  4. Einstellungen von Shuttercontrol
    5.4k
43 Beiträge 5 Kommentatoren 4.9k Aufrufe 7 Beobachtet
  • S StealthAngel
    @simatec
    shuttercontrol.0 2023-04-01 18:58:56.640	debug	Brightness State Down is: false
    shuttercontrol.0 2023-04-01 18:58:46.639	debug	Brightness sensor value: 831.9
    shuttercontrol.0 2023-04-01 18:56:46.623	debug	Brightness State Down is: false
    shuttercontrol.0 2023-04-01 18:56:36.622	debug	Brightness sensor value: 878.7
    shuttercontrol.0 2023-04-01 18:55:00.024	debug	Sun Elevation: 8.6°
    shuttercontrol.0 2023-04-01 18:55:00.023	debug	Sun Azimut: 266.3°
    shuttercontrol.0 2023-04-01 18:55:00.020	debug	calculate astrodata ...
    shuttercontrol.0 2023-04-01 18:54:22.145	debug	Brightness State Down is: false
    shuttercontrol.0 2023-04-01 18:54:12.143	debug	Brightness sensor value: 945.8
    shuttercontrol.0 2023-04-01 18:52:02.053	debug	status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
    shuttercontrol.0 2023-04-01 18:52:02.052	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0 2023-04-01 18:52:02.051	debug	Büro level conversion is disabled ...
    shuttercontrol.0 2023-04-01 18:51:43.204	debug	Brightness State Down is: false
    shuttercontrol.0 2023-04-01 18:51:33.203	debug	Brightness sensor value: 1002.8
    shuttercontrol.0 2023-04-01 18:50:02.051	debug	status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
    shuttercontrol.0 2023-04-01 18:50:02.049	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0 2023-04-01 18:50:02.049	debug	Büro level conversion is disabled ...
    shuttercontrol.0 2023-04-01 18:50:00.011	debug	Sun Elevation: 9.4°
    shuttercontrol.0 2023-04-01 18:50:00.011	debug	Sun Azimut: 265.3°
    shuttercontrol.0 2023-04-01 18:50:00.010	debug	calculate astrodata ...
    shuttercontrol.0 2023-04-01 18:48:49.900	debug	Brightness State Down is: false
    shuttercontrol.0 2023-04-01 18:48:39.899	debug	Brightness sensor value: 1025.1
    shuttercontrol.0 2023-04-01 18:46:46.084	debug	Brightness State Down is: false
    shuttercontrol.0 2023-04-01 18:46:36.083	debug	Brightness sensor value: 1037.3
    shuttercontrol.0 2023-04-01 18:45:02.060	debug	status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
    shuttercontrol.0 2023-04-01 18:45:02.059	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0 2023-04-01 18:45:00.022	debug	Sun Elevation: 10.1°
    shuttercontrol.0 2023-04-01 18:45:00.022	debug	Sun Azimut: 264.3°
    shuttercontrol.0 2023-04-01 18:45:00.021	debug	calculate astrodata ...
    shuttercontrol.0 2023-04-01 18:44:27.876	debug	Brightness State Down is: false
    shuttercontrol.0 2023-04-01 18:44:17.875	debug	Brightness sensor value: 1078
    shuttercontrol.0 2023-04-01 18:41:55.378	debug	Brightness State Down is: false
    shuttercontrol.0 2023-04-01 18:41:45.376	debug	Brightness sensor value: 1104.5
    shuttercontrol.0 2023-04-01 18:40:02.023	debug	status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
    shuttercontrol.0 2023-04-01 18:40:02.022	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0 2023-04-01 18:40:00.013	debug	Sun Elevation: 10.9°
    shuttercontrol.0 2023-04-01 18:40:00.013	debug	Sun Azimut: 263.3°
    shuttercontrol.0 2023-04-01 18:40:00.012	debug	calculate astrodata ...
    simatecS Offline
    simatecS Offline
    simatec
    @stealthangel OK gehen wir mal anderes an... Wenn dein Rollladen im Sonnenschutz fährt, wird im autoState sauber sunProtect gesetzt?
    Kannst auch mal den Log posten, wenn der Sonnenschutz aktiviert wird
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • simatecS simatec
      StealthAngel
      @simatec said in Einstellungen von Shuttercontrol:
      So wie ich das sehe, ja.
      2023-04-01 14:50:00.045 - debug: shuttercontrol.0 (131673) Sun Elevation: 39.6°
      2023-04-01 14:50:02.061 - debug: shuttercontrol.0 (131673) start pendingAlarm to check if an alarm is currently pending (exept frost)
      2023-04-01 14:50:02.062 - debug: shuttercontrol.0 (131673) status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
      2023-04-01 14:51:06.770 - debug: shuttercontrol.0 (131673) start pendingAlarm to check if an alarm is currently pending (exept frost)
      2023-04-01 14:51:06.772 - debug: shuttercontrol.0 (131673) Brightness sensor value: 4602
      2023-04-01 14:51:06.805 - debug: shuttercontrol.0 (131673) status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
      2023-04-01 14:51:07.862 - debug: shuttercontrol.0 (131673) Lightsensor up Büro already up at: 100% - setting current action: up
      2023-04-01 14:51:16.773 - debug: shuttercontrol.0 (131673) Brightness State Down is: false
      2023-04-01 14:53:27.486 - debug: shuttercontrol.0 (131673) start pendingAlarm to check if an alarm is currently pending (exept frost)
      2023-04-01 14:53:27.487 - debug: shuttercontrol.0 (131673) Brightness sensor value: 4591
      2023-04-01 14:53:27.489 - debug: shuttercontrol.0 (131673) status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
      2023-04-01 14:53:28.571 - debug: shuttercontrol.0 (131673) Lightsensor up Büro already up at: 100% - setting current action: up
      2023-04-01 14:53:37.488 - debug: shuttercontrol.0 (131673) Brightness State Down is: false
      2023-04-01 14:55:00.014 - debug: shuttercontrol.0 (131673) calculate astrodata ...
      2023-04-01 14:55:00.015 - debug: shuttercontrol.0 (131673) Sun Azimut: 208.4°
      2023-04-01 14:55:00.016 - debug: shuttercontrol.0 (131673) Sun Elevation: 39.2°
      2023-04-01 14:55:02.024 - debug: shuttercontrol.0 (131673) start pendingAlarm to check if an alarm is currently pending (exept frost)
      2023-04-01 14:55:02.025 - debug: shuttercontrol.0 (131673) status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
      2023-04-01 14:55:33.773 - debug: shuttercontrol.0 (131673) start pendingAlarm to check if an alarm is currently pending (exept frost)
      2023-04-01 14:55:33.774 - debug: shuttercontrol.0 (131673) Brightness sensor value: 4519
      2023-04-01 14:55:33.817 - debug: shuttercontrol.0 (131673) status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
      2023-04-01 14:55:34.874 - debug: shuttercontrol.0 (131673) Lightsensor up Büro already up at: 100% - setting current action: up
      2023-04-01 14:55:43.776 - debug: shuttercontrol.0 (131673) Brightness State Down is: false
      2023-04-01 14:58:29.519 - debug: shuttercontrol.0 (131673) start pendingAlarm to check if an alarm is currently pending (exept frost)
      2023-04-01 14:58:29.521 - debug: shuttercontrol.0 (131673) Brightness sensor value: 4320
      2023-04-01 14:58:29.525 - debug: shuttercontrol.0 (131673) status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
      2023-04-01 14:58:30.637 - debug: shuttercontrol.0 (131673) Lightsensor up Büro already up at: 100% - setting current action: up
      2023-04-01 14:58:39.522 - debug: shuttercontrol.0 (131673) Brightness State Down is: false
      2023-04-01 15:00:00.029 - debug: shuttercontrol.0 (131673) calculate astrodata ...
      2023-04-01 15:00:00.030 - debug: shuttercontrol.0 (131673) Sun Azimut: 210°
      2023-04-01 15:00:00.031 - debug: shuttercontrol.0 (131673) Sun Elevation: 38.8°
      2023-04-01 15:00:02.047 - debug: shuttercontrol.0 (131673) start pendingAlarm to check if an alarm is currently pending (exept frost)
      2023-04-01 15:00:02.051 - debug: shuttercontrol.0 (131673) status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
      2023-04-01 15:00:45.882 - info: web.0 (1054) ==> Connected system.user.admin from ::ffff:192.168.2.21
      2023-04-01 15:00:45.941 - info: web.0 (1054) ==> Connected system.user.admin from ::ffff:192.168.2.21
      2023-04-01 15:00:45.951 - info: web.0 (1054) ==> Connected system.user.admin from ::ffff:192.168.2.21
      2023-04-01 15:00:45.983 - info: web.0 (1054) ==> Connected system.user.admin from ::ffff:192.168.2.21
      2023-04-01 15:00:46.194 - info: web.0 (1054) ==> Connected system.user.admin from ::ffff:192.168.2.21
      2023-04-01 15:00:54.785 - info: web.0 (1054) ==> Connected system.user.admin from ::ffff:192.168.2.21
      2023-04-01 15:01:11.007 - debug: shuttercontrol.0 (131673) start pendingAlarm to check if an alarm is currently pending (exept frost)
      2023-04-01 15:01:11.008 - debug: shuttercontrol.0 (131673) Brightness sensor value: 4080
      2023-04-01 15:01:11.042 - debug: shuttercontrol.0 (131673) status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
      2023-04-01 15:01:12.101 - debug: shuttercontrol.0 (131673) Lightsensor up Büro already up at: 100% - setting current action: up
      2023-04-01 15:01:21.010 - debug: shuttercontrol.0 (131673) Brightness State Down is: false
      2023-04-01 15:03:38.021 - debug: shuttercontrol.0 (131673) start pendingAlarm to check if an alarm is currently pending (exept frost)
      2023-04-01 15:03:38.022 - debug: shuttercontrol.0 (131673) Brightness sensor value: 3841
      2023-04-01 15:03:38.028 - debug: shuttercontrol.0 (131673) status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
      2023-04-01 15:03:39.097 - debug: shuttercontrol.0 (131673) Lightsensor up Büro already up at: 100% - setting current action: up
      2023-04-01 15:03:48.023 - debug: shuttercontrol.0 (131673) Brightness State Down is: false
      2023-04-01 15:05:00.046 - debug: shuttercontrol.0 (131673) calculate astrodata ...
      2023-04-01 15:05:00.048 - debug: shuttercontrol.0 (131673) Sun Azimut: 211.5°
      2023-04-01 15:05:00.049 - debug: shuttercontrol.0 (131673) Sun Elevation: 38.4°
      2023-04-01 15:05:02.070 - debug: shuttercontrol.0 (131673) start pendingAlarm to check if an alarm is currently pending (exept frost)
      2023-04-01 15:05:02.072 - debug: shuttercontrol.0 (131673) status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
      2023-04-01 15:05:02.116 - debug: shuttercontrol.0 (131673) Büro: Check basis for sunprotect. Height:100 > HeightDownSun: 30 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
      2023-04-01 15:05:02.118 - info: shuttercontrol.0 (131673) Sunprotect #416 Set ID: Büro value: 30%
      2023-04-01 15:05:02.169 - info: mqtt.0 (955) send2Server mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos[shellies/Buero/Rolladen/roller/0/command/pos]
      2023-04-01 15:05:02.171 - debug: shuttercontrol.0 (131673) #0 wait for shutter check started
      2023-04-01 15:05:02.186 - debug: shuttercontrol.0 (131673) Sunprotect for Büro is active
      2023-04-01 15:05:02.187 - debug: shuttercontrol.0 (131673) RangeMinus: 210 < 211.5RangePlus: 390 > 211.5
      2023-04-01 15:05:02.187 - debug: shuttercontrol.0 (131673) last automatic Action for Büro: down_Sunprotect
      2023-04-01 15:05:02.187 - debug: shuttercontrol.0 (131673) Sunprotect Büro old height: 100% new height: 30%
      2023-04-01 15:05:22.172 - debug: shuttercontrol.0 (131673) #0 wait for shutter check end
      2023-04-01 15:05:22.177 - debug: shuttercontrol.0 (131673) Shutter state changed: Büro old value = 100 new value = 30
      2023-04-01 15:05:22.178 - debug: shuttercontrol.0 (131673) Büro Old value = 100. New value = 30. automatic is active
      2023-04-01 15:05:50.509 - debug: shuttercontrol.0 (131673) start pendingAlarm to check if an alarm is currently pending (exept frost)
      2023-04-01 15:05:50.509 - debug: shuttercontrol.0 (131673) Brightness sensor value: 3875
      2023-04-01 15:05:50.541 - debug: shuttercontrol.0 (131673) status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
      2023-04-01 15:05:50.596 - debug: shuttercontrol.0 (131673) Lightsensor up Büro already up at: 100% - setting current action: sunProtect
      2023-04-01 15:06:00.510 - debug: shuttercontrol.0 (131673) Brightness State Down is: false
      2023-04-01 15:08:52.737 - debug: shuttercontrol.0 (131673) start pendingAlarm to check if an alarm is currently pending (exept frost)
      2023-04-01 15:08:52.738 - debug: shuttercontrol.0 (131673) Brightness sensor value: 4014
      2023-04-01 15:08:52.742 - debug: shuttercontrol.0 (131673) status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
      2023-04-01 15:08:52.913 - debug: shuttercontrol.0 (131673) Lightsensor up Büro already up at: 100% - setting current action: sunProtect
      2023-04-01 15:09:02.740 - debug: shuttercontrol.0 (131673) Brightness State Down is: false
      2023-04-01 15:10:00.012 - debug: shuttercontrol.0 (131673) calculate astrodata ...
      2023-04-01 15:10:00.012 - debug: shuttercontrol.0 (131673) Sun Azimut: 213°
      2023-04-01 15:10:00.013 - debug: shuttercontrol.0 (131673) Sun Elevation: 38°
      2023-04-01 15:10:02.022 - debug: shuttercontrol.0 (131673) start pendingAlarm to check if an alarm is currently pending (exept frost)
      2023-04-01 15:10:02.026 - debug: shuttercontrol.0 (131673) status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
      2023-04-01 15:11:40.501 - debug: shuttercontrol.0 (131673) start pendingAlarm to check if an alarm is currently pending (exept frost)
      2023-04-01 15:11:40.502 - debug: shuttercontrol.0 (131673) Brightness sensor value: 4138
      2023-04-01 15:11:40.539 - debug: shuttercontrol.0 (131673) status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
      2023-04-01 15:11:40.591 - debug: shuttercontrol.0 (131673) Lightsensor up Büro already up at: 100% - setting current action: sunProtect
      2023-04-01 15:11:50.503 - debug: shuttercontrol.0 (131673) Brightness State Down is: false
      2023-04-01 15:14:13.761 - debug: shuttercontrol.0 (131673) start pendingAlarm to check if an alarm is currently pending (exept frost)
      2023-04-01 15:14:13.763 - debug: shuttercontrol.0 (131673) Brightness sensor value: 4158
      2023-04-01 15:14:13.800 - debug: shuttercontrol.0 (131673) status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
      2023-04-01 15:14:13.856 - debug: shuttercontrol.0 (131673) Lightsensor up Büro already up at: 100% - setting current action: sunProtect
      2023-04-01 15:14:23.764 - debug: shuttercontrol.0 (131673) Brightness State Down is: false
      2023-04-01 15:15:00.024 - debug: shuttercontrol.0 (131673) calculate astrodata ...
      2023-04-01 15:15:00.025 - debug: shuttercontrol.0 (131673) Sun Azimut: 214.5°
      2023-04-01 15:15:00.026 - debug: shuttercontrol.0 (131673) Sun Elevation: 37.6°
      • S StealthAngel
        simatecS Offline
        simatecS Offline
        simatec
        @stealthangel Habe es jetzt noch einmal nachgestellt...
        Deine Werte für Himmelsrichtung und Range können so nicht passen.
        Du kannst dir die richtigen Werte für deinen Standort und dein Fensterausrichtung bei https://www.sonnenverlauf.de ermitteln.
        Wenn ich aber deine Range sehe, dann kann das nicht passen. Du gibst 300 als Himmelsrichtung ein und eine Range von 90.
        Das würde bedeuten, dass bei größer 210 der Sonnenschutz aktiviert wird und bei größer 390 deaktiviert wird.
        390 ° gibt es nicht.
        Hier sollte der maximale Wert bei 360 liegen.
        Wenn ich jetzt aber ein Fenster habe, dass Richtung Westen liegt, dann sollte die Einstellung von 290° und einer Range von 50-60 ° ausreichend sein.
        Des Weiteren würde ich das Ende des Sonneschutzes im Verhältnis zum schließen de Lichtsensors nicht zu knapp machen. Setze lieber das Ende des Sonnenschutzes auf 12 oder 15
        • simatecS simatec
          StealthAngel
          @simatec Es ist mir ja schon fast peinlich, aber das war nicht die Lösung.
          Die Werte für das Fenster habe ich jetzt angepasst und Elevation steht jetzt auf 15°, aber nix passiert:
          2023-04-04 18:09:05.857 - debug: shuttercontrol.0 (144217) Brightness sensor value: 3883
          2023-04-04 18:09:15.859 - debug: shuttercontrol.0 (144217) Brightness State Down is: false
          2023-04-04 18:10:00.010 - debug: shuttercontrol.0 (144217) calculate astrodata ...
          2023-04-04 18:10:00.010 - debug: shuttercontrol.0 (144217) Sun Azimut: 258.1°
          2023-04-04 18:10:00.011 - debug: shuttercontrol.0 (144217) Sun Elevation: 16.3°
          2023-04-04 18:10:02.020 - debug: shuttercontrol.0 (144217) start pendingAlarm to check if an alarm is currently pending (exept frost)
          2023-04-04 18:10:02.021 - debug: shuttercontrol.0 (144217) status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
          2023-04-04 18:11:20.335 - debug: shuttercontrol.0 (144217) Brightness sensor value: 3852
          2023-04-04 18:11:30.336 - debug: shuttercontrol.0 (144217) Brightness State Down is: false
          2023-04-04 18:13:20.378 - debug: shuttercontrol.0 (144217) Brightness sensor value: 3830
          2023-04-04 18:13:30.379 - debug: shuttercontrol.0 (144217) Brightness State Down is: false
          2023-04-04 18:15:00.018 - debug: shuttercontrol.0 (144217) calculate astrodata ...
          2023-04-04 18:15:00.019 - debug: shuttercontrol.0 (144217) Sun Azimut: 259.1°
          2023-04-04 18:15:00.020 - debug: shuttercontrol.0 (144217) Sun Elevation: 15.5°
          2023-04-04 18:15:02.035 - debug: shuttercontrol.0 (144217) start pendingAlarm to check if an alarm is currently pending (exept frost)
          2023-04-04 18:15:02.036 - debug: shuttercontrol.0 (144217) status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
          2023-04-04 18:16:09.880 - debug: shuttercontrol.0 (144217) Brightness sensor value: 3807
          2023-04-04 18:16:19.881 - debug: shuttercontrol.0 (144217) Brightness State Down is: false
          2023-04-04 18:18:45.081 - debug: shuttercontrol.0 (144217) Brightness sensor value: 3789
          2023-04-04 18:18:55.082 - debug: shuttercontrol.0 (144217) Brightness State Down is: false
          2023-04-04 18:20:00.020 - debug: shuttercontrol.0 (144217) calculate astrodata ...
          2023-04-04 18:20:00.021 - debug: shuttercontrol.0 (144217) Sun Azimut: 260.1°
          2023-04-04 18:20:00.022 - debug: shuttercontrol.0 (144217) Sun Elevation: 14.7°
          2023-04-04 18:20:02.039 - debug: shuttercontrol.0 (144217) Buero level conversion is disabled ...
          2023-04-04 18:20:02.039 - debug: shuttercontrol.0 (144217) start pendingAlarm to check if an alarm is currently pending (exept frost)
          2023-04-04 18:20:02.041 - debug: shuttercontrol.0 (144217) status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
          2023-04-04 18:21:05.884 - debug: shuttercontrol.0 (144217) Brightness sensor value: 3767
          2023-04-04 18:21:15.884 - debug: shuttercontrol.0 (144217) Brightness State Down is: false
          2023-04-04 18:22:02.041 - debug: shuttercontrol.0 (144217) Buero level conversion is disabled ...
          2023-04-04 18:22:02.041 - debug: shuttercontrol.0 (144217) start pendingAlarm to check if an alarm is currently pending (exept frost)
          2023-04-04 18:22:02.042 - debug: shuttercontrol.0 (144217) status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
          2023-04-04 18:23:12.134 - debug: shuttercontrol.0 (144217) Brightness sensor value: 3761
          2023-04-04 18:23:22.136 - debug: shuttercontrol.0 (144217) Brightness State Down is: false
          2023-04-04 18:25:00.016 - debug: shuttercontrol.0 (144217) calculate astrodata ...
          2023-04-04 18:25:00.016 - debug: shuttercontrol.0 (144217) Sun Azimut: 261.1°
          2023-04-04 18:25:00.017 - debug: shuttercontrol.0 (144217) Sun Elevation: 14°
          2023-04-04 18:25:02.037 - debug: shuttercontrol.0 (144217) Buero level conversion is disabled ...
          2023-04-04 18:25:02.037 - debug: shuttercontrol.0 (144217) start pendingAlarm to check if an alarm is currently pending (exept frost)
          2023-04-04 18:25:02.040 - debug: shuttercontrol.0 (144217) status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
          2023-04-04 18:26:07.826 - debug: shuttercontrol.0 (144217) Brightness sensor value: 3767
          2023-04-04 18:26:17.827 - debug: shuttercontrol.0 (144217) Brightness State Down is: false
          2023-04-04 18:27:02.046 - debug: shuttercontrol.0 (144217) Buero level conversion is disabled ...
          2023-04-04 18:27:02.047 - debug: shuttercontrol.0 (144217) start pendingAlarm to check if an alarm is currently pending (exept frost)
          2023-04-04 18:27:02.052 - debug: shuttercontrol.0 (144217) status alarm pending for mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos: false
          2023-04-04 18:28:49.380 - debug: shuttercontrol.0 (144217) Brightness sensor value: 3737
          2023-04-04 18:28:59.380 - debug: shuttercontrol.0 (144217) Brightness State Down is: false
          2023-04-04 18:30:00.009 - debug: shuttercontrol.0 (144217) calculate astrodata ...
          2023-04-04 18:30:00.010 - debug: shuttercontrol.0 (144217) Sun Azimut: 262.2°
          2023-04-04 18:30:00.010 - debug: shuttercontrol.0 (144217) Sun Elevation: 13.2°
          2023-04-04 18:31:16.376 - debug: shuttercontrol.0 (144217) Brightness sensor value: 3700
          2023-04-04 18:31:26.377 - debug: shuttercontrol.0 (144217) Brightness State Down is: false
          2023-04-04 18:33:28.866 - debug: shuttercontrol.0 (144217) Brightness sensor value: 3678
          2023-04-04 18:33:38.869 - debug: shuttercontrol.0 (144217) Brightness State Down is: false
          2023-04-04 18:35:00.009 - debug: shuttercontrol.0 (144217) calculate astrodata ...
          2023-04-04 18:35:00.009 - debug: shuttercontrol.0 (144217) Sun Azimut: 263.2°
          2023-04-04 18:35:00.010 - debug: shuttercontrol.0 (144217) Sun Elevation: 12.5°
          2023-04-04 18:36:31.161 - debug: shuttercontrol.0 (144217) Brightness sensor value: 3602
          2023-04-04 18:36:41.163 - debug: shuttercontrol.0 (144217) Brightness State Down is: false
          2023-04-04 18:39:18.867 - debug: shuttercontrol.0 (144217) Brightness sensor value: 3590
          2023-04-04 18:39:28.868 - debug: shuttercontrol.0 (144217) Brightness State Down is: false
          Kannst Du bitte noch mal schauen? Welche Daten brauchst Du?
          Vielen Dank.....
          • simatecS Offline
            simatecS Offline
            simatec
            @stealthangel Stelle mal in den Rollladen Einstellungen die Automatik auch bei geöffneten Fenster ein.
            Passt der Wert 0 für den Fensterkontakt?
            • simatecS simatec
              StealthAngel
              Ich denke, das passt.
              Ich habe jetzt in den Sourcecode mal ein paar Debugs eingebaut.
              In die if Bedingung
              if ((currentValue === mustValue || currentValue === mustValueTilted) && shutterSettings[s].tempSensor != '' || (currentValue != mustValue && currentValue != mustValueTilted && shutterSettings[s].autoDrive != 'onlyDown' && shutterSettings[s].autoDrive != 'off') || (shutterSettings[s].triggerID == '')) {
              springt er schon nicht mehr rein.
              Die Objekte sind
              CurrentValue: 0
              mustValue: 0
              mustValueTilted: 0
              shutterSettungs.temp:
              shutterSettings[s].autoDrive: upDown
              shutterSettings[s].triggerID: hm-rpc.1.00155D898A87A1.1.STATE
              shutterSettings[s].driveAfterClose: false
              Mit meinen stümperhaften Programmierkenntnissen würde ich sagen es liegt an
              Aber ich habe keinen Temperatursensor :-(
              Was kann ich da tun?
              Danke für Eure Hilfe....
              TolkinT simatecS 2 Antworten Letzte Antwort
              • S StealthAngel
                In die if Bedingung
                Die Objekte sind
                CurrentValue: 0
                mustValue: 0
                mustValueTilted: 0
                TolkinT Offline
                TolkinT Offline
                Tolkin
                Mahlzeit und Frohe Ostern zusammen. Da einige Shelly's 2,5 bei mir defekt waren, habe ich heute neue Shelly's 2PM verbaut. Jetzt wollte ich gerade im ShutterControl Adapter die neuen Shellys hinzufügen und sehe, dass es den Reiter Position nicht mehr gibt? Kann mir jemand weiterhelfen und sagen wie ich bei den neuen Shelly's 2PM auf Positon fahren kann?
                • TolkinT Tolkin
                  StealthAngel
                  @tolkin said in Einstellungen von Shuttercontrol:
                  ....sagen wie ich bei den neuen Shelly's 2PM auf Positon fahren kann?
                  Schau mal hier:
                  Shelly Gen 2 Device API
                  und hier:
                  MQTT Control
                  Bei weiteren Fragen besser ein neues Thema aufmachen, das es nix mit den Shuttercontrol Adapter zu tun hat....
                  • S StealthAngel
                    In die if Bedingung
                    Die Objekte sind
                    CurrentValue: 0
                    mustValue: 0
                    mustValueTilted: 0
                    simatecS Offline
                    simatecS Offline
                    simatec
                    @stealthangel sagte in Einstellungen von Shuttercontrol:
                    Trage doch mal zum testen irgendeine ID bei tempSensor ein.
                    Damit könnte man den Fehler erstmal eingrenzen
                    • S StealthAngel
                      Schau mal hier:
                      und hier:
                      MQTT Control
                      simatecS Offline
                      simatecS Offline
                      simatec
                      @stealthangel Teste bitte mal die v1.4.24 ... Da sollte es egal sein, ob du einen Temperatursensor hast
                      • simatecS simatec
                        StealthAngel
                        Ich habe vermutlich den Fehler gefunden :-) Mit Temp-Sensor geht es.
                        Das ist aber gar nicht nötig. In der "sunProtect.js" ist in ca. Zeile 1251 steht die if-Bedingung
                        In der ganzen if-Bedingung wird "shutterSettings[].tempSensor" aber nicht gebraucht.
                        Aus meiner Sicht müsste
                        && shutterSettings[].tempSensor != ''
                        ersatzlos gelöscht werden. Habe ich auch ausprobiert. Damit klappt es.
                        Lade ich gleich mal und Teste....
                        • simatecS simatec
                          StealthAngel
                          Jau, damit klappt es. Super, danke.
                          Allerdings war es jetzt so, dass als sunProtect bei 210° Azimut gestartet wurde ist der Rollladen 3x innerhalb von wenigen Minuten runter und rauf gefahren 😨
                          2023-04-11 14:55:02.018 - info: shuttercontrol.0 (175760) Sunprotect #416 Set ID: Buero value: 30%
                          2023-04-11 14:55:02.037 - info: mqtt.0 (955) send2Server mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos[shellies/Buero/Rolladen/roller/0/command/pos]
                          2023-04-11 14:55:29.544 - info: shuttercontrol.0 (175760) Lightsensor #5 Set ID: Buero value: 100%
                          2023-04-11 14:55:29.552 - info: mqtt.0 (955) send2Server mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos[shellies/Buero/Rolladen/roller/0/command/pos]
                          2023-04-11 14:55:31.535 - info: shuttercontrol.0 (175760) Sunprotect #416 Set ID: Buero value: 30%
                          2023-04-11 14:55:31.542 - info: mqtt.0 (955) send2Server mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos[shellies/Buero/Rolladen/roller/0/command/pos]
                          2023-04-11 14:57:59.509 - info: shuttercontrol.0 (175760) Lightsensor #5 Set ID: Buero value: 100%
                          2023-04-11 14:57:59.519 - info: mqtt.0 (955) send2Server mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos[shellies/Buero/Rolladen/roller/0/command/pos]
                          2023-04-11 14:58:01.499 - info: shuttercontrol.0 (175760) Sunprotect #416 Set ID: Buero value: 30%
                          2023-04-11 14:58:01.505 - info: mqtt.0 (955) send2Server mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos[shellies/Buero/Rolladen/roller/0/command/pos]
                          Das war mit der Version davor nicht. (Obwohl ich gestehen muss, das heute noch zusätzlich "autoDown auf false gesetzt war).
                          Eine Idee dazu?....
                          • S StealthAngel
                            Eine Idee dazu?....
                            simatecS Offline
                            simatecS Offline
                            simatec
                            @stealthangel was sagt der Debuglog?
                            • simatecS simatec
                              StealthAngel
                              2023-04-12 14:50:00.010 - debug: shuttercontrol.0 (179737) calculate astrodata ...
                              2023-04-12 14:50:00.010 - debug: shuttercontrol.0 (179737) Sun Azimut: 209.5°
                              2023-04-12 14:50:00.011 - debug: shuttercontrol.0 (179737) Sun Elevation: 43.3°
                              2023-04-12 14:50:09.334 - debug: shuttercontrol.0 (179737) Brightness State Down is: false
                              2023-04-12 14:52:53.560 - debug: shuttercontrol.0 (179737) Brightness sensor value: 4125
                              2023-04-12 14:52:53.608 - debug: shuttercontrol.0 (179737) Lightsensor up Buero already up at: 100% - setting current action: up
                              2023-04-12 14:53:03.561 - debug: shuttercontrol.0 (179737) Brightness State Down is: false
                              2023-04-12 14:55:00.007 - debug: shuttercontrol.0 (179737) calculate astrodata ...
                              2023-04-12 14:55:00.008 - debug: shuttercontrol.0 (179737) Sun Azimut: 211.1°
                              2023-04-12 14:55:00.008 - debug: shuttercontrol.0 (179737) Sun Elevation: 42.9°
                              2023-04-12 14:55:02.018 - debug: shuttercontrol.0 (179737) Buero: Check basis for sunprotect. Height:100 > HeightDownSun: 30 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                              2023-04-12 14:55:02.019 - info: shuttercontrol.0 (179737) Sunprotect #416 Set ID: Buero value: 30%
                              2023-04-12 14:55:02.070 - debug: shuttercontrol.0 (179737) #0 wait for shutter check started
                              2023-04-12 14:55:02.069 - info: mqtt.0 (955) send2Server mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos[shellies/Buero/Rolladen/roller/0/command/pos]
                              2023-04-12 14:55:02.099 - debug: shuttercontrol.0 (179737) Sunprotect for Buero is active
                              2023-04-12 14:55:02.100 - debug: shuttercontrol.0 (179737) RangeMinus: 210 < 211.1RangePlus: 320 > 211.1
                              2023-04-12 14:55:02.100 - debug: shuttercontrol.0 (179737) last automatic Action for Buero: down_Sunprotect
                              2023-04-12 14:55:02.101 - debug: shuttercontrol.0 (179737) Sunprotect Buero old height: 100% new height: 30%
                              2023-04-12 14:55:22.072 - debug: shuttercontrol.0 (179737) #0 wait for shutter check end
                              2023-04-12 14:55:22.074 - debug: shuttercontrol.0 (179737) Shutter state changed: Buero old value = 100 new value = 30
                              2023-04-12 14:55:22.074 - debug: shuttercontrol.0 (179737) #1 shutterName: Buero
                              2023-04-12 14:55:22.074 - debug: shuttercontrol.0 (179737) #1 shutterState: 30 %
                              2023-04-12 14:55:22.074 - debug: shuttercontrol.0 (179737) #1 currentAction: Manu_Mode
                              2023-04-12 14:55:22.075 - debug: shuttercontrol.0 (179737) #1 triggerAction: Manu_Mode
                              2023-04-12 14:55:22.075 - debug: shuttercontrol.0 (179737) #1 currentHeight: 30 %
                              2023-04-12 14:55:22.075 - debug: shuttercontrol.0 (179737) #1 oldHeight: 100 %
                              2023-04-12 14:55:22.075 - debug: shuttercontrol.0 (179737) #1 currentShutterState: activated
                              2023-04-12 14:55:22.076 - debug: shuttercontrol.0 (179737) #1 currentShutterStateTime: 20 seconds
                              2023-04-12 14:55:22.127 - debug: shuttercontrol.0 (179737) Buero drived manually to 30. Old value = 100. New value = 30
                              2023-04-12 14:55:22.127 - debug: shuttercontrol.0 (179737) Buero Updated trigger action to Manu_Mode to prevent moving after window close
                              2023-04-12 14:55:33.323 - debug: shuttercontrol.0 (179737) Brightness sensor value: 4104
                              2023-04-12 14:55:33.354 - info: shuttercontrol.0 (179737) Lightsensor #5 Set ID: Buero value: 100%
                              2023-04-12 14:55:33.361 - info: mqtt.0 (955) send2Server mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos[shellies/Buero/Rolladen/roller/0/command/pos]
                              2023-04-12 14:55:33.362 - debug: shuttercontrol.0 (179737) #0 wait for shutter check started
                              2023-04-12 14:55:33.419 - debug: shuttercontrol.0 (179737) last automatic Action for Buero: up_Brightness
                              2023-04-12 14:55:33.420 - debug: shuttercontrol.0 (179737) save current height: 100% from Buero
                              2023-04-12 14:55:43.325 - debug: shuttercontrol.0 (179737) Brightness State Down is: false
                              2023-04-12 14:55:53.364 - debug: shuttercontrol.0 (179737) #0 wait for shutter check end
                              2023-04-12 14:55:53.365 - debug: shuttercontrol.0 (179737) Buero Old value = 100. New value = 100. automatic is active
                              2023-04-12 14:57:58.575 - debug: shuttercontrol.0 (179737) Brightness sensor value: 3967
                              2023-04-12 14:57:58.629 - debug: shuttercontrol.0 (179737) Lightsensor up Buero already up at: 100% - setting current action: up
                              2023-04-12 14:58:08.577 - debug: shuttercontrol.0 (179737) Brightness State Down is: false
                              2023-04-12 15:00:00.008 - debug: shuttercontrol.0 (179737) calculate astrodata ...
                              2023-04-12 15:00:00.008 - debug: shuttercontrol.0 (179737) Sun Azimut: 212.7°
                              2023-04-12 15:00:00.009 - debug: shuttercontrol.0 (179737) Sun Elevation: 42.5°
                              2023-04-12 15:00:02.020 - debug: shuttercontrol.0 (179737) Buero: Check basis for sunprotect. Height:100 > HeightDownSun: 30 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                              2023-04-12 15:00:02.020 - info: shuttercontrol.0 (179737) Sunprotect #416 Set ID: Buero value: 30%
                              2023-04-12 15:00:02.065 - info: mqtt.0 (955) send2Server mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos[shellies/Buero/Rolladen/roller/0/command/pos]
                              2023-04-12 15:00:02.066 - debug: shuttercontrol.0 (179737) #0 wait for shutter check started
                              2023-04-12 15:00:02.121 - debug: shuttercontrol.0 (179737) Sunprotect for Buero is active
                              2023-04-12 15:00:02.121 - debug: shuttercontrol.0 (179737) RangeMinus: 210 < 212.7RangePlus: 320 > 212.7
                              2023-04-12 15:00:02.121 - debug: shuttercontrol.0 (179737) last automatic Action for Buero: down_Sunprotect
                              2023-04-12 15:00:02.121 - debug: shuttercontrol.0 (179737) Sunprotect Buero old height: 100% new height: 30%
                              2023-04-12 15:00:09.576 - debug: shuttercontrol.0 (179737) Brightness sensor value: 3856
                              2023-04-12 15:00:09.606 - debug: shuttercontrol.0 (179737) outsidetemperature changed: hm-rpc.1.00181D89B4E7B4.1.ACTUAL_TEMPERATURE Value: 10.6
                              2023-04-12 15:00:09.672 - debug: shuttercontrol.0 (179737) Lightsensor up Buero already up at: 100% - setting current action: sunProtect
                              2023-04-12 15:00:19.577 - debug: shuttercontrol.0 (179737) Brightness State Down is: false
                              2023-04-12 15:00:22.067 - debug: shuttercontrol.0 (179737) #0 wait for shutter check end
                              2023-04-12 15:00:22.068 - debug: shuttercontrol.0 (179737) Shutter state changed: Buero old value = 100 new value = 30
                              2023-04-12 15:00:22.069 - debug: shuttercontrol.0 (179737) Buero Old value = 100. New value = 30. automatic is active
                              2023-04-12 15:03:10.046 - debug: shuttercontrol.0 (179737) Brightness sensor value: 4257
                              2023-04-12 15:03:10.068 - debug: shuttercontrol.0 (179737) outsidetemperature changed: hm-rpc.1.00181D89B4E7B4.1.ACTUAL_TEMPERATURE Value: 10.5
                              2023-04-12 15:03:10.130 - debug: shuttercontrol.0 (179737) Lightsensor up Buero already up at: 100% - setting current action: sunProtect
                              2023-04-12 15:03:20.047 - debug: shuttercontrol.0 (179737) Brightness State Down is: false
                              2023-04-12 15:05:00.008 - debug: shuttercontrol.0 (179737) calculate astrodata ...
                              2023-04-12 15:05:00.009 - debug: shuttercontrol.0 (179737) Sun Azimut: 214.3°
                              2023-04-12 15:05:00.009 - debug: shuttercontrol.0 (179737) Sun Elevation: 42.1°
                              2023-04-12 15:05:56.040 - debug: shuttercontrol.0 (179737) Brightness sensor value: 4471
                              2023-04-12 15:05:56.083 - debug: shuttercontrol.0 (179737) Lightsensor up Buero already up at: 100% - setting current action: sunProtect
                              2023-04-12 15:06:06.041 - debug: shuttercontrol.0 (179737) Brightness State Down is: false
                              2023-04-12 15:08:27.812 - debug: shuttercontrol.0 (179737) Brightness sensor value: 4399
                              2023-04-12 15:08:27.839 - debug: shuttercontrol.0 (179737) outsidetemperature changed: hm-rpc.1.00181D89B4E7B4.1.ACTUAL_TEMPERATURE Value: 10.6
                              2023-04-12 15:08:27.898 - debug: shuttercontrol.0 (179737) Lightsensor up Buero already up at: 100% - setting current action: sunProtect
                              2023-04-12 15:08:37.813 - debug: shuttercontrol.0 (179737) Brightness State Down is: false
                              2023-04-12 15:10:00.014 - debug: shuttercontrol.0 (179737) calculate astrodata ...
                              2023-04-12 15:10:00.014 - debug: shuttercontrol.0 (179737) Sun Azimut: 215.8°
                              2023-04-12 15:10:00.015 - debug: shuttercontrol.0 (179737) Sun Elevation: 41.6°
                              2023-04-12 15:10:45.049 - debug: shuttercontrol.0 (179737) Brightness sensor value: 4524
                              2023-04-12 15:10:45.135 - debug: shuttercontrol.0 (179737) Lightsensor up Buero already up at: 100% - setting current action: sunProtect
                              2023-04-12 15:10:55.050 - debug: shuttercontrol.0 (179737) Brightness State Down is: false
                              2023-04-12 15:12:47.794 - debug: shuttercontrol.0 (179737) Brightness sensor value: 4369
                              2023-04-12 15:12:47.834 - debug: shuttercontrol.0 (179737) Lightsensor up Buero already up at: 100% - setting current action: sunProtect
                              2023-04-12 15:12:57.795 - debug: shuttercontrol.0 (179737) Brightness State Down is: false
                              Danke für Deine Hilfe...
                              • S StealthAngel
                                simatecS Offline
                                simatecS Offline
                                simatec
                                @stealthangel Deine Überprüfung der Rollläden nach 20 Sekunden löst hier die Aktion aus.
                                Entweder deine Rollläden liefern einen sauberen State, dann schalte die Überprüfung aus oder setze der Wert höher.
                                Z.B. auf 60 oder 100 Sekunden
                                • simatecS simatec
                                  StealthAngel
                                  Hallo, die Überprüfung ist auf 60 Sekunden eingestellt
                                  Jetzt war ich zwar nicht zuhause, aber als ich nach Hause kam war der Rollladen hochgefahren (und nicht auf 30%).
                                  2023-04-13 14:50:00.007 - debug: shuttercontrol.0 (184934) calculate astrodata ...
                                  2023-04-13 14:50:00.008 - debug: shuttercontrol.0 (184934) Sun Azimut: 209.7°
                                  2023-04-13 14:50:00.008 - debug: shuttercontrol.0 (184934) Sun Elevation: 43.6°
                                  2023-04-13 14:50:04.184 - debug: shuttercontrol.0 (184934) Brightness sensor value: 7487
                                  2023-04-13 14:50:04.208 - debug: shuttercontrol.0 (184934) outsidetemperature changed: hm-rpc.1.00181D89B4E7B4.1.ACTUAL_TEMPERATURE Value: 12
                                  2023-04-13 14:50:04.274 - debug: shuttercontrol.0 (184934) Lightsensor up Buero already up at: 100% - setting current action: up
                                  2023-04-13 14:50:14.184 - debug: shuttercontrol.0 (184934) Brightness State Down is: false
                                  2023-04-13 14:52:53.676 - debug: shuttercontrol.0 (184934) Brightness sensor value: 7333
                                  2023-04-13 14:52:53.718 - debug: shuttercontrol.0 (184934) Lightsensor up Buero already up at: 100% - setting current action: up
                                  2023-04-13 14:53:03.677 - debug: shuttercontrol.0 (184934) Brightness State Down is: false
                                  2023-04-13 14:55:00.009 - debug: shuttercontrol.0 (184934) calculate astrodata ...
                                  2023-04-13 14:55:00.009 - debug: shuttercontrol.0 (184934) Sun Azimut: 211.4°
                                  2023-04-13 14:55:00.010 - debug: shuttercontrol.0 (184934) Sun Elevation: 43.2°
                                  2023-04-13 14:55:02.023 - debug: shuttercontrol.0 (184934) Buero: Check basis for sunprotect. Height:100 > HeightDownSun: 30 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                                  2023-04-13 14:55:02.024 - info: shuttercontrol.0 (184934) Sunprotect #416 Set ID: Buero value: 30%
                                  2023-04-13 14:55:02.075 - debug: shuttercontrol.0 (184934) #0 wait for shutter check started
                                  2023-04-13 14:55:02.073 - info: mqtt.0 (955) send2Server mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos[shellies/Buero/Rolladen/roller/0/command/pos]
                                  2023-04-13 14:55:02.126 - debug: shuttercontrol.0 (184934) Sunprotect for Buero is active
                                  2023-04-13 14:55:02.127 - debug: shuttercontrol.0 (184934) RangeMinus: 210 < 211.4RangePlus: 320 > 211.4
                                  2023-04-13 14:55:02.127 - debug: shuttercontrol.0 (184934) last automatic Action for Buero: down_Sunprotect
                                  2023-04-13 14:55:02.127 - debug: shuttercontrol.0 (184934) Sunprotect Buero old height: 100% new height: 30%
                                  2023-04-13 14:55:28.929 - debug: shuttercontrol.0 (184934) Brightness sensor value: 7345
                                  2023-04-13 14:55:28.952 - debug: shuttercontrol.0 (184934) outsidetemperature changed: hm-rpc.1.00181D89B4E7B4.1.ACTUAL_TEMPERATURE Value: 12.1
                                  2023-04-13 14:55:29.030 - debug: shuttercontrol.0 (184934) Lightsensor up Buero already up at: 100% - setting current action: sunProtect
                                  2023-04-13 14:55:38.930 - debug: shuttercontrol.0 (184934) Brightness State Down is: false
                                  2023-04-13 14:56:02.076 - debug: shuttercontrol.0 (184934) #0 wait for shutter check end
                                  2023-04-13 14:56:02.078 - debug: shuttercontrol.0 (184934) Shutter state changed: Buero old value = 100 new value = 30
                                  2023-04-13 14:56:02.078 - debug: shuttercontrol.0 (184934) Buero Old value = 100. New value = 30. automatic is active
                                  2023-04-13 14:57:49.676 - debug: shuttercontrol.0 (184934) Brightness sensor value: 7125
                                  2023-04-13 14:57:49.724 - debug: shuttercontrol.0 (184934) Lightsensor up Buero already up at: 100% - setting current action: sunProtect
                                  2023-04-13 14:57:59.677 - debug: shuttercontrol.0 (184934) Brightness State Down is: false
                                  2023-04-13 14:59:55.972 - debug: shuttercontrol.0 (184934) Brightness sensor value: 6848
                                  2023-04-13 14:59:56.003 - debug: shuttercontrol.0 (184934) outsidetemperature changed: hm-rpc.1.00181D89B4E7B4.1.ACTUAL_TEMPERATURE Value: 12.2
                                  2023-04-13 14:59:56.029 - debug: shuttercontrol.0 (184934) Lightsensor up Buero already up at: 100% - setting current action: sunProtect
                                  Die Objects sind der Meinung, dass der Rollladen auf 30% steht
                                  In Wirklichkeit ist der Rollladen aber auf 100%
                                  Also ist er scheinbar runter und gleich wieder hochgefahren.
                                  Kast Du bitte nochmal schauen, was hier schief gegangen ist?.....
                                  • simatecS simatec
                                    StealthAngel
                                    @simatec
                                    Halt Stop, ich habe noch einen Fehler bei mir gefunden. Wenn ich die "Objekt-ID Rollladen" einstelle wird vermutlich die Sollposition dort hin gesendet und die Position davon auch abgefragt, oder?
                                    Bei meinen Shellys muss ich aber auf
                                    schreiben und von
                                    mqtt.0.shellies.Buero.Rolladen.roller.0.pos
                                    lesen. Ich hatte als Object-ID "mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos". Das könnte der Fehler sein. Ich arbeite jetzt mit einen Alias.
                                        "alias": {
                                          "id": {
                                            "read": "mqtt.0.shellies.Buero.Rolladen.roller.0.pos",
                                            "write": "mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos"
                                    Ich hoffe, dass es jetzt morgen funktioniert.
                                    Erstmal Sorry und vielen Dank....
                                    • S StealthAngel
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      @stealthangel Laut dem Log hat Shuttercontrol mit dem Überprüfen nach 60 Sekunden alles richtig gemacht.
                                      Automatik wurde erkannt und er wurde in den Sonnenschutz gefahren.
                                      Ich gehe mal davon aus, dass da bei deinen States der Rollläden was krum ist.
                                      Hast du da noch irgendwelche Scripte laufen?
                                      Wann wurde denn der State des Rollladens geändert?
                                      • S StealthAngel
                                        @simatec
                                        schreiben und von
                                            "alias": {
                                              "id": {
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        @stealthangel Warum nutzt du nicht den Shelly Adapter??? Würde sicher einiges erleichtern
                                        • simatecS simatec
                                          StealthAngel
                                          Ich habe jetzt auch auf den Shelly Adapter umgestellt. Das Problem ist aber immer noch das Gleiche :(
                                          Der Rollladen ist wieder 3 mal runter und rauf gefahren. So langsam verzweifele ich ....
                                          2023-04-17 14:45:00.014 - debug: shuttercontrol.0 (207218) calculate astrodata ...
                                          2023-04-17 14:45:00.014 - debug: shuttercontrol.0 (207218) Sun Azimut: 209°
                                          2023-04-17 14:45:00.015 - debug: shuttercontrol.0 (207218) Sun Elevation: 45.3°
                                          2023-04-17 14:46:12.976 - debug: shuttercontrol.0 (207218) Brightness sensor value: 5032
                                          2023-04-17 14:46:14.052 - debug: shuttercontrol.0 (207218) Lightsensor up BueroRollladen already up at: 100% - setting current action: up
                                          2023-04-17 14:46:22.978 - debug: shuttercontrol.0 (207218) Brightness State Down is: false
                                          2023-04-17 14:48:53.703 - debug: shuttercontrol.0 (207218) Brightness sensor value: 4799
                                          2023-04-17 14:48:54.799 - debug: shuttercontrol.0 (207218) Lightsensor up BueroRollladen already up at: 100% - setting current action: up
                                          2023-04-17 14:49:03.703 - debug: shuttercontrol.0 (207218) Brightness State Down is: false
                                          2023-04-17 14:50:00.019 - debug: shuttercontrol.0 (207218) calculate astrodata ...
                                          2023-04-17 14:50:00.020 - debug: shuttercontrol.0 (207218) Sun Azimut: 210.7°
                                          2023-04-17 14:50:00.021 - debug: shuttercontrol.0 (207218) Sun Elevation: 44.9°
                                          2023-04-17 14:50:02.035 - debug: shuttercontrol.0 (207218) BueroRollladen: Check basis for sunprotect. Height:100 > HeightDownSun: 30 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                                          2023-04-17 14:50:02.036 - info: shuttercontrol.0 (207218) Sunprotect #416 Set ID: BueroRollladen value: 30%
                                          2023-04-17 14:50:02.048 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
                                          2023-04-17 14:50:02.059 - debug: shuttercontrol.0 (207218) Sunprotect for BueroRollladen is active
                                          2023-04-17 14:50:02.060 - debug: shuttercontrol.0 (207218) RangeMinus: 210 < 210.7RangePlus: 320 > 210.7
                                          2023-04-17 14:50:02.060 - debug: shuttercontrol.0 (207218) last automatic Action for BueroRollladen: down_Sunprotect
                                          2023-04-17 14:50:02.060 - debug: shuttercontrol.0 (207218) Sunprotect BueroRollladen old height: % new height: 30%
                                          2023-04-17 14:50:02.083 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
                                          2023-04-17 14:50:14.335 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
                                          2023-04-17 14:51:02.049 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
                                          2023-04-17 14:51:02.051 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = new value = 30
                                          2023-04-17 14:51:02.051 - debug: shuttercontrol.0 (207218) #1 shutterName: BueroRollladen
                                          2023-04-17 14:51:02.052 - debug: shuttercontrol.0 (207218) #1 shutterState: 30 %
                                          2023-04-17 14:51:02.052 - debug: shuttercontrol.0 (207218) #1 currentAction: Manu_Mode
                                          2023-04-17 14:51:02.052 - debug: shuttercontrol.0 (207218) #1 triggerAction: Manu_Mode
                                          2023-04-17 14:51:02.053 - debug: shuttercontrol.0 (207218) #1 currentHeight: 30 %
                                          2023-04-17 14:51:02.053 - debug: shuttercontrol.0 (207218) #1 oldHeight: %
                                          2023-04-17 14:51:02.053 - debug: shuttercontrol.0 (207218) #1 currentShutterState: activated
                                          2023-04-17 14:51:02.053 - debug: shuttercontrol.0 (207218) #1 currentShutterStateTime: 60 seconds
                                          2023-04-17 14:51:02.084 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
                                          2023-04-17 14:51:02.085 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = new value = 30
                                          2023-04-17 14:51:02.086 - debug: shuttercontrol.0 (207218) #1 shutterName: BueroRollladen
                                          2023-04-17 14:51:02.087 - debug: shuttercontrol.0 (207218) #1 shutterState: 30 %
                                          2023-04-17 14:51:02.087 - debug: shuttercontrol.0 (207218) #1 currentAction: Manu_Mode
                                          2023-04-17 14:51:02.087 - debug: shuttercontrol.0 (207218) #1 triggerAction: Manu_Mode
                                          2023-04-17 14:51:02.088 - debug: shuttercontrol.0 (207218) #1 currentHeight: 30 %
                                          2023-04-17 14:51:02.088 - debug: shuttercontrol.0 (207218) #1 oldHeight: %
                                          2023-04-17 14:51:02.089 - debug: shuttercontrol.0 (207218) #1 currentShutterState: activated
                                          2023-04-17 14:51:02.089 - debug: shuttercontrol.0 (207218) #1 currentShutterStateTime: 60 seconds
                                          2023-04-17 14:51:02.091 - debug: shuttercontrol.0 (207218) BueroRollladen drived manually to 30. Old value = . New value = 30
                                          2023-04-17 14:51:02.092 - debug: shuttercontrol.0 (207218) BueroRollladen Updated trigger action to Manu_Mode to prevent moving after window close
                                          2023-04-17 14:51:02.142 - debug: shuttercontrol.0 (207218) BueroRollladen drived manually to 30. Old value = . New value = 30
                                          2023-04-17 14:51:02.143 - debug: shuttercontrol.0 (207218) BueroRollladen Updated trigger action to Manu_Mode to prevent moving after window close
                                          2023-04-17 14:51:14.336 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
                                          2023-04-17 14:51:14.338 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = new value = 30
                                          2023-04-17 14:51:14.338 - debug: shuttercontrol.0 (207218) #1 shutterName: BueroRollladen
                                          2023-04-17 14:51:14.339 - debug: shuttercontrol.0 (207218) #1 shutterState: 30 %
                                          2023-04-17 14:51:14.339 - debug: shuttercontrol.0 (207218) #1 currentAction: Manu_Mode
                                          2023-04-17 14:51:14.339 - debug: shuttercontrol.0 (207218) #1 triggerAction: Manu_Mode
                                          2023-04-17 14:51:14.339 - debug: shuttercontrol.0 (207218) #1 currentHeight: 30 %
                                          2023-04-17 14:51:14.340 - debug: shuttercontrol.0 (207218) #1 oldHeight: %
                                          2023-04-17 14:51:14.340 - debug: shuttercontrol.0 (207218) #1 currentShutterState: activated
                                          2023-04-17 14:51:14.340 - debug: shuttercontrol.0 (207218) #1 currentShutterStateTime: 60 seconds
                                          2023-04-17 14:51:14.390 - debug: shuttercontrol.0 (207218) BueroRollladen drived manually to 30. Old value = . New value = 30
                                          2023-04-17 14:51:14.391 - debug: shuttercontrol.0 (207218) BueroRollladen Updated trigger action to Manu_Mode to prevent moving after window close
                                          2023-04-17 14:51:19.961 - debug: shuttercontrol.0 (207218) Brightness sensor value: 4622
                                          2023-04-17 14:51:19.995 - info: shuttercontrol.0 (207218) Lightsensor #5 Set ID: BueroRollladen value: 100%
                                          2023-04-17 14:51:20.003 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
                                          2023-04-17 14:51:20.013 - debug: shuttercontrol.0 (207218) last automatic Action for BueroRollladen: up_Brightness
                                          2023-04-17 14:51:20.013 - debug: shuttercontrol.0 (207218) save current height: 100% from BueroRollladen
                                          2023-04-17 14:51:20.035 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
                                          2023-04-17 14:51:29.963 - debug: shuttercontrol.0 (207218) Brightness State Down is: false
                                          2023-04-17 14:51:33.042 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
                                          2023-04-17 14:52:20.004 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
                                          2023-04-17 14:52:20.005 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = new value = 100
                                          2023-04-17 14:52:20.006 - debug: shuttercontrol.0 (207218) BueroRollladen Old value = . New value = 100. automatic is active
                                          2023-04-17 14:52:20.035 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
                                          2023-04-17 14:52:20.037 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = new value = 100
                                          2023-04-17 14:52:20.038 - debug: shuttercontrol.0 (207218) BueroRollladen Old value = . New value = 100. automatic is active
                                          2023-04-17 14:52:33.043 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
                                          2023-04-17 14:52:33.044 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = new value = 100
                                          2023-04-17 14:52:33.045 - debug: shuttercontrol.0 (207218) BueroRollladen Old value = . New value = 100. automatic is active
                                          2023-04-17 14:53:31.713 - debug: shuttercontrol.0 (207218) Brightness sensor value: 4502
                                          2023-04-17 14:53:31.770 - debug: shuttercontrol.0 (207218) Lightsensor up BueroRollladen already up at: 100% - setting current action: up
                                          2023-04-17 14:53:41.714 - debug: shuttercontrol.0 (207218) Brightness State Down is: false
                                          2023-04-17 14:55:00.017 - debug: shuttercontrol.0 (207218) calculate astrodata ...
                                          2023-04-17 14:55:00.018 - debug: shuttercontrol.0 (207218) Sun Azimut: 212.3°
                                          2023-04-17 14:55:00.018 - debug: shuttercontrol.0 (207218) Sun Elevation: 44.5°
                                          2023-04-17 14:55:02.040 - debug: shuttercontrol.0 (207218) BueroRollladen: Check basis for sunprotect. Height:100 > HeightDownSun: 30 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                                          2023-04-17 14:55:02.041 - info: shuttercontrol.0 (207218) Sunprotect #416 Set ID: BueroRollladen value: 30%
                                          2023-04-17 14:55:02.093 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
                                          2023-04-17 14:55:02.111 - debug: shuttercontrol.0 (207218) Sunprotect for BueroRollladen is active
                                          2023-04-17 14:55:02.112 - debug: shuttercontrol.0 (207218) RangeMinus: 210 < 212.3RangePlus: 320 > 212.3
                                          2023-04-17 14:55:02.113 - debug: shuttercontrol.0 (207218) last automatic Action for BueroRollladen: down_Sunprotect
                                          2023-04-17 14:55:02.113 - debug: shuttercontrol.0 (207218) Sunprotect BueroRollladen old height: 100% new height: 30%
                                          2023-04-17 14:55:02.136 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
                                          2023-04-17 14:55:14.373 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
                                          2023-04-17 14:56:02.095 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
                                          2023-04-17 14:56:02.097 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = 100 new value = 30
                                          2023-04-17 14:56:02.098 - debug: shuttercontrol.0 (207218) #1 shutterName: BueroRollladen
                                          2023-04-17 14:56:02.099 - debug: shuttercontrol.0 (207218) #1 shutterState: 30 %
                                          2023-04-17 14:56:02.099 - debug: shuttercontrol.0 (207218) #1 currentAction: Manu_Mode
                                          2023-04-17 14:56:02.100 - debug: shuttercontrol.0 (207218) #1 triggerAction: Manu_Mode
                                          2023-04-17 14:56:02.100 - debug: shuttercontrol.0 (207218) #1 currentHeight: 30 %
                                          2023-04-17 14:56:02.101 - debug: shuttercontrol.0 (207218) #1 oldHeight: 100 %
                                          2023-04-17 14:56:02.101 - debug: shuttercontrol.0 (207218) #1 currentShutterState: activated
                                          2023-04-17 14:56:02.101 - debug: shuttercontrol.0 (207218) #1 currentShutterStateTime: 60 seconds
                                          2023-04-17 14:56:02.137 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
                                          2023-04-17 14:56:02.143 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = 100 new value = 30
                                          2023-04-17 14:56:02.144 - debug: shuttercontrol.0 (207218) #1 shutterName: BueroRollladen
                                          2023-04-17 14:56:02.144 - debug: shuttercontrol.0 (207218) #1 shutterState: 30 %
                                          2023-04-17 14:56:02.145 - debug: shuttercontrol.0 (207218) #1 currentAction: Manu_Mode
                                          2023-04-17 14:56:02.146 - debug: shuttercontrol.0 (207218) #1 triggerAction: Manu_Mode
                                          2023-04-17 14:56:02.146 - debug: shuttercontrol.0 (207218) #1 currentHeight: 30 %
                                          2023-04-17 14:56:02.147 - debug: shuttercontrol.0 (207218) #1 oldHeight: 100 %
                                          2023-04-17 14:56:02.147 - debug: shuttercontrol.0 (207218) #1 currentShutterState: activated
                                          2023-04-17 14:56:02.148 - debug: shuttercontrol.0 (207218) #1 currentShutterStateTime: 60 seconds
                                          2023-04-17 14:56:02.152 - debug: shuttercontrol.0 (207218) BueroRollladen drived manually to 30. Old value = 100. New value = 30
                                          2023-04-17 14:56:02.153 - debug: shuttercontrol.0 (207218) BueroRollladen Updated trigger action to Manu_Mode to prevent moving after window close
                                          2023-04-17 14:56:02.208 - debug: shuttercontrol.0 (207218) BueroRollladen drived manually to 30. Old value = 100. New value = 30
                                          2023-04-17 14:56:02.209 - debug: shuttercontrol.0 (207218) BueroRollladen Updated trigger action to Manu_Mode to prevent moving after window close
                                          2023-04-17 14:56:14.374 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
                                          2023-04-17 14:56:14.377 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = 100 new value = 30
                                          2023-04-17 14:56:14.377 - debug: shuttercontrol.0 (207218) #1 shutterName: BueroRollladen
                                          2023-04-17 14:56:14.378 - debug: shuttercontrol.0 (207218) #1 shutterState: 30 %
                                          2023-04-17 14:56:14.378 - debug: shuttercontrol.0 (207218) #1 currentAction: Manu_Mode
                                          2023-04-17 14:56:14.378 - debug: shuttercontrol.0 (207218) #1 triggerAction: Manu_Mode
                                          2023-04-17 14:56:14.378 - debug: shuttercontrol.0 (207218) #1 currentHeight: 30 %
                                          2023-04-17 14:56:14.379 - debug: shuttercontrol.0 (207218) #1 oldHeight: 100 %
                                          2023-04-17 14:56:14.379 - debug: shuttercontrol.0 (207218) #1 currentShutterState: activated
                                          2023-04-17 14:56:14.379 - debug: shuttercontrol.0 (207218) #1 currentShutterStateTime: 60 seconds
                                          2023-04-17 14:56:14.432 - debug: shuttercontrol.0 (207218) BueroRollladen drived manually to 30. Old value = 100. New value = 30
                                          2023-04-17 14:56:14.432 - debug: shuttercontrol.0 (207218) BueroRollladen Updated trigger action to Manu_Mode to prevent moving after window close
                                          2023-04-17 14:56:32.952 - debug: shuttercontrol.0 (207218) Brightness sensor value: 4650
                                          2023-04-17 14:56:32.992 - info: shuttercontrol.0 (207218) Lightsensor #5 Set ID: BueroRollladen value: 100%
                                          2023-04-17 14:56:33.000 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
                                          2023-04-17 14:56:33.010 - debug: shuttercontrol.0 (207218) last automatic Action for BueroRollladen: up_Brightness
                                          2023-04-17 14:56:33.011 - debug: shuttercontrol.0 (207218) save current height: 100% from BueroRollladen
                                          2023-04-17 14:56:33.032 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
                                          2023-04-17 14:56:42.953 - debug: shuttercontrol.0 (207218) Brightness State Down is: false
                                          2023-04-17 14:56:46.052 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
                                          2023-04-17 14:57:26.778 - info: admin.0 (831) ==> Connected system.user.admin from ::ffff:192.168.2.21
                                          2023-04-17 14:57:33.002 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
                                          2023-04-17 14:57:33.003 - debug: shuttercontrol.0 (207218) BueroRollladen Old value = 100. New value = 100. automatic is active
                                          2023-04-17 14:57:33.032 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
                                          2023-04-17 14:57:33.034 - debug: shuttercontrol.0 (207218) BueroRollladen Old value = 100. New value = 100. automatic is active
                                          2023-04-17 14:57:38.475 - info: admin.0 (831) ==> Connected system.user.admin from ::ffff:192.168.2.21
                                          2023-04-17 14:57:46.054 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
                                          2023-04-17 14:57:46.055 - debug: shuttercontrol.0 (207218) BueroRollladen Old value = 100. New value = 100. automatic is active
                                          2023-04-17 14:59:19.969 - debug: shuttercontrol.0 (207218) Brightness sensor value: 4804
                                          2023-04-17 14:59:20.020 - debug: shuttercontrol.0 (207218) Lightsensor up BueroRollladen already up at: 100% - setting current action: up
                                          2023-04-17 14:59:29.971 - debug: shuttercontrol.0 (207218) Brightness State Down is: false
                                          2023-04-17 15:00:00.012 - debug: shuttercontrol.0 (207218) calculate astrodata ...
                                          2023-04-17 15:00:00.013 - debug: shuttercontrol.0 (207218) Sun Azimut: 213.9°
                                          2023-04-17 15:00:00.013 - debug: shuttercontrol.0 (207218) Sun Elevation: 44.1°
                                          2023-04-17 15:00:02.026 - debug: shuttercontrol.0 (207218) BueroRollladen: Check basis for sunprotect. Height:100 > HeightDownSun: 30 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                                          2023-04-17 15:00:02.026 - info: shuttercontrol.0 (207218) Sunprotect #416 Set ID: BueroRollladen value: 30%
                                          2023-04-17 15:00:02.075 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
                                          2023-04-17 15:00:02.086 - debug: shuttercontrol.0 (207218) Sunprotect for BueroRollladen is active
                                          2023-04-17 15:00:02.086 - debug: shuttercontrol.0 (207218) RangeMinus: 210 < 213.9RangePlus: 320 > 213.9
                                          2023-04-17 15:00:02.086 - debug: shuttercontrol.0 (207218) last automatic Action for BueroRollladen: down_Sunprotect
                                          2023-04-17 15:00:02.087 - debug: shuttercontrol.0 (207218) Sunprotect BueroRollladen old height: 100% new height: 30%
                                          2023-04-17 15:00:02.105 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
                                          2023-04-17 15:00:14.359 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
                                          2023-04-17 15:01:02.077 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
                                          2023-04-17 15:01:02.078 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = 100 new value = 30
                                          2023-04-17 15:01:02.079 - debug: shuttercontrol.0 (207218) #1 shutterName: BueroRollladen
                                          2023-04-17 15:01:02.079 - debug: shuttercontrol.0 (207218) #1 shutterState: 30 %
                                          2023-04-17 15:01:02.080 - debug: shuttercontrol.0 (207218) #1 currentAction: Manu_Mode
                                          2023-04-17 15:01:02.080 - debug: shuttercontrol.0 (207218) #1 triggerAction: Manu_Mode
                                          2023-04-17 15:01:02.080 - debug: shuttercontrol.0 (207218) #1 currentHeight: 30 %
                                          2023-04-17 15:01:02.080 - debug: shuttercontrol.0 (207218) #1 oldHeight: 100 %
                                          2023-04-17 15:01:02.081 - debug: shuttercontrol.0 (207218) #1 currentShutterState: activated
                                          2023-04-17 15:01:02.081 - debug: shuttercontrol.0 (207218) #1 currentShutterStateTime: 60 seconds
                                          2023-04-17 15:01:02.106 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
                                          2023-04-17 15:01:02.128 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = 100 new value = 30
                                          2023-04-17 15:01:02.128 - debug: shuttercontrol.0 (207218) #1 shutterName: BueroRollladen
                                          2023-04-17 15:01:02.129 - debug: shuttercontrol.0 (207218) #1 shutterState: 30 %
                                          2023-04-17 15:01:02.130 - debug: shuttercontrol.0 (207218) #1 currentAction: Manu_Mode
                                          2023-04-17 15:01:02.130 - debug: shuttercontrol.0 (207218) #1 triggerAction: Manu_Mode
                                          2023-04-17 15:01:02.132 - debug: shuttercontrol.0 (207218) #1 currentHeight: 30 %
                                          2023-04-17 15:01:02.132 - debug: shuttercontrol.0 (207218) #1 oldHeight: 100 %
                                          2023-04-17 15:01:02.132 - debug: shuttercontrol.0 (207218) #1 currentShutterState: activated
                                          2023-04-17 15:01:02.133 - debug: shuttercontrol.0 (207218) #1 currentShutterStateTime: 60 seconds
                                          2023-04-17 15:01:02.140 - debug: shuttercontrol.0 (207218) BueroRollladen drived manually to 30. Old value = 100. New value = 30
                                          2023-04-17 15:01:02.140 - debug: shuttercontrol.0 (207218) BueroRollladen Updated trigger action to Manu_Mode to prevent moving after window close
                                          2023-04-17 15:01:02.188 - debug: shuttercontrol.0 (207218) BueroRollladen drived manually to 30. Old value = 100. New value = 30
                                          2023-04-17 15:01:02.188 - debug: shuttercontrol.0 (207218) BueroRollladen Updated trigger action to Manu_Mode to prevent moving after window close
                                          2023-04-17 15:01:14.360 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
                                          2023-04-17 15:01:14.361 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = 100 new value = 30
                                          2023-04-17 15:01:14.362 - debug: shuttercontrol.0 (207218) #1 shutterName: BueroRollladen
                                          2023-04-17 15:01:14.362 - debug: shuttercontrol.0 (207218) #1 shutterState: 30 %
                                          2023-04-17 15:01:14.362 - debug: shuttercontrol.0 (207218) #1 currentAction: Manu_Mode
                                          2023-04-17 15:01:14.363 - debug: shuttercontrol.0 (207218) #1 triggerAction: Manu_Mode
                                          2023-04-17 15:01:14.363 - debug: shuttercontrol.0 (207218) #1 currentHeight: 30 %
                                          2023-04-17 15:01:14.363 - debug: shuttercontrol.0 (207218) #1 oldHeight: 100 %
                                          2023-04-17 15:01:14.363 - debug: shuttercontrol.0 (207218) #1 currentShutterState: activated
                                          2023-04-17 15:01:14.364 - debug: shuttercontrol.0 (207218) #1 currentShutterStateTime: 60 seconds
                                          2023-04-17 15:01:14.415 - debug: shuttercontrol.0 (207218) BueroRollladen drived manually to 30. Old value = 100. New value = 30
                                          2023-04-17 15:01:14.415 - debug: shuttercontrol.0 (207218) BueroRollladen Updated trigger action to Manu_Mode to prevent moving after window close
                                          2023-04-17 15:01:52.457 - debug: shuttercontrol.0 (207218) Brightness sensor value: 4873
                                          2023-04-17 15:01:52.494 - info: shuttercontrol.0 (207218) Lightsensor #5 Set ID: BueroRollladen value: 100%
                                          2023-04-17 15:01:52.506 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
                                          2023-04-17 15:01:52.520 - debug: shuttercontrol.0 (207218) last automatic Action for BueroRollladen: up_Brightness
                                          2023-04-17 15:01:52.520 - debug: shuttercontrol.0 (207218) save current height: 100% from BueroRollladen
                                          2023-04-17 15:01:52.537 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
                                          2023-04-17 15:02:02.459 - debug: shuttercontrol.0 (207218) Brightness State Down is: false
                                          2023-04-17 15:02:05.565 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
                                          Also irgendwas läuft noch falsch.
                                          Mich wundert, dass sich der Status ändert. Ist das so richtig?
                                          Screenshot ist von einem etwas späteren Zeitpunkt, war aber sonst auch so, allerdings nicht geloggt....
                                          Jetzt wo ich hier schreibe, fährt der Rollladen munter weiter rauf und runter.
                                          Es ist mit dem Shelly-Adapter also massiv schlechter geworden :(
