  4. go-e Adapter
    6.4k
go-e Adapter
1.0k Beiträge 83 Kommentatoren 460.4k Aufrufe 33 Beobachtet
  • C cb187
    @fabzap
    Api v1 auch an?
    FabzapF Offline
    FabzapF Offline
    Fabzap
    #667
    @cb187 Das war's! Vielen Dank.
    • C cb187
      @fabzap
      Api v1 auch an?
      FabzapF Offline
      FabzapF Offline
      Fabzap
      #668
      @cb187 Allerdings hängt sich jetzt der Adapter recht schnell auf.
      ost.raspisauen
      2023-03-19 11:48:52.535 warn Do not restart adapter system.adapter.go-e.0 because restart loop detected
      host.raspisauen
      2023-03-19 11:48:52.535 info Restart adapter system.adapter.go-e.0 because enabled
      host.raspisauen
      2023-03-19 11:48:52.535 error instance system.adapter.go-e.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.raspisauen
      2023-03-19 11:48:52.535 error Caught by controller[1]: at GoE.adjustAmpLevelInWatts (/opt/iobroker/node_modules/iobroker.go-e/main.js:793:25)
      host.raspisauen
      2023-03-19 11:48:52.534 error Caught by controller[1]: TypeError: Cannot read property 'finish' of undefined
      host.raspisauen
      2023-03-19 11:48:52.534 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      go-e.0
      2023-03-19 11:48:52.145 info 200 with message: OK
      go-e.0
      2023-03-19 11:48:51.990 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
      go-e.0
      2023-03-19 11:48:51.988 info terminating
      go-e.0
      2023-03-19 11:48:51.956 error Cannot read property 'finish' of undefined
      go-e.0
      2023-03-19 11:48:51.955 error TypeError: Cannot read property 'finish' of undefined at GoE.adjustAmpLevelInWatts (/opt/iobroker/node_modules/iobroker.go-e/main.js:793:25)
      go-e.0
      2023-03-19 11:48:51.954 error unhandled promise rejection: Cannot read property 'finish' of undefined
      go-e.0
      2023-03-19 11:48:51.952 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      go-e.0
      2023-03-19 11:48:51.939 info Set value 21 of id amx
      C 1 Antwort Letzte Antwort
      • FabzapF Fabzap
        ost.raspisauen
        host.raspisauen
        host.raspisauen
        host.raspisauen
        host.raspisauen
        host.raspisauen
        go-e.0
        go-e.0
        go-e.0
        go-e.0
        go-e.0
        go-e.0
        go-e.0
        go-e.0
        cb187
        #669
        @fabzap schreibst du was in amplevel?
        FabzapF 1 Antwort Letzte Antwort
        • nik82N nik82
          @chaarch0
          Schick mal einen Auszug vom Log, aber nur die go-e Adapter Einträge von der Zeit wo du den Test gemacht hast.
          Mike Hellracer
          schrieb am zuletzt editiert von Mike Hellracer
          #670
          @nik82
          Adapter = v.1.0.23 und die Firmware der Box = 55.0
          Cloud Verbindung ist an
          lokale HTTP API v2 ist an
          lokale HTTP API v1 ist an
          lokale ModbusTCP API ist an
          Alles wird erkannt und sauber ausgelesen
          Aber ich bekomme es einfach nicht hin, das die Box nur bei PV-Überschuss lädt. Entweder lädt sie volle Power oder gar nicht.
          Auch das Protokoll meldet noch nicht mal den Versuch einer Anpassung.
          Hier das Prokoll:
          go-e.1
          2023-03-31 13:51:24.834	debug	{"version":"B","tme":"3103231351","rbc":"248","rbt":"122758719","car":"2","amx":"10","amp":"10","err":"0","ast":"1","alw":"1","stp":"0","cbl":"20","pha":"63","fsp":"0","tma":[24.25,27],"dws":"4588847","dwo":"180","adi":"1","uby":"2","eto":"31534","wst":"3","fwv":"055.0","nrg":[227,227,228,0,91,91,92,17,16,17,0,520,83,80,84,1],"sse":"058233","wss":"Skynet","wke":"********","wen":"1","cdi":"0","tof":"101","tds":"1","lbr":"0","aho":"0","afi":"6","azo":"1","ama":"16","al1":"6","al2":"10","al3":"12","al4":"14","al5":"16","cid":"255","cch":"65535","cfi":"65280","lse":"0","ust":"2","wak":"********","r1x":"2","dto":"0","nmo":"0","sch":"AAAAAAAAAAAAAAAA","sdp":"0","eca":"6002","ecr":"25530","ecd":"0","ec4":"0","ec5":"0","ec6":"0","ec7":"0","ec8":"0","ec9":"0","ec1":"0","rca":"1","rcr":"1","rcd":"","rc4":"","rc5":"","rc6":"","rc7":"","rc8":"","rc9":"","rc1":"","rna":"Micha","rnm":"Anika","rne":"n/a","rn4":"n/a","rn5":"n/a","rn6":"n/a","rn7":"n/a","rn8":"n/a","rn9":"n/a","rn1":"n/a","loe":0,"lot":32,"lom":10,"lop":50,"log":"DBNFXQHD","lof":0,"loa":0,"lch":121943}
          go-e.1
          2023-03-31 13:51:24.833	debug	Response: 200 - OK with data as object
          go-e.1
          2023-03-31 13:51:24.613	debug	Starte Abfrage an: http://go-echarger-058233.fritz.box/status
          go-e.1
          2023-03-31 13:51:24.610	debug	Subscribe foreign object 0_userdata.0.Energiemanager.PowerPV
          go-e.1
          2023-03-31 13:51:24.609	debug	Subscribe foreign object 0_userdata.0.Energiemanager.PowerHome
          go-e.1
          2023-03-31 13:51:24.608	debug	Subscribe foreign object 0_userdata.0.Energiemanager.BatEnergy
          go-e.1
          2023-03-31 13:51:24.601	info	Intervall: 60
          go-e.1
          2023-03-31 13:51:24.600	info	Server: go-echarger-058233.fritz.box
          go-e.1
          2023-03-31 13:51:24.538	info	starting. Version 1.0.23 in /opt/iobroker/node_modules/iobroker.go-e, node: v16.19.1, js-controller: 4.0.23
          Was muss ich machen, damit die dynamische Steuerung funktioniert? Oder ggf. in der App konfigurieren?
          Muss ich in der App die Funktion "PV-Überschuss laden" oder noch etwas anderes aktivieren?
          Hier die Config des Adapter
          nik82N 1 Antwort Letzte Antwort
          • M Mike Hellracer
            @nik82
            Hier das Prokoll:
            go-e.1
            go-e.1
            go-e.1
            go-e.1
            go-e.1
            go-e.1
            go-e.1
            go-e.1
            go-e.1
            nik82N Offline
            nik82N Offline
            nik82
            #671
            @mike-hellracer
            Bitte mal screenshot deiner Datenpunkte, weil du brauchst überall positive werte, nicht das du einen negativen wert hast, das ist bei meinem fronius genauso, da muss ich den wert erstmal umwandeln.
            Und mach mal den datenpunkt bei batterie erstmal raus um adapter, den kannst nachher immer noch setzen wenns funktioniert.
            • nik82N nik82
              @mike-hellracer
              Mike Hellracer
              #672
              @nik82
              Hi, Danke für die prompte Rückmeldung...
              Bat habe ich raus gemacht, trotzdem brummt das Ding auf 8KW obwohl der PV-Ertrag derzeit nur 4 KW hat
              anbei:
              Jetzt ist auf 3kW runter, aber der PV Ertrag ist zur Zeit nur 900Watt. Ich hatte erwartet, das der PV-Ertrag nicht überschritten wird???
              Jetzt ist er erst mal aufgeladen. :) mal sehen wie es sich morgen verhällt.
              Eine Frage habe ich noch gibt es irgendwo den aktuellen Ladestand des Autos?
              nik82N HomoranH 2 Antworten Letzte Antwort
              • M Mike Hellracer
                @nik82
                anbei:
                nik82N Offline
                nik82N Offline
                nik82
                #673
                @mike-hellracer
                Also von der Einstellung her ist alles korrekt, sofern sich deine PV Objekte auch richtig aktualisieren muss das auch funktionieren.
                Probier mal.
                P.S. Wie sich das mit der Batterieladung verhält weiß ich nicht, das hab ich nicht bei mir aktiviert.
                • nik82N nik82
                  @mike-hellracer
                  Probier mal.
                  Mike Hellracer
                  #674
                  @nik82
                  Ich meinte den Status meines Autos. Wie voll ist der Akku gerade.
                  Oder habe ich den Wert übersehen?
                  • M Mike Hellracer
                    @nik82
                    anbei:
                    #675
                    @mike-hellracer sagte in Go e-charger:
                    ja, in den Datenpunkten deines Autos.
                    Woher soll der Charger den SoC deines Autos kennen?
                    • M Mike Hellracer
                      @nik82
                      nik82N Offline
                      nik82N Offline
                      nik82
                      #676
                      @mike-hellracer
                      Musst halt einen Adapter für dein Auto suchen wenn es da einen gibt.
                      Aber die Wallbox kann sowas nicht, egal welche, das geht nicht.
                      • nik82N nik82
                        @mike-hellracer
                        Mike Hellracer
                        #677
                        @nik82
                        Yep, danke auf den Trichter bin ich gestern abend auch gekommen und habe den passenden Adapter installiert. :)
                        Jetzt habe ich das ganze mal einen Moment beobachtet und es scheint soweit zu funktionieren, das der Adapter die Box auf Max 14A stellt und der LadeWert dann bis ca 3kw runter geregelt wird.
                        Aber leider nicht ganz auf Null.
                        Das bedeutet ständiger Netzbezug, wenn die Box nachts verbunden ist.
                        Weiter oben habe ich gelesen, daß 6A minimum wären. Wie ist das, könnt ihr das bestätigen?
                        Oder wie habt ihr das gelöst?
                        Vlt. Die Ladezeiten in der Box setzen?
                        Und ich habe 2 Go-e. Sollte ich da das Lastenmanagent aktivieren oder alles über iob regeln?
                        • M Mike Hellracer
                          @nik82
                          nik82N Offline
                          nik82N Offline
                          nik82
                          #678
                          1. Ja, minimum ist 6A, wenn du ausschalten willst, dann per Blockly lösen, hab ich auch hier im Threat irgendwo mal geschrieben wie das geht.
                          2. Durch dein Lastmanagement geht die Box nur auf 14A, mach das raus und es geht auch bis 16A.
                          • nik82N nik82
                            Mike Hellracer
                            #679
                            @nik82
                            Danke für die Antwort,
                            also entweder komplett auf das Blockly umsteigen
                            https://forum.iobroker.net/topic/30415/go-e-charger/18
                            Oder additiv zum Adapter mit deinem Blockly realisieren?
                            https://forum.iobroker.net/topic/30415/go-e-charger/605
                            (hier der Teil mit der Zeitsteuerung)
                            https://forum.iobroker.net/topic/30415/go-e-charger/613
                            Oder vlt auf OpenWB umsellen?
                            https://forum.iobroker.net/topic/30415/go-e-charger/119
                            Wahrscheinlich ist die Kombination aus Adapter und zusätzliches Blockly die einfachere. Und am besten das Abschalten dann über den Adapter des jeweiligen Autos regeln.
                            Könntest du dein Blockly nochmal komplett zur Verfügung stellen?
                            Wie ist deine Meinung?
                            Und eine Verständnisfrage habe ich noch:
                            Gebe ich unter Hausverbrauch den aktuellen Gesamtverbraucht an oder muss ich mir einen Wert ohne Wallbox erstellen?
                            • nik82N Offline
                              nik82N Offline
                              nik82
                              schrieb am zuletzt editiert von nik82
                              #680
                              Nur zur Info:
                              Beim neuesten Adapter Update gibt es nun ein Objekt: "solarLoadOnly":
                              Hier kann man nun mit einem klick auswählen ob die PV Steuerung im Adapter aktiv sein soll oder nicht 👍
                              P.S. Danke an @MK-2001
                              • M Mike Hellracer
                                @nik82
                                nik82N Offline
                                nik82N Offline
                                nik82
                                #681
                                @nik82
                                Sorry, hab deinen Post ganz überlesen.
                                Richtig, mach doch die PV Steuerung über Adapter und den Rest per Blockly. Aber im neuen Adapter gibts ja jetzt eine neue Funktion, wie oben bei dem Post beschreiben. Funktioniert bei mir aber noch nicht, brauche da mehrere Infos wie die Logik funktioniert.
                                P.S. Hausverbrauch ist der gesamte aktuelle Verbrauch des Hauses INKLUSIVE Wallbox, brauchst also nichts extra rumstellen.
                                • nik82N Offline
                                  nik82N Offline
                                  nik82
                                  #682
                                  Muss leider nochmal einen Post machen:
                                  ACHTUNG! beim Update auf die neue Version 1.0.26 bzw. 1.0.27:
                                  Die PV Steuerung funktioniert nicht mehr so (perfekt) wie vorher:
                                  Die Wallbox schaltet jetzt (wenn kein Überschuss mehr vorhanden ist) aus, also alw=0 und nicht mehr nur auf 6A.
                                  Und schaltet die Wallbox aber auch bei Überschuss nicht mehr ein.
                                  Ich glaube nicht das dies so vom Entwickler gewünscht ist, vielleicht mache ich auch etwas jetzt falsch oder übersehe etwas.
                                  Wird sich aufklären, habe schon in Issue im Github erstellt.
                                  KenzoK 1 Antwort Letzte Antwort
                                  • C cb187
                                    FabzapF Offline
                                    FabzapF Offline
                                    Fabzap
                                    #683
                                    @cb187 Ich hatte einen Nutzerdatenpunkt im Adapter eingetragen.
                                    Im nächsten Versuch habe ich das freigelassen und stattdessen mal versucht, aus dem Blockly Script direkt in das Feld "max_watts" zu schreiben. Es wird zwar gefüllt. Aber da bekomme ich dann die Fehlermeldung: "Error during set MaxWatts: setAmp is not defined"
                                    Zu setAmp konnte ich nichts nichts finden..
                                    Die Wallbox lädt völlig unbeeindruckt.
                                    Adapter: v1.0.27, API V1 und V2 und Cloud enabled.
                                    Settings:
                                    • FabzapF Fabzap
                                      Settings:
                                      cb187
                                      #684
                                      @fabzap
                                      ja hab ich auch gesehn in der neusten version.hatte die jetzt die tage mal getestet.
                                      Deshalb bin ich wieder auf 1.0.25 zurück wo alles wunderbar funjtioniert.
                                      FabzapF C 3 Antworten Letzte Antwort
                                      • C cb187
                                        @fabzap
                                        FabzapF Offline
                                        FabzapF Offline
                                        Fabzap
                                        #685
                                        @cb187 Wunderbar, das war's!! Danke!
                                        • FabzapF Fabzap
                                          cb187
                                          #686
                                          @fabzap said in Go e-charger:
