-04-14 08:11:46.928  - info: host.iobroker iobroker upload [5] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/img/info-big.png img/info-big.png image/png
                                	Zeile  2992: 2023-04-14 08:11:46.986  - info: host.iobroker iobroker upload [4] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.html index_m.html text/html
                                	Zeile  2993: 2023-04-14 08:11:46.991  - info: host.iobroker iobroker upload [3] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.js index_m.js application/javascript
                                	Zeile  2994: 2023-04-14 08:11:46.996  - info: host.iobroker iobroker upload [2] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/shuttercontrol.png shuttercontrol.png image/png
                                	Zeile  2995: 2023-04-14 08:11:47.002  - info: host.iobroker iobroker upload [1] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/style.css style.css text/css
                                	Zeile  2996: 2023-04-14 08:11:47.013  - info: host.iobroker iobroker upload [0] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/words.js words.js application/javascript
                                	Zeile  2997: 2023-04-14 08:11:47.018  - info: host.iobroker iobroker host.iobroker Adapter "system.adapter.shuttercontrol.0" is started
                                	Zeile  2998: 2023-04-14 08:11:47.074  - info: host.iobroker "system.adapter.shuttercontrol.0" enabled
                                	Zeile  2999: 2023-04-14 08:11:47.231  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1036423
                                	Zeile  3001: 2023-04-14 08:11:49.356  - info: shuttercontrol.0 (1036423) starting. Version 1.4.23 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.16.0, js-controller: 4.0.24
                                	Zeile  8903: 2023-04-14 10:22:57.353  - info: shuttercontrol.0 (1036423) Loglevel changed from "info" to "debug"
                                	Zeile  8907: 2023-04-14 10:24:39.082  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.04cf8cdf3c7b5a7e.illuminance Value: 1683
                                	Zeile  8909: 2023-04-14 10:24:52.892  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef4410000199f5.illuminance Value: 1356
                                	Zeile  8911: 2023-04-14 10:25:00.018  - debug: shuttercontrol.0 (1036423) calculate astrodata ...
                                	Zeile  8912: 2023-04-14 10:25:00.018  - debug: shuttercontrol.0 (1036423) Sun Azimut: 123.5°
                                	Zeile  8913: 2023-04-14 10:25:00.019  - debug: shuttercontrol.0 (1036423) Sun Elevation: 36.3°
                                	Zeile  8914: 2023-04-14 10:25:02.656  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef441000018d23.illuminance Value: 966
                                	Zeile  8915: 2023-04-14 10:25:02.938  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef441000019dc2.illuminance Value: 56
                                	Zeile  8916: 2023-04-14 10:25:05.627  - debug: shuttercontrol.0 (1036423) outsidetemperature changed: zigbee.0.00158d0006b0fc15.temperature Value: 7.35
                                	Zeile  8917: 2023-04-14 10:25:19.617  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef4410000199d2.illuminance Value: 98
                                	Zeile  8926: 2023-04-14 10:27:37.015  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef441000018d23.illuminance Value: 1053
                                	Zeile  8930: 2023-04-14 10:27:52.120  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef4410000199f5.illuminance Value: 1524
                                	Zeile  8931: 2023-04-14 10:27:53.223  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.04cf8cdf3c7b5a7e.illuminance Value: 1770
                                	Zeile  8935: 2023-04-14 10:28:43.006  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef4410001ffb25.illuminance Value: 266
                                	Zeile  8939: 2023-04-14 10:30:00.024  - debug: shuttercontrol.0 (1036423) calculate astrodata ...
                                	Zeile  8940: 2023-04-14 10:30:00.025  - debug: shuttercontrol.0 (1036423) Sun Azimut: 124.8°
                                	Zeile  8941: 2023-04-14 10:30:00.025  - debug: shuttercontrol.0 (1036423) Sun Elevation: 36.9°
                                	Zeile  8950: 2023-04-14 10:30:25.423  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef441000019dc2.illuminance Value: 80
                                	Zeile  8953: 2023-04-14 10:30:37.389  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.04cf8cdf3c7b5a7e.illuminance Value: 1712
                                	Zeile  8960: 2023-04-14 10:33:23.147  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef4410002000c5.illuminance Value: 160
                                	Zeile  8961: 2023-04-14 10:33:38.246  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef4410000199d2.illuminance Value: 114
                                	Zeile  8965: 2023-04-14 10:35:00.020  - debug: shuttercontrol.0 (1036423) calculate astrodata ...
                                	Zeile  8966: 2023-04-14 10:35:00.021  - debug: shuttercontrol.0 (1036423) Sun Azimut: 126.1°
                                	Zeile  8967: 2023-04-14 10:35:00.021  - debug: shuttercontrol.0 (1036423) Sun Elevation: 37.6°
                                	Zeile  8968: 2023-04-14 10:35:04.634  - debug: shuttercontrol.0 (1036423) insidetemperature changed: zigbee.0.00158d0001dde47f.temperature Value: 18.78
                                	Zeile  8971: 2023-04-14 10:35:40.643  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.04cf8cdf3c7b35d1.illuminance Value: 444
                                	Zeile  8972: 2023-04-14 10:35:45.916  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.04cf8cdf3c7b5a7e.illuminance Value: 1923
                                	Zeile  8973: 2023-04-14 10:35:47.163  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef441000018d23.illuminance Value: 1244
                                	Zeile  8974: 2023-04-14 10:35:49.813  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef4410000199f5.illuminance Value: 1718
                                	Zeile  8975: 2023-04-14 10:36:12.772  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef4410000199d2.illuminance Value: 101
                                	Zeile  8986: 2023-04-14 10:38:58.133  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
                                	Zeile  8987: 2023-04-14 10:38:58.183  - info: shuttercontrol.0 (1036423) Got terminate signal TERMINATE_YOURSELF
                                	Zeile  8988: 2023-04-14 10:38:58.184  - info: shuttercontrol.0 (1036423) cleaned everything up...
                                	Zeile  8989: 2023-04-14 10:38:58.184  - info: shuttercontrol.0 (1036423) terminating
                                	Zeile  8990: 2023-04-14 10:38:58.185  - debug: shuttercontrol.0 (1036423) Plugin sentry destroyed
                                	Zeile  8991: 2023-04-14 10:38:58.185  - info: shuttercontrol.0 (1036423) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                	Zeile  8992: 2023-04-14 10:38:58.194  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 send kill signal
                                	Zeile  8993: 2023-04-14 10:38:58.764  - info: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                	Zeile  8995: 2023-04-14 10:39:01.212  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1043851
                                	Zeile  8996: 2023-04-14 10:39:02.595  - info: shuttercontrol.0 (1043851) starting. Version 1.4.23 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.16.0, js-controller: 4.0.24
                                	Zeile  9519: 2023-04-14 13:00:55.709  - info: shuttercontrol.0 (1043851) Sunprotect #414 Set ID: Rollo Schlafzimmer.ShutterControl.level value: 74%
                                	Zeile  9899: 2023-04-14 14:50:34.972  - info: shuttercontrol.0 (1043851) Button openAll Set ID: Rollo Schlafzimmer.ShutterControl.level value: 0%
                                	Zeile  9955: 2023-04-14 15:11:57.398  - info: shuttercontrol.0 (1043851) Set ID: Rollo Kinderzimmer.ShutterControl.level to Auto-Mode
                                	Zeile  9956: 2023-04-14 15:11:59.453  - info: shuttercontrol.0 (1043851) Set ID: Rollo Schlafzimmer.ShutterControl.level to Auto-Mode
                                	Zeile  9957: 2023-04-14 15:12:01.506  - info: shuttercontrol.0 (1043851) Set ID: Rollo Badezimmer.ShutterControl.level to Auto-Mode
                                	Zeile  9958: 2023-04-14 15:12:03.580  - info: shuttercontrol.0 (1043851) Set ID: Rolllo Treppenhaus OG.ShutterControl.level to Auto-Mode
                                	Zeile  9959: 2023-04-14 15:12:05.641  - info: shuttercontrol.0 (1043851) Set ID: Rollo Büro Steffi.ShutterControl.level to Auto-Mode
                                	Zeile  9960: 2023-04-14 15:12:07.728  - info: shuttercontrol.0 (1043851) Set ID: Rollo Büro Mike.ShutterControl.level to Auto-Mode
                                	Zeile  9961: 2023-04-14 15:12:09.804  - info: shuttercontrol.0 (1043851) Set ID: Rollo Wohnzimmer.ShutterControl.level to Auto-Mode
                                	Zeile  9962: 2023-04-14 15:12:11.859  - info: shuttercontrol.0 (1043851) Set ID: Rollo Esszimmer.ShutterControl.level to Auto-Mode
                                	Zeile  9963: 2023-04-14 15:12:13.912  - info: shuttercontrol.0 (1043851) Set ID: Rolllo Treppenhaus EG.ShutterControl.level to Auto-Mode
                                	Zeile  9964: 2023-04-14 15:12:15.964  - info: shuttercontrol.0 (1043851) Set ID: Rollo Küchenfenster.ShutterControl.level to Auto-Mode
                                	Zeile  9965: 2023-04-14 15:12:18.189  - info: shuttercontrol.0 (1043851) Set ID: Rollo Terrassentür.ShutterControl.level to Auto-Mode
                                  neu 24 (237 Treffer)
                                	Zeile   1: Zeile  367: 2023-04-14 05:32:54.135  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Kinderzimmer.ShutterControl.level value: 0%
                                	Zeile   2: 	Zeile  372: 2023-04-14 05:32:58.289  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Badezimmer.ShutterControl.level value: 0%
                                	Zeile   3: 	Zeile  373: 2023-04-14 05:33:00.414  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rolllo Treppenhaus OG.ShutterControl.level value: 0%
                                	Zeile   4: 	Zeile  374: 2023-04-14 05:33:02.492  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Büro Steffi.ShutterControl.level value: 0%
                                	Zeile   5: 	Zeile  375: 2023-04-14 05:33:04.598  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Büro Mike.ShutterControl.level value: 0%
                                	Zeile   6: 	Zeile  376: 2023-04-14 05:33:06.669  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Wohnzimmer.ShutterControl.level value: 0%
                                	Zeile   7: 	Zeile  377: 2023-04-14 05:33:08.885  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Esszimmer.ShutterControl.level value: 0%
                                	Zeile   8: 	Zeile  378: 2023-04-14 05:33:10.978  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rolllo Treppenhaus EG.ShutterControl.level value: 0%
                                	Zeile   9: 	Zeile  379: 2023-04-14 05:33:13.104  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Küchenfenster.ShutterControl.level value: 0%
                                	Zeile  10: 	Zeile  380: 2023-04-14 05:33:15.161  - info: shuttercontrol.0 (832342) Button openAll Set ID: Rollo Terrassentür.ShutterControl.level value: 0%
                                	Zeile  11: 	Zeile  447: 2023-04-14 06:15:50.734  - info: host.iobroker iobroker url https://github.com/simatec/ioBroker.shuttercontrol --host iobroker --debug
                                	Zeile  12: 	Zeile  448: 2023-04-14 06:15:52.274  - info: host.iobroker iobroker install simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236
                                	Zeile  13: 	Zeile  449: 2023-04-14 06:15:53.508  - info: host.iobroker iobroker NPM version: 9.5.0Installing simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236... (System call)
                                	Zeile  14: 	Zeile  450: 2023-04-14 06:16:01.820  - info: host.iobroker iobroker npm WARN skipping integrity check for git dependency ssh://git@github.com/simatec/ioBroker.shuttercontrol.git
                                	Zeile  15: 	Zeile  455: 2023-04-14 06:16:03.206  - info: host.iobroker iobroker upload [5] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/img/info-big.png img/info-big.png image/png
                                	Zeile  16: 	Zeile  456: 2023-04-14 06:16:03.246  - info: host.iobroker iobroker upload [4] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.html index_m.html text/html
                                	Zeile  17: 	Zeile  457: 2023-04-14 06:16:03.252  - info: host.iobroker iobroker upload [3] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.js index_m.js application/javascript
                                	Zeile  18: 	Zeile  458: 2023-04-14 06:16:03.258  - info: host.iobroker iobroker upload [2] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/shuttercontrol.png shuttercontrol.png image/png
                                	Zeile  19: 	Zeile  459: 2023-04-14 06:16:03.263  - info: host.iobroker iobroker upload [1] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/style.css style.css text/css
                                	Zeile  20: 	Zeile  460: 2023-04-14 06:16:03.268  - info: host.iobroker iobroker upload [0] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/words.js words.js application/javascript
                                	Zeile  21: 	Zeile  461: 2023-04-14 06:16:03.400  - info: host.iobroker iobroker Update "system.adapter.shuttercontrol.0"
                                	Zeile  22: 	Zeile  462: 2023-04-14 06:16:03.540  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
                                	Zeile  23: 	Zeile  464: 2023-04-14 06:16:03.570  - info: shuttercontrol.0 (832342) Got terminate signal TERMINATE_YOURSELF
                                	Zeile  24: 	Zeile  465: 2023-04-14 06:16:03.578  - info: shuttercontrol.0 (832342) cleaned everything up...
                                	Zeile  25: 	Zeile  466: 2023-04-14 06:16:03.579  - info: shuttercontrol.0 (832342) terminating
                                	Zeile  26: 	Zeile  467: 2023-04-14 06:16:03.583  - info: shuttercontrol.0 (832342) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                	Zeile  27: 	Zeile  468: 2023-04-14 06:16:03.743  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 send kill signal
                                	Zeile  28: 	Zeile  469: 2023-04-14 06:16:04.350  - info: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                	Zeile  29: 	Zeile  471: 2023-04-14 06:16:06.778  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1025342
                                	Zeile  30: 	Zeile  472: 2023-04-14 06:16:10.575  - info: shuttercontrol.0 (1025342) starting. Version 1.4.25 (non-npm: simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236) in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.15.0, js-controller: 4.0.23
                                	Zeile  31: 	Zeile  550: 2023-04-14 06:58:21.788  - info: shuttercontrol.0 (1025342) cleaned everything up...
                                	Zeile  32: 	Zeile  625: 2023-04-14 06:58:22.057  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
                                	Zeile  33: 	Zeile  684: 2023-04-14 06:58:23.283  - info: shuttercontrol.0 (1025342) Got terminate signal TERMINATE_YOURSELF
                                	Zeile  34: 	Zeile  704: 2023-04-14 06:58:23.428  - info: shuttercontrol.0 (1025342) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                	Zeile  35: 	Zeile  797: 2023-04-14 06:58:24.107  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 send kill signal
                                	Zeile  36: 	Zeile  988: 2023-04-14 06:58:27.273  - info: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                	Zeile  37: 	Zeile 1491: 2023-04-14 07:02:42.398  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1029545
                                	Zeile  38: 	Zeile 1494: 2023-04-14 07:02:46.278  - info: shuttercontrol.0 (1029545) starting. Version 1.4.25 (non-npm: simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236) in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.15.0, js-controller: 4.0.24
                                	Zeile  39: 	Zeile 1683: 2023-04-14 07:06:56.752  - info: shuttercontrol.0 (1029545) cleaned everything up...
                                	Zeile  40: 	Zeile 1763: 2023-04-14 07:06:57.070  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
                                	Zeile  41: 	Zeile 1809: 2023-04-14 07:06:57.662  - info: shuttercontrol.0 (1029545) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                	Zeile  42: 	Zeile 1842: 2023-04-14 07:06:58.002  - info: shuttercontrol.0 (1029545) Got terminate signal TERMINATE_YOURSELF
                                	Zeile  43: 	Zeile 1944: 2023-04-14 07:06:58.547  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 send kill signal
                                	Zeile  44: 	Zeile 2028: 2023-04-14 07:07:00.593  - info: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                	Zeile  45: 	Zeile 2502: 2023-04-14 07:08:54.817  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1032326
                                	Zeile  46: 	Zeile 2503: 2023-04-14 07:08:55.926  - info: shuttercontrol.0 (1032326) starting. Version 1.4.25 (non-npm: simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236) in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.16.0, js-controller: 4.0.24
                                	Zeile  47: 	Zeile 2751: 2023-04-14 07:40:12.191  - error: shuttercontrol.0 (1032326) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                	Zeile  48: 	Zeile 2752: 2023-04-14 07:40:12.193  - error: shuttercontrol.0 (1032326) unhandled promise rejection: Cannot read properties of null (reading 'val')
                                	Zeile  49: 	Zeile 2753: 2023-04-14 07:40:12.201  - error: shuttercontrol.0 (1032326) TypeError: Cannot read properties of null (reading 'val')
                                	Zeile  50: 	Zeile 2754:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile  51: 	Zeile 2755: 2023-04-14 07:40:12.201  - error: shuttercontrol.0 (1032326) Cannot read properties of null (reading 'val')
                                	Zeile  52: 	Zeile 2756: 2023-04-14 07:40:12.210  - info: shuttercontrol.0 (1032326) cleaned everything up...
                                	Zeile  53: 	Zeile 2757: 2023-04-14 07:40:12.211  - info: shuttercontrol.0 (1032326) terminating
                                	Zeile  54: 	Zeile 2758: 2023-04-14 07:40:12.211  - warn: shuttercontrol.0 (1032326) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                	Zeile  55: 	Zeile 2761: 2023-04-14 07:40:12.764  - error: host.iobroker Caught by controller[1]:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile  56: 	Zeile 2762: 2023-04-14 07:40:12.764  - error: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                	Zeile  57: 	Zeile 2763: 2023-04-14 07:40:12.764  - info: host.iobroker Restart adapter system.adapter.shuttercontrol.0 because enabled
                                	Zeile  58: 	Zeile 2766: 2023-04-14 07:40:42.780  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1034247
                                	Zeile  59: 	Zeile 2767: 2023-04-14 07:40:44.258  - info: shuttercontrol.0 (1034247) starting. Version 1.4.25 (non-npm: simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236) in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.16.0, js-controller: 4.0.24
                                	Zeile  60: 	Zeile 2785: 2023-04-14 07:45:12.272  - error: shuttercontrol.0 (1034247) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                	Zeile  61: 	Zeile 2786: 2023-04-14 07:45:12.273  - error: shuttercontrol.0 (1034247) unhandled promise rejection: Cannot read properties of null (reading 'val')
                                	Zeile  62: 	Zeile 2787: 2023-04-14 07:45:12.275  - error: shuttercontrol.0 (1034247) TypeError: Cannot read properties of null (reading 'val')
                                	Zeile  63: 	Zeile 2788:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile  64: 	Zeile 2789: 2023-04-14 07:45:12.275  - error: shuttercontrol.0 (1034247) Cannot read properties of null (reading 'val')
                                	Zeile  65: 	Zeile 2790: 2023-04-14 07:45:12.284  - info: shuttercontrol.0 (1034247) cleaned everything up...
                                	Zeile  66: 	Zeile 2791: 2023-04-14 07:45:12.284  - info: shuttercontrol.0 (1034247) terminating
                                	Zeile  67: 	Zeile 2792: 2023-04-14 07:45:12.285  - warn: shuttercontrol.0 (1034247) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                	Zeile  68: 	Zeile 2795: 2023-04-14 07:45:12.837  - error: host.iobroker Caught by controller[1]:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile  69: 	Zeile 2796: 2023-04-14 07:45:12.837  - error: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                	Zeile  70: 	Zeile 2797: 2023-04-14 07:45:12.837  - info: host.iobroker Restart adapter system.adapter.shuttercontrol.0 because enabled
                                	Zeile  71: 	Zeile 2798: 2023-04-14 07:45:42.854  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1034482
                                	Zeile  72: 	Zeile 2799: 2023-04-14 07:45:44.189  - info: shuttercontrol.0 (1034482) starting. Version 1.4.25 (non-npm: simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236) in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.16.0, js-controller: 4.0.24
                                	Zeile  73: 	Zeile 2814: 2023-04-14 07:50:12.205  - error: shuttercontrol.0 (1034482) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                	Zeile  74: 	Zeile 2815: 2023-04-14 07:50:12.207  - error: shuttercontrol.0 (1034482) unhandled promise rejection: Cannot read properties of null (reading 'val')
                                	Zeile  75: 	Zeile 2816: 2023-04-14 07:50:12.210  - error: shuttercontrol.0 (1034482) TypeError: Cannot read properties of null (reading 'val')
                                	Zeile  76: 	Zeile 2817:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile  77: 	Zeile 2818: 2023-04-14 07:50:12.210  - error: shuttercontrol.0 (1034482) Cannot read properties of null (reading 'val')
                                	Zeile  78: 	Zeile 2819: 2023-04-14 07:50:12.219  - info: shuttercontrol.0 (1034482) cleaned everything up...
                                	Zeile  79: 	Zeile 2820: 2023-04-14 07:50:12.220  - info: shuttercontrol.0 (1034482) terminating
                                	Zeile  80: 	Zeile 2821: 2023-04-14 07:50:12.220  - warn: shuttercontrol.0 (1034482) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                	Zeile  81: 	Zeile 2824: 2023-04-14 07:50:12.792  - error: host.iobroker Caught by controller[1]:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile  82: 	Zeile 2825: 2023-04-14 07:50:12.792  - error: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                	Zeile  83: 	Zeile 2826: 2023-04-14 07:50:12.792  - info: host.iobroker Restart adapter system.adapter.shuttercontrol.0 because enabled
                                	Zeile  84: 	Zeile 2827: 2023-04-14 07:50:12.792  - warn: host.iobroker Do not restart adapter system.adapter.shuttercontrol.0 because restart loop detected
                                	Zeile  85: 	Zeile 2849: 2023-04-14 07:54:22.743  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1035403
                                	Zeile  86: 	Zeile 2852: 2023-04-14 07:54:25.215  - info: shuttercontrol.0 (1035403) starting. Version 1.4.25 (non-npm: simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236) in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.16.0, js-controller: 4.0.24
                                	Zeile  87: 	Zeile 2853: 2023-04-14 07:55:12.608  - error: shuttercontrol.0 (1035403) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                	Zeile  88: 	Zeile 2854: 2023-04-14 07:55:12.608  - error: shuttercontrol.0 (1035403) unhandled promise rejection: Cannot read properties of null (reading 'val')
                                	Zeile  89: 	Zeile 2855: 2023-04-14 07:55:12.610  - error: shuttercontrol.0 (1035403) TypeError: Cannot read properties of null (reading 'val')
                                	Zeile  90: 	Zeile 2856:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile  91: 	Zeile 2857: 2023-04-14 07:55:12.610  - error: shuttercontrol.0 (1035403) Cannot read properties of null (reading 'val')
                                	Zeile  92: 	Zeile 2858: 2023-04-14 07:55:12.640  - info: shuttercontrol.0 (1035403) cleaned everything up...
                                	Zeile  93: 	Zeile 2859: 2023-04-14 07:55:12.641  - info: shuttercontrol.0 (1035403) terminating
                                	Zeile  94: 	Zeile 2860: 2023-04-14 07:55:12.641  - warn: shuttercontrol.0 (1035403) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                	Zeile  95: 	Zeile 2863: 2023-04-14 07:55:13.202  - error: host.iobroker Caught by controller[1]:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile  96: 	Zeile 2864: 2023-04-14 07:55:13.202  - error: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                	Zeile  97: 	Zeile 2865: 2023-04-14 07:55:13.202  - info: host.iobroker Restart adapter system.adapter.shuttercontrol.0 because enabled
                                	Zeile  98: 	Zeile 2868: 2023-04-14 07:55:43.217  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1035493
                                	Zeile  99: 	Zeile 2869: 2023-04-14 07:55:44.606  - info: shuttercontrol.0 (1035493) starting. Version 1.4.25 (non-npm: simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236) in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.16.0, js-controller: 4.0.24
                                	Zeile 100: 	Zeile 2888: 2023-04-14 07:59:49.375  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
                                	Zeile 101: 	Zeile 2889: 2023-04-14 07:59:49.434  - info: shuttercontrol.0 (1035493) Got terminate signal TERMINATE_YOURSELF
                                	Zeile 102: 	Zeile 2890: 2023-04-14 07:59:49.438  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 send kill signal
                                	Zeile 103: 	Zeile 2891: 2023-04-14 07:59:49.436  - info: shuttercontrol.0 (1035493) cleaned everything up...
                                	Zeile 104: 	Zeile 2892: 2023-04-14 07:59:49.437  - info: shuttercontrol.0 (1035493) terminating
                                	Zeile 105: 	Zeile 2893: 2023-04-14 07:59:49.437  - info: shuttercontrol.0 (1035493) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                	Zeile 106: 	Zeile 2894: 2023-04-14 07:59:49.997  - info: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                	Zeile 107: 	Zeile 2895: 2023-04-14 07:59:52.464  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1035724
                                	Zeile 108: 	Zeile 2897: 2023-04-14 07:59:53.831  - info: shuttercontrol.0 (1035724) starting. Version 1.4.25 (non-npm: simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236) in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.16.0, js-controller: 4.0.24
                                	Zeile 109: 	Zeile 2907: 2023-04-14 08:00:12.487  - error: shuttercontrol.0 (1035724) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                	Zeile 110: 	Zeile 2908: 2023-04-14 08:00:12.489  - error: shuttercontrol.0 (1035724) unhandled promise rejection: Cannot read properties of null (reading 'val')
                                	Zeile 111: 	Zeile 2909: 2023-04-14 08:00:12.491  - error: shuttercontrol.0 (1035724) TypeError: Cannot read properties of null (reading 'val')
                                	Zeile 112: 	Zeile 2910:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile 113: 	Zeile 2911: 2023-04-14 08:00:12.491  - error: shuttercontrol.0 (1035724) Cannot read properties of null (reading 'val')
                                	Zeile 114: 	Zeile 2912: 2023-04-14 08:00:12.498  - info: shuttercontrol.0 (1035724) cleaned everything up...
                                	Zeile 115: 	Zeile 2913: 2023-04-14 08:00:12.499  - info: shuttercontrol.0 (1035724) terminating
                                	Zeile 116: 	Zeile 2914: 2023-04-14 08:00:12.499  - warn: shuttercontrol.0 (1035724) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                	Zeile 117: 	Zeile 2917: 2023-04-14 08:00:13.054  - error: host.iobroker Caught by controller[1]:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile 118: 	Zeile 2918: 2023-04-14 08:00:13.054  - error: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                	Zeile 119: 	Zeile 2919: 2023-04-14 08:00:13.054  - info: host.iobroker Restart adapter system.adapter.shuttercontrol.0 because enabled
                                	Zeile 120: 	Zeile 2922: 2023-04-14 08:00:43.087  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1035823
                                	Zeile 121: 	Zeile 2923: 2023-04-14 08:00:44.584  - info: shuttercontrol.0 (1035823) starting. Version 1.4.25 (non-npm: simatec/ioBroker.shuttercontrol#27b70e133a1012436c7f583835a5315148ce1236) in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.16.0, js-controller: 4.0.24
                                	Zeile 122: 	Zeile 2940: 2023-04-14 08:05:12.164  - error: shuttercontrol.0 (1035823) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                	Zeile 123: 	Zeile 2941: 2023-04-14 08:05:12.166  - error: shuttercontrol.0 (1035823) unhandled promise rejection: Cannot read properties of null (reading 'val')
                                	Zeile 124: 	Zeile 2942: 2023-04-14 08:05:12.167  - error: shuttercontrol.0 (1035823) TypeError: Cannot read properties of null (reading 'val')
                                	Zeile 125: 	Zeile 2943:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile 126: 	Zeile 2944: 2023-04-14 08:05:12.168  - error: shuttercontrol.0 (1035823) Cannot read properties of null (reading 'val')
                                	Zeile 127: 	Zeile 2945: 2023-04-14 08:05:12.178  - info: shuttercontrol.0 (1035823) cleaned everything up...
                                	Zeile 128: 	Zeile 2946: 2023-04-14 08:05:12.179  - info: shuttercontrol.0 (1035823) terminating
                                	Zeile 129: 	Zeile 2947: 2023-04-14 08:05:12.180  - warn: shuttercontrol.0 (1035823) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                	Zeile 130: 	Zeile 2950: 2023-04-14 08:05:12.732  - error: host.iobroker Caught by controller[1]:     at sunProtect (/opt/iobroker/node_modules/iobroker.shuttercontrol/lib/sunProtect.js:482:92)
                                	Zeile 131: 	Zeile 2951: 2023-04-14 08:05:12.732  - error: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                	Zeile 132: 	Zeile 2952: 2023-04-14 08:05:12.732  - info: host.iobroker Restart adapter system.adapter.shuttercontrol.0 because enabled
                                	Zeile 133: 	Zeile 2953: 2023-04-14 08:05:12.732  - warn: host.iobroker Do not restart adapter system.adapter.shuttercontrol.0 because restart loop detected
                                	Zeile 134: 	Zeile 2980: 2023-04-14 08:11:36.341  - info: host.iobroker iobroker upgrade shuttercontrol@1.4.23 --debug
                                	Zeile 135: 	Zeile 2981: 2023-04-14 08:11:38.453  - info: host.iobroker iobroker Update shuttercontrol from @1.4.25 to @1.4.23
                                	Zeile 136: 	Zeile 2982: 2023-04-14 08:11:38.469  - info: host.iobroker iobroker host.iobroker Adapter "system.adapter.shuttercontrol.0" is stopped.
                                	Zeile 137: 	Zeile 2983: 2023-04-14 08:11:38.533  - info: host.iobroker "system.adapter.shuttercontrol.0" disabled
                                	Zeile 138: 	Zeile 2984: 2023-04-14 08:11:40.126  - info: host.iobroker iobroker NPM version: 9.5.1Installing iobroker.shuttercontrol@1.4.23... (System call)
                                	Zeile 139: 	Zeile 2990: 2023-04-14 08:11:46.767  - info: host.iobroker iobroker Update "system.adapter.shuttercontrol.0"
                                	Zeile 140: 	Zeile 2991: 2023-04-14 08:11:46.928  - info: host.iobroker iobroker upload [5] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/img/info-big.png img/info-big.png image/png
                                	Zeile 141: 	Zeile 2992: 2023-04-14 08:11:46.986  - info: host.iobroker iobroker upload [4] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.html index_m.html text/html
                                	Zeile 142: 	Zeile 2993: 2023-04-14 08:11:46.991  - info: host.iobroker iobroker upload [3] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.js index_m.js application/javascript
                                	Zeile 143: 	Zeile 2994: 2023-04-14 08:11:46.996  - info: host.iobroker iobroker upload [2] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/shuttercontrol.png shuttercontrol.png image/png
                                	Zeile 144: 	Zeile 2995: 2023-04-14 08:11:47.002  - info: host.iobroker iobroker upload [1] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/style.css style.css text/css
                                	Zeile 145: 	Zeile 2996: 2023-04-14 08:11:47.013  - info: host.iobroker iobroker upload [0] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/words.js words.js application/javascript
                                	Zeile 146: 	Zeile 2997: 2023-04-14 08:11:47.018  - info: host.iobroker iobroker host.iobroker Adapter "system.adapter.shuttercontrol.0" is started
                                	Zeile 147: 	Zeile 2998: 2023-04-14 08:11:47.074  - info: host.iobroker "system.adapter.shuttercontrol.0" enabled
                                	Zeile 148: 	Zeile 2999: 2023-04-14 08:11:47.231  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1036423
                                	Zeile 149: 	Zeile 3001: 2023-04-14 08:11:49.356  - info: shuttercontrol.0 (1036423) starting. Version 1.4.23 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.16.0, js-controller: 4.0.24
                                	Zeile 150: 	Zeile 8903: 2023-04-14 10:22:57.353  - info: shuttercontrol.0 (1036423) Loglevel changed from "info" to "debug"
                                	Zeile 151: 	Zeile 8907: 2023-04-14 10:24:39.082  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.04cf8cdf3c7b5a7e.illuminance Value: 1683
                                	Zeile 152: 	Zeile 8909: 2023-04-14 10:24:52.892  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef4410000199f5.illuminance Value: 1356
                                	Zeile 153: 	Zeile 8911: 2023-04-14 10:25:00.018  - debug: shuttercontrol.0 (1036423) calculate astrodata ...
                                	Zeile 154: 	Zeile 8912: 2023-04-14 10:25:00.018  - debug: shuttercontrol.0 (1036423) Sun Azimut: 123.5°
                                	Zeile 155: 	Zeile 8913: 2023-04-14 10:25:00.019  - debug: shuttercontrol.0 (1036423) Sun Elevation: 36.3°
                                	Zeile 156: 	Zeile 8914: 2023-04-14 10:25:02.656  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef441000018d23.illuminance Value: 966
                                	Zeile 157: 	Zeile 8915: 2023-04-14 10:25:02.938  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef441000019dc2.illuminance Value: 56
                                	Zeile 158: 	Zeile 8916: 2023-04-14 10:25:05.627  - debug: shuttercontrol.0 (1036423) outsidetemperature changed: zigbee.0.00158d0006b0fc15.temperature Value: 7.35
                                	Zeile 159: 	Zeile 8917: 2023-04-14 10:25:19.617  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef4410000199d2.illuminance Value: 98
                                	Zeile 160: 	Zeile 8926: 2023-04-14 10:27:37.015  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef441000018d23.illuminance Value: 1053
                                	Zeile 161: 	Zeile 8930: 2023-04-14 10:27:52.120  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef4410000199f5.illuminance Value: 1524
                                	Zeile 162: 	Zeile 8931: 2023-04-14 10:27:53.223  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.04cf8cdf3c7b5a7e.illuminance Value: 1770
                                	Zeile 163: 	Zeile 8935: 2023-04-14 10:28:43.006  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef4410001ffb25.illuminance Value: 266
                                	Zeile 164: 	Zeile 8939: 2023-04-14 10:30:00.024  - debug: shuttercontrol.0 (1036423) calculate astrodata ...
                                	Zeile 165: 	Zeile 8940: 2023-04-14 10:30:00.025  - debug: shuttercontrol.0 (1036423) Sun Azimut: 124.8°
                                	Zeile 166: 	Zeile 8941: 2023-04-14 10:30:00.025  - debug: shuttercontrol.0 (1036423) Sun Elevation: 36.9°
                                	Zeile 167: 	Zeile 8950: 2023-04-14 10:30:25.423  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef441000019dc2.illuminance Value: 80
                                	Zeile 168: 	Zeile 8953: 2023-04-14 10:30:37.389  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.04cf8cdf3c7b5a7e.illuminance Value: 1712
                                	Zeile 169: 	Zeile 8960: 2023-04-14 10:33:23.147  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef4410002000c5.illuminance Value: 160
                                	Zeile 170: 	Zeile 8961: 2023-04-14 10:33:38.246  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef4410000199d2.illuminance Value: 114
                                	Zeile 171: 	Zeile 8965: 2023-04-14 10:35:00.020  - debug: shuttercontrol.0 (1036423) calculate astrodata ...
                                	Zeile 172: 	Zeile 8966: 2023-04-14 10:35:00.021  - debug: shuttercontrol.0 (1036423) Sun Azimut: 126.1°
                                	Zeile 173: 	Zeile 8967: 2023-04-14 10:35:00.021  - debug: shuttercontrol.0 (1036423) Sun Elevation: 37.6°
                                	Zeile 174: 	Zeile 8968: 2023-04-14 10:35:04.634  - debug: shuttercontrol.0 (1036423) insidetemperature changed: zigbee.0.00158d0001dde47f.temperature Value: 18.78
                                	Zeile 175: 	Zeile 8971: 2023-04-14 10:35:40.643  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.04cf8cdf3c7b35d1.illuminance Value: 444
                                	Zeile 176: 	Zeile 8972: 2023-04-14 10:35:45.916  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.04cf8cdf3c7b5a7e.illuminance Value: 1923
                                	Zeile 177: 	Zeile 8973: 2023-04-14 10:35:47.163  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef441000018d23.illuminance Value: 1244
                                	Zeile 178: 	Zeile 8974: 2023-04-14 10:35:49.813  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef4410000199f5.illuminance Value: 1718
                                	Zeile 179: 	Zeile 8975: 2023-04-14 10:36:12.772  - debug: shuttercontrol.0 (1036423) Lightsensor changed: zigbee.0.54ef4410000199d2.illuminance Value: 101
                                	Zeile 180: 	Zeile 8986: 2023-04-14 10:38:58.133  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
                                	Zeile 181: 	Zeile 8987: 2023-04-14 10:38:58.183  - info: shuttercontrol.0 (1036423) Got terminate signal TERMINATE_YOURSELF
                                	Zeile 182: 	Zeile 8988: 2023-04-14 10:38:58.184  - info: shuttercontrol.0 (1036423) cleaned everything up...
                                	Zeile 183: 	Zeile 8989: 2023-04-14 10:38:58.184  - info: shuttercontrol.0 (1036423) terminating
                                	Zeile 184: 	Zeile 8990: 2023-04-14 10:38:58.185  - debug: shuttercontrol.0 (1036423) Plugin sentry destroyed
                                	Zeile 185: 	Zeile 8991: 2023-04-14 10:38:58.185  - info: shuttercontrol.0 (1036423) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                	Zeile 186: 	Zeile 8992: 2023-04-14 10:38:58.194  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 send kill signal
                                	Zeile 187: 	Zeile 8993: 2023-04-14 10:38:58.764  - info: host.iobroker instance system.adapter.shuttercontrol.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                	Zeile 188: 	Zeile 8995: 2023-04-14 10:39:01.212  - info: host.iobroker instance system.adapter.shuttercontrol.0 started with pid 1043851
                                	Zeile 189: 	Zeile 8996: 2023-04-14 10:39:02.595  - info: shuttercontrol.0 (1043851) starting. Version 1.4.23 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.16.0, js-controller: 4.0.24
                                	Zeile 190: 	Zeile 9519: 2023-04-14 13:00:55.709  - info: shuttercontrol.0 (1043851) Sunprotect #414 Set ID: Rollo Schlafzimmer.ShutterControl.level value: 74%
                                  Die meisten meiner Rollos stehen aber auf Manu_Mode, inkl. dem, der heute nicht aus dem Sonnenschutz gekommen ist.
                                  welche Aktoren?
                                  firebowl
                                  #5610
                                  @homoran sagte in Test Adapter shuttercontrol v1.4.x:
                                  welche Aktoren?
                                  Sind die gleichen Bosch Aktoren wie die letzten beiden Jahre. Ich steuere aber Aliase an und nicht die Aktoren direkt weil der Level umgerechnet werden muss.
                                  Ist der Rollo zu 10% geschlossen, dann ist der Datenpunkt von Bosch bei 0,9 und damit kommt Shuttercontrol ja nicht klar.
                                  Im Alias steht bei 0,9 dann 10, aber das war von Anfang an so.
                                  Bei Position erst später bestimmen hab ich noch nie was eingestellt.
                                  Hab jetzt gerade noch mal nen Rollo von Hand bewegt und danach steht er natürlich auf Manu aber nach nem openAll bleibt er auf Manu, das war früher aber definitiv nicht so.
                                  Nach einem autoAll spring er wieder auf up anstatt Manu.
                                  • F firebowl
                                    welche Aktoren?
                                    HomoranH Offline
                                    HomoranH Offline
                                    #5611
                                    und was steht dann im debug log?
                                    F 1 Antwort Letzte Antwort
                                      firebowl
                                      #5612
                                      @homoran Nix, das ist ja das komische. Wenn ich den Rollo manuell bewege dann springt er erwartungsgemäß auf Manu aber das steht nicht im Log.
                                      Hier das Log vom openAll und dann autoAll und davor ist nichts von wechsel auf manu weil ich was manuell gemacht hab.
                                      shuttercontrol.0
                                      2023-04-14 19:04:55.228	info	Set ID: Rollo Terrassentür.ShutterControl.level to Auto-Mode
                                      shuttercontrol.0
                                      2023-04-14 19:04:53.176	info	Set ID: Rollo Küchenfenster.ShutterControl.level to Auto-Mode
                                      shuttercontrol.0
                                      2023-04-14 19:04:51.124	info	Set ID: Rolllo Treppenhaus EG.ShutterControl.level to Auto-Mode
                                      shuttercontrol.0
                                      2023-04-14 19:04:49.070	info	Set ID: Rollo Esszimmer.ShutterControl.level to Auto-Mode
                                      shuttercontrol.0
                                      2023-04-14 19:04:47.021	info	Set ID: Rollo Wohnzimmer.ShutterControl.level to Auto-Mode
                                      shuttercontrol.0
                                      2023-04-14 19:04:44.968	info	Set ID: Rollo Büro Mike.ShutterControl.level to Auto-Mode
                                      shuttercontrol.0
                                      2023-04-14 19:04:42.917	info	Set ID: Rollo Büro Steffi.ShutterControl.level to Auto-Mode
                                      shuttercontrol.0
                                      2023-04-14 19:04:40.864	info	Set ID: Rolllo Treppenhaus OG.ShutterControl.level to Auto-Mode
                                      shuttercontrol.0
                                      2023-04-14 19:04:38.813	info	Set ID: Rollo Badezimmer.ShutterControl.level to Auto-Mode
                                      shuttercontrol.0
                                      2023-04-14 19:04:36.760	info	Set ID: Rollo Schlafzimmer.ShutterControl.level to Auto-Mode
                                      shuttercontrol.0
                                      2023-04-14 19:04:34.708	info	Set ID: Rollo Kinderzimmer.ShutterControl.level to Auto-Mode
                                      shuttercontrol.0
                                      2023-04-14 19:04:06.294	info	Button openAll Set ID: Rollo Büro Mike.ShutterControl.level value: 0%
                                      • F firebowl
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        HomoranH Offline
                                        HomoranH Offline
                                        #5613
                                        @firebowl das ist kein debug log, nur info
                                        • W Offline
                                          W Offline
                                          WeiserWolf
                                          #5614
                                          @simatec Das Problem mit end of sunprotection funktioniert mit 1.4.24 und höher nach wie vor nicht bei mir.
                                          bleibe jetzt mal bei der 1.4.26
