  4. Backitup findet Dateien nicht auf NAS-Stick wird gesucht
    5.4k
100 Beiträge 6 Kommentatoren 4.4k Aufrufe 5 Beobachtet
  • O Olli63
    @thomas-braun said in Backitup findet Dateien nicht auf NAS-Stick wird gesucht:
    @olli63
    Zeig die Ausgabe zu
    sudo apt update
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Architecture:   armv7l
    Docker:         false
    Virtualization: none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     21:29:02 up 4 min,  1 user,  load average: 0.85, 0.89, 0.41
    CPU threads: 4
    *** Time and Time Zones ***
    Thu Mar 30 19:29:02 UTC 2023
    Thu Mar 30 21:29:02 CEST 2023
    CEST +0200
    Europe/Berlin
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev i2c lpadmin gpio spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:           1.9G        638M        904M        8.0M        327M        1.1G
    Swap:           99M          0B         99M
    Total:         2.0G        638M        1.0G
             1871 M total memory
              638 M used memory
              149 M active memory
              738 M inactive memory
              904 M free memory
               42 M buffer memory
              285 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       14G  6.1G  7.1G  47% /
    devtmpfs       devtmpfs  775M     0  775M   0% /dev
    tmpfs          tmpfs     936M     0  936M   0% /dev/shm
    tmpfs          tmpfs     936M  8.6M  928M   1% /run
    tmpfs          tmpfs     936M     0  936M   0% /sys/fs/cgroup
    /dev/sda1      vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     188M     0  188M   0% /run/user/1000
    Messages in dmesg:
    [Thu Mar 30 21:24:52 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1280x1024M@60 smsc95xx.macaddr=DC:A6:32:BD:45:5F vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=ae48e9dc-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Thu Mar 30 21:24:55 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Thu Mar 30 21:24:55 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Thu Mar 30 21:24:56 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
    TARGET        SOURCE    FSTYPE OPTIONS
    /             /dev/sda2 ext4   rw,noatime
    |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.2G    /var/
    534M    /var/log
    455M    /var/cache
    443M    /var/cache/apt
    384M    /var/cache/apt/archives
    /opt/iobroker/backups:
    13M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    242M    /opt/iobroker/iobroker-data/
    152M    /opt/iobroker/iobroker-data/files
    59M     /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    42M     /opt/iobroker/iobroker-data/files/devices.admin
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
    12M     /opt/iobroker/iobroker-data/objects.jsonl
    9.4M    /opt/iobroker/iobroker-data/states.jsonl
    8.2M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.15.0
    /usr/bin/node           v18.15.0
    /usr/bin/npm            9.5.0
    /usr/bin/npx            9.5.0
    nodejs:
      Installed: 18.15.0-deb-1nodesource1
      Candidate: 18.15.0-deb-1nodesource1
      Version table:
     *** 18.15.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u3 500
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : phoscon                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : phoscon                                  -  enabled
    + system.adapter.backitup.0               : backitup              : phoscon                                  -  enabled
    + system.adapter.ble.0                    : ble                   : phoscon                                  -  enabled
    + system.adapter.broadlink2.1             : broadlink2            : phoscon                                  -  enabled
    + system.adapter.deconz.0                 : deconz                : phoscon                                  -  enabled, port: 80
      system.adapter.devices.0                : devices               : phoscon                                  - disabled
    + system.adapter.discovery.0              : discovery             : phoscon                                  -  enabled
    + system.adapter.info.0                   : info                  : phoscon                                  -  enabled
    + system.adapter.iot.0                    : iot                   : phoscon                                  -  enabled
    + system.adapter.javascript.0             : javascript            : phoscon                                  -  enabled
    + system.adapter.meross.0                 : meross                : phoscon                                  -  enabled
    + system.adapter.shelly.0                 : shelly                : phoscon                                  -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : phoscon                                  -  enabled, port: 1883, bind: 192.168.178.42
    + system.adapter.sonoff.1                 : sonoff                : phoscon                                  -  enabled, port: 1889, bind: 192.168.178.42
    + system.adapter.wifilight.0              : wifilight             : phoscon                                  -  enabled
    + system.adapter.yahka.0                  : yahka                 : phoscon                                  -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.5.12   , installed 2.5.12
    Adapter    "ble"          : 0.13.0   , installed 0.13.0
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "devices"      : 1.1.2    , installed 1.1.2
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.14.2   , installed 1.14.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "meross"       : 1.14.0   , installed 1.14.0
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "yahka"        : 0.17.0   , installed 0.17.0
    Objects and States
    Objects:        2535
    States:         1845
    Hit:1 http://phoscon.de/apt/deconz buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 http://archive.raspberrypi.org/debian buster InRelease
    Hit:4 https://deb.nodesource.com/node_18.x buster InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          16328      542/dnsmasq
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19660      546/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17665      363/cupsd
    tcp        0      0 192.168.178.42:1883     0.0.0.0:*               LISTEN      1001       21663      1071/io.sonoff.0
    tcp        0      0 192.168.178.42:1889     0.0.0.0:*               LISTEN      1001       21264      1102/io.sonoff.1
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18811      502/iobroker.js-con
    tcp        0      0 127.0.0.1:44361         0.0.0.0:*               LISTEN      1001       25453      1293/io.yahka.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18804      502/iobroker.js-con
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          20565      521/vncserver-x11-c
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19085      672/io.admin.0
    tcp6       0      0 :::37715                :::*                    LISTEN      1001       23377      1293/io.yahka.0
    tcp6       0      0 :::53                   :::*                    LISTEN      0          16330      542/dnsmasq
    tcp6       0      0 :::22                   :::*                    LISTEN      0          19662      546/sshd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17664      363/cupsd
    tcp6       0      0 :::5900                 :::*                    LISTEN      0          20564      521/vncserver-x11-c
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       23748      1156/io.shelly.0
    udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          16327      542/dnsmasq
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          20624      457/dhcpcd
    udp        0      0 0.0.0.0:57972           0.0.0.0:*                           109        14298      333/avahi-daemon: r
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          20561      490/cups-browsed
    udp        0      0 192.168.178.42:123      0.0.0.0:*                           105        20424      525/ntpd
    udp        0      0 192.168.178.63:123      0.0.0.0:*                           105        20422      525/ntpd
    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          17493      525/ntpd
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          17488      525/ntpd
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       23811      1203/io.broadlink2.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           109        14296      333/avahi-daemon: r
    udp        0      0 0.0.0.0:37155           0.0.0.0:*                           1001       22208      1203/io.broadlink2.
    udp        0      0 0.0.0.0:38214           0.0.0.0:*                           1001       23009      1203/io.broadlink2.
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       25490      1486/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       25487      1486/io.deconz.0
    udp6       0      0 :::546                  :::*                                0          20258      457/dhcpcd
    udp6       0      0 :::57396                :::*                                109        14299      333/avahi-daemon: r
    udp6       0      0 :::53                   :::*                                0          16329      542/dnsmasq
    udp6       0      0 2003:cd:a712:7700:d:123 :::*                                105        21568      525/ntpd
    udp6       0      0 2003:cd:a712:7700:3:123 :::*                                105        21565      525/ntpd
    udp6       0      0 fe80::5415:655e:213:123 :::*                                105        20335      525/ntpd
    udp6       0      0 fe80::7251:64f0:bb3:123 :::*                                105        20331      525/ntpd
    udp6       0      0 ::1:123                 :::*                                0          17495      525/ntpd
    udp6       0      0 :::123                  :::*                                0          17485      525/ntpd
    udp6       0      0 :::5353                 :::*                                109        14297      333/avahi-daemon: r
    udp6       0      0 :::1900                 :::*                                1001       25492      1486/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       25491      1486/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       25489      1486/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       25488      1486/io.deconz.0
    2023-03-30 21:25:47.282  - debug: backitup.0 (1505) States create User PubSub Client
    2023-03-30 21:25:47.309  - debug: backitup.0 (1505) States connected to redis: 127.0.0.1:9000
    2023-03-30 21:25:47.393  - debug: backitup.0 (1505) Plugin sentry Initialize Plugin (enabled=true)
    2023-03-30 21:25:48.210  - info: backitup.0 (1505) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.15.0, js-controller: 4.0.24
    2023-03-30 21:25:48.297  - debug: backitup.0 (1505) Backitup has recognized a linux system
    2023-03-30 21:25:48.428  - info: backitup.0 (1505) [iobroker] backup was activated at 02:40 every 3 day(s)
    2023-03-30 21:25:48.571  - warn: backitup.0 (1505) No backup file was found
    2023-03-30 21:26:19.204  - info: admin.0 (672) <== Disconnect system.user.admin from ::ffff:192.168.178.87 admin
    2023-03-30 21:26:19.492  - info: admin.0 (672) ==> Connected system.user.admin from ::ffff:192.168.178.87
    2023-03-30 21:26:32.509  - info: admin.0 (672) ==> Connected system.user.admin from ::ffff:192.168.178.87
    2023-03-30 21:26:34.966  - info: host.phoscon Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-03-30 21:26:36.021  - info: admin.0 (672) <== Disconnect system.user.admin from ::ffff:192.168.178.87
    2023-03-30 21:27:09.981  - info: admin.0 (672) ==> Connected system.user.admin from ::ffff:192.168.178.87
    2023-03-30 21:27:10.337  - debug: backitup.0 (1505) telegram-instance:
    2023-03-30 21:27:10.676  - warn: deconz.0 (1486) Could not connect to websocket instance of deConz/Phoscon. Error: connect ECONNREFUSED 192.168.178.63:443
    2023-03-30 21:27:19.074  - debug: backitup.0 (1505) Backup list cannot be read ...
    2023-03-30 21:27:19.076  - debug: backitup.0 (1505) Backup list cannot be read ...
    2023-03-30 21:27:32.050  - info: admin.0 (672) <== Disconnect system.user.admin from ::ffff:192.168.178.87
    2023-03-30 21:27:50.625  - info: admin.0 (672) ==> Connected system.user.admin from ::ffff:192.168.178.87
    2023-03-30 21:27:54.316  - info: javascript.0 (807) Stop script script.js.Wohnzimmer.Neu
    2023-03-30 21:28:05.578  - info: admin.0 (672) <== Disconnect system.user.admin from ::ffff:192.168.178.87 javascript
    2023-03-30 21:28:05.774  - info: admin.0 (672) ==> Connected system.user.admin from ::ffff:192.168.178.87
    2023-03-30 21:28:08.095  - info: host.phoscon Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-03-30 21:28:10.681  - warn: deconz.0 (1486) Could not connect to websocket instance of deConz/Phoscon. Error: connect ECONNREFUSED 192.168.178.63:443
    2023-03-30 21:29:10.689  - warn: deconz.0 (1486) Could not connect to websocket instance of deConz/Phoscon. Error: connect ECONNREFUSED 192.168.178.63:443
    iob diag has finished.
    #83
    @olli63
    Hast du nach dem
    sudo apt upgrade
    die Kiste nochmal neugestartet?
    Wenn nicht, dann tu es jetzt.
    sudo reboot
    Und dann kannst du das noch durchackern:
    https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
    O 1 Antwort Letzte Antwort
      @olli63
      Hast du nach dem
      sudo apt upgrade
      sudo reboot
      O Offline
      O Offline
      Olli63
      #84
      sudo apt upgrade
      das letzte hätte ich nicht tun sollen....
      Bei 90 % stehen geblieben - System Tot
      • O Olli63
        sudo apt upgrade
        O Offline
        O Offline
        Olli63
        #85
        @olli63 said in Backitup findet Dateien nicht auf NAS-Stick wird gesucht:
        sudo apt upgrade
        3 Stunden umsonst ... gut wenn man eine Datensicherung auf einem Ersatzstick hat.
        Das mit dem Bullseye werde ich nicht nochmal probieren
        • O Olli63
          sudo apt upgrade
          #86
          @olli63
          Dann installier jetzt direkt Bullseye. Buster ist abgekündigt. Ein Backup zu haben ist eh eine Selbstverständlichkeit.
            @olli63
            O Offline
            O Offline
            Olli63
            #87
            @olli63
            Was bedeutet direkt bullseye zu installieren? ich bin dem Link gefolgt und habe die Schritte step by step ausgeführt.
            Bei apt full-upgrade ist das System bei 90 % gestorben.
            Gibt es ein en anderen Weg?
            • O Olli63
              @olli63
              #88
              @olli63 sagte in Backitup findet Dateien nicht auf NAS-Stick wird gesucht:
              Installier das System halt neu mit dem derzeitigen Release.
                O Offline
                O Offline
                Olli63
                #89
                gibt es dafür ein image
                • O Olli63
                  #90
                  Das nicht verwendet werden sollte.
                  • O Olli63
                    #91
                    was genau meinst du?
                    auf raspberrypi.org gibt es das Raspberrypi OS lite bullseye zum download
                      O Offline
                      O Offline
                      Olli63
                      #92
                      @homoran said in Backitup findet Dateien nicht auf NAS-Stick wird gesucht:
                      So, wir können das an dieser Stelle beenden. Das Problem anders gelöst:
                      Mit der Datensicherung das "alte" System neu aufgesetzt und aktualisiert
                      Backitup neu installiert und den Speicherort neu eingerichtet.
                      ... läuft jetzt in beide Richtungen.
                      Danke für Eure Hilfsversuche.
                      Und ja,.... bei Gelegenheit werde ich mich mit Bullseye beschäftigen.
                      LG
                      Olaf
                      • O Olli63
                        LG
                        Olaf
                        #93
                        @olli63
                        Die Notwendigkeit besteht jetzt, dein Buster wird nicht mehr unterhalten. Upgrade auf Bullseye dringend erforderlich.
                        R 1 Antwort Letzte Antwort
                          @olli63
                          Rico Sander
                          #94
                          Frage aus Interesse:
                          Dann dürfte ein
                          sudo apt-get update && sudo apt-get upgrade -y
                          bei Buster 10 nichts Neues mehr bringen bzw. ins Leere laufen? Oder wie muss ich das verstehen?
                          DAnke
                          VG Peter
                          Wenns nicht geht, wie man will
                          - muss mans tun, wie man kann.
                          • R Rico Sander
                            Dann dürfte ein
                            DAnke
                            VG Peter
                            #95
                            @pi-ter
                            https://www.debian.org/News/2022/20220910
                            Nach dieser Zwischenveröffentlichung werden Debians Security- und Release-Teams die Arbeit an Aktualisierungen für Debian 10 einstellen. Wer weiterhin Sicherheitsunterstützung erhalten möchte, sollte auf Debian 11 umsteigen
                            Ein seitens des Herstellers abgekündigtes System selber auf Stand zu halten kannst du als Endanwender nicht leisten, also Upgrade auf ein lebendes Release.
                              @pi-ter
                              Rico Sander
                              #96
                              Ok, danke. Wenn diese Meldung von September 2022 ist, hätte ich vorgestern mein Buster 10 gar nicht mehr auf neuesten Stand bringen können (bevor ich nach Anleitung auf bullseye umgestiegen bin). Ist schon alles verwirrend ... :-)
                              Schönes Wochenende...
                              • R Rico Sander
                                #97
                                @pi-ter sagte in Backitup findet Dateien nicht auf NAS-Stick wird gesucht:
                                Das ist der Stand vom September gewesen, danach sind keine Updates mehr von Debian über deren Kanäle erfolgt.
                                Übrigens kann man hier ganz gut sehen, wie die Systeme 'wegsterben' nach einiger Zeit:
                                https://github.com/nodesource/distributions
                                nodejs18 und neuer bekommst du auf Debian 9 / Stretch nicht mehr gebaut.
                                WARNING: BUILD SYSTEM CURRENTLY BROKEN FOR NODEJS 18+
                                • R Rico Sander
                                  #98
                                  die Frage ist was der neueste Stand ist.
                                  selbst der Stand von heute ist dann der selbe Stand wie zum Abkündigungsdatum
                                  wenn ich heute ein WIN95 ins Netz stellen würde und auf update klicke, wird wahrscheinlich eine Fehlermeldung kommen.
                                  Wenn es "rund" läuft wird es heißen: "Das System ist auf dem aktuellen Stand"
                                  ....was immer das heisst :-)
                                    Rico Sander
                                    #99
                                    @homoran 3
                                    Ich möchte Euch weder belehren, noch den Glauben nehmen. Und vielleicht bin ich ja auch zu blöd und sehe vieles völlig verkehrt. Aber ich habe am 19.03.23 ein Update mit wenigen Änderungen gefahren und ich habe am 31.03.23 ein Update mit wenigen Neuerungen gefahren.
                                    Wenn ich am 19.03. wirklich die allerletzten Updates (spät und nachträglich) eingespielt habe, woher kamen dann am 31.03. noch Änderungen?
                                    Und ja, ich kann das nicht beweisen und werde glauben, was geschrieben steht.
                                    Wir müssen das jetzt auch nicht weiter ausdiskutieren. Ich habe inzwischen bullseye und gut ist's. :-)
                                    • R Rico Sander
                                      @homoran 3
                                      #100
                                      Aus ThirdParty-Repos? nodesource baut ja auch noch für längst abgekündigte Releases. Bzw. sie versuchen es (siehe oben).
                                      Oder die sind von den Krankenpflegern von LTS gekommen. Die halten in sehr eingeschränktem Umfang den Patienten noch etwas halblebendig, damit auch die allerletzten den Schuss hören und weiter ziehen können.
                                      Ubuntu ist da rigoroser, die räumen bei abgekündigten Releases recht schnell die Server frei und du hängst dann komplett in der Luft.
