  4. Alpha Test js-controller 5.0
    6.6k
140 Beiträge 25 Kommentatoren 31.9k Aufrufe 31 Beobachtet
  • apollon77A Offline
    Alpha Changelog
    5.0.1-alpha.0-20230330-e0b409fe
    • Initial version
    5.0.1-alpha.0-20230403-fd495c2e
    • Fixes missing logging object when logTransporter is used (e.g. Admin)
    • Fixes other issue with logTransporter (e.g. Admin) - events should now stream again in Admin
    • Fixed Compact group initialization
    • Fixes Binary/Text detection in writeFile
    • Fixes sendToHost (all) command
    5.0.1-alpha.0-20230406-4552d569
    • Fixes compact mode
    • Hide warning about "www folder not found" for widgets adapters
    5.0.1-alpha.0-20230418-efa3e809
    • Fixed issue with certificate validity on leap years
    • Backup fixed (Fixed wrong return type on db level for readFile promisified)
    • Remove windows bat files completely, installer will create them when needed
    • Respect dns resolution (ipv4/ipv6 first) from config internally and provide relevant methods via adapter-core - I theory a ipv6 only iobroker in a ipv6 only network is possible with this!
    Changelog 5.0.1-alpha.0-20230525-c580eb7e
    • drop support for nodejs 14 with controller 5 as it is EOL
    • Enable upgrade of js-controller via Admin UI (Linux only) - will be testable when we start with Beta
    • fix wrong hostname after backup restore
    • new io-package flag common.supportedMessages to replace messagebox and other messagebox-related properties
    • adapter.sendTo now accepts an optional timeout argument
    Known issues
    • Doorbord Adapter broken: GitHub versionn tut
    • apollon77A apollon77
      Aktuelle Test Version 5.0.1-alpha.0-20230330-e0b409fe
      Veröffentlichungsdatum 30.03.2023
      Hallo ioBroker-Community,
      Heute möchte ich Euch den js-controller 5.0 für einen ersten Alpha-test zur Verfügung stellen. Dieser Post enthält alle wichtigen Infos.
      Node.js Versions-Anforderungen
      In diesem Release entfällt Node.js 12.x welches seit April letztem Jahr nicht mehr gepflegt wird. Node.js 18.x ist dazugekommen. Die unterstützten Node.js Versionen sind: 14.18.0+, 16.4.0+ und 18.x. Die empfohlene Node.js Version für ioBroker haben wir vor kurzem auf 18.x angehoben.
      Bitte beachtet weiterhin bei Node.js Updates die Anleitung im Forum unter https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-14-16-und-18 !
      Informationen zur Version
      In dieser Version wurde die Umstellung des Quellcodes auf TypeScript sehr stark vorangetrieben (inzwischen bei 76%), wodurch am Ende die Stabilität weiter steigt weil viele Code-Fehler nicht mehr auftreten können. Natürlich sind neben Optimierungen und Fehlerbehebungen auch ein paar neue Features hinzugekommen. Auch wenn mit dieser Version keine neuen Prüfungen hinzukommen, die zu Log-Ausgaben bei Adaptern führen, meldet aktuelle Logausgaben bitte weiterhin bei den Adaptern.
      Detailliertere Informationen zu allen Änderungen und Features findet Ihr weiter unten und im Changelog. Ich hoffe auch diesmal auf Eure tatkräftige Unterstützung, sodass der Latest-Release dann genau so reibungslos verläuft wie bei den letzten Versionen.
      Für die aktive Mitarbeit an dieser Version des js-controller bedanke mich diesmal wieder besonders bei foxriver76, AlCalzone und natürlich Bluefox und auch ein paar weiteren Entwicklern!
      ACHTUNG backups inkompatibel bei Downgrades!!
      Neben der Node.js Version gibt es eine wichtige Inkompatibilität: Backups die mit der 5.0 des js-controller erstellt wurden lassen sich nicht mit einem js-controller 4 oder kleiner wieder restoren!
      Darüber hinaus ist der js-controller 5.0 generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der 2.0/2.1/2.2/3.x ist problemlos möglich. Wir empfehlen allerings vor dem Update auf die 5.0 idealerweise ein Update auf die 4.0 und vorher auf 3.3.x durchzuführen, da ein Downgrade nach einem erfolgten Update nur auf eine 3.3.x möglich ist (siehe FAQ)! Nur die Node.js Version muss weiterhin mindestens 16.x sein, wie oben bereits ausgeführt. Wer überlegt die Node.js Version anzuheben bitte weiter unten im Abschnitt "Was ist zu testen" lesen 🙂
      Aufgrund einiger internen Umstellungen brauchen wieder einige Adapter Updates. Diese sollten am besten VOR dem Update installiert werden!
      Bitte dazu die Informationen weiter unten beachten!
      Installation
      VOR der Installation
      Wie bei jedem Test dieser Art: Bitte macht ein Backup! iobroker backup bzw kopieren des iobroker-data Verzeichnisses reichen an sich aus. Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt. Eine alte 4.0.x-Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version ("version" durch die gewünschte Versionsnummer ersetzen) installiert werden und sollte alles wieder herstellen (Letzter Stable Stand ist die 4.0.24)
      Nötige Adapter-Aktualisierungen
      Am besten dennoch VOR dem js-controller Update alle verfügbaren Adapter-Updates prüfen und alle Updates installieren, die im Changelog auf Optimierungen oder Anpassungen für den js-controller 4.0 oder höher hinweisen.
      Diesmal sind doch einige Adapter auf der Liste die man updaten muss! Siehe Spoiler!
      • admin -> v6.2.23+
      • backitup v2.6.16+
      • cloud v4.2.3+
      • discovery v3.0.6+
      • email v1.1.4+
      • enigma2 (GitHub version fixed)
      • fitbit-fitness - noch kein Fix
      • history v2.2.4+
      • hmrega v3.0.46+
      • iquontrol v2.2.1+
      • lgtv from https://github.com/foxriver76/ioBroker.lgtv nutzen bis Entwickler angepasst hat
      • lovelace - > v2.2.0+
      • mercury - released v0.1.6+
      • mqtt: v4.1.1+
      • nibeuplink v1.2.1+
      • node-red v4.0.1+
      • onvif 1.0.1+
      • owntracks v1.0.5+
      • pimatic v0.3.1+
      • rest-api -> v1.0.5+
      • ring - released in v3.2.7+
      • sayit v1.13.0+
      • simple-api v2.7.2+
      • smart-visu GitHub
      • socketio -> v6.2.0+
      • sonos v2.3.1+
      • synology v2.1.13+
      • tado v???? (issue opened)
      • telegram v1.15.1+
      • terminal v1.0.0+
      • tr-064 v4.2.18+
      • tuya v3.7.0+
      • unifi-protect v0.0.12+
      • web v5.2.10+
      • ws -> v2.2.0+
      • vis-google-fonts v1.0.4+
      • xterm v1.1.0+
      • yahka - v1.0.0+
      Achtung: MASTER-Systeme Reihenfolgen beachten!
      Bei einem Multi-Host-System, welches auf js-controller 2.2, 3.x oder 4.0.x läuft, ist es beim Update auf Version 5.0 empfohlen, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
      Bei Updates von Master/Slave-Systemen mit js-controller 1.5 oder früher Bitte die jeweiligen Update Threads der empfohlenen Zwischenversionen prüfen.
      Windows
      Generell muss das Update manuell via npm installiert werden.
      Hierzu im ioBroker-Verzeichnis nach stoppen des ioBroker den Befehl npm i iobroker.js-controller@next ausführen.
      Linux
      • ioBroker stoppen (iobroker stop)
      • Prüfen das keine Prozesse (Adapter, Backups) mehr laufen (ps auxww|grep io und auch ps auxww|grep backup ). Es passiert manchmal das trotz dem Stoppen noch Zombies zurückbleiben
      • cd /opt/iobroker
      • Das Update erfolgt via npm i iobroker.js-controller@next
      • ioBroker starten (iobroker start)
      Bei Fehlern:
      Wenn bei der Installation Fehler wegen fehlender Zugriffsrechte auftreten, am besten den Installation-Fixer (iobroker fix wer schon einen js-controller 2.x oder höher hat, alternativ weiterhin manuell via curl -sL https://iobroker.net/fix.sh | bash -) nutzen und die Installation wiederholen.
      Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install iobroker.js-controller versuchen. Bitte berichtet solche Fälle hier im Thread.
      NACH der Installation
      Wenn alles klappt merkt Ihr ausser der höheren Versionsnummer in der Host-Ansicht im Admin keinen Unterschied. Alles funktioniert weiterhin wie vorher. Alle Adapterinstanzen starten und funktionieren. Wenn das so ist hat alles geklappt.
      Falls im Log Warn-Meldungen auftauchen mit dem Hinweis diese an den Entwickler zu senden, dann bitte schauen welcher Adapter es ist und entsprechend dort Issues bitte anlegen!
      Was hat sich geändert, was besonders ansehen/beachten?
      Neben einiger weiterer Bugfixes gibt es folgende Änderungen und Fixes zu erwähnen:
      • generell siehe Changelog, speziell auch für die Features
      • generell bitte im CLI und auch sonst überall drüber schauen. Die Typescript Umstellungen haben sehr viel Code angefasst.
      • Falls jemand sporadisch Alias Fehler im Log hatte bitte versuchen diese mit der neuen version wieder zu provoziere und rückmelden
      Speziell die Entwickler sollten bitte die genannten Deprecations und neuen Features anschauen und beachten.
      Wie bereits gesagt, viele Änderungen fanden hinter den Kulissen statt. Hier für Interessierte als Spoiler eine Zusammenfassung:
      5.0.1 Release Jana
      BREAKING CHANGES
      • Support for Node.js 12 is dropped! Supported are Node.js 14.18.0+, 16.4.0+ and 18.x
      • Backups created with the new js-controller version cannot be restored on hosts with lower js-controller version!
      • Update recommended npm version to 8
      • Deprecate binary states, Adapters will change to use Files instead!
      Features
      • (foxriver76) Show npm error message on failing adapter installations and update also without debug parameter
      • (foxriver76) Introduce iobroker setting (dnsResolution) to choose between verbatim and ipv4 first dns resolution order
      • (foxriver76) Add support for windows for iob fix
      • (bluefox) Added CLI option to restart/start/stop all instances of an adapter (e.g. iob stop admin now also works)
      • (foxriver76) Allow to use iob host oldname command when new host already exists but has no instances
      • (foxriver76) Added an admin notification if redis is misconfigured and info how to fix it
      Optimizations and Fixes
      • (foxriver76) Speedup "getStates" calls with many IDs often used by visualizations: JSONL 17 times faster, Redis 23 times faster
      • (foxriver76) significantly reduce backup size
      • (foxriver76) Enhance CLI help for list command to show all possible types to list
      • (foxriver76) Also stop instances before updating from GitHub
      • (foxriver76) Conversion of big parts of the js-controller codebase to typeScript and address all found issues
      • (Apollon77) Only log error on "enable/disable via .alive" if there is an error
      • (foxriver76) Optimize adapter unload and stop handling for edge cases
      • (AlCalzone) Carefully normalize jsonlOptions
      • (bluefox) Do not show warning on a requested adapter stop/termination
      • (bluefox) Make sure that the first log line is not missing in Admin
      • (foxriver76) Fix wrong formatting of cli get binary state if no encoding is passed
      • (foxriver76) Fix restoring backups from pre js-controller 4.x which were created without config.system
      • (foxriver76) Preserve tier setting on adapter upload
      • (foxriver76) update apt sources before installing os dependencies
      • (foxriver76) Only skip erase on upload if opted out explicitly to always cleanup unneeded files
      • (foxriver76) Try to fix strange alias errors, inform us if it happens again!
      • (AlCalzone/Apollon77) Update jsonl db to prevent locking issues
      • (foxriver76) Fixes iob file sync not working for jsonl
      • (foxriver76) Do not crash if we cannot initialize db backup directory on start
      • (Apollon77/foxriver76) Make sure that all relevant files are removed when eraseOnUpload is used
      • (Apollon77, foxriver76, bluefox, AlCalzone) Several fixes and refactorings to prevent potential crash cases reported by Sentry and other sources
      Developer relevant DEPRECATIONS/WARNINGS
      • Deprecate binary states, Migrate your adapters to use Files instead!
      • If you need to access special js-controller common tools please use adapter-core instead of js-controller directly - see https://github.com/ioBroker/adapter-core#commontools
      Developer relevant new Features
      • (bluefox) Added options to subscribe to file changes: subscribeForeignFiles, unsubscribeForeignFiles, onAdapterFileChanged (event contains id, fileName, size and not the whole content of the file!)
      • (foxriver76) Introduce on("install") handler for adapter which is automatically called when adapter process is started with --install
      • (foxriver76) Introduce io-package flag common.nodeProcessParams to allow to pass adapter specific nodejs process parameters (disables compact mode for the adapter!)
      • (foxriver76) Add JSON-Schema for iobroker.json
      • (bluefox) Allowed export of password.js (to be used with adapter-core)
      • (bluefox) Added _design/chart to the system designs
      • (foxriver76) Automatically generated Code-Docs for Adapter class https://github.com/ioBroker/ioBroker.js-controller/tree/master/packages/controller/doc
      • (foxriver76) Added (foreign)objectExists to adapter methods
      • (bluefox) Extend getSuitableLicenses to look for other licenses
      • (buefox/foxriver76) Added new category for notifications: blocked and respect js-controller common.blockedVersions to block versions from starting
      • (bluefox) Added new system view "custom-full" to return the full objects for objects with a custom part and not only the custom details
      • (foxriver76) Added support for getForeignObjects with an array of strings as pattern
      • (AlCalzone) Preparations to allow js-controller Dev version to be used with dev-server
      • (foxriver76) Validate max timeout value (max 32bit max number) on setTimeout/setInterval and throw on error to prevent issues
      • Developer relevant Optimizations and Fixes
      • (foxriver76) Ensure setObjectNotExists returns id on success
      • (foxriver76) Fix Typings for sendTo/sendToHost
      • (Bluefox) Add User permission check to requireLog
      • general dependency updates
      • code style optimizations and streamline code
      Generell ist zu testen, ob alles noch so funktioniert wie vorher auch. Das ist das wichtigste!
      Wie Fehler melden?
      Wer sich unsicher ist, ob ein Fehler vorliegt, sollte am besten hier im Thread das Problem beschreiben. So können wir alle versuchen, das Problem nachzuvollziehen und ggf. einzugrenzen.
      Bitte checkt auch die "Known issues Liste" (zweiter Post) mit den Dingen die aktuell während der Alpha bekannt sind und bis zum Releasen noch angepasst werden.
      Sobald ein Fehler auftritt der in einer Fehlermeldung oder einen Crash mit Fehlerdetails im Log oder auf Kommandozeile endet, dann dazu am besten direkt ein GitHub-Issue im js-controller Projekt öffnen und zusätzlich hier im Thread posten. Je detaillierter die Angaben im Issue sind (genaue Fehlermeldungen/Logs, Infos zur OS- und Node.js-Umgebung sowie genaue Schritte zur Reproduktion des Problems), umso schneller können wir Fehler einkreisen und beheben.
      Bitte postet auch die Ausgabe von iob diag mit rein.
      Wir wünschen allen viel Spaß beim Testen und vielen Dank für Eure Unterstützung!
      Ingo
      sigi234S Online
      sigi234S Online
      @apollon77
      Läuft:
      Plattform: Windows
      ADMIN: 6.4.2
      RAM: 15.9 GB
      Node.js: v18.15.0
      NPM: v9.5.0
      • arteckA Offline
        arteckA Offline
        arteck
        vergiss es... läuft.. der Fehler ist aus meiner DEV Umgebeung
          Alpha Changelog
          • Initial version
          Known issues
          @apollon77
          Läuft hier auch ohne großen Schluckauf.
          • arteckA Offline
            arteckA Offline
            arteck
            @apollon77
            hier passt was nicht..was ist Familiennummer :-)
            und hier auch nicht ist ein redis/redis
              Installation
              • admin -> v6.2.23+
              • backitup v2.6.16+
              • cloud v4.2.3+
              • discovery v3.0.6+
              • email v1.1.4+
              • history v2.2.4+
              • hmrega v3.0.46+
              • iquontrol v2.2.1+
              • mqtt: v4.1.1+
              • node-red v4.0.1+
              • onvif 1.0.1+
              • owntracks v1.0.5+
              • pimatic v0.3.1+
              • sayit v1.13.0+
              • smart-visu GitHub
              • sonos v2.3.1+
              • synology v2.1.13+
              • telegram v1.15.1+
              • terminal v1.0.0+
              • tr-064 v4.2.18+
              • tuya v3.7.0+
              • web v5.2.10+
              • ws -> v2.2.0+
              • xterm v1.1.0+
              • yahka - v1.0.0+
              Windows
              Linux
              • cd /opt/iobroker
              Bei Fehlern:
              5.0.1 Release Jana
              BREAKING CHANGES
              Features
              Wie Fehler melden?
              Ingo
              sigi234S Online
              sigi234S Online
              @apollon77
              Wollte Kodi installieren:
              2023-03-30 19:55:00.820 - error: host.SmartHome iobroker npm ERR! code ENOENTnpm ERR! syscall spawn gitnpm ERR! path gitnpm ERR! errno -4058npm ERR! enoent An unknown git error occurrednpm ERR! enoent This is related to npm not being able to find a file.npm ERR! enoent npm ERR! A complete log of this run can be found in:npm ERR! C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2023-03-30T17_54_54_879Z-debug-0.log
              2023-03-30 19:55:00.821 - error: host.SmartHome iobroker host.SmartHome Cannot install iobroker-community-adapters/ioBroker.kodi#1ca9561e416237455374853f0415f1b95753cf50: 4294963238
              2023-03-30 19:55:01.847 - info: host.SmartHome iobroker exit 25
              Thomas BraunT apollon77A 2 Antworten Letzte Antwort
              • sigi234S sigi234
                @apollon77
                @sigi234
                Ich meine mich erinnern zu können das kodi auch ohne js-controller5 problematisch zu installieren sein kann.
                Hier funktioniert es allerdings:
                echad@chet:~ $ iob add kodi
                NPM version: 9.5.1
                 Installing iobroker.kodi@2.0.9... (System call)
                added 13 packages in 13s
                101 packages are looking for funding
                  run `npm fund` for details
                host.chet install adapter kodi
                upload [18] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/_data.json _data.json application/json
                upload [17] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/admin.d.ts admin.d.ts video/mp2t
                upload [16] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/background.jpg background.jpg image/jpeg
                upload [15] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/i18n/de/translations.json i18n/de/translations.json application/json
                upload [14] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/i18n/en/translations.json i18n/en/translations.json application/json
                upload [13] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/i18n/es/translations.json i18n/es/translations.json application/json
                upload [12] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                upload [11] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/i18n/it/translations.json i18n/it/translations.json application/json
                upload [10] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                upload [9] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                upload [8] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                upload [7] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                upload [6] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                upload [5] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                upload [4] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/index_m.html index_m.html text/html
                upload [3] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/kodi.png kodi.png image/png
                upload [2] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/remote.png remote.png image/png
                upload [1] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/tsconfig.json tsconfig.json application/json
                upload [0] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/words.js words.js application/javascript
                host.chet object system.adapter.kodi created/updated
                host.chet create instance kodi
                host.chet object system.adapter.kodi.0.alive created
                host.chet object system.adapter.kodi.0.connected created
                host.chet object system.adapter.kodi.0.compactMode created
                host.chet object system.adapter.kodi.0.cpu created
                host.chet object system.adapter.kodi.0.cputime created
                host.chet object system.adapter.kodi.0.memHeapUsed created
                host.chet object system.adapter.kodi.0.memHeapTotal created
                host.chet object system.adapter.kodi.0.memRss created
                host.chet object system.adapter.kodi.0.uptime created
                host.chet object system.adapter.kodi.0.inputCount created
                host.chet object system.adapter.kodi.0.outputCount created
                host.chet object system.adapter.kodi.0.eventLoopLag created
                host.chet object system.adapter.kodi.0.sigKill created
                host.chet object system.adapter.kodi.0.logLevel created
                host.chet object kodi.0.info.connection created
                host.chet Set default value of kodi.0.info.connection: false
                host.chet object system.adapter.kodi.0 created
                Wohl eher kein js-controller5-Thema.
                • arteckA arteck
                  @apollon77
                  @arteck admin issues bitte anlegen. Nix controller Thema.
                  • sigi234S sigi234
                    @apollon77
                    @sigi234 Kodi braucht ein installiertes git weil es eine git dependency hat. Hast du das? Bei Windows bestimmt im Pfad wo es sein muss. Ist im Standard nicht installiert.
                    • FeuersturmF Offline
                      FeuersturmF Offline
                      Feuersturm
                      Master Slave System wurde erfolgreich auf die neue js-controller Version aktualisiert. Bisher erstmal keine wirklichen Probleme.
                      Wenn ich im Admin das log Fenster offen habe, dann aktualisieren sich die Log Einträge nicht automatisch, sondern ich muss per Reload Button die Aktualisierung vom Log triggern. Ist das bei euch auch so?
                      Edit: https://github.com/ioBroker/ioBroker.js-controller/issues/2191
                      Thomas BraunT GaspodeG 2 Antworten Letzte Antwort
                      • FeuersturmF Feuersturm
                        @feuersturm sagte in Alpha Test js-controller 5.0:
                        Stimmt, ist bei mir auch. Ist mir nicht aufgefallen, weil ich immer ein Terminal damit beschäftigt habe, lese nämlich gerne von oben nach unten und nicht falsch herum. ;-)
                          FeuersturmF Offline
                          Feuersturm
                          @apollon77 Ist das Log update Problem ein js-controller oder admin issue?
                          Das Problem tritt erst mit der Kombination Admin 6.4.2 und js-controller 5 auf. Admin 6.4.2 und js-controller 4 ist i.O.
                            sigi234S Online
                            sigi234S Online
                            @apollon77 sagte in Alpha Test js-controller 5.0:
                            @sigi234 Kofi braucht ein installiertes git weil es eine git dependency hat. Hast du das? Bei Windows bestimmt im Pfad wo es sein muss. Ist im Standard nicht installiert.
                            Wie installiere ich das unter Windows?
                              FeuersturmF Offline
                              Feuersturm
                              Der hm-rega Adpater wirft nach dem js-controller Update Fehler vom Typ
                              "runScriptFile Error: Parameter "options" needs to be a real object but type "string" has been passed". Hab dazu mal ein issue angelegt: https://github.com/ioBroker/ioBroker.hm-rega/issues/368
                              • Thomas BraunT Online
                                @feuersturm
                                Da scheinen ein paar Adapter drunter zu fallen:
                                https://github.com/simatec/ioBroker.backitup/issues/915
                                https://github.com/DrozmotiX/ioBroker.tado/issues/618
                                  @feuersturm Bitte controller issue auf machen
                                  • sigi234S sigi234
                                    @sigi234 Vllt https://git-scm.com/download/win ?
                                      @feuersturm is: admin and admin user oder limitierter User? Bitte mit ins issue?
                                        Installation
                                        • admin -> v6.2.23+
                                        • backitup v2.6.16+
                                        • cloud v4.2.3+
                                        • discovery v3.0.6+
                                        • email v1.1.4+
                                        • history v2.2.4+
                                        • hmrega v3.0.46+
                                        • iquontrol v2.2.1+
                                        • mqtt: v4.1.1+
                                        • node-red v4.0.1+
                                        • onvif 1.0.1+
                                        • owntracks v1.0.5+
                                        • pimatic v0.3.1+
                                        • sayit v1.13.0+
                                        • smart-visu GitHub
                                        • sonos v2.3.1+
                                        • synology v2.1.13+
                                        • telegram v1.15.1+
                                        • terminal v1.0.0+
                                        • tr-064 v4.2.18+
                                        • tuya v3.7.0+
                                        • web v5.2.10+
                                        • ws -> v2.2.0+
                                        • xterm v1.1.0+
                                        • yahka - v1.0.0+
                                        Windows
                                        Linux
                                        • cd /opt/iobroker
                                        Bei Fehlern:
                                        5.0.1 Release Jana
                                        BREAKING CHANGES
                                        Features
                                        Wie Fehler melden?
                                        Ingo
                                        GaspodeG Online
                                        GaspodeG Online
                                        Gaspode
                                        schrieb am zuletzt editiert von Gaspode
                                        @apollon77
                                        Ich hab jetzt auf 3 Systemen testweise den Controller 5 installiert (Windows). Alle drei liefen vorher mit dem aktuellen Controller stabil.
                                        Ein System läuft bisher stabil, auf den beiden anderen habe ich Probleme mit dem Web Adapter:
                                        2023-03-31 09:45:05.687 - info: host.SmartHome2 iobroker npm-rebuild: exit 2147483651
                                        2023-03-31 09:45:05.713 - info: host.SmartHome2 instance system.adapter.web.0 started with pid 24788
                                        2023-03-31 09:45:07.047 - error: host.SmartHome2 Caught by controller[0]: node:internal/modules/cjs/loader:1078
                                        2023-03-31 09:45:07.047 - error: host.SmartHome2 Caught by controller[0]: throw err;
                                        2023-03-31 09:45:07.048 - error: host.SmartHome2 Caught by controller[0]: ^
                                        2023-03-31 09:45:07.048 - error: host.SmartHome2 Caught by controller[0]: Error: Cannot find module 'C:\ioBroker\_iob_SmartHome2\node_modules\iobroker.js-controller/lib/letsencrypt.js'
                                        2023-03-31 09:45:07.048 - error: host.SmartHome2 Caught by controller[0]: Require stack:
                                        2023-03-31 09:45:07.048 - error: host.SmartHome2 Caught by controller[0]: - C:\ioBroker\_iob_SmartHome2\node_modules\iobroker.web\main.js
                                        2023-03-31 09:45:07.048 - error: host.SmartHome2 Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
                                        2023-03-31 09:45:07.048 - error: host.SmartHome2 Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:920:27)
                                        2023-03-31 09:45:07.048 - error: host.SmartHome2 Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1141:19)
                                        2023-03-31 09:45:07.048 - error: host.SmartHome2 Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
                                        2023-03-31 09:45:07.048 - error: host.SmartHome2 Caught by controller[0]: at Object. (C:\ioBroker\_iob_SmartHome2\node_modules\iobroker.web\main.js:10:21)
                                        2023-03-31 09:45:07.048 - error: host.SmartHome2 Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1254:14)
                                        2023-03-31 09:45:07.049 - error: host.SmartHome2 Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
                                        2023-03-31 09:45:07.049 - error: host.SmartHome2 Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1117:32)
                                        2023-03-31 09:45:07.049 - error: host.SmartHome2 Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:958:12)
                                        2023-03-31 09:45:07.049 - error: host.SmartHome2 Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
                                        2023-03-31 09:45:07.049 - error: host.SmartHome2 Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                        2023-03-31 09:45:07.049 - error: host.SmartHome2 Caught by controller[0]: requireStack: [
                                        2023-03-31 09:45:07.049 - error: host.SmartHome2 Caught by controller[0]: 'C:\\ioBroker\\_iob_SmartHome2\\node_modules\\iobroker.web\\main.js'
                                        2023-03-31 09:45:07.049 - error: host.SmartHome2 Caught by controller[0]: ]
                                        2023-03-31 09:45:07.049 - error: host.SmartHome2 Caught by controller[0]: }
                                        2023-03-31 09:45:07.049 - error: host.SmartHome2 Caught by controller[0]: Node.js v18.15.0
                                        2023-03-31 09:45:07.049 - error: host.SmartHome2 instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2023-03-31 09:45:07.050 - info: host.SmartHome2 Adapter system.adapter.web.0 needs rebuild and will be restarted afterwards.
                                        2023-03-31 09:45:07.050 - info: host.SmartHome2 system.adapter.web.0 will be rebuilt
                                        2023-03-31 09:45:07.050 - warn: host.SmartHome2 adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                                        2023-03-31 09:45:07.050 - info: host.SmartHome2 iobroker rebuild
                                        Das wiederholt sich drei mal, dann gibt er auf.
                                        Encryption verwende ich nicht.
                                        Auf dem System, das läuft, lässt sich Kodi übrigens nicht installieren, obwohl git installiert ist (gleiche Fehlermeldung wie bei @sigi234 ). Auf einem anderen System mit Controller 4 geht das auf dem gleichen Rechner.
                                        Edit: Ach ja, Nodes.js wurde nicht verändert
                                        • GaspodeG Gaspode
                                          @apollon77
                                          @gaspode hast Du web aktualisiert wie s oben im ersten Post steht? Brauchst ne minimum Web version ....
                                          GaspodeG 1 Antwort Letzte Antwort
