  3. Off Topic
  4. Gelöst - Grafana und InfluxDB auf RPI3 ?
    6.1k
37 Beiträge 5 Kommentatoren 4.9k Aufrufe 4 Beobachtet
    @knopers1
    iob diag
    in der Langfassung sagt?
    knopers1
    @thomas-braun said in Grafana und InfluxDB auf RPI3 ?:
    @knopers1
    iob diag
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 3 Model B Rev 1.2
    Architecture:   armv7l
    Docker:         false
    Virtualization: none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     15:08:27 up 23 min,  3 users,  load average: 0.31, 0.30, 0.33
    CPU threads: 4
    *** Time and Time Zones ***
    Wed Mar 22 14:08:27 UTC 2023
    Wed Mar 22 15:08:27 CET 2023
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            921M        369M        121M        3.0M        431M        498M
    Swap:            99M        2.0M         97M
    Total:          1.0G        371M        218M
              921 M total memory
              369 M used memory
              661 M active memory
               70 M inactive memory
              121 M free memory
                3 M buffer memory
              428 M swap cache
               99 M total swap
                2 M used swap
               97 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       29G  4.7G   24G  17% /
    devtmpfs       devtmpfs  333M     0  333M   0% /dev
    tmpfs          tmpfs     461M     0  461M   0% /dev/shm
    tmpfs          tmpfs     185M  1.1M  184M   1% /run
    /dev/sda1      vfat      255M   51M  205M  20% /boot
    tmpfs          tmpfs      93M   20K   93M   1% /run/user/1000
    Messages in dmesg:
    [Wed Mar 22 14:45:23 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=be83d968-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Wed Mar 22 14:45:32 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Mar 22 14:45:32 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Wed Mar 22 14:45:34 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    647M    /var/
    330M    /var/cache
    324M    /var/cache/apt
    259M    /var/cache/apt/archives
    126M    /var/lib
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    44M     /opt/iobroker/iobroker-data/
    15M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    25M     /opt/iobroker/iobroker-data/objects.jsonl
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    2.6M    /opt/iobroker/iobroker-data/states.jsonl
    2.3M    /opt/iobroker/iobroker-data/backup-objects/2023-03-21_23-47_objects.jsonl.gz
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.1
    /usr/bin/node           v16.19.1
    /usr/bin/npm            8.19.3
    /usr/bin/npx            8.19.3
    nodejs:
      Installed: 16.19.1-deb-1nodesource1
      Candidate: 16.19.1-deb-1nodesource1
      Version table:
     *** 16.19.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u3 500
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.7
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : Vis2                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : Vis2                                     -  enabled
    + system.adapter.discovery.0              : discovery             : Vis2                                     -  enabled
    + system.adapter.influxdb.0               : influxdb              : Vis2                                     -  enabled, port: 8086
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.3.7    , installed 6.3.7
    Adapter    "backitup"     : 2.6.13   , installed 2.6.12 [Updatable]
    Objects and States
    Objects:        163
    States:         121
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://repos.influxdata.com/debian stable InRelease
    Hit:4 https://repos.influxdata.com/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:6 https://packages.grafana.com/oss/deb stable InRelease
    Reading package lists...
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        15374      542/influxd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14461      567/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15130      722/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15060      722/iobroker.js-con
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13935      534/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14463      567/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13934      534/cupsd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17106      1314/io.admin.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      116        14159      542/influxd
    tcp6       0      0 :::3000                 :::*                    LISTEN      117        16383      536/grafana
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          627        487/dhcpcd
    udp        0      0 0.0.0.0:37990           0.0.0.0:*                           108        505        393/avahi-daemon: r
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13953      591/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        503        393/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        504        393/avahi-daemon: r
    udp6       0      0 :::44863                :::*                                108        506        393/avahi-daemon: r
    2023-03-22 00:39:52.934  - info: host.Vis2 instance system.adapter.admin.0 started with pid 1314
    2023-03-22 00:39:52.966  - info: host.Vis2 Delete state "system.host.Vis2.versions.nodeNewest"
    2023-03-22 00:39:53.058  - info: host.Vis2 Delete state "system.host.Vis2.versions.nodeNewestNext"
    2023-03-22 00:39:53.088  - info: host.Vis2 Delete state "system.host.Vis2.versions.npmCurrent"
    2023-03-22 00:39:53.125  - info: host.Vis2 Delete state "system.host.Vis2.versions.npmNewest"
    2023-03-22 00:39:53.161  - info: host.Vis2 Delete state "system.host.Vis2.versions.npmNewestNext"
    2023-03-22 00:39:53.194  - info: host.Vis2 Some obsolete host states deleted.
    2023-03-22 14:46:11.054  - info: host.Vis2 instance system.adapter.influxdb.0 started with pid 1421
    2023-03-22 14:46:12.443  - info: admin.0 (1314) starting. Version 6.3.7 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.1, js-controller: 4.0.24
    2023-03-22 14:46:12.535  - info: admin.0 (1314) requesting all states
    2023-03-22 14:46:12.537  - info: admin.0 (1314) requesting all objects
    2023-03-22 14:46:15.143  - info: admin.0 (1314) received all objects
    2023-03-22 14:46:15.178  - info: host.Vis2 instance system.adapter.discovery.0 started with pid 1448
    2023-03-22 14:46:17.836  - info: admin.0 (1314) http server listening on port 8081
    2023-03-22 14:46:17.854  - info: admin.0 (1314) Use link "http://localhost:8081" to configure.
    2023-03-22 14:46:17.904  - info: admin.0 (1314) socket.io server listening on port 8081
    2023-03-22 14:46:19.047  - info: host.Vis2 instance system.adapter.backitup.0 started with pid 1466
    2023-03-22 14:46:19.367  - info: influxdb.0 (1421) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.influxdb, node: v16.19.1, js-controller: 4.0.24
    2023-03-22 14:46:19.434  - info: influxdb.0 (1421) No stored data from last exit found
    2023-03-22 14:46:19.438  - info: influxdb.0 (1421) Connecting http://192.168.1.97:8086/ ...
    2023-03-22 14:46:19.440  - info: influxdb.0 (1421) Influx DB Version used: 1.x
    2023-03-22 14:46:19.590  - info: influxdb.0 (1421) enabled logging of influxdb.0.info.connection, Alias=false, 1 points now activated
    2023-03-22 14:46:21.764  - info: discovery.0 (1448) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.19.1, js-controller: 4.0.24
    2023-03-22 14:46:23.713  - info: backitup.0 (1466) starting. Version 2.6.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.1, js-controller: 4.0.24
    2023-03-22 14:46:23.975  - info: backitup.0 (1466) [iobroker] backup was activated at 02:40 every 1 day(s)
    iob diag has finished.
    Press any key for a summary
    pi@Vis2:~ $
    • Marc BergM Marc Berg
      @knopers1 sagte in Grafana und InfluxDB auf RPI3 ?:
      influxdb.conf
      Du hast eine InfluxDB 1.x installiert. Da gibt es kein Webinterface mehr. Wenn du das haben willst, musst du 2.x installieren.
      knopers1
      @marc-berg said in Grafana und InfluxDB auf RPI3 ?:
      influxdb.conf
      ja, wird wohl so sein..... Ich poste gleich mal die Fehlermeldung!
      • K knopers1
        influxdb.conf
        Das kann auch nicht anders sein, weil du da ein 32bit-System fährst.
        influxdb2 wird nur für 64bit-Systeme gebaut.
        Und mit 1GB RAM würde ich da auch keinen Speicher für sowas unnötiges wie einen Desktop verschwenden, das kannst du sinnvoller für den Betrieb der Serverdienste verwenden.
          knopers1
          Danke Dir. Wollte nur kurz antesten falls es gehen sollte...
          Versuche gerade InfluDB zu konfigurireren... Anscheinend habe ich doch keinen User und Datenbank anlegen können.
          pi@Vis2:~ $ sudo nano /etc/influxdb/influxdb.conf
          pi@Vis2:~ $ sudo service influxdb restart
          pi@Vis2:~ $ influx
          Connected to http://localhost:8086 version 1.8.10
          InfluxDB shell version: 1.8.10
          > CREATE USER "admin" WITH PASSWORD 'admin' WITH ALL PRIVILEGES
          ERR: unable to parse authentication credentials
          Warning: It is possible this error is due to not setting a database.
          Please set a database with the command "use <database>".
          • Marc BergM Offline
            Marc BergM Offline
            Marc Berg
            du hast vergessen "use iobroker" einzugeben und damit die aktive Datenbank festzulegen.
              knopers1
              schrieb am zuletzt editiert von knopers1
              @marc-berg
              jetzt läuft es 😊
              musste vorher aus: /var/lib - den Ordner Influxdb löschen, danach ging auch die user und Datenbank nach meiner Beschreibung zu setzen.
              pi@Vis2:~ $ free
              Mem:          944092      415208      189532        3644      339352      481720
              Swap:         102396        1808      100588
              pi@Vis2:~ $
              • K knopers1
                @marc-berg
                jetzt läuft es 😊
                pi@Vis2:~ $ free
                pi@Vis2:~ $
                Im Normalfall muss nie manuell in /var/lib herumgeorgelt werden. Das sind Verzeichnisse, die vom System verwaltet werden. Gemeinhin reicht es hier mit normalen usern, die mit ordentlichen Rechten ausgestattet sind, zu agieren.
                  knopers1
                  danke Thomas, das ist wahr...
                  Durch meine "Installationsversuche" nach drei verschiedenen Beschreibungen hat sich dort Müll anscheinend angesammelt! Das Löschen des InfluxDB über Putty hat die Ordner dort nicht mitgelöscht.
                  Erst nachdem ich den ganzen Ordner selbst gelöscht hatte und die InfluxDB neu installiert habe, konnte ich die Datenbank erzeugen und die User eintragen. Jetzt ist alles verbunden. Jetzt fehlen mir paar Datenpunkte zum Spielen.
                  Kannst Du mir sagen, ob ich aus dem RPI3 einen Slave mit wenig Aufwand machen kann?
                  So könnte ich doch auf die Datenpunkte des RPI4 zugreifen? Stimmt es?
                  Thomas BraunT wendy2702W 3 Antworten Letzte Antwort
                  • K knopers1
                    Was soll denn 'über Putty' bedeuten? puTTY ist ein Terminal, darüber gibt man Kommandos ein. Die Frage ist dann immer, welche Kommandos.
                    • K knopers1
                      wendy2702W Offline
                      wendy2702W Offline
                      Dein Hauptsystem läuft auf dem PI4, richtig?
                      PI3, soll mit Grafana und Influx laufen.
                      Wenn ja, muss der PI3 kein Slave werden.
                      Du musst im Influx Adapter lediglich die IP usw. vom InFlux Server (PI3) eintragen.
                      IOB muss dafür nicht zusätzlich auf dem PI3 laufen.
                      • wendy2702W wendy2702
                        knopers1
                        @wendy2702
                        woow, Danke!
                        ja, RPI4 ist mein Hauptsystem!
                        das heist, ich muß erst Influx Adapter auf den RPI4 installieren stimmt?
                        Jetzt läuft Influx Adapter auf dem RPI3.
                        • K knopers1
                          @wendy2702
                          woow, Danke!
                          wendy2702W Offline
                          wendy2702W Offline
                          @knopers1 Da die Installation des PI3 ja eh etwas verbogen war, installiere das OS neu, dann nur Influx und Grafana.
                          Dann auf dem PI4 den Influx Adapter und den entsprechend Konfigurieren.
                          Dann schreibt iob schön seine Daten in die InfluxDB.
                          K 2 Antworten Letzte Antwort
                            knopers1
                            @wendy2702
                            super Idee, Danke....
                            ich berichte wenn dies geklappt hat!
                            • K knopers1
                              Zusätzliche Softwarepakete werden unter Linux/Debian ausschließlich über den Paketmanager installiert. Gibt ja nicht ohne Grund für influx und grafana passende Quellen
                                wendy2702W Offline
                                wendy2702W Offline
                                @thomas-braun Vielleicht schreibst du dafür bei Zeiten und ausreichender Langeweile sowie Motivation auch ein "How To" ;-)
                                  @wendy2702
                                  Naja, geht grundsätzlich so wie im Nodejs-HowTo auch mit Quellen hantiert wird.
                                  Die kleinen Unterschiede sind immer bei den Projekten zu finden. Aber eigentlich ist es immer gleich: Per Skript wird in /etc/apt/sources.list.d/ eine .list-Datei angelegt und nach einem sudo apt update liegt das Paket im Regal und muss nur noch aufgeklaubt werden. Viele Pakete sind aber ja auch schon direkt 'ab Werk' in den debian-Repos zu finden.
                                  Selbst influx könnte man da sofort schon finden, allerdings Debian-typisch in einer gut abgehangenen, durchgetesteten Version.
                                    knopers1
                                    @wendy2702
                                    Super, auf dem RPI4 kann ich jetzt in die Datenbank schreiben.
                                    Jetzt zu meinem Verständnis. Die Grafana Grafiken müsste ich am RPI3 erstellen, dort ist auch Grafana installiert. Bekomme ich dort erzeugte Grafik wieder auf dem RPI4 angebunden?
                                    • K knopers1
                                      @wendy2702
                                      wendy2702W Offline
                                      wendy2702W Offline
                                      @knopers1 Ja. Grafana Dashbords können z.B. in VIS etc eingebunden werden. Egal auf welcher Maschine die laufen.
                                      Wichtig ist das die Grafana.ini entsprechend angepasst ist.
                                      So sollte es klappen:
                                      [security]
                                      allow_embedding = true
                                      [auth.anonymous]
                                      enabled = true
                                      org_name = Main Org.
                                      org_role = Viewer
                                      [users]
                                      allow_sign_up = false
                                      Gibt es hier im Forum einige Threads mit hinweisen.
                                        [security]
                                        [auth.anonymous]
                                        enabled = true
                                        org_role = Viewer
                                        [users]
                                        knopers1
                                        @wendy2702
                                        Danke Dir! Die grafana.ini ist angepasst.
                                        habe jetzt das 64 Bit System Lite Debian installiert. Das System läuft vollständig auf einer SSD.
                                        pi@Vis2:~ $ free
                                        Mem:          931432      152464      540216         988      238752      724660
                                        Swap:         102396           0      102396
                                        pi@Vis2:~ $
                                        RAM ist noch genug da :) Grafana und InfluxDB installiert und läuft! 👍
                                        Jetzt logge ich morgen ein paar Daten meiner Solaranlagen und versuche etwas zu basteln!
                                        Besten Dank vorab für deine Hilfe.
                                        • K knopers1
                                          @wendy2702
                                          pi@Vis2:~ $ free
                                          pi@Vis2:~ $
                                          wendy2702W Offline
                                          wendy2702W Offline
                                          @knopers1 Wenn für dich OK, dann editiere doch bitte deinen Ersten Beitrag und setze ein [Gelöst] vor den Titel.
