  4. Web-Adapter stürzt ab
    5.5k
30 Beiträge 5 Kommentatoren 2.9k Aufrufe 4 Beobachtet
  • OliverIOO OliverIO
    @djsirius
    dann schau mal in die browser console.
    In Edge/Chrome/Firefox kannst du die mit F12 öffnen und dann im Tab Console bei den Fehlern schauen.
    Sag mir auch mal noch deine Versionsnummer des Openliga-Adapters
    djsirius
    @oliverio Version 1.2.4
    djsirius
    • D djsirius
      @oliverio
      Kannst du damit was anfangen?
      vis-editor.css:1          GET http://192.168.1.16:8082/vis/icon/dimmer.png 404 (Not Found)
      pivottable.png:1          GET http://192.168.1.16:8082/vis/widgets/openligadb/img/pivottable.png 404 (Not Found)
      Image (async)
      buildFragment @ jquery-1.11.2.min.js:3
      domManip @ jquery-1.11.2.min.js:3
      t.fn.domManip @ can.custom.min.js:28
      append @ jquery-1.11.2.min.js:3
      (anonymous) @ visEdit.js:2430
      each @ jquery-1.11.2.min.js:2
      editInitWidgetPreview @ visEdit.js:2415
      editInitNext @ visEdit.js:2940
      initNext @ vis.js:715
      (anonymous) @ vis.js:610
      loadWidgetSets @ vis.js:575
      init @ vis.js:609
      (anonymous) @ vis.js:3609
      (anonymous) @ conn.js:1350
      SocketClient.findAnswer @ socket.io.js:294
      socket.onmessage @ socket.io.js:202
      promisebuffer.ts:24 View:w01237, id: undefined not found
      (anonymous) @ promisebuffer.ts:24
      bindWidgetClick @ visEdit.js:3867
      multiselect @ edit.html?VIS3:9763
      eval @ tplJquiSelectList.js:57
      sentryWrapped @ helpers.ts:124
      promisebuffer.ts:24 [2023-03-22T11:46:27.884Z] ws connection error: CLOSE_ABNORMAL
      (anonymous) @ captureconsole.ts:16
      error @ socket.io.js:68
      socket.onclose @ socket.io.js:167
      promisebuffer.ts:24 [2023-03-22T11:46:27.889Z] Start reconnect 0
      promisebuffer.ts:24 [2023-03-22T11:46:27.890Z] Try to connect
      socket.io.js:130 WebSocket connection to 'ws://192.168.1.16:8082/?sid=1679485587890&' failed:
      SocketClient.connect @ socket.io.js:130
      (anonymous) @ socket.io.js:414
      promisebuffer.ts:24 [2023-03-22T11:46:30.105Z] Start reconnect 1
      promisebuffer.ts:24 [2023-03-22T11:46:30.106Z] ws connection error: CLOSE_ABNORMAL
      promisebuffer.ts:24 [2023-03-22T11:46:30.111Z] Reconnect is already running 1
      promisebuffer.ts:24 [2023-03-22T11:46:31.118Z] Try to connect
      socket.io.js:130 WebSocket connection to 'ws://192.168.1.16:8082/?sid=1679485591118&' failed:
      promisebuffer.ts:24 [2023-03-22T11:46:33.314Z] Start reconnect 2
      promisebuffer.ts:24 [2023-03-22T11:46:33.314Z] ws connection error: CLOSE_ABNORMAL
      promisebuffer.ts:24 [2023-03-22T11:46:33.317Z] Reconnect is already running 2
      promisebuffer.ts:24 [2023-03-22T11:46:35.321Z] Try to connect
      socket.io.js:130 WebSocket connection to 'ws://192.168.1.16:8082/?sid=1679485595321&' failed:
      promisebuffer.ts:24 [2023-03-22T11:46:37.526Z] Start reconnect 3
      promisebuffer.ts:24 [2023-03-22T11:46:37.526Z] ws connection error: CLOSE_ABNORMAL
      promisebuffer.ts:24 [2023-03-22T11:46:37.528Z] Reconnect is already running 3
      promisebuffer.ts:24 Trying connect...
      promisebuffer.ts:24 [2023-03-22T11:46:37.899Z] Try to connect
      socket.io.js:130 WebSocket connection to 'ws://192.168.1.16:8082/?sid=1679485597899&' failed:
      (anonymous) @ conn.js:158
      promisebuffer.ts:24 [2023-03-22T11:46:40.103Z] Start reconnect 3
      promisebuffer.ts:24 [2023-03-22T11:46:40.104Z] ws connection error: CLOSE_ABNORMAL
      promisebuffer.ts:24 [2023-03-22T11:46:40.106Z] Reconnect is already running 3
      promisebuffer.ts:24 [2023-03-22T11:46:43.108Z] Try to connect
      socket.io.js:130 WebSocket connection to 'ws://192.168.1.16:8082/?sid=1679485603109&' failed:
      promisebuffer.ts:24 [2023-03-22T11:46:45.281Z] Start reconnect 4
      promisebuffer.ts:24 [2023-03-22T11:46:45.281Z] ws connection error: CLOSE_ABNORMAL
      promisebuffer.ts:24 [2023-03-22T11:46:45.285Z] Reconnect is already running 4
      promisebuffer.ts:24 [2023-03-22T11:46:47.906Z] Try to connect
      socket.io.js:130 WebSocket connection to 'ws://192.168.1.16:8082/?sid=1679485607907&' failed:
      promisebuffer.ts:24 [2023-03-22T11:46:50.087Z] Start reconnect 4
      promisebuffer.ts:24 [2023-03-22T11:46:50.088Z] ws connection error: CLOSE_ABNORMAL
      promisebuffer.ts:24 [2023-03-22T11:46:50.091Z] Reconnect is already running 4
      CodierknechtC Offline
      Codierknecht
      @djsirius
      Zeig mal die Einstellungen des Web-Adapters
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      • CodierknechtC Codierknecht
        @djsirius
        djsirius
        schrieb am zuletzt editiert von djsirius
        @codierknecht
        djsirius
        • D djsirius
          @codierknecht
          Codierknecht
          @djsirius
          Die HAUPTEINSTELLUNGEN bitte ...
            @djsirius
            djsirius
            @codierknecht Sorry, da hat was nicht geklappt. Jetzt müsste das Bild da sein!
            djsirius
            • D djsirius
              Codierknecht
              @djsirius
              Hast Du mal testweise den Haken bei "Reine Websockets" rausgenommen?
                @djsirius
                djsirius
                @codierknecht Wenn ich den Haken raus nehme, dann dauert alles 10 mal so lange. Und ich bekomme in VIS immer no connection angezeigt. Der Web Adapter stürzt dann aber tatsächlich nicht ab.
                djsirius
                CodierknechtC OliverIOO 2 Antworten Letzte Antwort
                • D djsirius
                  Codierknecht
                  @djsirius
                  Dann solltest Du ja jetzt das fragwürdige Widget entfernen können ... und danach den Haken wieder setzen.
                  Ro75R D 2 Antworten Letzte Antwort
                    @djsirius
                    Ro75R Offline
                    Ro75R Offline
                    Ro75
                    @codierknecht Das geht ja leider nicht wegen "no connection".
                      @djsirius
                      djsirius
                      @codierknecht So hab´s mal getestet. VIS speichert meine Änderungen nicht ab. Und wenn ich die Seite über den Browser anzeigen lasse, dann stürzt der Web Adapter auch ab
                      djsirius
                      Ro75R 1 Antwort Letzte Antwort
                      • D djsirius
                        Ro75R Offline
                        Ro75R Offline
                        Ro75
                        schrieb am zuletzt editiert von Ro75
                        @djsirius also beim einen gibt es einen Absturz und bei der anderen Variante wird nix gespeichert.
                        ICH würde jetzt folgendes versuchen:
                        1. ioBroker beenden
                        2. Eine Kopie von der Datei "vis-views.json" im Verzeichnis "/opt/iobroker/iobroker-data/files/vis.0/main" erstellen.
                        3. Die Datei "vis-views.json" bearbeiten. Dort nach der View suchen und dann das betreffende Widget per Hand löschen.
                        Einsatz auf eigenes Risiko.
                        • Ro75R Ro75
                          1. ioBroker beenden
                          Codierknecht
                          @ro75
                          Wenn es denn tatsächlich an dem Widget liegen sollte, wäre das auch mein Vorschlag.
                          Das mit dem "no connection" wundert mich allerdings etwas. Bei mir läuft die Vis mit diesen Einstellungen völlig problemlos:
                          Und zwar sowohl mit als auch ohne "Reine Websockets"
                            @ro75
                            Ro75R Offline
                            Ro75R Offline
                            Ro75
                            @codierknecht Bei mir muss ebenfalls unten das Häkchen rein, sonst auch "no connection".
                            • D djsirius
                              OliverIOO Offline
                              OliverIOO Offline
                              OliverIO
                              @djsirius sagte in Web-Adapter stürzt ab:
                              dann würde ich gern nochmal die browser konsole sehen, wenn das häkchen da nicht gesetzt ist um zu sehen, warum es dann 10x solange dauert.
                              im bisherigen log habe ich nur ne menge fehler zur websocket verbindung gesehen, aber noch nix mit einem konkreten widget
                              Meine Adapter und Widgets
                              Links im Profil
                                djsirius
                                @oliverio
                                So, ich habe jetzt die Anzeige unten rechts entfernt, und nun stürzt auch nichts mehr ab.
                                Woran das jetzt lag, keine Ahnung. Ich habe noch gesehen, dass da noch veraltete Datenpunkte hinterlegt waren.
                                "allmatches_oid1": "openligadb.0.bl1.2021.allmatches",
                                                "showgamedaycount1": "9",
                                                "currgameday_oid1": "openligadb.0.bl1.2021.currgameday",
                                                "showabbreviation": true,
                                                "abbreviation1": "BL",
                                                "highlight1": "Köln",
                                                "showresult": true,
                                                "showweekday": false,
                                                "allmatches_oid3": "openligadb.0.dfb2021.2021.allmatches",
                                Kann es daran gelegen haben???
                                djsirius
                                • D djsirius
                                  @oliverio
                                                  "showresult": true,
                                  djsirius
                                  @OliverIO es liegt definitiv an folgendem Widget, ich hab es nochmal getestet. Sobald ich dieses Widget im VIS Editor reinziehe, stürzt direkt der Web Adapter ab.
                                  Die Frage ist halt, ob nur ich das Problem habe?
                                  djsirius
                                  • D djsirius
                                    OliverIOO Offline
                                    OliverIOO Offline
                                    OliverIO
                                    @djsirius
                                    kann evtl auch am widget, also an mir liegen.
                                    wir hatten schon mal sowas ähnliches in einem anderen adapter.
                                    ich schaue mal
                                    Links im Profil
