  4. Sporadische Neustarts/Crashes ioB (gelöst)
    5.4k
56 Beiträge 9 Kommentatoren 6.5k Aufrufe 9 Beobachtet
  • JackDanielJ JackDaniel
    @arteck sagte in Sporadische Neustarts/Crashes ioB:
    @jackdaniel das kannst du doch besser.....
    pack bitte die Ausgabe in den Code tag
    hehe das war code tags in code tags :(
    arteckA Offline
    arteckA Offline
    arteck
    @jackdaniel die platte läuft schon mal nicht voll.. aber irgendwas macht die die db verbindung zu
    was passiert um 03:36:40
    machst du backups ?
    2023-04-03 03:36:40.819  - error: unifi-protect.0 (163447) 192.168.1.1: Controller API connection reset.
    2023-04-03 03:36:40.820  - error: unifi-protect.0 (163447) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-04-03 03:36:40.845  - error: unifi-protect.0 (163447) unhandled promise rejection: Cannot read properties of null (reading 'headers')
    2023-04-03 03:36:40.859  - error: unifi-protect.0 (163447) TypeError: Cannot read properties of null (reading 'headers')
        at ProtectApi.login (/opt/iobroker/node_modules/iobroker.unifi-protect/protect_api/protect-api.js:96:30)
        at processTicksAndRejections (node:internal/process/task_queues:95:5)
        at ProtectApi.bootstrapProtect (/opt/iobroker/node_modules/iobroker.unifi-protect/protect_api/protect-api.js:114:9)
        at ProtectApi.refreshDevices (/opt/iobroker/node_modules/iobroker.unifi-protect/protect_api/protect-api.js:231:9)
    2023-04-03 03:36:40.859  - error: unifi-protect.0 (163447) Cannot read properties of null (reading 'headers')
    2023-04-03 03:36:40.994  - info: iot.0 (162845) Connection changed: connect
    2023-04-03 03:36:40.996  - info: lg-thinq.0 (163518) MQTT connected to: t20/op/c059fcaf4037e39ba3200a42cfdebf9dd3a1482df63220a351ec22c15964e2d9/inbox
    2023-04-03 03:36:40.990  - warn: influxdb.0 (162250) Store data for 6 points and 0 conflicts
    2023-04-03 03:36:40.776  - warn: chromecast.0 (162295) Balkon - Client error: Error: read ECONNRESET
        at TLSWrap.onStreamRead (node:internal/stream_base_commons:217:20)
    2023-04-03 03:36:40.777  - info: chromecast.0 (162295) Balkon - client disconnected
    2023-04-03 03:36:40.825  - info: chromecast.0 (162295) Destroying chromecast scanner
    2023-04-03 03:36:40.843  - info: chromecast.0 (162295) Gästezimmer - client disconnected
    2023-04-03 03:36:40.844  - info: chromecast.0 (162295) DaHam - client disconnected
    2023-04-03 03:36:40.849  - info: chromecast.0 (162295) Badezimmer - client disconnected
    2023-04-03 03:36:40.849  - info: chromecast.0 (162295) Keller - client disconnected
    2023-04-03 03:36:40.850  - info: chromecast.0 (162295) Nest Hub Schlafzimmer - Detached player
    2023-04-03 03:36:40.851  - info: chromecast.0 (162295) Nest Hub Schlafzimmer - client disconnected
    2023-04-03 03:36:41.026  - info: chromecast.0 (162295) Nest Hub Schlafzimmer - Connected client
    2023-04-03 03:36:41.012  - info: vw-connect.0 (163334) cleaned everything up...
    2023-04-03 03:36:41.062  - info: chromecast.0 (162295) Keller - Connected client
    2023-04-03 03:36:41.091  - info: chromecast.0 (162295) DaHam - Connected client
    2023-04-03 03:36:40.800  - info: javascript.0 (162265) Stop script script.js.An_Abwesenheit.An_Abwesend_Zähler
    2023-04-03 03:36:40.924  - info: javascript.0 (162265) Stop script script.js.An_Abwesenheit.An_Abwesend_setzen
    2023-04-03 03:36:40.925  - info: javascript.0 (162265) Stop script script.js.An_Abwesenheit.Enocean_Anwesenheitserkennung
    2023-04-03 03:36:40.925  - info: javascript.0 (162265) Stop script script.js.An_Abwesenheit.On_Offline_Handys
    2023-04-03 03:36:40.925  - info: javascript.0 (162265) Stop script script.js.Batteriestatus.Batterie_kritisch_Warnungen_Nuki
    2023-04-03 03:36:40.925  - info: javascript.0 (162265) Stop script script.js.Batteriestatus.Batterieliste_VIS
    2023-04-03 03:36:40.926  - info: javascript.0 (162265) Stop script script.js.Beleuchtung.Beleuchtung_Küche
    2023-04-03 03:36:40.926  - info: javascript.0 (162265) Stop script script.js.Beleuchtung.Beleuchtung_Wohnzimmer_Essbereich
    2023-04-03 03:36:40.926  - info: javascript.0 (162265) Stop script script.js.Beleuchtung.Bewegungsmelder_Küche_Ein_Aus
    2023-04-03 03:36:40.927  - info: javascript.0 (162265) Stop script script.js.Beleuchtung.Kalt_bis_Warm_(Farbtemperatur+Helligkeit)
    ab hier 03:36:40.800 fährt alles runnter
    JackDanielJ 1 Antwort Letzte Antwort
    • arteckA arteck
      machst du backups ?
      JackDanielJ Online
      JackDanielJ Online
      JackDaniel
      schrieb am zuletzt editiert von JackDaniel
      @arteck
      nein backup läuft viel früher (um 2:00 Uhr)
      das komische daran ist ja das es dann wieder sein kann das es tage/wochen ohne probleme läuft, und von jetzt auf gleich dann alle paar stunden passiert
      edit:
      in den log´s stehen eh keine "persöhnlichen" dinge wie zb. pw usw.. oder?
      Carpe diem
        @arteck
        edit:
        @jackdaniel sagte in Sporadische Neustarts/Crashes ioB:
        edit:
        Unter Umständen schon. Hängt vom Adapter ab.
          @arteck
          edit:
          @jackdaniel
          Ich vermute da klemmt irgendwas mit dem Dateisystem:
          [Mon Apr  3 03:36:39 2023]  ext4_filemap_fault+0x2d/0x50 [ext4]
          Bei google taucht die Meldung auch gerne in Verbindung mit Speicherproblemen auf.
            edit:
            @JackDaniel
            Und die influxdb-Quelle mal anschauen. Da ist eine Doublette drin:
            Hit:6 https://repos.influxdata.com/debian stable InRelease
            Hit:7 https://repos.influxdata.com/debian bullseye InRelease
            Im Moment kein Problem, weil bullseye = stable.
            Kann dir aber zum Problem werden, wenn später in diesem Jahr bullsyeye = oldstable werden wird.
            • apollon77A Offline
              Ich wäre auch dabei gewesen zu schauen was um den Fraglichen Zeitpunkt rum so in /var/log/syslog steht ... poste das bitte mal
              • apollon77A apollon77
                JackDanielJ Online
                JackDanielJ Online
                JackDaniel
                @apollon77
                würd ich gerne, aber wie bekomme ich den vom nuc (per ftp scheinen mir die rechte zu fehlen- /var/log/syslog.1: open for read: permission denied)
                Carpe diem
                apollon77A Thomas BraunT 2 Antworten Letzte Antwort
                  @JackDaniel
                  JackDanielJ Online
                  JackDanielJ Online
                  JackDaniel
                  @thomas-braun sagte in Sporadische Neustarts/Crashes ioB:
                  @JackDaniel
                  wie mach ich das am besten?
                  Carpe diem
                    @apollon77
                    @jackdaniel per ssh einloggen? :-) und dann im zweifel mit sudo
                      @JackDaniel
                      @jackdaniel
                      Schau in die influx*.list rein.
                      Findet sich in /etc/apt/sources.list.d/
                        @apollon77
                        @jackdaniel
                        Mit journalctl kann man das ganz gut eingrenzen:
                        https://wiki.ubuntuusers.de/systemd/journalctl/
                          @jackdaniel
                          JackDanielJ Online
                          JackDanielJ Online
                          JackDaniel
                          @jackdaniel
                          darin ist nur:
                          deb https://repos.influxdata.com/debian bullseye stable
                          Carpe diem
                            JackDanielJ Online
                            JackDanielJ Online
                            JackDaniel
                            @apollon77 sagte in Sporadische Neustarts/Crashes ioB:
                            hehe das bekomme ich ja noch hin, aber wie bekomme ich die log´s vom nuc (debian) auf meine windows gurke?
                            Carpe diem
                            Thomas BraunT arteckA 2 Antworten Letzte Antwort
                              @jackdaniel
                              darin ist nur:
                              @jackdaniel
                              Die Zeile ist so oder so falsch. Da fehlt der Key.
                              Ist aber ein anderes Thema.
                              So schaut die jedenfalls richtig aus:
                              echad@chet:~ $ cat /etc/apt/sources.list.d/influxdata.list
                              deb [signed-by=/etc/apt/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main
                              echad@chet:~ $
                                Copy paste aus dem SSH-Terminal? Wäre eine der Möglichkeiten.
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  @jackdaniel winscp ist dein freund https://winscp.net/eng/download.php
                                    JackDanielJ Online
                                    JackDanielJ Online
                                    JackDaniel
                                    jackdaniel@iobroker:~$  journalctl -f
                                    -- Journal begins at Mon 2022-11-21 10:57:20 CET. --
                                    Apr 04 10:37:33 iobroker systemd[270805]: Reached target Timers.
                                    Apr 04 10:37:33 iobroker systemd[270805]: Listening on GnuPG network certificate management daemon.
                                    Apr 04 10:37:33 iobroker systemd[270805]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
                                    Apr 04 10:37:33 iobroker systemd[270805]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
                                    Apr 04 10:37:33 iobroker systemd[270805]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
                                    Apr 04 10:37:33 iobroker systemd[270805]: Listening on GnuPG cryptographic agent and passphrase cache.
                                    Apr 04 10:37:33 iobroker systemd[270805]: Reached target Sockets.
                                    Apr 04 10:37:33 iobroker systemd[270805]: Reached target Basic System.
                                    Apr 04 10:37:33 iobroker systemd[270805]: Reached target Main User Target.
                                    Apr 04 10:37:33 iobroker systemd[270805]: Startup finished in 102ms.
                                    Carpe diem
                                    • arteckA arteck
                                      JackDanielJ Online
                                      JackDanielJ Online
                                      JackDaniel
                                      hab ich auch schon probiert
                                      Carpe diem
                                        @jackdaniel
                                        echad@chet:~ $
                                        JackDanielJ Online
                                        JackDanielJ Online
                                        JackDaniel
                                        @jackdaniel
                                        echad@chet:~ $
                                        jackdaniel@iobroker:~$ cat /etc/apt/sources.list.d/influxdata.list
                                        deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main
                                        Carpe diem
                                          Dein user sollte in der Gruppe 'adm' sein. Dann darf der auch Logs vollständig lesen.
